path: root/net/core/scm.c
2011-08-11scm: Capture the full credentials of the scm senderTim Chen
This patch corrects an erroneous update of credential's gid with uid introduced in commit 257b5358b32f17 since 2.6.36. Signed-off-by: Tim Chen <tim.c.chen@linux.intel.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Reviewed-by: James Morris <jmorris@namei.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-15Allow passing O_PATH descriptors via SCM_RIGHTS datagramsAl Viro
Just need to make sure that AF_UNIX garbage collector won't confuse O_PATHed socket on filesystem for real AF_UNIX opened socket. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-11-24scm: lower SCM_MAX_FDEric Dumazet
Lower SCM_MAX_FD from 255 to 253 so that allocations for scm_fp_list are halved. (commit f8d570a4 added two pointers in this structure) scm_fp_dup() should not copy whole structure (and trigger kmemcheck warnings), but only the used part. While we are at it, only allocate needed size. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-12net/core: EXPORT_SYMBOL cleanupsEric Dumazet
CodingStyle cleanups EXPORT_SYMBOL should immediately follow the symbol declaration. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-16scm: Capture the full credentials of the scm sender.Eric W. Biederman
Start capturing not only the userspace pid, uid and gid values of the sending process but also the struct pid and struct cred of the sending process as well. This is in preparation for properly supporting SCM_CREDENTIALS for sockets that have different uid and/or pid namespaces at the different ends. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Serge E. Hallyn <serge@hallyn.com> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-28scm: Only support SCM_RIGHTS on unix domain sockets.Eric W. Biederman
We use scm_send and scm_recv on both unix domain and netlink sockets, but only unix domain sockets support everything required for file descriptor passing, so error if someone attempts to pass file descriptors over netlink sockets. Cc: stable@kernel.org Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-18Merge branch 'master' into nextJames Morris
Conflicts: fs/cifs/misc.c Merge to resolve above, per the patch below. Signed-off-by: James Morris <jmorris@namei.org> diff --cc fs/cifs/misc.c index ec36410,addd1dc..0000000 --- a/fs/cifs/misc.c +++ b/fs/cifs/misc.c @@@ -347,13 -338,13 +338,13 @@@ header_assemble(struct smb_hdr *buffer /* BB Add support for establishing new tCon and SMB Session */ /* with userid/password pairs found on the smb session */ /* for other target tcp/ip addresses BB */ - if (current->fsuid != treeCon->ses->linux_uid) { + if (current_fsuid() != treeCon->ses->linux_uid) { cFYI(1, ("Multiuser mode and UID " "did not match tcon uid")); - read_lock(&GlobalSMBSeslock); - list_for_each(temp_item, &GlobalSMBSessionList) { - ses = list_entry(temp_item, struct cifsSesInfo, cifsSessionList); + read_lock(&cifs_tcp_ses_lock); + list_for_each(temp_item, &treeCon->ses->server->smb_ses_list) { + ses = list_entry(temp_item, struct cifsSesInfo, smb_ses_list); - if (ses->linux_uid == current->fsuid) { + if (ses->linux_uid == current_fsuid()) { if (ses->server == treeCon->ses->server) { cFYI(1, ("found matching uid substitute right smb_uid")); buffer->Uid = ses->Suid;
2008-11-14scm: fix scm_fp_list->list initialization made in wrong placePavel Emelyanov
This is the next page of the scm recursion story (the commit f8d570a4 net: Fix recursive descent in __scm_destroy()). In function scm_fp_dup(), the INIT_LIST_HEAD(&fpl->list) of newly created fpl is done *before* the subsequent memcpy from the old structure and thus the freshly initialized list is overwritten. But that's OK, since this initialization is not required at all, since the fpl->list is list_add-ed at the destruction time in any case (and is unused in other code), so I propose to drop both initializations, rather than moving it after the memcpy. Please, correct me if I miss something significant. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-14Merge branch 'master' into nextJames Morris
Conflicts: security/keys/internal.h security/keys/process_keys.c security/keys/request_key.c Fixed conflicts above by using the non 'tsk' versions. Signed-off-by: James Morris <jmorris@namei.org>
2008-11-14CRED: Wrap current->cred and a few other accessorsDavid Howells
Wrap current->cred and a few other accessors to hide their actual implementation. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2008-11-14CRED: Separate task security context from task_structDavid Howells
Separate the task security context from task_struct. At this point, the security data is temporarily embedded in the task_struct with two pointers pointing to it. Note that the Alpha arch is altered as it refers to (E)UID and (E)GID in entry.S via asm-offsets. With comment fixes Signed-off-by: Marc Dionne <marc.c.dionne@gmail.com> Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2008-11-14CRED: Wrap task credential accesses in the networking subsystemDavid Howells
Wrap access to task credentials so that they can be separated more easily from the task_struct during the introduction of COW creds. Change most current->(|e|s|fs)[ug]id to current_(|e|s|fs)[ug]id(). Change some task->e?[ug]id to task_e?[ug]id(). In some places it makes more sense to use RCU directly rather than a convenient wrapper; these will be addressed by later patches. Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Cc: netdev@vger.kernel.org Signed-off-by: James Morris <jmorris@namei.org>
2008-11-06net: Fix recursive descent in __scm_destroy().David Miller
__scm_destroy() walks the list of file descriptors in the scm_fp_list pointed to by the scm_cookie argument. Those, in turn, can close sockets and invoke __scm_destroy() again. There is nothing which limits how deeply this can occur. The idea for how to fix this is from Linus. Basically, we do all of the fput()s at the top level by collecting all of the scm_fp_list objects hit by an fput(). Inside of the initial __scm_destroy() we keep running the list until it is empty. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-12-20[NET]: Fix function put_cmsg() which may cause usr application memory overflowWei Yongjun
When used function put_cmsg() to copy kernel information to user application memory, if the memory length given by user application is not enough, by the bad length calculate of msg.msg_controllen, put_cmsg() function may cause the msg.msg_controllen to be a large value, such as 0xFFFFFFF0, so the following put_cmsg() can also write data to usr application memory even usr has no valid memory to store this. This may cause usr application memory overflow. int put_cmsg(struct msghdr * msg, int level, int type, int len, void *data) { struct cmsghdr __user *cm = (__force struct cmsghdr __user *)msg->msg_control; struct cmsghdr cmhdr; int cmlen = CMSG_LEN(len); ~~~~~~~~~~~~~~~~~~~~~ int err; if (MSG_CMSG_COMPAT & msg->msg_flags) return put_cmsg_compat(msg, level, type, len, data); if (cm==NULL || msg->msg_controllen < sizeof(*cm)) { msg->msg_flags |= MSG_CTRUNC; return 0; /* XXX: return error? check spec. */ } if (msg->msg_controllen < cmlen) { ~~~~~~~~~~~~~~~~~~~~~~~~ msg->msg_flags |= MSG_CTRUNC; cmlen = msg->msg_controllen; } cmhdr.cmsg_level = level; cmhdr.cmsg_type = type; cmhdr.cmsg_len = cmlen; err = -EFAULT; if (copy_to_user(cm, &cmhdr, sizeof cmhdr)) goto out; if (copy_to_user(CMSG_DATA(cm), data, cmlen - sizeof(struct cmsghdr))) goto out; cmlen = CMSG_SPACE(len); ~~~~~~~~~~~~~~~~~~~~~~~~~~~ If MSG_CTRUNC flags is set, msg->msg_controllen is less than CMSG_SPACE(len), "msg->msg_controllen -= cmlen" will cause unsinged int type msg->msg_controllen to be a large value. ~~~~~~~~~~~~~~~~~~~~~~~~~~~ msg->msg_control += cmlen; msg->msg_controllen -= cmlen; ~~~~~~~~~~~~~~~~~~~~~ err = 0; out: return err; } The same promble exists in put_cmsg_compat(). This patch can fix this problem. Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-19pid namespaces: changes to show virtual ids to userPavel Emelyanov
This is the largest patch in the set. Make all (I hope) the places where the pid is shown to or get from user operate on the virtual pids. The idea is: - all in-kernel data structures must store either struct pid itself or the pid's global nr, obtained with pid_nr() call; - when seeking the task from kernel code with the stored id one should use find_task_by_pid() call that works with global pids; - when showing pid's numerical value to the user the virtual one should be used, but however when one shows task's pid outside this task's namespace the global one is to be used; - when getting the pid from userspace one need to consider this as the virtual one and use appropriate task/pid-searching functions. [akpm@linux-foundation.org: build fix] [akpm@linux-foundation.org: nuther build fix] [akpm@linux-foundation.org: yet nuther build fix] [akpm@linux-foundation.org: remove unneeded casts] Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: Alexey Dobriyan <adobriyan@openvz.org> Cc: Sukadev Bhattiprolu <sukadev@us.ibm.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Paul Menage <menage@google.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-10[NET]: sparse warning fixesStephen Hemminger
Fix a bunch of sparse warnings. Mostly about 0 used as NULL pointer, and shadowed variable declarations. One notable case was that hash size should have been unsigned. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-16O_CLOEXEC for SCM_RIGHTSUlrich Drepper
Part two in the O_CLOEXEC saga: adding support for file descriptors received through Unix domain sockets. The patch is once again pretty minimal, it introduces a new flag for recvmsg and passes it just like the existing MSG_CMSG_COMPAT flag. I think this bit is not used otherwise but the networking people will know better. This new flag is not recognized by recvfrom and recv. These functions cannot be used for that purpose and the asymmetry this introduces is not worse than the already existing MSG_CMSG_COMPAT situations. The patch must be applied on the patch which introduced O_CLOEXEC. It has to remove static from the new get_unused_fd_flags function but since scm.c cannot live in a module the function still hasn't to be exported. Here's a test program to make sure the code works. It's so much longer than the actual patch... #include <errno.h> #include <error.h> #include <fcntl.h> #include <stdio.h> #include <string.h> #include <unistd.h> #include <sys/socket.h> #include <sys/un.h> #ifndef O_CLOEXEC # define O_CLOEXEC 02000000 #endif #ifndef MSG_CMSG_CLOEXEC # define MSG_CMSG_CLOEXEC 0x40000000 #endif int main (int argc, char *argv[]) { if (argc > 1) { int fd = atol (argv[1]); printf ("child: fd = %d\n", fd); if (fcntl (fd, F_GETFD) == 0 || errno != EBADF) { puts ("file descriptor valid in child"); return 1; } return 0; } struct sockaddr_un sun; strcpy (sun.sun_path, "./testsocket"); sun.sun_family = AF_UNIX; char databuf[] = "hello"; struct iovec iov[1]; iov[0].iov_base = databuf; iov[0].iov_len = sizeof (databuf); union { struct cmsghdr hdr; char bytes[CMSG_SPACE (sizeof (int))]; } buf; struct msghdr msg = { .msg_iov = iov, .msg_iovlen = 1, .msg_control = buf.bytes, .msg_controllen = sizeof (buf) }; struct cmsghdr *cmsg = CMSG_FIRSTHDR (&msg); cmsg->cmsg_level = SOL_SOCKET; cmsg->cmsg_type = SCM_RIGHTS; cmsg->cmsg_len = CMSG_LEN (sizeof (int)); msg.msg_controllen = cmsg->cmsg_len; pid_t child = fork (); if (child == -1) error (1, errno, "fork"); if (child == 0) { int sock = socket (PF_UNIX, SOCK_STREAM, 0); if (sock < 0) error (1, errno, "socket"); if (bind (sock, (struct sockaddr *) &sun, sizeof (sun)) < 0) error (1, errno, "bind"); if (listen (sock, SOMAXCONN) < 0) error (1, errno, "listen"); int conn = accept (sock, NULL, NULL); if (conn == -1) error (1, errno, "accept"); *(int *) CMSG_DATA (cmsg) = sock; if (sendmsg (conn, &msg, MSG_NOSIGNAL) < 0) error (1, errno, "sendmsg"); return 0; } /* For a test suite this should be more robust like a barrier in shared memory. */ sleep (1); int sock = socket (PF_UNIX, SOCK_STREAM, 0); if (sock < 0) error (1, errno, "socket"); if (connect (sock, (struct sockaddr *) &sun, sizeof (sun)) < 0) error (1, errno, "connect"); unlink (sun.sun_path); *(int *) CMSG_DATA (cmsg) = -1; if (recvmsg (sock, &msg, MSG_CMSG_CLOEXEC) < 0) error (1, errno, "recvmsg"); int fd = *(int *) CMSG_DATA (cmsg); if (fd == -1) error (1, 0, "no descriptor received"); char fdname[20]; snprintf (fdname, sizeof (fdname), "%d", fd); execl ("/proc/self/exe", argv[0], fdname, NULL); puts ("execl failed"); return 1; } [akpm@linux-foundation.org: Fix fastcall inconsistency noted by Michael Buesch] [akpm@linux-foundation.org: build fix] Signed-off-by: Ulrich Drepper <drepper@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Michael Buesch <mb@bu3sch.de> Cc: Michael Kerrisk <mtk-manpages@gmx.net> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-10[NET] CORE: Fix whitespace errors.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-11[NET]: File descriptor loss while receiving SCM_RIGHTSMiklos Szeredi
If more than one file descriptor was sent with an SCM_RIGHTS message, and on the receiving end, after installing a nonzero (but not all) file descritpors the process runs out of fds, then the already installed fds will be lost (userspace will have no way of knowing about them). The following patch makes sure, that at least the already installed fds are sent to userspace. It doesn't solve the issue of losing file descriptors in case of an EFAULT on the userspace buffer. Signed-off-by: Miklos Szeredi <miklos@szeredi.hu> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-11[PATCH] capable/capability.h (net/)Randy Dunlap
net: Use <linux/capability.h> where capable() is used. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-25[PATCH] kill gratitious includes of major.h under net/*Al Viro
A lot of places in there are including major.h for no reason whatsoever. Removed. And yes, it still builds. The history of that stuff is often amusing. E.g. for net/core/sock.c the story looks so, as far as I've been able to reconstruct it: we used to need major.h in net/socket.c circa 1.1.early. In 1.1.13 that need had disappeared, along with register_chrdev(SOCKET_MAJOR, "socket", &net_fops) in sock_init(). Include had not. When 1.2 -> 1.3 reorg of net/* had moved a lot of stuff from net/socket.c to net/core/sock.c, this crap had followed... Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
