git://git.kernel.org/pub/scm/linux/kernel/git/pablo/nf-next
Pablo Neira Ayuso says:
This is another batch containing Netfilter/IPVS updates for your net-next
tree, they are:
* Six patches to make the ipt_CLUSTERIP target support netnamespace,
from Gao feng.
* Two cleanups for the nf_conntrack_acct infrastructure, introducing
a new structure to encapsulate conntrack counters, from Holger
Eitzenberger.
* Fix missing verdict in SCTP support for IPVS, from Daniel Borkmann.
* Skip checksum recalculation in SCTP support for IPVS, also from
Daniel Borkmann.
* Fix behavioural change in xt_socket after IP early demux, from
Florian Westphal.
* Fix bogus large memory allocation in the bitmap port set type in ipset,
from Jozsef Kadlecsik.
* Fix possible compilation issues in the hash netnet set type in ipset,
also from Jozsef Kadlecsik.
* Define constants to identify netlink callback data in ipset dumps,
again from Jozsef Kadlecsik.
* Use sock_gen_put() in xt_socket to replace xt_socket_put_sk,
from Eric Dumazet.
* Improvements for the SH scheduler in IPVS, from Alexander Frolkin.
* Remove extra delay due to unneeded rcu barrier in IPVS net namespace
cleanup path, from Julian Anastasov.
* Save some cycles in ip6t_REJECT by skipping checksum validation in
packets leaving from our stack, from Stanislav Fomichev.
* Fix IPVS_CMD_ATTR_MAX definition in IPVS, larger that required, from
Julian Anastasov.
we can allow users in uninit net namespace to operate ipt_CLUSTERIP
now.
Signed-off-by: Gao feng <gaofeng@cn.fujitsu.com>
Create proc entries under the ipt_CLUSTERIP directory of proper
net namespace.
Inorder to find clusterip_config in net namespace.
this lock is used for protecting clusterip_configs of per
net namespace, it should be per net namespace too.
clusterip_configs should be per net namespace, so operate
cluster in one net namespace won't affect other net
namespace. right now, only allow to operate the clusterip_configs
of init net namespace.
Create /proc/net/ipt_CLUSTERIP directory for per net namespace.
Right now,only allow to create entries under the ipt_CLUSTERIP
in init net namespace.
Pass the hook ops to the hookfn to allow for generic hook
functions. This change is required by nf_tables.
Supply a function (proc_remove()) to remove a proc entry (and any subtree
rooted there) by proc_dir_entry pointer rather than by name and (optionally)
root dir entry pointer. This allows us to eliminate all remaining pde->name
accesses outside of procfs.
Acked-by: Grant Likely <grant.likely@linaro.or>
cc: linux-acpi@vger.kernel.org
cc: openipmi-developer@lists.sourceforge.net
cc: devicetree-discuss@lists.ozlabs.org
cc: linux-pci@vger.kernel.org
cc: netdev@vger.kernel.org
cc: netfilter-devel@vger.kernel.org
cc: alsa-devel@alsa-project.org
The only part of proc_dir_entry the code outside of fs/proc
really cares about is PDE(inode)->data. Provide a helper
for that; static inline for now, eventually will be moved
to fs/proc, along with the knowledge of struct proc_dir_entry
layout.
This patch replace the obsolete simple_strto<foo> with kstrto<foo>
Signed-off-by: Abhijit Pawar <abhi.c.pawar@gmail.com>
Standardize the net core ratelimited logging functions.
Coalesce formats, align arguments.
Change a printk then vprintk sequence to use printf extension %pV.
Site specific OOM messages are duplications of a generic MM
out of memory message and aren't really useful, so just
delete them.
Make the case labels the same indent as the switch.
git diff -w shows miscellaneous 80 column wrapping,
comment reflowing and a comment for a useless gcc
warning for an otherwise unused default: case.
Following error is raised (and other similar ones) :
net/ipv4/netfilter/nf_nat_standalone.c: In function ‘nf_nat_fn’:
net/ipv4/netfilter/nf_nat_standalone.c:119:2: warning: case value ‘4’
not in enumerated type ‘enum ip_conntrack_info’
gcc barfs on adding two enum values and getting a not enumerated
result :
case IP_CT_RELATED+IP_CT_IS_REPLY:
Add missing enum values
CC: David Miller <davem@davemloft.net>
'buffer' string is copied from userspace. It is not checked whether it is
zero terminated. This may lead to overflow inside of simple_strtoul().
Changli Gao suggested to copy not more than user supplied 'size' bytes.
It was introduced before the git epoch. Files "ipt_CLUSTERIP/*" are
root writable only by default, however, on some setups permissions might be
relaxed to e.g. network admin user.
Signed-off-by: Vasiliy Kulikov <segoon@openwall.com>
Acked-by: Changli Gao <xiaosuo@gmail.com>
When a packet is meant to be handled by another node of the cluster,
silently drop it instead of flooding kernel log.
Note : INVALID packets are also dropped without notice.
Acked-by: Pablo Neira Ayuso <pablo@netfilter.org>
Signed-off-by: Changli Gao <xiaosuo@gmail.com>
Network code uses the __packed macro instead of __attribute__((packed)).
Signed-off-by: Gustavo F. Padovan <padovan@profusion.mobi>
- clusterip_lock becomes a spinlock
- lockless lookups
- kfree() deferred after RCU grace period
- rcu_barrier_bh() inserted in clusterip_tg_exit()
v2)
- As Patrick pointed out, we use atomic_inc_not_zero() in
clusterip_config_find_get().
- list_add_rcu() and list_del_rcu() variants are used.
- atomic_dec_and_lock() used in clusterip_config_entry_put()
Signed-off-by: Jan Engelhardt <jengelh@medozas.de>
Documentation/feature-removal-schedule.txt
net/ipv6/netfilter/ip6t_REJECT.c
net/netfilter/xt_limit.c
drivers/net/stmmac/stmmac_main.c
drivers/net/wireless/wl12xx/wl1271_cmd.c
drivers/net/wireless/wl12xx/wl1271_main.c
drivers/net/wireless/wl12xx/wl1271_spi.c
net/core/ethtool.c
net/mac80211/scan.c
Converts the list and the core manipulating with it to be the same as uc_list.
+uses two functions for adding/removing mc address (normal and "global"
variant) instead of a function parameter.
+removes dev_mcast.c completely.
+exposes netdev_hw_addr_list_* macros along with __hw_addr_* functions for
manipulation with lists on a sandbox (used in bonding and 80211 drivers)
Signed-off-by: Jiri Pirko <jpirko@redhat.com>
If clusterip_seq_start() memory allocation fails, we crash later in
clusterip_seq_start(), trying to kfree(ERR_PTR(-ENOMEM))
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
The return value of nf_ct_l3proto_get can directly be returned even in
the case of success.
When extended status codes are available, such as ENOMEM on failed
allocations, or subsequent functions (e.g. nf_ct_get_l3proto), passing
them up to userspace seems like a good idea compared to just always
EINVAL.
Part of the transition of done by this semantic patch:
// <smpl>
@ rule1 @
struct xt_target ops;
identifier check;
ops.checkentry = check;
identifier rule1.check;
check(...) { <...
-return true;
+return 0;
check(...) { <...
-return false;
+return -EINVAL;
// </smpl>
Restore function signatures from bool to int so that we can report
memory allocation failures or similar using -ENOMEM rather than
always having to pass -EINVAL back.
// <smpl>
type bool;
identifier check, par;
-bool check
+int check
(struct xt_tgchk_param *par) { ... }
// </smpl>
Minus the change it does to xt_ct_find_proto.
Supplement to 1159683ef48469de71dc26f0ee1a9c30d131cf89.
Downgrade the log level to INFO for most checkentry messages as they
are, IMO, just an extra information to the -EINVAL code that is
returned as part of a parameter "constraint violation". Leave errors
to real errors, such as being unable to create a LED trigger.
Supplement to aa5fa3185791aac71c9172d4fda3e8729164b5d1.
The semantic patch for this change is:
// <smpl>
struct xt_target_param *par;
-par->target->family
+par->family
struct xt_tgchk_param *par;
+par->family
struct xt_tgdtor_param *par;
+par->family
// </smpl>
Pass "struct clusterip_config" itself to seq_file iterators
and save one dereference. Proc entry itself isn't interesting.
Compile tested only.
Using NIPQUAD() with NIPQUAD_FMT, %d.%d.%d.%d or %u.%u.%u.%u
can be replaced with %pI4
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
This patch does this for target extensions' destroy functions.
This patch does this for target extensions' checkentry functions.
This patch does this for target extensions' target functions.
Simply replace proc_create and further data assigned with proc_create_data.
Signed-off-by: Denis V. Lunev <den@openvz.org>
Acked-by: Patrick McHardy <kaber@trash.net>
git://git.kernel.org/pub/scm/linux/kernel/git/kaber/nf-2.6.26
drivers/net/ehea/ehea_main.c
drivers/net/wireless/iwlwifi/Kconfig
drivers/net/wireless/rt2x00/rt61pci.c
net/ipv4/inet_timewait_sock.c
net/ipv6/raw.c
net/mac80211/ieee80211_sta.c
function call
Directly call IPv4 and IPv6 variants where the address family is
easily known.
Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de>
_entry_put
Consider we are putting a clusterip_config entry with the "entries"
count == 1, and on the other CPU there's a clusterip_config_find_get
in progress:
CPU1: CPU2:
clusterip_config_entry_put: clusterip_config_find_get:
if (atomic_dec_and_test(&c->entries)) {
/* true */
read_lock_bh(&clusterip_lock);
c = __clusterip_config_find(clusterip);
/* found - it's still in list */
atomic_inc(&c->entries);
read_unlock_bh(&clusterip_lock);
write_lock_bh(&clusterip_lock);
list_del(&c->list);
write_unlock_bh(&clusterip_lock);
dev_put(c->dev);
Oops! We have an entry returned by the clusterip_config_find_get,
which is a) not in list b) has a stale dev pointer.
The problems will happen when the CPU2 will release the entry - it
will remove it from the list for the 2nd time, thus spoiling it, and
will put a stale dev pointer.
The fix is to make atomic_dec_and_test under the clusterip_lock.
Signed-off-by: Pavel Emelyanov <xemul@openvz.org>
git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6
drivers/net/usb/rndis_host.c
drivers/net/wireless/b43/dma.c
net/ipv6/ndisc.c
This elliminates infamous race during module loading when one could lookup
proc entry without proc_fops assigned.
With nf_conntrack DUMP_TUPLE got renamed to NF_CT_DUMP_TUPLE, fix
CLUSTERIP to use the proper macro name.
