path: root/net/ipv4
2010-10-24Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) Update broken web addresses in arch directory. Update broken web addresses in the kernel. Revert "drivers/usb: Remove unnecessary return's from void functions" for musb gadget Revert "Fix typo: configuation => configuration" partially ida: document IDA_BITMAP_LONGS calculation ext2: fix a typo on comment in ext2/inode.c drivers/scsi: Remove unnecessary casts of private_data drivers/s390: Remove unnecessary casts of private_data net/sunrpc/rpc_pipe.c: Remove unnecessary casts of private_data drivers/infiniband: Remove unnecessary casts of private_data drivers/gpu/drm: Remove unnecessary casts of private_data kernel/pm_qos_params.c: Remove unnecessary casts of private_data fs/ecryptfs: Remove unnecessary casts of private_data fs/seq_file.c: Remove unnecessary casts of private_data arm: uengine.c: remove C99 comments arm: scoop.c: remove C99 comments Fix typo configue => configure in comments Fix typo: configuation => configuration Fix typo interrest[ing|ed] => interest[ing|ed] Fix various typos of valid in comments ... Fix up trivial conflicts in: drivers/char/ipmi/ipmi_si_intf.c drivers/usb/gadget/rndis.c net/irda/irnet/irnet_ppp.c
2010-10-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1699 commits) bnx2/bnx2x: Unsupported Ethtool operations should return -EINVAL. vlan: Calling vlan_hwaccel_do_receive() is always valid. tproxy: use the interface primary IP address as a default value for --on-ip tproxy: added IPv6 support to the socket match cxgb3: function namespace cleanup tproxy: added IPv6 support to the TPROXY target tproxy: added IPv6 socket lookup function to nf_tproxy_core be2net: Changes to use only priority codes allowed by f/w tproxy: allow non-local binds of IPv6 sockets if IP_TRANSPARENT is enabled tproxy: added tproxy sockopt interface in the IPV6 layer tproxy: added udp6_lib_lookup function tproxy: added const specifiers to udp lookup functions tproxy: split off ipv6 defragmentation to a separate module l2tp: small cleanup nf_nat: restrict ICMP translation for embedded header can: mcp251x: fix generation of error frames can: mcp251x: fix endless loop in interrupt handler if CANINTF_MERRF is set can-raw: add msg_flags to distinguish local traffic 9p: client code cleanup rds: make local functions/variables static ... Fix up conflicts in net/core/dev.c, drivers/net/pcmcia/smc91c92_cs.c and drivers/net/wireless/ath/ath9k/debug.c as per David
2010-10-22Merge branch 'llseek' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bklLinus Torvalds
* 'llseek' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bkl: vfs: make no_llseek the default vfs: don't use BKL in default_llseek llseek: automatically add .llseek fop libfs: use generic_file_llseek for simple_attr mac80211: disallow seeks in minstrel debug code lirc: make chardev nonseekable viotape: use noop_llseek raw: use explicit llseek file operations ibmasmfs: use generic_file_llseek spufs: use llseek in all file operations arm/omap: use generic_file_llseek in iommu_debug lkdtm: use generic_file_llseek in debugfs net/wireless: use generic_file_llseek in debugfs drm: use noop_llseek
2010-10-21Merge branch 'core-rcu-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-rcu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (52 commits) sched: fix RCU lockdep splat from task_group() rcu: using ACCESS_ONCE() to observe the jiffies_stall/rnp->qsmask value sched: suppress RCU lockdep splat in task_fork_fair net: suppress RCU lockdep false positive in sock_update_classid rcu: move check from rcu_dereference_bh to rcu_read_lock_bh_held rcu: Add advice to PROVE_RCU_REPEATEDLY kernel config parameter rcu: Add tracing data to support queueing models rcu: fix sparse errors in rcutorture.c rcu: only one evaluation of arg in rcu_dereference_check() unless sparse kernel: Remove undead ifdef CONFIG_DEBUG_LOCK_ALLOC rcu: fix _oddness handling of verbose stall warnings rcu: performance fixes to TINY_PREEMPT_RCU callback checking rcu: upgrade stallwarn.txt documentation for CPU-bound RT processes vhost: add __rcu annotations rcu: add comment stating that list_empty() applies to RCU-protected lists rcu: apply TINY_PREEMPT_RCU read-side speedup to TREE_PREEMPT_RCU rcu: combine duplicate code, courtesy of CONFIG_PREEMPT_RCU rcu: Upgrade srcu_read_lock() docbook about SRCU grace periods rcu: document ways of stalling updates in low-memory situations rcu: repair code-duplication FIXMEs ...
2010-10-21Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/kaber/nf-next-2.6
2010-10-21Merge branch 'for-patrick' of ↵Patrick McHardy
git://git.kernel.org/pub/scm/linux/kernel/git/horms/lvs-test-2.6
2010-10-21nf_nat: restrict ICMP translation for embedded headerJulian Anastasov
Skip ICMP translation of embedded protocol header if NAT bits are not set. Needed for IPVS to see the original embedded addresses because for IPVS traffic the IPS_SRC_NAT_BIT and IPS_DST_NAT_BIT bits are not set. It happens when IPVS performs DNAT for client packets after using nf_conntrack_alter_reply to expect replies from real server. Signed-off-by: Julian Anastasov <ja@ssi.bg> Signed-off-by: Simon Horman <horms@verge.net.au>
2010-10-21tproxy: fix hash locking issue when using port redirection in ↵Balazs Scheidler
__inet_inherit_port() When __inet_inherit_port() is called on a tproxy connection the wrong locks are held for the inet_bind_bucket it is added to. __inet_inherit_port() made an implicit assumption that the listener's port number (and thus its bind bucket). Unfortunately, if you're using the TPROXY target to redirect skbs to a transparent proxy that assumption is not true anymore and things break. This patch adds code to __inet_inherit_port() so that it can handle this case by looking up or creating a new bind bucket for the child socket and updates callers of __inet_inherit_port() to gracefully handle __inet_inherit_port() failing. Reported by and original patch from Stephen Buck <stephen.buck@exinda.com>. See http://marc.info/?t=128169268200001&r=1&w=2 for the original discussion. Signed-off-by: KOVACS Krisztian <hidden@balabit.hu> Signed-off-by: Patrick McHardy <kaber@trash.net>
2010-10-21fib: introduce fib_alias_accessed() helperEric Dumazet
Perf tools session at NFWS 2010 pointed out a false sharing on struct fib_alias that can be avoided pretty easily, if we set FA_S_ACCESSED bit only if needed (ie : not already set) Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-21secmark: export secctx, drop secmark in procfsEric Paris
The current secmark code exports a secmark= field which just indicates if there is special labeling on a packet or not. We drop this field as it isn't particularly useful and instead export a new field secctx= which is the actual human readable text label. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Patrick McHardy <kaber@trash.net> Signed-off-by: James Morris <jmorris@namei.org>
2010-10-20net: avoid RCU for NOCACHE dstEric Dumazet
There is no point using RCU for dst we allocate for a very short time (used once). Change dst_release() to take DST_NOCACHE into account, but also change skb_dst_set_noref() to force a refcount increment for such dst. This is a _huge_ gain, because we dont waste memory to store xx thousand of dsts. Instead of queueing them to RCU, we can free them instantly. CPU caches can stay hot, re-using same memory blocks to hold temporary dsts. Note : remove unneeded smp_mb__before_atomic_dec(); in dst_release(), since atomic_dec_return() implies a full memory barrier. Stress test, 160.000.000 udp frames sent, IP route cache disabled (DDOS). Before: real 0m38.091s user 0m13.189s sys 7m53.018s After: real 0m29.946s user 0m12.157s sys 7m40.605s For reference, if IP route cache was enabled : real 0m32.030s user 0m10.521s sys 8m15.243s Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-19inet: RCU changes in inetdev_by_index()Eric Dumazet
Convert inetdev_by_index() to not increment in_dev refcount. Callers hold RCU or RTNL, and should not decrement in_dev refcount. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-19net: avoid a dev refcount in ip_mc_find_dev()Eric Dumazet
We hold RTNL in ip_mc_find_dev(), no need to touch device refcount. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-18IPv4: route.c: Change checks against 0xffffffff to ipv4_is_lbcast()Andy Walls
Change a few checks against the hardcoded broadcast address, 0xffffffff, to ipv4_is_lbcast(). Remove some existing checks using ipv4_is_lbcast() that are now obviously superfluous. Signed-off-by: Andy Walls <awalls@md.metrocast.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-18netfilter: fix kconfig unmet dependency warningRandy Dunlap
Fix netfilter kconfig unmet dependencies warning & spell out "compatible" while there. warning: (IP_NF_TARGET_TTL && NET && INET && NETFILTER && IP_NF_IPTABLES && NETFILTER_ADVANCED || IP6_NF_TARGET_HL && NET && INET && IPV6 && NETFILTER && IP6_NF_IPTABLES && NETFILTER_ADVANCED) selects NETFILTER_XT_TARGET_HL which has unmet direct dependencies ((IP_NF_MANGLE || IP6_NF_MANGLE) && NETFILTER_ADVANCED) Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Patrick McHardy <kaber@trash.net>
2010-10-18Update broken web addresses in the kernel.Justin P. Mattock
The patch below updates broken web addresses in the kernel Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Cc: Maciej W. Rozycki <macro@linux-mips.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Finn Thain <fthain@telegraphics.com.au> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Matt Turner <mattst88@gmail.com> Cc: Dimitry Torokhov <dmitry.torokhov@gmail.com> Cc: Mike Frysinger <vapier.adi@gmail.com> Acked-by: Ben Pfaff <blp@cs.stanford.edu> Acked-by: Hans J. Koch <hjk@linutronix.de> Reviewed-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-10-17fib_hash: RCU conversion phase 2Eric Dumazet
Get rid of fib_hash_lock rwlock. The fn_zone hash table resize is the noticeable part of this patch. I added a seqlock per fn_zone, so that readers can restart their lookup in the (very rare) case a writer expanded the hash table. Add rcu heads in fib_alias and fib_node, use call_rcu() to defer their freeing, and use appropriate _rcu list manipulations. Stress test (160.000.000 udp frames sent, IP route cache disabled to mimic DDOS attack, FIB_HASH) Before: real 0m41.191s user 0m13.137s sys 8m55.241s After: real 0m38.091s user 0m13.189s sys 7m53.018s Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-17fib_hash: RCU conversion phase 1Eric Dumazet
First step for RCU conversion of fib_hash : struct fn_zone are created and never deleted. Very classic conversion, using rcu_assign_pointer(), rcu_dereference() and rtnl_dereference() verbs. __rcu markers on fz_next and fn_zone_list They are created under RTNL, we dont need fib_hash_lock anymore in fn_new_zone(). Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-17fib_hash: embed initial hash table in fn_zoneEric Dumazet
While looking for false sharing problems, I noticed sizeof(struct fn_zone) was small (28 bytes) and possibly sharing a cache line with an often written kernel structure. Most of the time, fn_zone uses its initial hash table of 16 slots. We can avoid the false sharing problem by embedding this initial hash table in fn_zone itself, so that sizeof(fn_zone) > L1_CACHE_BYTES We did a similar optimization in commit a6501e080c (Reduce memory needs and speedup lookups) Add a fz_revorder field to speedup fn_hash() a bit. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-17tcp: use correct counters in CA_CWR state tooIlpo Järvinen
As CWR is stronger than CA_Disorder state, we can miscount SACK/Reno failure into other timeouts. Not a bad problem as it can happen only due to ECN, FRTO detecting spurious RTO or xmit error which are the only callers of tcp_enter_cwr. And even then losses and RTO must still follow thereafter to actually end up into the relevant code paths. Compile tested. Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-17tcp: sack lost marking fixesIlpo Järvinen
When only fast rexmit should be done, tcp_mark_head_lost marks L too far. Also, sacked_upto below 1 is perfectly valid number, the packets == 0 then needs to be trapped elsewhere. Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-16fib: avoid false sharing on fib_table_hashEric Dumazet
While doing profile analysis, I found fib_hash_table was sometime in a cache line shared by a possibly often written kernel structure. (CONFIG_IP_ROUTE_MULTIPATH || !CONFIG_IPV6_MULTIPLE_TABLES) It's hard to detect because not easily reproductible. Make sure we allocate a full cache line to keep this shared in all cpus caches. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-16fib_trie: use fls() instead of open coded loopEric Dumazet
fib_table_lookup() might use fls() to speedup an open coded loop. Noticed while doing a profile analysis. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
All file_operations should get a .llseek operation so we can make nonseekable_open the default for future file operations without a .llseek pointer. The three cases that we can automatically detect are no_llseek, seq_lseek and default_llseek. For cases where we can we can automatically prove that the file offset is always ignored, we use noop_llseek, which maintains the current behavior of not returning an error from a seek. New drivers should normally not use noop_llseek but instead use no_llseek and call nonseekable_open at open time. Existing drivers can be converted to do the same when the maintainer knows for certain that no user code relies on calling seek on the device file. The generated code is often incorrectly indented and right now contains comments that clarify for each added line why a specific variant was chosen. In the version that gets submitted upstream, the comments will be gone and I will manually fix the indentation, because there does not seem to be a way to do that using coccinelle. Some amount of new code is currently sitting in linux-next that should get the same modifications, which I will do at the end of the merge window. Many thanks to Julia Lawall for helping me learn to write a semantic patch that does all this. ===== begin semantic patch ===== // This adds an llseek= method to all file operations, // as a preparation for making no_llseek the default. // // The rules are // - use no_llseek explicitly if we do nonseekable_open // - use seq_lseek for sequential files // - use default_llseek if we know we access f_pos // - use noop_llseek if we know we don't access f_pos, // but we still want to allow users to call lseek // @ open1 exists @ identifier nested_open; @@ nested_open(...) { <+... nonseekable_open(...) ...+> } @ open exists@ identifier open_f; identifier i, f; identifier open1.nested_open; @@ int open_f(struct inode *i, struct file *f) { <+... ( nonseekable_open(...) | nested_open(...) ) ...+> } @ read disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ read_no_fpos disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { ... when != off } @ write @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ write_no_fpos @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { ... when != off } @ fops0 @ identifier fops; @@ struct file_operations fops = { ... }; @ has_llseek depends on fops0 @ identifier fops0.fops; identifier llseek_f; @@ struct file_operations fops = { ... .llseek = llseek_f, ... }; @ has_read depends on fops0 @ identifier fops0.fops; identifier read_f; @@ struct file_operations fops = { ... .read = read_f, ... }; @ has_write depends on fops0 @ identifier fops0.fops; identifier write_f; @@ struct file_operations fops = { ... .write = write_f, ... }; @ has_open depends on fops0 @ identifier fops0.fops; identifier open_f; @@ struct file_operations fops = { ... .open = open_f, ... }; // use no_llseek if we call nonseekable_open //////////////////////////////////////////// @ nonseekable1 depends on !has_llseek && has_open @ identifier fops0.fops; identifier nso ~= "nonseekable_open"; @@ struct file_operations fops = { ... .open = nso, ... +.llseek = no_llseek, /* nonseekable */ }; @ nonseekable2 depends on !has_llseek @ identifier fops0.fops; identifier open.open_f; @@ struct file_operations fops = { ... .open = open_f, ... +.llseek = no_llseek, /* open uses nonseekable */ }; // use seq_lseek for sequential files ///////////////////////////////////// @ seq depends on !has_llseek @ identifier fops0.fops; identifier sr ~= "seq_read"; @@ struct file_operations fops = { ... .read = sr, ... +.llseek = seq_lseek, /* we have seq_read */ }; // use default_llseek if there is a readdir /////////////////////////////////////////// @ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier readdir_e; @@ // any other fop is used that changes pos struct file_operations fops = { ... .readdir = readdir_e, ... +.llseek = default_llseek, /* readdir is present */ }; // use default_llseek if at least one of read/write touches f_pos ///////////////////////////////////////////////////////////////// @ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read.read_f; @@ // read fops use offset struct file_operations fops = { ... .read = read_f, ... +.llseek = default_llseek, /* read accesses f_pos */ }; @ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, ... + .llseek = default_llseek, /* write accesses f_pos */ }; // Use noop_llseek if neither read nor write accesses f_pos /////////////////////////////////////////////////////////// @ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; identifier write_no_fpos.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, .read = read_f, ... +.llseek = noop_llseek, /* read and write both use no f_pos */ }; @ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write_no_fpos.write_f; @@ struct file_operations fops = { ... .write = write_f, ... +.llseek = noop_llseek, /* write uses no f_pos */ }; @ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; @@ struct file_operations fops = { ... .read = read_f, ... +.llseek = noop_llseek, /* read uses no f_pos */ }; @ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; @@ struct file_operations fops = { ... +.llseek = noop_llseek, /* no read or write fn */ }; ===== End semantic patch ===== Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Julia Lawall <julia@diku.dk> Cc: Christoph Hellwig <hch@infradead.org>
2010-10-13netfilter: xtables: resolve indirect macros 3/3Jan Engelhardt
2010-10-13netfilter: xtables: resolve indirect macros 2/3Jan Engelhardt
Signed-off-by: Jan Engelhardt <jengelh@medozas.de>
2010-10-13netfilter: xtables: resolve indirect macros 1/3Jan Engelhardt
Many of the used macros are just there for userspace compatibility. Substitute the in-kernel code to directly use the terminal macro and stuff the defines into #ifndef __KERNEL__ sections. Signed-off-by: Jan Engelhardt <jengelh@medozas.de>
2010-10-11net dst: use a percpu_counter to track entriesEric Dumazet
struct dst_ops tracks number of allocated dst in an atomic_t field, subject to high cache line contention in stress workload. Switch to a percpu_counter, to reduce number of time we need to dirty a central location. Place it on a separate cache line to avoid dirtying read only fields. Stress test : (Sending 160.000.000 UDP frames, IP route cache disabled, dual E5540 @2.53GHz, 32bit kernel, FIB_TRIE, SLUB/NUMA) Before: real 0m51.179s user 0m15.329s sys 10m15.942s After: real 0m45.570s user 0m15.525s sys 9m56.669s With a small reordering of struct neighbour fields, subject of a following patch, (to separate refcnt from other read mostly fields) real 0m41.841s user 0m15.261s sys 8m45.949s Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-11neigh: Protect neigh->ha[] with a seqlockEric Dumazet
Add a seqlock in struct neighbour to protect neigh->ha[], and avoid dirtying neighbour in stress situation (many different flows / dsts) Dirtying takes place because of read_lock(&n->lock) and n->used writes. Switching to a seqlock, and writing n->used only on jiffies changes permits less dirtying. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-08ipv4: Remove leftover rcu_read_unlock calls from __mkroute_output()Dimitris Michailidis
Commit "fib: RCU conversion of fib_lookup()" removed rcu_read_lock() from __mkroute_output but left a couple of calls to rcu_read_unlock() in there. This causes lockdep to complain that the rcu_read_unlock() call in __ip_route_output_key causes a lock inbalance and quickly crashes the kernel. The below fixes this for me. Signed-off-by: Dimitris Michailidis <dm@chelsio.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-07Merge commit 'v2.6.36-rc7' into core/rcuIngo Molnar
Merge reason: Update from -rc3 to -rc7. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-10-07Merge branch 'rcu/urgent' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/paulmck/linux-2.6-rcu into core/rcu
2010-10-06TCP: Fix setting of snd_ssthresh in tcp_mtu_probe_successJohn Heffner
This looks like a simple typo that has gone unnoticed for some time. The impact is relatively low but it's clearly wrong. Signed-off-by: John Heffner <johnwheffner@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-05fib: RCU conversion of fib_lookup()Eric Dumazet
fib_lookup() converted to be called in RCU protected context, no reference taken and released on a contended cache line (fib_clntref) fib_table_lookup() and fib_semantic_match() get an additional parameter. struct fib_info gets an rcu_head field, and is freed after an rcu grace period. Stress test : (Sending 160.000.000 UDP frames on same neighbour, IP route cache disabled, dual E5540 @2.53GHz, 32bit kernel, FIB_HASH) (about same results for FIB_TRIE) Before patch : real 1m31.199s user 0m13.761s sys 23m24.780s After patch: real 1m5.375s user 0m14.997s sys 15m50.115s Before patch Profile : 13044.00 15.4% __ip_route_output_key vmlinux 8438.00 10.0% dst_destroy vmlinux 5983.00 7.1% fib_semantic_match vmlinux 5410.00 6.4% fib_rules_lookup vmlinux 4803.00 5.7% neigh_lookup vmlinux 4420.00 5.2% _raw_spin_lock vmlinux 3883.00 4.6% rt_set_nexthop vmlinux 3261.00 3.9% _raw_read_lock vmlinux 2794.00 3.3% fib_table_lookup vmlinux 2374.00 2.8% neigh_resolve_output vmlinux 2153.00 2.5% dst_alloc vmlinux 1502.00 1.8% _raw_read_lock_bh vmlinux 1484.00 1.8% kmem_cache_alloc vmlinux 1407.00 1.7% eth_header vmlinux 1406.00 1.7% ipv4_dst_destroy vmlinux 1298.00 1.5% __copy_from_user_ll vmlinux 1174.00 1.4% dev_queue_xmit vmlinux 1000.00 1.2% ip_output vmlinux After patch Profile : 13712.00 15.8% dst_destroy vmlinux 8548.00 9.9% __ip_route_output_key vmlinux 7017.00 8.1% neigh_lookup vmlinux 4554.00 5.3% fib_semantic_match vmlinux 4067.00 4.7% _raw_read_lock vmlinux 3491.00 4.0% dst_alloc vmlinux 3186.00 3.7% neigh_resolve_output vmlinux 3103.00 3.6% fib_table_lookup vmlinux 2098.00 2.4% _raw_read_lock_bh vmlinux 2081.00 2.4% kmem_cache_alloc vmlinux 2013.00 2.3% _raw_spin_lock vmlinux 1763.00 2.0% __copy_from_user_ll vmlinux 1763.00 2.0% ip_output vmlinux 1761.00 2.0% ipv4_dst_destroy vmlinux 1631.00 1.9% eth_header vmlinux 1440.00 1.7% _raw_read_unlock_bh vmlinux Reference results, if IP route cache is enabled : real 0m29.718s user 0m10.845s sys 7m37.341s 25213.00 29.5% __ip_route_output_key vmlinux 9011.00 10.5% dst_release vmlinux 4817.00 5.6% ip_push_pending_frames vmlinux 4232.00 5.0% ip_finish_output vmlinux 3940.00 4.6% udp_sendmsg vmlinux 3730.00 4.4% __copy_from_user_ll vmlinux 3716.00 4.4% ip_route_output_flow vmlinux 2451.00 2.9% __xfrm_lookup vmlinux 2221.00 2.6% ip_append_data vmlinux 1718.00 2.0% _raw_spin_lock_bh vmlinux 1655.00 1.9% __alloc_skb vmlinux 1572.00 1.8% sock_wfree vmlinux 1345.00 1.6% kfree vmlinux Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-05bonding: fix to rejoin multicast groups immediatelyFlavio Leitner
The IGMP specs states that if the system receives a membership report, it shouldn't send another for the next minute. However, if a link failure happens right after that, the backup slave and the switch connected to this slave will not know about the multicast and the traffic will hang for about a minute. This patch fixes it to rejoin multicast groups immediately after a failover restoring the multicast traffic. Signed-off-by: Flavio Leitner <fleitner@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-05net neigh: RCU conversion of neigh hash tableEric Dumazet
David This is the first step for RCU conversion of neigh code. Next patches will convert hash_buckets[] and "struct neighbour" to RCU protected objects. Thanks [PATCH net-next] net neigh: RCU conversion of neigh hash table Instead of storing hash_buckets, hash_mask and hash_rnd in "struct neigh_table", a new structure is defined : struct neigh_hash_table { struct neighbour **hash_buckets; unsigned int hash_mask; __u32 hash_rnd; struct rcu_head rcu; }; And "struct neigh_table" has an RCU protected pointer to such a neigh_hash_table. This means the signature of (*hash)() function changed: We need to add a third parameter with the actual hash_rnd value, since this is not anymore a neigh_table field. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-05net: add a core netdev->rx_dropped counterEric Dumazet
In various situations, a device provides a packet to our stack and we drop it before it enters protocol stack : - softnet backlog full (accounted in /proc/net/softnet_stat) - bad vlan tag (not accounted) - unknown/unregistered protocol (not accounted) We can handle a per-device counter of such dropped frames at core level, and automatically adds it to the device provided stats (rx_dropped), so that standard tools can be used (ifconfig, ip link, cat /proc/net/dev) This is a generalization of commit 8990f468a (net: rx_dropped accounting), thus reverting it. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-05fib: cleanupsEric Dumazet
Code style cleanups before upcoming functional changes. C99 initializer for fib_props array. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-04Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: net/ipv4/Kconfig net/ipv4/tcp_timer.c
2010-10-04netfilter: ipt_LOG: add bufferisation to call printk() onceEric Dumazet
ipt_LOG & ip6t_LOG use lot of calls to printk() and use a lock in a hope several cpus wont mix their output in syslog. printk() being very expensive [1], its better to call it once, on a prebuilt and complete line. Also, with mixed IPv4 and IPv6 trafic, separate IPv4/IPv6 locks dont avoid garbage. I used an allocation of a 1024 bytes structure, sort of seq_printf() but with a fixed size limit. Use a static buffer if dynamic allocation failed. Emit a once time alert if buffer size happens to be too short. [1]: printk() has various features like printk_delay()... Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Patrick McHardy <kaber@trash.net>
2010-10-04netfilter: nf_nat: make find/put staticStephen Hemminger
The functions nf_nat_proto_find_get and nf_nat_proto_put are only used internally in nf_nat_core. This might break some out of tree NAT module. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Patrick McHardy <kaber@trash.net>
2010-10-03net: introduce DST_NOCACHE flagEric Dumazet
While doing stress tests with IP route cache disabled, and multi queue devices, I noticed a very high contention on one rwlock used in neighbour code. When many cpus are trying to send frames (possibly using a high performance multiqueue device) to the same neighbour, they fight for the neigh->lock rwlock in order to call neigh_hh_init(), and fight on hh->hh_refcnt (a pair of atomic_inc/atomic_dec_and_test()) But we dont need to call neigh_hh_init() for dst that are used only once. It costs four atomic operations at least, on two contended cache lines, plus the high contention on neigh->lock rwlock. Introduce a new dst flag, DST_NOCACHE, that is set when dst was not inserted in route cache. With the stress test bench, sending 160000000 frames on one neighbour, results are : Before patch: real 2m28.406s user 0m11.781s sys 36m17.964s After patch: real 1m26.532s user 0m12.185s sys 20m3.903s Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-03ipv4: correct IGMP behavior on v3 query during v2-compatibility modeDavid Stevens
A recent patch to allow IGMPv2 responses to IGMPv3 queries bypasses length checks for valid query lengths, incorrectly resets the v2_seen timer, and does not support IGMPv1. The following patch responds with a v2 report as required by IGMPv2 while correcting the other problems introduced by the patch. Signed-Off-By: David L Stevens <dlstevens@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-03ipmr: cleanupsEric Dumazet
Various code style cleanups Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-03ipmr: RCU protection for mfc_cache_arrayEric Dumazet
Use RCU & RTNL protection for mfc_cache_array[] ipmr_cache_find() is called under rcu_read_lock(); Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-03ipmr: RCU conversion of mroute_skEric Dumazet
Use RCU and RTNL to protect (struct mr_table)->mroute_sk Readers use RCU, writers use RTNL. ip_ra_control() already use an RCU grace period before ip_ra_destroy_rcu(), so we dont need synchronize_rcu() in mrtsock_destruct() Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-03ipmr: __pim_rcv() is called under rcu_read_lockEric Dumazet
No need to get a reference on reg_dev and release it, we are in a rcu_read_lock() protected section. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-03gre: protocol table can be staticstephen hemminger
This table is only used in gre.c Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-03Revert "ipv4: Make INET_LRO a bool instead of tristate."Ben Hutchings
This reverts commit e81963b180ac502fda0326edf059b1e29cdef1a2. LRO is now deprecated in favour of GRO, and only a few drivers use it, so it is desirable to build it as a module in distribution kernels. The original change to prevent building it as a module was made in an attempt to avoid the case where some dependents are set to y and some to m, and INET_LRO can be set to m rather than y. However, the Kconfig system will reliably set INET_LRO=y in this case. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-30ipv4: rcu conversion in ip_route_output_slowEric Dumazet
ip_route_output_slow() is enclosed in an rcu_read_lock() protected section, so that no references are taken/released on device, thanks to __ip_dev_find() & dev_get_by_index_rcu() Tested with ip route cache disabled, and a stress test : Before patch: elapsed time : real 1m38.347s user 0m11.909s sys 23m51.501s Profile: 13788.00 22.7% ip_route_output_slow [kernel] 7875.00 13.0% dst_destroy [kernel] 3925.00 6.5% fib_semantic_match [kernel] 3144.00 5.2% fib_rules_lookup [kernel] 3061.00 5.0% dst_alloc [kernel] 2276.00 3.7% rt_set_nexthop [kernel] 1762.00 2.9% fib_table_lookup [kernel] 1538.00 2.5% _raw_read_lock [kernel] 1358.00 2.2% ip_output [kernel] After patch: real 1m28.808s user 0m13.245s sys 20m37.293s 10950.00 17.2% ip_route_output_slow [kernel] 10726.00 16.9% dst_destroy [kernel] 5170.00 8.1% fib_semantic_match [kernel] 3937.00 6.2% dst_alloc [kernel] 3635.00 5.7% rt_set_nexthop [kernel] 2900.00 4.6% fib_rules_lookup [kernel] 2240.00 3.5% fib_table_lookup [kernel] 1427.00 2.2% _raw_read_lock [kernel] 1157.00 1.8% kmem_cache_alloc [kernel] Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
