path: root/net/ipv6/Kconfig
2010-05-11ipv6: ip6mr: support multiple tablesPatrick McHardy
This patch adds support for multiple independant multicast routing instances, named "tables". Userspace multicast routing daemons can bind to a specific table instance by issuing a setsockopt call using a new option MRT6_TABLE. The table number is stored in the raw socket data and affects all following ip6mr setsockopt(), getsockopt() and ioctl() calls. By default, a single table (RT6_TABLE_DFLT) is created with a default routing rule pointing to it. Newly created pim6reg devices have the table number appended ("pim6regX"), with the exception of devices created in the default table, which are named just "pim6reg" for compatibility reasons. Packets are directed to a specific table instance using routing rules, similar to how regular routing rules work. Currently iif, oif and mark are supported as keys, source and destination addresses could be supported additionally. Example usage: - bind pimd/xorp/... to a specific table: uint32_t table = 123; setsockopt(fd, SOL_IPV6, MRT6_TABLE, &table, sizeof(table)); - create routing rules directing packets to the new table: # ip -6 mrule add iif eth0 lookup 123 # ip -6 mrule add oif eth0 lookup 123 Signed-off-by: Patrick McHardy <kaber@trash.net>
2009-10-07IPv6: Fix 6RD typoAlexandre Cassen
Following fix a small typo. Signed-off-by: Alexandre Cassen <acassen@freebox.fr> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-07ipv6 sit: 6rd (IPv6 Rapid Deployment) Support.YOSHIFUJI Hideaki / 吉藤英明
IPv6 Rapid Deployment (6rd; draft-ietf-softwire-ipv6-6rd) builds upon mechanisms of 6to4 (RFC3056) to enable a service provider to rapidly deploy IPv6 unicast service to IPv4 sites to which it provides customer premise equipment. Like 6to4, it utilizes stateless IPv6 in IPv4 encapsulation in order to transit IPv4-only network infrastructure. Unlike 6to4, a 6rd service provider uses an IPv6 prefix of its own in place of the fixed 6to4 prefix. With this option enabled, the SIT driver offers 6rd functionality by providing additional ioctl API to configure the IPv6 Prefix for in stead of static 2002::/16 for 6to4. Original patch was done by Alexandre Cassen <acassen@freebox.fr> based on old Internet-Draft. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-12trivial: Kconfig: .ko is normally not included in module namesPavel Machek
.ko is normally not included in Kconfig help, make it consistent. Signed-off-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-03-30trivial: fix typos/grammar errors in Kconfig textsMatt LaPlante
Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2008-07-25ipsec: ipcomp - Merge IPComp implementationsHerbert Xu
This patch merges the IPv4/IPv6 IPComp implementations since most of the code is identical. As a result future enhancements will no longer need to be duplicated. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-27Revert "ipv6: Fix typo in net/ipv6/Kconfig"David S. Miller
This reverts commit 5b3f129c5592ca35b3fe8916767c58b98710478c. As requested by Maciej W. Rozycki. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-24ipv6: Fix typo in net/ipv6/KconfigMichael Beasley
Two is used in the wrong context here, as you are connecting to an IPv6 network over IPv4; not connecting two IPv6 networks to an IPv4 one. Signed-off-by: Michael Beasley <youvegotmoxie@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-13[NET]: Sink IPv6 menuoptions into its own submenuJan Engelhardt
Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-08Merge branch 'net-2.6.26-isatap-20080403' of ↵David S. Miller
git://git.linux-ipv6.org/gitroot/yoshfuji/linux-2.6-dev
2008-04-05[IPV6] MROUTE: Support PIM-SM (SSM).YOSHIFUJI Hideaki
Based on ancient patch by Mickael Hoerdt <hoerdt@clarinet.u-strasbg.fr>, which is available at <http://www-r2.u-strasbg.fr/~hoerdt/dev/linux_ipv6_mforwarding/patch-linux-ipv6-mforwarding-0.1a>. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2008-04-05[IPV6] MROUTE: Support multicast forwarding.YOSHIFUJI Hideaki
2008-04-03[IPV6] NDISC: Don't rely on node-type hint from L2 unless required.YOSHIFUJI Hideaki
2008-03-20[IPV6] KCONFIG: Fix description about IPV6_TUNNEL.YOSHIFUJI Hideaki
Based on notice from "Colin" <colins@sjtu.edu.cn>. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-04[ESP]: Add select on AUTHENCHerbert Xu
Now the ESP uses the AEAD interface even for algorithms which are not combined mode, we need to select CONFIG_CRYPTO_AUTHENC as otherwise only combined mode algorithms will work. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-31[IPSEC]: Use crypto_aead and authenc in ESPHerbert Xu
This patch converts ESP to use the crypto_aead interface and in particular the authenc algorithm. This lays the foundations for future support of combined mode algorithms. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[IPV6] MIP6: Loadable module support for MIPv6.Masahide NAKAMURA
This patch makes MIPv6 loadable module named "mip6". Here is a modprobe.conf(5) example to load it automatically when user application uses XFRM state for MIPv6: alias xfrm-type-10-43 mip6 alias xfrm-type-10-60 mip6 Some MIPv6 feature is not included by this modular, however, it should not be affected to other features like either IPsec or IPv6 with and without the patch. We may discuss XFRM, MH (RAW socket) and ancillary data/sockopt separately for future work. Loadable features: * MH receiving check (to send ICMP error back) * RO header parsing and building (i.e. RH2 and HAO in DSTOPTS) * XFRM policy/state database handling for RO These are NOT covered as loadable: * Home Address flags and its rule on source address selection * XFRM sub policy (depends on its own kernel option) * XFRM functions to receive RO as IPv6 extension header * MH sending/receiving through raw socket if user application opens it (since raw socket allows to do so) * RH2 sending as ancillary data * RH2 operation with setsockopt(2) Signed-off-by: Masahide NAKAMURA <nakam@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[IPV6] ADDRCONF: Optimistic Duplicate Address Detection (RFC 4429) Support.Neil Horman
Nominally an autoconfigured IPv6 address is added to an interface in the Tentative state (as per RFC 2462). Addresses in this state remain in this state while the Duplicate Address Detection process operates on them to determine their uniqueness on the network. During this period, these tentative addresses may not be used for communication, increasing the time before a node may be able to communicate on a network. Using Optimistic Duplicate Address Detection, autoconfigured addresses may be used immediately for communication on the network, as long as certain rules are followed to avoid conflicts with other nodes during the Duplicate Address Detection process. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-13[IPSEC]: make sit use the xfrm4_tunnel_registerKazunori MIYAZAWA
This patch makes sit use xfrm4_tunnel_register instead of inet_add_protocol. It solves conflict of sit device with inter address family IPsec tunnel. Signed-off-by: Kazunori MIYAZAWA <miyazawa@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[NET]: Rethink mark field in struct flowiThomas Graf
Now that all protocols have been made aware of the mark field it can be moved out of the union thus simplyfing its usage. The config options in the IPv4/IPv6/DECnet subsystems to enable respectively disable mark based routing only obfuscate the code with ifdefs, the cost for the additional comparison in the flow key is insignificant, and most distributions have all these options enabled by default anyway. Therefore it makes sense to remove the config options and enable mark based routing by default. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-18[IPV6]: Make IPV6_SUBTREES depend on IPV6_MULTIPLE_TABLES.Ville Nuorvala
As IPV6_SUBTREES can't work without IPV6_MULTIPLE_TABLES have IPV6_SUBTREES depend on it. Signed-off-by: Ville Nuorvala <vnuorval@tcs.hut.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-11[IPV6]: Seperate sit driver to extra moduleJoerg Roedel
This patch removes the driver of the IPv6-in-IPv4 tunnel driver (sit) from the IPv6 module. It adds an option to Kconfig which makes it possible to compile it as a seperate module. Signed-off-by: Joerg Roedel <joro-lkml@zlug.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-04[XFRM]: BEET modeDiego Beltrami
This patch introduces the BEET mode (Bound End-to-End Tunnel) with as specified by the ietf draft at the following link: http://www.ietf.org/internet-drafts/draft-nikander-esp-beet-mode-06.txt The patch provides only single family support (i.e. inner family = outer family). Signed-off-by: Diego Beltrami <diego.beltrami@gmail.com> Signed-off-by: Miika Komu <miika@iki.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Abhinav Pathak <abhinav.pathak@hiit.fi> Signed-off-by: Jeff Ahrenholz <ahrenholz@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[IPV6] ROUTE: Routing by FWMARK.YOSHIFUJI Hideaki
Based on patch by Jean Lorchat <lorchat@sfc.wide.ad.jp>. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2006-09-22[IPV6]: Add Kconfig to enable Mobile IPv6.Masahide NAKAMURA
Add Kconfig to enable Mobile IPv6. Based on MIPL2 kernel patch. Signed-off-by: Noriaki TAKAMIYA <takamiya@po.ntts.co.jp> Signed-off-by: Masahide NAKAMURA <nakam@linux-ipv6.org> Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2006-09-22[XFRM] STATE: Introduce route optimization mode.Masahide NAKAMURA
Route optimization is used with routing header and destination options header for Mobile IPv6. At outbound it makes header space like IPsec transport. At inbound it does nothing because exhdrs.c functions have responsibility to update skbuff information for these headers. Signed-off-by: Masahide NAKAMURA <nakam@linux-ipv6.org> Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[IPV6] KCONFIG: Add subtrees support.YOSHIFUJI Hideaki
This is for developers only. Based on MIPL2 kernel patch. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: Ville Nuorvala <vnuorval@tcs.hut.fi Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[IPV6]: Policy Routing RulesThomas Graf
Adds support for policy routing rules including a new local table for routes with a local destination. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[IPV6]: Multiple Routing TablesThomas Graf
Adds the framework to support multiple IPv6 routing tables. Currently all automatically generated routes are put into the same table. This could be changed at a later point after considering the produced locking overhead. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-21[IPSEC] ESP: Use block ciphers where applicableHerbert Xu
This patch converts IPSec/ESP to use the new block cipher type where applicable. Similar to the HMAC conversion, existing algorithm names have been kept for compatibility. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2006-06-17[IPSEC] xfrm: Abstract out encapsulation modesHerbert Xu
This patch adds the structure xfrm_mode. It is meant to represent the operations carried out by transport/tunnel modes. By doing this we allow additional encapsulation modes to be added without clogging up the xfrm_input/xfrm_output paths. Candidate modes include 4-to-6 tunnel mode, 6-to-4 tunnel mode, and BEET modes. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-28[INET]: Introduce tunnel4/tunnel6Herbert Xu
Basically this patch moves the generic tunnel protocol stuff out of xfrm4_tunnel/xfrm6_tunnel and moves it into the new files of tunnel4.c and tunnel6 respectively. The reason for this is that the problem that Hugo uncovered is only the tip of the iceberg. The real problem is that when we removed the dependency of ipip on xfrm4_tunnel we didn't really consider the module case at all. For instance, as it is it's possible to build both ipip and xfrm4_tunnel as modules and if the latter is loaded then ipip simply won't load. After considering the alternatives I've decided that the best way out of this is to restore the dependency of ipip on the non-xfrm-specific part of xfrm4_tunnel. This is acceptable IMHO because the intention of the removal was really to be able to use ipip without the xfrm subsystem. This is still preserved by this patch. So now both ipip/xfrm4_tunnel depend on the new tunnel4.c which handles the arbitration between the two. The order of processing is determined by a simple integer which ensures that ipip gets processed before xfrm4_tunnel. The situation for ICMP handling is a little bit more complicated since we may not have enough information to determine who it's for. It's not a big deal at the moment since the xfrm ICMP handlers are basically no-ops. In future we can deal with this when we look at ICMP caching in general. The user-visible change to this is the removal of the TUNNEL Kconfig prompts. This makes sense because it can only be used through IPCOMP as it stands. The addition of the new modules shouldn't introduce any problems since module dependency will cause them to be loaded. Oh and I also turned some unnecessary pskb's in IPv6 related to this patch to skb's. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[IPV6]: ROUTE: Add experimental support for Route Information Option in RA ↵YOSHIFUJI Hideaki
(RFC4191). Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[IPV6]: ROUTE: Add support for Router Preference (RFC4191).YOSHIFUJI Hideaki
2006-03-20[IPV6]: ADDRCONF: Use our standard algorithm for randomized ifid.YOSHIFUJI Hideaki
RFC 3041 describes an algorithm to generate random interface identifier. In RFC 3041bis, it is allowed to use different algorithm than one described in RFC 3041. So, let's use our standard pseudo random algorithm to simplify our implementation. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-07-19[NET]: Make ipip/ip6_tunnel independant of XFRMPatrick McHardy
Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-07-11[NET]: move config options out to individual protocolsSam Ravnborg
Move the protocol specific config options out to the specific protocols. With this change net/Kconfig now starts to become readable and serve as a good basis for further re-structuring. The menu structure is left almost intact, except that indention is fixed in most cases. Most visible are the INET changes where several "depends on INET" are replaced with a single ifdef INET / endif pair. Several new files were created to accomplish this change - they are small but serve the purpose that config options are now distributed out where they belongs. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: David S. Miller <davem@davemloft.net>
