path: root/net/dccp/options.c
2008-06-11dccp ccid-2: Bug-Fix - Ack Vectors need to be ignored on request socketsGerrit Renker
This fixes an oversight from an earlier patch, ensuring that Ack Vectors are not processed on request sockets. The issue is that Ack Vectors must not be parsed on request sockets, since the Ack Vector feature depends on the selection of the (TX) CCID. During the initial handshake the CCIDs are undefined, and so RFC 4340, 10.3 applies: "Using CCID-specific options and feature options during a negotiation for the corresponding CCID feature is NOT RECOMMENDED [...]" And it is not even possible: when the server receives the Request from the client, the CCID and Ack vector features are undefined; when the Ack finalising the 3-way hanshake arrives, the request socket has not been cloned yet into a full socket. (This order is necessary, since otherwise the newly created socket would have to be destroyed whenever an option error occurred - a malicious hacker could simply send garbage options and exploit this.) Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk>
2008-01-28[DCCP]: Ignore feature negotiation on Data packetsGerrit Renker
This implements [RFC 4340, p. 32]: "any feature negotiation options received on DCCP-Data packets MUST be ignored". Also added a FIXME for further processing, since the code currently (wrongly) classifies empty Confirm options as invalid - this needs to be resolved in a separate patch. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Signed-off-by: Ian McDonald <ian.mcdonald@jandi.co.nz> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[DCCP]: Support inserting options during the 3-way handshakeGerrit Renker
This provides a separate routine to insert options during the initial handshake. The main purpose is to conduct feature negotiation, for the moment the only user is the timestamp echo needed for the (CCID3) handshake RTT sample. Padding of options has been put into a small separate routine, to be shared among the two functions. This could also be used as a generic routine to finish inserting options. Also removed an `XXX' comment since its content was obvious. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Signed-off-by: Ian McDonald <ian.mcdonald@jandi.co.nz> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[DCCP]: Handle timestamps on Request/Response exchange separatelyGerrit Renker
In DCCP, timestamps can occur on packets anytime, CCID3 uses a timestamp(/echo) on the Request/Response exchange. This patch addresses the following situation: * timestamps are recorded on the listening socket; * Responses are sent from dccp_request_sockets; * suppose two connections reach the listening socket with very small time in between: * the first timestamp value gets overwritten by the second connection request. This is not really good, so this patch separates timestamps into * those which are received by the server during the initial handshake (on dccp_request_sock); * those which are received by the client or the client after connection establishment. As before, a timestamp of 0 is regarded as indicating that no (meaningful) timestamp has been received (in addition, a warning message is printed if hosts send 0-valued timestamps). The timestamp-echoing now works as follows: * when a timestamp is present on the initial Request, it is placed into dreq, due to the call to dccp_parse_options in dccp_v{4,6}_conn_request; * when a timestamp is present on the Ack leading from RESPOND => OPEN, it is copied over from the request_sock into the child cocket in dccp_create_openreq_child; * timestamps received on an (established) dccp_sock are treated as before. Since Elapsed Time is measured in hundredths of milliseconds (13.2), the new dccp_timestamp() function is used, as it is expected that the time between receiving the timestamp and sending the timestamp echo will be very small against the wrap-around time. As a byproduct, this allows smaller timestamping-time fields. Furthermore, inserting the Timestamp Echo option has been taken out of the block starting with '!dccp_packet_without_ack()', since Timestamp Echo can be carried on any packet (5.8 and 13.3). Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Acked-by: Ian McDonald <ian.mcdonald@jandi.co.nz> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[DCCP]: Allow to parse options on Request SocketsGerrit Renker
The option parsing code currently only parses on full sk's. This causes a problem for options sent during the initial handshake (in particular timestamps and feature-negotiation options). Therefore, this patch extends the option parsing code with an additional argument for request_socks: if it is non-NULL, options are parsed on the request socket, otherwise the normal path (parsing on the sk) is used. Subsequent patches, which implement feature negotiation during connection setup, make use of this facility. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Signed-off-by: Ian McDonald <ian.mcdonald@jandi.co.nz> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[DCCP]: Ignore Ack Vectors / Elapsed Time on DCCP-Request alsoGerrit Renker
Small update with regard to RFC 4340 (references added as documentation): on Requests, Ack Vectors / Elapsed Time should be ignored. Length handling of Elapsed Time also simplified. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Signed-off-by: Ian McDonald <ian.mcdonald@jandi.co.nz> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-24[DCCP]: Unaligned pointer accessGerrit Renker
This fixes `unaligned (read) access' errors of the type Kernel unaligned access at TPC[100f970c] dccp_parse_options+0x4f4/0x7e0 [dccp] Kernel unaligned access at TPC[1011f2e4] ccid3_hc_tx_parse_options+0x1ac/0x380 [dccp_ccid3] Kernel unaligned access at TPC[100f9898] dccp_parse_options+0x680/0x880 [dccp] by using the get_unaligned macro for parsing options. Commiter note: Preserved the sparse __be{16,32} annotations. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Signed-off-by: Ian McDonald <ian.mcdonald@jandi.co.nz> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2007-10-10[DCCP]: Wrong format in printkGerrit Renker
The elapsed time uses u32, but printk was using %d, not %u. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Signed-off-by: Ian McDonald <ian.mcdonald@jandi.co.nz> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2007-10-10[DCCP]: Tidy-up -- minisock initialisationGerrit Renker
This * removes a declaration of a non-existent function __dccp_minisock_init; * shifts the initialisation function dccp_minisock_init() from options.c to minisocks.c, where it is more naturally expected to be. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Signed-off-by: Ian McDonald <ian.mcdonald@jandi.co.nz> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[DCCP]: Provide 10s of microsecond timesourceGerrit Renker
This provides a timesource, conveniently used for DCCP timestamps, which returns the elapsed time in 10s of microseconds since initialisation. This makes for a wrap-around time of about 11.9 hours, which should be sufficient for most applications. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[DCCP]: Nuke dccp_timestamp and dccps_epoch, not used anymoreArnaldo Carvalho de Melo
2007-10-10[DCCP] options: convert dccp_insert_option_timestamp to ktime_tArnaldo Carvalho de Melo
2007-10-10[DCCP]: Convert dccps_timestamp_time to ktime_tArnaldo Carvalho de Melo
2007-04-25[DCCP]: Debug statements for Elapsed Time optionGerrit Renker
This prints the value of the parsed Elapsed Time when received via a Timestamp Echo option [RFC 4342, 13.3]. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Acked-by: Ian McDonald <ian.mcdonald@jandi.co.nz> Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[DCCP]: Sample RTT from SYN exchangeGerrit Renker
Function:
2007-04-25[TCP/DCCP/RANDOM]: Remove unused exports.Adrian Bunk
This patch removes the following not or no longer used exports: - drivers/char/random.c: secure_tcp_sequence_number - net/dccp/options.c: sysctl_dccp_feat_sequence_window - net/netlink/af_netlink.c: netlink_set_err Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-10[NET] DCCP: Fix whitespace errors.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-11[DCCP] ccid: Deprecate ccid_hc_tx_insert_optionsGerrit Renker
The function ccid3_hc_tx_insert_options only does a redundant no-op, as the operation DCCP_SKB_CB(skb)->dccpd_ccval = hctx->ccid3hctx_last_win_count; is already performed _unconditionally_ in ccid3_hc_tx_send_packet. Since there is further no current need for this function, it is removed entirely. Since furthermore, there is actually no present need for the entire interface function ccid_hc_tx_insert_options, it was decided to remove it also, to clean up the interface. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2006-12-02[DCCP] ackvec: infrastructure for sending more than one ackvec per packetAndrea Bittau
Commiter note: This was split from Andrea's original patch, in the process I changed the type of the ackvec index fields to u16 instead of to int and haven't folded dccp_ackvec_parse with dccp_ackvec_check_rcv_ackno. Next patch will actually do the insertion of more than one ackvec per packet, using, initially, up to a max of 2 ackvecs as per Andrea's original patch, then I'll work on support for larger ackvecs, be it using a sysctl or using setsockopt. Signed-off-by: Andrea Bittau <a.bittau@cs.ucl.ac.uk> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2006-12-02[DCCP]: Simplified conditions due to use of enum:8 statesGerrit Renker
This reaps the benefit of the earlier patch, which changed the type of CCID 3 states to use enums, in that many conditions are now simplified and the number of possible (unexpected) values is greatly reduced. In a few instances, this also allowed to simplify pre-conditions; where care has been taken to retain logical equivalence. [DCCP]: Introduce a consistent BUG/WARN message scheme This refines the existing set of DCCP messages so that * BUG(), BUG_ON(), WARN_ON() have meaningful DCCP-specific counterparts * DCCP_CRIT (for severe warnings) is not rate-limited * DCCP_WARN() is introduced as rate-limited wrapper Using these allows a faster and cleaner transition to their original counterparts once the code has matured into a full DCCP implementation. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2006-12-02[DCCP]: Miscellaneous code tidy-upsGerrit Renker
This patch does not change code; it performs some trivial clean/tidy-ups: * removal of a `debug_prefix' string in favour of the already existing dccp_role(sk) * add documentation of structures and constants * separated out the cases for invalid packets (step 1 of the packet validation) * removing duplicate statements * combining declaration & initialisation Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2006-12-02[DCCP]: Make feature negotiation more readableGerrit Renker
This patch replaces cryptic feature negotiation messages of type Oct 31 15:42:20 kernel: dccp_feat_change: feat change type=32 feat=1 Oct 31 15:42:21 kernel: dccp_feat_change: feat change type=34 feat=1 Oct 31 15:42:21 kernel: dccp_feat_change: feat change type=32 feat=5 into ones of type: Nov 2 13:54:45 kernel: dccp_feat_change: ChangeL(CCID (1), 3) Nov 2 13:54:45 kernel: dccp_feat_change: ChangeR(CCID (1), 3) Nov 2 13:54:45 kernel: dccp_feat_change: ChangeL(Ack Ratio (5), 2) Also, * completed the feature number list wrt RFC 4340 sec. 6.4 * annotating which ones have been implemented so far * implemented rudimentary sanity checking in feat.c (FIXMEs) * some minor fixes Commiter note: uninlined dccp_feat_name and dccp_feat_typename, for consistency with dccp_{state,packet}_name, that, BTW, should be compiled only if CONFIG_IP_DCCP_DEBUG is selected, leaving this to another cset tho. Also shortened dccp_feat_negotiation_debug to dccp_feat_debug. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2006-12-02[DCCP]: Introduce a consistent naming scheme for sysctlsGerrit Renker
In order to make their function clearer and obtain a consistent naming scheme to identify sysctls, all existing DCCP sysctls have been prefixed with `sysctl_dccp', following the same convention as used by TCP. Feature-specific sysctls retain the `feat' in the middle, although the `default' has been dropped, since it is obvious from use. Also removed a duplicate `dccp_feat_default_sequence_window' in ipv4.c. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2006-10-24[DCCP]: Update documentation references.Gerrit Renker
Updates the references to spec documents throughout the code, taking into account that * the DCCP, CCID 2, and CCID 3 drafts all became RFCs in March this year * RFC 1063 was obsoleted by RFC 1191 * draft-ietf-tcpimpl-pmtud-0x.txt was published as an Informational RFC, RFC 2923 on 2000-09-22. All references verified. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-08-26[DCCP]: Update contact details and copyrightIan McDonald
Just updating copyright and contacts Signed off by: Ian McDonald <ian.mcdonald@jandi.co.nz> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-07-24[DCCP]: Fix default sequence window sizeIan McDonald
When using the default sequence window size (100) I got the following in my logs: Jun 22 14:24:09 localhost kernel: [ 1492.114775] DCCP: Step 6 failed for DATA packet, (LSWL(6279674225) <= P.seqno(6279674749) <= S.SWH(6279674324)) and (P.ackno doesn't exist or LAWL(18798206530) <= P.ackno(1125899906842620) <= S.AWH(18798206548), sending SYNC... Jun 22 14:24:09 localhost kernel: [ 1492.115147] DCCP: Step 6 failed for DATA packet, (LSWL(6279674225) <= P.seqno(6279674750) <= S.SWH(6279674324)) and (P.ackno doesn't exist or LAWL(18798206530) <= P.ackno(1125899906842620) <= S.AWH(18798206549), sending SYNC... I went to alter the default sysctl and it didn't take for new sockets. Below patch fixes this. I think the default is too low but it is what the DCCP spec specifies. As a side effect of this my rx speed using iperf goes from about 2.8 Mbits/sec to 3.5. This is still far too slow but it is a step in the right direction. Compile tested only for IPv6 but not particularly complex change. Signed off by: Ian McDonald <ian.mcdonald@jandi.co.nz> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[DCCP] minisock: Rename struct dccp_options to struct dccp_minisockArnaldo Carvalho de Melo
This will later be included in struct dccp_request_sock so that we can have per connection feature negotiation state while in the 3way handshake, when we clone the DCCP_ROLE_LISTEN socket (in dccp_create_openreq_child) we'll just copy this state from dreq_minisock to dccps_minisock. Also the feature negotiation and option parsing code will mostly touch dccps_minisock, which will simplify some stuff. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[DCCP]: Fix uninitialized var warnings in dccp_parse_options().David S. Miller
2006-03-20[DCCP] options: Make dccp_insert_options & friends yell on errorArnaldo Carvalho de Melo
And not the silly LIMIT_NETDEBUG and silently return without inserting the option requested. Also drop some old debugging messages associated to option insertion. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[DCCP] options: Fix handling of ackvecs in DATA packetsArnaldo Carvalho de Melo
I.e. they should be just ignored, but we have to use 'break', not 'continue', as we have to possibly reset the mandatory flag. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[DCCP] options: Fix some aspects of mandatory option processingArnaldo Carvalho de Melo
According to dccp draft (draft-ietf-dccp-spec-13.txt) section 5.8.2 (Mandatory Option) the following patch correct the handling of the following cases: 1) "... and any Mandatory options received on DCCP-Data packets MUST be ignored." 2) "The connection is in error and should be reset with Reset Code 5, ... if option O is absent (Mandatory was the last byte of the option list), or if option O equals Mandatory." Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: Hagen Paul Pfeifer <hagen@jauu.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[DCCP]: Move the IPv4 specific bits from proto.c to ipv4.cArnaldo Carvalho de Melo
With this patch in place we can break down the complexity by better compartmentalizing the code that is common to ipv6 and ipv4. Now we have these modules: Module Size Used by dccp_diag 1344 0 inet_diag 9448 1 dccp_diag dccp_ccid3 15856 0 dccp_tfrc_lib 12320 1 dccp_ccid3 dccp_ccid2 5764 0 dccp_ipv4 16996 2 dccp 48208 4 dccp_diag,dccp_ccid3,dccp_ccid2,dccp_ipv4 dccp_ipv6 still requires dccp_ipv4 due to dccp_ipv6_mapped, that is the next target to work on the "hey, ipv4 is legacy, I only want ipv6 dude!" direction. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[DCCP] feat: Introduce sysctls for the default featuresArnaldo Carvalho de Melo
[root@qemu ~]# for a in /proc/sys/net/dccp/default/* ; do echo $a ; cat $a ; done /proc/sys/net/dccp/default/ack_ratio 2 /proc/sys/net/dccp/default/rx_ccid 3 /proc/sys/net/dccp/default/send_ackvec 1 /proc/sys/net/dccp/default/send_ndp 1 /proc/sys/net/dccp/default/seq_window 100 /proc/sys/net/dccp/default/tx_ccid 3 [root@qemu ~]# So if wanting to test ccid3 as the tx CCID one can just do: [root@qemu ~]# echo 3 > /proc/sys/net/dccp/default/tx_ccid [root@qemu ~]# echo 2 > /proc/sys/net/dccp/default/rx_ccid [root@qemu ~]# cat /proc/sys/net/dccp/default/[tr]x_ccid 2 3 [root@qemu ~]# Of course we also need the setsockopt for each app to tell its preferences, but for testing or defining something other than CCID2 as the default for apps that don't explicitely set their preference the sysctl interface is handy. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[DCCP]: sparse endianness annotationsAndrea Bittau
This also fixes the layout of dccp_hdr short sequence numbers, problem was not fatal now as we only support long (48 bits) sequence numbers. Signed-off-by: Andrea Bittau <a.bittau@cs.ucl.ac.uk> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[DCCP]: Initial feature negotiation implementationAndrea Bittau
Still needs more work, but boots and doesn't crashes, even does some negotiation! 18:38:52.174934 127.0.0.1.43458 > 127.0.0.1.5001: request <change_l ack_ratio 2, change_r ccid 2, change_l ccid 2> 18:38:52.218526 127.0.0.1.5001 > 127.0.0.1.43458: response <nop, nop, change_l ack_ratio 2, confirm_r ccid 2 2, confirm_l ccid 2 2, confirm_r ack_ratio 2> 18:38:52.185398 127.0.0.1.43458 > 127.0.0.1.5001: <nop, confirm_r ack_ratio 2, ack_vector0 0x00, elapsed_time 212> :-) Signed-off-by: Andrea Bittau <a.bittau@cs.ucl.ac.uk> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-18[DCCP]: Don't use necessarily the same CCID for tx and rxArnaldo Carvalho de Melo
2005-09-18[DCCP]: Move the ack vector code to net/dccp/ackvec.[ch]Arnaldo Carvalho de Melo
Isolating it, that will be used when we introduce a CCID2 (TCP-Like) implementation. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-09[DCCP] Introduce dccp_timestampArnaldo Carvalho de Melo
To start the timestamps with 0.0ms, easing the integer maths in the CCIDs, this probably will be reworked to use the to be introduced struct timeval_offset infrastructure out of skb_get_timestamp, etc. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2005-09-09[DCCP] Give precedence to the biggest ELAPSED_TIMEArnaldo Carvalho de Melo
We can get this value in an TIMESTAMP_ECHO and/or in an ELAPSED_TIME option, if receiving both give precendence to the biggest one. In my tests they are very close if not equal at all times, so we may well think about removing the code in CCID3 that inserts this option and leaving this to the core, and perhaps even use just TIMESTAMP_ECHO including the elapsed time. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2005-09-09[CCID] Only call the HC insert_options methods when requestedArnaldo Carvalho de Melo
2005-08-29[CCID3]: Reorganise timeval handlingArnaldo Carvalho de Melo
Introducing functions to add to or subtract from a timeval variable and renaming now_delta to timeval_new_delta that calls do_gettimeofday and then timeval_delta, that should be used when there are several deltas made relative to the current time or setting variables to it, so as to avoid calling do_gettimeofday excessively. I'm leaving these "timeval_" prefixed funcions internal to DCCP for a while till we're sure there are no subtle bugs in it. It also is more correct as it checks if the number of usecs added to or subtracted from a tv_usec field is more than 2 seconds. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[DCCP]: Export dccp_insert_option_timestamp to CCIDsArnaldo Carvalho de Melo
And don't insert a TIMESTAMP option in all packets, leave the decision to the CCIDs. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[DCCP]: Fix the timestamp optionsIan McDonald
This changes timestamp, timestamp echo, and elapsed time to use units of 10 usecs as per DCCP spec. This has been tested to verify that times are correct. Also fixed up length and used hton/ntoh more. Still to add in later patches: - actually use elapsed time to adjust RTT (commented out as was prior to this patch) - send options at times more closely following the spec (content is now correct) Signed-off-by: Ian McDonald <iam4@cs.waikato.ac.nz> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[DCCP]: Fix elapsed time option as per section 13.2 of spec v11Ian McDonald
The elapsed time can be two bytes or four bytes only. Signed-off-by: Ian McDonald <iam4@cs.waikato.ac.nz> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[DCCP]: Fix sparse warningsArnaldo Carvalho de Melo
2005-08-29[DCCP]: Introduce the DCCP Kernel hacking menuArnaldo Carvalho de Melo
Only available if CONFIG_DEBUG_KERNEL is enabled in the "Kernel Hacking" Menu. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[DCCP]: Just reflow the source code to fit in 80 columnsArnaldo Carvalho de Melo
Andrew Morton should be happy now 8) Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NET]: Make NETDEBUG pure printk wrappersPatrick McHardy
Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[DCCP]: Fix u64 printf format warnings.David S. Miller
