[ Debian: net-add-recursion-limit-to-gro.patch ]
Currently, GRO can do unlimited recursion through the gro_receive
handlers. This was fixed for tunneling protocols by limiting tunnel GRO
to one level with encap_mark, but both VLAN and TEB still have this
problem. Thus, the kernel is vulnerable to a stack overflow, if we
receive a packet composed entirely of VLAN headers.
This patch adds a recursion counter to the GRO layer to prevent stack
overflow. When a gro_receive function hits the recursion limit, GRO is
aborted for this skb and it is processed normally.
Thanks to Vladimír Beneš <vbenes@redhat.com> for the initial bug report.
Fixes: CVE-2016-7039
Fixes: 9b174d88c257 ("net: Add Transparent Ethernet Bridging GRO support.")
Fixes: 66e5133f19e9 ("vlan: Add GRO support for non hardware accelerated vlan")
Signed-off-by: Sabrina Dubroca <sd@queasysnail.net>
Reviewed-by: Jiri Benc <jbenc@redhat.com>
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
Signed-off-by: Philipp Hahn <hahn@univention.de>
Use the built-in function instead of memset.
Now that there are no more users kill dev_rebuild_header and all of it's
implementations.
This is long overdue.
Currently the only tunnel protocol that supports GRO with encapsulated
Ethernet is VXLAN. This pulls out the Ethernet code into a proper layer
so that it can be used by other tunnel protocols such as GRE and Geneve.
Signed-off-by: Jesse Gross <jesse@nicira.com>
This patch updates some of the flow_dissector api so that it can be used to
parse the length of ethernet buffers stored in fragments. Most of the
changes needed were to __skb_get_poff as it needed to be updated to support
sending a linear buffer instead of a skb.
I have split __skb_get_poff into two functions, the first is skb_get_poff
and it retains the functionality of the original __skb_get_poff. The other
function is __skb_get_poff which now works much like __skb_flow_dissect in
relation to skb_flow_dissect in that it provides the same functionality but
works with just a data buffer and hlen instead of needing an skb.
Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com>
Acked-by: Alexei Starovoitov <ast@plumgrid.com>
DSA is currently registering one packet_type function per EtherType it
needs to intercept in the receive path of a DSA-enabled Ethernet device.
Right now we have three of them: trailer, DSA and eDSA, and there might
be more in the future, this will not scale to the addition of new
protocols.
This patch proceeds with adding a new layer of abstraction and two new
functions:
dsa_switch_rcv() which will dispatch into the tag-protocol specific
receive function implemented by net/dsa/tag_*.c
dsa_slave_xmit() which will dispatch into the tag-protocol specific
transmit function implemented by net/dsa/tag_*.c
When we do create the per-port slave network devices, we iterate over
the switch protocol to assign the DSA-specific receive and transmit
operations.
A new fake ethertype value is used: ETH_P_XDSA to illustrate the fact
that this is no longer going to look like ETH_P_DSA or ETH_P_TRAILER
like it used to be.
This allows us to greatly simplify the check in eth_type_trans() and
always override the skb->protocol with ETH_P_XDSA for Ethernet switches
tagged protocol, while also reducing the number repetitive slave
netdevice_ops assignments.
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
Extend alloc_netdev{,_mq{,s}}() to take name_assign_type as argument, and convert
all users to pass NET_NAME_UNKNOWN.
Coccinelle patch:
expression sizeof_priv, name, setup, txqs, rxqs, count;
-alloc_netdev_mqs(sizeof_priv, name, setup, txqs, rxqs)
+alloc_netdev_mqs(sizeof_priv, name, NET_NAME_UNKNOWN, setup, txqs, rxqs)
-alloc_netdev_mq(sizeof_priv, name, setup, count)
+alloc_netdev_mq(sizeof_priv, name, NET_NAME_UNKNOWN, setup, count)
-alloc_netdev(sizeof_priv, name, setup)
+alloc_netdev(sizeof_priv, name, NET_NAME_UNKNOWN, setup)
v9: move comments here from the wrong commit
Signed-off-by: Tom Gundersen <teg@jklm.no>
Reviewed-by: David Herrmann <dh.herrmann@gmail.com>
eth_type_trans() can read uninitialized memory as drivers
do not necessarily pull more than 14 bytes in skb->head before
calling it.
As David suggested, we can use skb_header_pointer() to
fix this without breaking some drivers that might not expect
eth_type_trans() pulling 2 additional bytes.
Cc: Ben Hutchings <bhutchings@solarflare.com>
Mark code path's likely/unlikely based on most common usage.
* Very few devices use dsa tags.
* Most traffic is Ethernet (not 802.2)
* No sane person uses trailer type or Novell encapsulation
Signed-off-by: Stephen Hemminger <stephen@networkplumber.org>
Remove old legacy comment and weird if condition.
The comment has outlived it's stay and is throwback to some
early net code (before my time). Maybe Dave remembers what it meant.
removed these checkpatch.pl warnings:
net/ethernet/eth.c:61: WARNING: Use #include <linux/uaccess.h> instead of <asm/uaccess.h>
net/ethernet/eth.c:136: WARNING: Prefer netdev_dbg(netdev, ... then dev_dbg(dev, ... then pr_debug(... to printk(KERN_DEBUG ...
net/ethernet/eth.c:181: ERROR: space prohibited before that close parenthesis ')'
Signed-off-by: Avinash Kumar <avi.kp.137@gmail.com>
It's just a duplicate implementation of "%*phC". Thanks to Joe
Perches for showing that we had exactly this support in the
lib/vsprintf.c code already.
Add a new constant ETH_P_802_3_MIN, the minimum ethernet type for
an 802.3 frame. Frames with a lower value in the ethernet type field
are Ethernet II.
Also update all the users of this value that David Miller and
I could find to use the new constant.
Also correct a bug in util.c. The comparison with ETH_P_802_3_MIN
should be >= not >.
As suggested by Jesse Gross.
Compile tested only.
Cc: Jesse Gross <jesse@nicira.com>
Cc: Karsten Keil <isdn@linux-pingi.de>
Cc: John W. Linville <linville@tuxdriver.com>
Cc: Johannes Berg <johannes@sipsolutions.net>
Cc: Bart De Schuymer <bart.de.schuymer@pandora.be>
Cc: Stephen Hemminger <stephen@networkplumber.org>
Cc: Patrick McHardy <kaber@trash.net>
Cc: Marcel Holtmann <marcel@holtmann.org>
Cc: Gustavo Padovan <gustavo@padovan.org>
Cc: Johan Hedberg <johan.hedberg@gmail.com>
Cc: linux-bluetooth@vger.kernel.org
Cc: netfilter-devel@vger.kernel.org
Cc: bridge@lists.linux-foundation.org
Cc: linux-wireless@vger.kernel.org
Cc: linux1394-devel@lists.sourceforge.net
Cc: linux-media@vger.kernel.org
Cc: netdev@vger.kernel.org
Cc: dev@openvswitch.org
Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com>
Acked-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
Signed-off-by: Simon Horman <horms@verge.net.au>
When we set mac address, software mac address in system and hardware mac
address all need to be updated. Current eth_mac_addr() doesn't allow
callers to implement error handling nicely.
This patch split eth_mac_addr() to prepare part and real commit part,
then we can prepare first, and try to change hardware address, then do
the real commit if hardware address is set successfully.
Signed-off-by: Stefan Hajnoczi <stefanha@gmail.com>
Signed-off-by: Amos Kong <akong@redhat.com>
NET_ADDR_SET is set in dev_set_mac_address() no need to alter
dev->addr_assign_type value in drivers.
Signed-off-by: Jiri Pirko <jiri@resnulli.us>
The Ethernet II wrapper is only used by IPX protocol, may have once
been used by Appletalk but not currently. Therefore it makes sense to
move it to the IPX dust bin and drop the exports.
Build tested only.
Fix incorrect start markers, wrapped summary lines, missing section
breaks, incorrect separators, and some name mismatches.
Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
Introduce IFF_LIVE_ADDR_CHANGE priv_flag and use it to disable
netif_running() check in eth_mac_addr()
Signed-off-by: Jiri Pirko <jpirko@redhat.com>
Use the new bool function ether_addr_equal_64bits to add
some clarity and reduce the likelihood for misuse of
compare_ether_addr_64bits for sorting.
Done via cocci script:
$ cat compare_ether_addr_64bits.cocci
expression a,b;
- !compare_ether_addr_64bits(a, b)
+ ether_addr_equal_64bits(a, b)
expression a,b;
- compare_ether_addr_64bits(a, b)
+ !ether_addr_equal_64bits(a, b)
expression a,b;
- !ether_addr_equal_64bits(a, b) == 0
expression a,b;
- !ether_addr_equal_64bits(a, b) != 0
expression a,b;
- ether_addr_equal_64bits(a, b) == 0
expression a,b;
- ether_addr_equal_64bits(a, b) != 0
expression a,b;
- !!ether_addr_equal_64bits(a, b)
Use of "unsigned int" is preferred to bare "unsigned" in net tree.
Remove all #inclusions of asm/system.h preparatory to splitting and killing
it. Performed with the following command:
perl -p -i -e 's!^#\s*include\s*<asm/system[.]h>.*\n!!' `grep -Irl '^#\s*include\s*<asm/system[.]h>' *`
If eth_mac_addr() get called, usually if SIOCSIFHWADDR was
used to change the MAC of a ethernet device, reset the
addr_assign_type to NET_ADDR_PERM if the state was
NET_ADDR_RANDOM before. Reset the state since the MAC is
no longer random at least not from the kernel side.
v2: changed to bitops, removed if()
Signed-off-by: Danny Kukawka <danny.kukawka@bisect.de>
d88733150 introduced the IFF_SKB_TX_SHARING flag, which I unilaterally set in
ether_setup. In doing this I didn't realize that other flags (such as
IFF_XMIT_DST_RELEASE) might be set prior to calling the ether_setup routine.
This patch changes ether_setup to or in SKB_TX_SHARING so as not to
inadvertently clear other existing flags. Thanks to Pekka Riikonen for pointing
out my error
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
Reported-by: Pekka Riikonen <priikone@iki.fi>
CC: "David S. Miller" <davem@davemloft.net>
Pktgen attempts to transmit shared skbs to net devices, which can't be used by
some drivers as they keep state information in skbs. This patch adds a flag
marking drivers as being able to handle shared skbs in their tx path. Drivers
are defaulted to being unable to do so, but calling ether_setup enables this
flag, as 90% of the drivers calling ether_setup touch real hardware and can
handle shared skbs. A subsequent patch will audit drivers to ensure that the
flag is set properly
Reported-by: Jiri Pirko <jpirko@redhat.com>
CC: Robert Olsson <robert.olsson@its.uu.se>
CC: Eric Dumazet <eric.dumazet@gmail.com>
CC: Alexey Dobriyan <adobriyan@gmail.com>
CC: David S. Miller <davem@davemloft.net>
Fix new kernel-doc warning in eth.c:
Warning(net/ethernet/eth.c:237): No description found for parameter 'type'
Signed-off-by: Randy Dunlap <rdunlap@xenotime.net>
Fix new kernel-doc warning (copy-paste typo):
Warning(net/ethernet/eth.c:366): No description found for parameter 'rxqs'
Added alloc_netdev_mqs function which allows the number of transmit and
receive queues to be specified independenty. alloc_netdev_mq was
changed to a macro to call the new function. Also added
alloc_etherdev_mqs with same purpose.
Signed-off-by: Tom Herbert <therbert@google.com>
Change "return (EXPR);" to "return EXPR;"
return is not a function, parentheses are not required.
strlcpy() returns the total length of the string they tried to create, so
we should not use its return value without any check. scnprintf() returns
the number of characters written into @buf not including the trailing '\0',
so use it instead here.
Signed-off-by: Changli Gao <xiaosuo@gmail.com>
This patch fix a code style issue, if a function is exported, the
EXPORT_SYMBOL macro for it should follow immediately after the closing
function brace line.
Signed-off-by: Chihau Chau <chihau@gmail.com>
remove useless union keyword in rtable, rt6_info and dn_route.
Since there is only one member in a union, the union keyword isn't useful.
In commit 6be8ac2f ("[NET]: uninline skb_pull, de-bloats a lot")
we uninlined skb_pull.
But in some critical paths it makes sense to inline this thing
and it helps performance significantly.
Create an skb_pull_inline() so that we can do this in a way that
serves also as annotation.
Based upon a patch by Eric Dumazet.
Eric's recent patch added __force, but this
place would seem to require actually doing
a byte order conversion so the printk is
consistent across architectures.
Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
Sparse can help us find endianness bugs, but we need to make some
cleanups to be able to more easily spot real bugs.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Using dev_hard_header allows us to use LLC with VLANs and potentially
other Ethernet/TokernRing specific encapsulations. It also removes code
duplication between LLC and Ethernet/TokenRing core code.
Signed-off-by: Octavian Purdila <opurdila@ixiacom.com>
The function print_mac in net/ethernet/eth.c is marked __deprecated
and not used. Remove it.
Signed-off-by: Marin Mitov <mitov@issp.bas.bg>
All drivers are already converted to new net_device_ops API
and nobody uses old API anymore.
Signed-off-by: Alexander Beregalov <a.beregalov@gmail.com>
Linus mentioned we could try to perform long word operations, even
on potentially unaligned addresses, on x86 at least. David mentioned
the HAVE_EFFICIENT_UNALIGNED_ACCESS test to handle this on all
arches that have efficient unailgned accesses.
I tried this idea and got nice assembly on 32 bits:
158: 33 82 38 01 00 00 xor 0x138(%edx),%eax
15e: 33 8a 34 01 00 00 xor 0x134(%edx),%ecx
164: c1 e0 10 shl $0x10,%eax
167: 09 c1 or %eax,%ecx
169: 74 0b je 176 <eth_type_trans+0x87>
And very nice assembly on 64 bits of course (one xor, one shl)
Nice oprofile improvement in eth_type_trans(), 0.17 % instead of 0.41 %,
expected since we remove 8 instructions on a fast path.
This patch implements a compare_ether_addr_64bits() function, that
uses the CONFIG_HAVE_EFFICIENT_UNALIGNED_ACCESS ifdef to efficiently
perform the 6 bytes comparison on all capable arches.
Signed-off-by: Eric Dumazet <dada1@cosmosbay.com>
When ethernet devices are converted, the function pointer setup
by eth_setup() need to be done during intialization.
This adds support for the Trailer switch tagging format. This is
another tagging that doesn't explicitly mark tagged packets with a
distinct ethertype, so that we need to add a similar hack in the
receive path as for the Original DSA tagging format.
Signed-off-by: Lennert Buytenhek <buytenh@marvell.com>
Tested-by: Byron Bradley <byron.bbradley@gmail.com>
Tested-by: Tim Ellis <tim.ellis@mac.com>
Most of the DSA switches currently in the field do not support the
Ethertype DSA tagging format that one of the previous patches added
support for, but only the original DSA tagging format.
The original DSA tagging format carries the same information as the
Ethertype DSA tagging format, but with the difference that it does not
have an ethertype field. In other words, when receiving a packet that
is tagged with an original DSA tag, there is no way of telling in
eth_type_trans() that this packet is in fact a DSA-tagged packet.
This patch adds a hook into eth_type_trans() which is only compiled in
if support for a switch chip that doesn't support Ethertype DSA is
selected, and which checks whether there is a DSA switch driver
instance attached to this network device which uses the old tag format.
If so, it sets the protocol field to ETH_P_DSA without looking at the
packet, so that the packet ends up in the right place.
Tested-by: Nicolas Pitre <nico@marvell.com>
Tested-by: Peter van Valderen <linux@ddcrew.com>
Tested-by: Dirk Teurlings <dirk@upexia.nl>
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
Paul Bolle wrote:
> http://bugzilla.kernel.org/show_bug.cgi?id=9923 would have been much easier to
> track down if eth_validate_addr() would somehow complain aloud if an address
> is invalid. Shouldn't it make at least some noise?
I guess it should return -EADDRNOTAVAIL similar to eth_mac_addr()
when validation fails.
print_mac() used many most net drivers and format_addr() used by
net-sysfs.c are very similar and they can be intergrated.
format_addr() is also identically redefined in the qla4xxx iscsi
driver.
Export a new function sysfs_format_mac() to be used by net-sysfs,
qla4xxx and others in the future. Both print_mac() and
sysfs_format_mac() call _format_mac_addr() to do the formatting.
Changed print_mac() to use unsigned char * to be consistent with
net_device struct's dev_addr. Added buffer length overrun checking
as suggested by Joe Perches.
Signed-off-by: Michael Chan <mchan@broadcom.com>
Since hardware header operations are part of the protocol class
not the device instance, make them into a separate object and
save memory.
Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org>
Wrap the hard_header_parse function to simplify next step of
header_ops conversion.
Add inline for common usage of hardware header creation, and
fix bug in IPV6 mcast where the assumption about negative return is
an errno. Negative return from hard_header means not enough space
was available,(ie -N bytes).
