[ Upstream commit 70b095c84326640eeacfd69a411db8fc36e8ab1a ]
IPV6=m
DEFRAG_IPV6=m
CONNTRACK=y yields:
net/netfilter/nf_conntrack_proto.o: In function `nf_ct_netns_do_get':
net/netfilter/nf_conntrack_proto.c:802: undefined reference to `nf_defrag_ipv6_enable'
net/netfilter/nf_conntrack_proto.o:(.rodata+0x640): undefined reference to `nf_conntrack_l4proto_icmpv6'
Setting DEFRAG_IPV6=y causes undefined references to ip6_rhash_params
ip6_frag_init and ip6_expire_frag_queue so it would be needed to force
IPV6=y too.
This patch gets rid of the 'followup linker error' by removing
the dependency of ipv6.ko symbols from netfilter ipv6 defrag.
Shared code is placed into a header, then used from both.
[ Upstream commit 40c3ff6d5e0809505a067dd423c110c5658c478c ]
Packet sockets may call dev_header_parse with NULL daddr. Make
lowpan_header_ops.create fail.
Fixes: 87a93e4eceb4 ("ieee802154: change needed headroom/tailroom")
Signed-off-by: Willem de Bruijn <willemb@google.com>
Acked-by: Alexander Aring <aring@mojatatu.com>
commit f18fa5de5ba7f1d6650951502bb96a6e4715a948 upstream.
This patch initialize stack variables which are used in
frag_lowpan_compare_key to zero. In my case there are padding bytes in the
structures ieee802154_addr as well in frag_lowpan_compare_key. Otherwise
the key variable contains random bytes. The result is that a compare of
two keys by memcmp works incorrect.
Fixes: 648700f76b03 ("inet: frags: use rhashtables for reassembly units")
Signed-off-by: Alexander Aring <aring@mojatatu.com>
Reported-by: Stefan Schmidt <stefan@osg.samsung.com>
Signed-off-by: Stefan Schmidt <stefan@osg.samsung.com>
Giving an integer to proc_doulongvec_minmax() is dangerous on 64bit arches,
since linker might place next to it a non zero value preventing a change
to ip6frag_low_thresh.
ip6frag_low_thresh is not used anymore in the kernel, but we do not
want to prematuraly break user scripts wanting to change it.
Since specifying a minimal value of 0 for proc_doulongvec_minmax()
is moot, let's remove these zero values in all defrag units.
Fixes: 6e00f7dd5e4e ("ipv6: frags: fix /proc/sys/net/ipv6/ip6frag_low_thresh")
Reported-by: Maciej Żenczykowski <maze@google.com>
(cherry picked from commit 3d23401283e80ceb03f765842787e0e79ff598b7)
Some users are willing to provision huge amounts of memory to be able
to perform reassembly reasonnably well under pressure.
Current memory tracking is using one atomic_t and integers.
Switch to atomic_long_t so that 64bit arches can use more than 2GB,
without any cost for 32bit arches.
Note that this patch avoids an overflow error, if high_thresh was set
to ~2GB, since this test in inet_frag_alloc() was never true :
if (... || frag_mem_limit(nf) > nf->high_thresh)
Tested:
$ echo 16000000000 >/proc/sys/net/ipv4/ipfrag_high_thresh
<frag DDOS>
$ grep FRAG /proc/net/sockstat
FRAG: inuse 14705885 memory 16000002880
$ nstat -n ; sleep 1 ; nstat | grep Reas
IpReasmReqds 3317150 0.0
IpReasmFails 3317112 0.0
(cherry picked from commit 3e67f106f619dcfaf6f4e2039599bdb69848c714)
This function is obsolete, after rhashtable addition to inet defrag.
(cherry picked from commit 2d44ed22e607f9a285b049de2263e3840673a260)
Some applications still rely on IP fragmentation, and to be fair linux
reassembly unit is not working under any serious load.
It uses static hash tables of 1024 buckets, and up to 128 items per bucket (!!!)
A work queue is supposed to garbage collect items when host is under memory
pressure, and doing a hash rebuild, changing seed used in hash computations.
This work queue blocks softirqs for up to 25 ms when doing a hash rebuild,
occurring every 5 seconds if host is under fire.
Then there is the problem of sharing this hash table for all netns.
It is time to switch to rhashtables, and allocate one of them per netns
to speedup netns dismantle, since this is a critical metric these days.
Lookup is now using RCU. A followup patch will even remove
the refcount hold/release left from prior implementation and save
a couple of atomic operations.
Before this patch, 16 cpus (16 RX queue NIC) could not handle more
than 1 Mpps frags DDOS.
After the patch, I reach 9 Mpps without any tuning, and can use up to 2GB
of storage for the fragments (exact number depends on frags being evicted
after timeout)
FRAG: inuse 1966916 memory 2140004608
A followup patch will change the limits for 64bit arches.
Cc: Kirill Tkhai <ktkhai@virtuozzo.com>
Cc: Herbert Xu <herbert@gondor.apana.org.au>
Cc: Florian Westphal <fw@strlen.de>
Cc: Jesper Dangaard Brouer <brouer@redhat.com>
Cc: Alexander Aring <alex.aring@gmail.com>
Cc: Stefan Schmidt <stefan@osg.samsung.com>
(cherry picked from commit 648700f76b03b7e8149d13cc2bdb3355035258a9)
We want to call lowpan_net_frag_init() earlier.
Similar to commit "inet: frags: refactor ipv6_frag_init()"
This is a prereq to "inet: frags: use rhashtables for reassembly units"
(cherry picked from commit 807f1844df4ac23594268fa9f41902d0549e92aa)
In preparation for unconditionally passing the struct timer_list pointer to
all timer callbacks, switch to using the new timer_setup() and from_timer()
to pass the timer pointer explicitly.
Cc: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru>
Cc: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org>
Cc: Pablo Neira Ayuso <pablo@netfilter.org>
Cc: Jozsef Kadlecsik <kadlec@blackhole.kfki.hu>
Cc: linux-wpan@vger.kernel.org
Cc: netdev@vger.kernel.org
Cc: netfilter-devel@vger.kernel.org
Cc: coreteam@netfilter.org
Acked-by: Stefan Schmidt <stefan@osg.samsung.com> # for ieee802154
(cherry picked from commit 78802011fbe34331bdef6f2dfb1634011f0e4c32)
In order to simplify the API, add a pointer to struct inet_frags.
This will allow us to make things less complex.
These functions no longer have a struct inet_frags parameter :
inet_frag_destroy(struct inet_frag_queue *q /*, struct inet_frags *f */)
inet_frag_put(struct inet_frag_queue *q /*, struct inet_frags *f */)
inet_frag_kill(struct inet_frag_queue *q /*, struct inet_frags *f */)
inet_frags_exit_net(struct netns_frags *nf /*, struct inet_frags *f */)
ip6_expire_frag_queue(struct net *net, struct frag_queue *fq)
(cherry picked from commit 093ba72914b696521e4885756a68a3332782c8de)
We will soon initialize one rhashtable per struct netns_frags
in inet_frags_init_net().
This patch changes the return value to eventually propagate an
error.
(cherry picked from commit 787bea7748a76130566f881c2342a0be4127d182)
commit ac74f87c789af40936a80131c4759f3e72579c3a upstream.
This patch fixes patch add handling to take care tail and headroom for
single 6lowpan frames. We need to be sure we have a skb with the right
head and tailroom for single frames. This patch do it by using
skb_copy_expand() if head and tailroom is not enough allocated by upper
layer.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=195059
Reported-by: David Palma <david.palma@ntnu.no>
Reported-by: Rabi Narayan Sahoo <rabinarayans0828@gmail.com>
Cc: stable@vger.kernel.org
Signed-off-by: Stefan Schmidt <stefan@datenfreihafen.org>
[ Upstream commit b30c122c0bbb0a1dc413085e177ea09467e65fdb ]
Otherwise NetworkManager (and iproute alike) is not able to identify the
parent IEEE 802.15.4 interface of a 6LoWPAN link.
Signed-off-by: Lubomir Rintel <lkundrak@v3.sk>
[ Upstream commit ca0edb131bdf1e6beaeb2b8289fd6b374b74147d ]
A tun device type can trivially be set to arbitrary value using
TUNSETLINK ioctl().
Therefore, lowpan_device_event() must really check that ieee802154_ptr
is not NULL.
Fixes: 2c88b5283f60d ("ieee802154: 6lowpan: remove check on null")
Reported-by: syzbot <syzkaller@googlegroups.com>
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
This reverts commit 1d6119baf0610f813eb9d9580eb4fd16de5b4ceb.
After reverting commit 6d7b857d541e ("net: use lib/percpu_counter API
for fragmentation mem accounting") then here is no need for this
fix-up patch. As percpu_counter is no longer used, it cannot
memory leak it any-longer.
Fixes: 6d7b857d541e ("net: use lib/percpu_counter API for fragmentation mem accounting")
Fixes: 1d6119baf061 ("net: fix percpu memory leaks")
Signed-off-by: Jesper Dangaard Brouer <brouer@redhat.com>
Make this const as it is only stored as a reference in a const field of
a net_device structure.
Signed-off-by: Bhumika Goyal <bhumirks@gmail.com>
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
Add support for extended error reporting.
Signed-off-by: Matthias Schiffer <mschiffer@universe-factory.net>
Acked-by: David Ahern <dsahern@gmail.com>
A common pattern with skb_put() is to just want to memcpy()
some data into the new space, introduce skb_put_data() for
this.
An spatch similar to the one for skb_put_zero() converts many
of the places using it:
identifier p, p2;
expression len, skb, data;
type t, t2;
-p = skb_put(skb, len);
+p = skb_put_data(skb, data, len);
-p = (t)skb_put(skb, len);
p2 = (t2)p;
-memcpy(p2, data, len);
-memcpy(p, data, len);
type t, t2;
identifier p, p2;
expression skb, data;
t *p;
-p = skb_put(skb, sizeof(t));
+p = skb_put_data(skb, data, sizeof(t));
-p = (t *)skb_put(skb, sizeof(t));
p2 = (t2)p;
-memcpy(p2, data, sizeof(*p));
-memcpy(p, data, sizeof(*p));
expression skb, len, data;
-memcpy(skb_put(skb, len), data, len);
+skb_put_data(skb, data, len);
(again, manually post-processed to retain some comments)
Reviewed-by: Stephen Hemminger <stephen@networkplumber.org>
The conflicts were two cases of overlapping changes in
batman-adv and the qed driver.
Network devices can allocate reasources and private memory using
netdev_ops->ndo_init(). However, the release of these resources
can occur in one of two different places.
Either netdev_ops->ndo_uninit() or netdev->destructor().
The decision of which operation frees the resources depends upon
whether it is necessary for all netdev refs to be released before it
is safe to perform the freeing.
netdev_ops->ndo_uninit() presumably can occur right after the
NETDEV_UNREGISTER notifier completes and the unicast and multicast
address lists are flushed.
netdev->destructor(), on the other hand, does not run until the
netdev references all go away.
Further complicating the situation is that netdev->destructor()
almost universally does also a free_netdev().
This creates a problem for the logic in register_netdevice().
Because all callers of register_netdevice() manage the freeing
of the netdev, and invoke free_netdev(dev) if register_netdevice()
fails.
If netdev_ops->ndo_init() succeeds, but something else fails inside
of register_netdevice(), it does call ndo_ops->ndo_uninit(). But
it is not able to invoke netdev->destructor().
This is because netdev->destructor() will do a free_netdev() and
then the caller of register_netdevice() will do the same.
However, this means that the resources that would normally be released
by netdev->destructor() will not be.
Over the years drivers have added local hacks to deal with this, by
invoking their destructor parts by hand when register_netdevice()
fails.
Many drivers do not try to deal with this, and instead we have leaks.
Let's close this hole by formalizing the distinction between what
private things need to be freed up by netdev->destructor() and whether
the driver needs unregister_netdevice() to perform the free_netdev().
netdev->priv_destructor() performs all actions to free up the private
resources that used to be freed by netdev->destructor(), except for
free_netdev().
netdev->needs_free_netdev is a boolean that indicates whether
free_netdev() should be done at the end of unregister_netdevice().
Now, register_netdevice() can sanely release all resources after
ndo_ops->ndo_init() succeeds, by invoking both ndo_ops->ndo_uninit()
and netdev->priv_destructor().
And at the end of unregister_netdevice(), we invoke
netdev->priv_destructor() and optionally call free_netdev().
This patch fixes the kernel oops when release net_device reference in
advance. In function raw_sendmsg(i think the dgram_sendmsg has the same
problem), there is a race condition between dev_put and dev_queue_xmit
when the device is gong that maybe lead to dev_queue_ximt to see
an illegal net_device pointer.
My test kernel is 3.13.0-32 and because i am not have a real 802154
device, so i change lowpan_newlink function to this:
/* find and hold real wpan device */
real_dev = dev_get_by_index(src_net, nla_get_u32(tb[IFLA_LINK]));
if (!real_dev)
return -ENODEV;
// if (real_dev->type != ARPHRD_IEEE802154) {
// dev_put(real_dev);
// return -EINVAL;
lowpan_dev_info(dev)->real_dev = real_dev;
lowpan_dev_info(dev)->fragment_tag = 0;
mutex_init(&lowpan_dev_info(dev)->dev_list_mtx);
Also, in order to simulate preempt, i change the raw_sendmsg function
to this:
skb->dev = dev;
skb->sk = sk;
skb->protocol = htons(ETH_P_IEEE802154);
dev_put(dev);
//simulate preempt
schedule_timeout_uninterruptible(30 * HZ);
err = dev_queue_xmit(skb);
if (err > 0)
err = net_xmit_errno(err);
and this is my userspace test code named test_send_data:
int main(int argc, char **argv)
char buf[127];
int sockfd;
sockfd = socket(AF_IEEE802154, SOCK_RAW, 0);
if (sockfd < 0) {
printf("create sockfd error: %s\n", strerror(errno));
return -1;
send(sockfd, buf, sizeof(buf), 0);
return 0;
This is my test case:
root@zhanglin-x-computer:~/develop/802154# uname -a
Linux zhanglin-x-computer 3.13.0-32-generic #57-Ubuntu SMP Tue Jul 15
03:51:08 UTC 2014 x86_64 x86_64 x86_64 GNU/Linux
root@zhanglin-x-computer:~/develop/802154# ip link add link eth0 name
lowpan0 type lowpan
//keep the lowpan0 device down
root@zhanglin-x-computer:~/develop/802154# ./test_send_data &
//wait a while
root@zhanglin-x-computer:~/develop/802154# ip link del link dev lowpan0
//the device is gone
//oops
[381.303307] general protection fault: 0000 [#1]SMP
[381.303407] Modules linked in: af_802154 6lowpan bnep rfcomm
bluetooth nls_iso8859_1 snd_hda_codec_hdmi snd_hda_codec_realtek
rts5139(C) snd_hda_intel
snd_had_codec snd_hwdep snd_pcm snd_page_alloc snd_seq_midi
snd_seq_midi_event snd_rawmidi snd_req intel_rapl snd_seq_device
coretemp i915 kvm_intel
kvm snd_timer snd crct10dif_pclmul crc32_pclmul ghash_clmulni_intel
cypted drm_kms_helper drm i2c_algo_bit soundcore video mac_hid
parport_pc ppdev ip parport hid_generic
usbhid hid ahci r8169 mii libahdi
[381.304286] CPU:1 PID: 2524 Commm: 1 Tainted: G C 0 3.13.0-32-generic
[381.304409] Hardware name: Haier Haier DT Computer/Haier DT Codputer,
BIOS FIBT19H02_X64 06/09/2014
[381.304546] tasks: ffff000096965fc0 ti: ffffB0013779c000 task.ti:
ffffB8013779c000
[381.304659] RIP: 0010:[<ffffffff01621fe1>] [<ffffffff81621fe1>]
__dev_queue_ximt+0x61/0x500
[381.304798] RSP: 0018:ffffB8013779dca0 EFLAGS: 00010202
[381.304880] RAX: 272b031d57565351 RBX: 0000000000000000 RCX: ffff8800968f1a00
[381.304987] RDX: 0000000000000000 RSI: 0000000000000000 RDI: ffff8800968f1a00
[381.305095] RBP: ffff8e013773dce0 R08: 0000000000000266 R09: 0000000000000004
[381.305202] R10: 0000000000000004 R11: 0000000000000005 R12: ffff88013902e000
[381.305310] R13: 000000000000007f R14: 000000000000007f R15: ffff8800968f1a00
[381.305418] FS: 00007fc57f50f740(0000) GS: ffff88013fc80000(0000)
knlGS: 0000000000000000
[381.305540] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
[381.305627] CR2: 00007fad0841c000 CR3: 00000001368dd000 CR4: 00000000001007e0
[361.905734] Stack:
[381.305768] 00000000002052d0 000000003facb30a ffff88013779dcc0
ffff880137764000
[381.305898] ffff88013779de70 000000000000007f 000000000000007f
ffff88013902e000
[381.306026] ffff88013779dcf0 ffffffff81622490 ffff88013779dd39
ffffffffa03af9f1
[381.306155] Call Trace:
[381.306202] [<ffffffff81622490>] dev_queue_xmit+0x10/0x20
[381.306294] [<ffffffffa03af9f1>] raw_sendmsg+0x1b1/0x270 [af_802154]
[381.306396] [<ffffffffa03af054>] ieee802154_sock_sendmsg+0x14/0x20 [af_802154]
[381.306512] [<ffffffff816079eb>] sock_sendmsg+0x8b/0xc0
[381.306600] [<ffffffff811d52a5>] ? __d_alloc+0x25/0x180
[381.306687] [<ffffffff811a1f56>] ? kmem_cache_alloc_trace+0x1c6/0x1f0
[381.306791] [<ffffffff81607b91>] SYSC_sendto+0x121/0x1c0
[381.306878] [<ffffffff8109ddf4>] ? vtime_account_user+x54/0x60
[381.306975] [<ffffffff81020d45>] ? syscall_trace_enter+0x145/0x250
[381.307073] [<ffffffff816086ae>] SyS_sendto+0xe/0x10
[381.307156] [<ffffffff8172c87f>] tracesys+0xe1/0xe6
[381.307233] Code: c6 a1 a4 ff 41 8b 57 78 49 8b 47 20 85 d2 48 8b 80
78 07 00 00 75 21 49 8b 57 18 48 85 d2 74 18 48 85 c0 74 13 8b 92 ac
01 00 00 <3b> 50 10 73 08 8b 44 90 14 41 89 47 78 41 f6 84 24 d5 00 00
00
[381.307801] RIP [<ffffffff81621fe1>] _dev_queue_xmit+0x61/0x500
[381.307901] RSP <ffff88013779dca0>
[381.347512] Kernel panic - not syncing: Fatal exception in interrupt
[381.347747] drm_kms_helper: panic occurred, switching back to text console
In my opinion, there is always exist a chance that the device is gong
before call dev_queue_xmit.
I think the latest kernel is have the same problem and that
dev_put should be behind of the dev_queue_xmit.
Signed-off-by: Lin Zhang <xiaolou4617@gmail.com>
Explicit set skb->sk is needless, sock_alloc_send_skb is already set it.
This is an add-on to the previous patch that passes the extended ACK
structure where it's already available by existing genl_info or extack
function arguments.
This was done with this spatch (with some manual adjustment of
indentation):
expression A, B, C, D, E;
identifier fn, info;
fn(..., struct genl_info *info, ...) {
-nlmsg_parse(A, B, C, D, E, NULL)
+nlmsg_parse(A, B, C, D, E, info->extack)
-nla_parse_nested(A, B, C, D, NULL)
+nla_parse_nested(A, B, C, D, info->extack)
identifier fn, extack;
fn(..., struct netlink_ext_ack *extack, ...) {
+nlmsg_parse(A, B, C, D, E, extack)
-nla_parse(A, B, C, D, E, NULL)
+nla_parse(A, B, C, D, E, extack)
expression A, B, C, D;
+nla_parse_nested(A, B, C, D, extack)
-nlmsg_validate(A, B, C, D, NULL)
+nlmsg_validate(A, B, C, D, extack)
-nla_validate(A, B, C, D, NULL)
+nla_validate(A, B, C, D, extack)
expression A, B, C;
-nla_validate_nested(A, B, C, NULL)
+nla_validate_nested(A, B, C, extack)
Reviewed-by: Jiri Pirko <jiri@mellanox.com>
Pass the new extended ACK reporting struct to all of the generic
netlink parsing functions. For now, pass NULL in almost all callers
(except for some in the core.)
Now that %z is standartised in C99 there is no reason to support %Z.
Unlike %L it doesn't even make format strings smaller.
Use BUILD_BUG_ON in a couple ATM drivers.
In case anyone didn't notice lib/vsprintf.o is about half of SLUB which
is in my opinion is quite an achievement. Hopefully this patch inspires
someone else to trim vsprintf.c more.
Link: http://lkml.kernel.org/r/20170103230126.GA30170@avx2
Cc: Andy Shevchenko <andy.shevchenko@gmail.com>
Cc: Rasmus Villemoes <linux@rasmusvillemoes.dk>
That's the default now, no need for makefiles to set it.
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
Acked-by: Kalle Valo <kvalo@codeaurora.org>
Acked-by: Marcel Holtmann <marcel@holtmann.org>
Acked-by: Marc Kleine-Budde <mkl@pengutronix.de>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Acked-by: Arend van Spriel <arend.vanspriel@broadcom.com>
__bitwise__ used to mean "yes, please enable sparse checks
unconditionally", but now that we dropped __CHECK_ENDIAN__
__bitwise is exactly the same.
There aren't many users, replace it by __bitwise everywhere.
Acked-by: Krzysztof Kozlowski <krzk@kernel.org>
Akced-by: Lee Duncan <lduncan@suse.com>
I've observed a NULL pointer dereference in ieee802154_del_iface() during
netlink fuzzing. It's the ->wpan_phy dereference here:
phy = dev->ieee802154_ptr->wpan_phy;
My bet is that we're not checking that this is an IEEE802154 interface,
so let's do what ieee802154_nl_get_dev() is doing. (Maybe we should even
be calling this directly?)
Cc: Lennert Buytenhek <buytenh@wantstofly.org>
Cc: Marcel Holtmann <marcel@holtmann.org>
Cc: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com>
Cc: Sergey Lapin <slapin@ossfans.org>
Signed-off-by: Vegard Nossum <vegard.nossum@oracle.com>
Acked-by: Alexander Aring <aar@pengutronix.de>
Now genl_register_family() is the only thing (other than the
users themselves, perhaps, but I didn't find any doing that)
writing to the family struct.
In all families that I found, genl_register_family() is only
called from __init functions (some indirectly, in which case
I've add __init annotations to clarifly things), so all can
actually be marked __ro_after_init.
This protects the data structure from accidental corruption.
Instead of providing macros/inline functions to initialize
the families, make all users initialize them statically and
get rid of the macros.
This reduces the kernel code size by about 1.6k on x86-64
(with allyesconfig).
Static family IDs have never really been used, the only
use case was the workaround I introduced for those users
that assumed their family ID was also their multicast
group ID.
Additionally, because static family IDs would never be
reserved by the generic netlink code, using a relatively
low ID would only work for built-in families that can be
registered immediately after generic netlink is started,
which is basically only the control family (apart from
the workaround code, which I also had to add code for so
it would reserve those IDs)
Thus, anything other than GENL_ID_GENERATE is flawed and
luckily not used except in the cases I mentioned. Move
those workarounds into a few lines of code, and then get
rid of GENL_ID_GENERATE entirely, making it more robust.
This helper function allows family implementations to access
their family's attrbuf. This gets rid of the attrbuf usage
in families, and also adds locking validation, since it's not
valid to use the attrbuf with parallel_ops or outside of the
dumpit callback.
The RIOT-OS stack does send intra-pan frames but don't set the intra pan
flag inside the mac header. It seems this is valid frame addressing but
inefficient. Anyway this patch adds a new function for intra pan
addressing, doesn't matter if intra pan flag or source and destination
are the same. The newly introduction function will be used to check on
intra pan addressing for 6lowpan.
Signed-off-by: Alexander Aring <aar@pengutronix.de>
This patch reverts commit f9d1ce8f81eb ("ieee802154: fix netns settings").
The lowpan interface need to be created inside the net namespace where
the wpan interface is available. The wpan namespace can be changed only
by nl802154 before. Without this patch it's not possible to create a
lowpan interface for a wpan interface which isn't inside init_net
namespace.
Cc: Nicolas Dichtel <nicolas.dichtel@6wind.com>
Reviewed-by: Stefan Schmidt <stefan@osg.samsung.com>
This patch adds netns support for 802.15.4 subsystem. Most parts are
copy&pasted from wireless subsystem, it has the identically userspace
API.
As the following patch will allow upper devices to follow the call down
lower devices, we need to add dev here and not rely on n->dev.
Signed-off-by: Jiri Pirko <jiri@mellanox.com>
Reviewed-by: Ido Schimmel <idosch@mellanox.com>
This patch adds necessary handling for use the short address for
802.15.4 6lowpan. It contains support for IPHC address compression
and new matching algorithmn to decide which link layer address will be
used for 802.15.4 frame.
This patch will introduce a 6lowpan neighbour private data. Like the
interface private data we handle private data for generic 6lowpan and
for link-layer specific 6lowpan.
The current first use case if to save the short address for a 802.15.4
6lowpan neighbour.
Acked-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
It is time to add netdev_lockdep_set_classes() helper
so that lockdep annotations per device type are easier to manage.
This removes a lot of copies and missing annotations.
Instead of using a single bit (__QDISC___STATE_RUNNING)
in sch->__state, use a seqcount.
This adds lockdep support, but more importantly it will allow us
to sample qdisc/class statistics without having to grab qdisc root lock.
Cc: Cong Wang <xiyou.wangcong@gmail.com>
Cc: Jamal Hadi Salim <jhs@mojatatu.com>
Fix a logic error to avoid potential null pointer dereference.
Signed-off-by: Baozeng Ding <sploving1@gmail.com>
Reviewed-by: Stefan Schmidt<stefan@osg.samsung.com>
git://git.kernel.org/pub/scm/linux/kernel/git/bluetooth/bluetooth-next
Johan Hedberg says:
pull request: bluetooth-next 2016-04-26
Here's another set of Bluetooth & 802.15.4 patches for the 4.7 kernel:
- Cleanups & refactoring of ieee802154 & 6lowpan code
- Security related additions to ieee802154 and mrf24j40 driver
- Memory corruption fix to Bluetooth 6lowpan code
- Race condition fix in vhci driver
- Enhancements to the atusb 802.15.4 driver
Please let me know if there are any issues pulling. Thanks.
Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com>
nla_data() is now aligned on a 64-bit area.
This patch moves the 802.15.4 link layer specific structures to generic
6lowpan. This is necessary for special 802.15.4 6lowpan handling in
6lowpan generic layer.
Acked-by: Jukka Rissanen <jukka.rissanen@linux.intel.com>
This patch changes the naming for interface private data for lowpan
intefaces. The current private data scheme is:
| 6LoWPAN Generic | LinkLayer 6LoWPAN |
the current naming schemes are:
- 6LoWPAN Generic:
- lowpan_priv
- LinkLayer 6LoWPAN:
- BTLE
- lowpan_dev
- 802.15.4:
- lowpan_dev_info
the new naming scheme with this patch will be:
- 6LoWPAN Generic:
- lowpan_dev
- BTLE
- lowpan_btle_dev
- 802.15.4:
- lowpan_802154_dev
The short address is unique in combination with the panid. This patch
will add the panid for generating an ieee802154 address hash.
