[ Upstream commit 8f659a03a0ba9289b9aeb9b4470e6fb263d6f483 ]
inet->hdrincl is racy, and could lead to uninitialized stack pointer
usage, so its value should be read only once.
Fixes: c008ba5bdc9f ("ipv4: Avoid reading user iov twice after raw_probe_proto_opt")
Signed-off-by: Mohamed Ghannam <simo.ghannam@gmail.com>
Reviewed-by: Eric Dumazet <edumazet@google.com>
[ Upstream commit 86f4c90a1c5c1493f07f2d12c1079f5bf01936f2 ]
raw_send_hdrinc() and rawv6_send_hdrinc() expect that the buffer copied
from the userspace contains the IPv4/IPv6 header, so if too few bytes are
copied, parts of the header may remain uninitialized.
This bug has been detected with KMSAN.
For the record, the KMSAN report:
BUG: KMSAN: use of unitialized memory in nf_ct_frag6_gather+0xf5a/0x44a0
inter: 0
CPU: 0 PID: 1036 Comm: probe Not tainted 4.11.0-rc5+ #2455
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs 01/01/2011
Call Trace:
__dump_stack lib/dump_stack.c:16
dump_stack+0x143/0x1b0 lib/dump_stack.c:52
kmsan_report+0x16b/0x1e0 mm/kmsan/kmsan.c:1078
__kmsan_warning_32+0x5c/0xa0 mm/kmsan/kmsan_instr.c:510
nf_ct_frag6_gather+0xf5a/0x44a0 net/ipv6/netfilter/nf_conntrack_reasm.c:577
ipv6_defrag+0x1d9/0x280 net/ipv6/netfilter/nf_defrag_ipv6_hooks.c:68
nf_hook_entry_hookfn ./include/linux/netfilter.h:102
nf_hook_slow+0x13f/0x3c0 net/netfilter/core.c:310
nf_hook ./include/linux/netfilter.h:212
NF_HOOK ./include/linux/netfilter.h:255
rawv6_send_hdrinc net/ipv6/raw.c:673
rawv6_sendmsg+0x2fcb/0x41a0 net/ipv6/raw.c:919
inet_sendmsg+0x3f8/0x6d0 net/ipv4/af_inet.c:762
sock_sendmsg_nosec net/socket.c:633
sock_sendmsg net/socket.c:643
SYSC_sendto+0x6a5/0x7c0 net/socket.c:1696
SyS_sendto+0xbc/0xe0 net/socket.c:1664
do_syscall_64+0x72/0xa0 arch/x86/entry/common.c:285
entry_SYSCALL64_slow_path+0x25/0x25 arch/x86/entry/entry_64.S:246
RIP: 0033:0x436e03
RSP: 002b:00007ffce48baf38 EFLAGS: 00000246 ORIG_RAX: 000000000000002c
RAX: ffffffffffffffda RBX: 00000000004002b0 RCX: 0000000000436e03
RDX: 0000000000000000 RSI: 0000000000000000 RDI: 0000000000000003
RBP: 00007ffce48baf90 R08: 00007ffce48baf50 R09: 000000000000001c
R10: 0000000000000000 R11: 0000000000000246 R12: 0000000000000000
R13: 0000000000401790 R14: 0000000000401820 R15: 0000000000000000
origin: 00000000d9400053
save_stack_trace+0x16/0x20 arch/x86/kernel/stacktrace.c:59
kmsan_save_stack_with_flags mm/kmsan/kmsan.c:362
kmsan_internal_poison_shadow+0xb1/0x1a0 mm/kmsan/kmsan.c:257
kmsan_poison_shadow+0x6d/0xc0 mm/kmsan/kmsan.c:270
slab_alloc_node mm/slub.c:2735
__kmalloc_node_track_caller+0x1f4/0x390 mm/slub.c:4341
__kmalloc_reserve net/core/skbuff.c:138
__alloc_skb+0x2cd/0x740 net/core/skbuff.c:231
alloc_skb ./include/linux/skbuff.h:933
alloc_skb_with_frags+0x209/0xbc0 net/core/skbuff.c:4678
sock_alloc_send_pskb+0x9ff/0xe00 net/core/sock.c:1903
sock_alloc_send_skb+0xe4/0x100 net/core/sock.c:1920
rawv6_send_hdrinc net/ipv6/raw.c:638
rawv6_sendmsg+0x2918/0x41a0 net/ipv6/raw.c:919
return_from_SYSCALL_64+0x0/0x6a arch/x86/entry/entry_64.S:246
, triggered by the following syscalls:
socket(PF_INET6, SOCK_RAW, IPPROTO_RAW) = 3
sendto(3, NULL, 0, 0, {sa_family=AF_INET6, sin6_port=htons(0), inet_pton(AF_INET6, "ff00::", &sin6_addr), sin6_flowinfo=0, sin6_scope_id=0}, 28) = -1 EPERM
A similar report is triggered in net/ipv4/raw.c if we use a PF_INET socket
instead of a PF_INET6 one.
Signed-off-by: Alexander Potapenko <glider@google.com>
Baozeng Ding reported KASAN traces showing uses after free in
udp_lib_get_port() and other related UDP functions.
A CONFIG_DEBUG_PAGEALLOC=y kernel would eventually crash.
I could write a reproducer with two threads doing :
static int sock_fd;
static void *thr1(void *arg)
for (;;) {
connect(sock_fd, (const struct sockaddr *)arg,
sizeof(struct sockaddr_in));
static void *thr2(void *arg)
struct sockaddr_in unspec;
for (;;) {
memset(&unspec, 0, sizeof(unspec));
connect(sock_fd, (const struct sockaddr *)&unspec,
sizeof(unspec));
Problem is that udp_disconnect() could run without holding socket lock,
and this was causing list corruptions.
Reported-by: Baozeng Ding <sploving1@gmail.com>
No longer needed
Signed-off-by: David Ahern <dsa@cumulusnetworks.com>
Currently, SOL_TIMESTAMPING can only be enabled using setsockopt.
This is very costly when users want to sample writes to gather
tx timestamps.
Add support for enabling SO_TIMESTAMPING via control messages by
using tsflags added in `struct sockcm_cookie` (added in the previous
patches in this series) to set the tx_flags of the last skb created in
a sendmsg. With this patch, the timestamp recording bits in tx_flags
of the skbuff is overridden if SO_TIMESTAMPING is passed in a cmsg.
Please note that this is only effective for overriding the recording
timestamps flags. Users should enable timestamp reporting (e.g.,
SOF_TIMESTAMPING_SOFTWARE | SOF_TIMESTAMPING_OPT_ID) using
socket options and then should ask for SOF_TIMESTAMPING_TX_*
using control messages per sendmsg to sample timestamps for each
write.
Signed-off-by: Soheil Hassas Yeganeh <soheil@google.com>
Acked-by: Willem de Bruijn <willemb@google.com>
Process socket-level control messages by invoking
__sock_cmsg_send in ip_cmsg_send for control messages on
the SOL_SOCKET layer.
This makes sure whenever ip_cmsg_send is called in udp, icmp,
and raw, we also process socket-level control messages.
Note that this commit interprets new control messages that
were ignored before. As such, this commit does not change
the behavior of IPv4 control messages.
drivers/net/phy/bcm7xxx.c
drivers/net/phy/marvell.c
drivers/net/vxlan.c
All three conflicts were cases of simple overlapping changes.
Dmitry reported memory leaks of IP options allocated in
ip_cmsg_send() when/if this function returns an error.
Callers are responsible for the freeing.
Many thanks to Dmitry for the report and diagnostic.
In order to support fast reuseport lookups in TCP, the hash function
defined in struct proto must be capable of returning an error code.
This patch changes the function signature of all related hash functions
to return an integer and handles or propagates this return value at
all call sites.
Signed-off-by: Craig Gallek <kraig@google.com>
Commands run in a vrf context are not failing as expected on a route lookup:
root@kenny:~# ip ro ls table vrf-red
unreachable default
root@kenny:~# ping -I vrf-red -c1 -w1 10.100.1.254
ping: Warning: source address might be selected on device other than vrf-red.
PING 10.100.1.254 (10.100.1.254) from 0.0.0.0 vrf-red: 56(84) bytes of data.
--- 10.100.1.254 ping statistics ---
2 packets transmitted, 0 received, 100% packet loss, time 999ms
Since the vrf table does not have a route for 10.100.1.254 the ping
should have failed. The saddr lookup causes a full VRF table lookup.
Propogating a lookup failure to the user allows the command to fail as
expected:
connect: No route to host
Sending ICMP packets with raw sockets ends up in the SNMP counters
logging the type as the first byte of the IPv4 header rather than
the ICMP header. This is fixed by adding the IP Header Length to
the casting into a icmphdr struct.
Signed-off-by: Ben Cartwright-Cox <ben@benjojo.co.uk>
Replace dst_output_okfn with dst_output
ping originated on box through a VRF device is showing up in tcpdump
without a source address:
$ tcpdump -n -i vrf-blue
08:58:33.311303 IP 0.0.0.0 > 10.2.2.254: ICMP echo request, id 2834, seq 1, length 64
08:58:33.311562 IP 10.2.2.254 > 10.2.2.2: ICMP echo reply, id 2834, seq 1, length 64
Add the call to l3mdev_get_saddr to raw_sendmsg.
This is immediately motivated by the bridge code that chains functions that
call into netfilter. Without passing net into the okfns the bridge code would
need to guess about the best expression for the network namespace to process
packets in.
As net is frequently one of the first things computed in continuation functions
after netfilter has done it's job passing in the desired network namespace is in
many cases a code simplification.
To support this change the function dst_output_okfn is introduced to
simplify passing dst_output as an okfn. For the moment dst_output_okfn
just silently drops the struct net.
Pass a network namespace parameter into the netfilter hooks. At the
call site of the netfilter hooks the path a packet is taking through
the network stack is well known which allows the network namespace to
be easily and reliabily.
This allows the replacement of magic code like
"dev_net(state->in?:state->out)" that appears at the start of most
netfilter hooks with "state->net".
In almost all cases the network namespace passed in is derived
from the first network device passed in, guaranteeing those
paths will not see any changes in practice.
The exceptions are:
xfrm/xfrm_output.c:xfrm_output_resume() xs_net(skb_dst(skb)->xfrm)
ipvs/ip_vs_xmit.c:ip_vs_nat_send_or_cont() ip_vs_conn_net(cp)
ipvs/ip_vs_xmit.c:ip_vs_send_or_cont() ip_vs_conn_net(cp)
ipv4/raw.c:raw_send_hdrinc() sock_net(sk)
ipv6/ip6_output.c:ip6_xmit() sock_net(sk)
ipv6/ndisc.c:ndisc_send_skb() dev_net(skb->dev) not dev_net(dst->dev)
ipv6/raw.c:raw6_send_hdrinc() sock_net(sk)
br_netfilter_hooks.c:br_nf_pre_routing_finish() dev_net(skb->dev) before skb->dev is set to nf_bridge->physindev
In all cases these exceptions seem to be a better expression for the
network namespace the packet is being processed in then the historic
"dev_net(in?in:out)". I am documenting them in case something odd
pops up and someone starts trying to track down what happened.
Add a sock paramter to dst_output making dst_output_sk superfluous.
Add a skb->sk parameter to all of the callers of dst_output
Have the callers of dst_output_sk call dst_output.
Al Viro says:
netdev-related stuff in vfs.git
There are several commits sitting in vfs.git that probably ought to go in
via net-next.git. First of all, there's merge with vfs.git#iocb - that's
Christoph's aio rework, which has triggered conflicts with the ->sendmsg()
and ->recvmsg() patches a while ago. It's not so much Christoph's stuff
that ought to be in net-next, as (pretty simple) conflict resolution on merge.
The next chunk is switch to {compat_,}import_iovec/import_single_range - new
safer primitives for initializing iov_iter. The primitives themselves come
from vfs/git#iov_iter (and they are used quite a lot in vfs part of queue),
conversion of net/socket.c syscalls belongs in net-next, IMO. Next there's
afs and rxrpc stuff from dhowells. And then there's sanitizing kernel_sendmsg
et.al. + missing inlined helper for "how much data is left in msg->msg_iter" -
this stuff is used in e.g. cifs stuff, but it belongs in net-next.
That pile is pullable from
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs.git for-davem
I'll post the individual patches in there in followups; could you take a look
and tell if everything in there is OK with you?
trivial conflict in net/socket.c and non-trivial one in crypto -
that one had evaded aio_complete() removal.
On the output paths in particular, we have to sometimes deal with two
socket contexts. First, and usually skb->sk, is the local socket that
generated the frame.
And second, is potentially the socket used to control a tunneling
socket, such as one the encapsulates using UDP.
We do not want to disassociate skb->sk when encapsulating in order
to fix this, because that would break socket memory accounting.
The most extreme case where this can cause huge problems is an
AF_PACKET socket transmitting over a vxlan device. We hit code
paths doing checks that assume they are dealing with an ipv4
socket, but are actually operating upon the AF_PACKET one.
The ipv4 code uses a mixture of coding styles. In some instances check
for non-NULL pointer is done as x != NULL and sometimes as x. x is
preferred according to checkpatch and this patch makes the code
consistent by adopting the latter form.
No changes detected by objdiff.
Signed-off-by: Ian Morris <ipm@chirality.org.uk>
for NULL pointer is done as x == NULL and sometimes as !x. !x is
struct kiocb now is a generic I/O container, so move it to fs.h.
Also do a #include diet for aio.h while we're at it.
As namespaces are sometimes used with overlapping ip address ranges,
we should also use the namespace as input to the hash to select the ip
fragmentation counter bucket.
Cc: Eric Dumazet <edumazet@google.com>
Cc: Flavio Leitner <fbl@redhat.com>
After TIPC doesn't depend on iocb argument in its internal
implementations of sendmsg() and recvmsg() hooks defined in proto
structure, no any user is using iocb argument in them at all now.
Then we can drop the redundant iocb argument completely from kinds of
implementations of both sendmsg() and recvmsg() in the entire
networking stack.
Suggested-by: Al Viro <viro@ZenIV.linux.org.uk>
Signed-off-by: Ying Xue <ying.xue@windriver.com>
That takes care of the majority of ->sendmsg() instances - most of them
via memcpy_to_msg() or assorted getfrag() callbacks. One place where we
still keep memcpy_fromiovecend() is tipc - there we potentially read the
same data over and over; separate patch, that...
Switch from passing msg->iov_iter.iov to passing msg itself
Note that the code _using_ ->msg_iter at that point will be very
unhappy with anything other than unshifted iovec-backed iov_iter.
We still need to convert users to proper primitives.
we'll want access to ->msg_iter
Ever since raw_probe_proto_opt was added it had the problem of
causing the user iov to be read twice, once during the probe for
the protocol header and once again in ip_append_data.
This is a potential security problem since it means that whatever
we're probing may be invalid. This patch plugs the hole by
firstly advancing the iov so we don't read the same spot again,
and secondly saving what we read the first time around for use
by ip_append_data.
The function raw_probe_proto_opt tries to extract the first two
bytes from the user input in order to seed the IPsec lookup for
ICMP packets. In doing so it's processing iovec by hand and
overcomplicating things.
This patch replaces the manual iovec processing with a call to
memcpy_fromiovecend.
This encapsulates all of the skb_copy_datagram_iovec() callers
with call argument signature "skb, offset, msghdr->msg_iov, length".
When we move to iov_iters in the networking, the iov_iter object will
sit in the msghdr.
Having a helper like this means there will be less places to touch
during that transformation.
Based upon descriptions and patch from Al Viro.
Currently, although IP_MULTICAST_ALL and IP_MSFILTER ioctl calls succeed on
raw sockets, there is no code to implement the functionality on received
packets; it is only implemented for UDP sockets. The raw(7) man page states:
"In addition, all ip(7) IPPROTO_IP socket options valid for datagram sockets
are supported", which implies these ioctls should work on raw sockets.
To fix this, add a call to ip_mc_sf_allow on raw sockets.
This should not break any existing code, since the current position of
not calling ip_mc_sf_filter makes it behave as if neither the IP_MULTICAST_ALL
nor the IP_MSFILTER ioctl had been called. Adding the call to ip_mc_sf_allow
will therefore maintain the current behaviour so long as IP_MULTICAST_ALL and
IP_MSFILTER ioctls are not called. Any code that currently is calling
IP_MULTICAST_ALL or IP_MSFILTER ioctls on raw sockets presumably is wanting
the filter to be applied, although no filtering will currently be occurring.
Signed-off-by: Quentin Armitage <quentin@armitage.org.uk>
Add SO_TIMESTAMPING to sockets of type PF_INET[6]/SOCK_RAW:
Add the necessary sock_tx_timestamp calls to the datapath for RAW
sockets (ping sockets already had these calls).
Fix the IP output path to pass the timestamp flags on the first
fragment also for these sockets. The existing code relies on
transhdrlen != 0 to indicate a first fragment. For these sockets,
that assumption does not hold.
This fixes http://bugzilla.kernel.org/show_bug.cgi?id=77221
Tested SOCK_RAW on IPv4 and IPv6, not PING.
Signed-off-by: Willem de Bruijn <willemb@google.com>
Acked-by: Richard Cochran <richardcochran@gmail.com>
Ideally, we would need to generate IP ID using a per destination IP
generator.
linux kernels used inet_peer cache for this purpose, but this had a huge
cost on servers disabling MTU discovery.
1) each inet_peer struct consumes 192 bytes
2) inetpeer cache uses a binary tree of inet_peer structs,
with a nominal size of ~66000 elements under load.
3) lookups in this tree are hitting a lot of cache lines, as tree depth
is about 20.
4) If server deals with many tcp flows, we have a high probability of
not finding the inet_peer, allocating a fresh one, inserting it in
the tree with same initial ip_id_count, (cf secure_ip_id())
5) We garbage collect inet_peer aggressively.
IP ID generation do not have to be 'perfect'
Goal is trying to avoid duplicates in a short period of time,
so that reassembly units have a chance to complete reassembly of
fragments belonging to one message before receiving other fragments
with a recycled ID.
We simply use an array of generators, and a Jenkin hash using the dst IP
as a key.
ipv6_select_ident() is put back into net/ipv6/ip6_output.c where it
belongs (it is only used from this file)
secure_ip_id() and secure_ipv6_id() no longer are needed.
Rename ip_select_ident_more() to ip_select_ident_segs() to avoid
unnecessary decrement/increment of the number of segments.
In case we decide in udp6_sendmsg to send the packet down the ipv4
udp_sendmsg path because the destination is either of family AF_INET or
the destination is an ipv4 mapped ipv6 address, we don't honor the
maybe specified ipv4 mapped ipv6 address in IPV6_PKTINFO.
We simply can check for this option in ip_cmsg_send because no calls to
ipv6 module functions are needed to do so.
Reported-by: Gert Doering <gert@space.net>
Cc: Tore Anderson <tore@fud.no>
This is a follow-up patch to f3d3342602f8bc ("net: rework recvmsg
handler msg_name and msg_namelen logic").
DECLARE_SOCKADDR validates that the structure we use for writing the
name information to is not larger than the buffer which is reserved
for msg->msg_name (which is 128 bytes). Also use DECLARE_SOCKADDR
consistently in sendmsg code paths.
Signed-off-by: Steffen Hurrle <steffen@hurrle.net>
Suggested-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
FLOWI_FLAG_CAN_SLEEP was used to notify xfrm about the posibility
to sleep until the needed states are resolved. This code is gone,
so FLOWI_FLAG_CAN_SLEEP is not needed anymore.
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
functions
Commit bceaa90240b6019ed73b49965eac7d167610be69 ("inet: prevent leakage
of uninitialized memory to user in recv syscalls") conditionally updated
addr_len if the msg_name is written to. The recv_error and rxpmtu
functions relied on the recvmsg functions to set up addr_len before.
As this does not happen any more we have to pass addr_len to those
functions as well and set it to the size of the corresponding sockaddr
length.
This broke traceroute and such.
Fixes: bceaa90240b6 ("inet: prevent leakage of uninitialized memory to user in recv syscalls")
Reported-by: Brad Spengler <spender@grsecurity.net>
Reported-by: Tom Labanowski
Cc: mpb <mpb.mail@gmail.com>
Only update *addr_len when we actually fill in sockaddr, otherwise we
can return uninitialized memory from the stack to the caller in the
recvfrom, recvmmsg and recvmsg syscalls. Drop the the (addr_len == NULL)
checks because we only get called with a valid addr_len pointer either
from sock_common_recvmsg or inet_recvmsg.
If a blocking read waits on a socket which is concurrently shut down we
now return zero and set msg_msgnamelen to 0.
Reported-by: mpb <mpb.mail@gmail.com>
Suggested-by: Eric Dumazet <eric.dumazet@gmail.com>
The since the removal of the routing cache computing
fib_compute_spec_dst() does a fib_table lookup for each UDP multicast
packet received. This has introduced a performance regression for some
UDP workloads.
This change skips populating the packet info for sockets that do not have
IP_PKTINFO set.
Benchmark results from a netperf UDP_RR test:
Before 89789.68 transactions/s
After 90587.62 transactions/s
Benchmark results from a fio 1 byte UDP multicast pingpong test
(Multicast one way unicast response):
Before 12.63us RTT
After 12.48us RTT
Signed-off-by: Shawn Bohrer <sbohrer@rgmadvisors.com>
drivers/net/ethernet/emulex/benet/be.h
drivers/net/usb/qmi_wwan.c
drivers/net/wireless/brcm80211/brcmfmac/dhd_bus.h
include/net/netfilter/nf_conntrack_synproxy.h
include/net/secure_seq.h
The conflicts are of two varieties:
1) Conflicts with Joe Perches's 'extern' removal from header file
function declarations. Usually it's an argument signature change
or a function being added/removed. The resolutions are trivial.
2) Some overlapping changes in qmi_wwan.c and be.h, one commit adds
a new value, another changes an existing value. That sort of
thing.
If IP_TOS or IP_TTL are specified as ancillary data, then sendmsg() sends out
packets with the specified TTL or TOS overriding the socket values specified
with the traditional setsockopt().
The struct inet_cork stores the values of TOS, TTL and priority that are
passed through the struct ipcm_cookie. If there are user-specified TOS
(tos != -1) or TTL (ttl != 0) in the struct ipcm_cookie, these values are
used to override the per-socket values. In case of TOS also the priority
is changed accordingly.
Two helper functions get_rttos and get_rtconn_flags are defined to take
into account the presence of a user specified TOS value when computing
RT_TOS and RT_CONN_FLAGS.
Signed-off-by: Francesco Fusco <ffusco@redhat.com>
Redirect isn't an error condition, it should leave
the error handler without touching the socket.
Signed-off-by: Duan Jiong <duanj.fnst@cn.fujitsu.com>
If local fragmentation is allowed, then ip_select_ident() and
ip_select_ident_more() need to generate unique IDs to ensure
correct defragmentation on the peer.
For example, if IPsec (tunnel mode) has to encrypt large skbs
that have local_df bit set, then all IP fragments that belonged
to different ESP datagrams would have used the same identificator.
If one of these IP fragments would get lost or reordered, then
peer could possibly stitch together wrong IP fragments that did
not belong to the same datagram. This would lead to a packet loss
or data corruption.
Signed-off-by: Ansis Atteka <aatteka@nicira.com>
drivers/net/ethernet/stmicro/stmmac/stmmac_platform.c
net/bridge/br_multicast.c
net/ipv6/sit.c
The conflicts were minor:
1) sit.c changes overlap with change to ip_tunnel_xmit() signature.
2) br_multicast.c had an overlap between computing max_delay using
msecs_to_jiffies and turning MLDV2_MRC() into an inline function
with a name using lowercase instead of uppercase letters.
3) stmmac had two overlapping changes, one which conditionally allocated
and hooked up a dma_cfg based upon the presence of the pbl OF property,
and another one handling store-and-forward DMA made. The latter of
which should not go into the new of_find_property() basic block.
ipv4: raw_sendmsg: don't use header's destination address
A sendto() regression was bisected and found to start with commit
f8126f1d5136be1 (ipv4: Adjust semantics of rt->rt_gateway.)
The problem is that it tries to ARP-lookup the constructed packet's
destination address rather than the explicitly provided address.
Fix this using FLOWI_FLAG_KNOWN_NH so that given nexthop is used.
cf. commit 2ad5b9e4bd314fc685086b99e90e5de3bc59e26b
Reported-by: Chris Clark <chris.clark@alcatel-lucent.com>
Bisected-by: Chris Clark <chris.clark@alcatel-lucent.com>
Tested-by: Chris Clark <chris.clark@alcatel-lucent.com>
Suggested-by: Julian Anastasov <ja@ssi.bg>
Signed-off-by: Chris Clark <chris.clark@alcatel-lucent.com>
UIDs are printed in the proc_fs as signed int, whereas
they are unsigned int.
I'm not sure why, but the hlist for each entry iterators were conceived
list_for_each_entry(pos, head, member)
The hlist ones were greedy and wanted an extra parameter:
hlist_for_each_entry(tpos, pos, head, member)
Why did they need an extra pos parameter? I'm not quite sure. Not only
they don't really need it, it also prevents the iterator from looking
exactly like the list iterator, which is unfortunate.
Besides the semantic patch, there was some manual work required:
- Fix up the actual hlist iterators in linux/list.h
- Fix up the declaration of other iterators based on the hlist ones.
- A very small amount of places were using the 'node' parameter, this
was modified to use 'obj->member' instead.
- Coccinelle didn't handle the hlist_for_each_entry_safe iterator
properly, so those had to be fixed up manually.
The semantic patch which is mostly the work of Peter Senna Tschudin is here:
iterator name hlist_for_each_entry, hlist_for_each_entry_continue, hlist_for_each_entry_from, hlist_for_each_entry_rcu, hlist_for_each_entry_rcu_bh, hlist_for_each_entry_continue_rcu_bh, for_each_busy_worker, ax25_uid_for_each, ax25_for_each, inet_bind_bucket_for_each, sctp_for_each_hentry, sk_for_each, sk_for_each_rcu, sk_for_each_from, sk_for_each_safe, sk_for_each_bound, hlist_for_each_entry_safe, hlist_for_each_entry_continue_rcu, nr_neigh_for_each, nr_neigh_for_each_safe, nr_node_for_each, nr_node_for_each_safe, for_each_gfn_indirect_valid_sp, for_each_gfn_sp, for_each_host;
type T;
expression a,c,d,e;
identifier b;
statement S;
-T b;
<+... when != b
hlist_for_each_entry(a,
- b,
c, d) S
hlist_for_each_entry_continue(a,
- b,
c) S
hlist_for_each_entry_from(a,
- b,
c) S
hlist_for_each_entry_rcu(a,
- b,
c, d) S
hlist_for_each_entry_rcu_bh(a,
- b,
c, d) S
hlist_for_each_entry_continue_rcu_bh(a,
- b,
c) S
for_each_busy_worker(a, c,
- b,
d) S
ax25_uid_for_each(a,
- b,
c) S
ax25_for_each(a,
- b,
c) S
inet_bind_bucket_for_each(a,
- b,
c) S
sctp_for_each_hentry(a,
- b,
c) S
sk_for_each(a,
- b,
c) S
sk_for_each_rcu(a,
- b,
c) S
sk_for_each_from
-(a, b)
+(a)
S
+ sk_for_each_from(a) S
sk_for_each_safe(a,
- b,
c, d) S
sk_for_each_bound(a,
- b,
c) S
hlist_for_each_entry_safe(a,
- b,
c, d, e) S
hlist_for_each_entry_continue_rcu(a,
- b,
c) S
nr_neigh_for_each(a,
- b,
c) S
nr_neigh_for_each_safe(a,
- b,
c, d) S
nr_node_for_each(a,
- b,
c) S
nr_node_for_each_safe(a,
- b,
c, d) S
- for_each_gfn_sp(a, c, d, b) S
+ for_each_gfn_sp(a, c, d) S
- for_each_gfn_indirect_valid_sp(a, c, d, b) S
+ for_each_gfn_indirect_valid_sp(a, c, d) S
for_each_host(a,
- b,
c) S
for_each_host_safe(a,
- b,
c, d) S
for_each_mesh_entry(a,
- b,
c, d) S
[akpm@linux-foundation.org: drop bogus change from net/ipv4/raw.c]
[akpm@linux-foundation.org: drop bogus hunk from net/ipv6/raw.c]
[akpm@linux-foundation.org: checkpatch fixes]
[akpm@linux-foundation.org: fix warnings]
[akpm@linux-foudnation.org: redo intrusive kvm changes]
Tested-by: Peter Senna Tschudin <peter.senna@gmail.com>
Cc: Wu Fengguang <fengguang.wu@intel.com>
Cc: Marcelo Tosatti <mtosatti@redhat.com>
Cc: Gleb Natapov <gleb@redhat.com>
proc_net_remove is only used to remove proc entries
that under /proc/net,it's not a general function for
removing proc entries of netns. if we want to remove
some proc entries which under /proc/net/stat/, we still
need to call remove_proc_entry.
this patch use remove_proc_entry to replace proc_net_remove.
we can remove proc_net_remove after this patch.
Signed-off-by: Gao feng <gaofeng@cn.fujitsu.com>
