path: root/net/dccp/ipv6.c
2006-01-31[DCCP] ipv6: dccp_v6_send_response() has a DST leak too.David S. Miller
It was copy&pasted from tcp_v6_send_synack() which has a DST leak recently fixed by Eric W. Biederman. So dccp_v6_send_response() needs the same fix too. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-07[IPV6]: Move nextheader offset to the IP6CBPatrick McHardy
Move nextheader offset to the IP6CB to make it possible to pass a packet to ip6_input_finish multiple times and have it skip already parsed headers. As a nice side effect this gets rid of the manual hopopts skipping in ip6_input_finish. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-07[DCCP]: ipv6.c needs net/ip6_checksum.cDavid S. Miller
Reported by Dave Jones. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[INET_SOCK]: Move struct inet_sock & helper functions to net/inet_sock.hArnaldo Carvalho de Melo
To help in reducing the number of include dependencies, several files were touched as they were getting needed headers indirectly for stuff they use. Thanks also to Alan Menegotto for pointing out that net/dccp/proto.c had linux/dccp.h include twice. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[SOCK]: Introduce sk_receive_skbArnaldo Carvalho de Melo
Its common enough to to justify that, TCP still can't use it as it has the prequeueing stuff, still to be made generic in the not so distant future :-) Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[IP_SOCKGLUE]: Remove most of the tcp specific callsArnaldo Carvalho de Melo
As DCCP needs to be called in the same spots. Now we have a member in inet_sock (is_icsk), set at sock creation time from struct inet_protosw->flags (if INET_PROTOSW_ICSK is set, like for TCP and DCCP) to see if a struct sock instance is a inet_connection_sock for places like the ones in ip_sockglue.c (v4 and v6) where we previously were looking if sk_type was SOCK_STREAM, that is insufficient because we now use the same code for DCCP, that has sk_type SOCK_DCCP. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[INET6]: Generalise tcp_v6_hash_connectArnaldo Carvalho de Melo
Renaming it to inet6_hash_connect, making it possible to ditch dccp_v6_hash_connect and share the same code with TCP instead. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[TWSK]: Introduce struct timewait_sock_opsArnaldo Carvalho de Melo
So that we can share several timewait sockets related functions and make the timewait mini sockets infrastructure closer to the request mini sockets one. Next changesets will take advantage of this, moving more code out of TCP and DCCP v4 and v6 to common infrastructure. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[DCCP]: Introduce DCCPv6Arnaldo Carvalho de Melo
Still needs mucho polishing, specially in the checksum code, but works just fine, inet_diag/iproute2 and all 8) Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
