[ Upstream commit 690cc86321eb9bcee371710252742fb16fe96824 ]
When CONFIG_IP_MULTICAST is not set and multicast ip is added to the device
with autojoin flag or when multicast ip is deleted kernel will crash.
steps to reproduce:
ip addr add 224.0.0.0/32 dev eth0
ip addr del 224.0.0.0/32 dev eth0
or
ip addr add 224.0.0.0/32 dev eth0 autojoin
Unable to handle kernel NULL pointer dereference at virtual address 0000000000000088
pc : _raw_write_lock_irqsave+0x1e0/0x2ac
lr : lock_sock_nested+0x1c/0x60
Call trace:
ip_mc_config.isra.28+0x50/0xe0
inet_rtm_deladdr+0x1a8/0x1f0
rtnetlink_rcv_msg+0x120/0x350
netlink_rcv_skb+0x58/0x120
rtnetlink_rcv+0x14/0x20
netlink_unicast+0x1b8/0x270
netlink_sendmsg+0x1a0/0x3b0
____sys_sendmsg+0x248/0x290
___sys_sendmsg+0x80/0xc0
__sys_sendmsg+0x68/0xc0
__arm64_sys_sendmsg+0x20/0x30
el0_svc_common.constprop.2+0x88/0x150
do_el0_svc+0x20/0x80
el0_sync_handler+0x118/0x190
el0_sync+0x140/0x180
Fixes: 93a714d6b53d ("multicast: Extend ip address command to enable multicast group join/leave on")
Signed-off-by: Taras Chornyi <taras.chornyi@plvision.eu>
Signed-off-by: Vadym Kochan <vadym.kochan@plvision.eu>
[ Upstream commit 25629fdaff2ff509dd0b3f5ff93d70a75e79e0a1 ]
when creating a new ipip interface with no local/remote configuration,
the lookup is done with TUNNEL_NO_KEY flag, making it impossible to
match the new interface (only possible match being fallback or metada
case interface); e.g: `ip link add tunl1 type ipip dev eth0`
To fix this case, adding a flag check before the key comparison so we
permit to match an interface with no local/remote config; it also avoids
breaking possible userland tools relying on TUNNEL_NO_KEY flag and
uninitialised key.
context being on my side, I'm creating an extra ipip interface attached
to the physical one, and moving it to a dedicated namespace.
Fixes: c54419321455 ("GRE: Refactor GRE tunneling code.")
Signed-off-by: William Dauchy <w.dauchy@criteo.com>
Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com>
[ Upstream commit fbe4e0c1b298b4665ee6915266c9d6c5b934ef4a ]
fib_triestat_seq_show() calls hlist_for_each_entry_rcu(tb, head,
tb_hlist) without rcu_read_lock() will trigger a warning,
net/ipv4/fib_trie.c:2579 RCU-list traversed in non-reader section!!
rcu_scheduler_active = 2, debug_locks = 1
1 lock held by proc01/115277:
#0: c0000014507acf00 (&p->lock){+.+.}-{3:3}, at: seq_read+0x58/0x670
Call Trace:
dump_stack+0xf4/0x164 (unreliable)
lockdep_rcu_suspicious+0x140/0x164
fib_triestat_seq_show+0x750/0x880
seq_read+0x1a0/0x670
proc_reg_read+0x10c/0x1b0
__vfs_read+0x3c/0x70
vfs_read+0xac/0x170
ksys_read+0x7c/0x140
system_call+0x5c/0x68
Fix it by adding a pair of rcu_read_lock/unlock() and use
cond_resched_rcu() to avoid the situation where walking of a large
number of items may prevent scheduling for a long time.
Signed-off-by: Qian Cai <cai@lca.pw>
Reviewed-by: Eric Dumazet <edumazet@google.com>
commit f1ed10264ed6b66b9cd5e8461cffce69be482356 upstream.
I forgot the 4in6/6in4 cases in my previous patch. Let's fix them.
Fixes: 95224166a903 ("vti[6]: fix packet tx through bpf_redirect()")
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
[ Upstream commit 28d35bcdd3925e7293408cdb8aa5f2aac5f0d6e3 ]
When an MTU update with PMTU smaller than net.ipv4.route.min_pmtu is
received, we must clamp its value. However, we can receive a PMTU
exception with PMTU < old_mtu < ip_rt_min_pmtu, which would lead to an
increase in PMTU.
To fix this, take the smallest of the old MTU and ip_rt_min_pmtu.
Before this patch, in case of an update, the exception's MTU would
always change. Now, an exception can have only its lock flag updated,
but not the MTU, so we need to add a check on locking to the following
"is this exception getting updated, or close to expiring?" test.
Fixes: d52e5a7e7ca4 ("ipv4: lock mtu in fnhe when received PMTU < net.ipv4.route.min_pmtu")
Signed-off-by: Sabrina Dubroca <sd@queasysnail.net>
Reviewed-by: Stefano Brivio <sbrivio@redhat.com>
commit 3e72dfdf8227b052393f71d820ec7599909dddc2 upstream.
Similarly to commit c543cb4a5f07 ("ipv4: ensure rcu_read_lock() in
ipv4_link_failure()"), __ip_options_compile() must be called under rcu
protection.
Fixes: 3da1ed7ac398 ("net: avoid use IPCB in cipso_v4_error")
Suggested-by: Guillaume Nault <gnault@redhat.com>
Signed-off-by: Matteo Croce <mcroce@redhat.com>
Acked-by: Paul Moore <paul@paul-moore.com>
[ Upstream commit 784f8344de750a41344f4bbbebb8507a730fc99c ]
tp->segs_in and tp->segs_out need to be cleared in tcp_disconnect().
tcp_disconnect() is rarely used, but it is worth fixing it.
Fixes: 2efd055c53c0 ("tcp: add tcpi_segs_in and tcpi_segs_out to tcp_info")
Cc: Marcelo Ricardo Leitner <mleitner@redhat.com>
Cc: Yuchung Cheng <ycheng@google.com>
Cc: Neal Cardwell <ncardwell@google.com>
Acked-by: Neal Cardwell <ncardwell@google.com>
Signed-off-by: Jakub Kicinski <kuba@kernel.org>
[ Upstream commit c13c48c00a6bc1febc73902505bdec0967bd7095 ]
total_retrans needs to be cleared in tcp_disconnect().
Fixes: 1da177e4c3f4 ("Linux-2.6.12-rc2")
Cc: SeongJae Park <sjpark@amazon.de>
[ Upstream commit 95224166a9032ff5d08fca633d37113078ce7d01 ]
With an ebpf program that redirects packets through a vti[6] interface,
the packets are dropped because no dst is attached.
This could also be reproduced with an AF_PACKET socket, with the following
python script (vti1 is an ip_vti interface):
import socket
send_s = socket.socket(socket.AF_PACKET, socket.SOCK_RAW, 0)
# scapy
# p = IP(src='10.100.0.2', dst='10.200.0.1')/ICMP(type='echo-request')
# raw(p)
req = b'E\x00\x00\x1c\x00\x01\x00\x00@\x01e\xb2\nd\x00\x02\n\xc8\x00\x01\x08\x00\xf7\xff\x00\x00\x00\x00'
send_s.sendto(req, ('vti1', 0x800, 0, 0))
[ Upstream commit d0f418516022c32ecceaf4275423e5bd3f8743a9 ]
in the same manner as commit 690afc165bb3 ("net: ip6_gre: fix moving
ip6gre between namespaces"), fix namespace moving as it was broken since
commit 2e15ea390e6f ("ip_gre: Add support to collect tunnel metadata.").
Indeed, the ip6_gre commit removed the local flag for collect_md
condition, so there is no reason to keep it for ip_gre/ip_tunnel.
this patch will fix both ip_tunnel and ip_gre modules.
Fixes: 2e15ea390e6f ("ip_gre: Add support to collect tunnel metadata.")
Acked-by: Nicolas Dichtel <nicolas.dichtel@6wind.com>
[ Upstream commit e176b1ba476cf36f723cfcc7a9e57f3cb47dec70 ]
When the packet pointed to by retransmit_skb_hint is unlinked by ACK,
retransmit_skb_hint will be set to NULL in tcp_clean_rtx_queue().
If packet loss is detected at this time, retransmit_skb_hint will be set
to point to the current packet loss in tcp_verify_retransmit_hint(),
then the packets that were previously marked lost but not retransmitted
due to the restriction of cwnd will be skipped and cannot be
retransmitted.
To fix this, when retransmit_skb_hint is NULL, retransmit_skb_hint can
be reset only after all marked lost packets are retransmitted
(retrans_out >= lost_out), otherwise we need to traverse from
tcp_rtx_queue_head in tcp_xmit_retransmit_queue().
Packetdrill to demonstrate:
// Disable RACK and set max_reordering to keep things simple
0 `sysctl -q net.ipv4.tcp_recovery=0`
+0 `sysctl -q net.ipv4.tcp_max_reordering=3`
// Establish a connection
+0 socket(..., SOCK_STREAM, IPPROTO_TCP) = 3
+0 setsockopt(3, SOL_SOCKET, SO_REUSEADDR, [1], 4) = 0
+0 bind(3, ..., ...) = 0
+0 listen(3, 1) = 0
+.1 < S 0:0(0) win 32792 <mss 1000,sackOK,nop,nop,nop,wscale 7>
+0 > S. 0:0(0) ack 1 <...>
+.01 < . 1:1(0) ack 1 win 257
+0 accept(3, ..., ...) = 4
// Send 8 data segments
+0 write(4, ..., 8000) = 8000
+0 > P. 1:8001(8000) ack 1
// Enter recovery and 1:3001 is marked lost
+.01 < . 1:1(0) ack 1 win 257 <sack 3001:4001,nop,nop>
+0 < . 1:1(0) ack 1 win 257 <sack 5001:6001 3001:4001,nop,nop>
+0 < . 1:1(0) ack 1 win 257 <sack 5001:7001 3001:4001,nop,nop>
// Retransmit 1:1001, now retransmit_skb_hint points to 1001:2001
+0 > . 1:1001(1000) ack 1
// 1001:2001 was ACKed causing retransmit_skb_hint to be set to NULL
+.01 < . 1:1(0) ack 2001 win 257 <sack 5001:8001 3001:4001,nop,nop>
// Now retransmit_skb_hint points to 4001:5001 which is now marked lost
// BUG: 2001:3001 was not retransmitted
+0 > . 2001:3001(1000) ack 1
Signed-off-by: Pengcheng Yang <yangpc@wangsu.com>
Tested-by: Neal Cardwell <ncardwell@google.com>
commit 1b789577f655060d98d20ed0c6f9fbd469d6ba63 upstream.
We get crash when the targets checkentry function tries to make
use of the network namespace pointer for arptables.
When the net pointer got added back in 2010, only ip/ip6/ebtables were
changed to initialize it, so arptables has this set to NULL.
This isn't a problem for normal arptables because no existing
arptables target has a checkentry function that makes use of par->net.
However, direct users of the setsockopt interface can provide any
target they want as long as its registered for ARP or UNPSEC protocols.
syzkaller managed to send a semi-valid arptables rule for RATEEST target
which is enough to trigger NULL deref:
kasan: GPF could be caused by NULL-ptr deref or user memory access
general protection fault: 0000 [#1] PREEMPT SMP KASAN
RIP: xt_rateest_tg_checkentry+0x11d/0xb40 net/netfilter/xt_RATEEST.c:109
xt_check_target+0x283/0x690 net/netfilter/x_tables.c:1019
check_target net/ipv4/netfilter/arp_tables.c:399 [inline]
find_check_entry net/ipv4/netfilter/arp_tables.c:422 [inline]
translate_table+0x1005/0x1d70 net/ipv4/netfilter/arp_tables.c:572
do_replace net/ipv4/netfilter/arp_tables.c:977 [inline]
do_arpt_set_ctl+0x310/0x640 net/ipv4/netfilter/arp_tables.c:1456
Fixes: add67461240c1d ("netfilter: add struct net * to target parameters")
Reported-by: syzbot+d7358a458d8a81aee898@syzkaller.appspotmail.com
Acked-by: Cong Wang <xiyou.wangcong@gmail.com>
[ Upstream commit c9655008e7845bcfdaac10a1ed8554ec167aea88 ]
When we receive a D-SACK, where the sequence number satisfies:
undo_marker <= start_seq < end_seq <= prior_snd_una
we consider this is a valid D-SACK and tcp_is_sackblock_valid()
returns true, then this D-SACK is discarded as "old stuff",
but the variable first_sack_index is not marked as negative
in tcp_sacktag_write_queue().
If this D-SACK also carries a SACK that needs to be processed
(for example, the previous SACK segment was lost), this SACK
will be treated as a D-SACK in the following processing of
tcp_sacktag_write_queue(), which will eventually lead to
incorrect updates of undo_retrans and reordering.
Fixes: fd6dad616d4f ("[TCP]: Earlier SACK block verification & simplify access to them")
[ Upstream commit 1f85e6267caca44b30c54711652b0726fadbb131 ]
Backport of commit fdfc5c8594c2 ("tcp: remove empty skb from
write queue in error cases") in linux-4.14 stable triggered
various bugs. One of them has been fixed in commit ba2ddb43f270
("tcp: Don't dequeue SYN/FIN-segments from write-queue"), but
we still have crashes in some occasions.
Root-cause is that when tcp_sendmsg() has allocated a fresh
skb and could not append a fragment before being blocked
in sk_stream_wait_memory(), tcp_write_xmit() might be called
and decide to send this fresh and empty skb.
Sending an empty packet is not only silly, it might have caused
many issues we had in the past with tp->packets_out being
out of sync.
Fixes: c65f7f00c587 ("[TCP]: Simplify SKB data portion allocation with NETIF_F_SG.")
Cc: Christoph Paasch <cpaasch@apple.com>
Cc: Jason Baron <jbaron@akamai.com>
Acked-by: Soheil Hassas Yeganeh <soheil@google.com>
Signed-off-by: Jakub Kicinski <jakub.kicinski@netronome.com>
commit bbab7ef235031f6733b5429ae7877bfa22339712 upstream.
This code reads two global variables without protection
of a lock. We need READ_ONCE()/WRITE_ONCE() pairs to
avoid load/store-tearing and better document the intent.
KCSAN reported :
BUG: KCSAN: data-race in icmp_global_allow / icmp_global_allow
read to 0xffffffff861a8014 of 4 bytes by task 11201 on cpu 0:
icmp_global_allow+0x36/0x1b0 net/ipv4/icmp.c:254
icmpv6_global_allow net/ipv6/icmp.c:184 [inline]
icmpv6_global_allow net/ipv6/icmp.c:179 [inline]
icmp6_send+0x493/0x1140 net/ipv6/icmp.c:514
icmpv6_send+0x71/0xb0 net/ipv6/ip6_icmp.c:43
ip6_link_failure+0x43/0x180 net/ipv6/route.c:2640
dst_link_failure include/net/dst.h:419 [inline]
vti_xmit net/ipv4/ip_vti.c:243 [inline]
vti_tunnel_xmit+0x27f/0xa50 net/ipv4/ip_vti.c:279
__netdev_start_xmit include/linux/netdevice.h:4420 [inline]
netdev_start_xmit include/linux/netdevice.h:4434 [inline]
xmit_one net/core/dev.c:3280 [inline]
dev_hard_start_xmit+0xef/0x430 net/core/dev.c:3296
__dev_queue_xmit+0x14c9/0x1b60 net/core/dev.c:3873
dev_queue_xmit+0x21/0x30 net/core/dev.c:3906
neigh_direct_output+0x1f/0x30 net/core/neighbour.c:1530
neigh_output include/net/neighbour.h:511 [inline]
ip6_finish_output2+0x7a6/0xec0 net/ipv6/ip6_output.c:116
__ip6_finish_output net/ipv6/ip6_output.c:142 [inline]
__ip6_finish_output+0x2d7/0x330 net/ipv6/ip6_output.c:127
ip6_finish_output+0x41/0x160 net/ipv6/ip6_output.c:152
NF_HOOK_COND include/linux/netfilter.h:294 [inline]
ip6_output+0xf2/0x280 net/ipv6/ip6_output.c:175
dst_output include/net/dst.h:436 [inline]
ip6_local_out+0x74/0x90 net/ipv6/output_core.c:179
write to 0xffffffff861a8014 of 4 bytes by task 11183 on cpu 1:
icmp_global_allow+0x174/0x1b0 net/ipv4/icmp.c:272
Reported by Kernel Concurrency Sanitizer on:
CPU: 1 PID: 11183 Comm: syz-executor.2 Not tainted 5.4.0-rc3+ #0
Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011
Fixes: 4cdf507d5452 ("icmp: add a global rate limitation")
Reported-by: syzbot <syzkaller@googlegroups.com>
[ Upstream commit 501a90c945103e8627406763dac418f20f3837b2 ]
syzbot was once again able to crash a host by setting a very small mtu
on loopback device.
Let's make inetdev_valid_mtu() available in include/net/ip.h,
and use it in ip_setup_cork(), so that we protect both ip_append_page()
and __ip_append_data()
Also add a READ_ONCE() when the device mtu is read.
Pairs this lockless read with one WRITE_ONCE() in __dev_set_mtu(),
even if other code paths might write over this field.
Add a big comment in include/linux/netdevice.h about dev->mtu
needing READ_ONCE()/WRITE_ONCE() annotations.
Hopefully we will add the missing ones in followup patches.
[1]
refcount_t: saturated; leaking memory.
WARNING: CPU: 0 PID: 9464 at lib/refcount.c:22 refcount_warn_saturate+0x138/0x1f0 lib/refcount.c:22
Kernel panic - not syncing: panic_on_warn set ...
CPU: 0 PID: 9464 Comm: syz-executor850 Not tainted 5.4.0-syzkaller #0
Call Trace:
__dump_stack lib/dump_stack.c:77 [inline]
dump_stack+0x197/0x210 lib/dump_stack.c:118
panic+0x2e3/0x75c kernel/panic.c:221
__warn.cold+0x2f/0x3e kernel/panic.c:582
report_bug+0x289/0x300 lib/bug.c:195
fixup_bug arch/x86/kernel/traps.c:174 [inline]
fixup_bug arch/x86/kernel/traps.c:169 [inline]
do_error_trap+0x11b/0x200 arch/x86/kernel/traps.c:267
do_invalid_op+0x37/0x50 arch/x86/kernel/traps.c:286
invalid_op+0x23/0x30 arch/x86/entry/entry_64.S:1027
RIP: 0010:refcount_warn_saturate+0x138/0x1f0 lib/refcount.c:22
Code: 06 31 ff 89 de e8 c8 f5 e6 fd 84 db 0f 85 6f ff ff ff e8 7b f4 e6 fd 48 c7 c7 e0 71 4f 88 c6 05 56 a6 a4 06 01 e8 c7 a8 b7 fd <0f> 0b e9 50 ff ff ff e8 5c f4 e6 fd 0f b6 1d 3d a6 a4 06 31 ff 89
RSP: 0018:ffff88809689f550 EFLAGS: 00010286
RAX: 0000000000000000 RBX: 0000000000000000 RCX: 0000000000000000
RDX: 0000000000000000 RSI: ffffffff815e4336 RDI: ffffed1012d13e9c
RBP: ffff88809689f560 R08: ffff88809c50a3c0 R09: fffffbfff15d31b1
R10: fffffbfff15d31b0 R11: ffffffff8ae98d87 R12: 0000000000000001
R13: 0000000000040100 R14: ffff888099041104 R15: ffff888218d96e40
refcount_add include/linux/refcount.h:193 [inline]
skb_set_owner_w+0x2b6/0x410 net/core/sock.c:1999
sock_wmalloc+0xf1/0x120 net/core/sock.c:2096
ip_append_page+0x7ef/0x1190 net/ipv4/ip_output.c:1383
udp_sendpage+0x1c7/0x480 net/ipv4/udp.c:1276
inet_sendpage+0xdb/0x150 net/ipv4/af_inet.c:821
kernel_sendpage+0x92/0xf0 net/socket.c:3794
sock_sendpage+0x8b/0xc0 net/socket.c:936
pipe_to_sendpage+0x2da/0x3c0 fs/splice.c:458
splice_from_pipe_feed fs/splice.c:512 [inline]
__splice_from_pipe+0x3ee/0x7c0 fs/splice.c:636
splice_from_pipe+0x108/0x170 fs/splice.c:671
generic_splice_sendpage+0x3c/0x50 fs/splice.c:842
do_splice_from fs/splice.c:861 [inline]
direct_splice_actor+0x123/0x190 fs/splice.c:1035
splice_direct_to_actor+0x3b4/0xa30 fs/splice.c:990
do_splice_direct+0x1da/0x2a0 fs/splice.c:1078
do_sendfile+0x597/0xd00 fs/read_write.c:1464
__do_sys_sendfile64 fs/read_write.c:1525 [inline]
__se_sys_sendfile64 fs/read_write.c:1511 [inline]
__x64_sys_sendfile64+0x1dd/0x220 fs/read_write.c:1511
do_syscall_64+0xfa/0x790 arch/x86/entry/common.c:294
entry_SYSCALL_64_after_hwframe+0x49/0xbe
RIP: 0033:0x441409
Code: e8 ac e8 ff ff 48 83 c4 18 c3 0f 1f 80 00 00 00 00 48 89 f8 48 89 f7 48 89 d6 48 89 ca 4d 89 c2 4d 89 c8 4c 8b 4c 24 08 0f 05 <48> 3d 01 f0 ff ff 0f 83 eb 08 fc ff c3 66 2e 0f 1f 84 00 00 00 00
RSP: 002b:00007fffb64c4f78 EFLAGS: 00000246 ORIG_RAX: 0000000000000028
RAX: ffffffffffffffda RBX: 0000000000000000 RCX: 0000000000441409
RDX: 0000000000000000 RSI: 0000000000000006 RDI: 0000000000000005
RBP: 0000000000073b8a R08: 0000000000000010 R09: 0000000000000010
R10: 0000000000010001 R11: 0000000000000246 R12: 0000000000402180
R13: 0000000000402210 R14: 0000000000000000 R15: 0000000000000000
Kernel Offset: disabled
Rebooting in 86400 seconds..
Fixes: 1470ddf7f8ce ("inet: Remove explicit write references to sk/inet in ip_append_data")
[ Upstream commit 9424e2e7ad93ffffa88f882c9bc5023570904b55 ]
Back in 2008, Adam Langley fixed the corner case of packets for flows
having all of the following options : MD5 TS SACK
Since MD5 needs 20 bytes, and TS needs 12 bytes, no sack block
can be cooked from the remaining 8 bytes.
tcp_established_options() correctly sets opts->num_sack_blocks
to zero, but returns 36 instead of 32.
This means TCP cooks packets with 4 extra bytes at the end
of options, containing unitialized bytes.
Fixes: 33ad798c924b ("tcp: options clean up")
[ Upstream commit 3976535af0cb9fe34a55f2ffb8d7e6b39a2f8188 ]
Previously there is an off-by-one bug on determining when to abort
a stalled window-probing socket. This patch fixes that so it is
consistent with tcp_write_timeout().
Signed-off-by: Yuchung Cheng <ycheng@google.com>
Signed-off-by: Neal Cardwell <ncardwell@google.com>
[ Upstream commit a904a0693c189691eeee64f6c6b188bd7dc244e9 ]
Historically linux tried to stick to RFC 791, 1122, 2003
for IPv4 ID field generation.
RFC 6864 made clear that no matter how hard we try,
we can not ensure unicity of IP ID within maximum
lifetime for all datagrams with a given source
address/destination address/protocol tuple.
Linux uses a per socket inet generator (inet_id), initialized
at connection startup with a XOR of 'jiffies' and other
fields that appear clear on the wire.
Thiemo Nagel pointed that this strategy is a privacy
concern as this provides 16 bits of entropy to fingerprint
devices.
Let's switch to a random starting point, this is just as
good as far as RFC 6864 is concerned and does not leak
anything critical.
Reported-by: Thiemo Nagel <tnagel@google.com>
[ Upstream commit 595e0651d0296bad2491a4a29a7a43eae6328b02 ]
...instead of -EINVAL. An issue was found with older kernel versions
while unplugging a NFS client with pending RPCs, and the wrong error
code here prevented it from recovering once link is back up with a
configured address.
Incidentally, this is not an issue anymore since commit 4f8943f80883
("SUNRPC: Replace direct task wakeups from softirq context"), included
in 5.2-rc7, had the effect of decoupling the forwarding of this error
by using SO_ERROR in xs_wake_error(), as pointed out by Benjamin
Coddington.
To the best of my knowledge, this isn't currently causing any further
issue, but the error code doesn't look appropriate anyway, and we
might hit this in other paths as well.
In detail, as analysed by Gonzalo Siero, once the route is deleted
because the interface is down, and can't be resolved and we return
-EINVAL here, this ends up, courtesy of inet_sk_rebuild_header(),
as the socket error seen by tcp_write_err(), called by
tcp_retransmit_timer().
In turn, tcp_write_err() indirectly calls xs_error_report(), which
wakes up the RPC pending tasks with a status of -EINVAL. This is then
seen by call_status() in the SUN RPC implementation, which aborts the
RPC call calling rpc_exit(), instead of handling this as a
potentially temporary condition, i.e. as a timeout.
Return -EINVAL only if the input parameters passed to
ip_route_output_key_hash_rcu() are actually invalid (this is the case
if the specified source address is multicast, limited broadcast or
all zeroes), but return -ENETUNREACH in all cases where, at the given
moment, the given source address doesn't allow resolving the route.
While at it, drop the initialisation of err to -ENETUNREACH, which
was added to __ip_route_output_key() back then by commit
0315e3827048 ("net: Fix behaviour of unreachable, blackhole and
prohibit routes"), but actually had no effect, as it was, and is,
overwritten by the fib_lookup() return code assignment, and anyway
ignored in all other branches, including the if (fl4->saddr) one:
I find this rather confusing, as it would look like -ENETUNREACH is
the "default" error, while that statement has no effect.
Also note that after commit fc75fc8339e7 ("ipv4: dont create routes
on down devices"), we would get -ENETUNREACH if the device is down,
but -EINVAL if the source address is specified and we can't resolve
the route, and this appears to be rather inconsistent.
Reported-by: Stefan Walter <walteste@inf.ethz.ch>
Analysed-by: Benjamin Coddington <bcodding@redhat.com>
Analysed-by: Gonzalo Siero <gsierohu@redhat.com>
Signed-off-by: Stefano Brivio <sbrivio@redhat.com>
[ Upstream commit b406472b5ad79ede8d10077f0c8f05505ace8b6d ]
Since commit c09551c6ff7f ("net: ipv4: use a dedicated counter
for icmp_v4 redirect packets") we use 'n_redirects' to account
for redirect packets, but we still use 'rate_tokens' to compute
the redirect packets exponential backoff.
If the device sent to the relevant peer any ICMP error packet
after sending a redirect, it will also update 'rate_token' according
to the leaking bucket schema; typically 'rate_token' will raise
above BITS_PER_LONG and the redirect packets backoff algorithm
will produce undefined behavior.
Fix the issue using 'n_redirects' to compute the exponential backoff
in ip_rt_send_redirect().
Note that we still clear rate_tokens after a redirect silence period,
to avoid changing an established behaviour.
The root cause predates git history; before the mentioned commit in
the critical scenario, the kernel stopped sending redirects, after
the mentioned commit the behavior more randomic.
Reported-by: Xiumei Mu <xmu@redhat.com>
Fixes: c09551c6ff7f ("net: ipv4: use a dedicated counter for icmp_v4 redirect packets")
Signed-off-by: Paolo Abeni <pabeni@redhat.com>
Acked-by: Lorenzo Bianconi <lorenzo.bianconi@redhat.com>
[ Upstream commit af38d07ed391b21f7405fa1f936ca9686787d6d2 ]
Fix tcp_ecn_withdraw_cwr() to clear the correct bit:
TCP_ECN_QUEUE_CWR.
Rationale: basically, TCP_ECN_DEMAND_CWR is a bit that is purely about
the behavior of data receivers, and deciding whether to reflect
incoming IP ECN CE marks as outgoing TCP th->ece marks. The
TCP_ECN_QUEUE_CWR bit is purely about the behavior of data senders,
and deciding whether to send CWR. The tcp_ecn_withdraw_cwr() function
is only called from tcp_undo_cwnd_reduction() by data senders during
an undo, so it should zero the sender-side state,
TCP_ECN_QUEUE_CWR. It does not make sense to stop the reflection of
incoming CE bits on incoming data packets just because outgoing
packets were spuriously retransmitted.
The bug has been reproduced with packetdrill to manifest in a scenario
with RFC3168 ECN, with an incoming data packet with CE bit set and
carrying a TCP timestamp value that causes cwnd undo. Before this fix,
the IP CE bit was ignored and not reflected in the TCP ECE header bit,
and sender sent a TCP CWR ('W') bit on the next outgoing data packet,
even though the cwnd reduction had been undone. After this fix, the
sender properly reflects the CE bit and does not set the W bit.
Note: the bug actually predates 2005 git history; this Fixes footer is
chosen to be the oldest SHA1 I have tested (from Sep 2007) for which
the patch applies cleanly (since before this commit the code was in a
.h file).
Fixes: bdf1ee5d3bd3 ("[TCP]: Move code from tcp_ecn.h to tcp*.c and tcp.h & remove it")
Acked-by: Yuchung Cheng <ycheng@google.com>
Cc: Eric Dumazet <edumazet@google.com>
commit df453700e8d81b1bdafdf684365ee2b9431fb702 upstream.
According to Amit Klein and Benny Pinkas, IP ID generation is too weak
and might be used by attackers.
Even with recent net_hash_mix() fix (netns: provide pure entropy for net_hash_mix())
having 64bit key and Jenkins hash is risky.
It is time to switch to siphash and its 128bit keys.
Reported-by: Amit Klein <aksecurity@gmail.com>
Reported-by: Benny Pinkas <benny@pinkas.net>
[bwh: Backported to 4.4: adjust context]
Signed-off-by: Ben Hutchings <ben.hutchings@codethink.co.uk>
[ Upstream commit b617158dc096709d8600c53b6052144d12b89fab ]
Some applications set tiny SO_SNDBUF values and expect
TCP to just work. Recent patches to address CVE-2019-11478
broke them in case of losses, since retransmits might
be prevented.
We should allow these flows to make progress.
This patch allows the first and last skb in retransmit queue
to be split even if memory limits are hit.
It also adds the some room due to the fact that tcp_sendmsg()
and tcp_sendpage() might overshoot sk_wmem_queued by about one full
TSO skb (64KB size). Note this allowance was already present
in stable backports for kernels < 4.15
Note for < 4.15 backports :
tcp_rtx_queue_tail() will probably look like :
static inline struct sk_buff *tcp_rtx_queue_tail(const struct sock *sk)
struct sk_buff *skb = tcp_send_head(sk);
return skb ? tcp_write_queue_prev(sk, skb) : tcp_write_queue_tail(sk);
Fixes: f070ef2ac667 ("tcp: tcp_fragment() should apply sane memory limits")
Reported-by: Andrew Prout <aprout@ll.mit.edu>
Tested-by: Andrew Prout <aprout@ll.mit.edu>
Tested-by: Jonathan Lemon <jonathan.lemon@gmail.com>
Tested-by: Michal Kubecek <mkubecek@suse.cz>
Acked-by: Christoph Paasch <cpaasch@apple.com>
Cc: Jonathan Looney <jtl@netflix.com>
[ Upstream commit e858faf556d4e14c750ba1e8852783c6f9520a0e ]
If an app is playing tricks to reuse a socket via tcp_disconnect(),
bytes_acked/received needs to be reset to 0. Otherwise tcp_info will
report the sum of the current and the old connection..
Fixes: 0df48c26d841 ("tcp: add tcpi_bytes_acked to tcp_info")
Fixes: bdd1f9edacb5 ("tcp: add tcpi_bytes_received to tcp_info")
Signed-off-by: Christoph Paasch <cpaasch@apple.com>
[ Upstream commit 2e60546368165c2449564d71f6005dda9205b5fb ]
Avoid the situation where an IPV6 only flag is applied to an IPv4 address:
# ip addr add 192.0.2.1/24 dev dummy0 nodad home mngtmpaddr noprefixroute
# ip -4 addr show dev dummy0
2: dummy0: <BROADCAST,NOARP,UP,LOWER_UP> mtu 1500 qdisc noqueue state UNKNOWN group default qlen 1000
inet 192.0.2.1/24 scope global noprefixroute dummy0
valid_lft forever preferred_lft forever
Or worse, by sending a malicious netlink command:
inet 192.0.2.1/24 scope global nodad optimistic dadfailed home tentative mngtmpaddr noprefixroute stable-privacy dummy0
Reviewed-by: David Ahern <dsahern@gmail.com>
[ Upstream commit 38c73529de13e1e10914de7030b659a2f8b01c3b ]
In commit 19e4e768064a8 ("ipv4: Fix raw socket lookup for local
traffic"), the dif argument to __raw_v4_lookup() is coming from the
returned value of inet_iif() but the change was done only for the first
lookup. Subsequent lookups in the while loop still use skb->dev->ifIndex.
Fixes: 19e4e768064a8 ("ipv4: Fix raw socket lookup for local traffic")
Signed-off-by: Stephen Suryaputra <ssuryaextr@gmail.com>
commit b6653b3629e5b88202be3c9abc44713973f5c4b4 upstream.
tcp_fragment() might be called for skbs in the write queue.
Memory limits might have been exceeded because tcp_sendmsg() only
checks limits at full skb (64KB) boundaries.
Therefore, we need to make sure tcp_fragment() wont punish applications
that might have setup very low SO_SNDBUF values.
Reported-by: Christoph Paasch <cpaasch@apple.com>
Tested-by: Christoph Paasch <cpaasch@apple.com>
commit 967c05aee439e6e5d7d805e195b3a20ef5c433d6 upstream.
If mtu probing is enabled tcp_mtu_probing() could very well end up
with a too small MSS.
Use the new sysctl tcp_min_snd_mss to make sure MSS search
is performed in an acceptable range.
CVE-2019-11479 -- tcp mss hardcoded to 48
Reported-by: Jonathan Lemon <jonathan.lemon@gmail.com>
Cc: Tyler Hicks <tyhicks@canonical.com>
Cc: Bruce Curtis <brucec@netflix.com>
commit 5f3e2bf008c2221478101ee72f5cb4654b9fc363 upstream.
Some TCP peers announce a very small MSS option in their SYN and/or
SYN/ACK messages.
This forces the stack to send packets with a very high network/cpu
overhead.
Linux has enforced a minimal value of 48. Since this value includes
the size of TCP options, and that the options can consume up to 40
bytes, this means that each segment can include only 8 bytes of payload.
In some cases, it can be useful to increase the minimal value
to a saner value.
We still let the default to 48 (TCP_MIN_SND_MSS), for compatibility
reasons.
Note that TCP_MAXSEG socket option enforces a minimal value
of (TCP_MIN_MSS). David Miller increased this minimal value
in commit c39508d6f118 ("tcp: Make TCP_MAXSEG minimum more correct.")
from 64 to 88.
We might in the future merge TCP_MIN_SND_MSS and TCP_MIN_MSS.
Suggested-by: Jonathan Looney <jtl@netflix.com>
Cc: Jonathan Lemon <jonathan.lemon@gmail.com>
commit f070ef2ac66716357066b683fb0baf55f8191a2e upstream.
Jonathan Looney reported that a malicious peer can force a sender
to fragment its retransmit queue into tiny skbs, inflating memory
usage and/or overflow 32bit counters.
TCP allows an application to queue up to sk_sndbuf bytes,
so we need to give some allowance for non malicious splitting
of retransmit queue.
A new SNMP counter is added to monitor how many times TCP
did not allow to split an skb if the allowance was exceeded.
Note that this counter might increase in the case applications
use SO_SNDBUF socket option to lower sk_sndbuf.
CVE-2019-11478 : tcp_fragment, prevent fragmenting a packet when the
socket is already using more than half the allowed space
Reported-by: Jonathan Looney <jtl@netflix.com>
Reviewed-by: Tyler Hicks <tyhicks@canonical.com>
commit 3b4929f65b0d8249f19a50245cd88ed1a2f78cff upstream.
Jonathan Looney reported that TCP can trigger the following crash
in tcp_shifted_skb() :
BUG_ON(tcp_skb_pcount(skb) < pcount);
This can happen if the remote peer has advertized the smallest
MSS that linux TCP accepts : 48
An skb can hold 17 fragments, and each fragment can hold 32KB
on x86, or 64KB on PowerPC.
This means that the 16bit witdh of TCP_SKB_CB(skb)->tcp_gso_segs
can overflow.
Note that tcp_sendmsg() builds skbs with less than 64KB
of payload, so this problem needs SACK to be enabled.
SACK blocks allow TCP to coalesce multiple skbs in the retransmit
queue, thus filling the 17 fragments to maximal capacity.
CVE-2019-11477 -- u16 overflow of TCP_SKB_CB(skb)->tcp_gso_segs
Backport notes, provided by Joao Martins <joao.m.martins@oracle.com>
v4.15 or since commit 737ff314563 ("tcp: use sequence distance to
detect reordering") had switched from the packet-based FACK tracking and
switched to sequence-based.
v4.14 and older still have the old logic and hence on
tcp_skb_shift_data() needs to retain its original logic and have
@fack_count in sync. In other words, we keep the increment of pcount with
tcp_skb_pcount(skb) to later used that to update fack_count. To make it
more explicit we track the new skb that gets incremented to pcount in
@next_pcount, and we get to avoid the constant invocation of
tcp_skb_pcount(skb) all together.
Fixes: 832d11c5cd07 ("tcp: Try to restore large SKBs while SACK processing")
[ Upstream commit 8742dc86d0c7a9628117a989c11f04a9b6b898f3 ]
We currently don't reload pointers pointing into skb header
after doing pskb_may_pull() in _decode_session4(). So in case
pskb_may_pull() changed the pointers, we read from random
memory. Fix this by putting all the needed infos on the
stack, so that we don't need to access the header pointers
after doing pskb_may_pull().
[ Upstream commit 5483844c3fc18474de29f5d6733003526e0a9f78 ]
If tunnel registration failed during module initialization, the module
would fail to deregister the IPPROTO_COMP protocol and would attempt to
deregister the tunnel.
The tunnel was not deregistered during module-exit.
Fixes: dd9ee3444014e ("vti4: Fix a ipip packet processing bug in 'IPCOMP' virtual tunnel")
Signed-off-by: Jeremy Sowden <jeremy@azazel.net>
[ Upstream commit 19e4e768064a87b073a4b4c138b55db70e0cfb9f ]
inet_iif should be used for the raw socket lookup. inet_iif considers
rt_iif which handles the case of local traffic.
As it stands, ping to a local address with the '-I <dev>' option fails
ever since ping was changed to use SO_BINDTODEVICE instead of
cmsg + IP_PKTINFO.
IPv6 works fine.
Signed-off-by: David Ahern <dsahern@gmail.com>
[ Upstream commit d2f0c961148f65bc73eda72b9fa3a4e80973cb49 ]
Previously, during fragmentation after forwarding, skb->skb_iif isn't
preserved, i.e. 'ip_copy_metadata' does not copy skb_iif from given
'from' skb.
As a result, ip_do_fragment's creates fragments with zero skb_iif,
leading to inconsistent behavior.
Assume for example an eBPF program attached at tc egress (post
forwarding) that examines __sk_buff->ingress_ifindex:
- the correct iif is observed if forwarding path does not involve
fragmentation/refragmentation
- a bogus iif is observed if forwarding path involves
fragmentation/refragmentatiom
Fix, by preserving skb_iif during 'ip_copy_metadata'.
Signed-off-by: Shmulik Ladkani <shmulik.ladkani@gmail.com>
[ Upstream commit 19fad20d15a6494f47f85d869f00b11343ee5c78 ]
There is a UBSAN report as below:
UBSAN: Undefined behaviour in net/ipv4/tcp_input.c:2877:56
signed integer overflow:
2147483647 * 1000 cannot be represented in type 'int'
CPU: 3 PID: 0 Comm: swapper/3 Not tainted 5.1.0-rc4-00058-g582549e #1
Call Trace:
<IRQ>
dump_stack+0x8c/0xba
ubsan_epilogue+0x11/0x60
handle_overflow+0x12d/0x170
? ttwu_do_wakeup+0x21/0x320
__ubsan_handle_mul_overflow+0x12/0x20
tcp_ack_update_rtt+0x76c/0x780
tcp_clean_rtx_queue+0x499/0x14d0
tcp_ack+0x69e/0x1240
? __wake_up_sync_key+0x2c/0x50
? update_group_capacity+0x50/0x680
tcp_rcv_established+0x4e2/0xe10
tcp_v4_do_rcv+0x22b/0x420
tcp_v4_rcv+0xfe8/0x1190
ip_protocol_deliver_rcu+0x36/0x180
ip_local_deliver+0x15b/0x1a0
ip_rcv+0xac/0xd0
__netif_receive_skb_one_core+0x7f/0xb0
__netif_receive_skb+0x33/0xc0
netif_receive_skb_internal+0x84/0x1c0
napi_gro_receive+0x2a0/0x300
receive_buf+0x3d4/0x2350
? detach_buf_split+0x159/0x390
virtnet_poll+0x198/0x840
? reweight_entity+0x243/0x4b0
net_rx_action+0x25c/0x770
__do_softirq+0x19b/0x66d
irq_exit+0x1eb/0x230
do_IRQ+0x7a/0x150
common_interrupt+0xf/0xf
</IRQ>
It can be reproduced by:
echo 2147483647 > /proc/sys/net/ipv4/tcp_min_rtt_wlen
Fixes: f672258391b42 ("tcp: track min RTT using windowed min-filter")
Signed-off-by: ZhangXiaoxu <zhangxiaoxu5@huawei.com>
[ Upstream commit 20ff83f10f113c88d0bb74589389b05250994c16 ]
Before calling __ip_options_compile(), we need to ensure the network
header is a an IPv4 one, and that it is already pulled in skb->head.
RAW sockets going through a tunnel can end up calling ipv4_link_failure()
with total garbage in the skb, or arbitrary lengthes.
syzbot report :
BUG: KASAN: stack-out-of-bounds in memcpy include/linux/string.h:355 [inline]
BUG: KASAN: stack-out-of-bounds in __ip_options_echo+0x294/0x1120 net/ipv4/ip_options.c:123
Write of size 69 at addr ffff888096abf068 by task syz-executor.4/9204
CPU: 0 PID: 9204 Comm: syz-executor.4 Not tainted 5.1.0-rc5+ #77
Call Trace:
dump_stack+0x172/0x1f0 lib/dump_stack.c:113
print_address_description.cold+0x7c/0x20d mm/kasan/report.c:187
kasan_report.cold+0x1b/0x40 mm/kasan/report.c:317
check_memory_region_inline mm/kasan/generic.c:185 [inline]
check_memory_region+0x123/0x190 mm/kasan/generic.c:191
memcpy+0x38/0x50 mm/kasan/common.c:133
__icmp_send+0x725/0x1400 net/ipv4/icmp.c:695
ipv4_link_failure+0x29f/0x550 net/ipv4/route.c:1204
dst_link_failure include/net/dst.h:427 [inline]
vti6_xmit net/ipv6/ip6_vti.c:514 [inline]
vti6_tnl_xmit+0x10d4/0x1c0c net/ipv6/ip6_vti.c:553
__netdev_start_xmit include/linux/netdevice.h:4414 [inline]
netdev_start_xmit include/linux/netdevice.h:4423 [inline]
xmit_one net/core/dev.c:3292 [inline]
dev_hard_start_xmit+0x1b2/0x980 net/core/dev.c:3308
__dev_queue_xmit+0x271d/0x3060 net/core/dev.c:3878
dev_queue_xmit+0x18/0x20 net/core/dev.c:3911
neigh_direct_output+0x16/0x20 net/core/neighbour.c:1527
neigh_output include/net/neighbour.h:508 [inline]
ip_finish_output2+0x949/0x1740 net/ipv4/ip_output.c:229
ip_finish_output+0x73c/0xd50 net/ipv4/ip_output.c:317
NF_HOOK_COND include/linux/netfilter.h:278 [inline]
ip_output+0x21f/0x670 net/ipv4/ip_output.c:405
dst_output include/net/dst.h:444 [inline]
NF_HOOK include/linux/netfilter.h:289 [inline]
raw_send_hdrinc net/ipv4/raw.c:432 [inline]
raw_sendmsg+0x1d2b/0x2f20 net/ipv4/raw.c:663
inet_sendmsg+0x147/0x5d0 net/ipv4/af_inet.c:798
sock_sendmsg_nosec net/socket.c:651 [inline]
sock_sendmsg+0xdd/0x130 net/socket.c:661
sock_write_iter+0x27c/0x3e0 net/socket.c:988
call_write_iter include/linux/fs.h:1866 [inline]
new_sync_write+0x4c7/0x760 fs/read_write.c:474
__vfs_write+0xe4/0x110 fs/read_write.c:487
vfs_write+0x20c/0x580 fs/read_write.c:549
ksys_write+0x14f/0x2d0 fs/read_write.c:599
__do_sys_write fs/read_write.c:611 [inline]
__se_sys_write fs/read_write.c:608 [inline]
__x64_sys_write+0x73/0xb0 fs/read_write.c:608
do_syscall_64+0x103/0x610 arch/x86/entry/common.c:290
RIP: 0033:0x458c29
Code: ad b8 fb ff c3 66 2e 0f 1f 84 00 00 00 00 00 66 90 48 89 f8 48 89 f7 48 89 d6 48 89 ca 4d 89 c2 4d 89 c8 4c 8b 4c 24 08 0f 05 <48> 3d 01 f0 ff ff 0f 83 7b b8 fb ff c3 66 2e 0f 1f 84 00 00 00 00
RSP: 002b:00007f293b44bc78 EFLAGS: 00000246 ORIG_RAX: 0000000000000001
RAX: ffffffffffffffda RBX: 0000000000000003 RCX: 0000000000458c29
RDX: 0000000000000014 RSI: 00000000200002c0 RDI: 0000000000000003
RBP: 000000000073bf00 R08: 0000000000000000 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000246 R12: 00007f293b44c6d4
R13: 00000000004c8623 R14: 00000000004ded68 R15: 00000000ffffffff
The buggy address belongs to the page:
page:ffffea00025aafc0 count:0 mapcount:0 mapping:0000000000000000 index:0x0
flags: 0x1fffc0000000000()
raw: 01fffc0000000000 0000000000000000 ffffffff025a0101 0000000000000000
raw: 0000000000000000 0000000000000000 00000000ffffffff 0000000000000000
page dumped because: kasan: bad access detected
Memory state around the buggy address:
ffff888096abef80: 00 00 00 f2 f2 f2 f2 f2 00 00 00 00 00 00 00 f2
ffff888096abf000: f2 f2 f2 f2 00 00 00 00 00 00 00 00 00 00 00 00
>ffff888096abf080: 00 00 f3 f3 f3 f3 00 00 00 00 00 00 00 00 00 00
ffff888096abf100: 00 00 00 00 f1 f1 f1 f1 00 00 f3 f3 00 00 00 00
ffff888096abf180: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Fixes: ed0de45a1008 ("ipv4: recompile ip options in ipv4_link_failure")
Cc: Stephen Suryaputra <ssuryaextr@gmail.com>
Acked-by: Willem de Bruijn <willemb@google.com>
[ Upstream commit c543cb4a5f07e09237ec0fc2c60c9f131b2c79ad ]
fib_compute_spec_dst() needs to be called under rcu protection.
syzbot reported :
WARNING: suspicious RCU usage
5.1.0-rc4+ #165 Not tainted
include/linux/inetdevice.h:220 suspicious rcu_dereference_check() usage!
1 lock held by swapper/0/0:
#0: 0000000051b67925 ((&n->timer)){+.-.}, at: lockdep_copy_map include/linux/lockdep.h:170 [inline]
#0: 0000000051b67925 ((&n->timer)){+.-.}, at: call_timer_fn+0xda/0x720 kernel/time/timer.c:1315
stack backtrace:
CPU: 0 PID: 0 Comm: swapper/0 Not tainted 5.1.0-rc4+ #165
Call Trace:
<IRQ>
lockdep_rcu_suspicious+0x153/0x15d kernel/locking/lockdep.c:5162
__in_dev_get_rcu include/linux/inetdevice.h:220 [inline]
fib_compute_spec_dst+0xbbd/0x1030 net/ipv4/fib_frontend.c:294
spec_dst_fill net/ipv4/ip_options.c:245 [inline]
__ip_options_compile+0x15a7/0x1a10 net/ipv4/ip_options.c:343
ipv4_link_failure+0x172/0x400 net/ipv4/route.c:1195
arp_error_report+0xd1/0x1c0 net/ipv4/arp.c:297
neigh_invalidate+0x24b/0x570 net/core/neighbour.c:995
neigh_timer_handler+0xc35/0xf30 net/core/neighbour.c:1081
call_timer_fn+0x190/0x720 kernel/time/timer.c:1325
expire_timers kernel/time/timer.c:1362 [inline]
__run_timers kernel/time/timer.c:1681 [inline]
__run_timers kernel/time/timer.c:1649 [inline]
run_timer_softirq+0x652/0x1700 kernel/time/timer.c:1694
__do_softirq+0x266/0x95a kernel/softirq.c:293
invoke_softirq kernel/softirq.c:374 [inline]
irq_exit+0x180/0x1d0 kernel/softirq.c:414
exiting_irq arch/x86/include/asm/apic.h:536 [inline]
smp_apic_timer_interrupt+0x14a/0x570 arch/x86/kernel/apic/apic.c:1062
apic_timer_interrupt+0xf/0x20 arch/x86/entry/entry_64.S:807
[ Upstream commit ed0de45a1008991fdaa27a0152befcb74d126a8b ]
Recompile IP options since IPCB may not be valid anymore when
ipv4_link_failure is called from arp_error_report.
Refer to the commit 3da1ed7ac398 ("net: avoid use IPCB in cipso_v4_error")
and the commit before that (9ef6b42ad6fd) for a similar issue.
[ Upstream commit 50ce163a72d817a99e8974222dcf2886d5deb1ae ]
For some reason, tcp_grow_window() correctly tests if enough room
is present before attempting to increase tp->rcv_ssthresh,
but does not prevent it to grow past tcp_space()
This is causing hard to debug issues, like failing
the (__tcp_select_window(sk) >= tp->rcv_wnd) test
in __tcp_ack_snd_check(), causing ACK delays and possibly
slow flows.
Depending on tcp_rmem[2], MTU, skb->len/skb->truesize ratio,
we can see the problem happening on "netperf -t TCP_RR -- -r 2000,2000"
after about 60 round trips, when the active side no longer sends
immediate acks.
This bug predates git history.
Acked-by: Wei Wang <weiwan@google.com>
[ Upstream commit 988dc4a9a3b66be75b30405a5494faf0dc7cffb6 ]
gue tunnels run iptunnel_pull_offloads on received skbs. This can
determine a possible use-after-free accessing guehdr pointer since
the packet will be 'uncloned' running pskb_expand_head if it is a
cloned gso skb (e.g if the packet has been sent though a veth device)
Fixes: a09a4c8dd1ec ("tunnels: Remove encapsulation offloads on decap")
Signed-off-by: Lorenzo Bianconi <lorenzo.bianconi@redhat.com>
[ Upstream commit aecfde23108b8e637d9f5c5e523b24fb97035dc3 ]
RFC8257 §3.5 explicitly states that "A DCTCP sender MUST react to
loss episodes in the same way as conventional TCP".
Currently, Linux DCTCP performs no cwnd reduction when losses
are encountered. Optionally, the dctcp_clamp_alpha_on_loss resets
alpha to its maximal value if a RTO happens. This behavior
is sub-optimal for at least two reasons: i) it ignores losses
triggering fast retransmissions; and ii) it causes unnecessary large
cwnd reduction in the future if the loss was isolated as it resets
the historical term of DCTCP's alpha EWMA to its maximal value (i.e.,
denoting a total congestion). The second reason has an especially
noticeable effect when using DCTCP in high BDP environments, where
alpha normally stays at low values.
This patch replace the clamping of alpha by setting ssthresh to
half of cwnd for both fast retransmissions and RTOs, at most once
per RTT. Consequently, the dctcp_clamp_alpha_on_loss module parameter
has been removed.
The table below shows experimental results where we measured the
drop probability of a PIE AQM (not applying ECN marks) at a
bottleneck in the presence of a single TCP flow with either the
alpha-clamping option enabled or the cwnd halving proposed by this
patch. Results using reno or cubic are given for comparison.
| Link | RTT | Drop
TCP CC | speed | base+AQM | probability
CUBIC | 40Mbps | 7+20ms | 0.21%
RENO | | | 0.19%
DCTCP-CLAMP-ALPHA | | | 25.80%
DCTCP-HALVE-CWND | | | 0.22%
CUBIC | 100Mbps | 7+20ms | 0.03%
RENO | | | 0.02%
DCTCP-CLAMP-ALPHA | | | 23.30%
DCTCP-HALVE-CWND | | | 0.04%
CUBIC | 800Mbps | 1+1ms | 0.04%
RENO | | | 0.05%
DCTCP-CLAMP-ALPHA | | | 18.70%
DCTCP-HALVE-CWND | | | 0.06%
We see that, without halving its cwnd for all source of losses,
DCTCP drives the AQM to large drop probabilities in order to keep
the queue length under control (i.e., it repeatedly faces RTOs).
Instead, if DCTCP reacts to all source of losses, it can then be
controlled by the AQM using similar drop levels than cubic or reno.
Signed-off-by: Koen De Schepper <koen.de_schepper@nokia-bell-labs.com>
Signed-off-by: Olivier Tilmans <olivier.tilmans@nokia-bell-labs.com>
Cc: Bob Briscoe <research@bobbriscoe.net>
Cc: Lawrence Brakmo <brakmo@fb.com>
Cc: Florian Westphal <fw@strlen.de>
Cc: Daniel Borkmann <borkmann@iogearbox.net>
Cc: Andrew Shewmaker <agshew@gmail.com>
Cc: Glenn Judd <glenn.judd@morganstanley.com>
Acked-by: Florian Westphal <fw@strlen.de>
Acked-by: Daniel Borkmann <daniel@iogearbox.net>
[ Upstream commit 7c1306723ee916ea9f1fa7d9e4c7a6d029ca7aaf ]
Lorenzo reported that we could not properly find v4mapped sockets
in inet_diag_find_one_icsk(). This patch fixes the issue.
Reported-by: Lorenzo Colitti <lorenzo@google.com>
Acked-by: Lorenzo Colitti <lorenzo@google.com>
commit 5ea8ea2cb7f1d0db15762c9b0bb9e7330425a071 upstream.
Per listen(fd, backlog) rules, there is really no point accepting a SYN,
sending a SYNACK, and dropping the following ACK packet if accept queue
is full, because application is not draining accept queue fast enough.
This behavior is fooling TCP clients that believe they established a
flow, while there is nothing at server side. They might then send about
10 MSS (if using IW10) that will be dropped anyway while server is under
stress.
commit da8ab57863ed7e912d10b179b6bdc652f635bd19 upstream.
Back in linux-4.4, I inadvertently put a call to reqsk_put() in
inet_child_forget(), forgetting it could be called from two different
points.
In the case it is called from inet_csk_reqsk_queue_add(), we want to
keep the reference on the request socket, since it is released later by
the caller (tcp_v{4|6}_rcv())
This bug never showed up because atomic_dec_and_test() was not signaling
the underflow, and SLAB_DESTROY_BY RCU semantic for request sockets
prevented the request to be put in quarantine.
Recent conversion of socket refcount from atomic_t to refcount_t finally
exposed the bug.
So move the reqsk_put() to inet_csk_listen_stop() to fix this.
Thanks to Shankara Pailoor for using syzkaller and providing
a nice set of .config and C repro.
WARNING: CPU: 2 PID: 4277 at lib/refcount.c:186
refcount_sub_and_test+0x167/0x1b0 lib/refcount.c:186
CPU: 2 PID: 4277 Comm: syz-executor0 Not tainted 4.13.0-rc7 #3
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS
Ubuntu-1.8.2-1ubuntu1 04/01/2014
Call Trace:
<IRQ>
__dump_stack lib/dump_stack.c:16 [inline]
dump_stack+0xf7/0x1aa lib/dump_stack.c:52
panic+0x1ae/0x3a7 kernel/panic.c:180
__warn+0x1c4/0x1d9 kernel/panic.c:541
report_bug+0x211/0x2d0 lib/bug.c:183
fixup_bug+0x40/0x90 arch/x86/kernel/traps.c:190
do_trap_no_signal arch/x86/kernel/traps.c:224 [inline]
do_trap+0x260/0x390 arch/x86/kernel/traps.c:273
do_error_trap+0x118/0x340 arch/x86/kernel/traps.c:310
do_invalid_op+0x1b/0x20 arch/x86/kernel/traps.c:323
invalid_op+0x18/0x20 arch/x86/entry/entry_64.S:846
RIP: 0010:refcount_sub_and_test+0x167/0x1b0 lib/refcount.c:186
RSP: 0018:ffff88006e006b60 EFLAGS: 00010286
RAX: 0000000000000026 RBX: 0000000000000000 RCX: 0000000000000000
RDX: 0000000000000026 RSI: 1ffff1000dc00d2c RDI: ffffed000dc00d60
RBP: ffff88006e006bf0 R08: 0000000000000001 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000000 R12: 1ffff1000dc00d6d
R13: 00000000ffffffff R14: 0000000000000001 R15: ffff88006ce9d340
refcount_dec_and_test+0x1a/0x20 lib/refcount.c:211
reqsk_put+0x71/0x2b0 include/net/request_sock.h:123
tcp_v4_rcv+0x259e/0x2e20 net/ipv4/tcp_ipv4.c:1729
ip_local_deliver_finish+0x2e2/0xba0 net/ipv4/ip_input.c:216
NF_HOOK include/linux/netfilter.h:248 [inline]
ip_local_deliver+0x1ce/0x6d0 net/ipv4/ip_input.c:257
dst_input include/net/dst.h:477 [inline]
ip_rcv_finish+0x8db/0x19c0 net/ipv4/ip_input.c:397
ip_rcv+0xc3f/0x17d0 net/ipv4/ip_input.c:488
__netif_receive_skb_core+0x1fb7/0x31f0 net/core/dev.c:4298
__netif_receive_skb+0x2c/0x1b0 net/core/dev.c:4336
process_backlog+0x1c5/0x6d0 net/core/dev.c:5102
napi_poll net/core/dev.c:5499 [inline]
net_rx_action+0x6d3/0x14a0 net/core/dev.c:5565
__do_softirq+0x2cb/0xb2d kernel/softirq.c:284
do_softirq_own_stack+0x1c/0x30 arch/x86/entry/entry_64.S:898
</IRQ>
do_softirq.part.16+0x63/0x80 kernel/softirq.c:328
do_softirq kernel/softirq.c:176 [inline]
__local_bh_enable_ip+0x84/0x90 kernel/softirq.c:181
local_bh_enable include/linux/bottom_half.h:31 [inline]
rcu_read_unlock_bh include/linux/rcupdate.h:705 [inline]
ip_finish_output2+0x8ad/0x1360 net/ipv4/ip_output.c:231
ip_finish_output+0x74e/0xb80 net/ipv4/ip_output.c:317
NF_HOOK_COND include/linux/netfilter.h:237 [inline]
ip_output+0x1cc/0x850 net/ipv4/ip_output.c:405
dst_output include/net/dst.h:471 [inline]
ip_local_out+0x95/0x160 net/ipv4/ip_output.c:124
ip_queue_xmit+0x8c6/0x1810 net/ipv4/ip_output.c:504
tcp_transmit_skb+0x1963/0x3320 net/ipv4/tcp_output.c:1123
tcp_send_ack.part.35+0x38c/0x620 net/ipv4/tcp_output.c:3575
tcp_send_ack+0x49/0x60 net/ipv4/tcp_output.c:3545
tcp_rcv_synsent_state_process net/ipv4/tcp_input.c:5795 [inline]
tcp_rcv_state_process+0x4876/0x4b60 net/ipv4/tcp_input.c:5930
tcp_v4_do_rcv+0x58a/0x820 net/ipv4/tcp_ipv4.c:1483
sk_backlog_rcv include/net/sock.h:907 [inline]
__release_sock+0x124/0x360 net/core/sock.c:2223
release_sock+0xa4/0x2a0 net/core/sock.c:2715
inet_wait_for_connect net/ipv4/af_inet.c:557 [inline]
__inet_stream_connect+0x671/0xf00 net/ipv4/af_inet.c:643
inet_stream_connect+0x58/0xa0 net/ipv4/af_inet.c:682
SYSC_connect+0x204/0x470 net/socket.c:1628
SyS_connect+0x24/0x30 net/socket.c:1609
entry_SYSCALL_64_fastpath+0x18/0xad
RIP: 0033:0x451e59
RSP: 002b:00007f474843fc08 EFLAGS: 00000216 ORIG_RAX: 000000000000002a
RAX: ffffffffffffffda RBX: 0000000000718000 RCX: 0000000000451e59
RDX: 0000000000000010 RSI: 0000000020002000 RDI: 0000000000000007
RBP: 0000000000000046 R08: 0000000000000000 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000216 R12: 0000000000000000
R13: 00007ffc040a0f8f R14: 00007f47484409c0 R15: 0000000000000000
Fixes: ebb516af60e1 ("tcp/dccp: fix race at listener dismantle phase")
Reported-by: Shankara Pailoor <sp3485@columbia.edu>
Tested-by: Shankara Pailoor <sp3485@columbia.edu>
Cc: Guillaume Nault <gnault@redhat.com>
[ Upstream commit 9d3e1368bb45893a75a5dfb7cd21fdebfa6b47af ]
Commit 7716682cc58e ("tcp/dccp: fix another race at listener
dismantle") let inet_csk_reqsk_queue_add() fail, and adjusted
{tcp,dccp}_check_req() accordingly. However, TFO and syncookies
weren't modified, thus leaking allocated resources on error.
Contrary to tcp_check_req(), in both syncookies and TFO cases,
we need to drop the request socket. Also, since the child socket is
created with inet_csk_clone_lock(), we have to unlock it and drop an
extra reference (->sk_refcount is initially set to 2 and
inet_csk_reqsk_queue_add() drops only one ref).
For TFO, we also need to revert the work done by tcp_try_fastopen()
(with reqsk_fastopen_remove()).
Fixes: 7716682cc58e ("tcp/dccp: fix another race at listener dismantle")
Signed-off-by: Guillaume Nault <gnault@redhat.com>
[ Upstream commit ee60ad219f5c7c4fb2f047f88037770063ef785f ]
The race occurs in __mkroute_output() when 2 threads lookup a dst:
CPU A CPU B
find_exception()
find_exception() [fnhe expires]
ip_del_fnhe() [fnhe is deleted]
rt_bind_exception()
In rt_bind_exception() it will bind a deleted fnhe with the new dst, and
this dst will get no chance to be freed. It causes a dev defcnt leak and
consecutive dmesg warnings:
unregister_netdevice: waiting for ethX to become free. Usage count = 1
Especially thanks Jon to identify the issue.
This patch fixes it by setting fnhe_daddr to 0 in ip_del_fnhe() to stop
binding the deleted fnhe with a new dst when checking fnhe's fnhe_daddr
and daddr in rt_bind_exception().
It works as both ip_del_fnhe() and rt_bind_exception() are protected by
fnhe_lock and the fhne is freed by kfree_rcu().
Fixes: deed49df7390 ("route: check and remove route cache when we get route")
Signed-off-by: Jon Maxwell <jmaxwell37@gmail.com>
Signed-off-by: Xin Long <lucien.xin@gmail.com>
GET_ENTRIES
commit b301f2538759933cf9ff1f7c4f968da72e3f0757 upstream.
Make sure the table names via getsockopt GET_ENTRIES is nul-terminated
in ebtables and all the x_tables variants and their respective compat
code. Uncovered by KASAN.
Reported-by: Baozeng Ding <sploving1@gmail.com>
Cc: Zubin Mithra <zsm@chromium.org>
commit 30c7be26fd3587abcb69587f781098e3ca2d565b upstream.
In commits 93821778def10 ("udp: Fix rcv socket locking") and
f7ad74fef3af ("net/ipv6/udp: UDP encapsulation: break backlog_rcv into
__udpv6_queue_rcv_skb") UDP backlog handlers were renamed, but UDPlite
was forgotten.
This leads to crashes if UDPlite header is pulled twice, which happens
starting from commit e6afc8ace6dd ("udp: remove headers from UDP packets
before queueing")
Bug found by syzkaller team, thanks a lot guys !
Note that backlog use in UDP/UDPlite is scheduled to be removed starting
from linux-4.10, so this patch is only needed up to linux-4.9
Fixes: 93821778def1 ("udp: Fix rcv socket locking")
Fixes: f7ad74fef3af ("net/ipv6/udp: UDP encapsulation: break backlog_rcv into __udpv6_queue_rcv_skb")
Fixes: e6afc8ace6dd ("udp: remove headers from UDP packets before queueing")
Reported-by: Andrey Konovalov <andreyknvl@google.com>
Cc: Benjamin LaHaise <bcrl@kvack.org>
Cc: Herbert Xu <herbert@gondor.apana.org.au>
