This reverts two changesets, ec3c0982a2dd1e671bad8e9d26c28dcba0039d87
("[TCP]: TCP_DEFER_ACCEPT updates - process as established") and
the follow-on bug fix 9ae27e0adbf471c7a6b80102e38e1d5a346b3b38
("tcp: Fix slab corruption with ipv6 and tcp6fuzz").
This change causes several problems, first reported by Ingo Molnar
as a distcc-over-loopback regression where connections were getting
stuck.
Ilpo Järvinen first spotted the locking problems. The new function
added by this code, tcp_defer_accept_check(), only has the
child socket locked, yet it is modifying state of the parent
listening socket.
Fixing that is non-trivial at best, because we can't simply just grab
the parent listening socket lock at this point, because it would
create an ABBA deadlock. The normal ordering is parent listening
socket --> child socket, but this code path would require the
reverse lock ordering.
Next is a problem noticed by Vitaliy Gusev, he noted:
>--- a/net/ipv4/tcp_timer.c
>+++ b/net/ipv4/tcp_timer.c
>@@ -481,6 +481,11 @@ static void tcp_keepalive_timer (unsigned long data)
> goto death;
>+ if (tp->defer_tcp_accept.request && sk->sk_state == TCP_ESTABLISHED) {
>+ tcp_send_active_reset(sk, GFP_ATOMIC);
>+ goto death;
Here socket sk is not attached to listening socket's request queue. tcp_done()
will not call inet_csk_destroy_sock() (and tcp_v4_destroy_sock() which should
release this sk) as socket is not DEAD. Therefore socket sk will be lost for
freeing.
Finally, Alexey Kuznetsov argues that there might not even be any
real value or advantage to these new semantics even if we fix all
of the bugs:
Hiding from accept() sockets with only out-of-order data only
is the only thing which is impossible with old approach. Is this really
so valuable? My opinion: no, this is nothing but a new loophole
to consume memory without control.
So revert this thing for now.
This bug is able to corrupt fackets_out in very rare cases.
In order for this to cause corruption:
1) DSACK in the middle of previous SACK block must be generated.
2) In order to take that particular branch, part or all of the
DSACKed segment must already be SACKed so that we have that
in cache in the first place.
3) The new info must be top enough so that fackets_out will be
updated on this iteration.
...then fack_count is updated while skb wasn't, then we walk again
that particular segment thus updating fack_count twice for
a single skb and finally that value is assigned to fackets_out
by tcp_sacktag_one.
It is safe to call tcp_sacktag_one just once for a segment (at
DSACK), no need to call again for plain SACK.
Potential problem of the miscount are limited to premature entry
to recovery and to inflated reordering metric (which could even
cancel each other out in the most the luckiest scenarios :-)).
Both are quite insignificant in worst case too and there exists
also code to reset them (fackets_out once sacked_out becomes zero
and reordering metric on RTO).
This has been reported by a number of people, because it occurred
quite rarely, it has been very evasive. Andy Furniss was able to
get it to occur couple of times so that a bit more info was
collected about the problem using a debug patch, though it still
required lot of checking around. Thanks also to others who have
tried to help here.
This is listed as Bugzilla #10346. The bug was introduced by
me in commit 68f8353b48 ([TCP]: Rewrite SACK block processing &
sack_recv_cache use), I probably thought back then that there's
need to scan that entry twice or didn't dare to make it go
through it just once there. Going through twice would have
required restoring fack_count after the walk but as noted above,
I chose to drop the additional walk step altogether here.
Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi>
It is possible that this skip path causes TCP to end up into an
invalid state where ca_state was left to CA_Open while some
segments already came into sacked_out. If next valid ACK doesn't
contain new SACK information TCP fails to enter into
tcp_fastretrans_alert(). Thus at least high_seq is set
incorrectly to a too high seqno because some new data segments
could be sent in between (and also, limited transmit is not
being correctly invoked there). Reordering in both directions
can easily cause this situation to occur.
I guess we would want to use tcp_moderate_cwnd(tp) there as well
as it may be possible to use this to trigger oversized burst to
network by sending an old ACK with huge amount of SACK info, but
I'm a bit unsure about its effects (mainly to FlightSize), so to
be on the safe side I just currently fixed it minimally to keep
TCP's state consistent (obviously, such nasty ACKs have been
possible this far). Though it seems that FlightSize is already
underestimated by some amount, so probably on the long term we
might want to trigger recovery there too, if appropriate, to make
FlightSize calculation to resemble reality at the time when the
losses where discovered (but such change scares me too much now
and requires some more thinking anyway how to do that as it
likely involves some code shuffling).
This bug was found by Brian Vowell while running my TCP debug
patch to find cause of another TCP issue (fackets_out
miscount).
If receiver consumes segments successfully only in-order, FRTO
fallback to conventional recovery produces RTO loop because
FRTO's forward transmissions will always get dropped and need to
be resent, yet by default they're not marked as lost (which are
the only segments we will retransmit in CA_Loss).
Price to pay about this is occassionally unnecessarily
retransmitting the forward transmission(s). SACK blocks help
a bit to avoid this, so it's mainly a concern for NewReno case
though SACK is not fully immune either.
This change has a side-effect of fixing SACKFRTO problem where
it didn't have snd_nxt of the RTO time available anymore when
fallback become necessary (this problem would have only occured
when RTO would occur for two or more segments and ECE arrives
in step 3; no need to figure out how to fix that unless the
TODO item of selective behavior is considered in future).
Reported-by: Damon L. Chesser <damon@damtek.com>
Tested-by: Damon L. Chesser <damon@damtek.com>
It seems that commit 009a2e3e4ec ("[TCP] FRTO: Improve
interoperability with other undo_marker users") run into
another land-mine which caused fallback to conventional
recovery to break:
1. Cumulative ACK arrives after FRTO retransmission
2. tcp_try_to_open sees zero retrans_out, clears retrans_stamp
which should be kept like in CA_Loss state it would be
3. undo_marker change allowed tcp_packet_delayed to return
true because of the cleared retrans_stamp once FRTO is
terminated causing LossUndo to occur, which means all loss
markings FRTO made are reverted.
This means that the conventional recovery basically recovered
one loss per RTT, which is not that efficient. It was quite
unobvious that the undo_marker change broken something like
this, I had a quite long session to track it down because of
the non-intuitiviness of the bug (luckily I had a trivial
reproducer at hand and I was also able to learn to use kprobes
in the process as well :-)).
This together with the NewReno+FRTO fix and FRTO in-order
workaround this fixes Damon's problems, this and the first
mentioned are enough to fix Bugzilla #10063.
Tested-by: Sebastian Hyrwall <zibbe@cisko.org>
Note: there's actually another bug in FRTO's SACK variant, which
is the causing failure in NewReno case because of the error
that's fixed here. I'll fix the SACK case separately (it's
a separate bug really, though related, but in order to fix that
I need to audit tp->snd_nxt usage a bit).
There were two places where SACK variant of FRTO is getting
incorrectly used even if SACK wasn't negotiated by the TCP flow.
This leads to incorrect setting of frto_highmark with NewReno
if a previous recovery was interrupted by another RTO.
An eventual fallback to conventional recovery then incorrectly
considers one or couple of segments as forward transmissions
though they weren't, which then are not LOST marked during
fallback making them "non-retransmittable" until the next RTO.
In a bad case, those segments are really lost and are the only
one left in the window. Thus TCP needs another RTO to continue.
The next FRTO, however, could again repeat the same events
making the progress of the TCP flow extremely slow.
In order for these events to occur at all, FRTO must occur
again in FRTOs step 3 while the key segments must be lost as
well, which is not too likely in practice. It seems to most
frequently with some small devices such as network printers
that *seem* to accept TCP segments only in-order. In cases
were key segments weren't lost, things get automatically
resolved because those wrongly marked segments don't need to be
retransmitted in order to continue.
I found a reproducer after digging up relevant reports (few
reports in total, none at netdev or lkml I know of), some
cases seemed to indicate middlebox issues which seems now
to be a false assumption some people had made. Bugzilla
#10063 _might_ be related. Damon L. Chesser <damon@damtek.com>
had a reproducable case and was kind enough to tcpdump it
for me. With the tcpdump log it was quite trivial to figure
out.
There are functions to refer to the value of dst->metric[THE_METRIC-1]
directly without use of a inline function "dst_metric" defined in
net/dst.h.
The following patch changes them to use the inline function
consistently.
Signed-off-by: Satoru SATOH <satoru.satoh@gmail.com>
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
This fixes a regression added by ec3c0982a2dd1e671bad8e9d26c28dcba0039d87
tcp_v6_do_rcv()->tcp_rcv_established(), the latter goes to step5, where
eventually skb can be freed via tcp_data_queue() (drop: label), then if
check for tcp_defer_accept_check() returns true and thus
tcp_rcv_established() returns -1, which forces tcp_v6_do_rcv() to jump
to reset: label, which in turn will pass through discard: label and free
the same skb again.
Tested by Eric Sesterhenn.
Acked-By: Patrick McManus <mcmanus@ducksong.com>
Make use of tcp before macro.
Signed-off-by: Arnd Hannemann <hannemann@nets.rwth-aachen.de>
master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6
Returns non-zero if tp->out_of_order_queue was seen non-empty.
This allows tcp_try_rmem_schedule() to return early.
Signed-off-by: Vitaliy Gusev <vgusev@openvz.org>
tcp_prune_queue() doesn't prune an out-of-order queue at all.
Therefore sk_rmem_schedule() can fail but the out-of-order queue isn't
pruned . This can lead to tcp deadlock state if the next two
conditions are held:
1. There are a sequence hole between last received in
order segment and segments enqueued to the out-of-order queue.
2. Size of all segments in the out-of-order queue is more than tcp_mem[2].
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
And use %u to format port.
drivers/net/ehea/ehea_main.c
drivers/net/wireless/iwlwifi/Kconfig
drivers/net/wireless/rt2x00/rt61pci.c
net/ipv4/inet_timewait_sock.c
net/ipv6/raw.c
net/mac80211/ieee80211_sta.c
This expresses __skb_append in terms of __skb_queue_after, exploiting that
__skb_append(old, new, list) = __skb_queue_after(list, old, new).
Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk>
MTU probe can cause some remedies for FRTO because the normal
packet ordering may be violated allowing FRTO to make a wrong
decision (it might not be that serious threat for anything
though). Thus it's safer to not run FRTO while MTU probe is
underway.
It seems that the basic FRTO variant should also look for an
skb at probe_seq.start to check if that's retransmitted one
but I didn't implement it now (plain seqno in window check
isn't robust against wraparounds).
This fixes Bugzilla #10384
tcp_simple_retransmit does L increment without any checking
whatsoever for overflowing S+L when Reno is in use.
The simplest scenario I can currently think of is rather
complex in practice (there might be some more straightforward
cases though). Ie., if mss is reduced during mtu probing, it
may end up marking everything lost and if some duplicate ACKs
arrived prior to that sacked_out will be non-zero as well,
leading to S+L > packets_out, tcp_clean_rtx_queue on the next
cumulative ACK or tcp_fastretrans_alert on the next duplicate
ACK will fix the S counter.
More straightforward (but questionable) solution would be to
just call tcp_reset_reno_sack() in tcp_simple_retransmit but
it would negatively impact the probe's retransmission, ie.,
the retransmissions would not occur if some duplicate ACKs
had arrived.
So I had to add reno sacked_out reseting to CA_Loss state
when the first cumulative ACK arrives (this stale sacked_out
might actually be the explanation for the reports of left_out
overflows in kernel prior to 2.6.23 and S+L overflow reports
of 2.6.24). However, this alone won't be enough to fix kernel
before 2.6.24 because it is building on top of the commit
1b6d427bb7e ([TCP]: Reduce sacked_out with reno when purging
write_queue) to keep the sacked_out from overflowing.
Reported-by: Alessandro Suardi <alessandro.suardi@gmail.com>
Fixes a long-standing bug which makes NewReno recovery crippled.
With GSO the whole head skb was marked as LOST which is in
violation of NewReno procedure that only wants to mark one packet
and ended up breaking our TCP code by causing counter overflow
because our code was built on top of assumption about valid
NewReno procedure. This manifested as triggering a WARN_ON for
the overflow in a number of places.
It seems relatively safe alternative to just do nothing if
tcp_fragment fails due to oom because another duplicate ACK is
likely to be received soon and the fragmentation will be retried.
Special thanks goes to Soeren Sonnenburg <kernel@nn7.de> who was
lucky enough to be able to reproduce this so that the warning
for the overflow was hit. It's not as easy task as it seems even
if this bug happens quite often because the amount of outstanding
data is pretty significant for the mismarkings to lead to an
overflow.
Because it's very late in 2.6.25-rc cycle (if this even makes in
time), I didn't want to touch anything with SACK enabled here.
Fragmenting might be useful for it as well but it's more or less
a policy decision rather than mandatory fix. Thus there's no need
to rush and we can postpone considering tcp_fragment with SACK
for 2.6.26.
In 2.6.24 and earlier, this very same bug existed but the effect
is slightly different because of a small changes in the if
conditions that fit to the patch's context. With them nothing
got lost marker and thus no retransmissions happened.
The fast retransmission can be forced locally to the rfc3517
branch in tcp_update_scoreboard instead of making such fragile
constructs deeper in tcp_mark_head_lost.
This is necessary for the next patch which must not have
loopholes for cnt > packets check. As one can notice,
readability got some improvements too because of this :-).
Change TCP_DEFER_ACCEPT implementation so that it transitions a
connection to ESTABLISHED after handshake is complete instead of
leaving it in SYN-RECV until some data arrvies. Place connection in
accept queue when first data packet arrives from slow path.
Benefits:
- established connection is now reset if it never makes it
to the accept queue
- diagnostic state of established matches with the packet traces
showing completed handshake
- TCP_DEFER_ACCEPT timeouts are expressed in seconds and can now be
enforced with reasonable accuracy instead of rounding up to next
exponential back-off of syn-ack retry.
Signed-off-by: Patrick McManus <mcmanus@ducksong.com>
__FUNCTION__ is gcc-specific, use __func__
net/mac80211/rc80211_pid_algo.c
Updated to incorporate Eric's suggestion of using a per cpu buffer
rather than allocating on the stack. Just a two line change, but will
resend in it's entirety.
Signed-off-by: Glenn Griffin <ggriffin.kernel@gmail.com>
It makes fackets_out to grow too slowly compared with the
real write queue.
This shouldn't cause those BUG_TRAP(packets <= tp->packets_out)
to trigger but how knows how such inconsistent fackets_out
affects here and there around TCP when everything is nowadays
assuming accurate fackets_out. So lets see if this silences
them all.
Reported by Guillaume Chazarain <guichaz@gmail.com>.
NewReno should add cnt per skb (as with FACK) instead of depending on
SACKED_ACKED bits which won't be set with it at all. Effectively,
NewReno should always exists after the first iteration anyway (or
immediately if there's already head in lost_out.
This was fixed earlier in net-2.6.25 but got reverted among other
stuff and I didn't notice that this is still necessary (actually
wasn't even considering this case while trying to figure out the
reports because I lived with different kind of code than it in reality
was).
This should solve the WARN_ONs in TCP code that as a result of this
triggered multiple times in every place we check for this invariant.
Special thanks to Dave Young <hidave.darkstar@gmail.com> and Krishna
Kumar2 <krkumar2@in.ibm.com> for trying with my debug patches.
Tested-by: Dave Young <hidave.darkstar@gmail.com>
Tested-by: Krishna Kumar2 <krkumar2@in.ibm.com>
Removed case indentation level & combined some nested ifs, mostly
within 80 lines now. This is a leftover from indent patch, it
just had to be done manually to avoid messing it up completely.
These were manually selected from indent's results which as is
are too noisy to be of any use without human reason. In addition,
some extra newlines between function and its comment were removed
too.
The snd_up check should be enough. I suspect this has been
there to provide a minor optimization in clean_rtx_queue which
used to have a small if (!->sacked) block which could skip
snd_up check among the other work.
SACK reneging can be precalculated to a FLAG in clean_rtx_queue
which has the right skb looked up. This will help a bit in
future because skb->sacked access will be changed eventually,
changing it already won't hurt any.
Earlier resolution for NewReno's sacked_out should now keep
it small enough for this to become invariant-like check.
This patch introduces new memory accounting functions for each network
protocol. Most of them are renamed from memory accounting functions
for stream protocols. At the same time, some stream memory accounting
functions are removed since other functions do same thing.
Renaming:
sk_stream_free_skb() -> sk_wmem_free_skb()
__sk_stream_mem_reclaim() -> __sk_mem_reclaim()
sk_stream_mem_reclaim() -> sk_mem_reclaim()
sk_stream_mem_schedule -> __sk_mem_schedule()
sk_stream_pages() -> sk_mem_pages()
sk_stream_rmem_schedule() -> sk_rmem_schedule()
sk_stream_wmem_schedule() -> sk_wmem_schedule()
sk_charge_skb() -> sk_mem_charge()
Removeing
sk_stream_rfree(): consolidates into sock_rfree()
sk_stream_set_owner_r(): consolidates into skb_set_owner_r()
sk_stream_mem_schedule()
The following functions are added.
sk_has_account(): check if the protocol supports accounting
sk_mem_uncharge(): do the opposite of sk_mem_charge()
In addition, to achieve consolidation, updating sk_wmem_queued is
removed from sk_mem_charge().
Next, to consolidate memory accounting functions, this patch adds
memory accounting calls to network core functions. Moreover, present
memory accounting call is renamed to new accounting call.
Finally we replace present memory accounting calls with new interface
in TCP and SCTP.
Signed-off-by: Takahiro Yasui <tyasui@redhat.com>
Signed-off-by: Hideo Aoki <haoki@redhat.com>
While checking Gavin's patch I noticed that the returned seq_rtt
is not used by the caller.
tcp_win_from_space() being signed, compiler might emit an integer divide
to compute tcp_win_from_space()/2 .
Using right shifts is OK here and less expensive.
Signed-off-by: Eric Dumazet <dada1@cosmosbay.com>
Pointing to the next skb is necessary to avoid referencing
already SACKed skbs which will soon be on a separate list.
Bogus seqno compares just mislead, the code is identical for
both sides of the seqno compare (and was even executed just
once because of return in between).
To get there, highest_sack must have advanced. When it advances,
a new skb is SACKed, which already sets that FLAG. Besides, the
original purpose of it has puzzled me, never understood why
LOST bit setting of retransmitted skb is marked with
FLAG_DATA_SACKED.
Usually those skbs will have L set, not counting them as lost
retransmissions is misleading.
1) Skip condition used to be wrong way around which made SACK
processing very broken, missed many blocks because of that.
2) Use highest_sack advancement only if some skbs are already
sacked because otherwise tcp_write_queue_next may move things
too far (occurs mainly with GSO). The other similar advancement
is not problem because highest_sack was previosly put to point
a sacked skb.
These problems were located because of problem report from Matt
Mathis <mathis@psc.edu>.
The sock_wake_async() performs a bit different actions
depending on "how" argument. Unfortunately this argument
ony has numerical magic values.
I propose to give names to their constants to help people
reading this function callers understand what's going on
without looking into this function all the time.
I suppose this is 2.6.25 material, but if it's not (or the
naming seems poor/bad/awful), I can rework it against the
current net-2.6 tree.
Signed-off-by: Pavel Emelyanov <xemul@openvz.org>
Previously one of the in-block skip branches was missing it.
Also, drop it from tail-fully-processed case because the next
iteration will do exactly the same thing, i.e., process the
SACK block that contains the DSACK information.
Key points of this patch are:
- In case new SACK information is advance only type, no skb
processing below previously discovered highest point is done
- Optimize cases below highest point too since there's no need
to always go up to highest point (which is very likely still
present in that SACK), this is not entirely true though
because I'm dropping the fastpath_skb_hint which could
previously optimize those cases even better. Whether that's
significant, I'm not too sure.
Currently it will provide skipping by walking. Combined with
RB-tree, all skipping would become fast too regardless of window
size (can be done incrementally later).
Previously a number of cases in TCP SACK processing fails to
take advantage of costly stored information in sack_recv_cache,
most importantly, expected events such as cumulative ACK and new
hole ACKs. Processing on such ACKs result in rather long walks
building up latencies (which easily gets nasty when window is
huge). Those latencies are often completely unnecessary
compared with the amount of _new_ information received, usually
for cumulative ACK there's no new information at all, yet TCP
walks whole queue unnecessary potentially taking a number of
costly cache misses on the way, etc.!
Since the inclusion of highest_sack, there's a lot information
that is very likely redundant (SACK fastpath hint stuff,
fackets_out, highest_sack), though there's no ultimate guarantee
that they'll remain the same whole the time (in all unearthly
scenarios). Take advantage of this knowledge here and drop
fastpath hint and use direct access to highest SACKed skb as
a replacement.
Effectively "special cased" fastpath is dropped. This change
adds some complexity to introduce better coveraged "fastpath",
though the added complexity should make TCP behave more cache
friendly.
The current ACK's SACK blocks are compared against each cached
block individially and only ranges that are new are then scanned
by the high constant walk. For other parts of write queue, even
when in previously known part of the SACK blocks, a faster skip
function is used (if necessary at all). In addition, whenever
possible, TCP fast-forwards to highest_sack skb that was made
available by an earlier patch. In typical case, no other things
but this fast-forward and mandatory markings after that occur
making the access pattern quite similar to the former fastpath
"special case".
DSACKs are special case that must always be walked.
The local to recv_sack_cache copying could be more intelligent
w.r.t DSACKs which are likely to be there only once but that
is left to a separate patch.
Worker function that implements the main logic of
the inner-most loop of tcp_sacktag_write_queue().
Idea was originally presented by David S. Miller.
