transforms ahave been applied
[ Upstream commit bfc0698bebcb16d19ecfc89574ad4d696955e5d3 ]
A policy may have been set up with multiple transforms (e.g., ESP
and ipcomp). In this situation, the ingress IPsec processing
iterates in xfrm_input() and applies each transform in turn,
processing the nexthdr to find any additional xfrm that may apply.
This patch resets the transport header back to network header
only after the last transformation so that subsequent xfrms
can find the correct transport header.
Fixes: 7785bba299a8 ("esp: Add a software GRO codepath")
Suggested-by: Steffen Klassert <steffen.klassert@secunet.com>
Signed-off-by: Sowmini Varadhan <sowmini.varadhan@oracle.com>
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
[ Upstream commit acf568ee859f098279eadf551612f103afdacb4e ]
This is an old bugbear of mine:
https://www.mail-archive.com/netdev@vger.kernel.org/msg03894.html
By crafting special packets, it is possible to cause recursion
in our kernel when processing transport-mode packets at levels
that are only limited by packet size.
The easiest one is with DNAT, but an even worse one is where
UDP encapsulation is used in which case you just have to insert
an UDP encapsulation header in between each level of recursion.
This patch avoids this problem by reinjecting tranport-mode packets
through a tasklet.
Fixes: b05e106698d9 ("[IPV4/6]: Netfilter IPsec input hooks")
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
This patch adds GRO ifrastructure and callbacks for ESP on
ipv4 and ipv6.
In case the GRO layer detects an ESP packet, the
esp{4,6}_gro_receive() function does a xfrm state lookup
and calls the xfrm input layer if it finds a matching state.
The packet will be decapsulated and reinjected it into layer 2.
This is immediately motivated by the bridge code that chains functions that
call into netfilter. Without passing net into the okfns the bridge code would
need to guess about the best expression for the network namespace to process
packets in.
As net is frequently one of the first things computed in continuation functions
after netfilter has done it's job passing in the desired network namespace is in
many cases a code simplification.
To support this change the function dst_output_okfn is introduced to
simplify passing dst_output as an okfn. For the moment dst_output_okfn
just silently drops the struct net.
Pass a network namespace parameter into the netfilter hooks. At the
call site of the netfilter hooks the path a packet is taking through
the network stack is well known which allows the network namespace to
be easily and reliabily.
This allows the replacement of magic code like
"dev_net(state->in?:state->out)" that appears at the start of most
netfilter hooks with "state->net".
In almost all cases the network namespace passed in is derived
from the first network device passed in, guaranteeing those
paths will not see any changes in practice.
The exceptions are:
xfrm/xfrm_output.c:xfrm_output_resume() xs_net(skb_dst(skb)->xfrm)
ipvs/ip_vs_xmit.c:ip_vs_nat_send_or_cont() ip_vs_conn_net(cp)
ipvs/ip_vs_xmit.c:ip_vs_send_or_cont() ip_vs_conn_net(cp)
ipv4/raw.c:raw_send_hdrinc() sock_net(sk)
ipv6/ip6_output.c:ip6_xmit() sock_net(sk)
ipv6/ndisc.c:ndisc_send_skb() dev_net(skb->dev) not dev_net(dst->dev)
ipv6/raw.c:raw6_send_hdrinc() sock_net(sk)
br_netfilter_hooks.c:br_nf_pre_routing_finish() dev_net(skb->dev) before skb->dev is set to nf_bridge->physindev
In all cases these exceptions seem to be a better expression for the
network namespace the packet is being processed in then the historic
"dev_net(in?in:out)". I am documenting them in case something odd
pops up and someone starts trying to track down what happened.
On the output paths in particular, we have to sometimes deal with two
socket contexts. First, and usually skb->sk, is the local socket that
generated the frame.
And second, is potentially the socket used to control a tunneling
socket, such as one the encapsulates using UDP.
We do not want to disassociate skb->sk when encapsulating in order
to fix this, because that would break socket memory accounting.
The most extreme case where this can cause huge problems is an
AF_PACKET socket transmitting over a vxlan device. We hit code
paths doing checks that assume they are dealing with an ipv4
socket, but are actually operating upon the AF_PACKET one.
The ipv4 code uses a mixture of coding styles. In some instances check
for NULL pointer is done as x == NULL and sometimes as !x. !x is
preferred according to checkpatch and this patch makes the code
consistent by adopting the latter form.
No changes detected by objdiff.
Signed-off-by: Ian Morris <ipm@chirality.org.uk>
This patch add an IPsec protocol multiplexer. With this
it is possible to add alternative protocol handlers as
needed for IPsec virtual tunnel interfaces.
This function will be used in next GRE_GSO patch. This patch does
not change any functionality.
Signed-off-by: Pravin B Shelar <pshelar@nicira.com>
With the routing cache removal we lost the "noref" code paths on
input, and this can kill some routing workloads.
Reinstate the noref path when we hit a cached route in the FIB
nexthops.
With help from Eric Dumazet.
Reported-by: Alexander Duyck <alexander.duyck@gmail.com>
The "noref" argument to ip_route_input_common() is now always ignored
because we do not cache routes, and in that case we must always grab
a reference to the resulting 'dst'.
This reverts commit c074da2810c118b3812f32d6754bd9ead2f169e7.
This change has several unwanted side effects:
1) Sockets will cache the DST_NOCACHE route in sk->sk_rx_dst and we'll
thus never create a real cached route.
2) All TCP traffic will use DST_NOCACHE and never use the routing
cache at all.
DDOS synflood attacks hit badly IP route cache.
On typical machines, this cache is allowed to hold up to 8 Millions dst
entries, 256 bytes for each, for a total of 2GB of memory.
rt_garbage_collect() triggers and tries to cleanup things.
Eventually route cache is disabled but machine is under fire and might
OOM and crash.
This patch exploits the new TCP early demux, to set a nocache
boolean in case incoming TCP frame is for a not yet ESTABLISHED or
TIMEWAIT socket.
This 'nocache' boolean is then used in case dst entry is not found in
route cache, to create an unhashed dst entry (DST_NOCACHE)
SYN-cookie-ACK sent use a similar mechanism (ipv4: tcp: dont cache
output dst for syncookies), so after this patch, a machine is able to
absorb a DDOS synflood attack without polluting its IP route cache.
Cc: Hans Schillstrom <hans.schillstrom@ericsson.com>
CodingStyle cleanups
EXPORT_SYMBOL should immediately follow the symbol declaration.
Use ip_route_input_noref() in ip fast path, to avoid two atomic ops per
incoming packet.
Note: loopback is excluded from this optimization in ip_rcv_finish()
Documentation/feature-removal-schedule.txt
net/ipv6/netfilter/ip6t_REJECT.c
net/netfilter/xt_limit.c
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
The semantic patch that was used:
// <smpl>
(NF_HOOK
|NF_HOOK_COND
|nf_hook
-PF_INET,
+NFPROTO_IPV4,
// </smpl>
Signed-off-by: Jan Engelhardt <jengelh@medozas.de>
Define three accessors to get/set dst attached to a skb
struct dst_entry *skb_dst(const struct sk_buff *skb)
void skb_dst_set(struct sk_buff *skb, struct dst_entry *dst)
void skb_dst_drop(struct sk_buff *skb)
This one should replace occurrences of :
dst_release(skb->dst)
skb->dst = NULL;
Delete skb->dst field
This patch removes a useless ret variable from the IPv4 ESP/UDP
decapsulation code.
When netfilter is off the transport-mode async resumption doesn't work
because we don't push back the IP header. This patch fixes that by
moving most of the code outside of ifdef NETFILTER since the only part
that's not common is the short-circuit in the protocol handler.
When merging the input paths of IPsec I accidentally left a hard-coded
AF_INET for the state lookup call. This broke IPv6 obviously. This
patch fixes by getting the input callers to specify the family through
skb->cb.
Credit goes to Kazunori Miyazawa for diagnosing this and providing an
initial patch.
The IPv4 and IPv6 hook values are identical, yet some code tries to figure
out the "correct" value by looking at the address family. Introduce NF_INET_*
values for both IPv4 and IPv6. The old values are kept in a #ifndef __KERNEL__
section for userspace compatibility.
Acked-by: Herbert Xu <herbert@gondor.apana.org.au>
This patch adds support for async resumptions on input. To do so, the
transform would return -EINPROGRESS and subsequently invoke the
function xfrm_input_resume to resume processing.
The nhoff field isn't actually necessary in xfrm_input. For tunnel
mode transforms we now throw away the output IP header so it makes no
sense to fill in the nexthdr field. For transport mode we can now let
the function transport_finish do the setting and it knows where the
nexthdr field is.
The only other thing that needs the nexthdr field to be set is the
header extraction code. However, we can simply move the protocol
extraction out of the generic header extraction.
We want to minimise the amount of info we have to carry around between
transforms as this simplifies the resumption process for async crypto.
As part of the work on asynchronous cryptographic operations, we need
to be able to resume from the spot where they occur. As such, it
helps if we isolate them to one spot.
This patch moves most of the remaining family-specific processing into
the common input code.
With inter-family transforms the inner mode differs from the outer
mode. Attempting to handle both sides from the same function means
that it needs to handle both IPv4 and IPv6 which creates duplication
and confusion.
This patch separates the two parts on the input path so that each
function deals with one family only.
In particular, the functions xfrm4_extract_inut/xfrm6_extract_inut
moves the pertinent fields from the IPv4/IPv6 IP headers into a
neutral format stored in skb->cb. This is then used by the inner mode
input functions to modify the inner IP header. In this way the input
function no longer has to know about the outer address family.
This patch adds a new field to xfrm states called inner_mode. The existing
mode object is renamed to outer_mode.
This is the first part of an attempt to fix inter-family transforms. As it
is we always use the outer family when determining which mode to use. As a
result we may end up shoving IPv4 packets into netfilter6 and vice versa.
What we really want is to use the inner family for the first part of outbound
processing and the outer family for the second part. For inbound processing
we'd use the opposite pairing.
I've also added a check to prevent silly combinations such as transport mode
with inter-family transforms.
Currently BEET mode does not reinject the packet back into the stack
like tunnel mode does. Since BEET should behave just like tunnel mode
this is incorrect.
This patch fixes this by introducing a flags field to xfrm_mode that
tells the IPsec code whether it should terminate and reinject the packet
back into the stack.
It then sets the flag for BEET and tunnel mode.
I've also added a number of missing BEET checks elsewhere where we check
whether a given mode is a tunnel or not.
This patch moves the tunnel parsing for IPv4 out of xfrm4_input and into
xfrm4_tunnel. This change is in line with what IPv6 does and will allow
us to merge the two input functions.
This patch makes the IPv4 x->type->input functions return the next protocol
instead of setting it directly. This is identical to how we do things in
IPv6 and will help us merge common code on the input path.
This cleanup fell out after adding L2TP support where a new encap_rcv
funcptr was added to struct udp_sock. Have XFRM use the new encap_rcv
funcptr, which allows us to move the XFRM encap code from udp.c into
xfrm4_input.c.
Make xfrm4_rcv_encap() static since it is no longer called externally.
Signed-off-by: James Chapman <jchapman@katalix.com>
Acked-by: Patrick McHardy <kaber@trash.net>
Signed-off-by: Kazunori MIYAZAWA <kazunori@miyazawa.org>
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
For the places where we need a pointer to the network header, it is still legal
to touch skb->nh.raw directly if just adding to, subtracting from or setting it
to another layer header.
This patch changes xfrm4_tunnel register and deregister
interface to prepare for solving the conflict of device
tunnels with inter address family IPsec tunnel.
Signed-off-by: Kazunori MIYAZAWA <miyazawa@linux-ipv6.org>
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
Transformation mode is used as either IPsec transport or tunnel.
It is required to add two more items, route optimization and inbound trigger
for Mobile IPv6.
Based on MIPL2 kernel patch.
This patch was also written by: Ville Nuorvala <vnuorval@tcs.hut.fi>
Signed-off-by: Masahide NAKAMURA <nakam@linux-ipv6.org>
This patch adds the structure xfrm_mode. It is meant to represent
the operations carried out by transport/tunnel modes.
By doing this we allow additional encapsulation modes to be added
without clogging up the xfrm_input/xfrm_output paths.
Candidate modes include 4-to-6 tunnel mode, 6-to-4 tunnel mode, and
BEET modes.
This patch moves the sending of ICMP messages when there are no IPv4/IPv6
tunnels present to tunnel4/tunnel6 respectively. Please note that for now
if xfrm4_tunnel/xfrm6_tunnel is loaded then no ICMP messages will ever be
sent. This is similar to how we handle AH/ESP/IPCOMP.
This move fixes the bug where we always send an ICMP message when there is
no ip6_tunnel device present for a given packet even if it is later handled
by IPsec. It also causes ICMP messages to be sent when no IPIP tunnel is
present.
I've decided to use the "port unreachable" ICMP message over the current
value of "address unreachable" (and "protocol unreachable" by GRE) because
it is not ambiguous unlike the other ones which can be triggered by other
conditions. There seems to be no standard specifying what value must be
used so this change should be OK. In fact we should change GRE to use
this value as well.
Incidentally, this patch also fixes a fairly serious bug in xfrm6_tunnel
where we don't check whether the embedded IPv6 header is present before
dereferencing it for the inside source address.
This patch is inspired by a previous patch by Hugo Santos <hsantos@av.it.pt>.
We need to dereference x->encap before dereferencing it for encap_type.
If it's absent then the encap_type is zero.
This patch removes the *_decap_state structures which were previously
used to share state between input/post_input. This is no longer
needed.
This patch removes the decap_state argument from the xfrm input hook.
Previously this function allowed the input hook to share state with
the post_input hook. The latter has since been removed.
The only purpose for it now is to check the encap type. However, it
is easier and better to move the encap type check to the generic
xfrm_rcv function. This allows us to get rid of the decap state
argument altogether.
When the innermost transform uses transport mode the decapsulated packet
is not visible to netfilter. Pass the packet through the PRE_ROUTING and
LOCAL_IN hooks again before handing it to upper layer protocols to make
netfilter-visibility symetrical to the output path.
infrastructure for it.
Let it rip!
