path: root/net/ipv4/raw.c
2011-05-24net: convert %p usage to %pKDan Rosenberg
The %pK format specifier is designed to hide exposed kernel pointers, specifically via /proc interfaces. Exposing these pointers provides an easy target for kernel write vulnerabilities, since they reveal the locations of writable structures containing easily triggerable function pointers. The behavior of %pK depends on the kptr_restrict sysctl. If kptr_restrict is set to 0, no deviation from the standard %p behavior occurs. If kptr_restrict is set to 1, the default, if the current user (intended to be a reader via seq_printf(), etc.) does not have CAP_SYSLOG (currently in the LSM tree), kernel pointers using %pK are printed as 0's. If kptr_restrict is set to 2, kernel pointers using %pK are printed as 0's regardless of privileges. Replacing with 0's was chosen over the default "(null)", which cannot be parsed by userland %p, which expects "(nil)". The supporting code for kptr_restrict and %pK are currently in the -mm tree. This patch converts users of %p in net/ to %pK. Cases of printing pointers to the syslog are not covered, since this would eliminate useful information for postmortem debugging and the reading of the syslog is already optionally protected by the dmesg_restrict sysctl. Signed-off-by: Dan Rosenberg <drosenberg@vsecurity.com> Cc: James Morris <jmorris@namei.org> Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: Thomas Graf <tgraf@infradead.org> Cc: Eugene Teo <eugeneteo@kernel.org> Cc: Kees Cook <kees.cook@canonical.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David S. Miller <davem@davemloft.net> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Eric Paris <eparis@parisplace.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-08ipv4: Pass flow key down into ip_append_*().David S. Miller
This way rt->rt_dst accesses are unnecessary. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-08ipv4: Pass flow keys down into datagram packet building engine.David S. Miller
This way ip_output.c no longer needs rt->rt_{src,dst}. We already have these keys sitting, ready and waiting, on the stack or in a socket structure. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-28inet: add RCU protection to inet->optEric Dumazet
We lack proper synchronization to manipulate inet->opt ip_options Problem is ip_make_skb() calls ip_setup_cork() and ip_setup_cork() possibly makes a copy of ipc->opt (struct ip_options), without any protection against another thread manipulating inet->opt. Another thread can change inet->opt pointer and free old one under us. Use RCU to protect inet->opt (changed to inet->inet_opt). Instead of handling atomic refcounts, just copy ip_options when necessary, to avoid cache line dirtying. We cant insert an rcu_head in struct ip_options since its included in skb->cb[], so this patch is large because I had to introduce a new ip_options_rcu structure. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-22inet: constify ip headers and in6_addrEric Dumazet
Add const qualifiers to structs iphdr, ipv6hdr and in6_addr pointers where possible, to make code intention more obvious. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-11Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/smsc911x.c
2011-03-31ipv4: Use flowi4_init_output() in raw_sendmsg()David S. Miller
2011-03-28ipv4: Don't ip_rt_put() an error pointer in RAW sockets.David S. Miller
Reported-by: Marc Kleine-Budde <mkl@pengutronix.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-12net: Put fl4_* macros to struct flowi4 and use them again.David S. Miller
2011-03-12ipv4: Use flowi4 in public route lookup interfaces.David S. Miller
2011-03-12net: Make flowi ports AF dependent.David S. Miller
Create two sets of port member accessors, one set prefixed by fl4_* and the other prefixed by fl6_* This will let us to create AF optimal flow instances. It will work because every context in which we access the ports, we have to be fully aware of which AF the flowi is anyways. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-12net: Put flowi_* prefix on AF independent members of struct flowiDavid S. Miller
I intend to turn struct flowi into a union of AF specific flowi structs. There will be a common structure that each variant includes first, much like struct sock_common. This is the first step to move in that direction. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-02ipv4: Make output route lookup return rtable directly.David S. Miller
Instead of on the stack. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-01ipv4: Kill can_sleep arg to ip_route_output_flow()David S. Miller
This boolean state is now available in the flow flags. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-01net: Add FLOWI_FLAG_CAN_SLEEP.David S. Miller
And set is in contexts where the route resolution can sleep. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-01ipv4: Make final arg to ip_route_output_flow to be boolean "can_sleep"David S. Miller
Since that is what the current vague "flags" argument means. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-30net: Add compat ioctl support for the ipv4 multicast ioctl SIOCGETSGCNTEric W. Biederman
SIOCGETSGCNT is not a unique ioctl value as it it maps tio SIOCPROTOPRIVATE +1, which unfortunately means the existing infrastructure for compat networking ioctls is insufficient. A trivial compact ioctl implementation would conflict with: SIOCAX25ADDUID SIOCAIPXPRISLT SIOCGETSGCNT_IN6 SIOCGETSGCNT SIOCRSSCAUSE SIOCX25SSUBSCRIP SIOCX25SDTEFACILITIES To make this work I have updated the compat_ioctl decode path to mirror the the normal ioctl decode path. I have added an ipv4 inet_compat_ioctl function so that I can have ipv4 specific compat ioctls. I have added a compat_ioctl function into struct proto so I can break out ioctls by which kind of ip socket I am using. I have added a compat_raw_ioctl function because SIOCGETSGCNT only works on raw sockets. I have added a ipmr_compat_ioctl that mirrors the normal ipmr_ioctl. This was necessary because unfortunately the struct layout for the SIOCGETSGCNT has unsigned longs in it so changes between 32bit and 64bit kernels. This change was sufficient to run a 32bit ip multicast routing daemon on a 64bit kernel. Reported-by: Bill Fenner <fenner@aristanetworks.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-17net: use the macros defined for the members of flowiChangli Gao
Use the macros defined for the members of flowi to clean the code up. Signed-off-by: Changli Gao <xiaosuo@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-19net: simplify flags for tx timestampingOliver Hartkopp
This patch removes the abstraction introduced by the union skb_shared_tx in the shared skb data. The access of the different union elements at several places led to some confusion about accessing the shared tx_flags e.g. in skb_orphan_try(). http://marc.info/?l=linux-netdev&m=128084897415886&w=2 Signed-off-by: Oliver Hartkopp <socketcan@hartkopp.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-10net-next: remove useless union keywordChangli Gao
remove useless union keyword in rtable, rt6_info and dn_route. Since there is only one member in a union, the union keyword isn't useful. Signed-off-by: Changli Gao <xiaosuo@gmail.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-07raw: avoid two atomics in xmitEric Dumazet
Avoid two atomic ops per raw_send_hdrinc() call Avoid two atomic ops per raw6_send_hdrinc() call Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-10Merge branch 'master' of /repos/git/net-next-2.6Patrick McHardy
Conflicts: net/bridge/br_device.c net/bridge/br_forward.c Signed-off-by: Patrick McHardy <kaber@trash.net>
2010-04-28net: ip_queue_rcv_skb() helperEric Dumazet
When queueing a skb to socket, we can immediately release its dst if target socket do not use IP_CMSG_PKTINFO. tcp_data_queue() can drop dst too. This to benefit from a hot cache line and avoid the receiver, possibly on another cpu, to dirty this cache line himself. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-20Merge branch 'master' of /repos/git/net-next-2.6Patrick McHardy
Conflicts: Documentation/feature-removal-schedule.txt net/ipv6/netfilter/ip6t_REJECT.c net/netfilter/xt_limit.c Signed-off-by: Patrick McHardy <kaber@trash.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-25netfilter: ipv4: use NFPROTO values for NF_HOOK invocationJan Engelhardt
The semantic patch that was used: // <smpl> @@ @@ (NF_HOOK |NF_HOOK_COND |nf_hook )( -PF_INET, +NFPROTO_IPV4, ...) // </smpl> Signed-off-by: Jan Engelhardt <jengelh@medozas.de>
2009-10-29Merge branch 'master' of ↵David S. Miller
2009-10-29AF_RAW: Augment raw_send_hdrinc to expand skb to fit iphdr->ihl (v2)Neil Horman
Augment raw_send_hdrinc to correct for incorrect ip header length values A series of oopses was reported to me recently. Apparently when using AF_RAW sockets to send data to peers that were reachable via ipsec encapsulation, people could panic or BUG halt their systems. I've tracked the problem down to user space sending an invalid ip header over an AF_RAW socket with IP_HDRINCL set to 1. Basically what happens is that userspace sends down an ip frame that includes only the header (no data), but sets the ip header ihl value to a large number, one that is larger than the total amount of data passed to the sendmsg call. In raw_send_hdrincl, we allocate an skb based on the size of the data in the msghdr that was passed in, but assume the data is all valid. Later during ipsec encapsulation, xfrm4_tranport_output moves the entire frame back in the skbuff to provide headroom for the ipsec headers. During this operation, the skb->transport_header is repointed to a spot computed by skb->network_header + the ip header length (ihl). Since so little data was passed in relative to the value of ihl provided by the raw socket, we point transport header to an unknown location, resulting in various crashes. This fix for this is pretty straightforward, simply validate the value of of iph->ihl when sending over a raw socket. If (iph->ihl*4U) > user data buffer size, drop the frame and return -EINVAL. I just confirmed this fixes the reported crashes. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-18inet: rename some inet_sock fieldsEric Dumazet
In order to have better cache layouts of struct sock (separate zones for rx/tx paths), we need this preliminary patch. Goal is to transfert fields used at lookup time in the first read-mostly cache line (inside struct sock_common) and move sk_refcnt to a separate cache line (only written by rx path) This patch adds inet_ prefix to daddr, rcv_saddr, dport, num, saddr, sport and id fields. This allows a future patch to define these fields as macros, like sk_refcnt, without name clashes. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-14net: sk_drops consolidationEric Dumazet
sock_queue_rcv_skb() can update sk_drops itself, removing need for callers to take care of it. This is more consistent since sock_queue_rcv_skb() also reads sk_drops when queueing a skb. This adds sk_drops managment to many protocols that not cared yet. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-12net: Generalize socket rx gap / receive queue overflow cmsgNeil Horman
Create a new socket level option to report number of queue overflows Recently I augmented the AF_PACKET protocol to report the number of frames lost on the socket receive queue between any two enqueued frames. This value was exported via a SOL_PACKET level cmsg. AFter I completed that work it was requested that this feature be generalized so that any datagram oriented socket could make use of this option. As such I've created this patch, It creates a new SOL_SOCKET level option called SO_RXQ_OVFL, which when enabled exports a SOL_SOCKET level cmsg that reports the nubmer of times the sk_receive_queue overflowed between any two given frames. It also augments the AF_PACKET protocol to take advantage of this new feature (as it previously did not touch sk->sk_drops, which this patch uses to record the overflow count). Tested successfully by me. Notes: 1) Unlike my previous patch, this patch simply records the sk_drops value, which is not a number of drops between packets, but rather a total number of drops. Deltas must be computed in user space. 2) While this patch currently works with datagram oriented protocols, it will also be accepted by non-datagram oriented protocols. I'm not sure if thats agreeable to everyone, but my argument in favor of doing so is that, for those protocols which aren't applicable to this option, sk_drops will always be zero, and reporting no drops on a receive queue that isn't used for those non-participating protocols seems reasonable to me. This also saves us having to code in a per-protocol opt in mechanism. 3) This applies cleanly to net-next assuming that commit 977750076d98c7ff6cbda51858bb5a5894a9d9ab (my af packet cmsg patch) is reverted Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-30net: Make setsockopt() optlen be unsigned.David S. Miller
This provides safety against negative optlen at the type level instead of depending upon (sometimes non-trivial) checks against this sprinkled all over the the place, in each and every implementation. Based upon work done by Arjan van de Ven and feedback from Linus Torvalds. Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-02ip: Report qdisc packet dropsEric Dumazet
Christoph Lameter pointed out that packet drops at qdisc level where not accounted in SNMP counters. Only if application sets IP_RECVERR, drops are reported to user (-ENOBUFS errors) and SNMP counters updated. IP_RECVERR is used to enable extended reliable error message passing, but these are not needed to update system wide SNMP stats. This patch changes things a bit to allow SNMP counters to be updated, regardless of IP_RECVERR being set or not on the socket. Example after an UDP tx flood # netstat -s ... IP: 1487048 outgoing packets dropped ... Udp: ... SndbufErrors: 1487048 send() syscalls, do however still return an OK status, to not break applications. Note : send() manual page explicitly says for -ENOBUFS error : "The output queue for a network interface was full. This generally indicates that the interface has stopped sending, but may be caused by transient congestion. (Normally, this does not occur in Linux. Packets are just silently dropped when a device queue overflows.) " This is not true for IP_RECVERR enabled sockets : a send() syscall that hit a qdisc drop returns an ENOBUFS error. Many thanks to Christoph, David, and last but not least, Alexey ! Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-18net: correct off-by-one write allocations reportsEric Dumazet
commit 2b85a34e911bf483c27cfdd124aeb1605145dc80 (net: No more expensive sock_hold()/sock_put() on each tx) changed initial sk_wmem_alloc value. We need to take into account this offset when reporting sk_wmem_alloc to user, in PROC_FS files or various ioctls (SIOCOUTQ/TIOCOUTQ) Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-03net: skb->dst accessorsEric Dumazet
Define three accessors to get/set dst attached to a skb struct dst_entry *skb_dst(const struct sk_buff *skb) void skb_dst_set(struct sk_buff *skb, struct dst_entry *dst) void skb_dst_drop(struct sk_buff *skb) This one should replace occurrences of : dst_release(skb->dst) skb->dst = NULL; Delete skb->dst field Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-15ip: support for TX timestamps on UDP and RAW socketsPatrick Ohly
Instructions for time stamping outgoing packets are take from the socket layer and later copied into the new skb. Signed-off-by: Patrick Ohly <patrick.ohly@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-24net: avoid a pair of dst_hold()/dst_release() in ip_append_data()Eric Dumazet
We can reduce pressure on dst entry refcount that slowdown UDP transmit path on SMP machines. This pressure is visible on RTP servers when delivering content to mediagateways, especially big ones, handling thousand of streams. Several cpus send UDP frames to the same destination, hence use the same dst entry. This patch makes ip_append_data() eventually steal the refcount its callers had to take on the dst entry. This doesnt avoid all refcounting, but still gives speedups on SMP, on UDP/RAW transmit path Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-03net: clean up net/ipv4/ipip.c raw.c tcp.c tcp_minisocks.c tcp_yeah.c ↵Jianjun Kong
xfrm4_policy.c Signed-off-by: Jianjun Kong <jianjun@zeuux.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-16mib: add net to IP_INC_STATSPavel Emelyanov
All the callers already have either the net itself, or the place where to get it from. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-14icmp: add struct net argument to icmp_out_countPavel Emelyanov
This routine deals with ICMP statistics, but doesn't have a struct net at hands, so add one. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-17udp: sk_drops handlingEric Dumazet
In commits 33c732c36169d7022ad7d6eb474b0c9be43a2dc1 ([IPV4]: Add raw drops counter) and a92aa318b4b369091fd80433c80e62838db8bc1c ([IPV6]: Add raw drops counter), Wang Chen added raw drops counter for /proc/net/raw & /proc/net/raw6 This patch adds this capability to UDP sockets too (/proc/net/udp & /proc/net/udp6). This means that 'RcvbufErrors' errors found in /proc/net/snmp can be also be examined for each udp socket. # grep Udp: /proc/net/snmp Udp: InDatagrams NoPorts InErrors OutDatagrams RcvbufErrors SndbufErrors Udp: 23971006 75 899420 16390693 146348 0 # cat /proc/net/udp sl local_address rem_address st tx_queue rx_queue tr tm->when retrnsmt --- uid timeout inode ref pointer drops 75: 00000000:02CB 00000000:0000 07 00000000:00000000 00:00000000 00000000 --- 0 0 2358 2 ffff81082a538c80 0 111: 00000000:006F 00000000:0000 07 00000000:00000000 00:00000000 00000000 --- 0 0 2286 2 ffff81042dd35c80 146348 In this example, only port 111 (0x006F) was flooded by messages that user program could not read fast enough. 146348 messages were lost. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-16Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/wireless/rt2x00/Kconfig drivers/net/wireless/rt2x00/rt2x00usb.c net/sctp/protocol.c
2008-06-16raw: Restore /proc/net/raw correct behaviorEric Dumazet
I just noticed "cat /proc/net/raw" was buggy, missing '\n' separators. I believe this was introduced by commit 8cd850efa4948d57a2ed836911cfd1ab299e89c6 ([RAW]: Cleanup IPv4 raw_seq_show.) This trivial patch restores correct behavior, and applies to current Linus tree (should also be applied to stable tree as well.) Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-14net: change proto destroy method to return voidBrian Haley
Change struct proto destroy function pointer to return void. Noticed by Al Viro. Signed-off-by: Brian Haley <brian.haley@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-11net: remove CVS keywordsAdrian Bunk
This patch removes CVS keywords that weren't updated for a long time from comments. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-04raw: Raw socket leak.Denis V. Lunev
The program below just leaks the raw kernel socket int main() { int fd = socket(PF_INET, SOCK_RAW, IPPROTO_UDP); struct sockaddr_in addr; memset(&addr, 0, sizeof(addr)); inet_aton("127.0.0.1", &addr.sin_addr); addr.sin_family = AF_INET; addr.sin_port = htons(2048); sendto(fd, "a", 1, MSG_MORE, &addr, sizeof(addr)); return 0; } Corked packet is allocated via sock_wmalloc which holds the owner socket, so one should uncork it and flush all pending data on close. Do this in the same way as in UDP. Signed-off-by: Denis V. Lunev <den@openvz.org> Acked-by: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-12net: Allow netdevices to specify needed head/tailroomJohannes Berg
This patch adds needed_headroom/needed_tailroom members to struct net_device and updates many places that allocate sbks to use them. Not all of them can be converted though, and I'm sure I missed some (I mostly grepped for LL_RESERVED_SPACE) Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-31[SOCK][NETNS]: Add a struct net argument to sock_prot_inuse_add and _get.Pavel Emelyanov
This counter is about to become per-proto-and-per-net, so we'll need two arguments to determine which cell in this "table" to work with. All the places, but proc already pass proper net to it - proc will be tuned a bit later. Some indentation with spaces in proc files is done to keep the file coding style consistent. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-28[SOCK]: Drop inuse pcounter from struct proto (v2).Pavel Emelyanov
An uppercut - do not use the pcounter on struct proto. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Acked-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
