[ Upstream commit e5b1c6c6277d5a283290a8c033c72544746f9b5b ]
im->tomb and/or im->sources might not be NULL, but we
currently overwrite their values blindly.
Using swap() will make sure the following call to kfree_pmc(pmc)
will properly free the psf structures.
Tested with the C repro provided by syzbot, which basically does :
socket(PF_INET, SOCK_DGRAM, IPPROTO_IP) = 3
setsockopt(3, SOL_IP, IP_ADD_MEMBERSHIP, "\340\0\0\2\177\0\0\1\0\0\0\0", 12) = 0
ioctl(3, SIOCSIFFLAGS, {ifr_name="lo", ifr_flags=0}) = 0
setsockopt(3, SOL_IP, IP_MSFILTER, "\340\0\0\2\177\0\0\1\1\0\0\0\1\0\0\0\377\377\377\377", 20) = 0
ioctl(3, SIOCSIFFLAGS, {ifr_name="lo", ifr_flags=IFF_UP}) = 0
exit_group(0) = ?
BUG: memory leak
unreferenced object 0xffff88811450f140 (size 64):
comm "softirq", pid 0, jiffies 4294942448 (age 32.070s)
hex dump (first 32 bytes):
00 00 00 00 00 00 00 00 ff ff ff ff 00 00 00 00 ................
00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 ................
backtrace:
[<00000000c7bad083>] kmemleak_alloc_recursive include/linux/kmemleak.h:43 [inline]
[<00000000c7bad083>] slab_post_alloc_hook mm/slab.h:439 [inline]
[<00000000c7bad083>] slab_alloc mm/slab.c:3326 [inline]
[<00000000c7bad083>] kmem_cache_alloc_trace+0x13d/0x280 mm/slab.c:3553
[<000000009acc4151>] kmalloc include/linux/slab.h:547 [inline]
[<000000009acc4151>] kzalloc include/linux/slab.h:742 [inline]
[<000000009acc4151>] ip_mc_add1_src net/ipv4/igmp.c:1976 [inline]
[<000000009acc4151>] ip_mc_add_src+0x36b/0x400 net/ipv4/igmp.c:2100
[<000000004ac14566>] ip_mc_msfilter+0x22d/0x310 net/ipv4/igmp.c:2484
[<0000000052d8f995>] do_ip_setsockopt.isra.0+0x1795/0x1930 net/ipv4/ip_sockglue.c:959
[<000000004ee1e21f>] ip_setsockopt+0x3b/0xb0 net/ipv4/ip_sockglue.c:1248
[<0000000066cdfe74>] udp_setsockopt+0x4e/0x90 net/ipv4/udp.c:2618
[<000000009383a786>] sock_common_setsockopt+0x38/0x50 net/core/sock.c:3126
[<00000000d8ac0c94>] __sys_setsockopt+0x98/0x120 net/socket.c:2072
[<000000001b1e9666>] __do_sys_setsockopt net/socket.c:2083 [inline]
[<000000001b1e9666>] __se_sys_setsockopt net/socket.c:2080 [inline]
[<000000001b1e9666>] __x64_sys_setsockopt+0x26/0x30 net/socket.c:2080
[<00000000420d395e>] do_syscall_64+0x76/0x1a0 arch/x86/entry/common.c:301
[<000000007fd83a4b>] entry_SYSCALL_64_after_hwframe+0x44/0xa9
Fixes: 24803f38a5c0 ("igmp: do not remove igmp souce list info when set link down")
Cc: Hangbin Liu <liuhangbin@gmail.com>
Reported-by: syzbot+6ca1abd0db68b5173a4f@syzkaller.appspotmail.com
[ Upstream commit 903869bd10e6719b9df6718e785be7ec725df59f ]
ip_sf_list_clear_all() needs to be defined even if !CONFIG_IP_MULTICAST
Fixes: 3580d04aa674 ("ipv4/igmp: fix another memory leak in igmpv3_del_delrec()")
Reported-by: kbuild test robot <lkp@intel.com>
[ Upstream commit 3580d04aa674383c42de7b635d28e52a1e5bc72c ]
syzbot reported memory leaks [1] that I have back tracked to
a missing cleanup from igmpv3_del_delrec() when
(im->sfmode != MCAST_INCLUDE)
Add ip_sf_list_clear_all() and kfree_pmc() helpers to explicitely
handle the cleanups before freeing.
[1]
BUG: memory leak
unreferenced object 0xffff888123e32b00 (size 64):
comm "softirq", pid 0, jiffies 4294942968 (age 8.010s)
00 00 00 00 00 00 00 00 e0 00 00 01 00 00 00 00 ................
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
backtrace:
[<000000006105011b>] kmemleak_alloc_recursive include/linux/kmemleak.h:55 [inline]
[<000000006105011b>] slab_post_alloc_hook mm/slab.h:439 [inline]
[<000000006105011b>] slab_alloc mm/slab.c:3326 [inline]
[<000000006105011b>] kmem_cache_alloc_trace+0x13d/0x280 mm/slab.c:3553
[<000000004bba8073>] kmalloc include/linux/slab.h:547 [inline]
[<000000004bba8073>] kzalloc include/linux/slab.h:742 [inline]
[<000000004bba8073>] ip_mc_add1_src net/ipv4/igmp.c:1961 [inline]
[<000000004bba8073>] ip_mc_add_src+0x36b/0x400 net/ipv4/igmp.c:2085
[<00000000a46a65a0>] ip_mc_msfilter+0x22d/0x310 net/ipv4/igmp.c:2475
[<000000005956ca89>] do_ip_setsockopt.isra.0+0x1795/0x1930 net/ipv4/ip_sockglue.c:957
[<00000000848e2d2f>] ip_setsockopt+0x3b/0xb0 net/ipv4/ip_sockglue.c:1246
[<00000000b9db185c>] udp_setsockopt+0x4e/0x90 net/ipv4/udp.c:2616
[<000000003028e438>] sock_common_setsockopt+0x38/0x50 net/core/sock.c:3130
[<0000000015b65589>] __sys_setsockopt+0x98/0x120 net/socket.c:2078
[<00000000ac198ef0>] __do_sys_setsockopt net/socket.c:2089 [inline]
[<00000000ac198ef0>] __se_sys_setsockopt net/socket.c:2086 [inline]
[<00000000ac198ef0>] __x64_sys_setsockopt+0x26/0x30 net/socket.c:2086
[<000000000a770437>] do_syscall_64+0x76/0x1a0 arch/x86/entry/common.c:301
[<00000000d3adb93b>] entry_SYSCALL_64_after_hwframe+0x44/0xa9
Fixes: 9c8bb163ae78 ("igmp, mld: Fix memory leak in igmpv3/mld_del_delrec()")
Reported-by: syzbot <syzkaller@googlegroups.com>
There are two scenarios that we will restore deleted records. The first is
when device down and up(or unmap/remap). In this scenario the new filter
mode is same with previous one. Because we get it from in_dev->mc_list and
we do not touch it during device down and up.
The other scenario is when a new socket join a group which was just delete
and not finish sending status reports. In this scenario, we should use the
current filter mode instead of restore old one. Here are 4 cases in total.
old_socket new_socket before_fix after_fix
IN(A) IN(A) ALLOW(A) ALLOW(A)
IN(A) EX( ) TO_IN( ) TO_EX( )
EX( ) IN(A) TO_EX( ) ALLOW(A)
EX( ) EX( ) TO_EX( ) TO_EX( )
Fixes: 24803f38a5c0b (igmp: do not remove igmp souce list info when set link down)
Fixes: 1666d49e1d416 (mld: do not remove mld souce list info when set link down)
Signed-off-by: Hangbin Liu <liuhangbin@gmail.com>
[ Upstream commit e7aadb27a5415e8125834b84a74477bfbee4eff5 ]
Newly added igmpv3_get_srcaddr() needs to be called under rcu lock.
Timer callbacks do not ensure this locking.
WARNING: suspicious RCU usage
4.15.0+ #200 Not tainted
./include/linux/inetdevice.h:216 suspicious rcu_dereference_check() usage!
rcu_scheduler_active = 2, debug_locks = 1
3 locks held by syzkaller616973/4074:
#0: (&mm->mmap_sem){++++}, at: [<00000000bfce669e>] __do_page_fault+0x32d/0xc90 arch/x86/mm/fault.c:1355
#1: ((&im->timer)){+.-.}, at: [<00000000619d2f71>] lockdep_copy_map include/linux/lockdep.h:178 [inline]
#1: ((&im->timer)){+.-.}, at: [<00000000619d2f71>] call_timer_fn+0x1c6/0x820 kernel/time/timer.c:1316
#2: (&(&im->lock)->rlock){+.-.}, at: [<000000005f833c5c>] spin_lock_bh include/linux/spinlock.h:315 [inline]
#2: (&(&im->lock)->rlock){+.-.}, at: [<000000005f833c5c>] igmpv3_send_report+0x98/0x5b0 net/ipv4/igmp.c:600
stack backtrace:
CPU: 0 PID: 4074 Comm: syzkaller616973 Not tainted 4.15.0+ #200
Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011
Call Trace:
<IRQ>
__dump_stack lib/dump_stack.c:17 [inline]
dump_stack+0x194/0x257 lib/dump_stack.c:53
lockdep_rcu_suspicious+0x123/0x170 kernel/locking/lockdep.c:4592
__in_dev_get_rcu include/linux/inetdevice.h:216 [inline]
igmpv3_get_srcaddr net/ipv4/igmp.c:329 [inline]
igmpv3_newpack+0xeef/0x12e0 net/ipv4/igmp.c:389
add_grhead.isra.27+0x235/0x300 net/ipv4/igmp.c:432
add_grec+0xbd3/0x1170 net/ipv4/igmp.c:565
igmpv3_send_report+0xd5/0x5b0 net/ipv4/igmp.c:605
igmp_send_report+0xc43/0x1050 net/ipv4/igmp.c:722
igmp_timer_expire+0x322/0x5c0 net/ipv4/igmp.c:831
call_timer_fn+0x228/0x820 kernel/time/timer.c:1326
expire_timers kernel/time/timer.c:1363 [inline]
__run_timers+0x7ee/0xb70 kernel/time/timer.c:1666
run_timer_softirq+0x4c/0x70 kernel/time/timer.c:1692
__do_softirq+0x2d7/0xb85 kernel/softirq.c:285
invoke_softirq kernel/softirq.c:365 [inline]
irq_exit+0x1cc/0x200 kernel/softirq.c:405
exiting_irq arch/x86/include/asm/apic.h:541 [inline]
smp_apic_timer_interrupt+0x16b/0x700 arch/x86/kernel/apic/apic.c:1052
apic_timer_interrupt+0xa9/0xb0 arch/x86/entry/entry_64.S:938
Fixes: a46182b00290 ("net: igmp: Use correct source address on IGMPv3 reports")
[ Upstream commit ad23b750933ea7bf962678972a286c78a8fa36aa ]
Commit "net: igmp: Use correct source address on IGMPv3 reports"
introduced a check to validate the source address of locally generated
IGMPv3 packets.
Instead of checking the local interface address directly, it uses
inet_ifa_match(fl4->saddr, ifa), which checks if the address is on the
local subnet (or equal to the point-to-point address if used).
This breaks for point-to-point interfaces, so check against
ifa->ifa_local directly.
Cc: Kevin Cernekee <cernekee@chromium.org>
Reported-by: Sebastian Gottschall <s.gottschall@dd-wrt.com>
Signed-off-by: Felix Fietkau <nbd@nbd.name>
[ Upstream commit a46182b00290839fa3fa159d54fd3237bd8669f0 ]
Closing a multicast socket after the final IPv4 address is deleted
from an interface can generate a membership report that uses the
source IP from a different interface. The following test script, run
from an isolated netns, reproduces the issue:
#!/bin/bash
ip link add dummy0 type dummy
ip link add dummy1 type dummy
ip link set dummy0 up
ip link set dummy1 up
ip addr add 10.1.1.1/24 dev dummy0
ip addr add 192.168.99.99/24 dev dummy1
tcpdump -U -i dummy0 &
socat EXEC:"sleep 2" \
UDP4-DATAGRAM:239.101.1.68:8889,ip-add-membership=239.0.1.68:10.1.1.1 &
sleep 1
ip addr del 10.1.1.1/24 dev dummy0
sleep 5
kill %tcpdump
RFC 3376 specifies that the report must be sent with a valid IP source
address from the destination subnet, or from address 0.0.0.0. Add an
extra check to make sure this is the case.
Signed-off-by: Kevin Cernekee <cernekee@chromium.org>
Reviewed-by: Andrew Lunn <andrew@lunn.ch>
[ Upstream commit b5476022bbada3764609368f03329ca287528dc8 ]
IPv4 stack reacts to changes to small MTU, by disabling itself under
RTNL.
But there is a window where threads not using RTNL can see a wrong
device mtu. This can lead to surprises, in igmp code where it is
assumed the mtu is suitable.
Fix this by reading device mtu once and checking IPv4 minimal MTU.
This patch adds missing IPV4_MIN_MTU define, to not abuse
ETH_MIN_MTU anymore.
Anuradha reported that statically added groups for interfaces enslaved
to a VRF device were not persisting. The problem is that igmp queries
and reports need to use the data in the in_dev for the real ingress
device rather than the VRF device. Update igmp_rcv accordingly.
Fixes: e58e41596811 ("net: Enable support for VRF with ipv4 multicast")
Reported-by: Anuradha Karuppiah <anuradhak@cumulusnetworks.com>
Signed-off-by: David Ahern <dsahern@gmail.com>
Reviewed-by: Nikolay Aleksandrov <nikolay@cumulusnetworks.com>
Mainline had UFO fixes, but UFO is removed in net-next so we
take the HEAD hunks.
Minor context conflict in bcmsysport statistics bug fix.
Commit dcd87999d415 ("igmp: net: Move igmp namespace init to correct file")
moved the igmp sysctls initialization from tcp_sk_init to igmp_net_init. This
function is only called as part of per-namespace initialization, only if
CONFIG_IP_MULTICAST is defined, otherwise igmp_mc_init() call in ip_init is
compiled out, casuing the igmp pernet ops to not be registerd and those sysctl
being left initialized with 0. However, there are certain functions, such as
ip_mc_join_group which are always compiled and make use of some of those
sysctls. Let's do a partial revert of the aforementioned commit and move the
sysctl initialization into inet_init_net, that way they will always have
sane values.
Fixes: dcd87999d415 ("igmp: net: Move igmp namespace init to correct file")
Link: https://bugzilla.kernel.org/show_bug.cgi?id=196595
Reported-by: Gerardo Exequiel Pozzi <vmlinuz386@gmail.com>
Signed-off-by: Nikolay Borisov <nborisov@suse.com>
refcount_t type and corresponding API should be
used instead of atomic_t when the variable is used as
a reference counter. This allows to avoid accidental
refcounter overflows that might lead to use-after-free
situations.
Signed-off-by: Elena Reshetova <elena.reshetova@intel.com>
Signed-off-by: Hans Liljestrand <ishkamiel@gmail.com>
Signed-off-by: David Windsor <dwindsor@gmail.com>
Two entries being added at the same time to the IFLA
policy table, whilst parallel bug fixes to decnet
routing dst handling overlapping with the dst gc removal
in net-next.
Andrey reported a lockdep warning on non-initialized
spinlock:
INFO: trying to register non-static key.
the code is fine but needs lockdep annotation.
turning off the locking correctness validator.
CPU: 1 PID: 4099 Comm: a.out Not tainted 4.12.0-rc6+ #9
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs 01/01/2011
Call Trace:
__dump_stack lib/dump_stack.c:16
dump_stack+0x292/0x395 lib/dump_stack.c:52
register_lock_class+0x717/0x1aa0 kernel/locking/lockdep.c:755
? 0xffffffffa0000000
__lock_acquire+0x269/0x3690 kernel/locking/lockdep.c:3255
lock_acquire+0x22d/0x560 kernel/locking/lockdep.c:3855
__raw_spin_lock_bh ./include/linux/spinlock_api_smp.h:135
_raw_spin_lock_bh+0x36/0x50 kernel/locking/spinlock.c:175
spin_lock_bh ./include/linux/spinlock.h:304
ip_mc_clear_src+0x27/0x1e0 net/ipv4/igmp.c:2076
igmpv3_clear_delrec+0xee/0x4f0 net/ipv4/igmp.c:1194
ip_mc_destroy_dev+0x4e/0x190 net/ipv4/igmp.c:1736
We miss a spin_lock_init() in igmpv3_add_delrec(), probably
because previously we never use it on this code path. Since
we already unlink it from the global mc_tomb list, it is
probably safe not to acquire this spinlock here. It does not
harm to have it although, to avoid conditional locking.
Fixes: c38b7d327aaf ("igmp: acquire pmc lock for ip_mc_clear_src()")
Reported-by: Andrey Konovalov <andreyknvl@google.com>
It seems like a historic accident that these return unsigned char *,
and in many places that means casts are required, more often than not.
Make these functions (skb_put, __skb_put and pskb_put) return void *
and remove all the casts across the tree, adding a (u8 *) cast only
where the unsigned char pointer was used directly, all done with the
following spatch:
expression SKB, LEN;
typedef u8;
identifier fn = { skb_put, __skb_put };
- *(fn(SKB, LEN))
+ *(u8 *)fn(SKB, LEN)
expression E, SKB, LEN;
type T;
- E = ((T *)(fn(SKB, LEN)))
+ E = fn(SKB, LEN)
which actually doesn't cover pskb_put since there are only three
users overall.
A handful of stragglers were converted manually, notably a macro in
drivers/isdn/i4l/isdn_bsdcomp.c and, oddly enough, one of the many
instances in net/bluetooth/hci_sock.c. In the former file, I also
had to fix one whitespace problem spatch introduced.
Andrey reported a use-after-free in add_grec():
for (psf = *psf_list; psf; psf = psf_next) {
psf_next = psf->sf_next;
where the struct ip_sf_list's were already freed by:
kfree+0xe8/0x2b0 mm/slub.c:3882
ip_mc_clear_src+0x69/0x1c0 net/ipv4/igmp.c:2078
ip_mc_dec_group+0x19a/0x470 net/ipv4/igmp.c:1618
ip_mc_drop_socket+0x145/0x230 net/ipv4/igmp.c:2609
inet_release+0x4e/0x1c0 net/ipv4/af_inet.c:411
sock_release+0x8d/0x1e0 net/socket.c:597
sock_close+0x16/0x20 net/socket.c:1072
This happens because we don't hold pmc->lock in ip_mc_clear_src()
and a parallel mr_ifc_timer timer could jump in and access them.
The RCU lock is there but it is merely for pmc itself, this
spinlock could actually ensure we don't access them in parallel.
Thanks to Eric and Long for discussion on this bug.
Cc: Eric Dumazet <edumazet@google.com>
Cc: Xin Long <lucien.xin@gmail.com>
Reviewed-by: Xin Long <lucien.xin@gmail.com>
In function igmpv3/mld_add_delrec() we allocate pmc and put it in
idev->mc_tomb, so we should free it when we don't need it in del_delrec().
But I removed kfree(pmc) incorrectly in latest two patches. Now fix it.
Fixes: 24803f38a5c0 ("igmp: do not remove igmp souce list info when ...")
Fixes: 1666d49e1d41 ("mld: do not remove mld souce list info when ...")
Reported-by: Daniel Borkmann <daniel@iogearbox.net>
5.2. Action on Reception of a Query
When a system receives a Query, it does not respond immediately.
Instead, it delays its response by a random amount of time, bounded
by the Max Resp Time value derived from the Max Resp Code in the
received Query message. A system may receive a variety of Queries on
different interfaces and of different kinds (e.g., General Queries,
Group-Specific Queries, and Group-and-Source-Specific Queries), each
of which may require its own delayed response.
Before scheduling a response to a Query, the system must first
consider previously scheduled pending responses and in many cases
schedule a combined response. Therefore, the system must be able to
maintain the following state:
o A timer per interface for scheduling responses to General Queries.
o A per-group and interface timer for scheduling responses to Group-
Specific and Group-and-Source-Specific Queries.
o A per-group and interface list of sources to be reported in the
response to a Group-and-Source-Specific Query.
When a new Query with the Router-Alert option arrives on an
interface, provided the system has state to report, a delay for a
response is randomly selected in the range (0, [Max Resp Time]) where
Max Resp Time is derived from Max Resp Code in the received Query
message. The following rules are then used to determine if a Report
needs to be scheduled and the type of Report to schedule. The rules
are considered in order and only the first matching rule is applied.
1. If there is a pending response to a previous General Query
scheduled sooner than the selected delay, no additional response
needs to be scheduled.
2. If the received Query is a General Query, the interface timer is
used to schedule a response to the General Query after the
selected delay. Any previously pending response to a General
Query is canceled.
--8<--
Currently the timer is rearmed with new random expiration time for
every incoming query regardless of possibly already pending report.
Which is not aligned with the above RFE.
It also might happen that higher rate of incoming queries can
postpone the report after the expiration time of the first query
causing group membership loss.
Now the per interface general query timer is rearmed only
when there is no pending report already scheduled on that interface or
the newly selected expiration time is before the already pending
scheduled report.
Signed-off-by: Michal Tesar <mtesar@redhat.com>
This was entirely automated, using the script by Al:
PATT='^[[:blank:]]*#[[:blank:]]*include[[:blank:]]*<asm/uaccess.h>'
sed -i -e "s!$PATT!#include <linux/uaccess.h>!" \
$(git grep -l "$PATT"|grep -v ^include/linux/uaccess.h)
to do the replacement at the end of the merge window.
Requested-by: Al Viro <viro@zeniv.linux.org.uk>
In commit 24cf3af3fed5 ("igmp: call ip_mc_clear_src..."), we forgot to remove
igmpv3_clear_delrec() in ip_mc_down(), which also called ip_mc_clear_src().
This make us clear all IGMPv3 source filter info after NETDEV_DOWN.
Move igmpv3_clear_delrec() to ip_mc_destroy_dev() and then no need
ip_mc_clear_src() in ip_mc_destroy_dev().
On the other hand, we should restore back instead of free all source filter
info in igmpv3_del_delrec(). Or we will not able to restore IGMPv3 source
filter info after NETDEV_UP and NETDEV_POST_TYPE_CHANGE.
Fixes: 24cf3af3fed5 ("igmp: call ip_mc_clear_src() only when ...")
Based on RFC3376 5.1 and RFC3810 6.1
If the per-interface listening change that triggers the new report is
a filter mode change, then the next [Robustness Variable] State
Change Reports will include a Filter Mode Change Record. This
applies even if any number of source list changes occur in that
period.
Old State New State State Change Record Sent
INCLUDE (A) EXCLUDE (B) TO_EX (B)
EXCLUDE (A) INCLUDE (B) TO_IN (B)
So we should not send source-list change if there is a filter-mode change.
Here are two scenarios:
1. Group deleted and filter mode is EXCLUDE, which means we need send a
TO_IN { }.
2. Not group deleted, but has pcm->crcount, which means we need send a
normal filter-mode-change.
At the same time, if the type is ALLOW or BLOCK, and have psf->sf_crcount,
we stop add records and decrease sf_crcount directly
Reference: https://www.ietf.org/mail-archive/web/magma/current/msg01274.html
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
Several cases of overlapping changes, as well as one instance
(vxlan) of a bug fix in 'net' overlapping with code movement
in 'net-next'.
The current reserved_tailroom calculation fails to take hlen and tlen into
account.
skb:
[__hlen__|__data____________|__tlen___|__extra__]
head skb_end_offset
In this representation, hlen + data + tlen is the size passed to alloc_skb.
"extra" is the extra space made available in __alloc_skb because of
rounding up by kmalloc. We can reorder the representation like so:
[__hlen__|__data____________|__extra__|__tlen___]
head skb_end_offset
The maximum space available for ip headers and payload without
fragmentation is min(mtu, data + extra). Therefore,
reserved_tailroom
= data + extra + tlen - min(mtu, data + extra)
= skb_end_offset - hlen - min(mtu, skb_end_offset - hlen - tlen)
= skb_tailroom - min(mtu, skb_tailroom - tlen) ; after skb_reserve(hlen)
Compare the second line to the current expression:
reserved_tailroom = skb_end_offset - min(mtu, skb_end_offset)
and we can see that hlen and tlen are not taken into account.
The min() in the third line can be expanded into:
if mtu < skb_tailroom - tlen:
reserved_tailroom = skb_tailroom - mtu
else:
reserved_tailroom = tlen
Depending on hlen, tlen, mtu and the number of multicast address records,
the current code may output skbs that have less tailroom than
dev->needed_tailroom or it may output more skbs than needed because not all
space available is used.
Fixes: 4c672e4b ("ipv6: mld: fix add_grhead skb_over_panic for devs with large MTUs")
Signed-off-by: Benjamin Poirier <bpoirier@suse.com>
Acked-by: Daniel Borkmann <daniel@iogearbox.net>
When igmp related sysctl were namespacified their initializatin was
erroneously put into the tcp socket namespace constructor. This
patch moves the relevant code into the igmp namespace constructor to
keep things consistent.
Also sprinkle some #ifdefs to silence warnings
Signed-off-by: Nikolay Borisov <kernel@kyup.com>
This was initially introduced in df2cf4a78e488d26 ("IGMP: Inhibit
reports for local multicast groups") by defining the sysctl in the
ipv4_net_table array, however it was never implemented to be
namespace aware. Fix this by changing the code accordingly.
When a multicast group is joined on a socket, a struct ip_mc_socklist
is appended to the sockets mc_list containing information about the
joined group.
If the interface is hot unplugged, this entry becomes stale. Prior to
commit 52ad353a5344f ("igmp: fix the problem when mc leave group") it
was possible to remove the stale entry by performing a
IP_DROP_MEMBERSHIP, passing either the old ifindex or ip address on
the interface. However, this fix enforces that the interface must
still exist. Thus with time, the number of stale entries grows, until
sysctl_igmp_max_memberships is reached and then it is not possible to
join and more groups.
The previous patch fixes an issue where a IP_DROP_MEMBERSHIP is
performed without specifying the interface, either by ifindex or ip
address. However here we do supply one of these. So loosen the
restriction on device existence to only apply when the interface has
not been specified. This then restores the ability to clean up the
stale entries.
Signed-off-by: Andrew Lunn <andrew@lunn.ch>
Fixes: 52ad353a5344f "(igmp: fix the problem when mc leave group")
Sasha reported the following lockdep warning:
Possible unsafe locking scenario:
CPU0 CPU1
lock(sk_lock-AF_INET);
lock(rtnl_mutex);
lock(rtnl_mutex);
This is due to that for IP_MSFILTER and MCAST_MSFILTER, we take
rtnl lock before the socket lock in setsockopt() path, but take
the socket lock before rtnl lock in getsockopt() path. All the
rest optnames are setsockopt()-only.
Fix this by aligning the getsockopt() path with the setsockopt()
path, so that all mcast socket path would be locked in the same
order.
Note, IPv6 part is different where rtnl lock is not held.
Fixes: 54ff9ef36bdf ("ipv4, ipv6: kill ip_mc_{join, leave}_group and ipv6_sock_mc_{join, drop}")
Reported-by: Sasha Levin <sasha.levin@oracle.com>
Cc: Marcelo Ricardo Leitner <marcelo.leitner@gmail.com>
Reviewed-by: Marcelo Ricardo Leitner <marcelo.leitner@gmail.com>
It is confusing and silly hiding a parameter so modify all of
the callers to pass in the appropriate socket or skb->sk if
no socket is known.
This patch updates ip_check_mc_rcu so that protocol is passed as a u8
instead of a u16.
The motivation is just to avoid any unneeded type transitions since some
systems will require an instruction to zero extend a u8 field to a u16.
Also it makes it a bit more readable as to the fact that protocol is a u8
so there are no byte ordering changes needed to pass it.
Signed-off-by: Alexander Duyck <aduyck@mirantis.com>
The range of addresses between 224.0.0.0 and 224.0.0.255 inclusive, is
reserved for the use of routing protocols and other low-level topology
discovery or maintenance protocols, such as gateway discovery and
group membership reporting. Multicast routers should not forward any
multicast datagram with destination addresses in this range,
regardless of its TTL.
Currently, IGMP reports are generated for this reserved range of
addresses even though a router will ignore this information since it
has no purpose. However, the presence of reserved group addresses in
an IGMP membership report uses up network bandwidth and can also
obscure addresses of interest when inspecting membership reports using
packet inspection or debug messages.
Although the RFCs for the various version of IGMP (e.g.RFC 3376 for
v3) do not specify that the reserved addresses be excluded from
membership reports, it should do no harm in doing so. In particular
there should be no adverse effect in any IGMP snooping functionality
since 224.0.0.x is specifically excluded as per RFC 4541 (IGMP and MLD
Snooping Switches Considerations) section 2.1.2. Data Forwarding
Rules:
2) Packets with a destination IP (DIP) address in the 224.0.0.X
range which are not IGMP must be forwarded on all ports.
IGMP reports for local multicast groups can now be optionally
inhibited by means of a system control variable (by setting the value
to zero) e.g.:
echo 0 > /proc/sys/net/ipv4/igmp_link_local_mcast_reports
To retain backwards compatibility the previous behaviour is retained
by default on system boot or reverted by setting the value back to
non-zero e.g.:
echo 1 > /proc/sys/net/ipv4/igmp_link_local_mcast_reports
Signed-off-by: Philip Downey <pdowney@brocade.com>
The recent refactoring of the IGMP and MLD parsing code into
ipv6_mc_check_mld() / ip_mc_check_igmp() introduced a potential crash /
BUG() invocation for bridges:
I wrongly assumed that skb_get() could be used as a simple reference
counter for an skb which is not the case. skb_get() bears additional
semantics, a user count. This leads to a BUG() invocation in
pskb_expand_head() / kernel panic if pskb_may_pull() is called on an skb
with a user count greater than one - unfortunately the refactoring did
just that.
Fixing this by removing the skb_get() call and changing the API: The
caller of ipv6_mc_check_mld() / ip_mc_check_igmp() now needs to
additionally check whether the returned skb_trimmed is a clone.
Fixes: 9afd85c9e455 ("net: Export IGMP/MLD message validation code")
Reported-by: Brenden Blanco <bblanco@plumgrid.com>
Signed-off-by: Linus Lüssing <linus.luessing@c0d3.blue>
Acked-by: Alexei Starovoitov <ast@plumgrid.com>
With this patch, the IGMP and MLD message validation functions are moved
from the bridge code to IPv4/IPv6 multicast files. Some small
refactoring was done to enhance readibility and to iron out some
differences in behaviour between the IGMP and MLD parsing code (e.g. the
skb-cloning of MLD messages is now only done if necessary, just like the
IGMP part always did).
Finally, these IGMP and MLD message validation functions are exported so
that not only the bridge can use it but batman-adv later, too.
The ipv4 code uses a mixture of coding styles. In some instances check
for non-NULL pointer is done as x != NULL and sometimes as x. x is
preferred according to checkpatch and this patch makes the code
consistent by adopting the latter form.
No changes detected by objdiff.
Signed-off-by: Ian Morris <ipm@chirality.org.uk>
for NULL pointer is done as x == NULL and sometimes as !x. !x is
As namespaces are sometimes used with overlapping ip address ranges,
we should also use the namespace as input to the hash to select the ip
fragmentation counter bucket.
Cc: Flavio Leitner <fbl@redhat.com>
in favor of their inner __ ones, which doesn't grab rtnl.
As these functions need to operate on a locked socket, we can't be
grabbing rtnl by then. It's too late and doing so causes reversed
locking.
So this patch:
- move rtnl handling to callers instead while already fixing some
reversed locking situations, like on vxlan and ipvs code.
- renames __ ones to not have the __ mark:
__ip_mc_{join,leave}_group -> ip_mc_{join,leave}_group
__ipv6_sock_mc_{join,drop} -> ipv6_sock_mc_{join,drop}
Signed-off-by: Marcelo Ricardo Leitner <marcelo.leitner@gmail.com>
Joining multicast group on ethernet level via "ip maddr" command would
not work if we have an Ethernet switch that does igmp snooping since
the switch would not replicate multicast packets on ports that did not
have IGMP reports for the multicast addresses.
Linux vxlan interfaces created via "ip link add vxlan" have the group option
that enables then to do the required join.
By extending ip address command with option "autojoin" we can get similar
functionality for openvswitch vxlan interfaces as well as other tunneling
mechanisms that need to receive multicast traffic. The kernel code is
structured similar to how the vxlan driver does a group join / leave.
example:
ip address add 224.1.1.10/24 dev eth5 autojoin
ip address del 224.1.1.10/24 dev eth5
Signed-off-by: Madhu Challa <challa@noironetworks.com>
There is a need to perform igmp join/leave operations while RTNL is
held.
Make ip_mc_{join|leave}_group() wrappers around
__ip_mc_{join|leave}_group() to avoid the proliferation of work queues.
For example, vxlan_igmp_join() could possibly be removed.
It has been reported that generating an MLD listener report on
devices with large MTUs (e.g. 9000) and a high number of IPv6
addresses can trigger a skb_over_panic():
skbuff: skb_over_panic: text:ffffffff80612a5d len:3776 put:20
head:ffff88046d751000 data:ffff88046d751010 tail:0xed0 end:0xec0
dev:port1
kernel BUG at net/core/skbuff.c:100!
invalid opcode: 0000 [#1] SMP
Modules linked in: ixgbe(O)
CPU: 3 PID: 0 Comm: swapper/3 Tainted: G O 3.14.23+ #4
Call Trace:
<IRQ>
[<ffffffff80578226>] ? skb_put+0x3a/0x3b
[<ffffffff80612a5d>] ? add_grhead+0x45/0x8e
[<ffffffff80612e3a>] ? add_grec+0x394/0x3d4
[<ffffffff80613222>] ? mld_ifc_timer_expire+0x195/0x20d
[<ffffffff8061308d>] ? mld_dad_timer_expire+0x45/0x45
[<ffffffff80255b5d>] ? call_timer_fn.isra.29+0x12/0x68
[<ffffffff80255d16>] ? run_timer_softirq+0x163/0x182
[<ffffffff80250e6f>] ? __do_softirq+0xe0/0x21d
[<ffffffff8025112b>] ? irq_exit+0x4e/0xd3
[<ffffffff802214bb>] ? smp_apic_timer_interrupt+0x3b/0x46
[<ffffffff8063f10a>] ? apic_timer_interrupt+0x6a/0x70
mld_newpack() skb allocations are usually requested with dev->mtu
in size, since commit 72e09ad107e7 ("ipv6: avoid high order allocations")
we have changed the limit in order to be less likely to fail.
However, in MLD/IGMP code, we have some rather ugly AVAILABLE(skb)
macros, which determine if we may end up doing an skb_put() for
adding another record. To avoid possible fragmentation, we check
the skb's tailroom as skb->dev->mtu - skb->len, which is a wrong
assumption as the actual max allocation size can be much smaller.
The IGMP case doesn't have this issue as commit 57e1ab6eaddc
("igmp: refine skb allocations") stores the allocation size in
the cb[].
Set a reserved_tailroom to make it fit into the MTU and use
skb_availroom() helper instead. This also allows to get rid of
igmp_skb_size().
Reported-by: Wei Liu <lw1a2.jing@gmail.com>
Fixes: 72e09ad107e7 ("ipv6: avoid high order allocations")
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
Cc: Hannes Frederic Sowa <hannes@stressinduktion.org>
Cc: David L Stevens <david.stevens@oracle.com>
Using a single fixed string is smaller code size than using
a format and many string arguments.
Reduces overall code size a little.
$ size net/ipv4/igmp.o* net/ipv6/mcast.o* net/ipv6/ip6_flowlabel.o*
34269 7012 14824 56105 db29 net/ipv4/igmp.o.new
34315 7012 14824 56151 db57 net/ipv4/igmp.o.old
30078 7869 13200 51147 c7cb net/ipv6/mcast.o.new
30105 7869 13200 51174 c7e6 net/ipv6/mcast.o.old
11434 3748 8580 23762 5cd2 net/ipv6/ip6_flowlabel.o.new
11491 3748 8580 23819 5d0b net/ipv6/ip6_flowlabel.o.old
use standard uppercase for definitions
Signed-off-by: Fabian Frederick <fabf@skynet.be>
In case we find a general query with non-zero number of sources, we
are dropping the skb as it's malformed.
RFC3376, section 4.1.8. Number of Sources (N):
This number is zero in a General Query or a Group-Specific Query,
and non-zero in a Group-and-Source-Specific Query.
Therefore, reflect that by using kfree_skb() instead of consume_skb().
Fixes: d679c5324d9a ("igmp: avoid drop_monitor false positives")
As in IPv6 people might increase the igmp query robustness variable to
make sure unsolicited state change reports aren't lost on the network. Add
and document this new knob to igmp code.
RFCs allow tuning this parameter back to first IGMP RFC, so we also use
this setting for all counters, including source specific multicast.
Also take over sysctl value when upping the interface and don't reuse
the last one seen on the interface.
Acked-by: Flavio Leitner <fbl@redhat.com>
The "rcu_dereference()" call is used directly in a condition.
Since its return value is never dereferenced it is recommended to use
"rcu_access_pointer()" instead of "rcu_dereference()".
Therefore, this patch makes the replacement.
The following Coccinelle semantic patch was used:
if(
- rcu_dereference
+ rcu_access_pointer
while(
- rcu_dereference
Signed-off-by: Andreea-Cristina Bernat <bernat.ada@gmail.com>
