path: root/net/core
2010-01-12Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (56 commits) sky2: Fix oops in sky2_xmit_frame() after TX timeout Documentation/3c509: document ethtool support af_packet: Don't use skb after dev_queue_xmit() vxge: use pci_dma_mapping_error to test return value netfilter: ebtables: enforce CAP_NET_ADMIN e1000e: fix and commonize code for setting the receive address registers e1000e: e1000e_enable_tx_pkt_filtering() returns wrong value e1000e: perform 10/100 adaptive IFS only on parts that support it e1000e: don't accumulate PHY statistics on PHY read failure e1000e: call pci_save_state() after pci_restore_state() netxen: update version to 4.0.72 netxen: fix set mac addr netxen: fix smatch warning netxen: fix tx ring memory leak tcp: update the netstamp_needed counter when cloning sockets TI DaVinci EMAC: Handle emac module clock correctly. dmfe/tulip: Let dmfe handle DM910x except for SPARC on-board chips ixgbe: Fix compiler warning about variable being used uninitialized netfilter: nf_ct_ftp: fix out of bounds read in update_nl_seq() mv643xx_eth: don't include cache padding in rx desc buffer size ... Fix trivial conflict in drivers/scsi/cxgb3i/cxgb3i_offload.c
2010-01-08tcp: update the netstamp_needed counter when cloning socketsOctavian Purdila
This fixes a netstamp_needed accounting issue when the listen socket has SO_TIMESTAMP set: s = socket(AF_INET, SOCK_STREAM, 0); setsockopt(s, SOL_SOCKET, SO_TIMESTAMP, 1); -> netstamp_needed = 1 bind(s, ...); listen(s, ...); s2 = accept(s, ...); -> netstamp_needed = 1 close(s2); -> netstamp_needed = 0 close(s); -> netstamp_needed = -1 Signed-off-by: Octavian Purdila <opurdila@ixiacom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-30Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (74 commits) Revert "b43: Enforce DMA descriptor memory constraints" iwmc3200wifi: fix array out-of-boundary access wl1251: timeout one too soon in wl1251_boot_run_firmware() mac80211: fix propagation of failed hardware reconfigurations mac80211: fix race with suspend and dynamic_ps_disable_work ath9k: fix missed error codes in the tx status check ath9k: wake hardware during AMPDU TX actions ath9k: wake hardware for interface IBSS/AP/Mesh removal ath9k: fix suspend by waking device prior to stop cfg80211: fix error path in cfg80211_wext_siwscan wl1271_cmd.c: cleanup char => u8 iwlwifi: Storage class should be before const qualifier ath9k: Storage class should be before const qualifier cfg80211: fix race between deauth and assoc response wireless: remove remaining qual code rt2x00: Add USB ID for Linksys WUSB 600N rev 2. ath5k: fix SWI calibration interrupt storm mac80211: fix ibss join with fixed-bssid libertas: Remove carrier signaling from the scan code orinoco: fix GFP_KERNEL in orinoco_set_key with interrupts disabled ...
2009-12-23pktgen: ndo_start_xmit can return NET_XMIT_xxx valuesJohn Fastabend
This updates pktgen so that it does not decrement skb->users when it receives valid NET_XMIT_xxx values. These are now valid return values from ndo_start_xmit in net-next-2.6. They also indicate the skb has been consumed. This fixes pktgen to work correctly with vlan devices. Signed-off-by: John Fastabend <john.r.fastabend@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-16Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (26 commits) net: sh_eth alignment fix for sh7724 using NET_IP_ALIGN V2 ixgbe: allow tx of pre-formatted vlan tagged packets ixgbe: Fix 82598 premature copper PHY link indicatation ixgbe: Fix tx_restart_queue/non_eop_desc statistics counters bcm63xx_enet: fix compilation failure after get_stats_count removal packet: dont call sleeping functions while holding rcu_read_lock() tcp: Revert per-route SACK/DSACK/TIMESTAMP changes. ipvs: zero usvc and udest netfilter: fix crashes in bridge netfilter caused by fragment jumps ipv6: reassembly: use seperate reassembly queues for conntrack and local delivery sky2: leave PCI config space writeable sky2: print Optima chip name x25: Update maintainer. ipvs: fix synchronization on connection close netfilter: xtables: document minimal required version drivers/net/bonding/: : use pr_fmt can: CAN_MCP251X should depend on HAS_DMA drivers/net/usb: Correct code taking the size of a pointer drivers/net/cpmac.c: Correct code taking the size of a pointer drivers/net/sfc: Correct code taking the size of a pointer ...
2009-12-16const: constify remaining pipe_buf_operationsAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-13net: Fix userspace RTM_NEWLINK notifications.Eric W. Biederman
I received some bug reports about userspace programs having problems because after RTM_NEWLINK was received they could not immediate access files under /proc/sys/net/ because they had not been registered yet. The original problem was trivially fixed by moving the userspace notification from rtnetlink_event() to the end of register_netdevice(). When testing that change I discovered I was still getting RTM_NEWLINK events before I could access proc and I was also getting RTM_NEWLINK events after I was seeing RTM_DELLINK. Things practically guaranteed to confuse userspace. After a little more investigation these extra notifications proved to be from the new notifiers NETDEV_POST_INIT and NETDEV_UNREGISTER_BATCH hitting the default case in rtnetlink_event, and triggering unnecessary RTM_NEWLINK messages. rtnetlink_event now explicitly handles NETDEV_UNREGISTER_BATCH and NETDEV_POST_INIT to avoid sending the incorrect userspace notifications. Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-11net: Handle NETREG_UNINITIALIZED devices correctlyKrishna Kumar
Fix two problems: 1. If unregister_netdevice_many() is called with both registered and unregistered devices, rollback_registered_many() bails out when it reaches the first unregistered device. The processing of the prior registered devices is unfinished, and the remaining devices are skipped, and possible registered netdev's are leaked/unregistered. 2. System hangs or panics depending on how the devices are passed, since when netdev_run_todo() runs, some devices were not fully processed. Tested by passing intermingled unregistered and registered vlan devices to unregister_netdevice_many() as follows: 1. dev, fake_dev1, fake_dev2: hangs in run_todo ("unregister_netdevice: waiting for eth1.100 to become free. Usage count = 1") 2. fake_dev1, dev, fake_dev2: failure during de-registration and next registration, followed by a vlan driver Oops during subsequent registration. Confirmed that the patch fixes both cases. Signed-off-by: Krishna Kumar <krkumar2@in.ibm.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-08Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1815 commits) mac80211: fix reorder buffer release iwmc3200wifi: Enable wimax core through module parameter iwmc3200wifi: Add wifi-wimax coexistence mode as a module parameter iwmc3200wifi: Coex table command does not expect a response iwmc3200wifi: Update wiwi priority table iwlwifi: driver version track kernel version iwlwifi: indicate uCode type when fail dump error/event log iwl3945: remove duplicated event logging code b43: fix two warnings ipw2100: fix rebooting hang with driver loaded cfg80211: indent regulatory messages with spaces iwmc3200wifi: fix NULL pointer dereference in pmkid update mac80211: Fix TX status reporting for injected data frames ath9k: enable 2GHz band only if the device supports it airo: Fix integer overflow warning rt2x00: Fix padding bug on L2PAD devices. WE: Fix set events not propagated b43legacy: avoid PPC fault during resume b43: avoid PPC fault during resume tcp: fix a timewait refcnt race ... Fix up conflicts due to sysctl cleanups (dead sysctl_check code and CTL_UNNUMBERED removed) in kernel/sysctl_check.c net/ipv4/sysctl_net_ipv4.c net/ipv6/addrconf.c net/sctp/sysctl.c
2009-12-08Merge git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/sysctl-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/sysctl-2.6: (43 commits) security/tomoyo: Remove now unnecessary handling of security_sysctl. security/tomoyo: Add a special case to handle accesses through the internal proc mount. sysctl: Drop & in front of every proc_handler. sysctl: Remove CTL_NONE and CTL_UNNUMBERED sysctl: kill dead ctl_handler definitions. sysctl: Remove the last of the generic binary sysctl support sysctl net: Remove unused binary sysctl code sysctl security/tomoyo: Don't look at ctl_name sysctl arm: Remove binary sysctl support sysctl x86: Remove dead binary sysctl support sysctl sh: Remove dead binary sysctl support sysctl powerpc: Remove dead binary sysctl support sysctl ia64: Remove dead binary sysctl support sysctl s390: Remove dead sysctl binary support sysctl frv: Remove dead binary sysctl support sysctl mips/lasat: Remove dead binary sysctl support sysctl drivers: Remove dead binary sysctl support sysctl crypto: Remove dead binary sysctl support sysctl security/keys: Remove dead binary sysctl support sysctl kernel: Remove binary sysctl logic ...
2009-12-05Merge branch 'master' of /home/davem/src/GIT/linux-2.6/David S. Miller
Conflicts: drivers/net/pcmcia/fmvj18x_cs.c drivers/net/pcmcia/nmclan_cs.c drivers/net/pcmcia/xirc2ps_cs.c drivers/net/wireless/ray_cs.c
2009-12-05Merge branch 'core-printk-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-printk-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: ratelimit: Make suppressed output messages more useful printk: Remove ratelimit.h from kernel.h ratelimit: Fix/allow use in atomic contexts ratelimit: Use per ratelimit context locking
2009-12-03netdevice: provide common routine for macvlan and vlan operstate managementPatrick Mullaney
Provide common routine for the transition of operational state for a leaf device during a root device transition. Signed-off-by: Patrick Mullaney <pmullaney@novell.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-03net: Allow fib_rule_unregister to batchEric W. Biederman
Refactor the code so fib_rules_register always takes a template instead of the actual fib_rules_ops structure that will be used. This is required for network namespace support so 2 out of the 3 callers already do this, it allows the error handling to be made common, and it allows fib_rules_unregister to free the template for hte caller. Modify fib_rules_unregister to use call_rcu instead of syncrhonize_rcu to allw multiple namespaces to be cleaned up in the same rcu grace period. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-03netns: Add an explicit rcu_barrier to unregister_pernet_{device|subsys}Eric W. Biederman
This allows namespace exit methods to batch work that comes requires an rcu barrier using call_rcu without having to treat the unregister_pernet_operations cases specially. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-03net: Move network device exit batchingEric W. Biederman
Move network device exit batching from a special case in net_namespace.c to using common mechanisms in dev.c Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-03net: Add support for batching network namespace cleanupsEric W. Biederman
- Add exit_list to struct net to support building lists of network namespaces to cleanup. - Add exit_batch to pernet_operations to allow running operations only once during a network namespace exit. Instead of once per network namespace. - Factor opt ops_exit_list and ops_exit_free so the logic with cleanup up a network namespace does not need to be duplicated. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-03net 04/05: fib_rules: allow to delete local rulePatrick McHardy
commit d124356ce314fff22a047ea334379d5105b2d834 Author: Patrick McHardy <kaber@trash.net> Date: Thu Dec 3 12:16:35 2009 +0100 net: fib_rules: allow to delete local rule Allow to delete the local rule and recreate it with a higher priority. This can be used to force packets with a local destination out on the wire instead of routing them to loopback. Additionally this patch allows to recreate rules with a priority of 0. Combined with the previous patch to allow oif classification, a socket can be bound to the desired interface and packets routed to the wire like this: # move local rule to lower priority ip rule add pref 1000 lookup local ip rule del pref 0 # route packets of sockets bound to eth0 to the wire independant # of the destination address ip rule add pref 100 oif eth0 lookup 100 ip route add default dev eth0 table 100 Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-03net 03/05: fib_rules: add oif classificationPatrick McHardy
commit 68144d350f4f6c348659c825cde6a82b34c27a91 Author: Patrick McHardy <kaber@trash.net> Date: Thu Dec 3 12:05:25 2009 +0100 net: fib_rules: add oif classification Support routing table lookup based on the flow's oif. This is useful to classify packets originating from sockets bound to interfaces differently. The route cache already includes the oif and needs no changes. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-03net 02/05: fib_rules: rename ifindex/ifname/FRA_IFNAME to ↵Patrick McHardy
iifindex/iifname/FRA_IIFNAME commit 229e77eec406ad68662f18e49fda8b5d366768c5 Author: Patrick McHardy <kaber@trash.net> Date: Thu Dec 3 12:05:23 2009 +0100 net: fib_rules: rename ifindex/ifname/FRA_IFNAME to iifindex/iifname/FRA_IIFNAME The next patch will add oif classification, rename interface related members and attributes to reflect that they're used for iif classification. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-02skbuff: remove skb_dma_map/unmapAlexander Duyck
The two functions skb_dma_map/unmap are unsafe to use as they cause problems when packets are cloned and sent to multiple devices while a HW IOMMU is enabled. Due to this it is best to remove the code so it is not used by any other network driver maintainters. Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-01net: Simplfy default_device_exit and improve batching.Eric W. Biederman
- Defer dellink to net_cleanup() allowing for batching. - Fix comment. - Use for_each_netdev_safe again as dev_change_net_namespace touches at most one network device (unlike veth dellink). Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-01net: Automatically allocate per namespace data.Eric W. Biederman
To get the full benefit of batched network namespace cleanup netowrk device deletion needs to be performed by the generic code. When using register_pernet_gen_device and freeing the data in exit_net it is impossible to delay allocation until after exit_net has called as the device uninit methods are no longer safe. To correct this, and to simplify working with per network namespace data I have moved allocation and deletion of per network namespace data into the network namespace core. The core now frees the data only after all of the network namespace exit routines have run. Now it is only required to set the new fields .id and .size in the pernet_operations structure if you want network namespace data to be managed for you automatically. This makes the current register_pernet_gen_device and register_pernet_gen_subsys routines unnecessary. For the moment I have left them as compatibility wrappers in net_namespace.h They will be removed once all of the users have been updated. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-01net: Batch network namespace destruction.Eric W. Biederman
It is fairly common to kill several network namespaces at once. Either because they are nested one inside the other or because they are cooperating in multiple machine networking experiments. As the network stack control logic does not parallelize easily batch up multiple network namespaces existing together. To get the full benefit of batching the virtual network devices to be removed must be all removed in one batch. For that purpose I have added a loop after the last network device operations have run that batches up all remaining network devices and deletes them. An extra benefit is that the reorganization slightly shrinks the size of the per network namespace data structures replaceing a work_struct with a list_head. In a trivial test with 4K namespaces this change reduced the cost of a destroying 4K namespaces from 7+ minutes (at 12% cpu) to 44 seconds (at 60% cpu). The bulk of that 44s was spent in inet_twsk_purge. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-01net: NETDEV_UNREGISTER_PERNET -> NETDEV_UNREGISTER_BATCHEric W. Biederman
The motivation for an additional notifier in batched netdevice notification (rt_do_flush) only needs to be called once per batch not once per namespace. For further batching improvements I need a guarantee that the netdevices are unregistered in order allowing me to unregister an all of the network devices in a network namespace at the same time with the guarantee that the loopback device is really and truly unregistered last. Additionally it appears that we moved the route cache flush after the final synchronize_net, which seems wrong and there was no explanation. So I have restored the original location of the final synchronize_net. Cc: Octavian Purdila <opurdila@ixiacom.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-29net: Move && and || to end of previous lineJoe Perches
Not including net/atm/ Compiled tested x86 allyesconfig only Added a > 80 column line or two, which I ignored. Existing checkpatch plaints willfully, cheerfully ignored. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-29pktgen: NUMA awareEric Dumazet
pktgen threads are bound to given CPU, we can allocate memory for these threads in a NUMA aware way. After a pktgen session on two threads, we can check flows memory was allocated on right node, instead of a not related one. # grep pktgen_thread_write /proc/vmallocinfo 0xffffc90007204000-0xffffc90007385000 1576960 pktgen_thread_write+0x3a4/0x6b0 [pktgen] pages=384 vmalloc N0=384 0xffffc90007386000-0xffffc90007507000 1576960 pktgen_thread_write+0x3a4/0x6b0 [pktgen] pages=384 vmalloc N1=384 Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-29Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/ieee802154/fakehard.c drivers/net/e1000e/ich8lan.c drivers/net/e1000e/phy.c drivers/net/netxen/netxen_nic_init.c drivers/net/wireless/ath/ath9k/main.c
2009-11-26veth: move loopback logic to common locationArnd Bergmann
The veth driver contains code to forward an skb from the start_xmit function of one network device into the receive path of another device. Moving that code into a common location lets us reuse the code for direct forwarding of data between macvlan ports, and possibly in other drivers. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-25net: use net_eq to compare netsOctavian Purdila
Generated with the following semantic patch @@ struct net *n1; struct net *n2; @@ - n1 == n2 + net_eq(n1, n2) @@ struct net *n1; struct net *n2; @@ - n1 != n2 + !net_eq(n1, n2) applied over {include,net,drivers/net}. Signed-off-by: Octavian Purdila <opurdila@ixiacom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-24pktgen: Fix netdevice unregisterEric Dumazet
When multi queue compatable names are used by pktgen (eg eth0@0), we currently cannot unload a NIC driver if one of its device is currently in use. Allow pktgen_find_dev() to find pktgen devices by their suffix (netdev name) Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-23pktgen: Fix device name comparesEric Dumazet
Commit e6fce5b916cd7f7f7 (pktgen: multiqueue etc.) tried to relax the pktgen restriction of one device per kernel thread, adding a '@' tag to device names. Problem is we dont perform check on full pktgen device name. This allows adding many time same 'device' to pktgen thread pgset "add_device eth0@0" one session later : pgset "add_device eth0@0" (This doesnt find previous device) This consumes ~1.5 MBytes of vmalloc memory per round and also triggers this warning : [ 673.186380] proc_dir_entry 'pktgen/eth0@0' already registered [ 673.186383] Modules linked in: pktgen ixgbe ehci_hcd psmouse mdio mousedev evdev [last unloaded: pktgen] [ 673.186406] Pid: 6219, comm: bash Tainted: G W 2.6.32-rc7-03302-g41cec6f-dirty #16 [ 673.186410] Call Trace: [ 673.186417] [<ffffffff8104a29b>] warn_slowpath_common+0x7b/0xc0 [ 673.186422] [<ffffffff8104a341>] warn_slowpath_fmt+0x41/0x50 [ 673.186426] [<ffffffff8114e789>] proc_register+0x109/0x210 [ 673.186433] [<ffffffff8100bf2e>] ? apic_timer_interrupt+0xe/0x20 [ 673.186438] [<ffffffff8114e905>] proc_create_data+0x75/0xd0 [ 673.186444] [<ffffffffa006ad38>] pktgen_thread_write+0x568/0x640 [pktgen] [ 673.186449] [<ffffffffa006a7d0>] ? pktgen_thread_write+0x0/0x640 [pktgen] [ 673.186453] [<ffffffff81149144>] proc_reg_write+0x84/0xc0 [ 673.186458] [<ffffffff810f5a58>] vfs_write+0xb8/0x180 [ 673.186463] [<ffffffff810f5c11>] sys_write+0x51/0x90 [ 673.186468] [<ffffffff8100b51b>] system_call_fastpath+0x16/0x1b [ 673.186470] ---[ end trace ccbb991b0a8d994d ]--- Solution to this problem is to use a odevname field (includes @ tag and suffix), instead of using netdevice name. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Robert Olsson <robert.olsson@its.uu.se> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-22net: Fix missing kernel-doc notationJaswinder Singh Rajput
Fix the following htmldocs warning: Warning(net/core/dev.c:5378): bad line: Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-20net: rename skb->iif to skb->skb_iifEric Dumazet
To help grep games, rename iif to skb_iif Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-18Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/sfc/sfe4001.c drivers/net/wireless/libertas/cmd.c drivers/staging/Kconfig drivers/staging/Makefile drivers/staging/rtl8187se/Kconfig drivers/staging/rtl8192e/Kconfig
2009-11-18net: device name allocation cleanupsOctavian Purdila
2009-11-18linkwatch: linkwatch_forget_dev() to speedup device dismantleEric Dumazet
Herbert Xu a écrit : > On Tue, Nov 17, 2009 at 04:26:04AM -0800, David Miller wrote: >> Really, the link watch stuff is just due for a redesign. I don't >> think a simple hack is going to cut it this time, sorry Eric :-) > > I have no objections against any redesigns, but since the only > caller of linkwatch_forget_dev runs in process context with the > RTNL, it could also legally emit those events. Thanks guys, here an updated version then, before linkwatch surgery ? In this version, I force the event to be sent synchronously. [PATCH net-next-2.6] linkwatch: linkwatch_forget_dev() to speedup device dismantle time ip link del eth3.103 ; time ip link del eth3.104 ; time ip link del eth3.105 real 0m0.266s user 0m0.000s sys 0m0.001s real 0m0.770s user 0m0.000s sys 0m0.000s real 0m1.022s user 0m0.000s sys 0m0.000s One problem of current schem in vlan dismantle phase is the holding of device done by following chain : vlan_dev_stop() -> netif_carrier_off(dev) -> linkwatch_fire_event(dev) -> dev_hold() ... And __linkwatch_run_queue() runs up to one second later... A generic fix to this problem is to add a linkwatch_forget_dev() method to unlink the device from the list of watched devices. dev->link_watch_next becomes dev->link_watch_list (and use a bit more memory), to be able to unlink device in O(1). After patch : time ip link del eth3.103 ; time ip link del eth3.104 ; time ip link del eth3.105 real 0m0.024s user 0m0.000s sys 0m0.000s real 0m0.032s user 0m0.000s sys 0m0.001s real 0m0.033s user 0m0.000s sys 0m0.000s Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-18net: introduce NETDEV_UNREGISTER_PERNETOctavian Purdila
This new event is called once for each unique net namespace in batched unregister operations (with the argument set to a random device from that namespace) and once per device in non-batched unregister operations. It allows us to factorize some device unregister work such as clearing the routing cache. Signed-off-by: Octavian Purdila <opurdila@ixiacom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-17net: add dev_txq_stats_fold() helperEric Dumazet
Some drivers ndo_get_stats() method need to perform txqueue stats folding. Move folding from dev_get_stats() to a new dev_txq_stats_fold() function Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-17gro: Fix illegal merging of trailer trashHerbert Xu
When we've merged skb's with page frags, and subsequently receive a trailer skb (< MSS) that is not completely non-linear (this can occur on Intel NICs if the packet size falls below the threshold), GRO ends up producing an illegal GSO skb with a frag_list. This is harmless unless the skb is then forwarded through an interface that requires software GSO, whereupon the GSO code will BUG. This patch detects this case in GRO and avoids merging the trailer skb. Reported-by: Mark Wagner <mwagner@redhat.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-17Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/can/Kconfig
2009-11-16net: Fix the rollback test in dev_change_name()Eric Dumazet
net: Fix the rollback test in dev_change_name() In dev_change_name() an err variable is used for storing the original call_netdevice_notifiers() errno (negative) and testing for a rollback error later, but the test for non-zero is wrong, because the err might have positive value as well - from dev_alloc_name(). It means the rollback for a netdevice with a number > 0 will never happen. (The err test is reordered btw. to make it more readable.) Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-15net: Optimize hard_start_xmit() return checkingJarek Poplawski
Recent changes in the TX error propagation require additional checking and masking of values returned from hard_start_xmit(), mainly to separate cases where skb was consumed. This aim can be simplified by changing the order of NETDEV_TX and NET_XMIT codes, because the latter are treated similarly to negative (ERRNO) values. After this change much simpler dev_xmit_complete() is also used in sch_direct_xmit(), so it is moved to netdevice.h. Additionally NET_RX definitions in netdevice.h are moved up from between TX codes to avoid confusion while reading the TX comment. Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-15net: check the return value of ndo_select_queue()Eric Dumazet
Check the return value of ndo_select_queue(). If the value isn't smaller than the real_num_tx_queues, print a warning message, and reset it to zero. Signed-off-by: Changli Gao <xiaosuo@gmail.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> ---- Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-13net: allow to propagate errors through ->ndo_hard_start_xmit()Patrick McHardy
Currently the ->ndo_hard_start_xmit() callbacks are only permitted to return one of the NETDEV_TX codes. This prevents any kind of error propagation for virtual devices, like queue congestion of the underlying device in case of layered devices, or unreachability in case of tunnels. This patches changes the NET_XMIT codes to avoid clashes with the NETDEV_TX codes and changes the two callers of dev_hard_start_xmit() to expect either errno codes, NET_XMIT codes or NETDEV_TX codes as return value. In case of qdisc_restart(), all non NETDEV_TX codes are mapped to NETDEV_TX_OK since no error propagation is possible when using qdiscs. In case of dev_queue_xmit(), the error is propagated upwards. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-12sysctl net: Remove unused binary sysctl codeEric W. Biederman
Now that sys_sysctl is a compatiblity wrapper around /proc/sys all sysctl strategy routines, and all ctl_name and strategy entries in the sysctl tables are unused, and can be revmoed. In addition neigh_sysctl_register has been modified to no longer take a strategy argument and it's callers have been modified not to pass one. Cc: "David Miller" <davem@davemloft.net> Cc: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org> Cc: netdev@vger.kernel.org Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2009-11-11netdev: fold name hash properly (v3)stephen hemminger
The full_name_hash function does not produce well distributed values in the lower bits, so most code uses hash_32() to fold it. This is really a bug introduced when name hashing was added, back in 2.5 when I added name hashing. hash_32 is all that is needed since full_name_hash returns unsigned int which is only 32 bits on 64 bit platforms. Also, there is no point in using hash_32 on ifindex, because the is naturally sequential and usually well distributed. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-11skbuff: Do not allow skb recycling with disabled IRQsAnton Vorontsov
NAPI drivers try to recycle SKBs in their polling routine, but we generally don't know the context in which the polling will be called, and the skb recycling itself may require IRQs to be enabled. This patch adds irqs_disabled() test to the skb_recycle_check() routine, so that we'll not let the drivers hit the skb recycling path with IRQs disabled. As a side effect, this patch actually disables skb recycling for some [broken] drivers. E.g. gianfar driver grabs an irqsave spinlock during TX ring processing, and then tries to recycle an skb, and that caused the following badness: nf_conntrack version 0.5.0 (1008 buckets, 4032 max) ------------[ cut here ]------------ Badness at kernel/softirq.c:143 NIP: c003e3c4 LR: c423a528 CTR: c003e344 ... NIP [c003e3c4] local_bh_enable+0x80/0xc4 LR [c423a528] destroy_conntrack+0xd4/0x13c [nf_conntrack] Call Trace: [c15d1b60] [c003e32c] local_bh_disable+0x1c/0x34 (unreliable) [c15d1b70] [c423a528] destroy_conntrack+0xd4/0x13c [nf_conntrack] [c15d1b80] [c02c6370] nf_conntrack_destroy+0x3c/0x70 Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-08net: Support specifying the network namespace upon device creation.Eric W. Biederman
There is no good reason to not support userspace specifying the network namespace during device creation, and it makes it easier to create a network device and pass it to a child network namespace with a well known name. We have to be careful to ensure that the target network namespace for the new device exists through the life of the call. To keep that logic clear I have factored out the network namespace grabbing logic into rtnl_link_get_net. In addtion we need to continue to pass the source network namespace to the rtnl_link_ops.newlink method so that we can find the base device source network namespace. Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com>
2009-11-07rtnetlink: CleanupsEric Dumazet
Pure cleanups patch Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
