Make the case labels the same indent as the switch.
git diff -w shows miscellaneous 80 column wrapping,
comment reflowing and a comment for a useless gcc
warning for an otherwise unused default: case.
Adding support for SNMP broadcast connection tracking. The SNMP
broadcast requests are now paired with the SNMP responses.
Thus allowing using SNMP broadcasts with firewall enabled.
Please refer to the following conversation:
http://marc.info/?l=netfilter-devel&m=125992205006600&w=2
Patrick McHardy wrote:
> > The best solution would be to add generic broadcast tracking, the
> > use of expectations for this is a bit of abuse.
> > The second best choice I guess would be to move the help() function
> > to a shared module and generalize it so it can be used for both.
This patch implements the "second best choice".
Since the netbios-ns conntrack module uses the same helper
functionality as the snmp, only one helper function is added
for both snmp and netbios-ns modules into the new object -
nf_conntrack_broadcast.
Signed-off-by: Jiri Olsa <jolsa@redhat.com>
Fix checksum calculation in nf_nat_snmp_basic.
Based on patches by Clark Wang <wtweeker@163.com> and
Stephen Hemminger <shemminger@vyatta.com>.
https://bugzilla.kernel.org/show_bug.cgi?id=17622
Make sure all printk messages have a severity level.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
obj has type struct snmp_object **, not struct snmp_object *. But indeed
it is not even clear why kmalloc is needed. The memory is freed by the end
of the function, so the local variable of pointer type should be sufficient.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
@disable sizeof_type_expr@
type T;
T **x;
x =
<+...sizeof(
- T
+ *x
// </smpl>
Base versions handle constant folding now.
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
Using NIPQUAD() with NIPQUAD_FMT, %d.%d.%d.%d or %u.%u.%u.%u
can be replaced with %pI4
Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi>
Fix a range check in netfilter IP NAT for SNMP to always use a big enough size
variable that the compiler won't moan about comparing it to ULONG_MAX/8 on a
64-bit platform.
- Don't trust a length which is greater than the working buffer.
An invalid length could cause overflow when calculating buffer size
for decoding oid.
- An oid length of zero is invalid and allows for an off-by-one error when
decoding oid because the first subid actually encodes first 2 subids.
- A primitive encoding may not have an indefinite length.
Thanks to Wei Wang from McAfee for report.
Cc: Steven French <sfrench@us.ibm.com>
Cc: stable@kernel.org
Acked-by: Patrick McHardy <kaber@trash.net>
Signed-off-by: Chris Wright <chrisw@sous-sol.org>
Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de>
Introduce expectation classes and policies. An expectation class
is used to distinguish different types of expectations by the
same helper (for example audio/video/t.120). The expectation
policy is used to hold the maximum number of expectations and
the initial timeout for each class.
The individual classes are isolated from each other, which means
that for example an audio expectation will only evict other audio
expectations.
Parenthesize macro parameters.
With all the users of the double pointers removed, this patch mops up by
finally replacing all occurances of sk_buff ** in the netfilter API by
sk_buff *.
Now that all callers of netfilter can guarantee that the skb is not shared,
we no longer have to copy the skb in skb_make_writable.
Since conntrack currently allows to use masks for every bit of both
helper and expectation tuples, we can't hash them and have to keep
them on two global lists that are searched for every new connection.
This patch removes the never used ability to use masks for the
destination part of the expectation tuple and completely removes
masks from helpers since the only reasonable choice is a full
match on l3num, protonum and src.u.all.
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
Add nf_conntrack port of the SNMP NAT helper.
