path: root/net/ipv4/devinet.c
2007-09-11[IPV4] devinet: show all addresses assigned to interfaceStephen Hemminger
Bug: http://bugzilla.kernel.org/show_bug.cgi?id=8876 Not all ips are shown by "ip addr show" command when IPs number assigned to an interface is more than 60-80 (in fact it depends on broadcast/label etc presence on each address). Steps to reproduce: It's terribly simple to reproduce: # for i in $(seq 1 100); do ip ad add 10.0.$i.1/24 dev eth10 ; done # ip addr show this will _not_ show all IPs. Looks like the problem is in netlink/ipv4 message processing. This is fix from bug submitter, it looks correct. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-31[IPV4/IPV6]: Fail registration if inet device construction failsHerbert Xu
Now that netdev notifications can fail, we can use this to signal errors during registration for IPv4/IPv6. In particular, if we fail to allocate memory for the inet device, we can fail the netdev registration. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-06-08[IPV4]: Do not remove idev when addresses are clearedHerbert Xu
Now that we create idev before addresses are added, it no longer makes sense to remove them when addresses are all deleted. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-06-07[NETLINK]: Mark netlink policies constPatrick McHardy
Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-06-07[IPV4]: Restore old behaviour of default config valuesHerbert Xu
Previously inet devices were only constructed when addresses are added (or rarely in ipmr). Therefore the default config values they get are the ones at the time of these operations. Now that we're creating inet devices earlier, this changes the behaviour of default config values in an incompatible way (see bug #8519). This patch creates a compromise by setting the default values at the same point as before but only for those that have not been explicitly set by the user since the inet device's creation. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-06-07[IPV4]: Add default config support after inetdev_initHerbert Xu
Previously once inetdev_init has been called on a device any changes made to ipv4_devconf_dflt would have no effect on that device's configuration. This creates a problem since we have moved the point where inetdev_init is called from when an address is added to where the device is registered. This patch is the first half of a set that tries to mimic the old behaviour while still calling inetdev_init. It propagates any changes to ipv4_devconf_dflt to those devices that have not had the corresponding attribute set. The next patch will forcibly set all values at the point where inetdev_init was previously called. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-06-07[IPV4]: Convert IPv4 devconf to an arrayHerbert Xu
This patch converts the ipv4_devconf config members (everything except sysctl) to an array. This allows easier manipulation which will be needed later on to provide better management of default config values. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-06-07[IPV4]: Only panic if inetdev_init fails for loopbackHerbert Xu
When I made the inetdev_init call work on all devices I incorrectly left in the panic call as well. It is obviously undesirable to panic on an allocation failure for a normal network device. This patch moves the panic call under the loopback if clause. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-03[NET]: Rework dev_base via list_head (v3)Pavel Emelianov
Cleanup of dev_base list use, with the aim to simplify making device list per-namespace. In almost every occasion, use of dev_base variable and dev->next pointer could be easily replaced by for_each_netdev loop. A few most complicated places were converted to using first_netdev()/next_netdev(). Signed-off-by: Pavel Emelianov <xemul@openvz.org> Acked-by: Kirill Korotaev <dev@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[RTNETLINK]: Remove unnecessary locking in dump callbacksPatrick McHardy
Since we're now holding the rtnl during the entire dump operation, we can remove additional locking for rtnl protected data. This patch does that for all simple cases (dev_base_lock for dev_base walking, RCU protection for FIB rule dumping). Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[IPv4]: Use rtnl registration interfaceThomas Graf
Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[IPV4]: cleanupStephen Hemminger
Add whitespace around keywords. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-03-09[IPV4]: Fix rtm_to_ifaddr() error handling.Evgeniy Polyakov
Return negative error value (embedded in the pointer) instead of returning NULL. Signed-off-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-26[IPV4] devinet: Register inetdev earlier.Herbert Xu
This patch allocates inetdev at registration for all devices in line with IPv6. This allows sysctl configuration on the devices to occur before they're brought up or addresses are added. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2007-02-14[PATCH] sysctl: remove the proc_dir_entry member for the sysctl tablesEric W. Biederman
It isn't needed anymore, all of the users are gone, and all of the ctl_table initializers have been converted to use explicit names of the fields they are initializing. [akpm@osdl.org: NTFS fix] Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Stephen Smalley <sds@tycho.nsa.gov> Cc: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] sysctl: remove insert_at_head from register_sysctlEric W. Biederman
The semantic effect of insert_at_head is that it would allow new registered sysctl entries to override existing sysctl entries of the same name. Which is pain for caching and the proc interface never implemented. I have done an audit and discovered that none of the current users of register_sysctl care as (excpet for directories) they do not register duplicate sysctl entries. So this patch simply removes the support for overriding existing entries in the sys_sysctl interface since no one uses it or cares and it makes future enhancments harder. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: David Howells <dhowells@redhat.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Andi Kleen <ak@muc.de> Cc: Jens Axboe <axboe@kernel.dk> Cc: Corey Minyard <minyard@acm.org> Cc: Neil Brown <neilb@suse.de> Cc: "John W. Linville" <linville@tuxdriver.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Jan Kara <jack@ucw.cz> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Mark Fasheh <mark.fasheh@oracle.com> Cc: David Chinner <dgc@sgi.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Patrick McHardy <kaber@trash.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-10[NET] IPV4: Fix whitespace errors.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-08[NETLINK]: Don't BUG on undersized allocationsPatrick McHardy
Currently netlink users BUG when the allocated skb for an event notification is undersized. While this is certainly a kernel bug, its not critical and crashing the kernel is too drastic, especially when considering that these errors have appeared multiple times in the past and it BUGs even if no listeners are present. This patch replaces BUG by WARN_ON and changes the notification functions to inform potential listeners of undersized allocations using a unique error code (EMSGSIZE). Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-01-09[IPV4] devinet: inetdev_init out label moved after RCU assignmentJarek Poplawski
inetdev_init out label moved after RCU assignment (final suggestion by Herbert Xu) Signed-off-by: Jarek Poplawski <jarkao2@o2.pl> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-01-04[IPV4/IPV6]: Fix inet{,6} device initialization order.David L Stevens
It is important that we only assign dev->ip{,6}_ptr only after all portions of the inet{,6} are setup. Otherwise we can receive packets before the multicast spinlocks et al. are initialized. Signed-off-by: David L Stevens <dlstevens@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-10[PATCH] sysctl: remove unused "context" paramAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Andi Kleen <ak@suse.de> Cc: "David S. Miller" <davem@davemloft.net> Cc: David Howells <dhowells@redhat.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-02[IPV4]: Use kmemdup in net/ipv4/devinet.cArnaldo Carvalho de Melo
Code diff stats: [acme@newtoy net-2.6.20]$ codiff /tmp/devinet.o.before /tmp/devinet.o.after /pub/scm/linux/kernel/git/acme/net-2.6.20/net/ipv4/devinet.c: devinet_sysctl_register | -38 1 function changed, 38 bytes removed [acme@newtoy net-2.6.20]$ Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2006-12-02[IPV6]: Assorted trivial endianness annotations.Al Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[NETLINK]: Do precise netlink message allocations where possibleThomas Graf
Account for the netlink message header size directly in nlmsg_new() instead of relying on the caller calculate it correctly. Replaces error handling of message construction functions when constructing notifications with bug traps since a failure implies a bug in calculating the size of the skb. Signed-off-by: Thomas Graf <tgraf@suug.ch> Acked-by: Paul Moore <paul.moore@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-28[IPV4]: annotate inetdev.h helpersAl Viro
inet_confirm_addr(), inet_ifa_byprefix(), ip_dev_find(), inet_make_mask() and inet_ifa_match() annotated, along with inferred net-endian variables Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-28[IPV4]: IFA_{LOCAL,ADDRESS,BROADCAST,ANYCAST} on ipv4 annotatedAl Viro
use be32 netlink accessors Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-28[IPV4]: annotate struct in_ifaddrAl Viro
ifa_local, ifa_address, ifa_mask, ifa_broadcast and ifa_anycast are net-endian. Annotated them and variables that are inferred to be net-endian. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-28[IPV4]: inet_addr_onlink() annotatedAl Viro
2006-09-28[IPV4]: inet_select_addr() annotationsAl Viro
argument and return value are net-endian. Annotated function and inferred net-endian variables in callers. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[NETLINK]: Make use of NLA_STRING/NLA_NUL_STRING attribute validationThomas Graf
Converts existing NLA_STRING attributes to use the new validation features, saving a couple of temporary buffers. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[IPv4] address: Convert address notification to use rtnl_notify()Thomas Graf
Adds support for NLM_F_ECHO allowing applications to easly see which address have been deleted, added, or promoted. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[IPv4]: Move interface address bits to linux/if_addr.hThomas Graf
2006-09-22[IPV4]: Convert address dumping to new netlink apiThomas Graf
2006-09-22[IPV4]: Convert address deletion to new netlink apiThomas Graf
Fixes various unvalidated netlink attributes causing memory corruptions when left empty by userspace. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[IPV4]: Convert address addition to new netlink apiThomas Graf
Adds rtm_to_ifaddr() transforming a netlink message to a struct in_ifaddr. Fixes various unvalidated netlink attributes causing memory corruptions when left empty by userspace applications. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[IPV4]: Use Protocol Independant Policy Routing Rules FrameworkThomas Graf
2006-07-21[NET]: Conversions from kmalloc+memset to k(z|c)alloc.Panagiotis Issaris
Signed-off-by: Panagiotis Issaris <takis@issaris.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-14[IPV4]: Possible cleanups.Adrian Bunk
This patch contains the following possible cleanups: - make the following needlessly global function static: - arp.c: arp_rcv() - remove the following unused EXPORT_SYMBOL's: - devinet.c: devinet_ioctl - fib_frontend.c: ip_rt_ioctl - inet_hashtables.c: inet_bind_bucket_create - inet_hashtables.c: inet_bind_hash - tcp_input.c: sysctl_tcp_abc - tcp_ipv4.c: sysctl_tcp_tw_reuse - tcp_output.c: sysctl_tcp_mtu_probing - tcp_output.c: sysctl_tcp_base_mss Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-27[PATCH] Notifier chain update: API changesAlan Stern
The kernel's implementation of notifier chains is unsafe. There is no protection against entries being added to or removed from a chain while the chain is in use. The issues were discussed in this thread: http://marc.theaimsgroup.com/?l=linux-kernel&m=113018709002036&w=2 We noticed that notifier chains in the kernel fall into two basic usage classes: "Blocking" chains are always called from a process context and the callout routines are allowed to sleep; "Atomic" chains can be called from an atomic context and the callout routines are not allowed to sleep. We decided to codify this distinction and make it part of the API. Therefore this set of patches introduces three new, parallel APIs: one for blocking notifiers, one for atomic notifiers, and one for "raw" notifiers (which is really just the old API under a new name). New kinds of data structures are used for the heads of the chains, and new routines are defined for registration, unregistration, and calling a chain. The three APIs are explained in include/linux/notifier.h and their implementation is in kernel/sys.c. With atomic and blocking chains, the implementation guarantees that the chain links will not be corrupted and that chain callers will not get messed up by entries being added or removed. For raw chains the implementation provides no guarantees at all; users of this API must provide their own protections. (The idea was that situations may come up where the assumptions of the atomic and blocking APIs are not appropriate, so it should be possible for users to handle these things in their own way.) There are some limitations, which should not be too hard to live with. For atomic/blocking chains, registration and unregistration must always be done in a process context since the chain is protected by a mutex/rwsem. Also, a callout routine for a non-raw chain must not try to register or unregister entries on its own chain. (This did happen in a couple of places and the code had to be changed to avoid it.) Since atomic chains may be called from within an NMI handler, they cannot use spinlocks for synchronization. Instead we use RCU. The overhead falls almost entirely in the unregister routine, which is okay since unregistration is much less frequent that calling a chain. Here is the list of chains that we adjusted and their classifications. None of them use the raw API, so for the moment it is only a placeholder. ATOMIC CHAINS ------------- arch/i386/kernel/traps.c: i386die_chain arch/ia64/kernel/traps.c: ia64die_chain arch/powerpc/kernel/traps.c: powerpc_die_chain arch/sparc64/kernel/traps.c: sparc64die_chain arch/x86_64/kernel/traps.c: die_chain drivers/char/ipmi/ipmi_si_intf.c: xaction_notifier_list kernel/panic.c: panic_notifier_list kernel/profile.c: task_free_notifier net/bluetooth/hci_core.c: hci_notifier net/ipv4/netfilter/ip_conntrack_core.c: ip_conntrack_chain net/ipv4/netfilter/ip_conntrack_core.c: ip_conntrack_expect_chain net/ipv6/addrconf.c: inet6addr_chain net/netfilter/nf_conntrack_core.c: nf_conntrack_chain net/netfilter/nf_conntrack_core.c: nf_conntrack_expect_chain net/netlink/af_netlink.c: netlink_chain BLOCKING CHAINS --------------- arch/powerpc/platforms/pseries/reconfig.c: pSeries_reconfig_chain arch/s390/kernel/process.c: idle_chain arch/x86_64/kernel/process.c idle_notifier drivers/base/memory.c: memory_chain drivers/cpufreq/cpufreq.c cpufreq_policy_notifier_list drivers/cpufreq/cpufreq.c cpufreq_transition_notifier_list drivers/macintosh/adb.c: adb_client_list drivers/macintosh/via-pmu.c sleep_notifier_list drivers/macintosh/via-pmu68k.c sleep_notifier_list drivers/macintosh/windfarm_core.c wf_client_list drivers/usb/core/notify.c usb_notifier_list drivers/video/fbmem.c fb_notifier_list kernel/cpu.c cpu_chain kernel/module.c module_notify_list kernel/profile.c munmap_notifier kernel/profile.c task_exit_notifier kernel/sys.c reboot_notifier_list net/core/dev.c netdev_chain net/decnet/dn_dev.c: dnaddr_chain net/ipv4/devinet.c: inetaddr_chain It's possible that some of these classifications are wrong. If they are, please let us know or submit a patch to fix them. Note that any chain that gets called very frequently should be atomic, because the rwsem read-locking used for blocking chains is very likely to incur cache misses on SMP systems. (However, if the chain's callout routines may sleep then the chain cannot be atomic.) The patch set was written by Alan Stern and Chandra Seetharaman, incorporating material written by Keith Owens and suggestions from Paul McKenney and Andrew Morton. [jes@sgi.com: restructure the notifier chain initialization macros] Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com> Signed-off-by: Jes Sorensen <jes@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-20[IPV4] ARP: Alloc acceptance of unsolicited ARP via netdevice sysctl.Neil Horman
Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-02-09[NETLINK]: illegal use of pid in rtnetlinkAlexey Kuznetsov
When a netlink message is not related to a netlink socket, it is issued by kernel socket with pid 0. Netlink "pid" has nothing to do with current->pid. I called it incorrectly, if it was named "port", the confusion would be avoided. Signed-off-by: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-11[PATCH] capable/capability.h (net/)Randy Dunlap
net: Use <linux/capability.h> where capable() is used. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-03[INET_SOCK]: Move struct inet_sock & helper functions to net/inet_sock.hArnaldo Carvalho de Melo
To help in reducing the number of include dependencies, several files were touched as they were getting needed headers indirectly for stuff they use. Thanks also to Alan Menegotto for pointing out that net/dccp/proto.c had linux/dccp.h include twice. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-22[IPV4]: Fix secondary IP addresses after promotionJamal Hadi Salim
This patch fixes the problem with promoting aliases when: a) a single primary and > 1 secondary addresses b) multiple primary addresses each with at least one secondary address Based on earlier efforts from Brian Pomerantz <bapper@piratehaven.org>, Patrick McHardy <kaber@trash.net> and Thomas Graf <tgraf@suug.ch> Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-10-26[IPV4]: Fix setting broadcast for SIOCSIFNETMASKDavid Engel
Fix setting of the broadcast address when the netmask is set via SIOCSIFNETMASK in Linux 2.6. The code wanted the old value of ifa->ifa_mask but used it after it had already been overwritten with the new value. Signed-off-by: David Engel <gigem@comcast.net> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2005-10-03[IPV4]: Replace __in_dev_get with __in_dev_get_rcu/rtnlHerbert Xu
The following patch renames __in_dev_get() to __in_dev_get_rtnl() and introduces __in_dev_get_rcu() to cover the second case. 1) RCU with refcnt should use in_dev_get(). 2) RCU without refcnt should use __in_dev_get_rcu(). 3) All others must hold RTNL and use __in_dev_get_rtnl(). There is one exception in net/ipv4/route.c which is in fact a pre-existing race condition. I've marked it as such so that we remember to fix it. This patch is based on suggestions and prior work by Suzanne Wood and Paul McKenney. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NETLINK]: Convert netlink users to use group numbers instead of bitmasksPatrick McHardy
2005-06-23[PATCH] create a kstrdup library functionPaulo Marques
This patch creates a new kstrdup library function and changes the "local" implementations in several places to use this function. Most of the changes come from the sound and net subsystems. The sound part had already been acknowledged by Takashi Iwai and the net part by David S. Miller. I left UML alone for now because I would need more time to read the code carefully before making changes there. Signed-off-by: Paulo Marques <pmarques@grupopie.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
