Convert the IPv4 NAT implementation to a protocol independent core and
address family specific modules.
CONFIG_NF_CT_NETLINK=y
LD init/built-in.o
net/built-in.o:(.data+0x4408): undefined reference to `nf_nat_tcp_seq_adjust'
make: *** [vmlinux] Error 1
This patch adds a new pointer hook (nfq_ct_nat_hook) similar to other existing
in Netfilter to solve our complicated configuration dependencies.
Reported-by: Valdis Kletnieks <valdis.kletnieks@vt.edu>
This patch allows you to set expectfn which is specifically used
by the NAT side of most of the existing conntrack helpers.
I have added a symbol map that uses a string as key to look up for
the function that is attached to the expectation object. This is
the best solution I came out with to solve this issue.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (53 commits)
Kconfig: acpi: Fix typo in comment.
misc latin1 to utf8 conversions
devres: Fix a typo in devm_kfree comment
btrfs: free-space-cache.c: remove extra semicolon.
fat: Spelling s/obsolate/obsolete/g
SCSI, pmcraid: Fix spelling error in a pmcraid_err() call
tools/power turbostat: update fields in manpage
mac80211: drop spelling fix
types.h: fix comment spelling for 'architectures'
typo fixes: aera -> area, exntension -> extension
devices.txt: Fix typo of 'VMware'.
sis900: Fix enum typo 'sis900_rx_bufer_status'
decompress_bunzip2: remove invalid vi modeline
treewide: Fix comment and string typo 'bufer'
hyper-v: Update MAINTAINERS
treewide: Fix typos in various parts of the kernel, and fix some comments.
clockevents: drop unknown Kconfig symbol GENERIC_CLOCKEVENTS_MIGR
gpio: Kconfig: drop unknown symbol 'CS5535_GPIO'
leds: Kconfig: Fix typo 'D2NET_V2'
sound: Kconfig: drop unknown symbol ARCH_CLPS7500
Fix up trivial conflicts in arch/powerpc/platforms/40x/Kconfig (some new
kconfig additions, close to removed commented-out old ones)
The inner tuple that is extracted from the packet is unused. The code also
doesn't have any useful side-effects like verifying the packet does contain
enough data to extract the inner tuple since conntrack already does the
same, so remove it.
The only remaining user of NAT protocol module reference counting is NAT
ctnetlink support. Since this is a fairly short sequence of code, convert
over to use RCU and remove module reference counting.
Module unregistration is already protected by RCU using synchronize_rcu(),
so no further changes are necessary.
Use nf_conntrack_hash_rnd in NAT bysource hash to avoid hash chain attacks.
Export the NAT definitions to userspace. So far userspace (specifically,
iptables) has been copying the headers files from include/net. Also
rename some structures and definitions in preparation for IPv6 NAT.
Since these have never been officially exported, this doesn't affect
existing userspace code.
One printk and one comment typo fix.
Signed-off-by: Wang YanQing <udknight@gmail.com>
When assigning a NULL value to an RCU protected pointer, no barrier
is needed. The rcu_assign_pointer, used to handle that but will soon
change to not handle the special case.
Convert all rcu_assign_pointer of NULL value.
//smpl
@@ expression P; @@
- rcu_assign_pointer(P, NULL)
+ RCU_INIT_POINTER(P, NULL)
// </smpl>
Following error is raised (and other similar ones) :
net/ipv4/netfilter/nf_nat_standalone.c: In function ‘nf_nat_fn’:
net/ipv4/netfilter/nf_nat_standalone.c:119:2: warning: case value ‘4’
not in enumerated type ‘enum ip_conntrack_info’
gcc barfs on adding two enum values and getting a not enumerated
result :
case IP_CT_RELATED+IP_CT_IS_REPLY:
Add missing enum values
CC: David Miller <davem@davemloft.net>
If SNAT isn't done, the wrong info maybe got by the other cts.
As the filter table is after DNAT table, the packets dropped in filter
table also bother bysource hash table.
Signed-off-by: Changli Gao <xiaosuo@gmail.com>
My previous patch (netfilter: nf_nat: don't use atomic bit operation)
made a mistake when converting atomic_set to a normal bit 'or'.
IPS_*_BIT should be replaced with IPS_*.
Cc: Tim Gardner <tim.gardner@canonical.com>
Use is_vmalloc_addr() in nf_ct_free_hashtable() and get rid of
the vmalloc flags to indicate that a hash table has been allocated
using vmalloc().
Use helpers to reduce number of sparse warnings
(CONFIG_SPARSE_RCU_POINTER=y)
As we own the conntrack and the others can't see it until we confirm it,
we don't need to use atomic bit operation on ct->status.
net/ipv4/netfilter/nf_nat_core.c:52: warning: 'nf_nat_proto_find_get' defined but not used
net/ipv4/netfilter/nf_nat_core.c:66: warning: 'nf_nat_proto_put' defined but not used
Reported-by: Geert Uytterhoeven <geert@linux-m68k.org>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1699 commits)
bnx2/bnx2x: Unsupported Ethtool operations should return -EINVAL.
vlan: Calling vlan_hwaccel_do_receive() is always valid.
tproxy: use the interface primary IP address as a default value for --on-ip
tproxy: added IPv6 support to the socket match
cxgb3: function namespace cleanup
tproxy: added IPv6 support to the TPROXY target
tproxy: added IPv6 socket lookup function to nf_tproxy_core
be2net: Changes to use only priority codes allowed by f/w
tproxy: allow non-local binds of IPv6 sockets if IP_TRANSPARENT is enabled
tproxy: added tproxy sockopt interface in the IPV6 layer
tproxy: added udp6_lib_lookup function
tproxy: added const specifiers to udp lookup functions
tproxy: split off ipv6 defragmentation to a separate module
l2tp: small cleanup
nf_nat: restrict ICMP translation for embedded header
can: mcp251x: fix generation of error frames
can: mcp251x: fix endless loop in interrupt handler if CANINTF_MERRF is set
can-raw: add msg_flags to distinguish local traffic
9p: client code cleanup
rds: make local functions/variables static
Fix up conflicts in net/core/dev.c, drivers/net/pcmcia/smc91c92_cs.c and
drivers/net/wireless/ath/ath9k/debug.c as per David
Skip ICMP translation of embedded protocol header
if NAT bits are not set. Needed for IPVS to see the original
embedded addresses because for IPVS traffic the IPS_SRC_NAT_BIT
and IPS_DST_NAT_BIT bits are not set. It happens when IPVS performs
DNAT for client packets after using nf_conntrack_alter_reply
to expect replies from real server.
Signed-off-by: Julian Anastasov <ja@ssi.bg>
Signed-off-by: Simon Horman <horms@verge.net.au>
The functions nf_nat_proto_find_get and nf_nat_proto_put are
only used internally in nf_nat_core. This might break some out
of tree NAT module.
other choice
Eliminate nf_nat_used_tuple() to save some CPU cycles when there is no
other choice.
Acked-by: Patrick McHardy <kaber@trash.net>
Reviewed-by: Josh Triplett <josh@joshtriplett.org>
Use local variable hdrlen instead of ip_hdrlen(skb).
proto->unique_tuple() will be called finally, if the previous calls fail. This
patch checks the false condition of (range->flags &IP_NAT_RANGE_PROTO_RANDOM)
instead to avoid duplicate line of code: proto->unique_tuple().
NOTRACK makes all cpus share a cache line on nf_conntrack_untracked
twice per packet. This is bad for performance.
__read_mostly annotation is also a bad choice.
This patch introduces IPS_UNTRACKED bit so that we can use later a
per_cpu untrack structure more easily.
A new helper, nf_ct_untracked_get() returns a pointer to
nf_conntrack_untracked.
Another one, nf_ct_untracked_status_or() is used by nf_nat_init() to add
IPS_NAT_DONE_MASK bits to untracked status.
nf_ct_is_untracked() prototype is changed to work on a nf_conn pointer.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Normally, each connection needs a unique identity. Conntrack zones allow
to specify a numerical zone using the CT target, connections in different
zones can use the same identity.
Example:
iptables -t raw -A PREROUTING -i veth0 -j CT --zone 1
iptables -t raw -A OUTPUT -o veth1 -j CT --zone 1
As noticed by Jon Masters <jonathan@jonmasters.org>, the conntrack hash
size is global and not per namespace, but modifiable at runtime through
/sys/module/nf_conntrack/hashsize. Changing the hash size will only
resize the hash in the current namespace however, so other namespaces
will use an invalid hash size. This can cause crashes when enlarging
the hashsize, or false negative lookups when shrinking it.
Move the hash size into the per-namespace data and only use the global
hash size to initialize the per-namespace value when instanciating a
new namespace. Additionally restrict hash resizing to init_net for
now as other namespaces are not handled currently.
Cc: stable@kernel.org
Vitezslav Samel discovered that since 2.6.30.4+ active FTP can not work
over NAT. The "cause" of the problem was a fix of unacknowledged data
detection with NAT (commit a3a9f79e361e864f0e9d75ebe2a0cb43d17c4272).
However, actually, that fix uncovered a long standing bug in TCP conntrack:
when NAT was enabled, we simply updated the max of the right edge of
the segments we have seen (td_end), by the offset NAT produced with
changing IP/port in the data. However, we did not update the other parameter
(td_maxend) which is affected by the NAT offset. Thus that could drift
away from the correct value and thus resulted breaking active FTP.
The patch below fixes the issue by *not* updating the conntrack parameters
from NAT, but instead taking into account the NAT offsets in conntrack in a
consistent way. (Updating from NAT would be more harder and expensive because
it'd need to re-calculate parameters we already calculated in conntrack.)
Signed-off-by: Jozsef Kadlecsik <kadlec@blackhole.kfki.hu>
Kernel 2.6.30 introduced a patch [1] for the persistent option in the
netfilter SNAT target. This is exactly what we need here so I had a quick look
at the code and noticed that the patch is wrong. The logic is simply inverted.
The patch below fixes this.
Also note that because of this the default behavior of the SNAT target has
changed since kernel 2.6.30 as it now ignores the destination IP in choosing
the source IP for nating (which should only be the case if the persistent
option is set).
[1] http://git.eu.kernel.org/?p=linux/kernel/git/torvalds/linux-2.6.git;a=commitdiff;h=98d500d66cb7940747b424b245fc6a51ecfbf005
Signed-off-by: Maximilian Engelhardt <maxi@daemonizer.de>
The removal of the SAME target accidentally removed one feature that is
not available from the normal NAT targets so far, having multi-range
mappings that use the same mapping for each connection from a single
client. The current behaviour is to choose the address from the range
based on source and destination IP, which breaks when communicating
with sites having multiple addresses that require all connections to
originate from the same IP address.
Introduce a IP_NAT_RANGE_PERSISTENT option that controls whether the
destination address is taken into account for selecting addresses.
http://bugzilla.kernel.org/show_bug.cgi?id=12954
Use "hlist_nulls" infrastructure we added in 2.6.29 for RCUification of UDP & TCP.
This permits an easy conversion from call_rcu() based hash lists to a
SLAB_DESTROY_BY_RCU one.
Avoiding call_rcu() delay at nf_conn freeing time has numerous gains.
First, it doesnt fill RCU queues (up to 10000 elements per cpu).
This reduces OOM possibility, if queued elements are not taken into account
This reduces latency problems when RCU queue size hits hilimit and triggers
emergency mode.
- It allows fast reuse of just freed elements, permitting better use of
CPU cache.
- We delete rcu_head from "struct nf_conn", shrinking size of this structure
by 8 or 16 bytes.
This patch only takes care of "struct nf_conn".
call_rcu() is still used for less critical conntrack parts, that may
be converted later if necessary.
Signed-off-by: Eric Dumazet <dada1@cosmosbay.com>
nf_nat
This patch removes the module dependency between ctnetlink and
nf_nat by means of an indirect call that is initialized when
nf_nat is loaded. Now, nf_conntrack_netlink only requires
nf_conntrack and nfnetlink.
This patch puts nfnetlink_parse_nat_setup_hook into the
nf_conntrack_core to avoid dependencies between ctnetlink,
nf_conntrack_ipv4 and nf_conntrack_ipv6.
This patch also introduces the function ctnetlink_change_nat
that is only invoked from the creation path. Actually, the
nat handling cannot be invoked from the update path since
this is not allowed. By introducing this function, we remove
the useless nat handling in the update path and we avoid
deadlock-prone code.
This patch also adds the required EAGAIN logic for nfnetlink.
* make per-netns conntrack hash
Other solution is to add ->ct_net pointer to tuplehashes and still has one
hash, I tried that it's ugly and requires more code deep down in protocol
modules et al.
* propagate netns pointer to where needed, e. g. to conntrack iterators.
Fix three ct_extend/NAT extension related races:
- When cleaning up the extension area and removing it from the bysource hash,
the nat->ct pointer must not be set to NULL since it may still be used in
a RCU read side
- When replacing a NAT extension area in the bysource hash, the nat->ct
pointer must be assigned before performing the replacement
- When reallocating extension storage in ct_extend, the old memory must
not be freed immediately since it may still be used by a RCU read side
Possibly fixes https://bugzilla.redhat.com/show_bug.cgi?id=449315
and/or http://bugzilla.kernel.org/show_bug.cgi?id=10875
git://git.kernel.org/pub/scm/linux/kernel/git/kaber/nf-2.6.26
Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de>
Connection tracking helpers (specifically FTP) need to be called
before NAT sequence numbers adjustments are performed to be able
to compare them against previously seen ones. We've introduced
two new hooks around 2.6.11 to maintain this ordering when NAT
modules were changed to get called from conntrack helpers directly.
The cost of netfilter hooks is quite high and sequence number
adjustments are only rarely needed however. Add a RCU-protected
sequence number adjustment function pointer and call it from
IPv4 conntrack after calling the helper.
Move to nf_nat_proto_common and rename to nf_nat_proto_... since they're
also used by protocols that don't have port numbers.
Without this patch, the generic L3 tracker would kick in
if nf_conntrack_ipv4 was not loaded before nf_nat, which
would lead to translation problems with ICMP errors.
NAT does not make sense without IPv4 connection tracking
anyway, so just add a call to need_ipv4_conntrack().
The ->move operation has two bugs:
- It is called with the same extension as source and destination,
so it doesn't update the new extension.
- The address of the old extension is calculated incorrectly,
instead of (void *)ct->ext + ct->ext->offset[i] it uses
ct->ext + ct->ext->offset[i].
Fixes a crash on x86_64 reported by Chuck Ebbert <cebbert@redhat.com>
and Thomas Woerner <twoerner@redhat.com>.
Tested-by: Thomas Woerner <twoerner@redhat.com>
Since we're using RCU, all users of nf_nat_lock take a write_lock.
Switch it to a spinlock.
The hash table is already initialized by nf_ct_alloc_hashtable().
