After commit ca777eff51f7 ("tcp: remove dst refcount false sharing for
prequeue mode") we have to relax check against skb dst in
tcp_v[46]_send_reset() if prequeue dropped the dst.
If a socket is provided, a full lookup was done to find this socket,
so the dst test can be skipped.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=88191
Reported-by: Jaša Bartelj <jasa.bartelj@gmail.com>
Reported-by: Daniel Borkmann <dborkman@redhat.com>
Fixes: ca777eff51f7 ("tcp: remove dst refcount false sharing for prequeue mode")
The commit "net: Save TX flow hash in sock and set in skbuf on xmit"
introduced the inet_set_txhash() and ip6_set_txhash() routines to calculate
and record flow hash(sk_txhash) in the socket structure. sk_txhash is used
to set skb->hash which is used to spread flows across multiple TXQs.
But, the above routines are invoked before the source port of the connection
is created. Because of this all outgoing connections that just differ in the
source port get hashed into the same TXQ.
This patch fixes this problem for IPv4/6 by invoking the the above routines
after the source port is available for the socket.
Fixes: b73c3d0e4("net: Save TX flow hash in sock and set in skbuf on xmit")
Signed-off-by: Sathya Perla <sathya.perla@emulex.com>
We can retrieve opt from skb, no need to pass it as a parameter.
And opt should always be non-NULL, no need to check.
Cc: Krzysztof Kolasa <kkolasa@winsoft.pl>
Cc: Eric Dumazet <edumazet@google.com>
Tested-by: Krzysztof Kolasa <kkolasa@winsoft.pl>
Signed-off-by: Cong Wang <cwang@twopensource.com>
cookie_v4_check() allocates ip_options_rcu in the same way
with tcp_v4_save_options(), we can just make it a helper function.
Pull networking updates from David Miller:
"Most notable changes in here:
1) By far the biggest accomplishment, thanks to a large range of
contributors, is the addition of multi-send for transmit. This is
the result of discussions back in Chicago, and the hard work of
several individuals.
Now, when the ->ndo_start_xmit() method of a driver sees
skb->xmit_more as true, it can choose to defer the doorbell
telling the driver to start processing the new TX queue entires.
skb->xmit_more means that the generic networking is guaranteed to
call the driver immediately with another SKB to send.
There is logic added to the qdisc layer to dequeue multiple
packets at a time, and the handling mis-predicted offloads in
software is now done with no locks held.
Finally, pktgen is extended to have a "burst" parameter that can
be used to test a multi-send implementation.
Several drivers have xmit_more support: i40e, igb, ixgbe, mlx4,
virtio_net
Adding support is almost trivial, so export more drivers to
support this optimization soon.
I want to thank, in no particular or implied order, Jesper
Dangaard Brouer, Eric Dumazet, Alexander Duyck, Tom Herbert, Jamal
Hadi Salim, John Fastabend, Florian Westphal, Daniel Borkmann,
David Tat, Hannes Frederic Sowa, and Rusty Russell.
2) PTP and timestamping support in bnx2x, from Michal Kalderon.
3) Allow adjusting the rx_copybreak threshold for a driver via
ethtool, and add rx_copybreak support to enic driver. From
Govindarajulu Varadarajan.
4) Significant enhancements to the generic PHY layer and the bcm7xxx
driver in particular (EEE support, auto power down, etc.) from
Florian Fainelli.
5) Allow raw buffers to be used for flow dissection, allowing drivers
to determine the optimal "linear pull" size for devices that DMA
into pools of pages. The objective is to get exactly the
necessary amount of headers into the linear SKB area pre-pulled,
but no more. The new interface drivers use is eth_get_headlen().
From WANG Cong, with driver conversions (several had their own
by-hand duplicated implementations) by Alexander Duyck and Eric
Dumazet.
6) Support checksumming more smoothly and efficiently for
encapsulations, and add "foo over UDP" facility. From Tom
Herbert.
7) Add Broadcom SF2 switch driver to DSA layer, from Florian
Fainelli.
8) eBPF now can load programs via a system call and has an extensive
testsuite. Alexei Starovoitov and Daniel Borkmann.
9) Major overhaul of the packet scheduler to use RCU in several major
areas such as the classifiers and rate estimators. From John
Fastabend.
10) Add driver for Intel FM10000 Ethernet Switch, from Alexander
Duyck.
11) Rearrange TCP_SKB_CB() to reduce cache line misses, from Eric
Dumazet.
12) Add Datacenter TCP congestion control algorithm support, From
Florian Westphal.
13) Reorganize sk_buff so that __copy_skb_header() is significantly
faster. From Eric Dumazet"
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1558 commits)
netlabel: directly return netlbl_unlabel_genl_init()
net: add netdev_txq_bql_{enqueue, complete}_prefetchw() helpers
net: description of dma_cookie cause make xmldocs warning
cxgb4: clean up a type issue
cxgb4: potential shift wrapping bug
i40e: skb->xmit_more support
net: fs_enet: Add NAPI TX
net: fs_enet: Remove non NAPI RX
r8169:add support for RTL8168EP
net_sched: copy exts->type in tcf_exts_change()
wimax: convert printk to pr_foo()
af_unix: remove 0 assignment on static
ipv6: Do not warn for informational ICMP messages, regardless of type.
Update Intel Ethernet Driver maintainers list
bridge: Save frag_max_size between PRE_ROUTING and POST_ROUTING
tipc: fix bug in multicast congestion handling
net: better IFF_XMIT_DST_RELEASE support
net/mlx4_en: remove NETDEV_TX_BUSY
3c59x: fix bad split of cpu_to_le32(pci_map_single())
net: bcmgenet: fix Tx ring priority programming
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/dmaengine
Pull dmaengine updates from Dan Williams:
"Even though this has fixes marked for -stable, given the size and the
needed conflict resolutions this is 3.18-rc1/merge-window material.
These patches have been languishing in my tree for a long while. The
fact that I do not have the time to do proper/prompt maintenance of
this tree is a primary factor in the decision to step down as
dmaengine maintainer. That and the fact that the bulk of drivers/dma/
activity is going through Vinod these days.
The net_dma removal has not been in -next. It has developed simple
conflicts against mainline and net-next (for-3.18).
Continuing thanks to Vinod for staying on top of drivers/dma/.
Summary:
1/ Step down as dmaengine maintainer see commit 08223d80df38
"dmaengine maintainer update"
2/ Removal of net_dma, as it has been marked 'broken' since 3.13
(commit 77873803363c "net_dma: mark broken"), without reports of
performance regression.
3/ Miscellaneous fixes"
* tag 'dmaengine-3.17' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/dmaengine:
net: make tcp_cleanup_rbuf private
net_dma: revert 'copied_early'
net_dma: simple removal
dmatest: prevent memory leakage on error path in thread
ioat: Use time_before_jiffies()
dmaengine: fix xor sources continuation
dma: mv_xor: Rename __mv_xor_slot_cleanup() to mv_xor_slot_cleanup()
dma: mv_xor: Remove all callers of mv_xor_slot_cleanup()
dma: mv_xor: Remove unneeded mv_xor_clean_completed_slots() call
ioat: Use pci_enable_msix_exact() instead of pci_enable_msix()
drivers: dma: Include appropriate header file in dca.c
drivers: dma: Mark functions as static in dma_v3.c
dma: mv_xor: Add DMA API error checks
ioat/dca: Use dev_is_pci() to check whether it is pci device
TCP maintains lists of skb in write queue, and in receive queues
(in order and out of order queues)
Scanning these lists both in input and output path usually requires
access to skb->next, TCP_SKB_CB(skb)->seq, and TCP_SKB_CB(skb)->end_seq
These fields are currently in two different cache lines, meaning we
waste lot of memory bandwidth when these queues are big and flows
have either packet drops or packet reorders.
We can move TCP_SKB_CB(skb)->header at the end of TCP_SKB_CB, because
this header is not used in fast path. This allows TCP to search much faster
in the skb lists.
Even with regular flows, we save one cache line miss in fast path.
Thanks to Christoph Paasch for noticing we need to cleanup
skb->cb[] (IPCB/IP6CB) before entering IP stack in tx path,
and that I forgot IPCB use in tcp_v4_hnd_req() and tcp_v4_save_options().
ip_options_echo() assumes struct ip_options is provided in &IPCB(skb)->opt
Lets break this assumption, but provide a helper to not change all call points.
ip_send_unicast_reply() gets a new struct ip_options pointer.
Per commit "77873803363c net_dma: mark broken" net_dma is no longer used
and there is no plan to fix it.
This is the mechanical removal of bits in CONFIG_NET_DMA ifdef guards.
Reverting the remainder of the net_dma induced changes is deferred to
subsequent patches.
Marked for stable due to Roman's report of a memory leak in
dma_pin_iovec_pages():
https://lkml.org/lkml/2014/9/3/177
Cc: Dave Jiang <dave.jiang@intel.com>
Cc: Vinod Koul <vinod.koul@intel.com>
Cc: David Whipple <whipple@securedatainnovations.ch>
Cc: Alexander Duyck <alexander.h.duyck@intel.com>
Cc: <stable@vger.kernel.org>
Reported-by: Roman Gushchin <klamm@yandex-team.ru>
icsk_rto is a 32bit field, and icsk_backoff can reach 15 by default,
or more if some sysctl (eg tcp_retries2) are changed.
Better use 64bit to perform icsk_rto << icsk_backoff operations
As Joe Perches suggested, add a helper for this.
Yuchung spotted the tcp_v4_err() case.
Input path of TCP do not currently uses TCP_SKB_CB(skb)->tcp_flags,
which is only used in output path.
tcp_recvmsg(), looks at tcp_hdr(skb)->syn for every skb found in receive queue,
and its unfortunate because this bit is located in a cache line right before
the payload.
We can simplify TCP by copying tcp flags into TCP_SKB_CB(skb)->tcp_flags.
This patch does so, and avoids the cache line miss in tcp_recvmsg()
Following patches will
- allow a segment with FIN being coalesced in tcp_try_coalesce()
- simplify tcp_collapse() by not copying the headers.
Acked-by: Neal Cardwell <ncardwell@google.com>
Alexander Duyck reported high false sharing on dst refcount in tcp stack
when prequeue is used. prequeue is the mechanism used when a thread is
blocked in recvmsg()/read() on a TCP socket, using a blocking model
rather than select()/poll()/epoll() non blocking one.
We already try to use RCU in input path as much as possible, but we were
forced to take a refcount on the dst when skb escaped RCU protected
region. When/if the user thread runs on different cpu, dst_release()
will then touch dst refcount again.
Commit 093162553c33 (tcp: force a dst refcount when prequeue packet)
was an example of a race fix.
It turns out the only remaining usage of skb->dst for a packet stored
in a TCP socket prequeue is IP early demux.
We can add a logic to detect when IP early demux is probably going
to use skb->dst. Because we do an optimistic check rather than duplicate
existing logic, we need to guard inet_sk_rx_dst_set() and
inet6_sk_rx_dst_set() from using a NULL dst.
Many thanks to Alexander for providing a nice bug report, git bisection,
and reproducer.
Tested using Alexander script on a 40Gb NIC, 8 RX queues.
Hosts have 24 cores, 48 hyper threads.
echo 0 >/proc/sys/net/ipv4/tcp_autocorking
for i in `seq 0 47`
do
for j in `seq 0 2`
do
netperf -H $DEST -t TCP_STREAM -l 1000 \
-c -C -T $i,$i -P 0 -- \
-m 64 -s 64K -D &
done
done
Before patch : ~6Mpps and ~95% cpu usage on receiver
After patch : ~9Mpps and ~35% cpu usage on receiver.
Reported-by: Alexander Duyck <alexander.h.duyck@intel.com>
After commit 740b0f1841f6 ("tcp: switch rtt estimations to usec resolution"),
we no longer need to maintain timestamps in two different fields.
TCP_SKB_CB(skb)->when can be removed, as same information sits in skb_mstamp.stamp_jiffies
Acked-by: Yuchung Cheng <ycheng@google.com>
TCP_SKB_CB(skb)->when has different meaning in output and input paths.
In output path, it contains a timestamp.
In input path, it contains an ISN, chosen by tcp_timewait_state_process()
Lets add a different name to ease code comprehension.
Note that 'when' field will disappear in following patch,
as skb_mstamp already contains timestamp, the anonymous
union will promptly disappear as well.
Fix places where there is space before tab, long lines, and
awkward if(){, double spacing etc. Add blank line after declaration/initialization.
Signed-off-by: Stephen Hemminger <stephen@networkplumber.org>
Make sure we use the correct address-family-specific function for
handling MTU reductions from within tcp_release_cb().
Previously AF_INET6 sockets were incorrectly always using the IPv6
code path when sometimes they were handling IPv4 traffic and thus had
an IPv4 dst.
Signed-off-by: Neal Cardwell <ncardwell@google.com>
Diagnosed-by: Willem de Bruijn <willemb@google.com>
Fixes: 563d34d057862 ("tcp: dont drop MTU reduction indications")
Reviewed-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
Since a8afca032 (tcp: md5: protects md5sig_info with RCU) tcp_md5_do_lookup
doesn't require socket lock, rcu_read_lock is enough. Therefore socket lock is
no longer required for tcp_v{4,6}_inbound_md5_hash too, so we can move these
calls (wrapped with rcu_read_{,un}lock) before bh_lock_sock:
from tcp_v{4,6}_do_rcv to tcp_v{4,6}_rcv.
Signed-off-by: Dmitry Popov <ixaphire@qrator.net>
tcpm_key is an array inside struct tcp_md5sig, there is no need to check it
against NULL.
Acked-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
When dealing with ICMPv[46] Error Message, function icmp_socket_deliver()
and icmpv6_notify() do some valid checks on packet's length, but then some
protocols check packet's length redaudantly. So remove those duplicated
statements, and increase counter ICMP_MIB_INERRORS/ICMP6_MIB_INERRORS in
function icmp_socket_deliver() and icmpv6_notify() respectively.
In addition, add missed counter in udp6/udplite6 when socket is NULL.
Signed-off-by: Duan Jiong <duanj.fnst@cn.fujitsu.com>
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
For a connected socket we can precompute the flow hash for setting
in skb->hash on output. This is a performance advantage over
calculating the skb->hash for every packet on the connection. The
computation is done using the common hash algorithm to be consistent
with computations done for packets of the connection in other states
where thers is no socket (e.g. time-wait, syn-recv, syn-cookies).
This patch adds sk_txhash to the sock structure. inet_set_txhash and
ip6_set_txhash functions are added which are called from points in
TCP and UDP where socket moves to established state.
skb_set_hash_from_sk is a function which sets skb->hash from the
sock txhash value. This is called in UDP and TCP transmit path when
transmitting within the context of a socket.
Tested: ran super_netperf with 200 TCP_RR streams over a vxlan
interface (in this case skb_get_hash called on every TX packet to
create a UDP source port).
Before fix:
95.02% CPU utilization
154/256/505 90/95/99% latencies
1.13042e+06 tps
Time in functions:
0.28% skb_flow_dissect
0.21% __skb_get_hash
After fix:
94.95% CPU utilization
156/254/485 90/95/99% latencies
1.15447e+06
Neither __skb_get_hash nor skb_flow_dissect appear in perf
Signed-off-by: Tom Herbert <therbert@google.com>
Always store in snt_synack the time at which the server received the
first client SYN and attempted to send the first SYNACK.
Recent commit aa27fc501 ("tcp: tcp_v[46]_conn_request: fix snt_synack
initialization") resolved an inconsistency between IPv4 and IPv6 in
the initialization of snt_synack. This commit brings back the idea
from 843f4a55e (tcp: use tcp_v4_send_synack on first SYN-ACK), which
was going for the original behavior of snt_synack from the commit
where it was added in 9ad7c049f0f79 ("tcp: RFC2988bis + taking RTT
sample from 3WHS for the passive open side") in v3.1.
In addition to being simpler (and probably a tiny bit faster),
unconditionally storing the time of the first SYNACK attempt has been
useful because it allows calculating a performance metric quantifying
how long it took to establish a passive TCP connection.
Signed-off-by: Yuchung Cheng <ycheng@google.com>
Cc: Octavian Purdila <octavian.purdila@intel.com>
Cc: Jerry Chu <hkchu@google.com>
Acked-by: Octavian Purdila <octavian.purdila@intel.com>
Create tcp_conn_request and remove most of the code from
tcp_v4_conn_request and tcp_v6_conn_request.
Signed-off-by: Octavian Purdila <octavian.purdila@intel.com>
Add queue_add_hash member to tcp_request_sock_ops so that we can later
unify tcp_v4_conn_request and tcp_v6_conn_request.
Add mss_clamp member to tcp_request_sock_ops so that we can later
Create a new tcp_request_sock_ops method to unify the IPv4/IPv6
signature for tcp_v[46]_send_synack. This allows us to later unify
tcp_v4_rtx_synack with tcp_v6_rtx_synack and tcp_v4_conn_request with
tcp_v4_conn_request.
More work in preparation of unifying tcp_v4_conn_request and
tcp_v6_conn_request: indirect the init sequence calls via the
tcp_request_sock_ops.
Create wrappers with same signature for the IPv4/IPv6 request routing
calls and use these wrappers (via route_req method from
tcp_request_sock_ops) in tcp_v4_conn_request and tcp_v6_conn_request
with the purpose of unifying the two functions in a later patch.
We can later drop the wrapper functions and modify inet_csk_route_req
and inet6_cks_route_req to use the same signature.
Move the specific IPv4/IPv6 cookie sequence initialization to a new
method in tcp_request_sock_ops in preparation for unifying
Move the specific IPv4/IPv6 intializations to a new method in
tcp_request_sock_ops in preparation for unifying tcp_v4_conn_request
Commit 016818d07 (tcp: TCP Fast Open Server - take SYNACK RTT after
completing 3WHS) changes the code to only take a snt_synack timestamp
when a SYNACK transmit or retransmit succeeds. This behaviour is later
broken by commit 843f4a55e (tcp: use tcp_v4_send_synack on first
SYN-ACK), as snt_synack is now updated even if tcp_v4_send_synack
fails.
Also, commit 3a19ce0ee (tcp: IPv6 support for fastopen server) misses
the required IPv6 updates for 016818d07.
This patch makes sure that snt_synack is updated only when the SYNACK
trasnmit/retransmit succeeds, for both IPv4 and IPv6.
Cc: Cardwell <ncardwell@google.com>
Cc: Daniel Lee <longinus00@gmail.com>
Cc: Yuchung Cheng <ycheng@google.com>
ir_mark initialization is done for both TCP v4 and v6, move it in the
common tcp_openreq_init function.
When using mark-based routing, sockets returned from accept()
may need to be marked differently depending on the incoming
connection request.
This is the case, for example, if different socket marks identify
different networks: a listening socket may want to accept
connections from all networks, but each connection should be
marked with the network that the request came in on, so that
subsequent packets are sent on the correct network.
This patch adds a sysctl to mark TCP sockets based on the fwmark
of the incoming SYN packet. If enabled, and an unmarked socket
receives a SYN, then the SYN packet's fwmark is written to the
connection's inet_request_sock, and later written back to the
accepted socket when the connection is established. If the
socket already has a nonzero mark, then the behaviour is the same
as it is today, i.e., the listening socket's fwmark is used.
Black-box tested using user-mode linux:
- IPv4/IPv6 SYN+ACK, FIN, etc. packets are routed based on the
mark of the incoming SYN packet.
- The socket returned by accept() is marked with the mark of the
- Tested with syncookies=1 and syncookies=2.
Signed-off-by: Lorenzo Colitti <lorenzo@google.com>
If a fast open socket is already accepted by the user, it should
be treated like a connected socket to record the ICMP error in
sk_softerr, so the user can fetch it. Do that in both tcp_v4_err
and tcp_v6_err.
Also refactor the sequence window check to improve readability
(e.g., there were two local variables named 'req').
Signed-off-by: Daniel Lee <longinus00@gmail.com>
Signed-off-by: Jerry Chu <hkchu@google.com>
To avoid large code duplication in IPv6, we need to first simplify
the complicate SYN-ACK sending code in tcp_v4_conn_request().
To use tcp_v4(6)_send_synack() to send all SYN-ACKs, we need to
initialize the mini socket's receive window before trying to
create the child socket and/or building the SYN-ACK packet. So we move
that initialization from tcp_make_synack() to tcp_v4_conn_request()
as a new function tcp_openreq_init_req_rwin().
After this refactoring the SYN-ACK sending code is simpler and easier
to implement Fast Open for IPv6.
Consolidate various cookie checking and generation code to simplify
the fast open processing. The main goal is to reduce code duplication
in tcp_v4_conn_request() for IPv6 support.
Removes two experimental sysctl flags TFO_SERVER_ALWAYS and
TFO_SERVER_COOKIE_NOT_CHKD used primarily for developmental debugging
purposes.
Move common TFO functions that will be used by both v4 and v6
to tcp_fastopen.c. Create a helper tcp_fastopen_queue_check().
Call skb_checksum_init instead of private functions.
Several spots in the kernel perform a sequence like:
skb_queue_tail(&sk->s_receive_queue, skb);
sk->sk_data_ready(sk, skb->len);
But at the moment we place the SKB onto the socket receive queue it
can be consumed and freed up. So this skb->len access is potentially
to freed up memory.
Furthermore, the skb->len can be modified by the consumer so it is
possible that the value isn't accurate.
And finally, no actual implementation of this callback actually uses
the length argument. And since nobody actually cared about it's
value, lots of call sites pass arbitrary values in such as '0' and
even '1'.
So just remove the length argument from the callback, that way there
is no confusion whatsoever and all of these use-after-free cases get
fixed as a side effect.
Based upon a patch by Eric Dumazet and his suggestion to audit this
issue tree-wide.
drivers/net/ethernet/marvell/mvneta.c
The mvneta.c conflict is a case of overlapping changes,
a conversion to devm_ioremap_resource() vs. a conversion
to netdev_alloc_pcpu_stats.
It seems I missed one change in get_timewait4_sock() to compute
the remaining time before deletion of IPV4 timewait socket.
This could result in wrong output in /proc/net/tcp for tm->when field.
Fixes: 96f817fedec4 ("tcp: shrink tcp6_timewait_sock by one cache line")
Signed-off-by: Daniel Baluta <dbaluta@ixiacom.com>
Add the following snmp stats:
TCPFastOpenActiveFail: Fast Open attempts (SYN/data) failed beacuse
the remote does not accept it or the attempts timed out.
TCPSynRetrans: number of SYN and SYN/ACK retransmits to break down
retransmissions into SYN, fast-retransmits, timeout retransmits, etc.
TCPOrigDataSent: number of outgoing packets with original data (excluding
retransmission but including data-in-SYN). This counter is different from
TcpOutSegs because TcpOutSegs also tracks pure ACKs. TCPOrigDataSent is
more useful to track the TCP retransmission rate.
Change TCPFastOpenActive to track only successful Fast Opens to be symmetric to
TCPFastOpenPassive.
Signed-off-by: Nandita Dukkipati <nanditad@google.com>
Signed-off-by: Lawrence Brakmo <brakmo@google.com>
Upcoming congestion controls for TCP require usec resolution for RTT
estimations. Millisecond resolution is simply not enough these days.
FQ/pacing in DC environments also require this change for finer control
and removal of bimodal behavior due to the current hack in
tcp_update_pacing_rate() for 'small rtt'
TCP_CONG_RTT_STAMP is no longer needed.
As Julian Anastasov pointed out, we need to keep user compatibility :
tcp_metrics used to export RTT and RTTVAR in msec resolution,
so we added RTT_US and RTTVAR_US. An iproute2 patch is needed
to use the new attributes if provided by the kernel.
In this example ss command displays a srtt of 32 usecs (10Gbit link)
lpk51:~# ./ss -i dst lpk52
Netid State Recv-Q Send-Q Local Address:Port Peer
Address:Port
tcp ESTAB 0 1 10.246.11.51:42959
10.246.11.52:64614
cubic wscale:6,6 rto:201 rtt:0.032/0.001 ato:40 mss:1448
cwnd:10 send
3620.0Mbps pacing_rate 7240.0Mbps unacked:1 rcv_rtt:993 rcv_space:29559
Updated iproute2 ip command displays :
lpk51:~# ./ip tcp_metrics | grep 10.246.11.52
10.246.11.52 age 561.914sec cwnd 10 rtt 274us rttvar 213us source
10.246.11.51
Old binary displays :
lpk51:~# ip tcp_metrics | grep 10.246.11.52
10.246.11.52 age 561.914sec cwnd 10 rtt 250us rttvar 125us source
10.246.11.51
With help from Julian Anastasov, Stephen Hemminger and Yuchung Cheng
Cc: Stephen Hemminger <stephen@networkplumber.org>
Cc: Larry Brakmo <brakmo@google.com>
Cc: Julian Anastasov <ja@ssi.bg>
As tcp_rcv_state_process() has already calls tcp_mtup_init() for non-fastopen
sock, we can delete the redundant calls of tcp_mtup_init() in
tcp_{v4,v6}_syn_recv_sock().
Signed-off-by: Weiping Pan <panweiping3@gmail.com>
Signed-off-by: Weilong Chen <chenweilong@huawei.com>
FLOWI_FLAG_CAN_SLEEP was used to notify xfrm about the posibility
to sleep until the needed states are resolved. This code is gone,
so FLOWI_FLAG_CAN_SLEEP is not needed anymore.
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
In commit c9e9042994d3 ("ipv4: fix possible seqlock deadlock") I left
another places where IP_INC_STATS_BH() were improperly used.
udp_sendmsg(), ping_v4_sendmsg() and tcp_v4_connect() are called from
process context, not from softirq context.
This was detected by lockdep seqlock support.
Reported-by: jongman heo <jongman.heo@samsung.com>
Fixes: 584bdf8cbdf6 ("[IPV4]: Fix "ipOutNoRoutes" counter error for TCP and UDP")
Fixes: c319b4d76b9e ("net: ipv4: add IPPROTO_ICMP socket kind")
Cc: Hannes Frederic Sowa <hannes@stressinduktion.org>
All seq_printf() users are using "%n" for calculating padding size,
convert them to use seq_setwidth() / seq_pad() pair.
Cc: Joe Perches <joe@perches.com>
Sockets marked with IP_PMTUDISC_INTERFACE won't do path mtu discovery,
their sockets won't accept and install new path mtu information and they
will always use the interface mtu for outgoing packets. It is guaranteed
that the packet is not fragmented locally. But we won't set the DF-Flag
on the outgoing frames.
Florian Weimer had the idea to use this flag to ensure DNS servers are
never generating outgoing fragments. They may well be fragmented on the
path, but the server never stores or usees path mtu values, which could
well be forged in an attack.
(The root of the problem with path MTU discovery is that there is
no reliable way to authenticate ICMP Fragmentation Needed But DF Set
messages because they are sent from intermediate routers with their
source addresses, and the IMCP payload will not always contain sufficient
information to identify a flow.)
Recent research in the DNS community showed that it is possible to
implement an attack where DNS cache poisoning is feasible by spoofing
fragments. This work was done by Amir Herzberg and Haya Shulman:
<https://sites.google.com/site/hayashulman/files/fragmentation-poisoning.pdf>
This issue was previously discussed among the DNS community, e.g.
<http://www.ietf.org/mail-archive/web/dnsext/current/msg01204.html>,
without leading to fixes.
This patch depends on the patch "ipv4: fix DO and PROBE pmtu mode
regarding local fragmentation with UFO/CORK" for the enforcement of the
non-fragmentable checks. If other users than ip_append_page/data should
use this semantic too, we have to add a new flag to IPCB(skb)->flags to
suppress local fragmentation and check for this in ip_finish_output.
Many thanks to Florian Weimer for the idea and feedback while implementing
this patch.
Suggested-by: Florian Weimer <fweimer@redhat.com>
