path: root/net/decnet
2014-08-22af_decnet: Use time_after_eqHimangi Saraogi
The functions time_before, time_before_eq, time_after, and time_after_eq are more robust for comparing jiffies against other values. A simplified version of the Coccinelle semantic patch making this change is as follows: @change@ expression E1,E2,E3; @@ - jiffies - E1 >= (E2*E3) + time_after_eq(jiffies, E1+E2*E3) Signed-off-by: Himangi Saraogi <himangi774@gmail.com> Acked-by: Julia Lawall <julia.lawall@lip6.fr> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-08-22decnet: Use time_after_eqHimangi Saraogi
The functions time_before, time_before_eq, time_after, and time_after_eq are more robust for comparing jiffies against other values. A simplified version of the Coccinelle semantic patch making this change is as follows: @change@ expression E1,E2; @@ - (jiffies - E1) >= E2 + time_after_eq(jiffies, E1+E2) Signed-off-by: Himangi Saraogi <himangi774@gmail.com> Acked-by: Julia Lawall <julia.lawall@lip6.fr> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-08-22dn_dev: Use time_beforeHimangi Saraogi
The functions time_before, time_before_eq, time_after, and time_after_eq are more robust for comparing jiffies against other values. A simplified version of the Coccinelle semantic patch making this change is as follows: @change@ expression E1,E2; @@ ( - (jiffies - E1) < E2 + time_before(jiffies, E1+E2) ) Signed-off-by: Himangi Saraogi <himangi774@gmail.com> Acked-by: Julia Lawall <julia.lawall@lip6.fr> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-05-23net: Split sk_no_check into sk_no_check_{rx,tx}Tom Herbert
Define separate fields in the sock structure for configuring disabling checksums in both TX and RX-- sk_no_check_tx and sk_no_check_rx. The SO_NO_CHECK socket option only affects sk_no_check_tx. Also, removed UDP_CSUM_* defines since they are no longer necessary. Signed-off-by: Tom Herbert <therbert@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-04-24net: Use netlink_ns_capable to verify the permisions of netlink messagesEric W. Biederman
It is possible by passing a netlink socket to a more privileged executable and then to fool that executable into writing to the socket data that happens to be valid netlink message to do something that privileged executable did not intend to do. To keep this from happening replace bare capable and ns_capable calls with netlink_capable, netlink_net_calls and netlink_ns_capable calls. Which act the same as the previous calls except they verify that the opener of the socket had the desired permissions as well. Reported-by: Andy Lutomirski <luto@amacapital.net> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-04-15ipv4: add a sock pointer to dst->output() path.Eric Dumazet
In the dst->output() path for ipv4, the code assumes the skb it has to transmit is attached to an inet socket, specifically via ip_mc_output() : The sk_mc_loop() test triggers a WARN_ON() when the provider of the packet is an AF_PACKET socket. The dst->output() method gets an additional 'struct sock *sk' parameter. This needs a cascade of changes so that this parameter can be propagated from vxlan to final consumer. Fixes: 8f646c922d55 ("vxlan: keep original skb ownership") Reported-by: lucien xin <lucien.xin@gmail.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-04-11net: Fix use after free by removing length arg from sk_data_ready callbacks.David S. Miller
Several spots in the kernel perform a sequence like: skb_queue_tail(&sk->s_receive_queue, skb); sk->sk_data_ready(sk, skb->len); But at the moment we place the SKB onto the socket receive queue it can be consumed and freed up. So this skb->len access is potentially to freed up memory. Furthermore, the skb->len can be modified by the consumer so it is possible that the value isn't accurate. And finally, no actual implementation of this callback actually uses the length argument. And since nobody actually cared about it's value, lots of call sites pass arbitrary values in such as '0' and even '1'. So just remove the length argument from the callback, that way there is no confusion whatsoever and all of these use-after-free cases get fixed as a side effect. Based upon a patch by Eric Dumazet and his suggestion to audit this issue tree-wide. Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-09net: Move prototype declaration to header file include/net/dn.h from ↵Rashika Kheria
net/decnet/af_decnet.c Move prototype declaration of functions to header file include/net/dn.h from net/decnet/af_decnet.c because they are used by more than one file. This eliminates the following warning in net/decnet/af_decnet.c: net/decnet/sysctl_net_decnet.c:354:6: warning: no previous prototype for ‘dn_register_sysctl’ [-Wmissing-prototypes] net/decnet/sysctl_net_decnet.c:359:6: warning: no previous prototype for ‘dn_unregister_sysctl’ [-Wmissing-prototypes] Signed-off-by: Rashika Kheria <rashika.kheria@gmail.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-09net: Move prototype declaration to appropriate header file from ↵Rashika Kheria
decnet/af_decnet.c Move prototype declaration of functions to header file include/net/dn_route.h from net/decnet/af_decnet.c because it is used by more than one file. This eliminates the following warning in net/decnet/dn_route.c: net/decnet/dn_route.c:629:5: warning: no previous prototype for ‘dn_route_rcv’ [-Wmissing-prototypes] Signed-off-by: Rashika Kheria <rashika.kheria@gmail.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-18net: add build-time checks for msg->msg_name sizeSteffen Hurrle
This is a follow-up patch to f3d3342602f8bc ("net: rework recvmsg handler msg_name and msg_namelen logic"). DECLARE_SOCKADDR validates that the structure we use for writing the name information to is not larger than the buffer which is reserved for msg->msg_name (which is 128 bytes). Also use DECLARE_SOCKADDR consistently in sendmsg code paths. Signed-off-by: Steffen Hurrle <steffen@hurrle.net> Suggested-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-14decnet: use __dev_get_by_index instead of dev_get_by_index to find interfaceYing Xue
The following call chain we can identify that dn_cache_getroute() is protected under rtnl_lock. So if we use __dev_get_by_index() instead of dev_get_by_index() to find interface handlers in it, this would help us avoid to change interface reference counter. rtnetlink_rcv() rtnl_lock() netlink_rcv_skb() dn_cache_getroute() rtnl_unlock() Signed-off-by: Ying Xue <ying.xue@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-19Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/klassert/ipsec-next Steffen Klassert says: ==================== pull request (net-next): ipsec-next 2013-12-19 1) Use the user supplied policy index instead of a generated one if present. From Fan Du. 2) Make xfrm migration namespace aware. From Fan Du. 3) Make the xfrm state and policy locks namespace aware. From Fan Du. 4) Remove ancient sleeping when the SA is in acquire state, we now queue packets to the policy instead. This replaces the sleeping code. 5) Remove FLOWI_FLAG_CAN_SLEEP. This was used to notify xfrm about the posibility to sleep. The sleeping code is gone, so remove it. 6) Check user specified spi for IPComp. Thr spi for IPcomp is only 16 bit wide, so check for a valid value. From Fan Du. 7) Export verify_userspi_info to check for valid user supplied spi ranges with pfkey and netlink. From Fan Du. 8) RFC3173 states that if the total size of a compressed payload and the IPComp header is not smaller than the size of the original payload, the IP datagram must be sent in the original non-compressed form. These packets are dropped by the inbound policy check because they are not transformed. Document the need to set 'level use' for IPcomp to receive such packets anyway. From Fan Du. Please pull or let me know if there are problems. ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-10dn_dev: add support for IFA_FLAGS nl attributeJiri Pirko
Signed-off-by: Jiri Pirko <jiri@resnulli.us> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-09neigh: convert parms to an arrayJiri Pirko
This patch converts the neigh param members to an array. This allows easier manipulation which will be needed later on to provide better management of default values. Signed-off-by: Jiri Pirko <jiri@resnulli.us> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-06net: Remove FLOWI_FLAG_CAN_SLEEPSteffen Klassert
FLOWI_FLAG_CAN_SLEEP was used to notify xfrm about the posibility to sleep until the needed states are resolved. This code is gone, so FLOWI_FLAG_CAN_SLEEP is not needed anymore. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
2013-10-14netfilter: pass hook ops to hookfnPatrick McHardy
Pass the hook ops to the hookfn to allow for generic hook functions. This change is required by nf_tables. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2013-06-13net: Convert uses of typedef ctl_table to struct ctl_tableJoe Perches
Reduce the uses of this unnecessary typedef. Done via perl script: $ git grep --name-only -w ctl_table net | \ xargs perl -p -i -e '\ sub trim { my ($local) = @_; $local =~ s/(^\s+|\s+$)//g; return $local; } \ s/\b(?<!struct\s)ctl_table\b(\s*\*\s*|\s+\w+)/"struct ctl_table " . trim($1)/ge' Reflow the modified lines that now exceed 80 columns. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-28net: pass info struct via netdevice notifierJiri Pirko
So far, only net_device * could be passed along with netdevice notifier event. This patch provides a possibility to pass custom structure able to provide info that event listener needs to know. Signed-off-by: Jiri Pirko <jiri@resnulli.us> v2->v3: fix typo on simeth shortened dev_getter shortened notifier_info struct name v1->v2: fix notifier_call parameter in call_netdevice_notifier() Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-07decnet: remove duplicated include from dn_table.cWei Yongjun
Remove duplicated include. Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-28net-next: replace obsolete NLMSG_* with type safe nlmsg_*Hong zhi guo
Signed-off-by: Hong Zhiguo <honkiko@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-22decnet: Move rtm_dn_policy to dn_route to make it available if ↵Thomas Graf
!CONFIG_DECNET_ROUTER Otherwise build fails with CONFIG_DECNET && !CONFIG_DECNET_ROUTER Reported-by: kbuild test robot <fengguang.wu@intel.com> Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-22rtnetlink: Remove passing of attributes into rtnl_doit functionsThomas Graf
With decnet converted, we can finally get rid of rta_buf and its computations around it. It also gets rid of the minimal header length verification since all message handlers do that explicitly anyway. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-22decnet: Parse netlink attributes on our ownThomas Graf
decnet is the only subsystem left that is relying on the global netlink attribute buffer rta_buf. It's horrible design and we want to get rid of it. This converts all of decnet to do implicit attribute parsing. It also gets rid of the error prone struct dn_kern_rta. Yes, the fib_magic() stuff is not pretty. It's compiled tested but I need someone with appropriate hardware to test the patch since I don't have access to it. Cc: linux-decnet-user@lists.sourceforge.net Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-27hlist: drop the node parameter from iteratorsSasha Levin
I'm not sure why, but the hlist for each entry iterators were conceived list_for_each_entry(pos, head, member) The hlist ones were greedy and wanted an extra parameter: hlist_for_each_entry(tpos, pos, head, member) Why did they need an extra pos parameter? I'm not quite sure. Not only they don't really need it, it also prevents the iterator from looking exactly like the list iterator, which is unfortunate. Besides the semantic patch, there was some manual work required: - Fix up the actual hlist iterators in linux/list.h - Fix up the declaration of other iterators based on the hlist ones. - A very small amount of places were using the 'node' parameter, this was modified to use 'obj->member' instead. - Coccinelle didn't handle the hlist_for_each_entry_safe iterator properly, so those had to be fixed up manually. The semantic patch which is mostly the work of Peter Senna Tschudin is here: @@ iterator name hlist_for_each_entry, hlist_for_each_entry_continue, hlist_for_each_entry_from, hlist_for_each_entry_rcu, hlist_for_each_entry_rcu_bh, hlist_for_each_entry_continue_rcu_bh, for_each_busy_worker, ax25_uid_for_each, ax25_for_each, inet_bind_bucket_for_each, sctp_for_each_hentry, sk_for_each, sk_for_each_rcu, sk_for_each_from, sk_for_each_safe, sk_for_each_bound, hlist_for_each_entry_safe, hlist_for_each_entry_continue_rcu, nr_neigh_for_each, nr_neigh_for_each_safe, nr_node_for_each, nr_node_for_each_safe, for_each_gfn_indirect_valid_sp, for_each_gfn_sp, for_each_host; type T; expression a,c,d,e; identifier b; statement S; @@ -T b; <+... when != b ( hlist_for_each_entry(a, - b, c, d) S | hlist_for_each_entry_continue(a, - b, c) S | hlist_for_each_entry_from(a, - b, c) S | hlist_for_each_entry_rcu(a, - b, c, d) S | hlist_for_each_entry_rcu_bh(a, - b, c, d) S | hlist_for_each_entry_continue_rcu_bh(a, - b, c) S | for_each_busy_worker(a, c, - b, d) S | ax25_uid_for_each(a, - b, c) S | ax25_for_each(a, - b, c) S | inet_bind_bucket_for_each(a, - b, c) S | sctp_for_each_hentry(a, - b, c) S | sk_for_each(a, - b, c) S | sk_for_each_rcu(a, - b, c) S | sk_for_each_from -(a, b) +(a) S + sk_for_each_from(a) S | sk_for_each_safe(a, - b, c, d) S | sk_for_each_bound(a, - b, c) S | hlist_for_each_entry_safe(a, - b, c, d, e) S | hlist_for_each_entry_continue_rcu(a, - b, c) S | nr_neigh_for_each(a, - b, c) S | nr_neigh_for_each_safe(a, - b, c, d) S | nr_node_for_each(a, - b, c) S | nr_node_for_each_safe(a, - b, c, d) S | - for_each_gfn_sp(a, c, d, b) S + for_each_gfn_sp(a, c, d) S | - for_each_gfn_indirect_valid_sp(a, c, d, b) S + for_each_gfn_indirect_valid_sp(a, c, d) S | for_each_host(a, - b, c) S | for_each_host_safe(a, - b, c, d) S | for_each_mesh_entry(a, - b, c, d) S ) ...+> [akpm@linux-foundation.org: drop bogus change from net/ipv4/raw.c] [akpm@linux-foundation.org: drop bogus hunk from net/ipv6/raw.c] [akpm@linux-foundation.org: checkpatch fixes] [akpm@linux-foundation.org: fix warnings] [akpm@linux-foudnation.org: redo intrusive kvm changes] Tested-by: Peter Senna Tschudin <peter.senna@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Gleb Natapov <gleb@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-21Merge tag 'driver-core-3.9-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core patches from Greg Kroah-Hartman: "Here is the big driver core merge for 3.9-rc1 There are two major series here, both of which touch lots of drivers all over the kernel, and will cause you some merge conflicts: - add a new function called devm_ioremap_resource() to properly be able to check return values. - remove CONFIG_EXPERIMENTAL Other than those patches, there's not much here, some minor fixes and updates" Fix up trivial conflicts * tag 'driver-core-3.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (221 commits) base: memory: fix soft/hard_offline_page permissions drivercore: Fix ordering between deferred_probe and exiting initcalls backlight: fix class_find_device() arguments TTY: mark tty_get_device call with the proper const values driver-core: constify data for class_find_device() firmware: Ignore abort check when no user-helper is used firmware: Reduce ifdef CONFIG_FW_LOADER_USER_HELPER firmware: Make user-mode helper optional firmware: Refactoring for splitting user-mode helper code Driver core: treat unregistered bus_types as having no devices watchdog: Convert to devm_ioremap_resource() thermal: Convert to devm_ioremap_resource() spi: Convert to devm_ioremap_resource() power: Convert to devm_ioremap_resource() mtd: Convert to devm_ioremap_resource() mmc: Convert to devm_ioremap_resource() mfd: Convert to devm_ioremap_resource() media: Convert to devm_ioremap_resource() iommu: Convert to devm_ioremap_resource() drm: Convert to devm_ioremap_resource() ...
2013-02-18net: proc: change proc_net_remove to remove_proc_entryGao feng
proc_net_remove is only used to remove proc entries that under /proc/net,it's not a general function for removing proc entries of netns. if we want to remove some proc entries which under /proc/net/stat/, we still need to call remove_proc_entry. this patch use remove_proc_entry to replace proc_net_remove. we can remove proc_net_remove after this patch. Signed-off-by: Gao feng <gaofeng@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-18net: proc: change proc_net_fops_create to proc_createGao feng
Right now, some modules such as bonding use proc_create to create proc entries under /proc/net/, and other modules such as ipv4 use proc_net_fops_create. It looks a little chaos.this patch changes all of proc_net_fops_create to proc_create. we can remove proc_net_fops_create after this patch. Signed-off-by: Gao feng <gaofeng@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-11net neighbour, decnet: Ensure to align device private data on preferred ↵YOSHIFUJI Hideaki / 吉藤英明
alignment. To allow both of protocol-specific data and device-specific data attached with neighbour entry, and to eliminate size calculation cost when allocating entry, sizeof protocol-speicic data must be multiple of NEIGH_PRIV_ALIGN. On 64bit archs, sizeof(struct dn_neigh) is multiple of NEIGH_PRIV_ALIGN, but on 32bit archs, it was not. Introduce NEIGH_ENTRY_SPACE() macro to ensure that protocol-specific entry-size meets our requirement. Reported-by: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-01-28decnet: use correct RCU API to deref sk_dst_cache fieldCong Wang
sock->sk_dst_cache is protected by RCU, therefore we should use __sk_dst_get() to deref it once we lock the sock. This fixes several sparse warnings. Cc: linux-decnet-user@lists.sourceforge.net Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Cong Wang <amwang@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-01-11net/decnet: remove depends on CONFIG_EXPERIMENTALKees Cook
The CONFIG_EXPERIMENTAL config item has not carried much meaning for a while now and is almost always enabled by default. As agreed during the Linux kernel summit, remove it from any "depends on" lines in Kconfigs. CC: "David S. Miller" <davem@davemloft.net> Signed-off-by: Kees Cook <keescook@chromium.org> Acked-by: David S. Miller <davem@davemloft.net>
2013-01-11net/decnet/netfilter: remove depends on CONFIG_EXPERIMENTALKees Cook
The CONFIG_EXPERIMENTAL config item has not carried much meaning for a while now and is almost always enabled by default. As agreed during the Linux kernel summit, remove it from any "depends on" lines in Kconfigs. CC: Pablo Neira Ayuso <pablo@netfilter.org> CC: Patrick McHardy <kaber@trash.net> CC: "David S. Miller" <davem@davemloft.net> Signed-off-by: Kees Cook <keescook@chromium.org> Acked-by: David S. Miller <davem@davemloft.net>
2012-11-18net: Push capable(CAP_NET_ADMIN) into the rtnl methodsEric W. Biederman
- In rtnetlink_rcv_msg convert the capable(CAP_NET_ADMIN) check to ns_capable(net->user-ns, CAP_NET_ADMIN). Allowing unprivileged users to make netlink calls to modify their local network namespace. - In the rtnetlink doit methods add capable(CAP_NET_ADMIN) so that calls that are not safe for unprivileged users are still protected. Later patches will remove the extra capable calls from methods that are safe for unprivilged users. Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-10-06sections: fix section conflicts in netAndi Kleen
Signed-off-by: Andi Kleen <ak@linux.intel.com> Cc: David Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-09-10netlink: Rename pid to portid to avoid confusionEric W. Biederman
It is a frequent mistake to confuse the netlink port identifier with a process identifier. Try to reduce this confusion by renaming fields that hold port identifiers portid instead of pid. I have carefully avoided changing the structures exported to userspace to avoid changing the userspace API. I have successfully built an allyesconfig kernel with this change. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Acked-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-08netlink: hide struct module parameter in netlink_kernel_createPablo Neira Ayuso
This patch defines netlink_kernel_create as a wrapper function of __netlink_kernel_create to hide the struct module *me parameter (which seems to be THIS_MODULE in all existing netlink subsystems). Suggested by David S. Miller. Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-31decnet: fix shutdown parameter checkingXi Wang
The allowed value of "how" is SHUT_RD/SHUT_WR/SHUT_RDWR (0/1/2), rather than SHUTDOWN_MASK (3). Signed-off-by: Xi Wang <xi.wang@gmail.com> Acked-by: Steven Whitehouse <swhiteho@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-09net: Loopback ifindex is constant nowPavel Emelyanov
As pointed out, there are places, that access net->loopback_dev->ifindex and after ifindex generation is made per-net this value becomes constant equals 1. So go ahead and introduce the LOOPBACK_IFINDEX constant and use it where appropriate. Signed-off-by: Pavel Emelyanov <xemul@parallels.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-23decnet: Don't set RTCF_DIRECTSRC.David S. Miller
It's an ipv4 defined route flag, and only ipv4 uses it. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-20net: Document dst->obsolete better.David S. Miller
Add a big comment explaining how the field works, and use defines instead of magic constants for the values assigned to it. Suggested by Joe Perches. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-17net: Pass optional SKB and SK arguments to dst_ops->{update_pmtu,redirect}()David S. Miller
This will be used so that we can compose a full flow key. Even though we have a route in this context, we need more. In the future the routes will be without destination address, source address, etc. keying. One ipv4 route will cover entire subnets, etc. In this environment we have to have a way to possess persistent storage for redirects and PMTU information. This persistent storage will exist in the FIB tables, and that's why we'll need to be able to rebuild a full lookup flow key here. Using that flow key will do a fib_lookup() and create/update the persistent entry. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-12net: Add dummy dst_ops->redirect method where needed.David S. Miller
2012-07-10rtnetlink: Remove ts/tsage args to rtnl_put_cacheinfo().David S. Miller
Nobody provides non-zero values any longer. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-10net: Don't report route RTT metric value in cache dumps.David S. Miller
We don't maintain it dynamically any longer, so reporting it would be extremely misleading. Report zero instead. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-05decnet: Use neighbours privately in dn_route struct.David S. Miller
This allows an easy conversion away from dst_get_neighbour*(). Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-05net: Add optional SKB arg to dst_ops->neigh_lookup().David S. Miller
Causes the handler to use the daddr in the ipv4/ipv6 header when the route gateway is unspecified (local subnet). Signed-off-by: David S. Miller <davem@davemloft.net>
2012-06-29netlink: add netlink_kernel_cfg parameter to netlink_kernel_createPablo Neira Ayuso
This patch adds the following structure: struct netlink_kernel_cfg { unsigned int groups; void (*input)(struct sk_buff *skb); struct mutex *cb_mutex; }; That can be passed to netlink_kernel_create to set optional configurations for netlink kernel sockets. I've populated this structure by looking for NULL and zero parameters at the existing code. The remaining parameters that always need to be set are still left in the original interface. That includes optional parameters for the netlink socket creation. This allows easy extensibility of this interface in the future. This patch also adapts all callers to use this new interface. Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-06-27netlink: Get rid of obsolete rtnetlink macrosThomas Graf
Removes all RTA_GET*() and RTA_PUT*() variations, as well as the the unused rtattr_strcmp(). Get rid of rtm_get_table() by moving it to its only user decnet. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-06-27decnet: Do not use RTA_PUT() macrosThomas Graf
Also, no need to trim on nlmsg_put() failure, nothing has been added yet. We also want to use nlmsg_end(), nlmsg_new() and nlmsg_free(). Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-06-26decnet: dn_table: Move away from NLMSG_NEW().David S. Miller
And use nlmsg_data() while we're here too. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-06-26decnet: dn_route: Move away from NLMSG_NEW().David S. Miller
