path: root/net/ipv4/fib_rules.c
2011-03-12ipv4: Use flowi4 in FIB layer.David S. Miller
2011-03-12ipv4: Pass ipv4 flow objects into fib_lookup() paths.David S. Miller
To start doing these conversions, we need to add some temporary flow4_* macros which will eventually go away when all the protocol code paths are changed to work on AF specific flowi objects. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-17ipv4: Use const'ify fib_result deep in the route call chains.David S. Miller
The only troublesome bit here is __mkroute_output which wants to override res->fi and res->type, compute those in local variables instead. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-14netfilter: fix Kconfig dependenciesPatrick McHardy
Fix dependencies of netfilter realm match: it depends on NET_CLS_ROUTE, which itself depends on NET_SCHED; this dependency is missing from netfilter. Since matching on realms is also useful without having NET_SCHED enabled and the option really only controls whether the tclassid member is included in route and dst entries, rename the config option to IP_ROUTE_CLASSID and move it outside of traffic scheduling context to get rid of the NET_SCHED dependeny. Reported-by: Vladis Kletnieks <Valdis.Kletnieks@vt.edu> Signed-off-by: Patrick McHardy <kaber@trash.net>
2010-10-05fib: RCU conversion of fib_lookup()Eric Dumazet
fib_lookup() converted to be called in RCU protected context, no reference taken and released on a contended cache line (fib_clntref) fib_table_lookup() and fib_semantic_match() get an additional parameter. struct fib_info gets an rcu_head field, and is freed after an rcu grace period. Stress test : (Sending 160.000.000 UDP frames on same neighbour, IP route cache disabled, dual E5540 @2.53GHz, 32bit kernel, FIB_HASH) (about same results for FIB_TRIE) Before patch : real 1m31.199s user 0m13.761s sys 23m24.780s After patch: real 1m5.375s user 0m14.997s sys 15m50.115s Before patch Profile : 13044.00 15.4% __ip_route_output_key vmlinux 8438.00 10.0% dst_destroy vmlinux 5983.00 7.1% fib_semantic_match vmlinux 5410.00 6.4% fib_rules_lookup vmlinux 4803.00 5.7% neigh_lookup vmlinux 4420.00 5.2% _raw_spin_lock vmlinux 3883.00 4.6% rt_set_nexthop vmlinux 3261.00 3.9% _raw_read_lock vmlinux 2794.00 3.3% fib_table_lookup vmlinux 2374.00 2.8% neigh_resolve_output vmlinux 2153.00 2.5% dst_alloc vmlinux 1502.00 1.8% _raw_read_lock_bh vmlinux 1484.00 1.8% kmem_cache_alloc vmlinux 1407.00 1.7% eth_header vmlinux 1406.00 1.7% ipv4_dst_destroy vmlinux 1298.00 1.5% __copy_from_user_ll vmlinux 1174.00 1.4% dev_queue_xmit vmlinux 1000.00 1.2% ip_output vmlinux After patch Profile : 13712.00 15.8% dst_destroy vmlinux 8548.00 9.9% __ip_route_output_key vmlinux 7017.00 8.1% neigh_lookup vmlinux 4554.00 5.3% fib_semantic_match vmlinux 4067.00 4.7% _raw_read_lock vmlinux 3491.00 4.0% dst_alloc vmlinux 3186.00 3.7% neigh_resolve_output vmlinux 3103.00 3.6% fib_table_lookup vmlinux 2098.00 2.4% _raw_read_lock_bh vmlinux 2081.00 2.4% kmem_cache_alloc vmlinux 2013.00 2.3% _raw_spin_lock vmlinux 1763.00 2.0% __copy_from_user_ll vmlinux 1763.00 2.0% ip_output vmlinux 1761.00 2.0% ipv4_dst_destroy vmlinux 1631.00 1.9% eth_header vmlinux 1440.00 1.7% _raw_read_unlock_bh vmlinux Reference results, if IP route cache is enabled : real 0m29.718s user 0m10.845s sys 7m37.341s 25213.00 29.5% __ip_route_output_key vmlinux 9011.00 10.5% dst_release vmlinux 4817.00 5.6% ip_push_pending_frames vmlinux 4232.00 5.0% ip_finish_output vmlinux 3940.00 4.6% udp_sendmsg vmlinux 3730.00 4.4% __copy_from_user_ll vmlinux 3716.00 4.4% ip_route_output_flow vmlinux 2451.00 2.9% __xfrm_lookup vmlinux 2221.00 2.6% ip_append_data vmlinux 1718.00 2.0% _raw_spin_lock_bh vmlinux 1655.00 1.9% __alloc_skb vmlinux 1572.00 1.8% sock_wfree vmlinux 1345.00 1.6% kfree vmlinux Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-05fib: cleanupsEric Dumazet
Code style cleanups before upcoming functional changes. C99 initializer for fib_props array. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-26net: rtnetlink: decouple rtnetlink address families from real address familiesPatrick McHardy
Decouple rtnetlink address families from real address families in socket.h to be able to add rtnetlink interfaces to code that is not a real address family without increasing AF_MAX/NPROTO. This will be used to add support for multicast route dumping from all tables as the proc interface can't be extended to support anything but the main table without breaking compatibility. This partialy undoes the patch to introduce independant families for routing rules and converts ipmr routing rules to a new rtnetlink family. Similar to that patch, values up to 127 are reserved for real address families, values above that may be used arbitrarily. Signed-off-by: Patrick McHardy <kaber@trash.net>
2010-04-26net: fib_rules: mark arguments to fib_rules_register const and __net_initdataPatrick McHardy
fib_rules_register() duplicates the template passed to it without modification, mark the argument as const. Additionally the templates are only needed when instantiating a new namespace, so mark them as __net_initdata, which means they can be discarded when CONFIG_NET_NS=n. Signed-off-by: Patrick McHardy <kaber@trash.net>
2010-04-13net: fib_rules: decouple address families from real address familiesPatrick McHardy
Decouple the address family values used for fib_rules from the real address families in socket.h. This allows to use fib_rules for code that is not a real address family without increasing AF_MAX/NPROTO. Values up to 127 are reserved for real address families and map directly to the corresponding AF value, values starting from 128 are for other uses. rtnetlink is changed to invoke the AF_UNSPEC dumpit/doit handlers for these families. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-13net: fib_rules: set family in fib_rule_hdr centrallyPatrick McHardy
All fib_rules implementations need to set the family in their ->fill() functions. Since the value is available to the generic fib_nl_fill_rule() function, set it there. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-13net: fib_rules: consolidate IPv4 and DECnet ->default_pref() functions.Patrick McHardy
Both functions are equivalent, consolidate them since a following patch needs a third implementation for multicast routing. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-03net: Allow fib_rule_unregister to batchEric W. Biederman
Refactor the code so fib_rules_register always takes a template instead of the actual fib_rules_ops structure that will be used. This is required for network namespace support so 2 out of the 3 callers already do this, it allows the error handling to be made common, and it allows fib_rules_unregister to free the template for hte caller. Modify fib_rules_unregister to use call_rcu instead of syncrhonize_rcu to allw multiple namespaces to be cleaned up in the same rcu grace period. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-03net 04/05: fib_rules: allow to delete local rulePatrick McHardy
commit d124356ce314fff22a047ea334379d5105b2d834 Author: Patrick McHardy <kaber@trash.net> Date: Thu Dec 3 12:16:35 2009 +0100 net: fib_rules: allow to delete local rule Allow to delete the local rule and recreate it with a higher priority. This can be used to force packets with a local destination out on the wire instead of routing them to loopback. Additionally this patch allows to recreate rules with a priority of 0. Combined with the previous patch to allow oif classification, a socket can be bound to the desired interface and packets routed to the wire like this: # move local rule to lower priority ip rule add pref 1000 lookup local ip rule del pref 0 # route packets of sockets bound to eth0 to the wire independant # of the destination address ip rule add pref 100 oif eth0 lookup 100 ip route add default dev eth0 table 100 Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-05ipv4: fib table algorithm performance improvementStephen Hemminger
The FIB algorithim for IPV4 is set at compile time, but kernel goes through the overhead of function call indirection at runtime. Save some cycles by turning the indirect calls to direct calls to either hash or trie code. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-20net: Remove unused parameter from fill method in fib_rules_ops.Rami Rosen
The netlink message header (struct nlmsghdr) is an unused parameter in fill method of fib_rules_ops struct. This patch removes this parameter from this method and fixes the places where this method is called. (include/net/fib_rules.h) Signed-off-by: Rami Rosen <ramirose@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-17ipv4: remove an unused parameter from configure method of fib_rules_ops.Rami Rosen
2008-07-05net: add fib_rules_ops to flush_cache methodDenis V. Lunev
This is required to pass namespace context into rt_cache_flush called from ->flush_cache. Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-05netns: add namespace parameter to rt_cache_flushDenis V. Lunev
2008-03-26[NET] NETNS: Omit sock->sk_net without CONFIG_NET_NS.YOSHIFUJI Hideaki
Introduce per-sock inlines: sock_net(), sock_net_set() and per-inet_timewait_sock inlines: twsk_net(), twsk_net_set(). Without CONFIG_NET_NS, no namespace other than &init_net exists. Let's explicitly define them to help compiler optimizations. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2008-01-28[IPV4]: Consolidate fib_select_default.Denis V. Lunev
The difference in the implementation of the fib_select_default when CONFIG_IP_MULTIPLE_TABLES is (not) defined looks negligible. Consolidate it and place into fib_frontend.c. Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETNS]: Add netns parameter to fib_lookup.Denis V. Lunev
2008-01-28[NETNS]: Process FIB rule action in the context of the namespace.Denis V. Lunev
Save namespace context on the fib rule at the rule creation time and call routing lookup in the correct namespace. Signed-off-by: Denis V. Lunev <den@openvz.org> Acked-by: Daniel Lezcano <dlezcano@fr.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETNS]: FIB rules API cleanup.Denis V. Lunev
Remove struct net from fib_rules_register(unregister)/notify_change paths and diet code size a bit. add/remove: 0/0 grow/shrink: 10/12 up/down: 35/-100 (-65) function old new delta notify_rule_change 273 280 +7 trie_show_stats 471 475 +4 fn_trie_delete 473 477 +4 fib_rules_unregister 144 148 +4 fib4_rule_compare 119 123 +4 resize 2842 2845 +3 fn_trie_select_default 515 518 +3 inet_sk_rebuild_header 836 838 +2 fib_trie_seq_show 764 766 +2 __devinet_sysctl_register 276 278 +2 fn_trie_lookup 1124 1123 -1 ip_fib_check_default 133 131 -2 devinet_conf_sysctl 223 221 -2 snmp_fold_field 126 123 -3 fn_trie_insert 2091 2086 -5 inet_create 876 870 -6 fib4_rules_init 197 191 -6 fib_sync_down 452 444 -8 inet_gso_send_check 334 325 -9 fib_create_info 3003 2991 -12 fib_nl_delrule 568 553 -15 fib_nl_newrule 883 852 -31 Signed-off-by: Denis V. Lunev <den@openvz.org> Acked-by: Daniel Lezcano <dlezcano@fr.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[FIB]: Add netns to fib_rules_ops.Denis V. Lunev
The backward link from FIB rules operations to the network namespace will allow to simplify the API a bit. Signed-off-by: Denis V. Lunev <den@openvz.org> Acked-by: Daniel Lezcano <dlezcano@fr.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETNS]: Namespacing IPv4 fib rules.Denis V. Lunev
The final trick for rules: place fib4_rules_ops into struct net and modify initialization path for this. Acked-by: Benjamin Thery <benjamin.thery@bull.net> Acked-by: Daniel Lezcano <dlezcano@fr.ibm.com> Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETNS]: Add netns parameter to fib_get_table/fib_new_table.Denis V. Lunev
This patch extends the fib_get_table and the fib_new_table functions with the network namespace pointer. That will allow to access the table relatively from the network namespace. Acked-by: Benjamin Thery <benjamin.thery@bull.net> Acked-by: Daniel Lezcano <dlezcano@fr.ibm.com> Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETNS]: Refactor fib initialization so it can handle multiple namespaces.Denis V. Lunev
This patch makes the fib to be initialized as a subsystem for the network namespaces. The code does not handle several namespaces yet, so in case of a creation of a network namespace, the creation/initialization will not occur. Acked-by: Benjamin Thery <benjamin.thery@bull.net> Acked-by: Daniel Lezcano <dlezcano@fr.ibm.com> Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[IPV4]: Check fib4_rules_init failure.Denis V. Lunev
This adds error paths into both versions of fib4_rules_init (with/without CONFIG_IP_MULTIPLE_TABLES) and returns error code to the caller. Acked-by: Benjamin Thery <benjamin.thery@bull.net> Acked-by: Daniel Lezcano <dlezcano@fr.ibm.com> Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETNS]: Pass fib_rules_ops into default_pref method.Denis V. Lunev
fib_rules_ops contains operations and the list of configured rules. ops will become per/namespace soon, so we need them to be known in the default_pref callback. Acked-by: Benjamin Thery <benjamin.thery@bull.net> Acked-by: Daniel Lezcano <dlezcano@fr.ibm.com> Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETNS]: Add netns parameter to fib_rules_(un)register.Denis V. Lunev
The patch extends the different fib rules API in order to pass the network namespace pointer. That will allow to access the different tables from a namespace relative object. As usual, the pointer to the init_net variable is passed as parameter so we don't break the network. Acked-by: Benjamin Thery <benjamin.thery@bull.net> Acked-by: Daniel Lezcano <dlezcano@fr.ibm.com> Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-11-10[INET]: Small possible memory leak in FIB rulesDenis V. Lunev
This patch fixes a small memory leak. Default fib rules can be deleted by the user if the rule does not carry FIB_RULE_PERMANENT flag, f.e. by ip rule flush Such a rule will not be freed as the ref-counter has 2 on start and becomes clearly unreachable after removal. Signed-off-by: Denis V. Lunev <den@openvz.org> Acked-by: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[IPV4/IPV6/DECNET]: Small cleanup for fib rules.Denis V. Lunev
This patch slightly cleanups FIB rules framework. rules_list as a pointer on struct fib_rules_ops is useless. It is always assigned with a static per/subsystem list in IPv4, IPv6 and DecNet. Signed-off-by: Denis V. Lunev <den@openvz.org> Acked-by: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-06-07[NETLINK]: Mark netlink policies constPatrick McHardy
2007-04-25[NET] fib_rules: delay route cache flush by ip_rt_min_delayThomas Graf
Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NET] fib_rules: Flush route cache after rule modificationsThomas Graf
The results of FIB rules lookups are cached in the routing cache except for IPv6 as no such cache exists. So far, it was the responsibility of the user to flush the cache after modifying any rules. This lead to many false bug reports due to misunderstanding of this concept. This patch automatically flushes the route cache after inserting or deleting a rule. Thanks to Muli Ben-Yehuda <muli@il.ibm.com> for catching a bug in the previous patch. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NET] rules: Unified rules dumpingThomas Graf
Implements a unified, protocol independant rules dumping function which is capable of both, dumping a specific protocol family or all of them. This speeds up dumping as less lookups are required. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[IPv4]: Use rtnl registration interfaceThomas Graf
2007-03-25[NET]: Fix fib_rules compatibility breakageThomas Graf
Based upon a patch from Patrick McHardy. The fib_rules netlink attribute policy introduced in 2.6.19 broke userspace compatibilty. When specifying a rule with "from all" or "to all", iproute adds a zero byte long netlink attribute, but the policy requires all addresses to have a size equal to sizeof(struct in_addr)/sizeof(struct in6_addr), resulting in a validation error. Check attribute length of FRA_SRC/FRA_DST in the generic framework by letting the family specific rules implementation provide the length of an address. Report an error if address length is non zero but no address attribute is provided. Fix actual bug by checking address length for non-zero instead of relying on availability of attribute. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[NETLINK]: Do precise netlink message allocations where possibleThomas Graf
Account for the netlink message header size directly in nlmsg_new() instead of relying on the caller calculate it correctly. Replaces error handling of message construction functions when constructing notifications with bug traps since a failure implies a bug in calculating the size of the skb. Signed-off-by: Thomas Graf <tgraf@suug.ch> Acked-by: Paul Moore <paul.moore@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[NET] rules: Share common attribute validation policyThomas Graf
Move the attribute policy for the non-specific attributes into net/fib_rules.h and include it in the respective protocols. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[NET] rules: Protocol independant mark selectorThomas Graf
Move mark selector currently implemented per protocol into the protocol independant part. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[NET]: Rethink mark field in struct flowiThomas Graf
Now that all protocols have been made aware of the mark field it can be moved out of the union thus simplyfing its usage. The config options in the IPv4/IPv6/DECnet subsystems to enable respectively disable mark based routing only obfuscate the code with ifdefs, the cost for the additional comparison in the flow key is insignificant, and most distributions have all these options enabled by default anyway. Therefore it makes sense to remove the config options and enable mark based routing by default. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-28[IPV4]: FRA_{DST,SRC} annotatedAl Viro
use be32 netlink accessors for those Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-28[IPV4]: net/ipv4/fib annotationsAl Viro
2006-09-22[NETLINK]: Make use of NLA_STRING/NLA_NUL_STRING attribute validationThomas Graf
Converts existing NLA_STRING attributes to use the new validation features, saving a couple of temporary buffers. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[IPV4]: Add support for fwmark masks in routing rulesPatrick McHardy
Add a FRA_FWMASK attributes for fwmark masks. For compatibility a mask of 0xFFFFFFFF is used when a mark value != 0 is sent without a mask. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[IPV4]: Increase number of possible routing tables to 2^32Patrick McHardy
Increase the number of possible routing tables to 2^32 by replacing the fixed sized array of pointers by a hash table and replacing iterations over all possible table IDs by hash table walking. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[NET]: Introduce RTA_TABLE/FRA_TABLE attributesPatrick McHardy
Introduce RTA_TABLE route attribute and FRA_TABLE routing rule attribute to hold 32 bit routing table IDs. Usespace compatibility is provided by continuing to accept and send the rtm_table field, but because of its limited size it can only carry the low 8 bits of the table ID. This implies that if larger IDs are used, _all_ userspace programs using them need to use RTA_TABLE. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[NET]: Use u32 for routing table IDsPatrick McHardy
Use u32 for routing table IDs in net/ipv4 and net/decnet in preparation of support for a larger number of routing tables. net/ipv6 already uses u32 everywhere and needs no further changes. No functional changes are made by this patch. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[IPV4]: Kill fib4_rules_clean().David S. Miller
As noted by Adrian Bunk this function is totally unused. Signed-off-by: David S. Miller <davem@davemloft.net>
