Make sure all printk messages have a severity level.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
The static initial tables are pretty large, and after the net
namespace has been instantiated, they just hang around for nothing.
This commit removes them and creates tables on-demand at runtime when
needed.
Size shrinks by 7735 bytes (x86_64).
Signed-off-by: Jan Engelhardt <jengelh@medozas.de>
The respective xt_table structures already have most of the metadata
needed for hook setup. Add a 'priority' field to struct xt_table so
that xt_hook_link() can be called with a reduced number of arguments.
So should we be having more tables in the future, it comes at no
static cost (only runtime, as before) - space saved:
6807373->6806555.
The calls to ip6t_do_table only show minimal differences, so it seems
like a good cleanup to merge them to a single one too.
Space saving obtained by both patches: 6807725->6807373
("Total" column from `size -A`.)
This patch combines all the per-hook functions in a given table into
a single function. Together with the 2nd patch, further
simplifications are possible up to the point of output code reduction.
Add ->net to match destructor list like ->net in constructor list.
Make sure it's set in ebtables/iptables/ip6tables, this requires to
propagate netns up to *_unregister_table().
The inputted table is never modified, so should be considered const.
Later patches change the locking on xt_table and the initialization of
the lock element is not needed since the lock is always initialized in
xt_table_register anyway.
Don't spam logs for locally generated short packets. these can only
be generated by root.
Now that dev_net() exists, the usefullness of them is even less. Also they're
a big problem in resolving circular header dependencies necessary for
NOTRACK-in-netns patch. See below.
Commit 9335f047fe61587ec82ff12fbb1220bcfdd32006 aka
"[NETFILTER]: ip_tables: per-netns FILTER, MANGLE, RAW"
added per-netns _view_ of iptables rules. They were shown to user, but
ignored by filtering code. Now that it's possible to at least ping loopback,
per-netns tables can affect filtering decisions.
netns is taken in case of
PRE_ROUTING, LOCAL_IN -- from in device,
POST_ROUTING, LOCAL_OUT -- from out device,
FORWARD -- from in device which should be equal to out device's netns.
This code is relatively new, so BUG_ON was plugged.
Wrappers were added to a) keep code the same from CONFIG_NET_NS=n users
(overwhelming majority), b) consolidate code in one place -- similar
changes will be done in ipv6 and arp netfilter code.
Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru>
Now, iptables show and configure different set of rules in different
netnss'. Filtering decisions are still made by consulting only
init_net's set.
Changes are identical except naming so no splitting.
P.S.: one need to remove init_net checks in nf_sockopt.c and inet_create()
to see the effect.
Typical table module registers xt_table structure (i.e. packet_filter)
and link it to list during it. We can't use one template for it because
corresponding list_head will become corrupted. We also can't unregister
with template because it wasn't changed at all and thus doesn't know in
which list it is.
So, we duplicate template at the very first step of table registration.
Table modules will save it for use during unregistration time and actual
filtering.
Do it at once to not screw bisection.
P.S.: renaming i.e. packet_filter => __packet_filter is temporary until
full netnsization of table modules is done.
The IPv4 and IPv6 hook values are identical, yet some code tries to figure
out the "correct" value by looking at the address family. Introduce NF_INET_*
values for both IPv4 and IPv6. The old values are kept in a #ifndef __KERNEL__
section for userspace compatibility.
Acked-by: Herbert Xu <herbert@gondor.apana.org.au>
With all the users of the double pointers removed, this patch mops up by
finally replacing all occurances of sk_buff ** in the netfilter API by
sk_buff *.
- move arp_tables initial table structure definitions to arp_tables.h
similar to ip_tables and ip6_tables
- use C99 initializers
- use initializer macros where possible
For the common sequence "skb->nh.iph->ihl * 4", removing a good number of open
coded skb->nh.iph uses, now to go after the rest...
Just out of curiosity, here are the idioms found to get the same result:
skb->nh.iph->ihl << 2
skb->nh.iph->ihl<<2
skb->nh.iph->ihl*4
(skb->nh.iph)->ihl * sizeof(u32)
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
structure names
Signed-off-by: Jan Engelhardt <jengelh@gmx.de>
Clean up hook registration by makeing use of the new mass registration and
unregistration helpers.
Every netfilter module uses `init' for its module_init() function and
`fini' or `cleanup' for its module_exit() function.
Problem is, this creates uninformative initcall_debug output and makes
ctags rather useless.
So go through and rename them all to $(filename)_init and
$(filename)_fini.
This monster-patch tries to do the best job for unifying the data
structures and backend interfaces for the three evil clones ip_tables,
ip6_tables and arp_tables. In an ideal world we would never have
allowed this kind of copy+paste programming... but well, our world
isn't (yet?) ideal.
o introduce a new x_tables module
o {ip,arp,ip6}_tables depend on this x_tables module
o registration functions for tables, matches and targets are only
wrappers around x_tables provided functions
o all matches/targets that are used from ip_tables and ip6_tables
are now implemented as xt_FOOBAR.c files and provide module aliases
to ipt_FOOBAR and ip6t_FOOBAR
o header files for xt_matches are in include/linux/netfilter/,
include/linux/netfilter_{ipv4,ipv6} contains compatibility wrappers
around the xt_FOOBAR.h headers
Based on this patchset we're going to further unify the code,
gradually getting rid of all the layer 3 specific assumptions.
Signed-off-by: Harald Welte <laforge@netfilter.org>
infrastructure for it.
Let it rip!
