[ Upstream commit e62a123b8ef7c5dc4db2c16383d506860ad21b47 ]
Neal reported crashes with this stack trace :
RIP: 0010:[<ffffffff8c57231b>] tcp_v4_send_ack+0x41/0x20f
CR2: 0000000000000018 CR3: 000000044005c000 CR4: 00000000001427e0
[<ffffffff8c57258e>] tcp_v4_reqsk_send_ack+0xa5/0xb4
[<ffffffff8c1a7caa>] tcp_check_req+0x2ea/0x3e0
[<ffffffff8c19e420>] tcp_rcv_state_process+0x850/0x2500
[<ffffffff8c1a6d21>] tcp_v4_do_rcv+0x141/0x330
[<ffffffff8c56cdb2>] sk_backlog_rcv+0x21/0x30
[<ffffffff8c098bbd>] tcp_recvmsg+0x75d/0xf90
[<ffffffff8c0a8700>] inet_recvmsg+0x80/0xa0
[<ffffffff8c17623e>] sock_aio_read+0xee/0x110
[<ffffffff8c066fcf>] do_sync_read+0x6f/0xa0
[<ffffffff8c0673a1>] SyS_read+0x1e1/0x290
[<ffffffff8c5ca262>] system_call_fastpath+0x16/0x1b
The problem here is the skb we provide to tcp_v4_send_ack() had to
be parked in the backlog of a new TCP fastopen child because this child
was owned by the user at the time an out of window packet arrived.
Before queuing a packet, TCP has to set skb->dev to NULL as the device
could disappear before packet is removed from the queue.
Fix this issue by using the net pointer provided by the socket (being a
timewait or a request socket).
IPv6 is immune to the bug : tcp_v6_send_response() already gets the net
pointer from the socket if provided.
Fixes: 168a8f58059a ("tcp: TCP Fast Open Server - main code path")
Reported-by: Neal Cardwell <ncardwell@google.com>
Cc: Jerry Chu <hkchu@google.com>
Cc: Yuchung Cheng <ycheng@google.com>
Acked-by: Neal Cardwell <ncardwell@google.com>
[ Upstream commit 5037e9ef9454917b047f9f3a19b4dd179fbf7cd4 ]
David Wilder reported crashes caused by dst reuse.
<quote David>
I am seeing a crash on a distro V4.2.3 kernel caused by a double
release of a dst_entry. In ipv4_dst_destroy() the call to
list_empty() finds a poisoned next pointer, indicating the dst_entry
has already been removed from the list and freed. The crash occurs
18 to 24 hours into a run of a network stress exerciser.
</quote>
Thanks to his detailed report and analysis, we were able to understand
the core issue.
IP early demux can associate a dst to skb, after a lookup in TCP/UDP
sockets.
When socket cache is not properly set, we want to store into
sk->sk_dst_cache the dst for future IP early demux lookups,
by acquiring a stable refcount on the dst.
Problem is this acquisition is simply using an atomic_inc(),
which works well, unless the dst was queued for destruction from
dst_release() noticing dst refcount went to zero, if DST_NOCACHE
was set on dst.
We need to make sure current refcount is not zero before incrementing
it, or risk double free as David reported.
This patch, being a stable candidate, adds two new helpers, and use
them only from IP early demux problematic paths.
It might be possible to merge in net-next skb_dst_force() and
skb_dst_force_safe(), but I prefer having the smallest patch for stable
kernels : Maybe some skb_dst_force() callers do not expect skb->dst
can suddenly be cleared.
Can probably be backported back to linux-3.6 kernels
Reported-by: David J. Wilder <dwilder@us.ibm.com>
Tested-by: David J. Wilder <dwilder@us.ibm.com>
[ Upstream commit 1b8e6a01e19f001e9f93b39c32387961c91ed3cc ]
When a passive TCP is created, we eventually call tcp_md5_do_add()
with sk pointing to the child. It is not owner by the user yet (we
will add this socket into listener accept queue a bit later anyway)
But we do own the spinlock, so amend the lockdep annotation to avoid
following splat :
[ 8451.090932] net/ipv4/tcp_ipv4.c:923 suspicious rcu_dereference_protected() usage!
[ 8451.090932]
[ 8451.090932] other info that might help us debug this:
[ 8451.090932]
[ 8451.090934]
[ 8451.090934] rcu_scheduler_active = 1, debug_locks = 1
[ 8451.090936] 3 locks held by socket_sockopt_/214795:
[ 8451.090936] #0: (rcu_read_lock){.+.+..}, at: [<ffffffff855c6ac1>] __netif_receive_skb_core+0x151/0xe90
[ 8451.090947] #1: (rcu_read_lock){.+.+..}, at: [<ffffffff85618143>] ip_local_deliver_finish+0x43/0x2b0
[ 8451.090952] #2: (slock-AF_INET){+.-...}, at: [<ffffffff855acda5>] sk_clone_lock+0x1c5/0x500
[ 8451.090958]
[ 8451.090958] stack backtrace:
[ 8451.090960] CPU: 7 PID: 214795 Comm: socket_sockopt_
[ 8451.091215] Call Trace:
[ 8451.091216] <IRQ> [<ffffffff856fb29c>] dump_stack+0x55/0x76
[ 8451.091229] [<ffffffff85123b5b>] lockdep_rcu_suspicious+0xeb/0x110
[ 8451.091235] [<ffffffff8564544f>] tcp_md5_do_add+0x1bf/0x1e0
[ 8451.091239] [<ffffffff85645751>] tcp_v4_syn_recv_sock+0x1f1/0x4c0
[ 8451.091242] [<ffffffff85642b27>] ? tcp_v4_md5_hash_skb+0x167/0x190
[ 8451.091246] [<ffffffff85647c78>] tcp_check_req+0x3c8/0x500
[ 8451.091249] [<ffffffff856451ae>] ? tcp_v4_inbound_md5_hash+0x11e/0x190
[ 8451.091253] [<ffffffff85647170>] tcp_v4_rcv+0x3c0/0x9f0
[ 8451.091256] [<ffffffff85618143>] ? ip_local_deliver_finish+0x43/0x2b0
[ 8451.091260] [<ffffffff856181b6>] ip_local_deliver_finish+0xb6/0x2b0
[ 8451.091263] [<ffffffff85618143>] ? ip_local_deliver_finish+0x43/0x2b0
[ 8451.091267] [<ffffffff85618d38>] ip_local_deliver+0x48/0x80
[ 8451.091270] [<ffffffff85618510>] ip_rcv_finish+0x160/0x700
[ 8451.091273] [<ffffffff8561900e>] ip_rcv+0x29e/0x3d0
[ 8451.091277] [<ffffffff855c74b7>] __netif_receive_skb_core+0xb47/0xe90
Fixes: a8afca0329988 ("tcp: md5: protects md5sig_info with RCU")
Reported-by: Willem de Bruijn <willemb@google.com>
[ Upstream commit 3257d8b12f954c462d29de6201664a846328a522 ]
In commit b357a364c57c9 ("inet: fix possible panic in
reqsk_queue_unlink()"), I missed fact that tcp_check_req()
can return the listener socket in one case, and that we must
release the request socket refcount or we leak it.
Tested:
Following packetdrill test template shows the issue
0 socket(..., SOCK_STREAM, IPPROTO_TCP) = 3
+0 setsockopt(3, SOL_SOCKET, SO_REUSEADDR, [1], 4) = 0
+0 bind(3, ..., ...) = 0
+0 listen(3, 1) = 0
+0 < S 0:0(0) win 2920 <mss 1460,sackOK,nop,nop>
+0 > S. 0:0(0) ack 1 <mss 1460,nop,nop,sackOK>
+.002 < . 1:1(0) ack 21 win 2920
+0 > R 21:21(0)
Fixes: b357a364c57c9 ("inet: fix possible panic in reqsk_queue_unlink()")
[ 3897.923145] BUG: unable to handle kernel NULL pointer dereference at
0000000000000080
[ 3897.931025] IP: [<ffffffffa9f27686>] reqsk_timer_handler+0x1a6/0x243
There is a race when reqsk_timer_handler() and tcp_check_req() call
inet_csk_reqsk_queue_unlink() on the same req at the same time.
Before commit fa76ce7328b2 ("inet: get rid of central tcp/dccp listener
timer"), listener spinlock was held and race could not happen.
To solve this bug, we change reqsk_queue_unlink() to not assume req
must be found, and we return a status, to conditionally release a
refcount on the request sock.
This also means tcp_check_req() in non fastopen case might or not
consume req refcount, so tcp_v6_hnd_req() & tcp_v4_hnd_req() have
to properly handle this.
(Same remark for dccp_check_req() and its callers)
inet_csk_reqsk_queue_drop() is now too big to be inlined, as it is
called 4 times in tcp and 3 times in dccp.
Fixes: fa76ce7328b2 ("inet: get rid of central tcp/dccp listener timer")
Reported-by: Yuchung Cheng <ycheng@google.com>
Using a timer wheel for timewait sockets was nice ~15 years ago when
memory was expensive and machines had a single processor.
This does not scale, code is ugly and source of huge latencies
(Typically 30 ms have been seen, cpus spinning on death_lock spinlock.)
We can afford to use an extra 64 bytes per timewait sock and spread
timewait load to all cpus to have better behavior.
Tested:
On following test, /proc/sys/net/ipv4/tcp_tw_recycle is set to 1
on the target (lpaa24)
Before patch :
lpaa23:~# ./super_netperf 200 -H lpaa24 -t TCP_CC -l 60 -- -p0,0
419594
437171
While test is running, we can observe 25 or even 33 ms latencies.
lpaa24:~# ping -c 1000 -i 0.02 -qn lpaa23
1000 packets transmitted, 1000 received, 0% packet loss, time 20601ms
rtt min/avg/max/mdev = 0.020/0.217/25.771/1.535 ms, pipe 2
1000 packets transmitted, 1000 received, 0% packet loss, time 20702ms
rtt min/avg/max/mdev = 0.019/0.183/33.761/1.441 ms, pipe 2
After patch :
About 90% increase of throughput :
810442
800992
And latencies are kept to minimal values during this load, even
if network utilization is 90% higher :
1000 packets transmitted, 1000 received, 0% packet loss, time 19991ms
rtt min/avg/max/mdev = 0.023/0.064/0.360/0.042 ms
Lookup key for tcp_md5_do_lookup() has to be taken
from addr_sk, not sk (which can be the listener)
Fixes: fd3a154a00fb ("tcp: md5: get rid of tcp_v[46]_reqsk_md5_lookup()")
The ipv4 code uses a mixture of coding styles. In some instances check
for non-NULL pointer is done as x != NULL and sometimes as x. x is
preferred according to checkpatch and this patch makes the code
consistent by adopting the latter form.
No changes detected by objdiff.
Signed-off-by: Ian Morris <ipm@chirality.org.uk>
for NULL pointer is done as x == NULL and sometimes as !x. !x is
drivers/net/usb/asix_common.c
drivers/net/usb/sr9800.c
drivers/net/usb/usbnet.c
include/linux/usb/usbnet.h
net/ipv4/tcp_ipv4.c
net/ipv6/tcp_ipv6.c
The TCP conflicts were overlapping changes. In 'net' we added a
READ_ONCE() to the socket cached RX route read, whilst in 'net-next'
Eric Dumazet touched the surrounding code dealing with how mini
sockets are handled.
With USB, it's a case of the same bug fix first going into net-next
and then I cherry picked it back into net.
After commit 1fb6f159fd21 ("tcp: add tcp_conn_request"),
tcp_syn_flood_action() is no longer used from IPv6.
We can make it static, by moving it above tcp_conn_request()
Reviewed-by: Octavian Purdila <octavian.purdila@intel.com>
ss should display ipv4 mapped request sockets like this :
tcp SYN-RECV 0 0 ::ffff:192.168.0.1:8080 ::ffff:192.0.2.1:35261
and not like this :
tcp SYN-RECV 0 0 192.168.0.1:8080 192.0.2.1:35261
We should init ireq->ireq_family based on listener sk_family,
not the actual protocol carried by SYN packet.
This means we can set ireq_family in inet_reqsk_alloc()
Fixes: 3f66b083a5b7 ("inet: introduce ireq_family")
With request socks convergence, we no longer need
different lookup methods. A request socket can
use generic lookup function.
Add const qualifier to 2nd tcp_v[46]_md5_lookup() parameter.
Since request and established sockets now have same base,
there is no need to pass two pointers to tcp_v4_md5_hash_skb()
or tcp_v6_md5_hash_skb()
Also add a const qualifier to their struct tcp_md5sig_key argument.
It is guaranteed that both tcp_v4_rcv() and tcp_v6_rcv()
run from rcu read locked sections :
ip_local_deliver_finish() and ip6_input_finish() both
use rcu_read_lock()
Also align tcp_v6_inbound_md5_hash() on tcp_v4_inbound_md5_hash()
by returning a boolean.
On s390x, gcc 4.8 compiles this part of tcp_v6_early_demux()
struct dst_entry *dst = sk->sk_rx_dst;
if (dst)
dst = dst_check(dst, inet6_sk(sk)->rx_dst_cookie);
to code reading sk->sk_rx_dst twice, once for the test and once for
the argument of ip6_dst_check() (dst_check() is inline). This allows
ip6_dst_check() to be called with null first argument, causing a crash.
Protect sk->sk_rx_dst access by READ_ONCE() both in IPv4 and IPv6
TCP early demux code.
Fixes: 41063e9dd119 ("ipv4: Early TCP socket demux.")
Fixes: c7109986db3c ("ipv6: Early TCP socket demux")
Signed-off-by: Michal Kubecek <mkubecek@suse.cz>
Eric Hugne reported following error :
I'm hitting this warning on latest net-next when i try to SSH into a machine
with eth0 added to a bridge (but i think the problem is older than that)
Steps to reproduce:
node2 ~ # brctl addif br0 eth0
[ 223.758785] device eth0 entered promiscuous mode
node2 ~ # ip link set br0 up
[ 244.503614] br0: port 1(eth0) entered forwarding state
[ 244.505108] br0: port 1(eth0) entered forwarding state
node2 ~ # [ 251.160159] ------------[ cut here ]------------
[ 251.160831] WARNING: CPU: 0 PID: 3 at include/net/request_sock.h:102 tcp_v4_err+0x6b1/0x720()
[ 251.162077] Modules linked in:
[ 251.162496] CPU: 0 PID: 3 Comm: ksoftirqd/0 Not tainted 4.0.0-rc3+ #18
[ 251.163334] Hardware name: Bochs Bochs, BIOS Bochs 01/01/2011
[ 251.164078] ffffffff81a8365c ffff880038a6ba18 ffffffff8162ace4 0000000000009898
[ 251.165084] 0000000000000000 ffff880038a6ba58 ffffffff8104da85 ffff88003fa437c0
[ 251.166195] ffff88003fa437c0 ffff88003fa74e00 ffff88003fa43bb8 ffff88003fad99a0
[ 251.167203] Call Trace:
[ 251.167533] [<ffffffff8162ace4>] dump_stack+0x45/0x57
[ 251.168206] [<ffffffff8104da85>] warn_slowpath_common+0x85/0xc0
[ 251.169239] [<ffffffff8104db65>] warn_slowpath_null+0x15/0x20
[ 251.170271] [<ffffffff81559d51>] tcp_v4_err+0x6b1/0x720
[ 251.171408] [<ffffffff81630d03>] ? _raw_read_lock_irq+0x3/0x10
[ 251.172589] [<ffffffff81534e20>] ? inet_del_offload+0x40/0x40
[ 251.173366] [<ffffffff81569295>] icmp_socket_deliver+0x65/0xb0
[ 251.174134] [<ffffffff815693a2>] icmp_unreach+0xc2/0x280
[ 251.174820] [<ffffffff8156a82d>] icmp_rcv+0x2bd/0x3a0
[ 251.175473] [<ffffffff81534ea2>] ip_local_deliver_finish+0x82/0x1e0
[ 251.176282] [<ffffffff815354d8>] ip_local_deliver+0x88/0x90
[ 251.177004] [<ffffffff815350f0>] ip_rcv_finish+0xf0/0x310
[ 251.177693] [<ffffffff815357bc>] ip_rcv+0x2dc/0x390
[ 251.178336] [<ffffffff814f5da3>] __netif_receive_skb_core+0x713/0xa20
[ 251.179170] [<ffffffff814f7fca>] __netif_receive_skb+0x1a/0x80
[ 251.179922] [<ffffffff814f97d4>] process_backlog+0x94/0x120
[ 251.180639] [<ffffffff814f9612>] net_rx_action+0x1e2/0x310
[ 251.181356] [<ffffffff81051267>] __do_softirq+0xa7/0x290
[ 251.182046] [<ffffffff81051469>] run_ksoftirqd+0x19/0x30
[ 251.182726] [<ffffffff8106cc23>] smpboot_thread_fn+0x153/0x1d0
[ 251.183485] [<ffffffff8106cad0>] ? SyS_setgroups+0x130/0x130
[ 251.184228] [<ffffffff8106935e>] kthread+0xee/0x110
[ 251.184871] [<ffffffff81069270>] ? kthread_create_on_node+0x1b0/0x1b0
[ 251.185690] [<ffffffff81631108>] ret_from_fork+0x58/0x90
[ 251.186385] [<ffffffff81069270>] ? kthread_create_on_node+0x1b0/0x1b0
[ 251.187216] ---[ end trace c947fc7b24e42ea1 ]---
[ 259.542268] br0: port 1(eth0) entered forwarding state
Remove the double calls to reqsk_put()
[edumazet] :
I got confused because reqsk_timer_handler() _has_ to call
reqsk_put(req) after calling inet_csk_reqsk_queue_drop(), as
the timer handler holds a reference on req.
Signed-off-by: Fan Du <fan.du@intel.com>
Reported-by: Erik Hugne <erik.hugne@ericsson.com>
tcp_v4_err() can restrict lookups to ehash table, and not to listeners.
Note this patch creates the infrastructure, but this means that ICMP
messages for request sockets are ignored until complete conversion.
New tcp_req_err() helper is exported so that we can use it in IPv6
in following patch.
This is a low hanging fruit, as we'll get rid of syn_wait_lock eventually.
We hold syn_wait_lock for such small sections, that it makes no sense to use
a read/write lock. A spin lock is simply faster.
One of the major issue for TCP is the SYNACK rtx handling,
done by inet_csk_reqsk_queue_prune(), fired by the keepalive
timer of a TCP_LISTEN socket.
This function runs for awful long times, with socket lock held,
meaning that other cpus needing this lock have to spin for hundred of ms.
SYNACK are sent in huge bursts, likely to cause severe drops anyway.
This model was OK 15 years ago when memory was very tight.
We now can afford to have a timer per request sock.
Timer invocations no longer need to lock the listener,
and can be run from all cpus in parallel.
With following patch increasing somaxconn width to 32 bits,
I tested a listener with more than 4 million active request sockets,
and a steady SYNFLOOD of ~200,000 SYN per second.
Host was sending ~830,000 SYNACK per second.
This is ~100 times more what we could achieve before this patch.
Later, we will get rid of the listener hash and use ehash instead.
When request sock are put in ehash table, the whole notion
of having a previous request to update dl_next is pointless.
Also, following patch will get rid of big purge timer,
so we want to delete a request sock without holding listener lock.
In order to be able to use sk_ehashfn() for request socks,
we need to initialize their IPv6/IPv4 addresses.
Intent is to converge IPv4 & IPv6 inet_hash functions to
factorize code.
IPv4 sockets initialize sk_rcv_saddr and sk_v6_daddr
in this patch, thanks to new sk_daddr_set() and sk_rcv_saddr_set()
helpers.
__inet6_hash can now use sk_ehashfn() instead of a private
inet6_sk_ehashfn() and will simply use __inet_hash() in a
following patch.
When a request socket is created, we do not cache ip route
dst entry, like for timewait sockets.
Let's use sk_fullsock() helper.
Before inserting request socks into general hash table,
fill their socket family.
ireq->ir_num contains local port, use it.
Also, get_openreq4() dumping listen_sk->refcnt makes litle sense.
inet_diag_fill_req() can also use ireq->ir_num
As per RFC4821 7.3. Selecting Probe Size, a probe timer should
be armed once probing has converged. Once this timer expired,
probing again to take advantage of any path PMTU change. The
recommended probing interval is 10 minutes per RFC1981. Probing
interval could be sysctled by sysctl_tcp_probe_interval.
Eric Dumazet suggested to implement pseudo timer based on 32bits
jiffies tcp_time_stamp instead of using classic timer for such
rare event.
Current probe_size is chosen by doubling mss_cache,
the probing process will end shortly with a sub-optimal
mss size, and the link mtu will not be taken full
advantage of, in return, this will make user to tweak
tcp_base_mss with care.
Use binary search to choose probe_size in a fine
granularity manner, an optimal mss will be found
to boost performance as its maxmium.
In addition, introduce a sysctl_tcp_probe_threshold
to control when probing will stop in respect to
the width of search range.
Test env:
Docker instance with vxlan encapuslation(82599EB)
iperf -c 10.0.0.24 -t 60
before this patch:
1.26 Gbits/sec
After this patch: increase 26%
1.59 Gbits/sec
Acked-by: John Heffner <johnwheffner@gmail.com>
Packetization Layer Path MTU Discovery works separately beside
Path MTU Discovery at IP level, different net namespace has
various requirements on which one to chose, e.g., a virutalized
container instance would require TCP PMTU to probe an usable
effective mtu for underlying tunnel, while the host would
employ classical ICMP based PMTU to function.
Hence making TCP PMTU mechanism per net namespace to decouple
two functionality. Furthermore the probe base MSS should also
be configured separately for each namespace.
drivers/net/vxlan.c
drivers/vhost/net.c
include/linux/if_vlan.h
net/core/dev.c
The net/core/dev.c conflict was the overlap of one commit marking an
existing function static whilst another was adding a new function.
In the include/linux/if_vlan.h case, the type used for a local
variable was changed in 'net', whereas the function got rewritten
to fix a stacked vlan bug in 'net-next'.
In drivers/vhost/net.c, Al Viro's iov_iter conversions in 'net-next'
overlapped with an endainness fix for VHOST 1.0 in 'net'.
In drivers/net/vxlan.c, vxlan_find_vni() added a 'flags' parameter
in 'net-next' whereas in 'net' there was a bug fix to pass in the
correct network namespace pointer in calls to this function.
In commit be9f4a44e7d41 ("ipv4: tcp: remove per net tcp_sock")
I tried to address contention on a socket lock, but the solution
I chose was horrible :
commit 3a7c384ffd57e ("ipv4: tcp: unicast_sock should not land outside
of TCP stack") addressed a selinux regression.
commit 0980e56e506b ("ipv4: tcp: set unicast_sock uc_ttl to -1")
took care of another regression.
commit b5ec8eeac46 ("ipv4: fix ip_send_skb()") fixed another regression.
commit 811230cd85 ("tcp: ipv4: initialize unicast_sock sk_pacing_rate")
was another shot in the dark.
Really, just use a proper socket per cpu, and remove the skb_orphan()
call, to re-enable flow control.
This solves a serious problem with FQ packet scheduler when used in
hostile environments, as we do not want to allocate a flow structure
for every RST packet sent in response to a spoofed packet.
This work adds the possibility to define a per route/destination
congestion control algorithm. Generally, this opens up the possibility
for a machine with different links to enforce specific congestion
control algorithms with optimal strategies for each of them based
on their network characteristics, even transparently for a single
application listening on all links.
For our specific use case, this additionally facilitates deployment
of DCTCP, for example, applications can easily serve internal
traffic/dsts in DCTCP and external one with CUBIC. Other scenarios
would also allow for utilizing e.g. long living, low priority
background flows for certain destinations/routes while still being
able for normal traffic to utilize the default congestion control
algorithm. We also thought about a per netns setting (where different
defaults are possible), but given its actually a link specific
property, we argue that a per route/destination setting is the most
natural and flexible.
The administrator can utilize this through ip-route(8) by appending
"congctl [lock] <name>", where <name> denotes the name of a
congestion control algorithm and the optional lock parameter allows
to enforce the given algorithm so that applications in user space
would not be allowed to overwrite that algorithm for that destination.
The dst metric lookups are being done when a dst entry is already
available in order to avoid a costly lookup and still before the
algorithms are being initialized, thus overhead is very low when the
feature is not being used. While the client side would need to drop
the current reference on the module, on server side this can actually
even be avoided as we just got a flat-copied socket clone.
Joint work with Florian Westphal.
Suggested-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
drivers/net/ethernet/amd/xgbe/xgbe-desc.c
drivers/net/ethernet/renesas/sh_eth.c
Overlapping changes in both conflict cases.
When I cooked commit c3658e8d0f1 ("tcp: fix possible NULL dereference in
tcp_vX_send_reset()") I missed other spots we could deref a NULL
skb_dst(skb)
Again, if a socket is provided, we do not need skb_dst() to get a
pointer to network namespace : sock_net(sk) is good enough.
Reported-by: Dann Frazier <dann.frazier@canonical.com>
Bisected-by: Dann Frazier <dann.frazier@canonical.com>
Tested-by: Dann Frazier <dann.frazier@canonical.com>
Fixes: ca777eff51f7 ("tcp: remove dst refcount false sharing for prequeue mode")
After commit ca777eff51f7 ("tcp: remove dst refcount false sharing for
prequeue mode") we have to relax check against skb dst in
tcp_v[46]_send_reset() if prequeue dropped the dst.
If a socket is provided, a full lookup was done to find this socket,
so the dst test can be skipped.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=88191
Reported-by: Jaša Bartelj <jasa.bartelj@gmail.com>
Reported-by: Daniel Borkmann <dborkman@redhat.com>
Alternative to RPS/RFS is to use hardware support for multiple
queues.
Then split a set of million of sockets into worker threads, each
one using epoll() to manage events on its own socket pool.
Ideally, we want one thread per RX/TX queue/cpu, but we have no way to
know after accept() or connect() on which queue/cpu a socket is managed.
We normally use one cpu per RX queue (IRQ smp_affinity being properly
set), so remembering on socket structure which cpu delivered last packet
is enough to solve the problem.
After accept(), connect(), or even file descriptor passing around
processes, applications can use :
int cpu;
socklen_t len = sizeof(cpu);
getsockopt(fd, SOL_SOCKET, SO_INCOMING_CPU, &cpu, &len);
And use this information to put the socket into the right silo
for optimal performance, as all networking stack should run
on the appropriate cpu, without need to send IPI (RPS/RFS).
sk_mark_napi_id() is used to record for a flow napi id of incoming
packets for busypoll sake.
We should do this only on established flows, not on listeners.
This was 'working' by virtue of the socket cloning, but doing
this on SYN packets in unecessary cache line dirtying.
Even if we move sk_napi_id in the same cache line than sk_lock,
we are working to make SYN processing lockless, so it is desirable
to set sk_napi_id only for established flows.
The commit "net: Save TX flow hash in sock and set in skbuf on xmit"
introduced the inet_set_txhash() and ip6_set_txhash() routines to calculate
and record flow hash(sk_txhash) in the socket structure. sk_txhash is used
to set skb->hash which is used to spread flows across multiple TXQs.
But, the above routines are invoked before the source port of the connection
is created. Because of this all outgoing connections that just differ in the
source port get hashed into the same TXQ.
This patch fixes this problem for IPv4/6 by invoking the the above routines
after the source port is available for the socket.
Fixes: b73c3d0e4("net: Save TX flow hash in sock and set in skbuf on xmit")
Signed-off-by: Sathya Perla <sathya.perla@emulex.com>
We can retrieve opt from skb, no need to pass it as a parameter.
And opt should always be non-NULL, no need to check.
Cc: Krzysztof Kolasa <kkolasa@winsoft.pl>
Cc: Eric Dumazet <edumazet@google.com>
Tested-by: Krzysztof Kolasa <kkolasa@winsoft.pl>
Signed-off-by: Cong Wang <cwang@twopensource.com>
cookie_v4_check() allocates ip_options_rcu in the same way
with tcp_v4_save_options(), we can just make it a helper function.
Pull networking updates from David Miller:
"Most notable changes in here:
1) By far the biggest accomplishment, thanks to a large range of
contributors, is the addition of multi-send for transmit. This is
the result of discussions back in Chicago, and the hard work of
several individuals.
Now, when the ->ndo_start_xmit() method of a driver sees
skb->xmit_more as true, it can choose to defer the doorbell
telling the driver to start processing the new TX queue entires.
skb->xmit_more means that the generic networking is guaranteed to
call the driver immediately with another SKB to send.
There is logic added to the qdisc layer to dequeue multiple
packets at a time, and the handling mis-predicted offloads in
software is now done with no locks held.
Finally, pktgen is extended to have a "burst" parameter that can
be used to test a multi-send implementation.
Several drivers have xmit_more support: i40e, igb, ixgbe, mlx4,
virtio_net
Adding support is almost trivial, so export more drivers to
support this optimization soon.
I want to thank, in no particular or implied order, Jesper
Dangaard Brouer, Eric Dumazet, Alexander Duyck, Tom Herbert, Jamal
Hadi Salim, John Fastabend, Florian Westphal, Daniel Borkmann,
David Tat, Hannes Frederic Sowa, and Rusty Russell.
2) PTP and timestamping support in bnx2x, from Michal Kalderon.
3) Allow adjusting the rx_copybreak threshold for a driver via
ethtool, and add rx_copybreak support to enic driver. From
Govindarajulu Varadarajan.
4) Significant enhancements to the generic PHY layer and the bcm7xxx
driver in particular (EEE support, auto power down, etc.) from
Florian Fainelli.
5) Allow raw buffers to be used for flow dissection, allowing drivers
to determine the optimal "linear pull" size for devices that DMA
into pools of pages. The objective is to get exactly the
necessary amount of headers into the linear SKB area pre-pulled,
but no more. The new interface drivers use is eth_get_headlen().
From WANG Cong, with driver conversions (several had their own
by-hand duplicated implementations) by Alexander Duyck and Eric
Dumazet.
6) Support checksumming more smoothly and efficiently for
encapsulations, and add "foo over UDP" facility. From Tom
Herbert.
7) Add Broadcom SF2 switch driver to DSA layer, from Florian
Fainelli.
8) eBPF now can load programs via a system call and has an extensive
testsuite. Alexei Starovoitov and Daniel Borkmann.
9) Major overhaul of the packet scheduler to use RCU in several major
areas such as the classifiers and rate estimators. From John
Fastabend.
10) Add driver for Intel FM10000 Ethernet Switch, from Alexander
Duyck.
11) Rearrange TCP_SKB_CB() to reduce cache line misses, from Eric
Dumazet.
12) Add Datacenter TCP congestion control algorithm support, From
Florian Westphal.
13) Reorganize sk_buff so that __copy_skb_header() is significantly
faster. From Eric Dumazet"
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1558 commits)
netlabel: directly return netlbl_unlabel_genl_init()
net: add netdev_txq_bql_{enqueue, complete}_prefetchw() helpers
net: description of dma_cookie cause make xmldocs warning
cxgb4: clean up a type issue
cxgb4: potential shift wrapping bug
i40e: skb->xmit_more support
net: fs_enet: Add NAPI TX
net: fs_enet: Remove non NAPI RX
r8169:add support for RTL8168EP
net_sched: copy exts->type in tcf_exts_change()
wimax: convert printk to pr_foo()
af_unix: remove 0 assignment on static
ipv6: Do not warn for informational ICMP messages, regardless of type.
Update Intel Ethernet Driver maintainers list
bridge: Save frag_max_size between PRE_ROUTING and POST_ROUTING
tipc: fix bug in multicast congestion handling
net: better IFF_XMIT_DST_RELEASE support
net/mlx4_en: remove NETDEV_TX_BUSY
3c59x: fix bad split of cpu_to_le32(pci_map_single())
net: bcmgenet: fix Tx ring priority programming
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/dmaengine
Pull dmaengine updates from Dan Williams:
"Even though this has fixes marked for -stable, given the size and the
needed conflict resolutions this is 3.18-rc1/merge-window material.
These patches have been languishing in my tree for a long while. The
fact that I do not have the time to do proper/prompt maintenance of
this tree is a primary factor in the decision to step down as
dmaengine maintainer. That and the fact that the bulk of drivers/dma/
activity is going through Vinod these days.
The net_dma removal has not been in -next. It has developed simple
conflicts against mainline and net-next (for-3.18).
Continuing thanks to Vinod for staying on top of drivers/dma/.
Summary:
1/ Step down as dmaengine maintainer see commit 08223d80df38
"dmaengine maintainer update"
2/ Removal of net_dma, as it has been marked 'broken' since 3.13
(commit 77873803363c "net_dma: mark broken"), without reports of
performance regression.
3/ Miscellaneous fixes"
* tag 'dmaengine-3.17' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/dmaengine:
net: make tcp_cleanup_rbuf private
net_dma: revert 'copied_early'
net_dma: simple removal
dmatest: prevent memory leakage on error path in thread
ioat: Use time_before_jiffies()
dmaengine: fix xor sources continuation
dma: mv_xor: Rename __mv_xor_slot_cleanup() to mv_xor_slot_cleanup()
dma: mv_xor: Remove all callers of mv_xor_slot_cleanup()
dma: mv_xor: Remove unneeded mv_xor_clean_completed_slots() call
ioat: Use pci_enable_msix_exact() instead of pci_enable_msix()
drivers: dma: Include appropriate header file in dca.c
drivers: dma: Mark functions as static in dma_v3.c
dma: mv_xor: Add DMA API error checks
ioat/dca: Use dev_is_pci() to check whether it is pci device
TCP maintains lists of skb in write queue, and in receive queues
(in order and out of order queues)
Scanning these lists both in input and output path usually requires
access to skb->next, TCP_SKB_CB(skb)->seq, and TCP_SKB_CB(skb)->end_seq
These fields are currently in two different cache lines, meaning we
waste lot of memory bandwidth when these queues are big and flows
have either packet drops or packet reorders.
We can move TCP_SKB_CB(skb)->header at the end of TCP_SKB_CB, because
this header is not used in fast path. This allows TCP to search much faster
in the skb lists.
Even with regular flows, we save one cache line miss in fast path.
Thanks to Christoph Paasch for noticing we need to cleanup
skb->cb[] (IPCB/IP6CB) before entering IP stack in tx path,
and that I forgot IPCB use in tcp_v4_hnd_req() and tcp_v4_save_options().
ip_options_echo() assumes struct ip_options is provided in &IPCB(skb)->opt
Lets break this assumption, but provide a helper to not change all call points.
ip_send_unicast_reply() gets a new struct ip_options pointer.
Per commit "77873803363c net_dma: mark broken" net_dma is no longer used
and there is no plan to fix it.
This is the mechanical removal of bits in CONFIG_NET_DMA ifdef guards.
Reverting the remainder of the net_dma induced changes is deferred to
subsequent patches.
Marked for stable due to Roman's report of a memory leak in
dma_pin_iovec_pages():
https://lkml.org/lkml/2014/9/3/177
Cc: Dave Jiang <dave.jiang@intel.com>
Cc: Vinod Koul <vinod.koul@intel.com>
Cc: David Whipple <whipple@securedatainnovations.ch>
Cc: Alexander Duyck <alexander.h.duyck@intel.com>
Cc: <stable@vger.kernel.org>
Reported-by: Roman Gushchin <klamm@yandex-team.ru>
icsk_rto is a 32bit field, and icsk_backoff can reach 15 by default,
or more if some sysctl (eg tcp_retries2) are changed.
Better use 64bit to perform icsk_rto << icsk_backoff operations
As Joe Perches suggested, add a helper for this.
Yuchung spotted the tcp_v4_err() case.
Input path of TCP do not currently uses TCP_SKB_CB(skb)->tcp_flags,
which is only used in output path.
tcp_recvmsg(), looks at tcp_hdr(skb)->syn for every skb found in receive queue,
and its unfortunate because this bit is located in a cache line right before
the payload.
We can simplify TCP by copying tcp flags into TCP_SKB_CB(skb)->tcp_flags.
This patch does so, and avoids the cache line miss in tcp_recvmsg()
Following patches will
- allow a segment with FIN being coalesced in tcp_try_coalesce()
- simplify tcp_collapse() by not copying the headers.
Alexander Duyck reported high false sharing on dst refcount in tcp stack
when prequeue is used. prequeue is the mechanism used when a thread is
blocked in recvmsg()/read() on a TCP socket, using a blocking model
rather than select()/poll()/epoll() non blocking one.
We already try to use RCU in input path as much as possible, but we were
forced to take a refcount on the dst when skb escaped RCU protected
region. When/if the user thread runs on different cpu, dst_release()
will then touch dst refcount again.
Commit 093162553c33 (tcp: force a dst refcount when prequeue packet)
was an example of a race fix.
It turns out the only remaining usage of skb->dst for a packet stored
in a TCP socket prequeue is IP early demux.
We can add a logic to detect when IP early demux is probably going
to use skb->dst. Because we do an optimistic check rather than duplicate
existing logic, we need to guard inet_sk_rx_dst_set() and
inet6_sk_rx_dst_set() from using a NULL dst.
Many thanks to Alexander for providing a nice bug report, git bisection,
and reproducer.
Tested using Alexander script on a 40Gb NIC, 8 RX queues.
Hosts have 24 cores, 48 hyper threads.
echo 0 >/proc/sys/net/ipv4/tcp_autocorking
for i in `seq 0 47`
do
for j in `seq 0 2`
do
netperf -H $DEST -t TCP_STREAM -l 1000 \
-c -C -T $i,$i -P 0 -- \
-m 64 -s 64K -D &
done
done
Before patch : ~6Mpps and ~95% cpu usage on receiver
After patch : ~9Mpps and ~35% cpu usage on receiver.
Reported-by: Alexander Duyck <alexander.h.duyck@intel.com>
After commit 740b0f1841f6 ("tcp: switch rtt estimations to usec resolution"),
we no longer need to maintain timestamps in two different fields.
TCP_SKB_CB(skb)->when can be removed, as same information sits in skb_mstamp.stamp_jiffies
Acked-by: Yuchung Cheng <ycheng@google.com>
