path: root/net/ipv6/addrlabel.c
2008-01-28[IPV6] ADDRLABEL: Fix double free on label deletion.YOSHIFUJI Hideaki
If an entry is being deleted because it has only one reference, we immediately delete it and blindly register the rcu handler for it, This results in oops by double freeing that object. This patch fixes it by consolidating the code paths for the deletion; let its rcu handler delete the object if it has no more reference. Bug was found by Mitsuru Chinen <mitch@linux.vnet.ibm.com> Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[IPV6] ADDRLABEL: Sparse: Make several functions static.YOSHIFUJI Hideaki
Fix following sparse warnings: | net/ipv6/addrlabel.c:172:25: warning: symbol 'ip6addrlbl_alloc' was not declared. Should it be static? | net/ipv6/addrlabel.c:219:5: warning: symbol '__ip6addrlbl_add' was not declared. Should it be static? | net/ipv6/addrlabel.c:260:5: warning: symbol 'ip6addrlbl_add' was not declared. Should it be static? | net/ipv6/addrlabel.c:285:5: warning: symbol '__ip6addrlbl_del' was not declared. Should it be static? | net/ipv6/addrlabel.c:311:5: warning: symbol 'ip6addrlbl_del' was not declared. Should it be static? Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2008-01-28[NET]: Make rtnetlink infrastructure network namespace aware (v3)Denis V. Lunev
After this patch none of the netlink callback support anything except the initial network namespace but the rtnetlink infrastructure now handles multiple network namespaces. Changes from v2: - IPv6 addrlabel processing Changes from v1: - no need for special rtnl_unlock handling - fixed IPv6 ndisc Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NET]: Modify all rtnetlink methods to only work in the initial namespace (v2)Denis V. Lunev
Before I can enable rtnetlink to work in all network namespaces I need to be certain that something won't break. So this patch deliberately disables all of the rtnletlink methods in everything except the initial network namespace. After the methods have been audited this extra check can be disabled. Changes from v1: - added IPv6 addrlabel protection Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-28[IPV6] ADDRCONF: Support RFC3484 configurable address selection policy table.YOSHIFUJI Hideaki
Policy table is implemented as an RCU linear list since we do not expect large list nor frequent updates. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
