path: root/net/ipv4/syncookies.c
2013-12-26ipv4: fix checkpatch error "space prohibited"Weilong Chen
Signed-off-by: Weilong Chen <chenweilong@huawei.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-10-19inet: split syncookie keys for ipv4 and ipv6 and initialize with ↵Hannes Frederic Sowa
net_get_random_once This patch splits the secret key for syncookies for ipv4 and ipv6 and initializes them with net_get_random_once. This change was the reason I did this series. I think the initialization of the syncookie_secret is way to early. Cc: Florian Westphal <fw@strlen.de> Cc: Eric Dumazet <edumazet@google.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-10-10inet: rename ir_loc_port to ir_numEric Dumazet
In commit 634fb979e8f ("inet: includes a sock_common in request_sock") I forgot that the two ports in sock_common do not have same byte order : skc_dport is __be16 (network order), but skc_num is __u16 (host order) So sparse complains because ir_loc_port (mapped into skc_num) is considered as __u16 while it should be __be16 Let rename ir_loc_port to ireq->ir_num (analogy with inet->inet_num), and perform appropriate htons/ntohs conversions. Signed-off-by: Eric Dumazet <edumazet@google.com> Reported-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-10-10inet: includes a sock_common in request_sockEric Dumazet
TCP listener refactoring, part 5 : We want to be able to insert request sockets (SYN_RECV) into main ehash table instead of the per listener hash table to allow RCU lookups and remove listener lock contention. This patch includes the needed struct sock_common in front of struct request_sock This means there is no more inet6_request_sock IPv6 specific structure. Following inet_request_sock fields were renamed as they became macros to reference fields from struct sock_common. Prefix ir_ was chosen to avoid name collisions. loc_port -> ir_loc_port loc_addr -> ir_loc_addr rmt_addr -> ir_rmt_addr rmt_port -> ir_rmt_port iif -> ir_iif Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-09-24tcp: syncookies: reduce mss table to four valuesFlorian Westphal
Halve mss table size to make blind cookie guessing more difficult. This is sad since the tables were already small, but there is little alternative except perhaps adding more precise mss information in the tcp timestamp. Timestamps are unfortunately not ubiquitous. Guessing all possible cookie values still has 8-in 2**32 chance. Reported-by: Jakob Lell <jakob@jakoblell.com> Signed-off-by: Florian Westphal <fw@strlen.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-09-24tcp: syncookies: reduce cookie lifetime to 128 secondsFlorian Westphal
We currently accept cookies that were created less than 4 minutes ago (ie, cookies with counter delta 0-3). Combined with the 8 mss table values, this yields 32 possible values (out of 2**32) that will be valid. Reducing the lifetime to < 2 minutes halves the guessing chance while still providing a large enough period. While at it, get rid of jiffies value -- they overflow too quickly on 32 bit platforms. getnstimeofday is used to create a counter that increments every 64s. perf shows getnstimeofday cost is negible compared to sha_transform; normal tcp initial sequence number generation uses getnstimeofday, too. Reported-by: Jakob Lell <jakob@jakoblell.com> Signed-off-by: Florian Westphal <fw@strlen.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-08-28net: syncookies: export cookie_v4_init_sequence/cookie_v4_checkPatrick McHardy
Extract the local TCP stack independant parts of tcp_v4_init_sequence() and cookie_v4_check() and export them for use by the upcoming SYNPROXY target. Signed-off-by: Patrick McHardy <kaber@trash.net> Acked-by: David S. Miller <davem@davemloft.net> Tested-by: Martin Topholm <mph@one.com> Signed-off-by: Jesper Dangaard Brouer <brouer@redhat.com> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2013-04-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/ethernet/emulex/benet/be_main.c drivers/net/ethernet/intel/igb/igb_main.c drivers/net/wireless/brcm80211/brcmsmac/mac80211_if.c include/net/scm.h net/batman-adv/routing.c net/ipv4/tcp_input.c The e{uid,gid} --> {uid,gid} credentials fix conflicted with the cleanup in net-next to now pass cred structs around. The be2net driver had a bug fix in 'net' that overlapped with the VLAN interface changes by Patrick McHardy in net-next. An IGB conflict existed because in 'net' the build_skb() support was reverted, and in 'net-next' there was a comment style fix within that code. Several batman-adv conflicts were resolved by making sure that all calls to batadv_is_my_mac() are changed to have a new bat_priv first argument. Eric Dumazet's TS ECR fix in TCP in 'net' conflicted with the F-RTO rewrite in 'net-next', mostly overlapping changes. Thanks to Stephen Rothwell and Antonio Quartulli for help with several of these merge resolutions. Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-11tcp: incoming connections might use wrong route under synfloodDmitry Popov
There is a bug in cookie_v4_check (net/ipv4/syncookies.c): flowi4_init_output(&fl4, 0, sk->sk_mark, RT_CONN_FLAGS(sk), RT_SCOPE_UNIVERSE, IPPROTO_TCP, inet_sk_flowi_flags(sk), (opt && opt->srr) ? opt->faddr : ireq->rmt_addr, ireq->loc_addr, th->source, th->dest); Here we do not respect sk->sk_bound_dev_if, therefore wrong dst_entry may be taken. This dst_entry is used by new socket (get_cookie_sock -> tcp_v4_syn_recv_sock), so its packets may take the wrong path. Signed-off-by: Dmitry Popov <dp@highloadlab.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-17tcp: Remove TCPCTChristoph Paasch
TCPCT uses option-number 253, reserved for experimental use and should not be used in production environments. Further, TCPCT does not fully implement RFC 6013. As a nice side-effect, removing TCPCT increases TCP's performance for very short flows: Doing an apache-benchmark with -c 100 -n 100000, sending HTTP-requests for files of 1KB size. before this patch: average (among 7 runs) of 20845.5 Requests/Second after: average (among 7 runs) of 21403.6 Requests/Second Signed-off-by: Christoph Paasch <christoph.paasch@uclouvain.be> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-01-06tcp: make sysctl_tcp_ecn namespace awareHannes Frederic Sowa
As per suggestion from Eric Dumazet this patch makes tcp_ecn sysctl namespace aware. The reason behind this patch is to ease the testing of ecn problems on the internet and allows applications to tune their own use of ecn. Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: David Miller <davem@davemloft.net> Cc: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-03tcp: better retrans tracking for defer-acceptEric Dumazet
For passive TCP connections using TCP_DEFER_ACCEPT facility, we incorrectly increment req->retrans each time timeout triggers while no SYNACK is sent. SYNACK are not sent for TCP_DEFER_ACCEPT that were established (for which we received the ACK from client). Only the last SYNACK is sent so that we can receive again an ACK from client, to move the req into accept queue. We plan to change this later to avoid the useless retransmit (and potential problem as this SYNACK could be lost) TCP_INFO later gives wrong information to user, claiming imaginary retransmits. Decouple req->retrans field into two independent fields : num_retrans : number of retransmit num_timeout : number of timeouts num_timeout is the counter that is incremented at each timeout, regardless of actual SYNACK being sent or not, and used to compute the exponential timeout. Introduce inet_rtx_syn_ack() helper to increment num_retrans only if ->rtx_syn_ack() succeeded. Use inet_rtx_syn_ack() from tcp_check_req() to increment num_retrans when we re-send a SYNACK in answer to a (retransmitted) SYN. Prior to this patch, we were not counting these retransmits. Change tcp_v[46]_rtx_synack() to increment TCP_MIB_RETRANSSEGS only if a synack packet was successfully queued. Reported-by: Yuchung Cheng <ycheng@google.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Julian Anastasov <ja@ssi.bg> Cc: Vijay Subramanian <subramanian.vijay@gmail.com> Cc: Elliott Hughes <enh@google.com> Cc: Neal Cardwell <ncardwell@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-31tcp: TCP Fast Open Server - support TFO listenersJerry Chu
This patch builds on top of the previous patch to add the support for TFO listeners. This includes - 1. allocating, properly initializing, and managing the per listener fastopen_queue structure when TFO is enabled 2. changes to the inet_csk_accept code to support TFO. E.g., the request_sock can no longer be freed upon accept(), not until 3WHS finishes 3. allowing a TCP_SYN_RECV socket to properly poll() and sendmsg() if it's a TFO socket 4. properly closing a TFO listener, and a TFO socket before 3WHS finishes 5. supporting TCP_FASTOPEN socket option 6. modifying tcp_check_req() to use to check a TFO socket as well as request_sock 7. supporting TCP's TFO cookie option 8. adding a new SYN-ACK retransmit handler to use the timer directly off the TFO socket rather than the listener socket. Note that TFO server side will not retransmit anything other than SYN-ACK until the 3WHS is completed. The patch also contains an important function "reqsk_fastopen_remove()" to manage the somewhat complex relation between a listener, its request_sock, and the corresponding child socket. See the comment above the function for the detail. Signed-off-by: H.K. Jerry Chu <hkchu@google.com> Cc: Yuchung Cheng <ycheng@google.com> Cc: Neal Cardwell <ncardwell@google.com> Cc: Eric Dumazet <edumazet@google.com> Cc: Tom Herbert <therbert@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-19net-tcp: Fast Open baseYuchung Cheng
This patch impelements the common code for both the client and server. 1. TCP Fast Open option processing. Since Fast Open does not have an option number assigned by IANA yet, it shares the experiment option code 254 by implementing draft-ietf-tcpm-experimental-options with a 16 bits magic number 0xF989. This enables global experiments without clashing the scarce(2) experimental options available for TCP. When the draft status becomes standard (maybe), the client should switch to the new option number assigned while the server supports both numbers for transistion. 2. The new sysctl tcp_fastopen 3. A place holder init function Signed-off-by: Yuchung Cheng <ycheng@google.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-03-11tcp: fix syncookie regressionEric Dumazet
commit ea4fc0d619 (ipv4: Don't use rt->rt_{src,dst} in ip_queue_xmit()) added a serious regression on synflood handling. Simon Kirby discovered a successful connection was delayed by 20 seconds before being responsive. In my tests, I discovered that xmit frames were lost, and needed ~4 retransmits and a socket dst rebuild before being really sent. In case of syncookie initiated connection, we use a different path to initialize the socket dst, and inet->cork.fl.u.ip4 is left cleared. As ip_queue_xmit() now depends on inet flow being setup, fix this by copying the temp flowi4 we use in cookie_v4_check(). Reported-by: Simon Kirby <sim@netnation.com> Bisected-by: Simon Kirby <sim@netnation.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Tested-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-21tcp: Replace constants with #define macrosVijay Subramanian
to record the state of SACK/FACK and DSACK for better readability and maintenance. Signed-off-by: Vijay Subramanian <subramanian.vijay@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-10-31net: Add export.h for EXPORT_SYMBOL/THIS_MODULE to non-modulesPaul Gortmaker
These files are non modular, but need to export symbols using the macros now living in export.h -- call out the include so that things won't break when we remove the implicit presence of module.h from everywhere. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-21tcp: add const qualifiers where possibleEric Dumazet
Adding const qualifiers to pointers can ease code review, and spot some bugs. It might allow compiler to optimize code further. For example, is it legal to temporary write a null cksum into tcphdr in tcp_md5_hash_header() ? I am afraid a sniffer could catch the temporary null value... Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-10tcp: initialize variable ecn_ok in syncookies pathMike Waychison
Using a gcc 4.4.3, warnings are emitted for a possibly uninitialized use of ecn_ok. This can happen if cookie_check_timestamp() returns due to not having seen a timestamp. Defaulting to ecn off seems like a reasonable thing to do in this case, so initialized ecn_ok to false. Signed-off-by: Mike Waychison <mikew@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-08tcp: RFC2988bis + taking RTT sample from 3WHS for the passive open sideJerry Chu
This patch lowers the default initRTO from 3secs to 1sec per RFC2988bis. It falls back to 3secs if the SYN or SYN-ACK packet has been retransmitted, AND the TCP timestamp option is not on. It also adds support to take RTT sample during 3WHS on the passive open side, just like its active open counterpart, and uses it, if valid, to seed the initRTO for the data transmission phase. The patch also resets ssthresh to its initial default at the beginning of the data transmission phase, and reduces cwnd to 1 if there has been MORE THAN ONE retransmission during 3WHS per RFC5681. Signed-off-by: H.K. Jerry Chu <hkchu@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-28inet: add RCU protection to inet->optEric Dumazet
We lack proper synchronization to manipulate inet->opt ip_options Problem is ip_make_skb() calls ip_setup_cork() and ip_setup_cork() possibly makes a copy of ipc->opt (struct ip_options), without any protection against another thread manipulating inet->opt. Another thread can change inet->opt pointer and free old one under us. Use RCU to protect inet->opt (changed to inet->inet_opt). Instead of handling atomic refcounts, just copy ip_options when necessary, to avoid cache line dirtying. We cant insert an rcu_head in struct ip_options since its included in skb->cb[], so this patch is large because I had to introduce a new ip_options_rcu structure. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-31ipv4: Use flowi4_init_output() in cookie_v4_check()David S. Miller
2011-03-12net: Put fl4_* macros to struct flowi4 and use them again.David S. Miller
2011-03-12ipv4: Use flowi4 in public route lookup interfaces.David S. Miller
2011-03-12net: Make flowi ports AF dependent.David S. Miller
Create two sets of port member accessors, one set prefixed by fl4_* and the other prefixed by fl6_* This will let us to create AF optimal flow instances. It will work because every context in which we access the ports, we have to be fully aware of which AF the flowi is anyways. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-12net: Put flowi_* prefix on AF independent members of struct flowiDavid S. Miller
I intend to turn struct flowi into a union of AF specific flowi structs. There will be a common structure that each variant includes first, much like struct sock_common. This is the first step to move in that direction. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-02ipv4: Make output route lookup return rtable directly.David S. Miller
Instead of on the stack. Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-17net: use the macros defined for the members of flowiChangli Gao
Use the macros defined for the members of flowi to clean the code up. Signed-off-by: Changli Gao <xiaosuo@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-26syncookies: add support for ECNFlorian Westphal
Allows use of ECN when syncookies are in effect by encoding ecn_ok into the syn-ack tcp timestamp. While at it, remove a uneeded #ifdef CONFIG_SYN_COOKIES. With CONFIG_SYN_COOKIES=nm want_cookie is ifdef'd to 0 and gcc removes the "if (0)". Signed-off-by: Florian Westphal <fw@strlen.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-26syncookies: do not store rcv_wscale in tcp timestampFlorian Westphal
As pointed out by Fernando Gont there is no need to encode rcv_wscale into the cookie. We did not use the restored rcv_wscale anyway; it is recomputed via tcp_select_initial_window(). Thus we can save 4 bits in the ts option space by removing rcv_wscale. In case window scaling was not supported, we set the (invalid) wscale value 0xf. Signed-off-by: Florian Westphal <fw@strlen.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-16syncookies: check decoded options against sysctl settingsFlorian Westphal
Discard the ACK if we find options that do not match current sysctl settings. Previously it was possible to create a connection with sack, wscale, etc. enabled even if the feature was disabled via sysctl. Also remove an unneeded call to tcp_sack_reset() in cookie_check_timestamp: Both call sites (cookie_v4_check, cookie_v6_check) zero "struct tcp_options_received", hand it to tcp_parse_options() (which does not change tcp_opt->num_sacks/dsack) and then call cookie_check_timestamp(). Even if num_sacks/dsacks were changed, the structure is allocated on the stack and after cookie_check_timestamp returns only a few selected members are copied to the inet_request_sock. Signed-off-by: Florian Westphal <fw@strlen.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-10net-next: remove useless union keywordChangli Gao
remove useless union keyword in rtable, rt6_info and dn_route. Since there is only one member in a union, the union keyword isn't useful. Signed-off-by: Changli Gao <xiaosuo@gmail.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-06Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/sfc/net_driver.h drivers/net/sfc/siena.c
2010-06-05syncookies: update mss tablesFlorian Westphal
- ipv6 msstab: account for ipv6 header size - ipv4 msstab: add mss for Jumbograms. Signed-off-by: Florian Westphal <fw@strlen.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-05syncookies: avoid unneeded tcp header flag double checkFlorian Westphal
caller: if (!th->rst && !th->syn && th->ack) callee: if (!th->ack) make the caller only check for !syn (common for 3whs), and move the !rst / ack test to the callee. Signed-off-by: Florian Westphal <fw@strlen.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-04tcp: use correct net ns in cookie_v4_check()Eric Dumazet
Its better to make a route lookup in appropriate namespace. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-23net: Add rtnetlink init_rcvwnd to set the TCP initial receive windowlaurent chavey
Add rtnetlink init_rcvwnd to set the TCP initial receive window size advertised by passive and active TCP connections. The current Linux TCP implementation limits the advertised TCP initial receive window to the one prescribed by slow start. For short lived TCP connections used for transaction type of traffic (i.e. http requests), bounding the advertised TCP initial receive window results in increased latency to complete the transaction. Support for setting initial congestion window is already supported using rtnetlink init_cwnd, but the feature is useless without the ability to set a larger TCP initial receive window. The rtnetlink init_rcvwnd allows increasing the TCP initial receive window, allowing TCP connection to advertise larger TCP receive window than the ones bounded by slow start. Signed-off-by: Laurent Chavey <chavey@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-15tcp: Revert per-route SACK/DSACK/TIMESTAMP changes.David S. Miller
It creates a regression, triggering badness for SYN_RECV sockets, for example: [19148.022102] Badness at net/ipv4/inet_connection_sock.c:293 [19148.022570] NIP: c02a0914 LR: c02a0904 CTR: 00000000 [19148.023035] REGS: eeecbd30 TRAP: 0700 Not tainted (2.6.32) [19148.023496] MSR: 00029032 <EE,ME,CE,IR,DR> CR: 24002442 XER: 00000000 [19148.024012] TASK = eee9a820[1756] 'privoxy' THREAD: eeeca000 This is likely caused by the change in the 'estab' parameter passed to tcp_parse_options() when invoked by the functions in net/ipv4/tcp_minisocks.c But even if that is fixed, the ->conn_request() changes made in this patch series is fundamentally wrong. They try to use the listening socket's 'dst' to probe the route settings. The listening socket doesn't even have a route, and you can't get the right route (the child request one) until much later after we setup all of the state, and it must be done by hand. This stuff really isn't ready, so the best thing to do is a full revert. This reverts the following commits: f55017a93f1a74d50244b1254b9a2bd7ac9bbf7d 022c3f7d82f0f1c68018696f2f027b87b9bb45c2 1aba721eba1d84a2defce45b950272cee1e6c72a cda42ebd67ee5fdf09d7057b5a4584d36fe8a335 345cda2fd695534be5a4494f1b59da9daed33663 dc343475ed062e13fc260acccaab91d7d80fd5b2 05eaade2782fb0c90d3034fd7a7d5a16266182bb 6a2a2d6bf8581216e08be15fcb563cfd6c430e1e Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-02TCPCT part 1g: Responder Cookie => InitiatorWilliam Allen Simpson
Parse incoming TCP_COOKIE option(s). Calculate <SYN,ACK> TCP_COOKIE option. Send optional <SYN,ACK> data. This is a significantly revised implementation of an earlier (year-old) patch that no longer applies cleanly, with permission of the original author (Adam Langley): http://thread.gmane.org/gmane.linux.network/102586 Requires: TCPCT part 1a: add request_values parameter for sending SYNACK TCPCT part 1b: generate Responder Cookie secret TCPCT part 1c: sysctl_tcp_cookie_size, socket option TCP_COOKIE_TRANSACTIONS TCPCT part 1d: define TCP cookie option, extend existing struct's TCPCT part 1e: implement socket option TCP_COOKIE_TRANSACTIONS TCPCT part 1f: Initiator Cookie => Responder Signed-off-by: William.Allen.Simpson@gmail.com Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-29Allow tcp_parse_options to consult dst entryGilad Ben-Yossef
We need tcp_parse_options to be aware of dst_entry to take into account per dst_entry TCP options settings Signed-off-by: Gilad Ben-Yossef <gilad@codefidence.com> Sigend-off-by: Ori Finkelman <ori@comsleep.com> Sigend-off-by: Yony Amit <yony@comsleep.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-07net: Add sk_mark route lookup support for IPv4 listening socketsAtis Elsts
Add support for route lookup using sk_mark on IPv4 listening sockets. Signed-off-by: Atis Elsts <atis@mikrotik.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-24percpu: clean up percpu variable definitionsTejun Heo
Percpu variable definition is about to be updated such that all percpu symbols including the static ones must be unique. Update percpu variable definitions accordingly. * as,cfq: rename ioc_count uniquely * cpufreq: rename cpu_dbs_info uniquely * xen: move nesting_count out of xen_evtchn_do_upcall() and rename it * mm: move ratelimits out of balance_dirty_pages_ratelimited_nr() and rename it * ipv4,6: rename cookie_scratch uniquely * x86 perf_counter: rename prev_left to pmc_prev_left, irq_entry to pmc_irq_entry and nmi_entry to pmc_nmi_entry * perf_counter: rename disable_count to perf_disable_count * ftrace: rename test_event_disable to ftrace_test_event_disable * kmemleak: rename test_pointer to kmemleak_test_pointer * mce: rename next_interval to mce_next_interval [ Impact: percpu usage cleanups, no duplicate static percpu var names ] Signed-off-by: Tejun Heo <tj@kernel.org> Reviewed-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Dave Jones <davej@redhat.com> Cc: Jeremy Fitzhardinge <jeremy@xensource.com> Cc: linux-mm <linux-mm@kvack.org> Cc: David S. Miller <davem@davemloft.net> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Steven Rostedt <srostedt@redhat.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Andi Kleen <andi@firstfloor.org>
2009-06-24percpu: cleanup percpu array definitionsTejun Heo
Currently, the following three different ways to define percpu arrays are in use. 1. DEFINE_PER_CPU(elem_type[array_len], array_name); 2. DEFINE_PER_CPU(elem_type, array_name[array_len]); 3. DEFINE_PER_CPU(elem_type, array_name)[array_len]; Unify to #1 which correctly separates the roles of the two parameters and thus allows more flexibility in the way percpu variables are defined. [ Impact: cleanup ] Signed-off-by: Tejun Heo <tj@kernel.org> Reviewed-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Tony Luck <tony.luck@intel.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Jeremy Fitzhardinge <jeremy@xensource.com> Cc: linux-mm@kvack.org Cc: Christoph Lameter <cl@linux-foundation.org> Cc: David S. Miller <davem@davemloft.net>
2009-04-20syncookies: remove last_synq_overflow from struct tcp_sockFlorian Westphal
last_synq_overflow eats 4 or 8 bytes in struct tcp_sock, even though it is only used when a listening sockets syn queue is full. We can (ab)use rx_opt.ts_recent_stamp to store the same information; it is not used otherwise as long as a socket is in listen state. Move linger2 around to avoid splitting struct mtu_probe across cacheline boundary on 32 bit arches. Signed-off-by: Florian Westphal <fw@strlen.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-28lsm: Relocate the IPv4 security_inet_conn_request() hooksPaul Moore
The current placement of the security_inet_conn_request() hooks do not allow individual LSMs to override the IP options of the connection's request_sock. This is a problem as both SELinux and Smack have the ability to use labeled networking protocols which make use of IP options to carry security attributes and the inability to set the IP options at the start of the TCP handshake is problematic. This patch moves the IPv4 security_inet_conn_request() hooks past the code where the request_sock's IP options are set/reset so that the LSM can safely manipulate the IP options as needed. This patch intentionally does not change the related IPv6 hooks as IPv6 based labeling protocols which use IPv6 options are not currently implemented, once they are we will have a better idea of the correct placement for the IPv6 hooks. Signed-off-by: Paul Moore <paul.moore@hp.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: James Morris <jmorris@namei.org>
2008-10-01tcp: Port redirection support for TCPKOVACS Krisztian
Current TCP code relies on the local port of the listening socket being the same as the destination address of the incoming connection. Port redirection used by many transparent proxying techniques obviously breaks this, so we have to store the original destination port address. This patch extends struct inet_request_sock and stores the incoming destination port value there. It also modifies the handshake code to use that value as the source port when sending reply packets. Signed-off-by: KOVACS Krisztian <hidden@sch.bme.hu> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-01ipv4: Make Netfilter's ip_route_me_harder() non-local address compatibleKOVACS Krisztian
Netfilter's ip_route_me_harder() tries to re-route packets either generated or re-routed by Netfilter. This patch changes ip_route_me_harder() to handle packets from non-locally-bound sockets with IP_TRANSPARENT set as local and to set the appropriate flowi flags when re-doing the routing lookup. Signed-off-by: KOVACS Krisztian <hidden@sch.bme.hu> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-26syncookies: Make sure ECN is disabledFlorian Westphal
ecn_ok is not initialized when a connection is established by cookies. The cookie syn-ack never sets ECN, so ecn_ok must be set to 0. Spotted using ns-3/network simulation cradle simulator and valgrind. Signed-off-by: Florian Westphal <fw@strlen.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-16mib: add net to NET_INC_STATS_BHPavel Emelyanov
Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-13Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/smc911x.c
