I noticed sysctl_local_port_range[] and its associated seqlock
sysctl_local_port_range_lock were on separate cache lines.
Moreover, sysctl_local_port_range[] was close to unrelated
variables, highly modified, leading to cache misses.
Moving these two variables in a structure can help data
locality and moving this structure to read_mostly section
helps sharing of this data among cpus.
Cleanup of extern declarations (moved in include file where
they belong), and use of inet_get_local_port_range()
accessor instead of direct access to ports values.
Signed-off-by: Eric Dumazet <dada1@cosmosbay.com>
Current UDP port allocation is suboptimal.
We select the shortest chain to chose a port (out of 512)
that will hash in this shortest chain.
First, it can lead to give not so ramdom ports and ease
give attackers more opportunities to break the system.
Second, it can consume a lot of CPU to scan all table
in order to find the shortest chain.
Third, in some pathological cases we can fail to find
a free port even if they are plenty of them.
This patch zap the search for a short chain and only
use one random seed. Problem of getting long chains
should be addressed in another way, since we can
obtain long chains with non random ports.
Based on a report and patch from Vitaly Mayatskikh
While looking for some common code I came across difference
in checksum calculation between tcp_v6_send_(reset|ack) I
couldn't explain. I checked both v4 and v6 and found out that
both seem to have the same "feature". I couldn't find anything
in rfc nor anywhere else which would state that md5 option
should be ignored like it was in case of reset so I came to
a conclusion that this is probably a genuine bug. I suspect
that addition of md5 just was fooled by the excessive
copy-paste code in those functions and the reset part was
never tested well enough to find out the problem.
Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi>
git://git.kernel.org/pub/scm/linux/kernel/git/kaber/nf-next-2.6
By passing in the family through which extensions were invoked, a bit
of data space can be reclaimed. The "family" member will be added to
the parameter structures and the check functions be adjusted.
Signed-off-by: Jan Engelhardt <jengelh@medozas.de>
This patch does this for target extensions' destroy functions.
This patch does this for target extensions' checkentry functions.
This patch does this for target extensions' target functions.
This patch does this for match extensions' destroy functions.
This patch does this for match extensions' checkentry functions.
The function signatures for Xtables extensions have grown over time.
It involves a lot of typing/replication, and also a bit of stack space
even if they are not used. Realize an NFWS2008 idea and pack them into
structs. The skb remains outside of the struct so gcc can continue to
apply its optimizations.
This patch does this for match extensions' match functions.
A few ambiguities have also been addressed. The "offset" parameter for
example has been renamed to "fragoff" (there are so many different
offsets already) and "protoff" to "thoff" (there is more than just one
protocol here, so clarify).
It used to be that {ip,ip6,etc}_tables called extension->checkentry
themselves, but this can be moved into the xtables core.
Netfilter connection tracking requires all IPv4 packets to be defragmented.
Both the socket match and the TPROXY target depend on this functionality, so
this patch separates the Netfilter IPv4 defrag hooks into a separate module.
Signed-off-by: KOVACS Krisztian <hidden@sch.bme.hu>
Same story as with iptable_filter, iptables_raw tables.
First, allow entry in notifier hook.
Second, start conntrack cleanup in netns to which netdevice belongs.
net.netfilter.nf_conntrack_log_invalid sysctl
sysctl
/proc/net/stat/ip_conntrack
Show correct conntrack count, while I'm at it.
not skb
This is cleaner, we already know conntrack to which event is relevant.
/proc/net/stat/ip_conntrack, /proc/net/ip_conntrack_expect
Again, it's deducible from skb, but we're going to use it for
nf_conntrack_checksum and statistics, so just pass it from upper layer.
It's deducible from skb->dev or skb->dst->dev, but we know netns at
the moment of call, so pass it down and use for finding and creating
conntracks.
Make per-netns a) expectation hash and b) expectations count.
Expectations always belongs to netns to which it's master conntrack belong.
This is natural and doesn't bloat expectation.
Proc files and leaf users are stubbed to init_net, this is temporary.
Take netns from skb->dst->dev. It should be safe because, they are called
from LOCAL_OUT hook where dst is valid (though, I'm not exactly sure about
IPVS and queueing packets to userspace).
[Patrick: its safe everywhere since they already expect skb->dst to be set]
* make per-netns conntrack hash
Other solution is to add ->ct_net pointer to tuplehashes and still has one
hash, I tried that it's ugly and requires more code deep down in protocol
modules et al.
* propagate netns pointer to where needed, e. g. to conntrack iterators.
Sysctls and proc files are stubbed to init_net's one. This is temporary.
Now that dev_net() exists, the usefullness of them is even less. Also they're
a big problem in resolving circular header dependencies necessary for
NOTRACK-in-netns patch. See below.
Like with other modules (such as ipt_state), ipt_recent.h is changed
to forward definitions to (IOW include) xt_recent.h, and xt_recent.c
is changed to use the new constant names.
and (try to) consistently use u_int8_t for the L3 family.
Because of rounding, in certain conditions, i.e. when in congestion
avoidance state rho is smaller than 1/128 of the current cwnd, TCP
Hybla congestion control starves and the cwnd is kept constant
forever.
This patch forces an increment by one segment after #send_cwnd calls
without increments(newreno behavior).
Signed-off-by: Daniele Lacamera <root@danielinux.net>
This patch add mc_count to struct in_device and updates
increment/decrement/initilaize of this field in IPv4 and in IPv6.
- Also printing the vfs /proc entry (/proc/net/igmp) is adjusted to
use the new mc_count.
Signed-off-by: Rami Rosen <ramirose@gmail.com>
When TCP receive copy offload is enabled it's possible that
tcp_rcv_established() will cause two acks to be sent for a single
packet. In the case that a tcp_dma_early_copy() is successful,
copied_early is set to true which causes tcp_cleanup_rbuf() to be
called early which can send an ack. Further along in
tcp_rcv_established(), __tcp_ack_snd_check() is called and will
schedule a delayed ACK. If no packets are processed before the delayed
ack timer expires the packet will be acked twice.
Signed-off-by: Denis V. Lunev <den@openvz.org>
I'm quite sure that if I give this function in its old format
for you to inspect, you start to wonder what is the type of
demanded or if it's a global variable.
It all started from me noticing that this urgent check in
tcp_clean_rtx_queue is unnecessarily inside the loop. Then
I took a longer look to it and found out that the users of
urg_mode can trivially do without, well almost, there was
one gotcha.
Bonus: those funny people who use urg with >= 2^31 write_seq -
snd_una could now rejoice too (that's the only purpose for the
between being there, otherwise a simple compare would have done
the thing). Not that I assume that the rest of the tcp code
happily lives with such mind-boggling numbers :-). Alas, it
turned out to be impossible to set wmem to such numbers anyway,
yes I really tried a big sendfile after setting some wmem but
nothing happened :-). ...Tcp_wmem is int and so is sk_sndbuf...
So I hacked a bit variable to long and found out that it seems
to work... :-)
Wrap calling sk->sk_backlog_rcv() in a function. This will allow extending the
generic sk_backlog_rcv behaviour.
Use the socket cached in the skb if it's present.
Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com>
To be able to use the cached socket reference in the skb during input
processing we add a new set of lookup functions that receive the skb on
their argument list.
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
lvs-next-2.6
Since IPVS now has partial IPv6 support, this patch moves IPVS from
net/ipv4/ipvs to net/netfilter/ipvs. It's a result of:
$ git mv net/ipv4/ipvs net/netfilter
and adapting the relevant Kconfigs/Makefiles to the new path.
Signed-off-by: Julius Volz <juliusv@google.com>
Signed-off-by: Simon Horman <horms@verge.net.au>
Based upon a report by Vito Caputo.
The iptables tproxy code has to be able to do UDP socket hash lookups,
so we have to provide an exported lookup function for this purpose.
