path: root/net/ipv4/tunnel4.c
2012-03-11net: Convert printks to pr_<level>Joe Perches
Use a more current kernel messaging style. Convert a printk block to print_hex_dump. Coalesce formats, align arguments. Use %s, __func__ instead of embedding function names. Some messages that were prefixed with <foo>_close are now prefixed with <foo>_fini. Some ah4 and esp messages are now not prefixed with "ip ". The intent of this patch is to later add something like #define pr_fmt(fmt) "IPv4: " fmt. to standardize the output messages. Text size is trivially reduced. (x86-32 allyesconfig) $ size net/ipv4/built-in.o* text data bss dec hex filename 887888 31558 249696 1169142 11d6f6 net/ipv4/built-in.o.new 887934 31558 249800 1169292 11d78c net/ipv4/built-in.o.old Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-11net: use IS_ENABLED(CONFIG_IPV6)Eric Dumazet
Instead of testing defined(CONFIG_IPV6) || defined(CONFIG_IPV6_MODULE) Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-27tunnels: add __rcu annotationsEric Dumazet
Add __rcu annotations to : (struct ip_tunnel)->prl (struct ip_tunnel_prl_entry)->next (struct xfrm_tunnel)->next struct xfrm_tunnel *tunnel4_handlers struct xfrm_tunnel *tunnel64_handlers And use appropriate rcu primitives to reduce sparse warnings if CONFIG_SPARSE_RCU_POINTER=y Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-09tunnels: missing rcu_assign_pointer()Eric Dumazet
xfrm4_tunnel_register() & xfrm6_tunnel_register() should use rcu_assign_pointer() to make sure previous writes (to handler->next) are committed to memory before chain insertion. deregister functions dont need a particular barrier. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-01net: tunnels should use rcu_dereferenceEric Dumazet
tunnel4_handlers, tunnel64_handlers, tunnel6_handlers and tunnel46_handlers are protected by RCU, but we dont use appropriate rcu primitives to scan them. rcu_lock() is already held by caller. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-30net: struct xfrm_tunnel in read_mostly sectionEric Dumazet
tunnel4_handlers chain being scanned for each incoming packet, make sure it doesnt share an often dirtied cache line. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-12net/ipv4: EXPORT_SYMBOL cleanupsEric Dumazet
CodingStyle cleanups EXPORT_SYMBOL should immediately follow the symbol declaration. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-09-14net: constify struct net_protocolAlexey Dobriyan
Remove long removed "inet_protocol_base" declaration. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-05[IPV4] TUNNEL4: Fix incoming packet length check for inter-protocol tunnel.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2008-04-16[SIT]: Allow for IPPROTO_IPV6 protocol in namespaces.Pavel Emelyanov
This makes sit-generated traffic enter the namespace. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-16[IPIP]: Allow for IPPROTO_IPIP protocol in namespaces.Pavel Emelyanov
This one was disabled by default for sanity. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-11-10[INET]: Cleanup the xfrm4_tunnel_(un)registerPavel Emelyanov
Both check for the family to select an appropriate tunnel list. Consolidate this check and make the for() loop more readable. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-11-10[INET]: Add missed tunnel64_err handlerPavel Emelyanov
The tunnel64_protocol uses the tunnel4_protocol's err_handler and thus calls the tunnel4_protocol's handlers. This is not very good, as in case of (icmp) error the wrong error handlers will be called (e.g. ipip ones instead of sit) and this won't be noticed at all, because the error is not reported. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-13[IPSEC]: Changing API of xfrm4_tunnel_register.Kazunori MIYAZAWA
This patch changes xfrm4_tunnel register and deregister interface to prepare for solving the conflict of device tunnels with inter address family IPsec tunnel. Signed-off-by: Kazunori MIYAZAWA <miyazawa@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-09[INET]: Move no-tunnel ICMP error to tunnel4/tunnel6Herbert Xu
This patch moves the sending of ICMP messages when there are no IPv4/IPv6 tunnels present to tunnel4/tunnel6 respectively. Please note that for now if xfrm4_tunnel/xfrm6_tunnel is loaded then no ICMP messages will ever be sent. This is similar to how we handle AH/ESP/IPCOMP. This move fixes the bug where we always send an ICMP message when there is no ip6_tunnel device present for a given packet even if it is later handled by IPsec. It also causes ICMP messages to be sent when no IPIP tunnel is present. I've decided to use the "port unreachable" ICMP message over the current value of "address unreachable" (and "protocol unreachable" by GRE) because it is not ambiguous unlike the other ones which can be triggered by other conditions. There seems to be no standard specifying what value must be used so this change should be OK. In fact we should change GRE to use this value as well. Incidentally, this patch also fixes a fairly serious bug in xfrm6_tunnel where we don't check whether the embedded IPv6 header is present before dereferencing it for the inside source address. This patch is inspired by a previous patch by Hugo Santos <hsantos@av.it.pt>. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-28[INET]: Introduce tunnel4/tunnel6Herbert Xu
Basically this patch moves the generic tunnel protocol stuff out of xfrm4_tunnel/xfrm6_tunnel and moves it into the new files of tunnel4.c and tunnel6 respectively. The reason for this is that the problem that Hugo uncovered is only the tip of the iceberg. The real problem is that when we removed the dependency of ipip on xfrm4_tunnel we didn't really consider the module case at all. For instance, as it is it's possible to build both ipip and xfrm4_tunnel as modules and if the latter is loaded then ipip simply won't load. After considering the alternatives I've decided that the best way out of this is to restore the dependency of ipip on the non-xfrm-specific part of xfrm4_tunnel. This is acceptable IMHO because the intention of the removal was really to be able to use ipip without the xfrm subsystem. This is still preserved by this patch. So now both ipip/xfrm4_tunnel depend on the new tunnel4.c which handles the arbitration between the two. The order of processing is determined by a simple integer which ensures that ipip gets processed before xfrm4_tunnel. The situation for ICMP handling is a little bit more complicated since we may not have enough information to determine who it's for. It's not a big deal at the moment since the xfrm ICMP handlers are basically no-ops. In future we can deal with this when we look at ICMP caching in general. The user-visible change to this is the removal of the TUNNEL Kconfig prompts. This makes sense because it can only be used through IPCOMP as it stands. The addition of the new modules shouldn't introduce any problems since module dependency will cause them to be loaded. Oh and I also turned some unnecessary pskb's in IPv6 related to this patch to skb's. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
