path: root/net/ipv4/ip_fragment.c
2013-12-17net: Add utility functions to clear rxhashTom Herbert
In several places 'skb->rxhash = 0' is being done to clear the rxhash value in an skb. This does not clear l4_rxhash which could still be set so that the rxhash wouldn't be recalculated on subsequent call to skb_get_rxhash. This patch adds an explict function to clear all the rxhash related information in the skb properly. skb_clear_hash_if_not_l4 clears the rxhash only if it is not marked as l4_rxhash. Fixed up places where 'skb->rxhash = 0' was being called. Signed-off-by: Tom Herbert <therbert@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-10-23ipv4: initialize ip4_frags hash secret as late as possibleHannes Frederic Sowa
Defer the generation of the first hash secret for the ipv4 fragmentation cache as late as possible. ip4_frags.rnd gets initial seeded by inet_frags_init and regulary reseeded by inet_frag_secret_rebuild. Either we call ipqhashfn directly from ip_fragment.c in which case we initialize the secret directly. If we first get called by inet_frag_secret_rebuild we install a new secret by a manual call to get_random_bytes. This secret will be overwritten as soon as the first call to ipqhashfn happens. This is safe because we won't race while publishing the new secrets with anyone else. Cc: Eric Dumazet <edumazet@google.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/ethernet/emulex/benet/be_main.c drivers/net/ethernet/intel/igb/igb_main.c drivers/net/wireless/brcm80211/brcmsmac/mac80211_if.c include/net/scm.h net/batman-adv/routing.c net/ipv4/tcp_input.c The e{uid,gid} --> {uid,gid} credentials fix conflicted with the cleanup in net-next to now pass cred structs around. The be2net driver had a bug fix in 'net' that overlapped with the VLAN interface changes by Patrick McHardy in net-next. An IGB conflict existed because in 'net' the build_skb() support was reverted, and in 'net-next' there was a comment style fix within that code. Several batman-adv conflicts were resolved by making sure that all calls to batadv_is_my_mac() are changed to have a new bat_priv first argument. Eric Dumazet's TS ECR fix in TCP in 'net' conflicted with the F-RTO rewrite in 'net-next', mostly overlapping changes. Thanks to Stephen Rothwell and Antonio Quartulli for help with several of these merge resolutions. Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-17net: drop dst before queueing fragmentsEric Dumazet
Commit 4a94445c9a5c (net: Use ip_route_input_noref() in input path) added a bug in IP defragmentation handling, as non refcounted dst could escape an RCU protected section. Commit 64f3b9e203bd068 (net: ip_expire() must revalidate route) fixed the case of timeouts, but not the general problem. Tom Parkin noticed crashes in UDP stack and provided a patch, but further analysis permitted us to pinpoint the root cause. Before queueing a packet into a frag list, we must drop its dst, as this dst has limited lifetime (RCU protected) When/if a packet is finally reassembled, we use the dst of the very last skb, still protected by RCU and valid, as the dst of the reassembled packet. Use same logic in IPv6, as there is no need to hold dst references. Reported-by: Tom Parkin <tparkin@katalix.com> Tested-by: Tom Parkin <tparkin@katalix.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-24inet: generalize ipv4-only RFC3168 5.3 ecn fragmentation handling for future ↵Hannes Frederic Sowa
use by ipv6 This patch just moves some code arround to make the ip4_frag_ecn_table and IPFRAG_ECN_* constants accessible from the other reassembly engines. I also renamed ip4_frag_ecn_table to ip_frag_ecn_table. Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: Jesper Dangaard Brouer <jbrouer@redhat.com> Cc: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Acked-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-19inet: limit length of fragment queue hash table bucket listsHannes Frederic Sowa
This patch introduces a constant limit of the fragment queue hash table bucket list lengths. Currently the limit 128 is choosen somewhat arbitrary and just ensures that we can fill up the fragment cache with empty packets up to the default ip_frag_high_thresh limits. It should just protect from list iteration eating considerable amounts of cpu. If we reach the maximum length in one hash bucket a warning is printed. This is implemented on the caller side of inet_frag_find to distinguish between the different users of inet_fragment.c. I dropped the out of memory warning in the ipv4 fragment lookup path, because we already get a warning by the slab allocator. Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: Jesper Dangaard Brouer <jbrouer@redhat.com> Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-15net: Add skb_unclone() helper function.Pravin B Shelar
This function will be used in next GRE_GSO patch. This patch does not change any functionality. Signed-off-by: Pravin B Shelar <pshelar@nicira.com> Acked-by: Eric Dumazet <edumazet@google.com>
2013-01-29net: frag, move LRU list maintenance outside of rwlockJesper Dangaard Brouer
Updating the fragmentation queues LRU (Least-Recently-Used) list, required taking the hash writer lock. However, the LRU list isn't tied to the hash at all, so we can use a separate lock for it. Original-idea-by: Florian Westphal <fw@strlen.de> Signed-off-by: Jesper Dangaard Brouer <brouer@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-01-29net: frag helper functions for mem limit trackingJesper Dangaard Brouer
This change is primarily a preparation to ease the extension of memory limit tracking. The change does reduce the number atomic operation, during freeing of a frag queue. This does introduce a some performance improvement, as these atomic operations are at the core of the performance problems seen on NUMA systems. Signed-off-by: Jesper Dangaard Brouer <brouer@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-01-17net: increase fragment memory usage limitsJesper Dangaard Brouer
Increase the amount of memory usage limits for incomplete IP fragments. Arguing for new thresh high/low values: High threshold = 4 MBytes Low threshold = 3 MBytes The fragmentation memory accounting code, tries to account for the real memory usage, by measuring both the size of frag queue struct (inet_frag_queue (ipv4:ipq/ipv6:frag_queue)) and the SKB's truesize. We want to be able to handle/hold-on-to enough fragments, to ensure good performance, without causing incomplete fragments to hurt scalability, by causing the number of inet_frag_queue to grow too much (resulting longer searches for frag queues). For IPv4, how much memory does the largest frag consume. Maximum size fragment is 64K, which is approx 44 fragments with MTU(1500) sized packets. Sizeof(struct ipq) is 200. A 1500 byte packet results in a truesize of 2944 (not 2048 as I first assumed) (44*2944)+200 = 129736 bytes The current default high thresh of 262144 bytes, is obviously problematic, as only two 64K fragments can fit in the queue at the same time. How many 64K fragment can we fit into 4 MBytes: 4*2^20/((44*2944)+200) = 32.34 fragment in queues An attacker could send a separate/distinct fake fragment packets per queue, causing us to allocate one inet_frag_queue per packet, and thus attacking the hash table and its lists. How many frag queue do we need to store, and given a current hash size of 64, what is the average list length. Using one MTU sized fragment per inet_frag_queue, each consuming (2944+200) 3144 bytes. 4*2^20/(2944+200) = 1334 frag queues -> 21 avg list length An attack could send small fragments, the smallest packet I could send resulted in a truesize of 896 bytes (I'm a little surprised by this). 4*2^20/(896+200) = 3827 frag queues -> 59 avg list length When increasing these number, we also need to followup with improvements, that is going to help scalability. Simply increasing the hash size, is not enough as the current implementation does not have a per hash bucket locking. Signed-off-by: Jesper Dangaard Brouer <brouer@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-12-12Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking changes from David Miller: 1) Allow to dump, monitor, and change the bridge multicast database using netlink. From Cong Wang. 2) RFC 5961 TCP blind data injection attack mitigation, from Eric Dumazet. 3) Networking user namespace support from Eric W. Biederman. 4) tuntap/virtio-net multiqueue support by Jason Wang. 5) Support for checksum offload of encapsulated packets (basically, tunneled traffic can still be checksummed by HW). From Joseph Gasparakis. 6) Allow BPF filter access to VLAN tags, from Eric Dumazet and Daniel Borkmann. 7) Bridge port parameters over netlink and BPDU blocking support from Stephen Hemminger. 8) Improve data access patterns during inet socket demux by rearranging socket layout, from Eric Dumazet. 9) TIPC protocol updates and cleanups from Ying Xue, Paul Gortmaker, and Jon Maloy. 10) Update TCP socket hash sizing to be more in line with current day realities. The existing heurstics were choosen a decade ago. From Eric Dumazet. 11) Fix races, queue bloat, and excessive wakeups in ATM and associated drivers, from Krzysztof Mazur and David Woodhouse. 12) Support DOVE (Distributed Overlay Virtual Ethernet) extensions in VXLAN driver, from David Stevens. 13) Add "oops_only" mode to netconsole, from Amerigo Wang. 14) Support set and query of VEB/VEPA bridge mode via PF_BRIDGE, also allow DCB netlink to work on namespaces other than the initial namespace. From John Fastabend. 15) Support PTP in the Tigon3 driver, from Matt Carlson. 16) tun/vhost zero copy fixes and improvements, plus turn it on by default, from Michael S. Tsirkin. 17) Support per-association statistics in SCTP, from Michele Baldessari. And many, many, driver updates, cleanups, and improvements. Too numerous to mention individually. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1722 commits) net/mlx4_en: Add support for destination MAC in steering rules net/mlx4_en: Use generic etherdevice.h functions. net: ethtool: Add destination MAC address to flow steering API bridge: add support of adding and deleting mdb entries bridge: notify mdb changes via netlink ndisc: Unexport ndisc_{build,send}_skb(). uapi: add missing netconf.h to export list pkt_sched: avoid requeues if possible solos-pci: fix double-free of TX skb in DMA mode bnx2: Fix accidental reversions. bna: Driver Version Updated to 3.1.2.1 bna: Firmware update bna: Add RX State bna: Rx Page Based Allocation bna: TX Intr Coalescing Fix bna: Tx and Rx Optimizations bna: Code Cleanup and Enhancements ath9k: check pdata variable before dereferencing it ath5k: RX timestamp is reported at end of frame ath9k_htc: RX timestamp is reported at end of frame ...
2012-12-10ipv4: ip_check_defrag must not modify skb before unsharingJohannes Berg
ip_check_defrag() might be called from af_packet within the RX path where shared SKBs are used, so it must not modify the input SKB before it has unshared it for defragmentation. Use skb_copy_bits() to get the IP header and only pull in everything later. The same is true for the other caller in macvlan as it is called from dev->rx_handler which can also get a shared SKB. Reported-by: Eric Leblond <eric@regit.org> Cc: stable@vger.kernel.org Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-18net: Don't export sysctls to unprivileged usersEric W. Biederman
In preparation for supporting the creation of network namespaces by unprivileged users, modify all of the per net sysctl exports and refuse to allow them to unprivileged users. This makes it safe for unprivileged users in general to access per net sysctls, and allows sysctls to be exported to unprivileged users on an individual basis as they are deemed safe. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-19ipv6: unify fragment thresh handling codeAmerigo Wang
Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: Michal Kubeček <mkubecek@suse.cz> Cc: David Miller <davem@davemloft.net> Signed-off-by: Cong Wang <amwang@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-26ipv4: fix path MTU discovery with connection trackingPatrick McHardy
IPv4 conntrack defragments incoming packet at the PRE_ROUTING hook and (in case of forwarded packets) refragments them at POST_ROUTING independent of the IP_DF flag. Refragmentation uses the dst_mtu() of the local route without caring about the original fragment sizes, thereby breaking PMTUD. This patch fixes this by keeping track of the largest received fragment with IP_DF set and generates an ICMP fragmentation required error during refragmentation if that size exceeds the MTU. Signed-off-by: Patrick McHardy <kaber@trash.net> Acked-by: Eric Dumazet <edumazet@google.com> Acked-by: David S. Miller <davem@davemloft.net>
2012-07-26ipv4: Fix input route performance regression.David S. Miller
With the routing cache removal we lost the "noref" code paths on input, and this can kill some routing workloads. Reinstate the noref path when we hit a cached route in the FIB nexthops. With help from Eric Dumazet. Reported-by: Alexander Duyck <alexander.duyck@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-20ipv4: Kill ip_route_input_noref().David Miller
The "noref" argument to ip_route_input_common() is now always ignored because we do not cache routes, and in that case we must always grab a reference to the resulting 'dst'. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-06-27Revert "ipv4: tcp: dont cache unconfirmed intput dst"David S. Miller
This reverts commit c074da2810c118b3812f32d6754bd9ead2f169e7. This change has several unwanted side effects: 1) Sockets will cache the DST_NOCACHE route in sk->sk_rx_dst and we'll thus never create a real cached route. 2) All TCP traffic will use DST_NOCACHE and never use the routing cache at all. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-06-27ipv4: tcp: dont cache unconfirmed intput dstEric Dumazet
DDOS synflood attacks hit badly IP route cache. On typical machines, this cache is allowed to hold up to 8 Millions dst entries, 256 bytes for each, for a total of 2GB of memory. rt_garbage_collect() triggers and tries to cleanup things. Eventually route cache is disabled but machine is under fire and might OOM and crash. This patch exploits the new TCP early demux, to set a nocache boolean in case incoming TCP frame is for a not yet ESTABLISHED or TIMEWAIT socket. This 'nocache' boolean is then used in case dst entry is not found in route cache, to create an unhashed dst entry (DST_NOCACHE) SYN-cookie-ACK sent use a similar mechanism (ipv4: tcp: dont cache output dst for syncookies), so after this patch, a machine is able to absorb a DDOS synflood attack without polluting its IP route cache. Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Hans Schillstrom <hans.schillstrom@ericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-06-09inet: Pass inetpeer root into inet_getpeer*() interfaces.David S. Miller
Otherwise we reference potentially non-existing members when ipv6 is disabled. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-06-08inetpeer: add parameter net for inet_getpeer_v4,v6Gao feng
add struct net as a parameter of inet_getpeer_v[4,6], use net to replace &init_net. and modify some places to provide net for inet_getpeer_v[4,6] Signed-off-by: Gao feng <gaofeng@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-05-19ipv4: use skb coalescing in defragmentationEric Dumazet
ip_frag_reasm() can use skb_try_coalesce() to build optimized skb, reducing memory used by them (truesize), and reducing number of cache line misses and overhead for the consumer. Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Alexander Duyck <alexander.h.duyck@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-05-18ip_frag: struct inet_frags match() method returns a boolEric Dumazet
- match() method returns a boolean - return (A && B && C && D) -> return A && B && C && D - fix indentation Signed-off-by: Eric Dumazet <edumazet@google.com>
2012-05-15net: Convert net_ratelimit uses to net_<level>_ratelimitedJoe Perches
Standardize the net core ratelimited logging functions. Coalesce formats, align arguments. Change a printk then vprintk sequence to use printf extension %pV. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-20net: Convert all sysctl registrations to register_net_sysctlEric W. Biederman
This results in code with less boiler plate that is a bit easier to read. Additionally stops us from using compatibility code in the sysctl core, hastening the day when the compatibility code can be removed. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Pavel Emelyanov <xemul@parallels.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-20net: Kill register_sysctl_rotableEric W. Biederman
register_sysctl_rotable never caught on as an interesting way to register sysctls. My take on the situation is that what we want are sysctls that we can only see in the initial network namespace. What we have implemented with register_sysctl_rotable are sysctls that we can see in all of the network namespaces and can only change in the initial network namespace. That is a very silly way to go. Just register the network sysctls in the initial network namespace and we don't have any weird special cases to deal with. The sysctls affected are: /proc/sys/net/ipv4/ipfrag_secret_interval /proc/sys/net/ipv4/ipfrag_max_dist /proc/sys/net/ipv6/ip6frag_secret_interval /proc/sys/net/ipv6/mld_max_msf I really don't expect anyone will miss them if they can't read them in a child user namespace. CC: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Pavel Emelyanov <xemul@parallels.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-19ipv4: dont drop packet in defrag but consume itEric Dumazet
When defragmentation is finalized, we clone a packet and kfree_skb() it. Call consume_skb() to not confuse dropwatch, since its not a drop. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-03-12net: ipv4: Standardize prefixes for message loggingJoe Perches
Add #define pr_fmt(fmt) as appropriate. Add "IPv4: ", "TCP: ", and "IPsec: " to appropriate files. Standardize on "UDPLite: " for appropriate uses. Some prefixes were previously "UDPLITE: " and "UDP-Lite: ". Add KBUILD_MODNAME ": " to icmp and gre. Remove embedded prefixes as appropriate. Add missing "\n" to pr_info in gre.c. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-03-11net: Convert printks to pr_<level>Joe Perches
Use a more current kernel messaging style. Convert a printk block to print_hex_dump. Coalesce formats, align arguments. Use %s, __func__ instead of embedding function names. Some messages that were prefixed with <foo>_close are now prefixed with <foo>_fini. Some ah4 and esp messages are now not prefixed with "ip ". The intent of this patch is to later add something like #define pr_fmt(fmt) "IPv4: " fmt. to standardize the output messages. Text size is trivially reduced. (x86-32 allyesconfig) $ size net/ipv4/built-in.o* text data bss dec hex filename 887888 31558 249696 1169142 11d6f6 net/ipv4/built-in.o.new 887934 31558 249800 1169292 11d78c net/ipv4/built-in.o.old Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-02treewide: Fix typos in various parts of the kernel, and fix some comments.Justin P. Mattock
The below patch fixes some typos in various parts of the kernel, as well as fixes some comments. Please let me know if I missed anything, and I will try to get it changed and resent. Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-10-19net: add skb frag size accessorsEric Dumazet
To ease skb->truesize sanitization, its better to be able to localize all references to skb frags size. Define accessors : skb_frag_size() to fetch frag size, and skb_frag_size_{set|add|sub}() to manipulate it. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-10-18macvlan: handle fragmented multicast framesEric Dumazet
Fragmented multicast frames are delivered to a single macvlan port, because ip defrag logic considers other samples are redundant. Implement a defrag step before trying to send the multicast frame. Reported-by: Ben Greear <greearb@candelatech.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-05ipv4: Add ip_defrag() agent IP_DEFRAG_AF_PACKET.David S. Miller
Elide the ICMP on frag queue timeouts unconditionally for this user. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-17ipv4: Don't use enums as bitmasks in ip_fragment.cDavid S. Miller
Noticed by Joe Perches. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-16ipv4: more compliant RFC 3168 supportEric Dumazet
Commit 6623e3b24a5e (ipv4: IP defragmentation must be ECN aware) was an attempt to not lose "Congestion Experienced" (CE) indications when performing datagram defragmentation. Stefanos Harhalakis raised the point that RFC 3168 requirements were not completely met by this commit. In particular, we MUST detect invalid combinations and eventually drop illegal frames. Reported-by: Stefanos Harhalakis <v13@v13.gr> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-04net: ip_expire() must revalidate routeEric Dumazet
Commit 4a94445c9a5c (net: Use ip_route_input_noref() in input path) added a bug in IP defragmentation handling, in case timeout is fired. When a frame is defragmented, we use last skb dst field when building final skb. Its dst is valid, since we are in rcu read section. But if a timeout occurs, we take first queued fragment to build one ICMP TIME EXCEEDED message. Problem is all queued skb have weak dst pointers, since we escaped RCU critical section after their queueing. icmp_send() might dereference a now freed (and possibly reused) part of memory. Calling skb_dst_drop() and ip_route_input_noref() to revalidate route is the only possible choice. Reported-by: Denys Fedoryshchenko <denys@visp.net.lb> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-06ipv4: IP defragmentation must be ECN awareEric Dumazet
RFC3168 (The Addition of Explicit Congestion Notification to IP) states : 5.3. Fragmentation ECN-capable packets MAY have the DF (Don't Fragment) bit set. Reassembly of a fragmented packet MUST NOT lose indications of congestion. In other words, if any fragment of an IP packet to be reassembled has the CE codepoint set, then one of two actions MUST be taken: * Set the CE codepoint on the reassembled packet. However, this MUST NOT occur if any of the other fragments contributing to this reassembly carries the Not-ECT codepoint. * The packet is dropped, instead of being reassembled, for any other reason. This patch implements this requirement for IPv4, choosing the first action : If one fragment had NO-ECT codepoint reassembled frame has NO-ECT ElIf one fragment had CE codepoint reassembled frame has CE Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-30inetpeer: Make inet_getpeer() take an inet_peer_adress_t pointer.David S. Miller
And make an inet_getpeer_v4() helper, update callers. Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-23net: return operator cleanupEric Dumazet
Change "return (EXPR);" to "return EXPR;" return is not a function, parentheses are not required. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-23net: Rename skb_has_frags to skb_has_frag_listDavid S. Miller
SKBs can be "fragmented" in two ways, via a page array (called skb_shinfo(skb)->frags[]) and via a list of SKBs (called skb_shinfo(skb)->frag_list). Since skb_has_frags() tests the latter, it's name is confusing since it sounds more like it's testing the former. Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-12net/ipv4: EXPORT_SYMBOL cleanupsEric Dumazet
CodingStyle cleanups EXPORT_SYMBOL should immediately follow the symbol declaration. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-30fragment: add fast path for in-order fragmentsChangli Gao
add fast path for in-order fragments As the fragments are sent in order in most of OSes, such as Windows, Darwin and FreeBSD, it is likely the new fragments are at the end of the inet_frag_queue. In the fast path, we check if the skb at the end of the inet_frag_queue is the prev we expect. Signed-off-by: Changli Gao <xiaosuo@gmail.com> ---- include/net/inet_frag.h | 1 + net/ipv4/ip_fragment.c | 12 ++++++++++++ net/ipv6/reassembly.c | 11 +++++++++++ 3 files changed, 24 insertions(+) Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-15ipfrag : frag_kfree_skb() cleanupEric Dumazet
Third param (work) is unused, remove it. Remove __inline__ and inline qualifiers. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-15ip_frag: Remove some atomic opsEric Dumazet
Instead of doing one atomic operation per frag, we can factorize them. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-02ipv4: ip_fragment: fix unbalanced rcu_read_unlock()Patrick McHardy
Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-23IP: Send an ICMP "Fragment Reassembly Timeout" message when enabling ↵Shan Wei
connection track No matter whether connection track is enabled, an end host should send an ICMPv4 "Fragment Reassembly Timeout" message when defrag timeout. The reasons are following two points: 1. RFC 792 says: >>>> >> > > If a host reassembling a fragmented datagram cannot complete the >>>> >> > > reassembly due to missing fragments within its time limit it >>>> >> > > discards the datagram, and it may send a time exceeded message. >>>> >> > > >>>> >> > > If fragment zero is not available then no time exceeded need be >>>> >> > > sent at all. >>>> >> > > >>>> >> > > Read more: http://www.faqs.org/rfcs/rfc792.html#ixzz0aOXRD7Wp 2. Patrick McHardy also agrees with this opinion. :-) About the discussion of this opinion, refer to http://patchwork.ozlabs.org/patch/41649 The patch fixed the problem like this: When enabling connection track, fragments are received at PRE_ROUTING HOOK. If they are failed to reassemble, ip_expire() will be called. Before sending an ICMP "Fragment Reassembly Timeout" message, the patch searches router table to get the destination entry only for host type. The patch has been tested on both host type and route type. Signed-off-by: Shan Wei <shanwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-17net: spread __net_init, __net_exitAlexey Dobriyan
__net_init/__net_exit are apparently not going away, so use them to full extent. In some cases __net_init was removed, because it was called from __net_exit code. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-08Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1815 commits) mac80211: fix reorder buffer release iwmc3200wifi: Enable wimax core through module parameter iwmc3200wifi: Add wifi-wimax coexistence mode as a module parameter iwmc3200wifi: Coex table command does not expect a response iwmc3200wifi: Update wiwi priority table iwlwifi: driver version track kernel version iwlwifi: indicate uCode type when fail dump error/event log iwl3945: remove duplicated event logging code b43: fix two warnings ipw2100: fix rebooting hang with driver loaded cfg80211: indent regulatory messages with spaces iwmc3200wifi: fix NULL pointer dereference in pmkid update mac80211: Fix TX status reporting for injected data frames ath9k: enable 2GHz band only if the device supports it airo: Fix integer overflow warning rt2x00: Fix padding bug on L2PAD devices. WE: Fix set events not propagated b43legacy: avoid PPC fault during resume b43: avoid PPC fault during resume tcp: fix a timewait refcnt race ... Fix up conflicts due to sysctl cleanups (dead sysctl_check code and CTL_UNNUMBERED removed) in kernel/sysctl_check.c net/ipv4/sysctl_net_ipv4.c net/ipv6/addrconf.c net/sctp/sysctl.c
2009-12-08Merge git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/sysctl-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/sysctl-2.6: (43 commits) security/tomoyo: Remove now unnecessary handling of security_sysctl. security/tomoyo: Add a special case to handle accesses through the internal proc mount. sysctl: Drop & in front of every proc_handler. sysctl: Remove CTL_NONE and CTL_UNNUMBERED sysctl: kill dead ctl_handler definitions. sysctl: Remove the last of the generic binary sysctl support sysctl net: Remove unused binary sysctl code sysctl security/tomoyo: Don't look at ctl_name sysctl arm: Remove binary sysctl support sysctl x86: Remove dead binary sysctl support sysctl sh: Remove dead binary sysctl support sysctl powerpc: Remove dead binary sysctl support sysctl ia64: Remove dead binary sysctl support sysctl s390: Remove dead sysctl binary support sysctl frv: Remove dead binary sysctl support sysctl mips/lasat: Remove dead binary sysctl support sysctl drivers: Remove dead binary sysctl support sysctl crypto: Remove dead binary sysctl support sysctl security/keys: Remove dead binary sysctl support sysctl kernel: Remove binary sysctl logic ...
