path: root/net/ieee802154
2009-08-06af_ieee802154: provide dummy get/setsockoptDmitry Eremin-Solenikov
Provide dummt get/setsockopt implementations to stop these syscalls from oopsing on our sockets. Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com>
2009-08-06af_ieee802154: fix ioctl processingDmitry Eremin-Solenikov
fix two errors in ioctl processing: 1) if the ioctl isn't supported one should return -ENOIOCTLCMD 2) don't call ndo_do_ioctl if the device doesn't provide it Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com>
2009-06-29nl802154: add module license and descriptionDmitry Eremin-Solenikov
2009-06-29nl802154: fix Oops in ieee802154_nl_get_devDmitry Eremin-Solenikov
ieee802154_nl_get_dev() lacks check for the existance of the device that was returned by dev_get_XXX, thus resulting in Oops for non-existing devices. Fix it. Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com>
2009-06-19ieee802154: use standard routine for printing dumpsDmitry Baryshkov
Use print_hex_dump_bytes instead of self-written dumping function for outputting packet dumps. Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-18net: correct off-by-one write allocations reportsEric Dumazet
commit 2b85a34e911bf483c27cfdd124aeb1605145dc80 (net: No more expensive sock_hold()/sock_put() on each tx) changed initial sk_wmem_alloc value. We need to take into account this offset when reporting sk_wmem_alloc to user, in PROC_FS files or various ioctls (SIOCOUTQ/TIOCOUTQ) Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-11ieee802154: Use '%Zu' printf format for size_t.David S. Miller
2009-06-09net: add NL802154 interface for configuration of 802.15.4 devicesSergey Lapin
Add a netlink interface for configuration of IEEE 802.15.4 device. Also this interface specifies events notification sent by devices towards higher layers. Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Signed-off-by: Sergey Lapin <slapin@ossfans.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-09net: add IEEE 802.15.4 socket family implementationSergey Lapin
Add support for communication over IEEE 802.15.4 networks. This implementation is neither certified nor complete, but aims to that goal. This commit contains only the socket interface for communication over IEEE 802.15.4 networks. One can either send RAW datagrams or use SOCK_DGRAM to encapsulate data inside normal IEEE 802.15.4 packets. Configuration interface, drivers and software MAC 802.15.4 implementation will follow. Initial implementation was done by Maxim Gorbachyov, Maxim Osipov and Pavel Smolensky as a research project at Siemens AG. Later the stack was heavily reworked to better suit the linux networking model, and is now maitained as an open project partially sponsored by Siemens. Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Signed-off-by: Sergey Lapin <slapin@ossfans.org> Signed-off-by: David S. Miller <davem@davemloft.net>
