This is the fallout from adding memcpy alignment workaround for certain
IOATDMA hardware. NetDMA will only use DMA engine that can handle byte align
ops.
Signed-off-by: Dave Jiang <dave.jiang@intel.com>
Change-Id: Ib3b69ffc5ac3e07c9cc44cc49e9142088eec477e
commit ea4fc0d619 (ipv4: Don't use rt->rt_{src,dst} in ip_queue_xmit())
added a serious regression on synflood handling.
Simon Kirby discovered a successful connection was delayed by 20 seconds
before being responsive.
In my tests, I discovered that xmit frames were lost, and needed ~4
retransmits and a socket dst rebuild before being really sent.
In case of syncookie initiated connection, we use a different path to
initialize the socket dst, and inet->cork.fl.u.ip4 is left cleared.
As ip_queue_xmit() now depends on inet flow being setup, fix this by
copying the temp flowi4 we use in cookie_v4_check().
Reported-by: Simon Kirby <sim@netnation.com>
Bisected-by: Simon Kirby <sim@netnation.com>
Tested-by: Eric Dumazet <eric.dumazet@gmail.com>
Binding RST packet outgoing interface to incoming interface
for tcp v4 when there is no socket associate with it.
when sk is not NULL, using sk->sk_bound_dev_if instead.
(suggested by Eric Dumazet).
This has few benefits:
1. tcp_v6_send_reset already did that.
2. This helps tcp connect with SO_BINDTODEVICE set. When
connection is lost, we still able to sending out RST using
same interface.
3. we are sending reply, it is most likely to be succeed
if iif is used
Signed-off-by: Shawn Lu <shawn.lu@ericsson.com>
md5 key is added in socket through remote address.
remote address should be used in finding md5 key when
sending out reset packet.
Signed-off-by: shawnlu <shawn.lu@ericsson.com>
This patch allows each namespace to independently set up
its levels for tcp memory pressure thresholds. This patch
alone does not buy much: we need to make this values
per group of process somehow. This is achieved in the
patches that follows in this patchset.
Signed-off-by: Glauber Costa <glommer@parallels.com>
Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
CC: David S. Miller <davem@davemloft.net>
CC: Eric W. Biederman <ebiederm@xmission.com>
This patch introduces memory pressure controls for the tcp
protocol. It uses the generic socket memory pressure code
introduced in earlier patches, and fills in the
necessary data in cg_proto struct.
Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujtisu.com>
This patch replaces all uses of struct sock fields' memory_pressure,
memory_allocated, sockets_allocated, and sysctl_mem to acessor
macros. Those macros can either receive a socket argument, or a mem_cgroup
argument, depending on the context they live in.
Since we're only doing a macro wrapping here, no performance impact at all is
expected in the case where we don't have cgroups disabled.
Reviewed-by: Hiroyouki Kamezawa <kamezawa.hiroyu@jp.fujitsu.com>
CC: Eric Dumazet <eric.dumazet@gmail.com>
Rick Jones reported that TCP_CONGESTION sockopt performed on a listener
was ignored for its children sockets : right after accept() the
congestion control for new socket is the system default one.
This seems an oversight of the initial design (quoted from Stephen)
Based on prior investigation and patch from Rick.
Reported-by: Rick Jones <rick.jones2@hp.com>
CC: Stephen Hemminger <shemminger@vyatta.com>
CC: Yuchung Cheng <ycheng@google.com>
Tested-by: Rick Jones <rick.jones2@hp.com>
Simon Kirby reported divides by zero errors in __tcp_select_window()
This happens when inet_csk_route_child_sock() returns a NULL pointer :
We free new socket while we eventually armed keepalive timer in
tcp_create_openreq_child()
Fix this by a call to tcp_clear_xmit_timers()
[ This is a followup to commit 918eb39962dff (net: add missing
bh_unlock_sock() calls) ]
Reported-by: Simon Kirby <sim@hostway.ca>
Tested-by: Simon Kirby <sim@hostway.ca>
Simon Kirby reported lockdep warnings and following messages :
[104661.897577] huh, entered softirq 3 NET_RX ffffffff81613740
preempt_count 00000101, exited with 00000102?
[104661.923653] huh, entered softirq 3 NET_RX ffffffff81613740
Problem comes from commit 0e734419
(ipv4: Use inet_csk_route_child_sock() in DCCP and TCP.)
If inet_csk_route_child_sock() returns NULL, we should release socket
lock before freeing it.
Another lock imbalance exists if __inet_inherit_port() returns an error
since commit 093d282321da ( tproxy: fix hash locking issue when using
port redirection in __inet_inherit_port()) a backport is also needed for
>= 2.6.37 kernels.
CC: Balazs Scheidler <bazsi@balabit.hu>
CC: KOVACS Krisztian <hidden@balabit.hu>
the tcp and udp code creates a set of struct file_operations at runtime
while it can also be done at compile time, with the added benefit of then
having these file operations be const.
the trickiest part was to get the "THIS_MODULE" reference right; the naive
method of declaring a struct in the place of registration would not work
for this reason.
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
There is a long standing bug in linux tcp stack, about ACK messages sent
on behalf of TIME_WAIT sockets.
In the IP header of the ACK message, we choose to reflect TOS field of
incoming message, and this might break some setups.
Example of things that were broken :
- Routing using TOS as a selector
- Firewalls
- Trafic classification / shaping
We now remember in timewait structure the inet tos field and use it in
ACK generation, and route lookup.
Notes :
- We still reflect incoming TOS in RST messages.
- We could extend MuraliRaja Muniraju patch to report TOS value in
netlink messages for TIME_WAIT sockets.
- A patch is needed for IPv6
Now tcp_md5_hash_header() has a const tcphdr argument, we can add more
const attributes to callers.
Adding const qualifiers to pointers can ease code review, and spot some
bugs. It might allow compiler to optimize code further.
For example, is it legal to temporary write a null cksum into tcphdr
in tcp_md5_hash_header() ? I am afraid a sniffer could catch the
temporary null value...
net/batman-adv/soft-interface.c
tcp_v4_clear_md5_list() assumes that multiple tcp md5sig peers
only hold one reference to md5sig_pool. but tcp_v4_md5_do_add()
increases use count of md5sig_pool for each peer. This patch
makes tcp_v4_md5_do_add() only increases use count for the first
tcp md5sig peer.
Signed-off-by: Zheng Yan <zheng.z.yan@intel.com>
struct tcp_skb_cb contains a "flags" field containing either tcp flags
or IP dsfield depending on context (input or output path)
Introduce ip_dsfield to make the difference clear and ease maintenance.
If later we want to save space, we can union flags/ip_dsfield
MAINTAINERS
drivers/net/Kconfig
drivers/net/ethernet/broadcom/bnx2x/bnx2x_link.c
drivers/net/ethernet/broadcom/tg3.c
drivers/net/wireless/iwlwifi/iwl-pci.c
drivers/net/wireless/iwlwifi/iwl-trans-tx-pcie.c
drivers/net/wireless/rt2x00/rt2800usb.c
drivers/net/wireless/wl12xx/main.c
"Possible SYN flooding on port xxxx " messages can fill logs on servers.
Change logic to log the message only once per listener, and add two new
SNMP counters to track :
TCPReqQFullDoCookies : number of times a SYNCOOKIE was replied to client
TCPReqQFullDrop : number of times a SYN request was dropped because
syncookies were not enabled.
Based on a prior patch from Tom Herbert, and suggestions from David.
CC: Tom Herbert <therbert@google.com>
The l4_rxhash flag was added to the skb structure to indicate
that the rxhash value was computed over the 4 tuple for the
packet which includes the port information in the encapsulated
transport packet. This is used by the stack to preserve the
rxhash value in __skb_rx_tunnel.
Signed-off-by: Tom Herbert <therbert@google.com>
Computers have become a lot faster since we compromised on the
partial MD4 hash which we use currently for performance reasons.
MD5 is a much safer choice, and is inline with both RFC1948 and
other ISS generators (OpenBSD, Solaris, etc.)
Furthermore, only having 24-bits of the sequence number be truly
unpredictable is a very serious limitation. So the periodic
regeneration and 8-bit counter have been removed. We compute and
use a full 32-bit sequence number.
For ipv6, DCCP was found to use a 32-bit truncated initial sequence
number (it needs 43-bits) and that is fixed here as well.
Reported-by: Dan Kaminsky <dan@doxpara.com>
Tested-by: Willy Tarreau <w@1wt.eu>
drivers/net/wireless/iwlwifi/iwl-agn-rxon.c
drivers/net/wireless/rtlwifi/pci.c
net/netfilter/ipvs/ip_vs_core.c
Le jeudi 16 juin 2011 à 23:38 -0400, David Miller a écrit :
> From: Ben Hutchings <bhutchings@solarflare.com>
> Date: Fri, 17 Jun 2011 00:50:46 +0100
> > On Wed, 2011-06-15 at 04:15 +0200, Eric Dumazet wrote:
> >> @@ -1594,6 +1594,7 @@ int tcp_v4_do_rcv(struct sock *sk, struct sk_buff *skb)
> >> goto discard;
> >> if (nsk != sk) {
> >> + sock_rps_save_rxhash(nsk, skb->rxhash);
> >> if (tcp_child_process(sk, nsk, skb)) {
> >> rsk = nsk;
> >> goto reset;
> > I haven't tried this, but it looks reasonable to me.
> > What about IPv6? The logic in tcp_v6_do_rcv() looks very similar.
> Indeed ipv6 side needs the same fix.
> Eric please add that part and resubmit. And in fact I might stick
> this into net-2.6 instead of net-next-2.6
OK, here is the net-2.6 based one then, thanks !
[PATCH v2] net: rfs: enable RFS before first data packet is received
First packet received on a passive tcp flow is not correctly RFS
steered.
One sock_rps_record_flow() call is missing in inet_accept()
But before that, we also must record rxhash when child socket is setup.
CC: Ben Hutchings <bhutchings@solarflare.com>
CC: Jamal Hadi Salim <hadi@cyberus.ca>
Signed-off-by: David S. Miller <davem@conan.davemloft.net>
This patch lowers the default initRTO from 3secs to 1sec per
RFC2988bis. It falls back to 3secs if the SYN or SYN-ACK packet
has been retransmitted, AND the TCP timestamp option is not on.
It also adds support to take RTT sample during 3WHS on the passive
open side, just like its active open counterpart, and uses it, if
valid, to seed the initRTO for the data transmission phase.
The patch also resets ssthresh to its initial default at the
beginning of the data transmission phase, and reduces cwnd to 1 if
there has been MORE THAN ONE retransmission during 3WHS per RFC5681.
Signed-off-by: H.K. Jerry Chu <hkchu@google.com>
The %pK format specifier is designed to hide exposed kernel pointers,
specifically via /proc interfaces. Exposing these pointers provides an
easy target for kernel write vulnerabilities, since they reveal the
locations of writable structures containing easily triggerable function
pointers. The behavior of %pK depends on the kptr_restrict sysctl.
If kptr_restrict is set to 0, no deviation from the standard %p behavior
occurs. If kptr_restrict is set to 1, the default, if the current user
(intended to be a reader via seq_printf(), etc.) does not have CAP_SYSLOG
(currently in the LSM tree), kernel pointers using %pK are printed as 0's.
If kptr_restrict is set to 2, kernel pointers using %pK are printed as
0's regardless of privileges. Replacing with 0's was chosen over the
default "(null)", which cannot be parsed by userland %p, which expects
"(nil)".
The supporting code for kptr_restrict and %pK are currently in the -mm
tree. This patch converts users of %p in net/ to %pK. Cases of printing
pointers to the syslog are not covered, since this would eliminate useful
information for postmortem debugging and the reading of the syslog is
already optionally protected by the dmesg_restrict sysctl.
Signed-off-by: Dan Rosenberg <drosenberg@vsecurity.com>
Cc: Thomas Graf <tgraf@infradead.org>
Cc: Eugene Teo <eugeneteo@kernel.org>
Cc: Kees Cook <kees.cook@canonical.com>
Cc: Eric Paris <eparis@parisplace.org>
This will next trickle down to rt_bind_peer().
This way the caller can get at the fully resolved fl4->{daddr,saddr}
etc.
This eliminates an access to rt->rt_src.
Operation order is now transposed, we first create the child
socket then we try to hook up the route.
Since this is invoked from inet_stream_connect() the socket is locked
and therefore this usage is safe.
Now that output route lookups update the flow with
destination address selection, we can fetch it from
fl4->daddr instead of rt->rt_dst
source address selection, we can fetch it from
fl4->saddr instead of rt->rt_src
We lack proper synchronization to manipulate inet->opt ip_options
Problem is ip_make_skb() calls ip_setup_cork() and
ip_setup_cork() possibly makes a copy of ipc->opt (struct ip_options),
without any protection against another thread manipulating inet->opt.
Another thread can change inet->opt pointer and free old one under us.
Use RCU to protect inet->opt (changed to inet->inet_opt).
Instead of handling atomic refcounts, just copy ip_options when
necessary, to avoid cache line dirtying.
We cant insert an rcu_head in struct ip_options since its included in
skb->cb[], so this patch is large because I had to introduce a new
ip_options_rcu structure.
Cc: Herbert Xu <herbert@gondor.apana.org.au>
These functions are used together as a unit for route resolution
during connect(). They address the chicken-and-egg problem that
exists when ports need to be allocated during connect() processing,
yet such port allocations require addressing information from the
routing code.
It's currently more heavy handed than it needs to be, and in
particular we allocate and initialize a flow object twice.
Let the callers provide the on-stack flow object. That way we only
need to initialize it once in the ip_route_connect() call.
Later, if ip_route_newports() needs to do anything, it re-uses that
flow object as-is except for the ports which it updates before the
route re-lookup.
Also, describe why this set of facilities are needed and how it works
in a big comment.
Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com>
Add const qualifiers to structs iphdr, ipv6hdr and in6_addr pointers
where possible, to make code intention more obvious.
Instead of on the stack.
Since that's what the current vague "flags" thing means.
ip_route_newports() is the only place in the entire kernel that
cares about the port members in the routing cache entry's lookup
flow key.
Therefore the only reason we store an entire flow inside of the
struct rtentry is for this one special case.
Rewrite ip_route_newports() such that:
1) The caller passes in the original port values, so we don't need
to use the rth->fl.fl_ip_{s,d}port values to remember them.
2) The lookup flow is constructed by hand instead of being copied
from the routing cache entry's flow.
Now, TCP_CHECK_TIMER is not used for debuging, it does nothing.
And, it has been there for several years, maybe 6 years.
Remove it to keep code clearer.
Signed-off-by: Shan Wei <shanwei@cn.fujitsu.com>
Future changes will add caching information, and some of
these new elements will be addresses.
Since the family is implicit via the ->daddr.family member,
replicating the family in ever address we store is entirely
redundant.
commit a8b690f98baf9fb19 (tcp: Fix slowness in read /proc/net/tcp)
introduced a bug in handling of SYN_RECV sockets.
st->offset represents number of sockets found since beginning of
listening_hash[st->bucket].
We should not reset st->offset when iterating through
syn_table[st->sbucket], or else if more than ~25 sockets (if
PAGE_SIZE=4096) are in SYN_RECV state, we exit from listening_get_next()
with a too small st->offset
Next time we enter tcp_seek_last_pos(), we are not able to seek past
already found sockets.
Reported-by: PK <runningdoglackey@yahoo.com>
net/ipv4/fib_frontend.c
Alexey Vlasov found /proc/net/tcp could sometime loop and display
millions of sockets in LISTEN state.
In 2.6.29, when we converted TCP hash tables to RCU, we left two
sk_next() calls in listening_get_next().
We must instead use sk_nulls_next() to properly detect an end of chain.
Reported-by: Alexey Vlasov <renton@renton.name>
Make all RTAX_ADVMSS metric accesses go through a new helper function,
dst_metric_advmss().
Leave the actual default metric as "zero" in the real metric slot,
and compute the actual default value dynamically via a new dst_ops
AF specific callback.
For stacked IPSEC routes, we use the advmss of the path which
preserves existing behavior.
Unlike ipv4/ipv6, DecNET ties the advmss to the mtu and thus updates
advmss on pmtu updates. This inconsistency in advmss handling
results in more raw metric accesses than I wish we ended up with.
drivers/net/wireless/ath/ath9k/ar9003_eeprom.c
net/llc/af_llc.c
The only thing AF-specific about remembering the timestamp
for a time-wait TCP socket is getting the peer.
Abstract that behind a new timewait_sock_ops vector.
Support for real IPV6 sockets is not filled in yet, but
curiously this makes timewait recycling start to work
for v4-mapped ipv6 sockets.
Then we can make a completely generic tcp_remember_stamp()
that uses ->get_peer() as a helper, minimizing the AF specific
code and minimizing the eventual code duplication when we implement
the ipv6 side of TW recycling.
