path: root/net/dccp/ipv4.c
2011-08-06net: Compute protocol sequence numbers and fragment IDs using MD5.David S. Miller
Computers have become a lot faster since we compromised on the partial MD4 hash which we use currently for performance reasons. MD5 is a much safer choice, and is inline with both RFC1948 and other ISS generators (OpenBSD, Solaris, etc.) Furthermore, only having 24-bits of the sequence number be truly unpredictable is a very serious limitation. So the periodic regeneration and 8-bit counter have been removed. We compute and use a full 32-bit sequence number. For ipv6, DCCP was found to use a 32-bit truncated initial sequence number (it needs 43-bits) and that is fixed here as well. Reported-by: Dan Kaminsky <dan@doxpara.com> Tested-by: Willy Tarreau <w@1wt.eu> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-18ipv4: Make caller provide flowi4 key to inet_csk_route_req().David S. Miller
This way the caller can get at the fully resolved fl4->{daddr,saddr} etc. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-08ipv4: Use inet_csk_route_child_sock() in DCCP and TCP.David S. Miller
Operation order is now transposed, we first create the child socket then we try to hook up the route. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-08dccp: Use cork flow in dccp_v4_connect()David S. Miller
Since this is invoked from inet_stream_connect() the socket is locked and therefore this usage is safe. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-03dccp: Use flowi4->saddr in dccp_v4_connect()David S. Miller
2011-04-28ipv4: Get route daddr from flow key in dccp_v4_connect().David S. Miller
Now that output route lookups update the flow with destination address selection, we can fetch it from fl4->daddr instead of rt->rt_dst Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-28inet: add RCU protection to inet->optEric Dumazet
We lack proper synchronization to manipulate inet->opt ip_options Problem is ip_make_skb() calls ip_setup_cork() and ip_setup_cork() possibly makes a copy of ipc->opt (struct ip_options), without any protection against another thread manipulating inet->opt. Another thread can change inet->opt pointer and free old one under us. Use RCU to protect inet->opt (changed to inet->inet_opt). Instead of handling atomic refcounts, just copy ip_options when necessary, to avoid cache line dirtying. We cant insert an rcu_head in struct ip_options since its included in skb->cb[], so this patch is large because I had to introduce a new ip_options_rcu structure. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-27ipv4: Sanitize and simplify ip_route_{connect,newports}()David S. Miller
These functions are used together as a unit for route resolution during connect(). They address the chicken-and-egg problem that exists when ports need to be allocated during connect() processing, yet such port allocations require addressing information from the routing code. It's currently more heavy handed than it needs to be, and in particular we allocate and initialize a flow object twice. Let the callers provide the on-stack flow object. That way we only need to initialize it once in the ip_route_connect() call. Later, if ip_route_newports() needs to do anything, it re-uses that flow object as-is except for the ports which it updates before the route re-lookup. Also, describe why this set of facilities are needed and how it works in a big comment. Signed-off-by: David S. Miller <davem@davemloft.net> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com>
2011-03-12net: Put fl4_* macros to struct flowi4 and use them again.David S. Miller
2011-03-12ipv4: Use flowi4 in public route lookup interfaces.David S. Miller
2011-03-12net: Make flowi ports AF dependent.David S. Miller
Create two sets of port member accessors, one set prefixed by fl4_* and the other prefixed by fl6_* This will let us to create AF optimal flow instances. It will work because every context in which we access the ports, we have to be fully aware of which AF the flowi is anyways. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-12net: Put flowi_* prefix on AF independent members of struct flowiDavid S. Miller
I intend to turn struct flowi into a union of AF specific flowi structs. There will be a common structure that each variant includes first, much like struct sock_common. This is the first step to move in that direction. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-02ipv4: Make output route lookup return rtable directly.David S. Miller
Instead of on the stack. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-01ipv4: Kill can_sleep arg to ip_route_output_flow()David S. Miller
This boolean state is now available in the flow flags. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-01ipv4: Make final arg to ip_route_output_flow to be boolean "can_sleep"David S. Miller
Since that is what the current vague "flags" argument means. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-01ipv4: Can final ip_route_connect() arg to boolean "can_sleep".David S. Miller
Since that's what the current vague "flags" thing means. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-24ipv4: Rearrange how ip_route_newports() gets port keys.David S. Miller
ip_route_newports() is the only place in the entire kernel that cares about the port members in the routing cache entry's lookup flow key. Therefore the only reason we store an entire flow inside of the struct rtentry is for this one special case. Rewrite ip_route_newports() such that: 1) The caller passes in the original port values, so we don't need to use the rth->fl.fl_ip_{s,d}port values to remember them. 2) The lookup flow is constructed by hand instead of being copied from the routing cache entry's flow. Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-17net: use the macros defined for the members of flowiChangli Gao
Use the macros defined for the members of flowi to clean the code up. Signed-off-by: Changli Gao <xiaosuo@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-21tproxy: fix hash locking issue when using port redirection in ↵Balazs Scheidler
__inet_inherit_port() When __inet_inherit_port() is called on a tproxy connection the wrong locks are held for the inet_bind_bucket it is added to. __inet_inherit_port() made an implicit assumption that the listener's port number (and thus its bind bucket). Unfortunately, if you're using the TPROXY target to redirect skbs to a transparent proxy that assumption is not true anymore and things break. This patch adds code to __inet_inherit_port() so that it can handle this case by looking up or creating a new bind bucket for the child socket and updates callers of __inet_inherit_port() to gracefully handle __inet_inherit_port() failing. Reported by and original patch from Stephen Buck <stephen.buck@exinda.com>. See http://marc.info/?t=128169268200001&r=1&w=2 for the original discussion. Signed-off-by: KOVACS Krisztian <hidden@balabit.hu> Signed-off-by: Patrick McHardy <kaber@trash.net>
2010-06-10net-next: remove useless union keywordChangli Gao
remove useless union keyword in rtable, rt6_info and dn_route. Since there is only one member in a union, the union keyword isn't useful. Signed-off-by: Changli Gao <xiaosuo@gmail.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-11inet: Remove unused send_check length argumentHerbert Xu
inet: Remove unused send_check length argument This patch removes the unused length argument from the send_check function in struct inet_connection_sock_af_ops. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Tested-by: Yinghai <yinghai.lu@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-15net-2.6 [Bug-Fix][dccp]: fix oops caused after failed initialisationGerrit Renker
dccp: fix panic caused by failed initialisation This fixes a kernel panic reported thanks to Andre Noll: if DCCP is compiled into the kernel and any out of the initialisation steps in net/dccp/proto.c:dccp_init() fail, a subsequent attempt to create a SOCK_DCCP socket will panic, since inet{,6}_create() are not prevented from creating DCCP sockets. This patch fixes the problem by propagating a failure in dccp_init() to dccp_v{4,6}_init_net(), and from there to dccp_v{4,6}_init(), so that the DCCP protocol is not made available if its initialisation fails. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-17net: spread __net_init, __net_exitAlexey Dobriyan
__net_init/__net_exit are apparently not going away, so use them to full extent. In some cases __net_init was removed, because it was called from __net_exit code. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-08tcp: Fix a connect() race with timewait socketsEric Dumazet
First patch changes __inet_hash_nolisten() and __inet6_hash() to get a timewait parameter to be able to unhash it from ehash at same time the new socket is inserted in hash. This makes sure timewait socket wont be found by a concurrent writer in __inet_check_established() Reported-by: kapil dakhane <kdakhane@gmail.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-02TCPCT part 1a: add request_values parameter for sending SYNACKWilliam Allen Simpson
Add optional function parameters associated with sending SYNACK. These parameters are not needed after sending SYNACK, and are not used for retransmission. Avoids extending struct tcp_request_sock, and avoids allocating kernel memory. Also affects DCCP as it uses common struct request_sock_ops, but this parameter is currently reserved for future use. Signed-off-by: William.Allen.Simpson@gmail.com Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-05net: drop capability from protocol definitionsEric Paris
struct can_proto had a capability field which wasn't ever used. It is dropped entirely. struct inet_protosw had a capability field which can be more clearly expressed in the code by just checking if sock->type = SOCK_RAW. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-18inet: rename some inet_sock fieldsEric Dumazet
In order to have better cache layouts of struct sock (separate zones for rx/tx paths), we need this preliminary patch. Goal is to transfert fields used at lookup time in the first read-mostly cache line (inside struct sock_common) and move sk_refcnt to a separate cache line (only written by rx path) This patch adds inet_ prefix to daddr, rcv_saddr, dport, num, saddr, sport and id fields. This allows a future patch to define these fields as macros, like sk_refcnt, without name clashes. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-14net: constify struct net_protocolAlexey Dobriyan
Remove long removed "inet_protocol_base" declaration. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-02inet: inet_connection_sock_af_ops constStephen Hemminger
The function block inet_connect_sock_af_ops contains no data make it constant. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-03net: skb->dst accessorsEric Dumazet
Define three accessors to get/set dst attached to a skb struct dst_entry *skb_dst(const struct sk_buff *skb) void skb_dst_set(struct sk_buff *skb, struct dst_entry *dst) void skb_dst_drop(struct sk_buff *skb) This one should replace occurrences of : dst_release(skb->dst) skb->dst = NULL; Delete skb->dst field Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-03net: skb->rtable accessorEric Dumazet
Define skb_rtable(const struct sk_buff *skb) accessor to get rtable from skb Delete skb->rtable field Setting rtable is not allowed, just set dst instead as rtable is an alias. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-16net: Convert TCP & DCCP hash tables to use RCU / hlist_nullsEric Dumazet
RCU was added to UDP lookups, using a fast infrastructure : - sockets kmem_cache use SLAB_DESTROY_BY_RCU and dont pay the price of call_rcu() at freeing time. - hlist_nulls permits to use few memory barriers. This patch uses same infrastructure for TCP/DCCP established and timewait sockets. Thanks to SLAB_DESTROY_BY_RCU, no slowdown for applications using short lived TCP connections. A followup patch, converting rwlocks to spinlocks will even speedup this case. __inet_lookup_established() is pretty fast now we dont have to dirty a contended cache line (read_lock/read_unlock) Only established and timewait hashtable are converted to RCU (bind table and listen table are still using traditional locking) Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-04dccp: Cleanup routines for feature negotiationGerrit Renker
This inserts the required de-allocation routines for memory allocated by feature negotiation in the socket destructors, replacing dccp_feat_clean() in one instance. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Acked-by: Ian McDonald <ian.mcdonald@jandi.co.nz> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-04dccp: Per-socket initialisation of feature negotiationGerrit Renker
This provides feature-negotiation initialisation for both DCCP sockets and DCCP request_sockets, to support feature negotiation during connection setup. It also resolves a FIXME regarding the congestion control initialisation. Thanks to Wei Yongjun for help with the IPv6 side of this patch. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Acked-by: Ian McDonald <ian.mcdonald@jandi.co.nz> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-31net: replace NIPQUAD() in net/*/Harvey Harrison
Using NIPQUAD() with NIPQUAD_FMT, %d.%d.%d.%d or %u.%u.%u.%u can be replaced with %pI4 Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-07inet_hashtables: Add inet_lookup_skb helpersArnaldo Carvalho de Melo
To be able to use the cached socket reference in the skb during input processing we add a new set of lookup functions that receive the skb on their argument list. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: KOVACS Krisztian <hidden@sch.bme.hu> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-09-09This reverts "Merge branch 'dccp' of git://eden-feed.erg.abdn.ac.uk/dccp_exp"Gerrit Renker
as it accentally contained the wrong set of patches. These will be submitted separately. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk>
2008-09-04dccp: Cleanup routines for feature negotiationGerrit Renker
2008-09-04dccp: Per-socket initialisation of feature negotiationGerrit Renker
2008-07-26dccp: Fix incorrect length check for ICMPv4 packetsWei Yongjun
Unlike TCP, which only needs 8 octets of original packet data, DCCP requires minimally 12 or 16 bytes for ICMP-payload sequence number checks. This patch replaces the insufficient length constant of 8 with a two-stage test, making sure that 12 bytes are available, before computing the basic header length required for sequence number checks. Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk>
2008-07-26dccp: Fix sequence number check for ICMPv4 packetsWei Yongjun
The payload of ICMP message is a part of the packet sent by ourself, so the sequence number check must use AWL and AWH, not SWL and SWH. For example: Endpoint A Endpoint B DATA-ACK --------> (SEQ=X) <-------- ICMP (Fragmentation Needed) (SEQ=X) Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Acked-by: Gerrit Renker <gerrit@erg.abdn.ac.uk>
2008-07-25net: convert BUG_TRAP to generic WARN_ONIlpo Järvinen
Removes legacy reinvent-the-wheel type thing. The generic machinery integrates much better to automated debugging aids such as kerneloops.org (and others), and is unambiguous due to better naming. Non-intuively BUG_TRAP() is actually equal to WARN_ON() rather than BUG_ON() though some might actually be promoted to BUG_ON() but I left that to future. I could make at least one BUILD_BUG_ON conversion. Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-16mib: add net to NET_INC_STATS_BHPavel Emelyanov
Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-16mib: add net to IP_INC_STATS_BHPavel Emelyanov
2008-07-14mib: add struct net to ICMP_INC_STATS_BHPavel Emelyanov
2008-07-14inet: toss struct net initialization aroundPavel Emelyanov
Some places, that deal with ICMP statistics already have where to get a struct net from, but use it directly, without declaring a separate variable on the stack. Since I will need this net soon, I declare a struct net on the stack and use it in the existing places in a separate patch not to spoil the future ones. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-10inet{6}_request_sock: Init ->opt and ->pktopts in the constructorArnaldo Carvalho de Melo
Wei Yongjun noticed that we may call reqsk_free on request sock objects where the opt fields may not be initialized, fix it by introducing inet_reqsk_alloc where we initialize ->opt to NULL and set ->pktopts to NULL in inet6_reqsk_alloc. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-27dccp: Fix to handle short sequence numbers packet correctlyWei Yongjun
RFC4340 said: 8.5. Pseudocode ... If P.type is not Data, Ack, or DataAck and P.X == 0 (the packet has short sequence numbers), drop packet and return But DCCP has some mistake to handle short sequence numbers packet, now it drop packet only if P.type is Data, Ack, or DataAck and P.X == 0. Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Acked-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-14[DCCP]: Fix comment about control sockets.Pavel Emelyanov
These sockets now have a bit other names and are no longer global. Shame on me, I haven't provided a good comment for this when sending DCCP netnsization patches. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
