path: root/net/dns_resolver
2012-10-14Merge branch 'modules-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull module signing support from Rusty Russell: "module signing is the highlight, but it's an all-over David Howells frenzy..." Hmm "Magrathea: Glacier signing key". Somebody has been reading too much HHGTTG. * 'modules-next' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: (37 commits) X.509: Fix indefinite length element skip error handling X.509: Convert some printk calls to pr_devel asymmetric keys: fix printk format warning MODSIGN: Fix 32-bit overflow in X.509 certificate validity date checking MODSIGN: Make mrproper should remove generated files. MODSIGN: Use utf8 strings in signer's name in autogenerated X.509 certs MODSIGN: Use the same digest for the autogen key sig as for the module sig MODSIGN: Sign modules during the build process MODSIGN: Provide a script for generating a key ID from an X.509 cert MODSIGN: Implement module signature checking MODSIGN: Provide module signing public keys to the kernel MODSIGN: Automatically generate module signing keys if missing MODSIGN: Provide Kconfig options MODSIGN: Provide gitignore and make clean rules for extra files MODSIGN: Add FIPS policy module: signature checking hook X.509: Add a crypto key parser for binary (DER) X.509 certificates MPILIB: Provide a function to read raw data into an MPI X.509: Add an ASN.1 decoder X.509: Add simple ASN.1 grammar compiler ...
2012-10-08KEYS: Add payload preparsing opportunity prior to key instantiate or updateDavid Howells
Give the key type the opportunity to preparse the payload prior to the instantiation and update routines being called. This is done with the provision of two new key type operations: int (*preparse)(struct key_preparsed_payload *prep); void (*free_preparse)(struct key_preparsed_payload *prep); If the first operation is present, then it is called before key creation (in the add/update case) or before the key semaphore is taken (in the update and instantiate cases). The second operation is called to clean up if the first was called. preparse() is given the opportunity to fill in the following structure: struct key_preparsed_payload { char *description; void *type_data[2]; void *payload; const void *data; size_t datalen; size_t quotalen; }; Before the preparser is called, the first three fields will have been cleared, the payload pointer and size will be stored in data and datalen and the default quota size from the key_type struct will be stored into quotalen. The preparser may parse the payload in any way it likes and may store data in the type_data[] and payload fields for use by the instantiate() and update() ops. The preparser may also propose a description for the key by attaching it as a string to the description field. This can be used by passing a NULL or "" description to the add_key() system call or the key_create_or_update() function. This cannot work with request_key() as that required the description to tell the upcall about the key to be created. This, for example permits keys that store PGP public keys to generate their own name from the user ID and public key fingerprint in the key. The instantiate() and update() operations are then modified to look like this: int (*instantiate)(struct key *key, struct key_preparsed_payload *prep); int (*update)(struct key *key, struct key_preparsed_payload *prep); and the new payload data is passed in *prep, whether or not it was preparsed. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-09-13userns: net: Call key_alloc with GLOBAL_ROOT_UID, GLOBAL_ROOT_GID instead of ↵Eric W. Biederman
0, 0 In net/dns_resolver/dns_key.c and net/rxrpc/ar-key.c make them work with user namespaces enabled where key_alloc takes kuids and kgids. Pass GLOBAL_ROOT_UID and GLOBAL_ROOT_GID instead of bare 0's. Cc: Sage Weil <sage@inktank.com> Cc: ceph-devel@vger.kernel.org Cc: David Howells <dhowells@redhat.com> Cc: David Miller <davem@davemloft.net> Cc: linux-afs@lists.infradead.org Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-05-21Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security Pull security subsystem updates from James Morris: "New notable features: - The seccomp work from Will Drewry - PR_{GET,SET}_NO_NEW_PRIVS from Andy Lutomirski - Longer security labels for Smack from Casey Schaufler - Additional ptrace restriction modes for Yama by Kees Cook" Fix up trivial context conflicts in arch/x86/Kconfig and include/linux/filter.h * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (65 commits) apparmor: fix long path failure due to disconnected path apparmor: fix profile lookup for unconfined ima: fix filename hint to reflect script interpreter name KEYS: Don't check for NULL key pointer in key_validate() Smack: allow for significantly longer Smack labels v4 gfp flags for security_inode_alloc()? Smack: recursive tramsmute Yama: replace capable() with ns_capable() TOMOYO: Accept manager programs which do not start with / . KEYS: Add invalidation support KEYS: Do LRU discard in full keyrings KEYS: Permit in-place link replacement in keyring list KEYS: Perform RCU synchronisation on keys prior to key destruction KEYS: Announce key type (un)registration KEYS: Reorganise keys Makefile KEYS: Move the key config into security/keys/Kconfig KEYS: Use the compat keyctl() syscall wrapper on Sparc64 for Sparc32 compat Yama: remove an unused variable samples/seccomp: fix dependencies on arch macros Yama: add additional ptrace scopes ...
2012-05-11KEYS: Announce key type (un)registrationDavid Howells
Announce the (un)registration of a key type in the core key code rather than in the callers. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Mimi Zohar <zohar@us.ibm.com>
2012-04-15net: cleanup unsigned to unsigned intEric Dumazet
Use of "unsigned int" is preferred to bare "unsigned" in net tree. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-01-19KEYS: Allow special keyrings to be clearedDavid Howells
The kernel contains some special internal keyrings, for instance the DNS resolver keyring : 2a93faf1 I----- 1 perm 1f030000 0 0 keyring .dns_resolver: empty It would occasionally be useful to allow the contents of such keyrings to be flushed by root (cache invalidation). Allow a flag to be set on a keyring to mark that someone possessing the sysadmin capability can clear the keyring, even without normal write access to the keyring. Set this flag on the special keyrings created by the DNS resolver, the NFS identity mapper and the CIFS identity mapper. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Jeff Layton <jlayton@redhat.com> Acked-by: Steve Dickson <steved@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2011-03-17KEYS: Improve /proc/keysDavid Howells
Improve /proc/keys by: (1) Don't attempt to summarise the payload of a negated key. It won't have one. To this end, a helper function - key_is_instantiated() has been added that allows the caller to find out whether the key is positively instantiated (as opposed to being uninstantiated or negatively instantiated). (2) Do show keys that are negative, expired or revoked rather than hiding them. This requires an override flag (no_state_check) to be passed to search_my_process_keyrings() and keyring_search_aux() to suppress this check. Without this, keys that are possessed by the caller, but only grant permissions to the caller if possessed are skipped as the possession check fails. Keys that are visible due to user, group or other checks are visible with or without this patch. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2011-03-04DNS: Fix a NULL pointer deref when trying to read an error key [CVE-2011-1076]David Howells
When a DNS resolver key is instantiated with an error indication, attempts to read that key will result in an oops because user_read() is expecting there to be a payload - and there isn't one [CVE-2011-1076]. Give the DNS resolver key its own read handler that returns the error cached in key->type_data.x[0] as an error rather than crashing. Also make the kenter() at the beginning of dns_resolver_instantiate() limit the amount of data it prints, since the data is not necessarily NUL-terminated. The buggy code was added in: commit 4a2d789267e00b5a1175ecd2ddefcc78b83fbf09 Author: Wang Lei <wang840925@gmail.com> Date: Wed Aug 11 09:37:58 2010 +0100 Subject: DNS: If the DNS server returns an error, allow that to be cached [ver #2] This can trivially be reproduced by any user with the following program compiled with -lkeyutils: #include <stdlib.h> #include <keyutils.h> #include <err.h> static char payload[] = "#dnserror=6"; int main() { key_serial_t key; key = add_key("dns_resolver", "a", payload, sizeof(payload), KEY_SPEC_SESSION_KEYRING); if (key == -1) err(1, "add_key"); if (keyctl_read(key, NULL, 0) == -1) err(1, "read_key"); return 0; } What should happen is that keyctl_read() reports error 6 (ENXIO) to the user: dns-break: read_key: No such device or address but instead the kernel oopses. This cannot be reproduced with the 'keyutils add' or 'keyutils padd' commands as both of those cut the data down below the NUL termination that must be included in the data. Without this dns_resolver_instantiate() will return -EINVAL and the key will not be instantiated such that it can be read. The oops looks like: BUG: unable to handle kernel NULL pointer dereference at 0000000000000010 IP: [<ffffffff811b99f7>] user_read+0x4f/0x8f PGD 3bdf8067 PUD 385b9067 PMD 0 Oops: 0000 [#1] SMP last sysfs file: /sys/devices/pci0000:00/0000:00:19.0/irq CPU 0 Modules linked in: Pid: 2150, comm: dns-break Not tainted 2.6.38-rc7-cachefs+ #468 /DG965RY RIP: 0010:[<ffffffff811b99f7>] [<ffffffff811b99f7>] user_read+0x4f/0x8f RSP: 0018:ffff88003bf47f08 EFLAGS: 00010246 RAX: 0000000000000001 RBX: ffff88003b5ea378 RCX: ffffffff81972368 RDX: 0000000000000000 RSI: 0000000000000000 RDI: ffff88003b5ea378 RBP: ffff88003bf47f28 R08: ffff88003be56620 R09: 0000000000000000 R10: 0000000000000395 R11: 0000000000000002 R12: 0000000000000000 R13: 0000000000000000 R14: 0000000000000000 R15: ffffffffffffffa1 FS: 00007feab5751700(0000) GS:ffff88003e000000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 0000000000000010 CR3: 000000003de40000 CR4: 00000000000006f0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Process dns-break (pid: 2150, threadinfo ffff88003bf46000, task ffff88003be56090) Stack: ffff88003b5ea378 ffff88003b5ea3a0 0000000000000000 0000000000000000 ffff88003bf47f68 ffffffff811b708e ffff88003c442bc8 0000000000000000 00000000004005a0 00007fffba368060 0000000000000000 0000000000000000 Call Trace: [<ffffffff811b708e>] keyctl_read_key+0xac/0xcf [<ffffffff811b7c07>] sys_keyctl+0x75/0xb6 [<ffffffff81001f7b>] system_call_fastpath+0x16/0x1b Code: 75 1f 48 83 7b 28 00 75 18 c6 05 58 2b fb 00 01 be bb 00 00 00 48 c7 c7 76 1c 75 81 e8 13 c2 e9 ff 4c 8b b3 e0 00 00 00 4d 85 ed <41> 0f b7 5e 10 74 2d 4d 85 e4 74 28 e8 98 79 ee ff 49 39 dd 48 RIP [<ffffffff811b99f7>] user_read+0x4f/0x8f RSP <ffff88003bf47f08> CR2: 0000000000000010 Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Jeff Layton <jlayton@redhat.com> cc: Wang Lei <wang840925@gmail.com> Signed-off-by: James Morris <jmorris@namei.org>
2010-11-22Net: dns_resolver: Makefile: Remove deprecated kbuild goal definitionsTracey Dent
Changed Makefile to use <modules>-y instead of <modules>-objs because -objs is deprecated and not mentioned in Documentation/kbuild/makefiles.txt. Signed-off-by: Tracey Dent <tdent48227@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-11DNS: If the DNS server returns an error, allow that to be cached [ver #2]Wang Lei
If the DNS server returns an error, allow that to be cached in the DNS resolver key in lieu of a value. Userspace passes the desired error number as an option in the payload: "#dnserror=<number>" Userspace must map h_errno from the name resolution routines to an appropriate Linux error before passing it up. Something like the following mapping is recommended: [HOST_NOT_FOUND] = ENODATA, [TRY_AGAIN] = EAGAIN, [NO_RECOVERY] = ECONNREFUSED, [NO_DATA] = ENODATA, in lieu of Linux errors specifically for representing name service errors. The filesystem must map these errors appropropriately before passing them to userspace. AFS is made to map ENODATA and EAGAIN to EDESTADDRREQ for the return to userspace; ECONNREFUSED is allowed to stand as is. The error can be seen in /proc/keys as a negative number after the description of the key. Compare, for example, the following key entries: 2f97238c I--Q-- 1 53s 3f010000 0 0 dns_resol afsdb:grand.centrall.org: -61 338bfbbe I--Q-- 1 59m 3f010000 0 0 dns_resol afsdb:grand.central.org: 37 If the error option is supplied in the payload, the main part of the payload is discarded. The key should have an expiry time set by userspace. Signed-off-by: Wang Lei <wang840925@gmail.com> Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-08-06[DNS RESOLVER] Minor typo correctionSteve French
CC: Dave Howells <dhowells@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-08-06DNS: Fixes for the DNS query moduleDavid Howells
Fixes for the DNS query module, including: (1) Use 'negative' instead of '-ve' in the documentation. (2) Mark the kdoc comment with '/**' on dns_query(). Reported-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-08-06cifs: Include linux/err.h for IS_ERR and PTR_ERRStephen Rothwell
Fixes build errors: net/dns_resolver/dns_key.c: In function 'init_dns_resolver': net/dns_resolver/dns_key.c:170: error: implicit declaration of function 'IS_ERR' net/dns_resolver/dns_key.c:171: error: implicit declaration of function 'PTR_ERR' net/dns_resolver/dns_query.c: In function 'dns_query': net/dns_resolver/dns_query.c:126: error: implicit declaration of function 'IS_ERR' net/dns_resolver/dns_query.c:127: error: implicit declaration of function 'PTR_ERR' Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-08-05DNS: Separate out CIFS DNS Resolver codeWang Lei
Separate out the DNS resolver key type from the CIFS filesystem into its own module so that it can be made available for general use, including the AFS filesystem module. This facility makes it possible for the kernel to upcall to userspace to have it issue DNS requests, package up the replies and present them to the kernel in a useful form. The kernel is then able to cache the DNS replies as keys can be retained in keyrings. Resolver keys are of type "dns_resolver" and have a case-insensitive description that is of the form "[<type>:]<domain_name>". The optional <type> indicates the particular DNS lookup and packaging that's required. The <domain_name> is the query to be made. If <type> isn't given, a basic hostname to IP address lookup is made, and the result is stored in the key in the form of a printable string consisting of a comma-separated list of IPv4 and IPv6 addresses. This key type is supported by userspace helpers driven from /sbin/request-key and configured through /etc/request-key.conf. The cifs.upcall utility is invoked for UNC path server name to IP address resolution. The CIFS functionality is encapsulated by the dns_resolve_unc_to_ip() function, which is used to resolve a UNC path to an IP address for CIFS filesystem. This part remains in the CIFS module for now. See the added Documentation/networking/dns_resolver.txt for more information. Signed-off-by: Wang Lei <wang840925@gmail.com> Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
