NULL ptr OOPS
ipv4 ip_frag_reasm(), fully replace 'dev_net(dev)' with 'net', defined
previously patched into 2.6.29.
Between 2.6.28.10 and 2.6.29, net/ipv4/ip_fragment.c was patched,
changing from dev_net(dev) to container_of(...). Unfortunately the goto
section (out_fail) on oversized packets inside ip_frag_reasm() didn't
get touched up as well. Oversized IP packets cause a NULL pointer
dereference and immediate hang.
I discovered this running openvasd and my previous email on this is
titled: NULL pointer dereference at 2.6.32-rc8:net/ipv4/ip_fragment.c:566
Signed-off-by: David Ford <david@blue-labs.org>
Define three accessors to get/set dst attached to a skb
struct dst_entry *skb_dst(const struct sk_buff *skb)
void skb_dst_set(struct sk_buff *skb, struct dst_entry *dst)
void skb_dst_drop(struct sk_buff *skb)
This one should replace occurrences of :
dst_release(skb->dst)
skb->dst = NULL;
Delete skb->dst field
dev can be NULL in ip[6]_frag_reasm for skb's coming from RAW sockets.
Quagga's OSPFD sends fragmented packets on a RAW socket, when netfilter
conntrack reassembles them on the OUTPUT path you hit this code path.
You can test it with something like "hping2 -0 -d 2000 -f AA.BB.CC.DD"
With help from Jarek Poplawski.
Signed-off-by: Jorge Boncompte [DTI2] <jorge@dti2.net>
I want to compile out proc_* and sysctl_* handlers totally and
stub them to NULL depending on config options, however usage of &
will prevent this, since taking adress of NULL pointer will break
compilation.
So, drop & in front of every ->proc_handler and every ->strategy
handler, it was never needed in fact.
Signed-off-by: Jianjun Kong <jianjun@zeuux.org>
Using NIPQUAD() with NIPQUAD_FMT, %d.%d.%d.%d or %u.%u.%u.%u
can be replaced with %pI4
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
Clean up the various different email addresses of mine listed in the code
to a single current and valid address. As Dave says his network merges
for 2.6.28 are now done this seems a good point to send them in where
they won't risk disrupting real changes.
Signed-off-by: Alan Cox <alan@redhat.com>
Removes legacy reinvent-the-wheel type thing. The generic
machinery integrates much better to automated debugging aids
such as kerneloops.org (and others), and is unambiguous due to
better naming. Non-intuively BUG_TRAP() is actually equal to
WARN_ON() rather than BUG_ON() though some might actually be
promoted to BUG_ON() but I left that to future.
I could make at least one BUILD_BUG_ON conversion.
Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi>
Very simple - only ip_evictor (fragments) requires such.
This patch ends up the IP_XXX_STATS patching.
Signed-off-by: Pavel Emelyanov <xemul@openvz.org>
Some places, that deal with IP statistics already have where to
get a struct net from, but use it directly, without declaring
a separate variable on the stack.
So, save this net on the stack for future IP_XXX_STATS macros.
drivers/net/wireless/iwlwifi/iwl4965-base.c
The problem is that while we work w/o the inet_frags.lock even
read-locked the secret rebuild timer may occur (on another CPU, since
BHs are still disabled in the inet_frag_find) and change the rnd seed
for ipv4/6 fragments.
It was caused by my patch fd9e63544cac30a34c951f0ec958038f0529e244
([INET]: Omit double hash calculations in xxx_frag_intern) late
in the 2.6.24 kernel, so this should probably be queued to -stable.
This patch removes CVS keywords that weren't updated for a long time
from comments.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
Parts of fragments-related sysctls are read-only, but this is
done by cloning all the tables and dropping write-bits from
mode. Do the same but with read-only root.
The fragments sysctls also contains some, that are to be
visible, but read-only in net namespaces.
The naming in net/core/sysctl_net_core.c is - tables, that are
to be registered in namespaces have a "ns" word in their names.
So rename ones in ipv4/ip_fragment.c and ipv6/reassembly.c to
fit this.
And use %u to format port.
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
On Fri, 2008-03-28 at 03:24 -0700, Andrew Morton wrote:
> they should all be renamed.
Done for include/net and net
Introduce per-net_device inlines: dev_net(), dev_net_set().
Without CONFIG_NET_NS, no namespace other than &init_net exists.
Let's explicitly define them to help compiler optimizations.
Replace all the rest of the init_net with a proper net on the IP layer.
Signed-off-by: Denis V. Lunev <den@openvz.org>
Been seeing occasional panics in my testing of 2.6.25-rc in ip_defrag.
Offending line in ip_defrag is here:
net = skb->dev->nd_net
where dev is NULL. Bisected the problem down to commit
ac18e7509e7df327e30d6e073a787d922eaf211d ([NETNS][FRAGS]: Make the
inet_frag_queue lookup work in namespaces).
Below patch (idea from Patrick McHardy) fixes the problem for me.
Signed-off-by: Phil Oester <kernel@linuxace.com>
Acked-by: Patrick McHardy <kaber@trash.net>
On namespace start we mainly prepare the ctl variables.
When the namespace is stopped we have to kill all the fragments that
point to this namespace. The inet_frags_exit_net() handles it.
The inet_frags.lru_list is used for evicting only, so we have
to make it per-namespace, to evict only those fragments, who's
namespace exceeded its high threshold, but not the whole hash.
Besides, this helps to avoid long loops in evictor.
The spinlock is not per-namespace because it protects the
hash table as well, which is global.
Since we have one hashtable to lookup the fragment, having
different secret_interval-s for hash rebuild doesn't make
sense, so move this one to inet_frags.
The inet_frags_ctl becomes empty after this, so remove it.
The appropriate ctl table is kept read-only in namespaces.
This is the same as with the timeout variable.
Currently, after exceeding the high threshold _all_
the fragments are evicted, but it will be fixed in
later patch.
Move it to the netns_frags, adjust the usage and
make the appropriate ctl table writable.
Now fragment, that live in different namespaces can
live for different times.
Each namespace has to have own tables to tune their
different parameters, so duplicate the tables and
register them.
All the tables in sub-namespaces are temporarily made
read-only.
This is also simple, but introduces more changes, since
then mem counter is altered in more places.
This is simple - just move the variable from struct inet_frags
to struct netns_frags and adjust the usage appropriately.
Since fragment management code is consolidated, we cannot have the
pointer from inet_frag_queue to struct net, since we must know what
king of fragment this is.
So, I introduce the netns_frags structure. This one is currently
empty, but will be eventually filled with per-namespace
attributes. Each inet_frag_queue is tagged with this one.
The conntrack_reasm is not "netns-izated", so it has one static
netns_frags instance to keep working in init namespace.
This is a preparation for sysctl netns-ization.
Move the ctl tables to the files, where the tuning
variables reside. Plus make the helpers to register
the tables.
This will simplify the later patches and will keep
similar things closer to each other.
ipv4, ipv6 and conntrack_reasm are patched differently,
but the result is all the tables are in appropriate files.
Fix uninitialised variable in ip_frag_reasm(). err should be set to
-ENOMEM if the initial call of skb_clone() fails.
Since we now allocate the queues in inet_fragment.c, we
can safely free it in the same place. The ->destructor
callback thus becomes optional for inet_frags.
Since this callback is used to check for conflicts in
hashtable when inserting a newly created frag queue, we can
do the same by checking for matching the queue with the
argument, used to create one.
Here we need another callback ->match to check whether the
entry found in hash matches the key passed. The key used
is the same as the creation argument for inet_frag_create.
Yet again, this ->match is the same for netfilter and ipv6.
Running a frew steps forward - this callback will later
replace the ->equal one.
Since the inet_frag_find() uses the already consolidated
inet_frag_create() remove the xxx_frag_create from protocol
codes.
This one uses the xxx_frag_intern() and xxx_frag_alloc()
routines, which are already consolidated, so remove them
from protocol code (as promised).
The ->constructor callback is used to init the rest of
the frag queue and it is the same for netfilter and ipv6.
Just perform the kzalloc() allocation and setup common
fields in the inet_frag_queue(). Then return the result
to the caller to initialize the rest.
The inet_frag_alloc() may return NULL, so check the
return value before doing the container_of(). This looks
ugly, but the xxx_frag_alloc() will be removed soon.
The xxx_expire() timer callbacks are patches,
because the argument is now the inet_frag_queue, not
the protocol specific queue.
This routine checks for the existence of a given entry
in the hash table and inserts the new one if needed.
The ->equal callback is used to compare two frag_queue-s
together, but this one is temporary and will be removed
later. The netfilter code and the ipv6 one use the same
routine to compare frags.
The inet_frag_intern() always returns non-NULL pointer,
so convert the inet_frag_queue into protocol specific
one (with the container_of) without any checks.
Since the hash value is already calculated in xxx_find, we can
simply use it later. This is already done in netfilter code,
so make the same in ipv4 and ipv6.
kmalloc + memset -> kzalloc in frag_alloc_queue
These ones use the generic data types too, so move
them in one place.
After the evictor code is consolidated there is no need in
passing the extra pointer to the xxx_put() functions.
The only place when it made sense was the evictor code itself.
Maybe this change must got with the previous (or with the
next) patch, but I try to make them shorter as much as
possible to simplify the review (but they are still large
anyway), so this change goes in a separate patch.
The evictors collect some statistics for ipv4 and ipv6,
so make it return the number of evicted queues and account
them all at once in the caller.
The XXX_ADD_STATS_BH() macros are just for this case,
but maybe there are places in code, that can make use of
them as well.
To make in possible we need to know the exact frag queue
size for inet_frags->mem management and two callbacks:
* to destoy the skb (optional, used in conntracks only)
* to free the queue itself (mandatory, but later I plan to
move the allocation and the destruction of frag_queues
into the common place, so this callback will most likely
be optional too).
This code works with the generic data types as well, so
move this into inet_fragment.c
This move makes it possible to hide the secret_timer
management and the secret_rebuild routine completely in
the inet_fragment.c
Introduce the ->hashfn() callback in inet_frags() to get
the hashfun for a given inet_frag_queue() object.
Since now all the xxx_frag_kill functions now work
with the generic inet_frag_queue data type, this can
be moved into a common place.
The xxx_unlink() code is moved as well.
Some sysctl variables are used to tune the frag queues
management and it will be useful to work with them in
a common way in the future, so move them into one
structure, moreover they are the same for all the frag
management codes.
I don't place them in the existing inet_frags object,
introduced in the previous patch for two reasons:
1. to keep them in the __read_mostly section;
2. not to export the whole inet_frags objects outside.
There are some objects that are common in all the places
which are used to keep track of frag queues, they are:
* hash table
* LRU list
* rw lock
* rnd number for hash function
* the number of queues
* the amount of memory occupied by queues
* secret timer
Move all this stuff into one structure (struct inet_frags)
to make it possible use them uniformly in the future. Like
with the previous patch this mostly consists of hunks like
- write_lock(&ipfrag_lock);
+ write_lock(&ip4_frags.lock);
To address the issue with exporting the number of queues and
the amount of memory occupied by queues outside the .c file
they are declared in, I introduce a couple of helpers.
Introduce the struct inet_frag_queue in include/net/inet_frag.h
file and place there all the common fields from three structs:
* struct ipq in ipv4/ip_fragment.c
* struct nf_ct_frag6_queue in nf_conntrack_reasm.c
* struct frag_queue in ipv6/reassembly.c
After this, replace these fields on appropriate structures with
this structure instance and fix the users to use correct names
i.e. hunks like
- atomic_dec(&fq->refcnt);
+ atomic_dec(&fq->q.refcnt);
(these occupy most of the patch)
