[ Upstream commit f0e3d0689da401f7d1981c2777a714ba295ea5ff ]
Using a gcc 4.4.3, warnings are emitted for a possibly uninitialized use
of ecn_ok.
This can happen if cookie_check_timestamp() returns due to not having
seen a timestamp. Defaulting to ecn off seems like a reasonable thing
to do in this case, so initialized ecn_ok to false.
Signed-off-by: Mike Waychison <mikew@google.com>
We lack proper synchronization to manipulate inet->opt ip_options
Problem is ip_make_skb() calls ip_setup_cork() and
ip_setup_cork() possibly makes a copy of ipc->opt (struct ip_options),
without any protection against another thread manipulating inet->opt.
Another thread can change inet->opt pointer and free old one under us.
Use RCU to protect inet->opt (changed to inet->inet_opt).
Instead of handling atomic refcounts, just copy ip_options when
necessary, to avoid cache line dirtying.
We cant insert an rcu_head in struct ip_options since its included in
skb->cb[], so this patch is large because I had to introduce a new
ip_options_rcu structure.
Cc: Herbert Xu <herbert@gondor.apana.org.au>
Create two sets of port member accessors, one set prefixed by fl4_*
and the other prefixed by fl6_*
This will let us to create AF optimal flow instances.
It will work because every context in which we access the ports,
we have to be fully aware of which AF the flowi is anyways.
I intend to turn struct flowi into a union of AF specific flowi
structs. There will be a common structure that each variant includes
first, much like struct sock_common.
This is the first step to move in that direction.
Instead of on the stack.
Use the macros defined for the members of flowi to clean the code up.
Signed-off-by: Changli Gao <xiaosuo@gmail.com>
Allows use of ECN when syncookies are in effect by encoding ecn_ok
into the syn-ack tcp timestamp.
While at it, remove a uneeded #ifdef CONFIG_SYN_COOKIES.
With CONFIG_SYN_COOKIES=nm want_cookie is ifdef'd to 0 and gcc
removes the "if (0)".
As pointed out by Fernando Gont there is no need to encode rcv_wscale
into the cookie.
We did not use the restored rcv_wscale anyway; it is recomputed
via tcp_select_initial_window().
Thus we can save 4 bits in the ts option space by removing rcv_wscale.
In case window scaling was not supported, we set the (invalid) wscale
value 0xf.
Discard the ACK if we find options that do not match current sysctl
settings.
Previously it was possible to create a connection with sack, wscale,
etc. enabled even if the feature was disabled via sysctl.
Also remove an unneeded call to tcp_sack_reset() in
cookie_check_timestamp: Both call sites (cookie_v4_check,
cookie_v6_check) zero "struct tcp_options_received", hand it to
tcp_parse_options() (which does not change tcp_opt->num_sacks/dsack)
and then call cookie_check_timestamp().
Even if num_sacks/dsacks were changed, the structure is allocated on
the stack and after cookie_check_timestamp returns only a few selected
members are copied to the inet_request_sock.
remove useless union keyword in rtable, rt6_info and dn_route.
Since there is only one member in a union, the union keyword isn't useful.
drivers/net/sfc/net_driver.h
drivers/net/sfc/siena.c
- ipv6 msstab: account for ipv6 header size
- ipv4 msstab: add mss for Jumbograms.
caller: if (!th->rst && !th->syn && th->ack)
callee: if (!th->ack)
make the caller only check for !syn (common for 3whs), and move
the !rst / ack test to the callee.
Its better to make a route lookup in appropriate namespace.
Add rtnetlink init_rcvwnd to set the TCP initial receive window size
advertised by passive and active TCP connections.
The current Linux TCP implementation limits the advertised TCP initial
receive window to the one prescribed by slow start. For short lived
TCP connections used for transaction type of traffic (i.e. http
requests), bounding the advertised TCP initial receive window results
in increased latency to complete the transaction.
Support for setting initial congestion window is already supported
using rtnetlink init_cwnd, but the feature is useless without the
ability to set a larger TCP initial receive window.
The rtnetlink init_rcvwnd allows increasing the TCP initial receive
window, allowing TCP connection to advertise larger TCP receive window
than the ones bounded by slow start.
Signed-off-by: Laurent Chavey <chavey@google.com>
It creates a regression, triggering badness for SYN_RECV
sockets, for example:
[19148.022102] Badness at net/ipv4/inet_connection_sock.c:293
[19148.022570] NIP: c02a0914 LR: c02a0904 CTR: 00000000
[19148.023035] REGS: eeecbd30 TRAP: 0700 Not tainted (2.6.32)
[19148.023496] MSR: 00029032 <EE,ME,CE,IR,DR> CR: 24002442 XER: 00000000
[19148.024012] TASK = eee9a820[1756] 'privoxy' THREAD: eeeca000
This is likely caused by the change in the 'estab' parameter
passed to tcp_parse_options() when invoked by the functions
in net/ipv4/tcp_minisocks.c
But even if that is fixed, the ->conn_request() changes made in
this patch series is fundamentally wrong. They try to use the
listening socket's 'dst' to probe the route settings. The
listening socket doesn't even have a route, and you can't
get the right route (the child request one) until much later
after we setup all of the state, and it must be done by hand.
This stuff really isn't ready, so the best thing to do is a
full revert. This reverts the following commits:
f55017a93f1a74d50244b1254b9a2bd7ac9bbf7d
022c3f7d82f0f1c68018696f2f027b87b9bb45c2
1aba721eba1d84a2defce45b950272cee1e6c72a
cda42ebd67ee5fdf09d7057b5a4584d36fe8a335
345cda2fd695534be5a4494f1b59da9daed33663
dc343475ed062e13fc260acccaab91d7d80fd5b2
05eaade2782fb0c90d3034fd7a7d5a16266182bb
6a2a2d6bf8581216e08be15fcb563cfd6c430e1e
Parse incoming TCP_COOKIE option(s).
Calculate <SYN,ACK> TCP_COOKIE option.
Send optional <SYN,ACK> data.
This is a significantly revised implementation of an earlier (year-old)
patch that no longer applies cleanly, with permission of the original
author (Adam Langley):
http://thread.gmane.org/gmane.linux.network/102586
Requires:
TCPCT part 1a: add request_values parameter for sending SYNACK
TCPCT part 1b: generate Responder Cookie secret
TCPCT part 1c: sysctl_tcp_cookie_size, socket option TCP_COOKIE_TRANSACTIONS
TCPCT part 1d: define TCP cookie option, extend existing struct's
TCPCT part 1e: implement socket option TCP_COOKIE_TRANSACTIONS
TCPCT part 1f: Initiator Cookie => Responder
Signed-off-by: William.Allen.Simpson@gmail.com
We need tcp_parse_options to be aware of dst_entry to
take into account per dst_entry TCP options settings
Signed-off-by: Gilad Ben-Yossef <gilad@codefidence.com>
Sigend-off-by: Ori Finkelman <ori@comsleep.com>
Sigend-off-by: Yony Amit <yony@comsleep.com>
Add support for route lookup using sk_mark on IPv4 listening sockets.
Signed-off-by: Atis Elsts <atis@mikrotik.com>
Percpu variable definition is about to be updated such that all percpu
symbols including the static ones must be unique. Update percpu
variable definitions accordingly.
* as,cfq: rename ioc_count uniquely
* cpufreq: rename cpu_dbs_info uniquely
* xen: move nesting_count out of xen_evtchn_do_upcall() and rename it
* mm: move ratelimits out of balance_dirty_pages_ratelimited_nr() and
rename it
* ipv4,6: rename cookie_scratch uniquely
* x86 perf_counter: rename prev_left to pmc_prev_left, irq_entry to
pmc_irq_entry and nmi_entry to pmc_nmi_entry
* perf_counter: rename disable_count to perf_disable_count
* ftrace: rename test_event_disable to ftrace_test_event_disable
* kmemleak: rename test_pointer to kmemleak_test_pointer
* mce: rename next_interval to mce_next_interval
[ Impact: percpu usage cleanups, no duplicate static percpu var names ]
Reviewed-by: Christoph Lameter <cl@linux-foundation.org>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: Jens Axboe <jens.axboe@oracle.com>
Cc: Dave Jones <davej@redhat.com>
Cc: Jeremy Fitzhardinge <jeremy@xensource.com>
Cc: linux-mm <linux-mm@kvack.org>
Cc: Steven Rostedt <srostedt@redhat.com>
Cc: Li Zefan <lizf@cn.fujitsu.com>
Currently, the following three different ways to define percpu arrays
are in use.
1. DEFINE_PER_CPU(elem_type[array_len], array_name);
2. DEFINE_PER_CPU(elem_type, array_name[array_len]);
3. DEFINE_PER_CPU(elem_type, array_name)[array_len];
Unify to #1 which correctly separates the roles of the two parameters
and thus allows more flexibility in the way percpu variables are
defined.
[ Impact: cleanup ]
Cc: linux-mm@kvack.org
last_synq_overflow eats 4 or 8 bytes in struct tcp_sock, even
though it is only used when a listening sockets syn queue
is full.
We can (ab)use rx_opt.ts_recent_stamp to store the same information;
it is not used otherwise as long as a socket is in listen state.
Move linger2 around to avoid splitting struct mtu_probe
across cacheline boundary on 32 bit arches.
The current placement of the security_inet_conn_request() hooks do not allow
individual LSMs to override the IP options of the connection's request_sock.
This is a problem as both SELinux and Smack have the ability to use labeled
networking protocols which make use of IP options to carry security attributes
and the inability to set the IP options at the start of the TCP handshake is
problematic.
This patch moves the IPv4 security_inet_conn_request() hooks past the code
where the request_sock's IP options are set/reset so that the LSM can safely
manipulate the IP options as needed. This patch intentionally does not change
the related IPv6 hooks as IPv6 based labeling protocols which use IPv6 options
are not currently implemented, once they are we will have a better idea of
the correct placement for the IPv6 hooks.
Signed-off-by: Paul Moore <paul.moore@hp.com>
Signed-off-by: James Morris <jmorris@namei.org>
Current TCP code relies on the local port of the listening socket
being the same as the destination address of the incoming
connection. Port redirection used by many transparent proxying
techniques obviously breaks this, so we have to store the original
destination port address.
This patch extends struct inet_request_sock and stores the incoming
destination port value there. It also modifies the handshake code to
use that value as the source port when sending reply packets.
Signed-off-by: KOVACS Krisztian <hidden@sch.bme.hu>
Netfilter's ip_route_me_harder() tries to re-route packets either
generated or re-routed by Netfilter. This patch changes
ip_route_me_harder() to handle packets from non-locally-bound sockets
with IP_TRANSPARENT set as local and to set the appropriate flowi
flags when re-doing the routing lookup.
ecn_ok is not initialized when a connection is established by cookies.
The cookie syn-ack never sets ECN, so ecn_ok must be set to 0.
Spotted using ns-3/network simulation cradle simulator and valgrind.
Signed-off-by: Pavel Emelyanov <xemul@openvz.org>
drivers/net/smc911x.c
This patch removes CVS keywords that weren't updated for a long time
from comments.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
Wei Yongjun noticed that we may call reqsk_free on request sock objects where
the opt fields may not be initialized, fix it by introducing inet_reqsk_alloc
where we initialize ->opt to NULL and set ->pktopts to NULL in
inet6_reqsk_alloc.
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
Allow the use of SACK and window scaling when syncookies are used
and the client supports tcp timestamps. Options are encoded into
the timestamp sent in the syn-ack and restored from the timestamp
echo when the ack is received.
Based on earlier work by Glenn Griffin.
This patch avoids increasing the size of structs by encoding TCP
options into the least significant bits of the timestamp and
by not using any 'timestamp offset'.
The downside is that the timestamp sent in the packet after the synack
will increase by several seconds.
changes since v1:
don't duplicate timestamp echo decoding function, put it into ipv4/syncookie.c
and have ipv6/syncookies.c use it.
Feedback from Glenn Griffin: fix line indented with spaces, kill redundant if ()
Reviewed-by: Hagen Paul Pfeifer <hagen@jauu.net>
the first u32 copied from syncookie_secret is overwritten by the
minute-counter four lines below. After adjusting the destination
address, the size of syncookie_secret can be reduced accordingly.
AFAICS, the only other user of syncookie_secret[] is the ipv6
syncookie support. Because ipv6 syncookies only grab 44 bytes from
syncookie_secret[], this shouldn't affect them in any way.
With fixes from Glenn Griffin.
Acked-by: Glenn Griffin <ggriffin.kernel@gmail.com>
Updated to incorporate Eric's suggestion of using a per cpu buffer
rather than allocating on the stack. Just a two line change, but will
resend in it's entirety.
Signed-off-by: Glenn Griffin <ggriffin.kernel@gmail.com>
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
400 bytes allocated on stack might be a litle bit too much. Using a
per_cpu var is more friendly.
Signed-off-by: Eric Dumazet <dada1@cosmosbay.com>
Needed to propagate it down to the ip_route_output_flow.
Signed-off-by: Denis V. Lunev <den@openvz.org>
This automatically labels the TCP, Unix stream, and dccp child sockets
as well as openreqs to be at the same MLS level as the peer. This will
result in the selection of appropriately labeled IPSec Security
Associations.
This also uses the sock's sid (as opposed to the isec sid) in SELinux
enforcement of secmark in rcv_skb and postroute_last hooks.
Signed-off-by: Venkat Yekkirala <vyekkirala@TrustedCS.com>
This labels the flows that could utilize IPSec xfrms at the points the
flows are defined so that IPSec policy and SAs at the right label can
be used.
The following protos are currently not handled, but they should
continue to be able to use single-labeled IPSec like they currently
do.
ipmr
ip_gre
ipip
igmp
sit
sctp
ip6_tunnel (IPv6 over IPv6 tunnel device)
decnet
And move it to struct inet_connection_sock. DCCP will use it in the
upcoming changesets.
Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
Of this type, mostly:
CHECK net/ipv6/netfilter.c
net/ipv6/netfilter.c:96:12: warning: symbol 'ipv6_netfilter_init' was not declared. Should it be static?
net/ipv6/netfilter.c:101:6: warning: symbol 'ipv6_netfilter_fini' was not declared. Should it be static?
This creates struct inet_connection_sock, moving members out of struct
tcp_sock that are shareable with other INET connection oriented
protocols, such as DCCP, that in my private tree already uses most of
these members.
The functions that operate on these members were renamed, using a
inet_csk_ prefix while not being moved yet to a new file, so as to
ease the review of these changes.
Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net>
Ok, this one just renames some stuff to have a better namespace and to
dissassociate it from TCP:
struct open_request -> struct request_sock
tcp_openreq_alloc -> reqsk_alloc
tcp_openreq_free -> reqsk_free
tcp_openreq_fastfree -> __reqsk_free
With this most of the infrastructure closely resembles a struct
sock methods subset.
Kept this first changeset minimal, without changing existing names to
ease peer review.
Basicaly tcp_openreq_alloc now receives the or_calltable, that in turn
has two new members:
->slab, that replaces tcp_openreq_cachep
->obj_size, to inform the size of the openreq descendant for
a specific protocol
The protocol specific fields in struct open_request were moved to a
class hierarchy, with the things that are common to all connection
oriented PF_INET protocols in struct inet_request_sock, the TCP ones
in tcp_request_sock, that is an inet_request_sock, that is an
open_request.
I.e. this uses the same approach used for the struct sock class
hierarchy, with sk_prot indicating if the protocol wants to use the
open_request infrastructure by filling in sk_prot->rsk_prot with an
or_calltable.
Results? Performance is improved and TCP v4 now uses only 64 bytes per
open request minisock, down from 96 without this patch :-)
Next changeset will rename some of the structs, fields and functions
mentioned above, struct or_calltable is way unclear, better name it
struct request_sock_ops, s/struct open_request/struct request_sock/g,
etc.
infrastructure for it.
Let it rip!
