path: root/net/ipv4/proc.c
2009-04-27snmp: add missing counters for RFC 4293Neil Horman
The IP MIB (RFC 4293) defines stats for InOctets, OutOctets, InMcastOctets and OutMcastOctets: http://tools.ietf.org/html/rfc4293 But it seems we don't track those in any way that easy to separate from other protocols. This patch adds those missing counters to the stats file. Tested successfully by me With help from Eric Dumazet. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-16net: replace commatas with semicolonsThomas Gleixner
Impact: syntax fix Interestingly enough this compiles w/o any complaints: orphans = percpu_counter_sum_positive(&tcp_orphan_count), sockets = percpu_counter_sum_positive(&tcp_sockets_allocated), Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-29net: Fix percpu counters deadlockHerbert Xu
When we converted the protocol atomic counters such as the orphan count and the total socket count deadlocks were introduced due to the mismatch in BH status of the spots that used the percpu counter operations. Based on the diagnosis and patch by Peter Zijlstra, this patch fixes these issues by disabling BH where we may be in process context. Reported-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Tested-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-25net: Use a percpu_counter for orphan_countEric Dumazet
Instead of using one atomic_t per protocol, use a percpu_counter for "orphan_count", to reduce cache line contention on heavy duty network servers. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-25net: Use a percpu_counter for sockets_allocatedEric Dumazet
Instead of using one atomic_t per protocol, use a percpu_counter for "sockets_allocated", to reduce cache line contention on heavy duty network servers. Note : We revert commit (248969ae31e1b3276fc4399d67ce29a5d81e6fd9 net: af_unix can make unix_nr_socks visbile in /proc), since it is not anymore used after sock_prot_inuse_add() addition Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-24tcp: add some mibs to track collapsingIlpo Järvinen
Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-10net: fix /proc/net/snmp as memory corruptorEric Dumazet
icmpmsg_put() can happily corrupt kernel memory, using a static table and forgetting to reset an array index in a loop. Remove the static array since its not safe without proper locking. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-30tcp: MD5: Use MIB counter instead of warning for MD5 mismatch.David S. Miller
From a report by Matti Aarnio, and preliminary patch by Adam Langley. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-18proc: consolidate per-net single-release callersPavel Emelyanov
They are symmetrical to single_open ones :) Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-18proc: consolidate per-net single_open callersPavel Emelyanov
There are already 7 of them - time to kill some duplicate code. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-18proc: clean the ip_misc_proc_init and ip_proc_init_net error pathsPavel Emelyanov
After all this stuff is moved outside, this function can look better. Besides, I tuned the error path in ip_proc_init_net to make it have only 2 exit points, not 3. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-18proc: show per-net ip_devconf.forwarding in /proc/net/snmpPavel Emelyanov
This one has become per-net long ago, but the appropriate file is per-net only now. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-18proc: create /proc/net/snmp file in each netPavel Emelyanov
All the statistics shown in this file have been made per-net already. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-18proc: create /proc/net/netstat file in each netPavel Emelyanov
Now all the shown in it statistics is netnsizated, time to show it in appropriate net. The appropriate net init/exit ops already exist - they make the sockstat file per net - so just extend them. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-18mib: put icmpmsg statistics on struct netPavel Emelyanov
2008-07-18mib: put icmp statistics on struct netPavel Emelyanov
2008-07-18mib: put udplite statistics on struct netPavel Emelyanov
2008-07-18mib: put udp statistics on struct netPavel Emelyanov
Similar to... ouch, I repeat myself. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-18mib: put net statistics on struct netPavel Emelyanov
Similar to ip and tcp ones :) Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-18mib: put ip statistics on struct netPavel Emelyanov
Similar to tcp one. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-18mib: put tcp statistics on struct netPavel Emelyanov
Proc temporary uses stats from init_net. BTW, TCP_XXX_STATS are beautiful (w/o do { } while (0) facing) again :) Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-11net: remove CVS keywordsAdrian Bunk
This patch removes CVS keywords that weren't updated for a long time from comments. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-31[IPV4][NETNS]: Display per-net info in sockstat file.Pavel Emelyanov
Besides, now we can see per-net fragments statistics in the same file, since this stats is already per-net. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-31[SOCK][NETNS]: Register sockstat(6) files in each net.Pavel Emelyanov
Currently they live in init_net only, but now almost all the info they can provide is available per-net. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-31[SOCK][NETNS]: Add a struct net argument to sock_prot_inuse_add and _get.Pavel Emelyanov
This counter is about to become per-proto-and-per-net, so we'll need two arguments to determine which cell in this "table" to work with. All the places, but proc already pass proper net to it - proc will be tuned a bit later. Some indentation with spaces in proc files is done to keep the file coding style consistent. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-06[UDP]: Revert udplite and code split.David S. Miller
This reverts commit db1ed684f6c430c4cdad67d058688b8a1b5e607c ("[IPV6] UDP: Rename IPv6 UDP files."), commit 8be8af8fa4405652e6c0797db5465a4be8afb998 ("[IPV4] UDP: Move IPv4-specific bits to other file.") and commit e898d4db2749c6052072e9bc4448e396cbdeb06a ("[UDP]: Allow users to configure UDP-Lite."). First, udplite is of such small cost, and it is a core protocol just like TCP and normal UDP are. We spent enormous amounts of effort to make udplite share as much code with core UDP as possible. All of that work is less valuable if we're just going to slap a config option on udplite support. It is also causing build failures, as reported on linux-next, showing that the changeset was not tested very well. In fact, this is the second build failure resulting from the udplite change. Finally, the config options provided was a bool, instead of a modular option. Meaning the udplite code does not even get build tested by allmodconfig builds, and furthermore the user is not presented with a reasonable modular build option which is particularly needed by distribution vendors. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-04[UDP]: Allow users to configure UDP-Lite.YOSHIFUJI Hideaki
Let's give users an option for disabling UDP-Lite (~4K). old: | text data bss dec hex filename | 286498 12432 6072 305002 4a76a net/ipv4/built-in.o | 193830 8192 3204 205226 321aa net/ipv6/ipv6.o new (without UDP-Lite): | text data bss dec hex filename | 284086 12136 5432 301654 49a56 net/ipv4/built-in.o | 191835 7832 3076 202743 317f7 net/ipv6/ipv6.o Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2008-01-28[NETNS][FRAGS]: Make the mem counter per-namespace.Pavel Emelyanov
This is also simple, but introduces more changes, since then mem counter is altered in more places. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETNS][FRAGS]: Make the nqueues counter per-namespace.Pavel Emelyanov
This is simple - just move the variable from struct inet_frags to struct netns_frags and adjust the usage appropriately. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NET]: prot_inuse cleanups and optimizationsEric Dumazet
1) Cleanups (all functions are prefixed by sock_prot_inuse) sock_prot_inc_use(prot) -> sock_prot_inuse_add(prot,-1) sock_prot_dec_use(prot) -> sock_prot_inuse_add(prot,-1) sock_prot_inuse() -> sock_prot_inuse_get() New functions : sock_prot_inuse_init() and sock_prot_inuse_free() to abstract pcounter use. 2) if CONFIG_PROC_FS=n, we can zap 'inuse' member from "struct proto", since nobody wants to read the inuse value. This saves 1372 bytes on i386/SMP and some cpu cycles. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[UDP]: Add memory accounting.Hideo Aoki
Signed-off-by: Takahiro Yasui <tyasui@redhat.com> Signed-off-by: Hideo Aoki <haoki@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[IPV4]: Switch users of ipv4_devconf(_all) to use the pernet onePavel Emelyanov
These are scattered over the code, but almost all the "critical" places already have the proper struct net at hand except for snmp proc showing function and routing rtnl handler. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-11-07[NET]: Define infrastructure to keep 'inuse' changes in an efficent SMP/NUMA ↵Eric Dumazet
way. "struct proto" currently uses an array stats[NR_CPUS] to track change on 'inuse' sockets per protocol. If NR_CPUS is big, this means we use a big memory area for this. Moreover, all this memory area is located on a single node on NUMA machines, increasing memory pressure on the boot node. In this patch, I tried to : - Keep a fast !CONFIG_SMP implementation - Keep a fast CONFIG_SMP implementation for often used protocols (tcp,udp,raw,...) - Introduce a NUMA efficient implementation Some helper macros are defined in include/net/sock.h These macros take into account CONFIG_SMP If a "struct proto" is declared without using DEFINE_PROTO_INUSE / REF_PROTO_INUSE macros, it will automatically use a default implementation, using a dynamically allocated percpu zone. This default implementation will be NUMA efficient, but might use 32/64 bytes per possible cpu because of current alloc_percpu() implementation. However it still should be better than previous implementation based on stats[NR_CPUS] field. When a "struct proto" is changed to use the new macros, we use a single static "int" percpu variable, lowering the memory and cpu costs, still preserving NUMA efficiency. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-29[IPv4] SNMP: Refer correct memory location to display ICMP out-going statisticsMitsuru Chinen
While displaying ICMP out-going statistics as Out<name> counters in /proc/net/snmp, the memory location for ICMP in-coming statistics was referred by mistake. Signed-off-by: Mitsuru Chinen <mitch@linux.vnet.ibm.com> Acked-by: David L Stevens <dlstevens@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-25[IPV4]: Remove no longer used snmp4_icmp_list.David S. Miller
This was obsoleted by a previous change, but the removal was forgotten. Reported by David Howells and David Stevens. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-15[INET]: Collect frag queues management objects togetherPavel Emelyanov
There are some objects that are common in all the places which are used to keep track of frag queues, they are: * hash table * LRU list * rw lock * rnd number for hash function * the number of queues * the amount of memory occupied by queues * secret timer Move all this stuff into one structure (struct inet_frags) to make it possible use them uniformly in the future. Like with the previous patch this mostly consists of hunks like - write_lock(&ipfrag_lock); + write_lock(&ip4_frags.lock); To address the issue with exporting the number of queues and the amount of memory occupied by queues outside the .c file they are declared in, I introduce a couple of helpers. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: sparse warning fixesStephen Hemminger
Fix a bunch of sparse warnings. Mostly about 0 used as NULL pointer, and shadowed variable declarations. One notable case was that hash size should have been unsigned. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[TCP] MIB: Count FRTO's successfully detected spurious RTOsIlpo Järvinen
2007-10-10[IPV4]: Add ICMPMsgStats MIB (RFC 4293)David L Stevens
Background: RFC 4293 deprecates existing individual, named ICMP type counters to be replaced with the ICMPMsgStatsTable. This table includes entries for both IPv4 and IPv6, and requires counting of all ICMP types, whether or not the machine implements the type. These patches "remove" (but not really) the existing counters, and replace them with the ICMPMsgStats tables for v4 and v6. It includes the named counters in the /proc places they were, but gets the values for them from the new tables. It also counts packets generated from raw socket output (e.g., OutEchoes, MLD queries, RA's from radvd, etc). Changes: 1) create icmpmsg_statistics mib 2) create icmpv6msg_statistics mib 3) modify existing counters to use these 4) modify /proc/net/snmp to add "IcmpMsg" with all ICMP types listed by number for easy SNMP parsing 5) modify /proc/net/snmp printing for "Icmp" to get the named data from new counters. Signed-off-by: David L Stevens <dlstevens@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Make /proc/net per network namespaceEric W. Biederman
This patch makes /proc/net per network namespace. It modifies the global variables proc_net and proc_net_stat to be per network namespace. The proc_net file helpers are modified to take a network namespace argument, and all of their callers are fixed to pass &init_net for that argument. This ensures that all of the /proc/net files are only visible and usable in the initial network namespace until the code behind them has been updated to be handle multiple network namespaces. Making /proc/net per namespace is necessary as at least some files in /proc/net depend upon the set of network devices which is per network namespace, and even more files in /proc/net have contents that are relevant to a single network namespace. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[TCP] MIB: Add counters for discarded SACK blocksIlpo Järvinen
In DSACK case, some events are not extraordinary, such as packet duplication generated DSACK. They can arrive easily below snd_una when undo_marker is not set (TCP being in CA_Open), counting such DSACKs amoung SACK discards will likely just mislead if they occur in some scenario when there are other problems as well. Similarly, excessively delayed packets could cause "normal" DSACKs. Therefore, separate counters are allocated for DSACK events. Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-06-07[IPV4]: Convert IPv4 devconf to an arrayHerbert Xu
This patch converts the ipv4_devconf config members (everything except sysctl) to an array. This allows easier manipulation which will be needed later on to provide better management of default config values. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-14[IPV4] SNMP: Display new statistics at /proc/net/netstatMitsuru Chinen
This displays the statistics specified in the updated IP-MIB RFC (RFC4293) in /proc/net/netstat. The reason why these are not displayed in /proc/net/snmp is that some existing utilities are developed under the assumption which ipstat items in /proc/net/snmp is unchanged. Signed-off-by: Mitsuru Chinen <mitch@linux.vnet.ibm.com> Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[IPV4]: Consolidate common SNMP codeHerbert Xu
This patch moves the SNMP code shared between IPv4/IPv6 from proc.c into net/ipv4/af_inet.c. This makes sense because these functions aren't specific to /proc. As a result we can again skip proc.o if /proc is disabled. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Acked-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[IPV4]: Fix build without procfs.YOSHIFUJI Hideaki
2007-04-25[IPV4] SNMP: Move some statistic bits to net/ipv4/proc.c.YOSHIFUJI Hideaki
This also fixes memory leak in error path. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-12[PATCH] mark struct file_operations const 7Arjan van de Ven
Many struct file_operations in the kernel can be "const". Marking them const moves these to the .rodata section, which avoids false sharing with potential dirty data. In addition it'll catch accidental writes at compile time to these shared resources. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-10[NET] IPV4: Fix whitespace errors.YOSHIFUJI Hideaki
2006-12-02[NET]: Supporting UDP-Lite (RFC 3828) in LinuxGerrit Renker
This is a revision of the previously submitted patch, which alters the way files are organized and compiled in the following manner: * UDP and UDP-Lite now use separate object files * source file dependencies resolved via header files net/ipv{4,6}/udp_impl.h * order of inclusion files in udp.c/udplite.c adapted accordingly [NET/IPv4]: Support for the UDP-Lite protocol (RFC 3828) This patch adds support for UDP-Lite to the IPv4 stack, provided as an extension to the existing UDPv4 code: * generic routines are all located in net/ipv4/udp.c * UDP-Lite specific routines are in net/ipv4/udplite.c * MIB/statistics support in /proc/net/snmp and /proc/net/udplite * shared API with extensions for partial checksum coverage [NET/IPv6]: Extension for UDP-Lite over IPv6 It extends the existing UDPv6 code base with support for UDP-Lite in the same manner as per UDPv4. In particular, * UDPv6 generic and shared code is in net/ipv6/udp.c * UDP-Litev6 specific extensions are in net/ipv6/udplite.c * MIB/statistics support in /proc/net/snmp6 and /proc/net/udplite6 * support for IPV6_ADDRFORM * aligned the coding style of protocol initialisation with af_inet6.c * made the error handling in udpv6_queue_rcv_skb consistent; to return `-1' on error on all error cases * consolidation of shared code [NET]: UDP-Lite Documentation and basic XFRM/Netfilter support The UDP-Lite patch further provides * API documentation for UDP-Lite * basic xfrm support * basic netfilter support for IPv4 and IPv6 (LOG target) Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[IPV4]: add the UdpSndbufErrors and UdpRcvbufErrors MIBsMartin Bligh
Signed-off-by: Martin Bligh <mbligh@google.com> Signed-off-by: Andrew Morton <akpm@osdl.org>
