[ Upstream commit b0691c8ee7c28a72748ff32e91b165ec12ae4de6 ]
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (46 commits)
hwrng: via_rng - Fix memory scribbling on some CPUs
crypto: padlock - Move padlock.h into include/crypto
hwrng: via_rng - Fix asm constraints
crypto: n2 - use __devexit not __exit in n2_unregister_algs
crypto: mark crypto workqueues CPU_INTENSIVE
crypto: mv_cesa - dont return PTR_ERR() of wrong pointer
crypto: ripemd - Set module author and update email address
crypto: omap-sham - backlog handling fix
crypto: gf128mul - Remove experimental tag
crypto: af_alg - fix af_alg memory_allocated data type
crypto: aesni-intel - Fixed build with binutils 2.16
crypto: af_alg - Make sure sk_security is initialized on accept()ed sockets
net: Add missing lockdep class names for af_alg
include: Install linux/if_alg.h for user-space crypto API
crypto: omap-aes - checkpatch --file warning fixes
crypto: omap-aes - initialize aes module once per request
crypto: omap-aes - unnecessary code removed
crypto: omap-aes - error handling implementation improved
crypto: omap-aes - redundant locking is removed
crypto: omap-aes - DMA initialization fixes for OMAP off mode
Leonardo Chiquitto found poll() could block forever on tcp sockets and
Urgent data was received, if the event flag only contains POLLPRI.
He did a bisection and found commit 4938d7e0233 (poll: avoid extra
wakeups in select/poll) was the source of the problem.
Problem is TCP sockets use standard sock_def_readable() function for
their sk_data_ready() handler, and sock_def_readable() doesnt signal
POLLPRI.
Only TCP is affected by the problem. Adding POLLPRI to the list of flags
might trigger unnecessary schedules, but URGENT handling is such a
seldom used feature this seems a good compromise.
Thanks a lot to Leonardo for providing the bisection result and a test
program as well.
Reference : http://www.spinics.net/lists/netdev/msg151793.html
Reported-and-bisected-by: Leonardo Chiquitto <leonardo.lists@gmail.com>
Tested-by: Eric Dumazet <eric.dumazet@gmail.com>
drivers/net/bnx2x/bnx2x.h
drivers/net/wireless/iwlwifi/iwl-1000.c
drivers/net/wireless/iwlwifi/iwl-6000.c
drivers/net/wireless/iwlwifi/iwl-core.h
drivers/vhost/vhost.c
Special care is taken inside sk_port_alloc to avoid overwriting
skc_node/skc_nulls_node. We should also avoid overwriting
skc_bind_node/skc_portaddr_node.
The patch fixes the following crash:
BUG: unable to handle kernel paging request at fffffffffffffff0
IP: [<ffffffff812ec6dd>] udp4_lib_lookup2+0xad/0x370
[<ffffffff812ecc22>] __udp4_lib_lookup+0x282/0x360
[<ffffffff812ed63e>] __udp4_lib_rcv+0x31e/0x700
[<ffffffff812bba45>] ? ip_local_deliver_finish+0x65/0x190
[<ffffffff812bbbf8>] ? ip_local_deliver+0x88/0xa0
[<ffffffff812eda35>] udp_rcv+0x15/0x20
[<ffffffff812bba45>] ip_local_deliver_finish+0x65/0x190
[<ffffffff812bbbf8>] ip_local_deliver+0x88/0xa0
[<ffffffff812bb2cd>] ip_rcv_finish+0x32d/0x6f0
[<ffffffff8128c14c>] ? netif_receive_skb+0x99c/0x11c0
[<ffffffff812bb94b>] ip_rcv+0x2bb/0x350
[<ffffffff8128c14c>] netif_receive_skb+0x99c/0x11c0
Signed-off-by: Leonard Crestez <lcrestez@ixiacom.com>
Signed-off-by: Octavian Purdila <opurdila@ixiacom.com>
Followup of commit b178bb3dfc30 (net: reorder struct sock fields)
Optimize INET input path a bit further, by :
1) moving sk_refcnt close to sk_lock.
This reduces number of dirtied cache lines by one on 64bit arches (and
64 bytes cache line size).
2) moving inet_daddr & inet_rcv_saddr at the beginning of sk
(same cache line than hash / family / bound_dev_if / nulls_node)
This reduces number of accessed cache lines in lookups by one, and dont
increase size of inet and timewait socks.
inet and tw sockets now share same place-holder for these fields.
Before patch :
offsetof(struct sock, sk_refcnt) = 0x10
offsetof(struct sock, sk_lock) = 0x40
offsetof(struct sock, sk_receive_queue) = 0x60
offsetof(struct inet_sock, inet_daddr) = 0x270
offsetof(struct inet_sock, inet_rcv_saddr) = 0x274
After patch :
offsetof(struct sock, sk_refcnt) = 0x44
offsetof(struct sock, sk_lock) = 0x48
offsetof(struct sock, sk_receive_queue) = 0x68
offsetof(struct inet_sock, inet_daddr) = 0x0
offsetof(struct inet_sock, inet_rcv_saddr) = 0x4
compute_score() (udp or tcp) now use a single cache line per ignored
item, instead of two.
Signed-off-by: Miloslav Trmač <mitr@redhat.com>
Robin Holt tried to boot a 16TB machine and found some limits were
reached : sysctl_tcp_mem[2], sysctl_udp_mem[2]
We can switch infrastructure to use long "instead" of "int", now
atomic_long_t primitives are available for free.
Reported-by: Robin Holt <holt@sgi.com>
Reviewed-by: Robin Holt <holt@sgi.com>
Add __rcu annotation to :
(struct sock)->sk_filter
And use appropriate rcu primitives to reduce sparse warnings if
CONFIG_SPARSE_RCU_POINTER=y
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1699 commits)
bnx2/bnx2x: Unsupported Ethtool operations should return -EINVAL.
vlan: Calling vlan_hwaccel_do_receive() is always valid.
tproxy: use the interface primary IP address as a default value for --on-ip
tproxy: added IPv6 support to the socket match
cxgb3: function namespace cleanup
tproxy: added IPv6 support to the TPROXY target
tproxy: added IPv6 socket lookup function to nf_tproxy_core
be2net: Changes to use only priority codes allowed by f/w
tproxy: allow non-local binds of IPv6 sockets if IP_TRANSPARENT is enabled
tproxy: added tproxy sockopt interface in the IPV6 layer
tproxy: added udp6_lib_lookup function
tproxy: added const specifiers to udp lookup functions
tproxy: split off ipv6 defragmentation to a separate module
l2tp: small cleanup
nf_nat: restrict ICMP translation for embedded header
can: mcp251x: fix generation of error frames
can: mcp251x: fix endless loop in interrupt handler if CANINTF_MERRF is set
can-raw: add msg_flags to distinguish local traffic
9p: client code cleanup
rds: make local functions/variables static
Fix up conflicts in net/core/dev.c, drivers/net/pcmcia/smc91c92_cs.c and
drivers/net/wireless/ath/ath9k/debug.c as per David
> [ INFO: suspicious rcu_dereference_check() usage. ]
> include/linux/cgroup.h:542 invoked rcu_dereference_check() without protection!
> other info that might help us debug this:
> rcu_scheduler_active = 1, debug_locks = 0
> 1 lock held by swapper/1:
> #0: (net_mutex){+.+.+.}, at: [<ffffffff813e9010>]
> register_pernet_subsys+0x1f/0x47
> stack backtrace:
> Pid: 1, comm: swapper Not tainted 2.6.35.4-28.fc14.x86_64 #1
> Call Trace:
> [<ffffffff8107bd3a>] lockdep_rcu_dereference+0xaa/0xb3
> [<ffffffff813e04b9>] sock_update_classid+0x7c/0xa2
> [<ffffffff813e054a>] sk_alloc+0x6b/0x77
> [<ffffffff8140b281>] __netlink_create+0x37/0xab
> [<ffffffff813f941c>] ? rtnetlink_rcv+0x0/0x2d
> [<ffffffff8140cee1>] netlink_kernel_create+0x74/0x19d
> [<ffffffff8149c3ca>] ? __mutex_lock_common+0x339/0x35b
> [<ffffffff813f7e9c>] rtnetlink_net_init+0x2e/0x48
> [<ffffffff813e8d7a>] ops_init+0xe9/0xff
> [<ffffffff813e8f0d>] register_pernet_operations+0xab/0x130
> [<ffffffff813e901f>] register_pernet_subsys+0x2e/0x47
> [<ffffffff81db7bca>] rtnetlink_init+0x53/0x102
> [<ffffffff81db835c>] netlink_proto_init+0x126/0x143
> [<ffffffff81db8236>] ? netlink_proto_init+0x0/0x143
> [<ffffffff810021b8>] do_one_initcall+0x72/0x186
> [<ffffffff81d78ebc>] kernel_init+0x23b/0x2c9
> [<ffffffff8100aae4>] kernel_thread_helper+0x4/0x10
> [<ffffffff8149e2d0>] ? restore_args+0x0/0x30
> [<ffffffff81d78c81>] ? kernel_init+0x0/0x2c9
> [<ffffffff8100aae0>] ? kernel_thread_helper+0x0/0x10
The sock_update_classid() function calls task_cls_classid(current),
but the calling task cannot go away, so there is no danger of
the associated structures disappearing. Insert an RCU read-side
critical section to suppress the false positive.
Reported-by: Subrata Modak <subrata@linux.vnet.ibm.com>
drivers/net/qlcnic/qlcnic_init.c
net/ipv4/ip_output.c
We have for each socket :
One spinlock (sk_slock.slock)
One rwlock (sk_callback_lock)
Possible scenarios are :
(A) (this is used in net/sunrpc/xprtsock.c)
read_lock(&sk->sk_callback_lock) (without blocking BH)
<BH>
spin_lock(&sk->sk_slock.slock);
read_lock(&sk->sk_callback_lock);
(B)
write_lock_bh(&sk->sk_callback_lock)
stuff
write_unlock_bh(&sk->sk_callback_lock)
(C)
spin_lock_bh(&sk->sk_slock)
stuff
spin_unlock_bh(&sk->sk_slock)
This (C) case conflicts with (A) :
CPU1 [A] CPU2 [C]
read_lock(callback_lock)
<BH> spin_lock_bh(slock)
<wait to spin_lock(slock)>
<wait to write_lock_bh(callback_lock)>
We have one problematic (C) use case in inet_csk_listen_stop() :
local_bh_disable();
bh_lock_sock(child); // spin_lock_bh(&sk->sk_slock)
WARN_ON(sock_owned_by_user(child));
sock_orphan(child); // write_lock_bh(&sk->sk_callback_lock)
lockdep is not happy with this, as reported by Tetsuo Handa
It seems only way to deal with this is to use read_lock_bh(callbacklock)
everywhere.
Thanks to Jarek for pointing a bug in my first attempt and suggesting
this solution.
Reported-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
Tested-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
CC: Jarek Poplawski <jarkao2@gmail.com>
__lock_sock() and __release_sock() releases and regrabs lock but
were missing proper annotations. Add it. This removes following
warning from sparse. (Currently __lock_sock() does not emit any
warning about it but I think it is better to add also.)
net/core/sock.c:1580:17: warning: context imbalance in '__release_sock' - unexpected unlock
Signed-off-by: Namhyung Kim <namhyung@gmail.com>
Use modern this_cpu_xxx() api, saving few bytes on x86
Avoid two extra instructions in sock_free(), to reload
skb->truesize and skb->sk
AF_UNIX references this, and can be built as a module,
so...
Use struct pid and struct cred to store the peer credentials on struct
sock. This gives enough information to convert the peer credential
information to a value relative to whatever namespace the socket is in
at the time.
This removes nasty surprises when using SO_PEERCRED on socket
connetions where the processes on either side are in different pid and
user namespaces.
Acked-by: Daniel Lezcano <daniel.lezcano@free.fr>
Acked-by: Pavel Emelyanov <xemul@openvz.org>
To keep the coming code clear and to allow both the sock
code and the scm code to share the logic introduce a
fuction to translate from struct cred to struct ucred.
CAIF is using "xxx-AF_MAX" strings for the lock validator. It should use
its own strings.
Signed-off-by: Alex Lorca <alex.lorca@gmail.com>
This new sock lock primitive was introduced to speedup some user context
socket manipulation. But it is unsafe to protect two threads, one using
regular lock_sock/release_sock, one using lock_sock_bh/unlock_sock_bh
This patch changes lock_sock_bh to be careful against 'owned' state.
If owned is found to be set, we must take the slow path.
lock_sock_bh() now returns a boolean to say if the slow path was taken,
and this boolean is used at unlock_sock_bh time to call the appropriate
unlock function.
After this change, BH are either disabled or enabled during the
lock_sock_bh/unlock_sock_bh protected section. This might be misleading,
so we rename these functions to lock_sock_fast()/unlock_sock_fast().
Reported-by: Anton Blanchard <anton@samba.org>
Tested-by: Anton Blanchard <anton@samba.org>
This patch makes tun update its socket classid every time we
inject a packet into the network stack. This is so that any
updates made by the admin to the process writing packets to
tun is effected.
Up until now cls_cgroup has relied on fetching the classid out of
the current executing thread. This runs into trouble when a packet
processing is delayed in which case it may execute out of another
thread's context.
Furthermore, even when a packet is not delayed we may fail to
classify it if soft IRQs have been disabled, because this scenario
is indistinguishable from one where a packet unrelated to the
current thread is processed by a real soft IRQ.
In fact, the current semantics is inherently broken, as a single
skb may be constructed out of the writes of two different tasks.
A different manifestation of this problem is when the TCP stack
transmits in response of an incoming ACK. This is currently
unclassified.
As we already have a concept of packet ownership for accounting
purposes in the skb->sk pointer, this is a natural place to store
the classid in a persistent manner.
This patch adds the cls_cgroup classid in struct sock, filling up
an existing hole on 64-bit :)
The value is set at socket creation time. So all sockets created
via socket(2) automatically gains the ID of the thread creating it.
Whenever another process touches the socket by either reading or
writing to it, we will change the socket classid to that of the
process if it has a valid (non-zero) classid.
For sockets created on inbound connections through accept(2), we
inherit the classid of the original listening socket through
sk_clone, possibly preceding the actual accept(2) call.
In order to minimise risks, I have not made this the authoritative
classid. For now it is only used as a backup when we execute
with soft IRQs disabled. Once we're completely happy with its
semantics we can use it as the sole classid.
Footnote: I have rearranged the error path on cls_group module
creation. If we didn't do this, then there is a window where
someone could create a tc rule using cls_group before the cgroup
subsystem has been registered.
Use low order bit of skb->_skb_dst to tell dst is not refcounted.
Change _skb_dst to _skb_refdst to make sure all uses are catched.
skb_dst() returns the dst, regardless of noref bit set or not, but
with a lockdep check to make sure a noref dst is not given if current
user is not rcu protected.
New skb_dst_set_noref() helper to set an notrefcounted dst on a skb.
(with lockdep check)
skb_dst_drop() drops a reference only if skb dst was refcounted.
skb_dst_force() helper is used to force a refcount on dst, when skb
is queued and not anymore RCU protected.
Use skb_dst_force() in __sk_add_backlog(), __dev_xmit_skb() if
!IFF_XMIT_DST_RELEASE or skb enqueued on qdisc queue, in
sock_queue_rcv_skb(), in __nf_queue().
Use skb_dst_force() in dev_requeue_skb().
Note: dst_use_noref() still dirties dst, we might transform it
later to do one dirtying per jiffies.
TCP-MD5 sessions have intermittent failures, when route cache is
invalidated. ip_queue_xmit() has to find a new route, calls
sk_setup_caps(sk, &rt->u.dst), destroying the
sk->sk_route_caps &= ~NETIF_F_GSO_MASK
that MD5 desperately try to make all over its way (from
tcp_transmit_skb() for example)
So we send few bad packets, and everything is fine when
tcp_transmit_skb() is called again for this socket.
Since ip_queue_xmit() is at a lower level than TCP-MD5, I chose to use a
socket field, sk_route_nocaps, containing bits to mask on sk_route_caps.
Reported-by: Bhaskar Dutta <bhaskie@gmail.com>
sk_callback_lock rwlock actually protects sk->sk_sleep pointer, so we
need two atomic operations (and associated dirtying) per incoming
packet.
RCU conversion is pretty much needed :
1) Add a new structure, called "struct socket_wq" to hold all fields
that will need rcu_read_lock() protection (currently: a
wait_queue_head_t and a struct fasync_struct pointer).
[Future patch will add a list anchor for wakeup coalescing]
2) Attach one of such structure to each "struct socket" created in
sock_alloc_inode().
3) Respect RCU grace period when freeing a "struct socket_wq"
4) Change sk_sleep pointer in "struct sock" by sk_wq, pointer to "struct
socket_wq"
5) Change sk_sleep() function to use new sk->sk_wq instead of
sk->sk_sleep
6) Change sk_has_sleeper() to wq_has_sleeper() that must be used inside
a rcu_read_lock() section.
7) Change all sk_has_sleeper() callers to :
- Use rcu_read_lock() instead of read_lock(&sk->sk_callback_lock)
- Use wq_has_sleeper() to eventually wakeup tasks.
- Use rcu_read_unlock() instead of read_unlock(&sk->sk_callback_lock)
8) sock_wake_async() is modified to use rcu protection as well.
9) Exceptions :
macvtap, drivers/net/tun.c, af_unix use integrated "struct socket_wq"
instead of dynamically allocated ones. They dont need rcu freeing.
Some cleanups or followups are probably needed, (possible
sk_callback_lock conversion to a spinlock for example...).
Current socket backlog limit is not enough to really stop DDOS attacks,
because user thread spend many time to process a full backlog each
round, and user might crazy spin on socket lock.
We should add backlog size and receive_queue size (aka rmem_alloc) to
pace writers, and let user run without being slow down too much.
Introduce a sk_rcvqueues_full() helper, to avoid taking socket lock in
stress situations.
Under huge stress from a multiqueue/RPS enabled NIC, a single flow udp
receiver can now process ~200.000 pps (instead of ~100 pps before the
patch) on a 8 core machine.
Define a new function to return the waitqueue of a "struct sock".
static inline wait_queue_head_t *sk_sleep(struct sock *sk)
return sk->sk_sleep;
Change all read occurrences of sk_sleep by a call to this function.
Needed for a future RCU conversion. sk_sleep wont be a field directly
available.
With latest CONFIG_PROVE_RCU stuff, I felt more comfortable to make this
work.
sk->sk_dst_cache is currently protected by a rwlock (sk_dst_lock)
This rwlock is readlocked for a very small amount of time, and dst
entries are already freed after RCU grace period. This calls for RCU
again :)
This patch converts sk_dst_lock to a spinlock, and use RCU for readers.
__sk_dst_get() is supposed to be called with rcu_read_lock() or if
socket locked by user, so use appropriate rcu_dereference_check()
condition (rcu_read_lock_held() || sock_owned_by_user(sk))
This patch avoids two atomic ops per tx packet on UDP connected sockets,
for example, and permits sk_dst_lock to be much less dirtied.
We test that "prot->rsk_prot" is non-null right before we dereference it
on this line.
sk_add_backlog -> __sk_add_backlog
sk_add_backlog_limited -> sk_add_backlog
Signed-off-by: Zhu Yi <yi.zhu@intel.com>
We got system OOM while running some UDP netperf testing on the loopback
device. The case is multiple senders sent stream UDP packets to a single
receiver via loopback on local host. Of course, the receiver is not able
to handle all the packets in time. But we surprisingly found that these
packets were not discarded due to the receiver's sk->sk_rcvbuf limit.
Instead, they are kept queuing to sk->sk_backlog and finally ate up all
the memory. We believe this is a secure hole that a none privileged user
can crash the system.
The root cause for this problem is, when the receiver is doing
__release_sock() (i.e. after userspace recv, kernel udp_recvmsg ->
skb_free_datagram_locked -> release_sock), it moves skbs from backlog to
sk_receive_queue with the softirq enabled. In the above case, multiple
busy senders will almost make it an endless loop. The skbs in the
backlog end up eat all the system memory.
The issue is not only for UDP. Any protocols using socket backlog is
potentially affected. The patch adds limit for socket backlog so that
the backlog size cannot be expanded endlessly.
Reported-by: Alex Shi <alex.shi@intel.com>
Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net>
Cc: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru
Cc: "Pekka Savola (ipv6)" <pekkas@netcore.fi>
Cc: Patrick McHardy <kaber@trash.net>
Cc: Vlad Yasevich <vladislav.yasevich@hp.com>
Cc: Sridhar Samudrala <sri@us.ibm.com>
Cc: Jon Maloy <jon.maloy@ericsson.com>
Cc: Allan Stephens <allan.stephens@windriver.com>
Cc: Andrew Hendry <andrew.hendry@gmail.com>
Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com>
drivers/firmware/iscsi_ibft.c
Update rcu_dereference() primitives to use new lockdep-based
checking. The rcu_dereference() in __in6_dev_get() may be
protected either by rcu_read_lock() or RTNL, per Eric Dumazet.
The rcu_dereference() in __sk_free() is protected by the fact
that it is never reached if an update could change it. Check
for this by using rcu_dereference_check() to verify that the
struct sock's ->sk_wmem_alloc counter is zero.
Cc: laijs@cn.fujitsu.com
Cc: dipankar@in.ibm.com
Cc: mathieu.desnoyers@polymtl.ca
Cc: josh@joshtriplett.org
Cc: dvhltc@us.ibm.com
Cc: niv@us.ibm.com
Cc: peterz@infradead.org
Cc: rostedt@goodmis.org
Cc: Valdis.Kletnieks@vt.edu
Cc: dhowells@redhat.com
LKML-Reference: <1266887105-1528-5-git-send-email-paulmck@linux.vnet.ibm.com>
kasprintf() makes code smaller.
__net_init/__net_exit are apparently not going away, so use them
to full extent.
In some cases __net_init was removed, because it was called from
__net_exit code.
In sock_getsockopt the symbol 'lv' is declared as an
unsigned int type, probably due to sizeof returning a
size_t which is really an unsigned int.
This produces a sparse warning for SO_PEERNAME due to
the sock->ops->getname() call:
warning: incorrect type in argument 3 (different signedness)
expected int *sockaddr_len
got unsigned int *<noident>
Quiet the warning by changing the type of 'lv' to an int.
This fixes a netstamp_needed accounting issue when the listen socket
has SO_TIMESTAMP set:
s = socket(AF_INET, SOCK_STREAM, 0);
setsockopt(s, SOL_SOCKET, SO_TIMESTAMP, 1); -> netstamp_needed = 1
bind(s, ...);
listen(s, ...);
s2 = accept(s, ...); -> netstamp_needed = 1
close(s2); -> netstamp_needed = 0
close(s); -> netstamp_needed = -1
net/core/sock.c: In function 'sock_setsockopt':
net/core/sock.c:396: warning: 'index' may be used uninitialized in this function
net/core/sock.c:396: note: 'index' was declared here
GCC can't see that all paths initialize index, so just
set it to the default (0) and eliminate the specific
code block that handles the null device name string.
Avoid dev_hold()/dev_put() in sock_bindtodevice()
dst_negative_advice() should check for changed dst and reset
sk_tx_queue_mapping accordingly. Pass sock to the callers of
dst_negative_advice.
(sk_reset_txq is defined just for use by dst_negative_advice. The
only way I could find to get around this is to move dst_negative_()
from dst.h to dst.c, include sock.h in dst.c, etc)
Signed-off-by: Krishna Kumar <krkumar2@in.ibm.com>
Introduce sk_tx_queue_mapping; and functions that set, test and
get this value. Reset sk_tx_queue_mapping to -1 whenever the dst
cache is set/reset, and in socket alloc. Setting txq to -1 and
using valid txq=<0 to n-1> allows the tx path to use the value
of sk_tx_queue_mapping directly instead of subtracting 1 on every
tx.
sock_queue_rcv_skb() can update sk_drops itself, removing need for
callers to take care of it. This is more consistent since
sock_queue_rcv_skb() also reads sk_drops when queueing a skb.
This adds sk_drops managment to many protocols that not cared yet.
Create a new socket level option to report number of queue overflows
Recently I augmented the AF_PACKET protocol to report the number of frames lost
on the socket receive queue between any two enqueued frames. This value was
exported via a SOL_PACKET level cmsg. AFter I completed that work it was
requested that this feature be generalized so that any datagram oriented socket
could make use of this option. As such I've created this patch, It creates a
new SOL_SOCKET level option called SO_RXQ_OVFL, which when enabled exports a
SOL_SOCKET level cmsg that reports the nubmer of times the sk_receive_queue
overflowed between any two given frames. It also augments the AF_PACKET
protocol to take advantage of this new feature (as it previously did not touch
sk->sk_drops, which this patch uses to record the overflow count). Tested
successfully by me.
Notes:
1) Unlike my previous patch, this patch simply records the sk_drops value, which
is not a number of drops between packets, but rather a total number of drops.
Deltas must be computed in user space.
2) While this patch currently works with datagram oriented protocols, it will
also be accepted by non-datagram oriented protocols. I'm not sure if thats
agreeable to everyone, but my argument in favor of doing so is that, for those
protocols which aren't applicable to this option, sk_drops will always be zero,
and reporting no drops on a receive queue that isn't used for those
non-participating protocols seems reasonable to me. This also saves us having
to code in a per-protocol opt in mechanism.
3) This applies cleanly to net-next assuming that commit
977750076d98c7ff6cbda51858bb5a5894a9d9ab (my af packet cmsg patch) is reverted
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
Commit 2b85a34e911bf483c27cfdd124aeb1605145dc80
(net: No more expensive sock_hold()/sock_put() on each tx)
opens a window in sock_wfree() where another cpu
might free the socket we are working on.
A fix is to call sk->sk_write_space(sk) while still
holding a reference on sk.
Reported-by: Jike Song <albcamus@gmail.com>
This provides safety against negative optlen at the type
level instead of depending upon (sometimes non-trivial)
checks against this sprinkled all over the the place, in
each and every implementation.
Based upon work done by Arjan van de Ven and feedback
from Linus Torvalds.
Sizing of memory allocations shouldn't depend on the number of physical
pages found in a system, as that generally includes (perhaps a huge amount
of) non-RAM pages. The amount of what actually is usable as storage
should instead be used as a basis here.
Some of the calculations (i.e. those not intending to use high memory)
should likely even use (totalram_pages - totalhigh_pages).
Signed-off-by: Jan Beulich <jbeulich@novell.com>
Acked-by: Rusty Russell <rusty@rustcorp.com.au>
Cc: Dave Airlie <airlied@linux.ie>
Cc: Kyle McMartin <kyle@mcmartin.ca>
Cc: Pekka Enberg <penberg@cs.helsinki.fi>
Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk>
drivers/net/yellowfin.c
After commit 2b85a34e911bf483c27cfdd124aeb1605145dc80
sk_free() frees socks conditionally and depends
on sk_wmem_alloc being set e.g. in sock_init_data(). But in some
cases sk_free() is called earlier, usually after other alloc errors.
Fix is to move sk_wmem_alloc initialization from sock_init_data()
to sk_alloc() itself.
Signed-off-by: Jarek Poplawski <jarkao2@gmail.com>
