ndm_type means L3 address type, in neighbour proxy and vxlan, it's RTN_UNICAST.
NDA_DST is for netlink TLV type, hence it's not right value in this context.
Signed-off-by: Jun Zhao <mypopydev@gmail.com>
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
The code in neigh_sysctl_register() relies on a specific layout of
struct neigh_table, namely that the 'gc_*' variables are directly
following the 'parms' member in a specific order. The code, though,
expresses this in the most ugly way.
Get rid of the ugly casts and use the 'tbl' pointer to get a handle to
the table. This way we can refer to the 'gc_*' variables directly.
Similarly seen in the grsecurity patch, written by Brad Spengler.
Signed-off-by: Mathias Krause <minipli@googlemail.com>
Cc: Brad Spengler <spender@grsecurity.net>
Since commit 7e98056964("ipv6: router reachability probing"), a router falls
into NUD_FAILED will be probed.
Now if function rt6_select() selects a router which neighbour state is NUD_FAILED,
and at the same time function rt6_probe() changes the neighbour state to NUD_PROBE,
then function dst_neigh_output() can directly send packets, but actually the
neighbour still is unreachable. If we set nud_state to NUD_INCOMPLETE instead
NUD_PROBE, packets will not be sent out until the neihbour is reachable.
In addition, because the route should be probes with a single NS, so we must
set neigh->probes to neigh_max_probes(), then the neigh timer timeout and function
neigh_timer_handler() will not send other NS Messages.
Signed-off-by: Duan Jiong <duanj.fnst@cn.fujitsu.com>
drivers/net/wireless/ath/ath9k/recv.c
drivers/net/wireless/mwifiex/pcie.c
net/ipv6/sit.c
The SIT driver conflict consists of a bug fix being done by hand
in 'net' (missing u64_stats_init()) whilst in 'net-next' a helper
was created (netdev_alloc_pcpu_stats()) which takes care of this.
The two wireless conflicts were overlapping changes.
If the neigh table's entries is less than gc_thresh1, the function
will return directly, and the reachabletime will not be recompute,
so the reachabletime can be guessed.
Because those following if conditions will not be matched.
iproute2 arpd seems to expect this as there's code and comments
to handle netlink probes with NUD_PROBE set. It is used to flush
the arpd cached mappings.
opennhrp instead turns off unicast probes (so it can handle all
neighbour discovery). Without this change it will not see NUD_PROBE
probes and cannot reconfirm the mapping. Thus currently neigh entry
will just fail and can cause few packets dropped until broadcast
discovery is restarted.
Earlier discussion on the subject:
http://marc.info/?t=139305877100001&r=1&w=2
Signed-off-by: Timo Teräs <timo.teras@iki.fi>
This patch fixes bug introduced by:
commit 1d4c8c29841b9991cdf3c7cc4ba7f96a94f104ca
"neigh: restore old behaviour of default parms values"
The thing is that in neigh_sysctl_register, extra1 and extra2 which were
previously set for NEIGH_VAR_GC_* are overwritten. That leads to
nonsense int limits for gc_* variables. So fix this by not touching
extra* fields for gc_* variables.
Signed-off-by: Jiri Pirko <jiri@resnulli.us>
Workqueue used in neighbour layer have no real dependency of scheduling these on
the cpu which scheduled them.
On a idle system, it is observed that an idle cpu wakes up many times just to
service this work. It would be better if we can schedule it on a cpu which the
scheduler believes to be the most appropriate one.
This patch replaces normal workqueues with power efficient versions. This
doesn't change existing behavior of code unless CONFIG_WQ_POWER_EFFICIENT is
enabled.
Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
introduced by:
commit 1f9248e5606afc6485255e38ad57bdac08fa7711
"neigh: convert parms to an array"
This patch removes the net_random and net_srandom macros and replaces
them with direct calls to the prandom ones. As new commits only seem to
use prandom_u32 there is no use to keep them around.
This change makes it easier to grep for users of prandom_u32.
Signed-off-by: Aruna-Hewapathirane <aruna.hewapathirane@gmail.com>
Suggested-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
drivers/net/ethernet/qlogic/qlcnic/qlcnic_sriov_pf.c
net/ipv6/ip6_tunnel.c
net/ipv6/ip6_vti.c
ipv6 tunnel statistic bug fixes conflicting with consolidation into
generic sw per-cpu net stats.
qlogic conflict between queue counting bug fix and the addition
of multiple MAC address support.
When the vlan code detects that the real device can do TX VLAN offloads
in hardware, it tries to arrange for the real device's header_ops to
be invoked directly.
But it does so illegally, by simply hooking the real device's
header_ops up to the VLAN device.
This doesn't work because we will end up invoking a set of header_ops
routines which expect a device type which matches the real device, but
will see a VLAN device instead.
Fix this by providing a pass-thru set of header_ops which will arrange
to pass the proper real device instead.
To facilitate this add a dev_rebuild_header(). There are
implementations which provide a ->cache and ->create but not a
->rebuild (f.e. PLIP). So we need a helper function just like
dev_hard_header() to avoid crashes.
Use this helper in the one existing place where the
header_ops->rebuild was being invoked, the neighbour code.
With lots of help from Florian Westphal.
drivers/net/ethernet/intel/i40e/i40e_main.c
drivers/net/macvtap.c
Both minor merge hassles, simple overlapping changes.
The neighbour code sends up an RTM_NEWNEIGH netlink notification if
the NUD state of a neighbour cache entry is changed by a timer (e.g.
from REACHABLE to STALE), even if the lladdr of the entry has not
changed.
But an administrative change to the the NUD state of a neighbour cache
entry that does not change the lladdr (e.g. via "ip -4 neigh change
... nud ...") does not trigger a netlink notification. This means
that netlink listeners will not hear about administrative NUD state
changes such as from a resolved state to PERMANENT.
This patch changes the neighbor code to generate an RTM_NEWNEIGH
message when the NUD state of an entry is changed administratively.
Signed-off-by: Bob Gilligan <gilligan@aristanetworks.com>
Acked-by: Nicolas Dichtel <nicolas.dichtel@6wind.com>
RFC 4191 states in 3.5:
When a host avoids using any non-reachable router X and instead sends
a data packet to another router Y, and the host would have used
router X if router X were reachable, then the host SHOULD probe each
such router X's reachability by sending a single Neighbor
Solicitation to that router's address. A host MUST NOT probe a
router's reachability in the absence of useful traffic that the host
would have sent to the router if it were reachable. In any case,
these probes MUST be rate-limited to no more than one per minute per
router.
Currently, when the neighbour corresponding to a router falls into
NUD_FAILED, it's never considered again. Introduce a new rt6_nud_state
value, RT6_NUD_FAIL_PROBE, which suggests the route should not be used but
should be probed with a single NS. The probe is ratelimited by the existing
code. To better distinguish meanings of the failure values, rename
RT6_NUD_FAIL_SOFT to RT6_NUD_FAIL_DO_RR.
Signed-off-by: Jiri Benc <jbenc@redhat.com>
This fixes compile error when CONFIG_NET_NS is not set.
Introduced by:
Make the behaviour similar to ipv4. This will allow user to set sysctl
default neigh param values and these values will be respected even by
devices registered before (that ones what do not have address set yet).
Previously inet devices were only constructed when addresses are added.
Therefore the default neigh parms values they get are the ones at the
time of these operations.
Now that we're creating inet devices earlier, this changes the behaviour
of default neigh parms values in an incompatible way (see bug #8519).
This patch creates a compromise by setting the default values at the
same point as before but only for those that have not been explicitly
set by the user since the inet device's creation.
Introduced by:
commit 8030f54499925d073a88c09f30d5d844fb1b3190
Author: Herbert Xu <herbert@gondor.apana.org.au>
Date: Thu Feb 22 01:53:47 2007 +0900
[IPV4] devinet: Register inetdev earlier.
This will be needed later on to provide better management of default values.
This patch converts the neigh param members to an array. This allows easier
manipulation which will be needed later on to provide better management of
default values.
Currently we always use the first member of the arp_queue to determine
the sender ip address of the arp packet (or in case of IPv6 - source
address of the ndisc packet). This skb is fixed as long as the queue is
not drained by a complete purge because of a timeout or by a successful
response.
If the first packet enqueued on the arp_queue is from a local application
with a manually set source address and the to be discovered system
does some kind of uRPF checks on the source address in the arp packet
the resolving process hangs until a timeout and restarts. This hurts
communication with the participating network node.
This could be mitigated a bit if we use the latest enqueued skb's
source address for the resolving process, which is not as static as
the arp_queue's head. This change of the source address could result in
better recovery of a failed solicitation.
Cc: Julian Anastasov <ja@ssi.bg>
Reviewed-by: Julian Anastasov <ja@ssi.bg>
This config option is superfluous in that it only guards a call
to neigh_app_ns(). Enabling CONFIG_ARPD by default has no
change in behavior. There will now be call to __neigh_notify()
for each ARP resolution, which has no impact unless there is a
user space daemon waiting to receive the notification, i.e.,
the case for which CONFIG_ARPD was designed anyways.
Suggested-by: Eric W. Biederman <ebiederm@xmission.com>
Cc: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru>
Cc: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org>
Cc: Patrick McHardy <kaber@trash.net>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Gao feng <gaofeng@cn.fujitsu.com>
Cc: Joe Perches <joe@perches.com>
Cc: Veaceslav Falico <vfalico@redhat.com>
Signed-off-by: Tim Gardner <tim.gardner@canonical.com>
Reviewed-by: "Eric W. Biederman" <ebiederm@xmission.com>
Merge net into net-next to setup some infrastructure Eric
Dumazet needs for usbnet changes.
dev->ndo_neigh_setup() might need some of the values of neigh_parms, so
populate them before calling it.
Signed-off-by: Veaceslav Falico <vfalico@redhat.com>
Without this patch, the fields app_solicit, gc_thresh1, gc_thresh2,
gc_thresh3, proxy_qlen, ucast_solicit, mcast_solicit could have
assumed negative values when setting large numbers.
Signed-off-by: Francesco Fusco <ffusco@redhat.com>
There is a race in neighbour code, because neigh_destroy() uses
skb_queue_purge(&neigh->arp_queue) without holding neighbour lock,
while other parts of the code assume neighbour rwlock is what
protects arp_queue
Convert all skb_queue_purge() calls to the __skb_queue_purge() variant
Use __skb_queue_head_init() instead of skb_queue_head_init()
to make clear we do not use arp_queue.lock
And hold neigh->lock in neigh_destroy() to close the race.
Reported-by: Joe Jin <joe.jin@oracle.com>
thresh and interval are global resources,
only init net can change them.
Signed-off-by: Gao feng <gaofeng@cn.fujitsu.com>
Though we don't export the /proc/sys/net/ipv[4,6]/neigh/default/
directory to the un-init_net, but we can still use cmd such as
"ip ntable change name arp_cache locktime 129" to change the locktime
of default neigh_parms.
This patch disallows the un-init_net to find out the neigh_table.parms.
So the un-init_net will failed to influence the init_net.
neigh_table.parms always exist and is initialized,kmemdup
can use it to create new neigh_parms, actually lookup_neigh_parms
here will return neigh_table.parms too.
Reduce the uses of this unnecessary typedef.
Done via perl script:
$ git grep --name-only -w ctl_table net | \
xargs perl -p -i -e '\
sub trim { my ($local) = @_; $local =~ s/(^\s+|\s+$)//g; return $local; } \
s/\b(?<!struct\s)ctl_table\b(\s*\*\s*|\s+\w+)/"struct ctl_table " . trim($1)/ge'
Reflow the modified lines that now exceed 80 columns.
Pull VFS updates from Al Viro,
Misc cleanups all over the place, mainly wrt /proc interfaces (switch
create_proc_entry to proc_create(), get rid of the deprecated
create_proc_read_entry() in favor of using proc_create_data() and
seq_file etc).
7kloc removed.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (204 commits)
don't bother with deferred freeing of fdtables
proc: Move non-public stuff from linux/proc_fs.h to fs/proc/internal.h
proc: Make the PROC_I() and PDE() macros internal to procfs
proc: Supply a function to remove a proc entry by PDE
take cgroup_open() and cpuset_open() to fs/proc/base.c
ppc: Clean up scanlog
ppc: Clean up rtas_flash driver somewhat
hostap: proc: Use remove_proc_subtree()
drm: proc: Use remove_proc_subtree()
drm: proc: Use minor->index to label things, not PDE->name
drm: Constify drm_proc_list[]
zoran: Don't print proc_dir_entry data in debug
reiserfs: Don't access the proc_dir_entry in r_open(), r_start() r_show()
proc: Supply an accessor for getting the data from a PDE's parent
airo: Use remove_proc_subtree()
rtl8192u: Don't need to save device proc dir PDE
rtl8187se: Use a dir under /proc/net/r8180/
proc: Add proc_mkdir_data()
proc: Move some bits from linux/proc_fs.h to linux/{of.h,signal.h,tty.h}
proc: Move PDE_NET() to fs/proc/proc_net.c
Update debugging messages to a more current style.
Emit these debugging messages at KERN_DEBUG instead
of KERN_DEFAULT.
Add and use neigh_dbg(level, fmt, ...) macro
Add dynamic_debug capability via pr_debug
Convert embedded function names to "%s: ", __func__
The only part of proc_dir_entry the code outside of fs/proc
really cares about is PDE(inode)->data. Provide a helper
for that; static inline for now, eventually will be moved
to fs/proc, along with the knowledge of struct proc_dir_entry
layout.
With decnet converted, we can finally get rid of rta_buf and its
computations around it. It also gets rid of the minimal header
length verification since all message handlers do that explicitly
anyway.
Signed-off-by: Thomas Graf <tgraf@suug.ch>
When allocating memory for neighbour cache entry, if
tbl->entry_size is not set, we always calculate
sizeof(struct neighbour) + tbl->key_len, which is common
in the same table.
With this change, set tbl->entry_size during the table
initialization phase, if it was not set, and use it in
neigh_alloc() and neighbour_priv().
This change also allow us to have both of protocol private
data and device priate data at tha same time.
Note that the only user of prototcol private is DECnet
and the only user of device private is ATM CLIP.
Since those are exclusive, we have not been facing issues
here.
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
Since we have removed NCE (Neighbour Cache Entry) reference from
routing entries, the only refcnt holders of an NCE are its timer
(if running) and its owner table, in usual cases. As a result,
neigh_periodic_work() purges NCEs over and over again even for
gateways.
It does not make sense to purge entries, if number of them is
very small, so keep them. The minimum number of entries to keep
is specified by gc_thresh1.
net/core/neighbour.c:65:12: warning: 'zero' defined but not used [-Wunused-variable]
net/core/neighbour.c:66:12: warning: 'unres_qlen_max' defined but not used [-Wunused-variable]
These variables are only used when CONFIG_SYSCTL is defined,
so move them under #ifdef CONFIG_SYSCTL.
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
Signed-off-by: Cong Wang <amwang@redhat.com>
Acked-by: Shan Wei <davidshan@tencent.com>
unres_qlen_bytes and unres_qlen are int type.
But multiple relation(unres_qlen_bytes = unres_qlen * SKB_TRUESIZE(ETH_FRAME_LEN))
will cause type overflow when seting unres_qlen. e.g.
$ echo 1027506 > /proc/sys/net/ipv4/neigh/eth1/unres_qlen
$ cat /proc/sys/net/ipv4/neigh/eth1/unres_qlen
1182657265
$ cat /proc/sys/net/ipv4/neigh/eth1/unres_qlen_bytes
-2147479756
The gutted value is not that we setting。
But user/administrator don't know this is caused by int type overflow.
what's more, it is meaningless and even dangerous that unres_qlen_bytes is set
with negative number. Because, for unresolved neighbour address, kernel will cache packets
without limit in __neigh_event_send()(e.g. (u32)-1 = 2GB).
Signed-off-by: Shan Wei <davidshan@tencent.com>
- Only allow moving network devices to network namespaces you have
CAP_NET_ADMIN privileges over.
- Enable creating/deleting/modifying interfaces
- Enable adding/deleting addresses
- Enable adding/setting/deleting neighbour entries
- Enable adding/removing routes
- Enable adding/removing fib rules
- Enable setting the forwarding state
- Enable adding/removing ipv6 address labels
- Enable setting bridge parameter
- In rtnetlink_rcv_msg convert the capable(CAP_NET_ADMIN) check
to ns_capable(net->user-ns, CAP_NET_ADMIN). Allowing unprivileged
users to make netlink calls to modify their local network
namespace.
- In the rtnetlink doit methods add capable(CAP_NET_ADMIN) so
that calls that are not safe for unprivileged users are still
protected.
Later patches will remove the extra capable calls from methods
that are safe for unprivilged users.
Acked-by: Serge Hallyn <serge.hallyn@canonical.com>
In preparation for supporting the creation of network namespaces
by unprivileged users, modify all of the per net sysctl exports
and refuse to allow them to unprivileged users.
This makes it safe for unprivileged users in general to access
per net sysctls, and allows sysctls to be exported to unprivileged
users on an individual basis as they are deemed safe.
The retry loop in neigh_resolve_output() and neigh_connected_output()
call dev_hard_header() with out reseting the skb to network_header.
This causes the retry to fail with skb_under_panic. The fix is to
reset the network_header within the retry loop.
Signed-off-by: Ramesh Nagappa <ramesh.nagappa@ericsson.com>
Reviewed-by: Shawn Lu <shawn.lu@ericsson.com>
Reviewed-by: Robert Coulson <robert.coulson@ericsson.com>
Reviewed-by: Billie Alsup <billie.alsup@ericsson.com>
Pull networking changes from David Miller:
1) GRE now works over ipv6, from Dmitry Kozlov.
2) Make SCTP more network namespace aware, from Eric Biederman.
3) TEAM driver now works with non-ethernet devices, from Jiri Pirko.
4) Make openvswitch network namespace aware, from Pravin B Shelar.
5) IPV6 NAT implementation, from Patrick McHardy.
6) Server side support for TCP Fast Open, from Jerry Chu and others.
7) Packet BPF filter supports MOD and XOR, from Eric Dumazet and Daniel
Borkmann.
8) Increate the loopback default MTU to 64K, from Eric Dumazet.
9) Use a per-task rather than per-socket page fragment allocator for
outgoing networking traffic. This benefits processes that have very
many mostly idle sockets, which is quite common.
From Eric Dumazet.
10) Use up to 32K for page fragment allocations, with fallbacks to
smaller sizes when higher order page allocations fail. Benefits are
a) less segments for driver to process b) less calls to page
allocator c) less waste of space.
From Eric Dumazet.
11) Allow GRO to be used on GRE tunnels, from Eric Dumazet.
12) VXLAN device driver, one way to handle VLAN issues such as the
limitation of 4096 VLAN IDs yet still have some level of isolation.
From Stephen Hemminger.
13) As usual there is a large boatload of driver changes, with the scale
perhaps tilted towards the wireless side this time around.
Fix up various fairly trivial conflicts, mostly caused by the user
namespace changes.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1012 commits)
hyperv: Add buffer for extended info after the RNDIS response message.
hyperv: Report actual status in receive completion packet
hyperv: Remove extra allocated space for recv_pkt_list elements
hyperv: Fix page buffer handling in rndis_filter_send_request()
hyperv: Fix the missing return value in rndis_filter_set_packet_filter()
hyperv: Fix the max_xfer_size in RNDIS initialization
vxlan: put UDP socket in correct namespace
vxlan: Depend on CONFIG_INET
sfc: Fix the reported priorities of different filter types
sfc: Remove EFX_FILTER_FLAG_RX_OVERRIDE_IP
sfc: Fix loopback self-test with separate_tx_channels=1
sfc: Fix MCDI structure field lookup
sfc: Add parentheses around use of bitfield macro arguments
sfc: Fix null function pointer in efx_sriov_channel_type
vxlan: virtual extensible lan
igmp: export symbol ip_mc_leave_group
netlink: add attributes to fdb interface
tg3: unconditionally select HWMON support when tg3 is enabled.
Revert "net: ti cpsw ethernet: allow reading phy interface mode from DT"
gre: fix sparse warning
It is a frequent mistake to confuse the netlink port identifier with a
process identifier. Try to reduce this confusion by renaming fields
that hold port identifiers portid instead of pid.
I have carefully avoided changing the structures exported to
userspace to avoid changing the userspace API.
I have successfully built an allyesconfig kernel with this change.
Acked-by: Stephen Hemminger <shemminger@vyatta.com>
Initalizers for deferrable delayed_work are confused.
* __DEFERRED_WORK_INITIALIZER()
* DECLARE_DEFERRED_WORK()
* INIT_DELAYED_WORK_DEFERRABLE()
Rename them to
* __DEFERRABLE_WORK_INITIALIZER()
* DECLARE_DEFERRABLE_WORK()
* INIT_DEFERRABLE_WORK()
This patch doesn't cause any functional changes.
Do not use the dst cached neigh, we'll be getting rid of that.
Denys found out "ip neigh" output was truncated to
about 54 neighbours.
Reported-by: Denys Fedoryshchenko <denys@visp.net.lb>
