Current TCP code relies on the local port of the listening socket
being the same as the destination address of the incoming
connection. Port redirection used by many transparent proxying
techniques obviously breaks this, so we have to store the original
destination port address.
This patch extends struct inet_request_sock and stores the incoming
destination port value there. It also modifies the handshake code to
use that value as the source port when sending reply packets.
Signed-off-by: KOVACS Krisztian <hidden@sch.bme.hu>
Netfilter's ip_route_me_harder() tries to re-route packets either
generated or re-routed by Netfilter. This patch changes
ip_route_me_harder() to handle packets from non-locally-bound sockets
with IP_TRANSPARENT set as local and to set the appropriate flowi
flags when re-doing the routing lookup.
The TCP stack sends out SYN+ACK/ACK/RST reply packets in response to
incoming packets. The non-local source address check on output bites
us again, as replies for transparently redirected traffic won't have a
chance to leave the node.
This patch selectively sets the FLOWI_FLAG_ANYSRC flag when doing the
route lookup for those replies. Transparent replies are enabled if the
listening socket has the transparent socket flag set.
inet_iif() in inet_sock.h requires route.h. Since users of inet_iif()
usually require other route.h functionality anyway this patch moves
inet_iif() to route.h.
Setting IP_TRANSPARENT is not really useful without allowing non-local
binds for the socket. To make user-space code simpler we allow these
binds even if IP_TRANSPARENT is set but IP_FREEBIND is not.
Signed-off-by: Tóth László Attila <panther@balabit.hu>
This patch introduces the IP_TRANSPARENT socket option: enabling that
will make the IPv4 routing omit the non-local source address check on
output. Setting IP_TRANSPARENT requires NET_ADMIN capability.
ip_route_output() contains a check to make sure that no flows with
non-local source IP addresses are routed. This obviously makes using
such addresses impossible.
This patch introduces a flowi flag which makes omitting this check
possible. The new flag provides a way of handling transparent and
non-transparent connections differently.
Signed-off-by: Julian Anastasov <ja@ssi.bg>
drivers/net/wireless/ath9k/core.c
drivers/net/wireless/ath9k/main.c
net/core/dev.c
Fix NULL dereference in tcp_4_send_ack().
As skb->dev is reset to NULL in tcp_v4_rcv() thus OOPS occurs:
BUG: unable to handle kernel NULL pointer dereference at 00000000000004d0
IP: [<ffffffff80498503>] tcp_v4_send_ack+0x203/0x250
Stack: ffff810005dbb000 ffff810015c8acc0 e77b2c6e5f861600 a01610802e90cb6d
0a08010100000000 88afffff88afffff 0000000080762be8 0000000115c872e8
0004122000000000 0000000000000001 ffffffff80762b88 0000000000000020
Call Trace:
<IRQ> [<ffffffff80499c33>] tcp_v4_reqsk_send_ack+0x20/0x22
[<ffffffff8049bce5>] tcp_check_req+0x108/0x14c
[<ffffffff8047aaf7>] ? rt_intern_hash+0x322/0x33c
[<ffffffff80499846>] tcp_v4_do_rcv+0x399/0x4ec
[<ffffffff8045ce4b>] ? skb_checksum+0x4f/0x272
[<ffffffff80485b74>] ? __inet_lookup_listener+0x14a/0x15c
[<ffffffff8049babc>] tcp_v4_rcv+0x6a1/0x701
[<ffffffff8047e739>] ip_local_deliver_finish+0x157/0x24a
[<ffffffff8047ec9a>] ip_local_deliver+0x72/0x7c
[<ffffffff8047e5bd>] ip_rcv_finish+0x38d/0x3b2
[<ffffffff803d3548>] ? scsi_io_completion+0x19d/0x39e
[<ffffffff8047ebe5>] ip_rcv+0x2a2/0x2e5
[<ffffffff80462faa>] netif_receive_skb+0x293/0x303
[<ffffffff80465a9b>] process_backlog+0x80/0xd0
[<ffffffff802630b4>] ? __rcu_process_callbacks+0x125/0x1b4
[<ffffffff8046560e>] net_rx_action+0xb9/0x17f
[<ffffffff80234cc5>] __do_softirq+0xa3/0x164
[<ffffffff8020c52c>] call_softirq+0x1c/0x28
<EOI> [<ffffffff8020de1c>] do_softirq+0x34/0x72
[<ffffffff80234b8e>] local_bh_enable_ip+0x3f/0x50
[<ffffffff804d43ca>] _spin_unlock_bh+0x12/0x14
[<ffffffff804599cd>] release_sock+0xb8/0xc1
[<ffffffff804a6f9a>] inet_stream_connect+0x146/0x25c
[<ffffffff80243078>] ? autoremove_wake_function+0x0/0x38
[<ffffffff8045751f>] sys_connect+0x68/0x8e
[<ffffffff80291818>] ? fd_install+0x5f/0x68
[<ffffffff80457784>] ? sock_map_fd+0x55/0x62
[<ffffffff8020b39b>] system_call_after_swapgs+0x7b/0x80
Code: 41 10 11 d0 83 d0 00 4d 85 ed 89 45 c0 c7 45 c4 08 00 00 00 74 07 41 8b 45 04 89 45 c8 48 8b 43 20 8b 4d b8 48 8d 55 b0 48 89 de <48> 8b 80 d0 04 00 00 48 8b b8 60 01 00 00 e8 20 ae fe ff 65 48
RIP [<ffffffff80498503>] tcp_v4_send_ack+0x203/0x250
RSP <ffffffff80762b78>
CR2: 00000000000004d0
Signed-off-by: Vitaliy Gusev <vgusev@openvz.org>
We must check tcp_skb_is_last() before doing a tcp_write_queue_next().
tcp_write_queue_next() must only be made if we know that
tcp_skb_is_last() evaluates to false.
This minor cleanup simplifies later changes which will convert
struct sk_buff and friends over to using struct list_head.
Signed-off-by: Sven Wegener <sven.wegener@stealer.net>
Signed-off-by: Simon Horman <horms@verge.net.au>
The nr_conns variable in the sync message header is only eight bits wide
and will overflow on interfaces with a large MTU. As a result the backup
won't parse all connections contained in the sync buffer. On regular
ethernet with an MTU of 1500 this isn't a problem, because we can't
overflow the value, but consider jumbo frames being used on a cross-over
connection between both directors.
We now restrict the size of the sync buffer, so that we never put more
than 255 connections into a single sync buffer.
I'm trying to use the TCP_MAXSEG option to setsockopt() to set the MSS
for both sides of a bidirectional connection.
man tcp says: "If this option is set before connection establishment, it
also changes the MSS value announced to the other end in the initial
packet."
However, the kernel only uses the MTU/route cache to set the advertised
MSS. That means if I set the MSS to, say, 500 before calling connect(),
I will send at most 500-byte packets, but I will still receive 1500-byte
packets in reply.
This is a bug, either in the kernel or the documentation.
This patch (applies to latest net-2.6) reduces the advertised value to
that requested by the user as long as setsockopt() is called before
connect() or accept(). This seems like the behavior that one would
expect as well as that which is documented.
I've tried to make sure that things that depend on the advertised MSS
are set correctly.
Signed-off-by: Tom Quetchenbach <virtualphtn@gmail.com>
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
If lost skb is sacked, we might have nothing to retransmit
as high as the retransmit_high is pointing to, so place
it lower to avoid unnecessary walking.
This is mainly for the case where high L'ed skbs gets sacked.
Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi>
Most importantly avoid doing it with cumulative ACK. However,
since we have lost_cnt_hint in the picture as well needing
adjustments, it's not as trivial as dealing with
retransmit_skb_hint (and cannot be done in the all place we
could trivially leave retransmit_skb_hint untouched).
With the previous patch, this should mostly remove O(n^2)
behavior while cumulative ACKs start flowing once rexmit
after a lossy round-trip made it through.
Most importantly avoid doing it with cumulative ACK. Not clearing
means that we no longer need n^2 processing in resolution of each
fast recovery.
This doesn't much sense here afaict, probably never has. Since
fragmenting and collapsing deal the hints by themselves, there
should be very little reason for the rexmit loop to do that.
Both loops are quite similar, so they can be combined
with little effort. As a result, forward_skb_hint becomes
obsolete as well.
The validity of the retransmit_high must then be ensured
if no L'ed skb exits!
This makes a minor change to behavior, we now have to
iterate the head to find out that the loop terminates.
Because lost counter no longer requires tuning, this is
trivial to remove (the tuning wouldn't have been too
hard either) because no "new" retransmittable skb appeared
below retransmit_skb_hint when SACKing for sure.
I suspect it might have been related to the changed amount
of lost skbs, which was counted by retransmit_cnt_hint that
got changed.
The place for this clearing was very illogical anyway,
it should have been after the LOST-bit clearing loop to
make any sense.
Main benefit in this is that we can then freely point
the retransmit_skb_hint to anywhere we want to because
there's no longer need to know what would be the count
changes involve, and since this is really used only as a
terminator, unnecessary work is one time walk at most,
and if some retransmissions are necessary after that
point later on, the walk is not full waste of time
anyway.
Since retransmit_high must be kept valid, all lost
markers must ensure that.
Now I also have learned how those "holes" in the
rexmittable skbs can appear, mtu probe does them. So
I removed the misleading comment as well.
This useful because we'd need to verifying soon in many places
which makes things slightly more complex than it used to be.
Ie., the difference between partial and all clearing doesn't
exists anymore since the SACK optimizations got dropped by
an sacktag rewrite.
Change __contant_htons() to htons() in the IPVS code when not in an
initializer.
-Brian
Signed-off-by: Brian Haley <brian.haley@hp.com>
Acked-by: Julius Volz <juliusv@google.com>
ip_vs_info_seq_start/ip_vs_info_seq_stop
This teaches sparse that the following are not problems:
make C=1
CHECK net/ipv4/ipvs/ip_vs_ctl.c
net/ipv4/ipvs/ip_vs_ctl.c:1793:14: warning: context imbalance in 'ip_vs_info_seq_start' - wrong count at exit
net/ipv4/ipvs/ip_vs_ctl.c:1842:13: warning: context imbalance in 'ip_vs_info_seq_stop' - unexpected unlock
Acked-by: Sven Wegener <sven.wegener@stealer.net>
ip_vs_conn_new expects a union nf_inet_addr as the type for its address
parameters, not a plain integer.
This problem was detected by sparse.
make C=1
CHECK net/ipv4/ipvs/ip_vs_core.c
net/ipv4/ipvs/ip_vs_core.c:469:9: warning: Using plain integer as NULL pointer
Jumping to out unlocks __ip_vs_svc_lock, but that lock is not taken until
after code that may jump to out.
make C=1
net/ipv4/ipvs/ip_vs_ctl.c:1332:2: warning: context imbalance in 'ip_vs_edit_service' - unexpected unlock
The previous patch in response to the recursive locking on IPsec
reception is broken as it tries to drop the BH socket lock while in
user context.
This patch fixes it by shrinking the section protected by the
socket lock to sock_queue_rcv_skb only. The only reason we added
the lock is for the accounting which happens in that function.
lvs-next-2.6
as it accentally contained the wrong set of patches. These will be
submitted separately.
Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk>
net/dccp/input.c
net/dccp/options.c
master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6
net/mac80211/mlme.c
Instead of duplicating the fields, integrate a user stats structure into
the kernel stats structure. This is more robust when the members are
changed, because they are now automatically kept in sync.
Reviewed-by: Julius Volz <juliusv@google.com>
Instead of checking the value in include/net/ip_vs.h, we can just
restrict the range in our Kconfig file. This will prevent values outside
of the range early.
Remove an incorrect ip_route_me_harder() that was probably a result of
merging my IPv6 patches with the local client patches. With this, IPv6+NAT
are working again.
Signed-off-by: Julius Volz <juliusv@google.com>
Now that LVS can load balance locally generated traffic, packets may come
from the loopback device and thus may have a partial checksum.
The existing code allows for the case where there is no checksum at all for
TCP, however Herbert Xu has confirmed that this is not legal.
How to reproduce ?
- create a network namespace
- use tcp protocol and get timewait socket
- exit the network namespace
- after a moment (when the timewait socket is destroyed), the kernel
panics.
# BUG: unable to handle kernel NULL pointer dereference at
0000000000000007
IP: [<ffffffff821e394d>] inet_twdr_do_twkill_work+0x6e/0xb8
PGD 119985067 PUD 11c5c0067 PMD 0
Oops: 0000 [1] SMP
CPU 1
Modules linked in: ipv6 button battery ac loop dm_mod tg3 libphy ext3 jbd
edd fan thermal processor thermal_sys sg sata_svw libata dock serverworks
sd_mod scsi_mod ide_disk ide_core [last unloaded: freq_table]
Pid: 0, comm: swapper Not tainted 2.6.27-rc2 #3
RIP: 0010:[<ffffffff821e394d>] [<ffffffff821e394d>]
RSP: 0018:ffff88011ff7fed0 EFLAGS: 00010246
RAX: ffffffffffffffff RBX: ffffffff82339420 RCX: ffff88011ff7ff30
RDX: 0000000000000001 RSI: ffff88011a4d03c0 RDI: ffff88011ac2fc00
RBP: ffffffff823392e0 R08: 0000000000000000 R09: ffff88002802a200
R10: ffff8800a5c4b000 R11: ffffffff823e4080 R12: ffff88011ac2fc00
R13: 0000000000000001 R14: 0000000000000001 R15: 0000000000000000
FS: 0000000041cbd940(0000) GS:ffff8800bff839c0(0000)
knlGS:0000000000000000
CS: 0010 DS: 0018 ES: 0018 CR0: 000000008005003b
CR2: 0000000000000007 CR3: 00000000bd87c000 CR4: 00000000000006e0
Process swapper (pid: 0, threadinfo ffff8800bff9e000, task
ffff88011ff76690)
Stack: ffffffff823392e0 0000000000000100 ffffffff821e3a3a
0000000000000008
0000000000000000 ffffffff821e3a61 ffff8800bff7c000 ffffffff8203c7e7
ffff88011ff7ff10 ffff88011ff7ff10 0000000000000021 ffffffff82351108
Call Trace:
<IRQ> [<ffffffff821e3a3a>] ? inet_twdr_hangman+0x0/0x9e
[<ffffffff821e3a61>] ? inet_twdr_hangman+0x27/0x9e
[<ffffffff8203c7e7>] ? run_timer_softirq+0x12c/0x193
[<ffffffff820390d1>] ? __do_softirq+0x5e/0xcd
[<ffffffff8200d08c>] ? call_softirq+0x1c/0x28
[<ffffffff8200e611>] ? do_softirq+0x2c/0x68
[<ffffffff8201a055>] ? smp_apic_timer_interrupt+0x8e/0xa9
[<ffffffff8200cad6>] ? apic_timer_interrupt+0x66/0x70
<EOI> [<ffffffff82011f4c>] ? default_idle+0x27/0x3b
[<ffffffff8200abbd>] ? cpu_idle+0x5f/0x7d
Code: e8 01 00 00 4c 89 e7 41 ff c5 e8 8d fd ff ff 49 8b 44 24 38 4c 89 e7
65 8b 14 25 24 00 00 00 89 d2 48 8b 80 e8 00 00 00 48 f7 d0 <48> 8b 04 d0
48 ff 40 58 e8 fc fc ff ff 48 89 df e8 c0 5f 04 00
RIP [<ffffffff821e394d>] inet_twdr_do_twkill_work+0x6e/0xb8
RSP <ffff88011ff7fed0>
This patch provides a function to purge all timewait sockets related
to a network namespace. The timewait sockets life cycle is not tied with
the network namespace, that means the timewait sockets stay alive while
the network namespace dies. The timewait sockets are for avoiding to
receive a duplicate packet from the network, if the network namespace is
freed, the network stack is removed, so no chance to receive any packets
from the outside world. Furthermore, having a pending destruction timer
on these sockets with a network namespace freed is not safe and will lead
to an oops if the timer callback which try to access data belonging to
the namespace like for example in:
-> NET_INC_STATS_BH(twsk_net(tw), LINUX_MIB_TIMEWAITED);
Purging the timewait sockets at the network namespace destruction will:
1) speed up memory freeing for the namespace
2) fix kernel panic on asynchronous timewait destruction
Signed-off-by: Daniel Lezcano <dlezcano@fr.ibm.com>
Acked-by: Denis V. Lunev <den@openvz.org>
Acked-by: Eric W. Biederman <ebiederm@xmission.com>
It is standard to use ipv6_addr_copy() to fill in
the in6 element of a union nf_inet_addr snet.
Thanks to Julius Volz for pointing this out.
Cc: Brian Haley <brian.haley@hp.com>
Sorry, this was my error.
Thanks to Julius Volz for pointing it out.
We can't use non-local link-local addresses for destinations, without
knowing the interface on which we can reach the address. Reject them for
now.
They are only used in this file, so they should be static
