path: root/net/core/ethtool.c
2013-11-07net: Add layer 2 hardware acceleration operations for macvlan devicesJohn Fastabend
Add a operations structure that allows a network interface to export the fact that it supports package forwarding in hardware between physical interfaces and other mac layer devices assigned to it (such as macvlans). This operaions structure can be used by virtual mac devices to bypass software switching so that forwarding can be done in hardware more efficiently. Signed-off-by: John Fastabend <john.r.fastabend@intel.com> Signed-off-by: Neil Horman <nhorman@tuxdriver.com> CC: Andy Gospodarek <andy@greyhouse.net> CC: "David S. Miller" <davem@davemloft.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-10-21ipv6: sit: add GSO/TSO supportEric Dumazet
Now ipv6_gso_segment() is stackable, its relatively easy to implement GSO/TSO support for SIT tunnels Performance results, when segmentation is done after tunnel device (as no NIC is yet enabled for TSO SIT support) : Before patch : lpq84:~# ./netperf -H 2002:af6:1153:: -Cc MIGRATED TCP STREAM TEST from ::0 (::) port 0 AF_INET6 to 2002:af6:1153:: () port 0 AF_INET6 Recv Send Send Utilization Service Demand Socket Socket Message Elapsed Send Recv Send Recv Size Size Size Time Throughput local remote local remote bytes bytes bytes secs. 10^6bits/s % S % S us/KB us/KB 87380 16384 16384 10.00 3168.31 4.81 4.64 2.988 2.877 After patch : lpq84:~# ./netperf -H 2002:af6:1153:: -Cc MIGRATED TCP STREAM TEST from ::0 (::) port 0 AF_INET6 to 2002:af6:1153:: () port 0 AF_INET6 Recv Send Send Utilization Service Demand Socket Socket Message Elapsed Send Recv Send Recv Size Size Size Time Throughput local remote local remote bytes bytes bytes secs. 10^6bits/s % S % S us/KB us/KB 87380 16384 16384 10.00 5525.00 7.76 5.17 2.763 1.840 Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-10-19ipip: add GSO/TSO supportEric Dumazet
Now inet_gso_segment() is stackable, its relatively easy to implement GSO/TSO support for IPIP Performance results, when segmentation is done after tunnel device (as no NIC is yet enabled for TSO IPIP support) : Before patch : lpq83:~# ./netperf -H 7.7.9.84 -Cc MIGRATED TCP STREAM TEST from 0.0.0.0 (0.0.0.0) port 0 AF_INET to 7.7.9.84 () port 0 AF_INET Recv Send Send Utilization Service Demand Socket Socket Message Elapsed Send Recv Send Recv Size Size Size Time Throughput local remote local remote bytes bytes bytes secs. 10^6bits/s % S % S us/KB us/KB 87380 16384 16384 10.00 3357.88 5.09 3.70 2.983 2.167 After patch : lpq83:~# ./netperf -H 7.7.9.84 -Cc MIGRATED TCP STREAM TEST from 0.0.0.0 (0.0.0.0) port 0 AF_INET to 7.7.9.84 () port 0 AF_INET Recv Send Send Utilization Service Demand Socket Socket Message Elapsed Send Recv Send Recv Size Size Size Time Throughput local remote local remote bytes bytes bytes secs. 10^6bits/s % S % S us/KB us/KB 87380 16384 16384 10.00 7710.19 4.52 6.62 1.152 1.687 Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-07-16ethtool: fixed trailing statements in ethtoolDragos Foianu
Applied fixes suggested by checkpatch.pl. Signed-off-by: Dragos Foianu <dragos.foianu@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-07-02ethtool: make .get_dump_data() harder to misuse by driversMichal Schmidt
As the patch "bnx2x: remove zeroing of dump data buffer" showed, it is too easy implement .get_dump_data incorrectly in a driver. Let's make sure drivers cannot get confused by userspace requesting a too big dump. Also WARN if the driver sets dump->len to something weird and make sure the length reported to userspace is the actual length of data copied to userspace. Signed-off-by: Michal Schmidt <mschmidt@redhat.com> Reviewed-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-06-19Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/wireless/ath/ath9k/Kconfig drivers/net/xen-netback/netback.c net/batman-adv/bat_iv_ogm.c net/wireless/nl80211.c The ath9k Kconfig conflict was a change of a Kconfig option name right next to the deletion of another option. The xen-netback conflict was overlapping changes involving the handling of the notify list in xen_netbk_rx_action(). Batman conflict resolution provided by Antonio Quartulli, basically keep everything in both conflict hunks. The nl80211 conflict is a little more involved. In 'net' we added a dynamic memory allocation to nl80211_dump_wiphy() to fix a race that Linus reported. Meanwhile in 'net-next' the handlers were converted to use pre and post doit handlers which use a flag to determine whether to hold the RTNL mutex around the operation. However, the dump handlers to not use this logic. Instead they have to explicitly do the locking. There were apparent bugs in the conversion of nl80211_dump_wiphy() in that we were not dropping the RTNL mutex in all the return paths, and it seems we very much should be doing so. So I fixed that whilst handling the overlapping changes. To simplify the initial returns, I take the RTNL mutex after we try to allocate 'tb'. Signed-off-by: David S. Miller <davem@davemloft.net>
2013-06-17vlan: restore ethtool ABI to control VLAN hardware accelerationFernando Luis Vazquez Cao
As part of the push to add 802.1ad server provider tagging support to the kernel the VLAN features flags were renamed. Unfortunately the kernel name for the VLAN hardware acceleration features that the kernel shows user space was included in the rename, which broke ethtool (txvlan and rxvlan options do not work). This patch restores the original names, i.e. the original ABI. If we wanted to make clear to users that we are refering to CTAGs we can always change ethtool's short_name and long_name for these features (for example something along the lines of txvlan -> txvlan-ctag, tx-vlan-offload -> tx-vlan-ctag-offload). Cc: Patrick McHardy <kaber@trash.net> Cc: David S. Miller <davem@davemloft.net> Cc: netdev@vger.kernel.org Signed-off-by: Fernando Luis Vazquez Cao <fernando@oss.ntt.co.jp> Reviewed-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-06-04net/ethtool: Fix comment regarding location of dev_ethtool() callYan Burman
Signed-off-by: Yan Burman <yanb@mellanox.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-27MPLS: Add limited GSO supportSimon Horman
In the case where a non-MPLS packet is received and an MPLS stack is added it may well be the case that the original skb is GSO but the NIC used for transmit does not support GSO of MPLS packets. The aim of this code is to provide GSO in software for MPLS packets whose skbs are GSO. SKB Usage: When an implementation adds an MPLS stack to a non-MPLS packet it should do the following to skb metadata: * Set skb->inner_protocol to the old non-MPLS ethertype of the packet. skb->inner_protocol is added by this patch. * Set skb->protocol to the new MPLS ethertype of the packet. * Set skb->network_header to correspond to the end of the L3 header, including the MPLS label stack. I have posted a patch, "[PATCH v3.29] datapath: Add basic MPLS support to kernel" which adds MPLS support to the kernel datapath of Open vSwtich. That patch sets the above requirements in datapath/actions.c:push_mpls() and was used to exercise this code. The datapath patch is against the Open vSwtich tree but it is intended that it be added to the Open vSwtich code present in the mainline Linux kernel at some point. Features: I believe that the approach that I have taken is at least partially consistent with the handling of other protocols. Jesse, I understand that you have some ideas here. I am more than happy to change my implementation. This patch adds dev->mpls_features which may be used by devices to advertise features supported for MPLS packets. A new NETIF_F_MPLS_GSO feature is added for devices which support hardware MPLS GSO offload. Currently no devices support this and MPLS GSO always falls back to software. Alternate Implementation: One possible alternate implementation is to teach netif_skb_features() and skb_network_protocol() about MPLS, in a similar way to their understanding of VLANs. I believe this would avoid the need for net/mpls/mpls_gso.c and in particular the calls to __skb_push() and __skb_push() in mpls_gso_segment(). I have decided on the implementation in this patch as it should not introduce any overhead in the case where mpls_gso is not compiled into the kernel or inserted as a module. MPLS GSO suggested by Jesse Gross. Based in part on "v4 GRE: Add TCP segmentation offload for GRE" by Pravin B Shelar. Cc: Jesse Gross <jesse@nicira.com> Cc: Pravin B Shelar <pshelar@nicira.com> Signed-off-by: Simon Horman <horms@verge.net.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-02net: vlan,ethtool: netdev_features_t is more than 32 bitBjørn Mork
Signed-off-by: Bjørn Mork <bjorn@mork.no> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-19net: Add missing netdev feature strings for NETIF_F_HW_VLAN_STAG_*David S. Miller
Noticed by Ben Hutchings. Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-19net: vlan: rename NETIF_F_HW_VLAN_* feature flags to NETIF_F_HW_VLAN_CTAG_*Patrick McHardy
Rename the hardware VLAN acceleration features to include "CTAG" to indicate that they only support CTAGs. Follow up patches will introduce 802.1ad server provider tagging (STAGs) and require the distinction for hardware not supporting acclerating both. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-09tunneling: Add generic Tunnel segmentation.Pravin B Shelar
Adds generic tunneling offloading support for IPv4-UDP based tunnels. GSO type is added to request this offload for a skb. netdev feature NETIF_F_UDP_TUNNEL is added for hardware offloaded udp-tunnel support. Currently no device supports this feature, software offload is used. This can be used by tunneling protocols like VXLAN. CC: Jesse Gross <jesse@nicira.com> Signed-off-by: Pravin B Shelar <pshelar@nicira.com> Acked-by: Stephen Hemminger <stephen@networkplumber.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-15v4 GRE: Add TCP segmentation offload for GREPravin B Shelar
Following patch adds GRE protocol offload handler so that skb_gso_segment() can segment GRE packets. SKB GSO CB is added to keep track of total header length so that skb_segment can push entire header. e.g. in case of GRE, skb_segment need to push inner and outer headers to every segment. New NETIF_F_GRE_GSO feature is added for devices which support HW GRE TSO offload. Currently none of devices support it therefore GRE GSO always fall backs to software GSO. [ Compute pkt_len before ip_local_out() invocation. -DaveM ] Signed-off-by: Pravin B Shelar <pshelar@nicira.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-01-07ethtool: consolidate work with ethtool_opsJiri Pirko
No need to check if ethtool_ops == NULL since it can't be. Use local variable "ops" in functions where it is present instead of dev->ethtool_ops Introduce local variable "ops" in functions where dev->ethtool_ops is used many times. Signed-off-by: Jiri Pirko <jiri@resnulli.us> Reviewed-by: Ben Hutchings <bhutchings@solarflare.com> Reviewed-by: Flavio Leitner <fbl@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-18net: Allow userns root control of the core of the network stack.Eric W. Biederman
Allow an unpriviled user who has created a user namespace, and then created a network namespace to effectively use the new network namespace, by reducing capable(CAP_NET_ADMIN) and capable(CAP_NET_RAW) calls to be ns_capable(net->user_ns, CAP_NET_ADMIN), or capable(net->user_ns, CAP_NET_RAW) calls. Settings that merely control a single network device are allowed. Either the network device is a logical network device where restrictions make no difference or the network device is hardware NIC that has been explicity moved from the initial network namespace. In general policy and network stack state changes are allowed while resource control is left unchanged. Allow ethtool ioctls. Allow binding to network devices. Allow setting the socket mark. Allow setting the socket priority. Allow setting the network device alias via sysfs. Allow setting the mtu via sysfs. Allow changing the network device flags via sysfs. Allow setting the network device group via sysfs. Allow the following network device ioctls. SIOCGMIIPHY SIOCGMIIREG SIOCSIFNAME SIOCSIFFLAGS SIOCSIFMETRIC SIOCSIFMTU SIOCSIFHWADDR SIOCSIFSLAVE SIOCADDMULTI SIOCDELMULTI SIOCSIFHWBROADCAST SIOCSMIIREG SIOCBONDENSLAVE SIOCBONDRELEASE SIOCBONDSETHWADDR SIOCBONDCHANGEACTIVE SIOCBRADDIF SIOCBRDELIF SIOCSHWTSTAMP Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-19net: provide a default dev->ethtool_opsEric Dumazet
Instead of forcing device drivers to provide empty ethtool_ops or tweak net/core/ethtool.c again, we could provide a generic ethtool_ops. This occurred to me when I wanted to add GSO support to GRE tunnels. ethtool -k support should be generic for all drivers. Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Ben Hutchings <bhutchings@solarflare.com> Cc: Maciej Żenczykowski <maze@google.com> Reviewed-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-06-12ethtool: Make more commands available to unprivileged processesBen Hutchings
'Get' commands should generally not require CAP_NET_ADMIN, with the exception of those that expose internal state. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-06-07Added kernel support in EEE Ethtool commandsYuval Mintz
This patch extends the kernel's ethtool interface by adding support for 2 new EEE commands - get_eee and set_eee. Thanks goes to Giuseppe Cavallaro for his original patch adding this support. Signed-off-by: Yuval Mintz <yuvalmin@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Reviewed-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-05-10ethtool: Extend the ethtool API to obtain plugin module eeprom dataStuart Hodgson
ETHTOOL_GMODULEINFO returns a new struct ethtool_modinfo that will return the type and size of plug-in module eeprom (such as SFP+) for parsing by userland program. ETHTOOL_GMODULEEEPROM returns the raw eeprom information using the existing ethtool_eeprom structture to return the data Signed-off-by: Stuart Hodgson <smhodgson@solarflare.com> Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
2012-05-10ethtool: Split ethtool_get_eeprom() to allow for additional EEPROM accessorsBen Hutchings
We want to support reading module (SFP+, XFP, ...) EEPROMs as well as NIC EEPROMs. They will need a different command number and driver operation, but the structure and arguments will be the same and so we can share most of the code here. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
2012-04-04ethtool: Add a common function for drivers with transmit time stamping.Richard Cochran
Currently, most drivers do not support transmit SO_TIMESTAMPING. For those that do support it, there is one appropriate response to the get_ts_info query. This patch adds a common function providing this response. Signed-off-by: Richard Cochran <richardcochran@gmail.com> Reviewed-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-04ethtool: Introduce a method for getting time stamping capabilities.Richard Cochran
This commit adds a new ethtool ioctl that exposes the SO_TIMESTAMPING capabilities of a network interface. In addition, user space programs can use this ioctl to discover the PTP Hardware Clock (PHC) device associated with the interface. Since software receive time stamps are handled by the stack, the generic ethtool code can answer the query correctly in case the MAC or PHY drivers lack special time stamping features. Signed-off-by: Richard Cochran <richardcochran@gmail.com> Reviewed-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-02-24net: Support RX-ALL feature flag.Ben Greear
This flag requests that network devices pass all received frames up the stack, even ones with errors such as invalid FCS (frame check sum). This will allow sniffers to see bad packets and perhaps give the user some idea how to fix the problem. Signed-off-by: Ben Greear <greearb@candelatech.com> Tested-by: Aaron Brown <aaron.f.brown@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2012-02-24net: Support RXFCS feature flag.Ben Greear
When set on hardware that supports the feature, this causes the Ethernet FCS to be appended to the end of the skb. Useful for sniffing packets. Signed-off-by: Ben Greear <greearb@candelatech.com> Tested-by: Aaron Brown <aaron.f.brown@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2012-02-01ethtool: Null-terminate filename passed to ethtool_ops::flash_deviceBen Hutchings
The parameters for ETHTOOL_FLASHDEV include a filename, which ought to be null-terminated. Currently the only driver that implements ethtool_ops::flash_device attempts to add a null terminator if necessary, but does it wrongly. Do it in the ethtool core instead. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-01-22ethtool: allow ETHTOOL_GSSET_INFO for usersMichał Mirosław
Allow ETHTOOL_GSSET_INFO ethtool ioctl() for unprivileged users. ETHTOOL_GSTRINGS is already allowed, but is unusable without this one. Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Acked-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-01-04ethtool: Remove ethtool_ops::set_rx_ntuple operationBen Hutchings
All implementations have been converted to implement set_rxnfc instead. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-01-04ethtool: Allow drivers to select RX NFC rule locationsBen Hutchings
Define special location values for RX NFC that request the driver to select the actual rule location. This allows for implementation on devices that use hash-based filter lookup, whereas currently the API is more suited to devices with TCAM lookup or linear search. In ethtool_set_rxnfc() and the compat wrapper ethtool_ioctl(), copy the structure back to user-space after insertion so that the actual location is returned. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-16ethtool: Define and apply a default policy for RX flow hash indirectionBen Hutchings
All drivers that support modification of the RX flow hash indirection table initialise it in the same way: RX rings are assigned to table entries in rotation. Make that default policy explicit by having them call a ethtool_rxfh_indir_default() function. In the ethtool core, add support for a zero size value for ETHTOOL_SRXFHINDIR, which resets the table to this default. Partly-suggested-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Acked-by: Shreyas N Bhatewara <sbhatewara@vmware.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-16ethtool: Centralise validation of ETHTOOL_{G, S}RXFHINDIR parametersBen Hutchings
Add a new ethtool operation (get_rxfh_indir_size) to get the indirectional table size. Use this to validate the user buffer size before calling get_rxfh_indir or set_rxfh_indir. Use get_rxnfc to get the number of RX rings, and validate the contents of the new indirection table before calling set_rxfh_indir. Remove this validation from drivers. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Acked-by: Dimitris Michailidis <dm@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-11-16net: ethtool: fix coding styleMichał Mirosław
Add missing spaces around multiplication operator. Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-11-16net: remove NETIF_F_NO_CSUM feature bitMichał Mirosław
Only distinct use is checking if NETIF_F_NOCACHE_COPY should be enabled by default. The check heuristics is altered a bit here, so it hits other people than before. The default shouldn't be trusted for performance-critical cases anyway. For all other uses NETIF_F_NO_CSUM is equivalent to NETIF_F_HW_CSUM. Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-11-16ethtool: prepare for larger netdev_features_t typeMichał Mirosław
v2: changed loop in ethtool_set_features() per Ben's suggestion Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-11-16net: ethtool: use C99 array initialization for feature-names tableMichał Mirosław
2011-11-16net: introduce and use netdev_features_t for device features setsMichał Mirosław
v2: add couple missing conversions in drivers split unexporting netdev_fix_features() implemented %pNF convert sock::sk_route_(no?)caps Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-11-16net: ethtool: break association of ETH_FLAG_* with NETIF_F_*Michał Mirosław
This is the only place left where dev->features are directly exposed to userspace. I know checkpatch.pl complains about __ethtool_{get,set}_flags(), but the code is easier to read this way. Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Acked-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-11-16net: remove legacy ethtool opsMichał Mirosław
As all drivers are converted, we may now remove discrete offload setting callback handling. Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Acked-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-09-15net: consolidate and fix ethtool_ops->get_settings callingJiri Pirko
This patch does several things: - introduces __ethtool_get_settings which is called from ethtool code and from drivers as well. Put ASSERT_RTNL there. - dev_ethtool_get_settings() is replaced by __ethtool_get_settings() - changes calling in drivers so rtnl locking is respected. In iboe_get_rate was previously ->get_settings() called unlocked. This fixes it. Also prb_calc_retire_blk_tmo() in af_packet.c had the same problem. Also fixed by calling __dev_get_by_index() instead of dev_get_by_index() and holding rtnl_lock for both calls. - introduces rtnl_lock in bnx2fc_vport_create() and fcoe_vport_create() so bnx2fc_if_create() and fcoe_if_create() are called locked as they are from other places. - use __ethtool_get_settings() in bonding code Signed-off-by: Jiri Pirko <jpirko@redhat.com> v2->v3: -removed dev_ethtool_get_settings() -added ASSERT_RTNL into __ethtool_get_settings() -prb_calc_retire_blk_tmo - use __dev_get_by_index() and lock around it and __ethtool_get_settings() call v1->v2: add missing export_symbol Reviewed-by: Ben Hutchings <bhutchings@solarflare.com> [except FCoE bits] Acked-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-21ethtool: Allow zero-length register dumps againBen Hutchings
Some drivers (ab)use the ethtool_ops::get_regs operation to expose only a hardware revision ID. Commit a77f5db361ed9953b5b749353ea2c7fed2bf8d93 ('ethtool: Allocate register dump buffer with vmalloc()') had the side-effect of breaking these, as vmalloc() returns a null pointer for size=0 whereas kmalloc() did not. For backward-compatibility, allow zero-length dumps again. Reported-by: Kalle Valo <kvalo@qca.qualcomm.com> Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Cc: stable@kernel.org [2.6.37+] Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-08v2 ethtool: remove support for ETHTOOL_GRXNTUPLEAlexander Duyck
This change is meant to remove all support for displaying an ntuple as strings via ETHTOOL_GRXNTUPLE. The reason for this change is due to the fact that multiple issues have been found including: - Multiple buffer overruns for strings being displayed. - Incorrect filters displayed, cleared filters with ring of -2 are displayed - Setting get_rx_ntuple displays no rules if defined. - Endianess wrong on displayed values. - Hard limit of 1024 filters makes display functionality extremely limited The only driver that had supported this interface was ixgbe. Since it no longer uses the interface and due to the issues mentioned above I am submitting this patch to remove it. v2: Updated based on comments from Ben Hutchings - Left ETH_SS_NTUPLE_FILTERS in code but commented on it being deprecated - Removed ethtool_rx_ntuple_list and ethtool_rx_ntuple_flow_spec_container - Left ETHTOOL_GRXNTUPLE but commented it as deprecated Also cleaned up set_rx_ntuple since there is no flow spec container to maintain we can drop all the code for the alloc and free of it and just return ops->set_rx_ntuple(). Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com> Acked-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-26net: fix ETHTOOL_SFEATURES compatibility with old ethtool_ops.set_flagsMichał Mirosław
Current code squashes flags to bool - this makes set_flags fail whenever some ETH_FLAG_* equivalent features are set. Fix this. Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-17Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/vmxnet3/vmxnet3_ethtool.c net/core/dev.c
2011-05-17net: ethtool: fix IPV6 checksum feature name stringMichał Mirosław
2011-05-13ethtool: Added support for FW dumpAnirban Chakraborty
Added code to take FW dump via ethtool. Dump level can be controlled via setting the dump flag. A get function is provided to query the current setting of the dump flag. Dump data is obtained from the driver via a separate get function. Changes from v3: Fixed buffer length issue in ethtool_get_dump_data function. Updated kernel doc for ethtool_dump struct and get_dump_flag function. Changes from v2: Provided separate commands for get flag and data. Check for minimum of the two buffer length obtained via ethtool and driver and use that for dump buffer Pass up the driver return error codes up to the caller. Added kernel doc comments. Signed-off-by: Anirban Chakraborty <anirban.chakraborty@qlogic.com> Reviewed-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-12ethtool: bring back missing comma in netdev features stringsFranco Fichtner
The issue was introduced in commit eed2a12f1ed9aabf. Signed-off-by: Franco Fichtner <franco@lastsummer.de> Acked-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Acked-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-08net: Allow ethtool to set interface in loopback mode.Mahesh Bandewar
This patch enables ethtool to set the loopback mode on a given interface. By configuring the interface in loopback mode in conjunction with a policy route / rule, a userland application can stress the egress / ingress path exposing the flows of the change in progress and potentially help developer(s) understand the impact of those changes without even sending a packet out on the network. Following set of commands illustrates one such example - a) ip -4 addr add 192.168.1.1/24 dev eth1 b) ip -4 rule add from all iif eth1 lookup 250 c) ip -4 route add local 0/0 dev lo proto kernel scope host table 250 d) arp -Ds 192.168.1.100 eth1 e) arp -Ds 192.168.1.200 eth1 f) sysctl -w net.ipv4.ip_nonlocal_bind=1 g) sysctl -w net.ipv4.conf.all.accept_local=1 # Assuming that the machine has 8 cores h) taskset 000f netserver -L 192.168.1.200 i) taskset 00f0 netperf -t TCP_CRR -L 192.168.1.100 -H 192.168.1.200 -l 30 Signed-off-by: Mahesh Bandewar <maheshb@google.com> Acked-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-08ethtool: remove phys_id from ethtool_opsStephen Hemminger
After that all the upstream kernel drivers now use phys_id, and the old ethtool_ops interface (phys_id) can be removed. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-21net: fix hw_features ethtool_ops->set_flags compatibilityMichał Mirosław
__ethtool_set_flags() was not taking into account features set but not user-toggleable. Since GFLAGS returns masked dev->features, EINVAL is returned when passed flags differ to it, and not to wanted_features. Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-14ethtool: allow custom interval for physical identificationAllan, Bruce W
When physical identification of an adapter is done by toggling the mechanism on and off through software utilizing the set_phys_id operation, it is done with a fixed duration for both on and off states. Some drivers may want to set a custom duration for the on/off intervals. This patch changes the API so the return code from the driver's entry point when it is called with ETHTOOL_ID_ACTIVE can specify the frequency at which to cycle the on/off states, and updates the drivers that have already been converted to use the new set_phys_id and use the synchronous method for identifying an adapter. The physical identification frequency set in the updated drivers is based on how it was done prior to the introduction of set_phys_id. Compile tested only. Also fixes a compiler warning in sfc. v2: drivers do not return -EINVAL for ETHOOL_ID_ACTIVE v3: fold patchset into single patch and cleanup per Ben's feedback Signed-off-by: Bruce Allan <bruce.w.allan@intel.com> Cc: Ben Hutchings <bhutchings@solarflare.com> Cc: Sathya Perla <sathya.perla@emulex.com> Cc: Subbu Seetharaman <subbu.seetharaman@emulex.com> Cc: Ajit Khaparde <ajit.khaparde@emulex.com> Cc: Michael Chan <mchan@broadcom.com> Cc: Eilon Greenstein <eilong@broadcom.com> Cc: Divy Le Ray <divy@chelsio.com> Cc: Don Fry <pcnet32@frontier.com> Cc: Jon Mason <jdmason@kudzu.us> Cc: Solarflare linux maintainers <linux-net-drivers@solarflare.com> Cc: Steve Hodgson <shodgson@solarflare.com> Cc: Stephen Hemminger <shemminger@linux-foundation.org> Cc: Matt Carlson <mcarlson@broadcom.com> Acked-by: Jon Mason <jdmason@kudzu.us> Acked-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
