When an application needs to force a source IP on an active TCP socket
it has to use bind(IP, port=x).
As most applications do not want to deal with already used ports, x is
often set to 0, meaning the kernel is in charge to find an available
port.
But kernel does not know yet if this socket is going to be a listener or
be connected.
It has very limited choices (no full knowledge of final 4-tuple for a
connect())
With limited ephemeral port range (about 32K ports), it is very easy to
fill the space.
This patch adds a new SOL_IP socket option, asking kernel to ignore
the 0 port provided by application in bind(IP, port=0) and only
remember the given IP address.
The port will be automatically chosen at connect() time, in a way
that allows sharing a source port as long as the 4-tuples are unique.
This new feature is available for both IPv4 and IPv6 (Thanks Neal)
Tested:
Wrote a test program and checked its behavior on IPv4 and IPv6.
strace(1) shows sequences of bind(IP=127.0.0.2, port=0) followed by
connect().
Also getsockname() show that the port is still 0 right after bind()
but properly allocated after connect().
socket(PF_INET, SOCK_STREAM, IPPROTO_IP) = 5
setsockopt(5, SOL_IP, IP_BIND_ADDRESS_NO_PORT, [1], 4) = 0
bind(5, {sa_family=AF_INET, sin_port=htons(0), sin_addr=inet_addr("127.0.0.2")}, 16) = 0
getsockname(5, {sa_family=AF_INET, sin_port=htons(0), sin_addr=inet_addr("127.0.0.2")}, [16]) = 0
connect(5, {sa_family=AF_INET, sin_port=htons(53174), sin_addr=inet_addr("127.0.0.3")}, 16) = 0
getsockname(5, {sa_family=AF_INET, sin_port=htons(38050), sin_addr=inet_addr("127.0.0.2")}, [16]) = 0
IPv6 test :
socket(PF_INET6, SOCK_STREAM, IPPROTO_IP) = 7
setsockopt(7, SOL_IP, IP_BIND_ADDRESS_NO_PORT, [1], 4) = 0
bind(7, {sa_family=AF_INET6, sin6_port=htons(0), inet_pton(AF_INET6, "::1", &sin6_addr), sin6_flowinfo=0, sin6_scope_id=0}, 28) = 0
getsockname(7, {sa_family=AF_INET6, sin6_port=htons(0), inet_pton(AF_INET6, "::1", &sin6_addr), sin6_flowinfo=0, sin6_scope_id=0}, [28]) = 0
connect(7, {sa_family=AF_INET6, sin6_port=htons(57300), inet_pton(AF_INET6, "::1", &sin6_addr), sin6_flowinfo=0, sin6_scope_id=0}, 28) = 0
getsockname(7, {sa_family=AF_INET6, sin6_port=htons(60964), inet_pton(AF_INET6, "::1", &sin6_addr), sin6_flowinfo=0, sin6_scope_id=0}, [28]) = 0
I was able to bind()/connect() a million concurrent IPv4 sockets,
instead of ~32000 before patch.
lpaa23:~# ulimit -n 1000010
lpaa23:~# ./bind --connect --num-flows=1000000 &
1000000 sockets
lpaa23:~# grep TCP /proc/net/sockstat
TCP: inuse 2000063 orphan 0 tw 47 alloc 2000157 mem 66
Check that a given source port is indeed used by many different
connections :
lpaa23:~# ss -t src :40000 | head -10
State Recv-Q Send-Q Local Address:Port Peer Address:Port
ESTAB 0 0 127.0.0.2:40000 127.0.202.33:44983
ESTAB 0 0 127.0.0.2:40000 127.2.27.240:44983
ESTAB 0 0 127.0.0.2:40000 127.2.98.5:44983
ESTAB 0 0 127.0.0.2:40000 127.0.124.196:44983
ESTAB 0 0 127.0.0.2:40000 127.2.139.38:44983
ESTAB 0 0 127.0.0.2:40000 127.1.59.80:44983
ESTAB 0 0 127.0.0.2:40000 127.3.6.228:44983
ESTAB 0 0 127.0.0.2:40000 127.0.38.53:44983
ESTAB 0 0 127.0.0.2:40000 127.1.197.10:44983
In preparation for changing how struct net is refcounted
on kernel sockets pass the knowledge that we are creating
a kernel socket from sock_create_kern through to sk_alloc.
This patch divides the IPv6 flow label space into two ranges:
0-7ffff is reserved for flow label manager, 80000-fffff will be
used for creating auto flow labels (per RFC6438). This only affects how
labels are set on transmit, it does not affect receive. This range split
can be disbaled by systcl.
Background:
IPv6 flow labels have been an unmitigated disappointment thus far
in the lifetime of IPv6. Support in HW devices to use them for ECMP
is lacking, and OSes don't turn them on by default. If we had these
we could get much better hashing in IPv6 networks without resorting
to DPI, possibly eliminating some of the motivations to to define new
encaps in UDP just for getting ECMP.
Unfortunately, the initial specfications of IPv6 did not clarify
how they are to be used. There has always been a vague concept that
these can be used for ECMP, flow hashing, etc. and we do now have a
good standard how to this in RFC6438. The problem is that flow labels
can be either stateful or stateless (as in RFC6438), and we are
presented with the possibility that a stateless label may collide
with a stateful one. Attempts to split the flow label space were
rejected in IETF. When we added support in Linux for RFC6438, we
could not turn on flow labels by default due to this conflict.
This patch splits the flow label space and should give us
a path to enabling auto flow labels by default for all IPv6 packets.
This is an API change so we need to consider compatibility with
existing deployment. The stateful range is chosen to be the lower
values in hopes that most uses would have chosen small numbers.
Once we resolve the stateless/stateful issue, we can proceed to
look at enabling RFC6438 flow labels by default (starting with
scaled testing).
Signed-off-by: Tom Herbert <tom@herbertland.com>
The ipv6 code uses a mixture of coding styles. In some instances check for NULL
pointer is done as x != NULL and sometimes as x. x is preferred according to
checkpatch and this patch makes the code consistent by adopting the latter
form.
No changes detected by objdiff.
Signed-off-by: Ian Morris <ipm@chirality.org.uk>
pointer is done as x == NULL and sometimes as !x. !x is preferred according to
form.
This is specified by RFC 7217.
Cc: Erik Kline <ek@google.com>
Cc: Fernando Gont <fgont@si6networks.com>
Cc: Lorenzo Colitti <lorenzo@google.com>
Cc: YOSHIFUJI Hideaki/吉藤英明 <hideaki.yoshifuji@miraclelinux.com>
As part of an effort to move skb->dropcount to skb->cb[] use a common
macro in protocol families using skb->cb[] for ancillary data to
validate available room in skb->cb[].
Signed-off-by: Eyal Birger <eyal.birger@gmail.com>
Try to reduce number of possible fn_sernum mutation by constraining them
to their namespace.
Also remove rt_genid which I forgot to remove in 705f1c869d577c ("ipv6:
remove rt6i_genid").
Cc: YOSHIFUJI Hideaki <hideaki@yoshifuji.org>
Cc: Martin Lau <kafai@fb.com>
ipv6_opt_accepted() assumes IP6CB(skb) holds the struct inet6_skb_parm
that it needs. Lets not assume this, as TCP stack might use a different
place.
net.ipv4.ip_nonlocal_bind sysctl was global to all network
namespaces. This patch allows to set a different value for each
network namespace.
Signed-off-by: Vincent Bernat <vincent@bernat.im>
This patch makes no changes to the logic of the code but simply addresses
coding style issues as detected by checkpatch.
Both objdump and diff -w show no differences.
A number of items are addressed in this patch:
* Multiple spaces converted to tabs
* Spaces before tabs removed.
* Spaces in pointer typing cleansed (char *)foo etc.
* Remove space after sizeof
* Ensure spacing around comparators such as if statements.
Automatically generate flow labels for IPv6 packets on transmit.
The flow label is computed based on skb_get_hash. The flow label will
only automatically be set when it is zero otherwise (i.e. flow label
manager hasn't set one). This supports the transmit side functionality
of RFC 6438.
Added an IPv6 sysctl auto_flowlabels to enable/disable this behavior
system wide, and added IPV6_AUTOFLOWLABEL socket option to enable this
functionality per socket.
By default, auto flowlabels are disabled to avoid possible conflicts
with flow label manager, however if this feature proves useful we
may want to enable it by default.
It should also be noted that FreeBSD has already implemented automatic
flow labels (including the sysctl and socket option). In FreeBSD,
automatic flow labels default to enabled.
Performance impact:
Running super_netperf with 200 flows for TCP_RR and UDP_RR for
IPv6. Note that in UDP case, __skb_get_hash will be called for
every packet with explains slight regression. In the TCP case
the hash is saved in the socket so there is no regression.
Automatic flow labels disabled:
TCP_RR:
86.53% CPU utilization
127/195/322 90/95/99% latencies
1.40498e+06 tps
UDP_RR:
90.70% CPU utilization
118/168/243 90/95/99% latencies
1.50309e+06 tps
Automatic flow labels enabled:
TCP_RR:
85.90% CPU utilization
128/199/337 90/95/99% latencies
1.40051e+06
UDP_RR
92.61% CPU utilization
115/164/236 90/95/99% latencies
1.4687e+06
Signed-off-by: Tom Herbert <therbert@google.com>
When an UDP application switches from AF_INET to AF_INET6 sockets, we
have a small performance degradation for IPv4 communications because of
extra cache line misses to access ipv6only information.
This can also be noticed for TCP listeners, as ipv6_only_sock() is also
used from __inet_lookup_listener()->compute_score()
This is magnified when SO_REUSEPORT is used.
Move ipv6only into struct sock_common so that it is available at
no extra cost in lookups.
It doesn't seem like an protocols are setting anything other
than the default, and allowing to arbitrarily disable checksums
for a whole protocol seems dangerous. This can be done on a per
socket basis.
commit 8f0ea0fe3a036a47767f9c80e (snmp: reduce percpu needs by 50%)
reduced snmp array size to 1, so technically it doesn't have to be
an array any more. What's more, after the following commit:
commit 933393f58fef9963eac61db8093689544e29a600
Date: Thu Dec 22 11:58:51 2011 -0600
percpu: Remove irqsafe_cpu_xxx variants
We simply say that regular this_cpu use must be safe regardless of
preemption and interrupt state. That has no material change for x86
and s390 implementations of this_cpu operations. However, arches that
do not provide their own implementation for this_cpu operations will
now get code generated that disables interrupts instead of preemption.
probably no arch wants to have SNMP_ARRAY_SZ == 2. At least after
almost 3 years, no one complains.
So, just convert the array to a single pointer and remove snmp_mib_init()
and snmp_mib_free() as well.
Cc: Christoph Lameter <cl@linux.com>
With the introduction of IPV6_FL_F_REFLECT, there is no guarantee of
flow label unicity. This patch introduces a new sysctl to protect the old
behaviour, enable by default.
Changelog of V3:
* rename ip6_flowlabel_consistency to flowlabel_consistency
* use net_info_ratelimited()
* checkpatch cleanups
Signed-off-by: Florent Fourcot <florent.fourcot@enst-bretagne.fr>
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
git://git.kernel.org/pub/scm/linux/kernel/git/klassert/ipsec-next
Steffen Klassert says:
pull request (net-next): ipsec-next 2013-12-19
1) Use the user supplied policy index instead of a generated one
if present. From Fan Du.
2) Make xfrm migration namespace aware. From Fan Du.
3) Make the xfrm state and policy locks namespace aware. From Fan Du.
4) Remove ancient sleeping when the SA is in acquire state,
we now queue packets to the policy instead. This replaces the
sleeping code.
5) Remove FLOWI_FLAG_CAN_SLEEP. This was used to notify xfrm about the
posibility to sleep. The sleeping code is gone, so remove it.
6) Check user specified spi for IPComp. Thr spi for IPcomp is only
16 bit wide, so check for a valid value. From Fan Du.
7) Export verify_userspi_info to check for valid user supplied spi ranges
with pfkey and netlink. From Fan Du.
8) RFC3173 states that if the total size of a compressed payload and the IPComp
header is not smaller than the size of the original payload, the IP datagram
must be sent in the original non-compressed form. These packets are dropped
by the inbound policy check because they are not transformed. Document the need
to set 'level use' for IPcomp to receive such packets anyway. From Fan Du.
Please pull or let me know if there are problems.
The other field in ipv4_config, log_martians, was converted to a
per-interface setting, so we can just remove the whole structure.
Reviewed-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
FLOWI_FLAG_CAN_SLEEP was used to notify xfrm about the posibility
to sleep until the needed states are resolved. This code is gone,
so FLOWI_FLAG_CAN_SLEEP is not needed anymore.
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
Pull networking fixes from David Miller:
"Mostly these are fixes for fallout due to merge window changes, as
well as cures for problems that have been with us for a much longer
period of time"
1) Johannes Berg noticed two major deficiencies in our genetlink
registration. Some genetlink protocols we passing in constant
counts for their ops array rather than something like
ARRAY_SIZE(ops) or similar. Also, some genetlink protocols were
using fixed IDs for their multicast groups.
We have to retain these fixed IDs to keep existing userland tools
working, but reserve them so that other multicast groups used by
other protocols can not possibly conflict.
In dealing with these two problems, we actually now use less state
management for genetlink operations and multicast groups.
2) When configuring interface hardware timestamping, fix several
drivers that simply do not validate that the hwtstamp_config value
is one the driver actually supports. From Ben Hutchings.
3) Invalid memory references in mwifiex driver, from Amitkumar Karwar.
4) In dev_forward_skb(), set the skb->protocol in the right order
relative to skb_scrub_packet(). From Alexei Starovoitov.
5) Bridge erroneously fails to use the proper wrapper functions to make
calls to netdev_ops->ndo_vlan_rx_{add,kill}_vid. Fix from Toshiaki
Makita.
6) When detaching a bridge port, make sure to flush all VLAN IDs to
prevent them from leaking, also from Toshiaki Makita.
7) Put in a compromise for TCP Small Queues so that deep queued devices
that delay TX reclaim non-trivially don't have such a performance
decrease. One particularly problematic area is 802.11 AMPDU in
wireless. From Eric Dumazet.
8) Fix crashes in tcp_fastopen_cache_get(), we can see NULL socket dsts
here. Fix from Eric Dumzaet, reported by Dave Jones.
9) Fix use after free in ipv6 SIT driver, from Willem de Bruijn.
10) When computing mergeable buffer sizes, virtio-net fails to take the
virtio-net header into account. From Michael Dalton.
11) Fix seqlock deadlock in ip4_datagram_connect() wrt. statistic
bumping, this one has been with us for a while. From Eric Dumazet.
12) Fix NULL deref in the new TIPC fragmentation handling, from Erik
Hugne.
13) 6lowpan bit used for traffic classification was wrong, from Jukka
Rissanen.
14) macvlan has the same issue as normal vlans did wrt. propagating LRO
disabling down to the real device, fix it the same way. From Michal
Kubecek.
15) CPSW driver needs to soft reset all slaves during suspend, from
Daniel Mack.
16) Fix small frame pacing in FQ packet scheduler, from Eric Dumazet.
17) The xen-netfront RX buffer refill timer isn't properly scheduled on
partial RX allocation success, from Ma JieYue.
18) When ipv6 ping protocol support was added, the AF_INET6 protocol
initialization cleanup path on failure was borked a little. Fix
from Vlad Yasevich.
19) If a socket disconnects during a read/recvmsg/recvfrom/etc that
blocks we can do the wrong thing with the msg_name we write back to
userspace. From Hannes Frederic Sowa. There is another fix in the
works from Hannes which will prevent future problems of this nature.
20) Fix route leak in VTI tunnel transmit, from Fan Du.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (106 commits)
genetlink: make multicast groups const, prevent abuse
genetlink: pass family to functions using groups
genetlink: add and use genl_set_err()
genetlink: remove family pointer from genl_multicast_group
genetlink: remove genl_unregister_mc_group()
hsr: don't call genl_unregister_mc_group()
quota/genetlink: use proper genetlink multicast APIs
drop_monitor/genetlink: use proper genetlink multicast APIs
genetlink: only pass array to genl_register_family_with_ops()
tcp: don't update snd_nxt, when a socket is switched from repair mode
atm: idt77252: fix dev refcnt leak
xfrm: Release dst if this dst is improper for vti tunnel
netlink: fix documentation typo in netlink_set_err()
be2net: Delete secondary unicast MAC addresses during be_close
be2net: Fix unconditional enabling of Rx interface options
net, virtio_net: replace the magic value
ping: prevent NULL pointer dereference on write to msg_name
bnx2x: Prevent "timeout waiting for state X"
bnx2x: prevent CFC attention
bnx2x: Prevent panic during DMAE timeout
Commit 6d0bfe22611602f36617bc7aa2ffa1bbb2f54c67
net: ipv6: Add IPv6 support to the ping socket
introduced a change in the cleanup logic of inet6_init and
has a bug in that ipv6_packet_cleanup() may not be called.
Fix the cleanup ordering.
CC: Hannes Frederic Sowa <hannes@stressinduktion.org>
CC: Lorenzo Colitti <lorenzo@google.com>
CC: Fabio Estevam <fabio.estevam@freescale.com>
Signed-off-by: Vlad Yasevich <vyasevich@gmail.com>
Pull core locking changes from Ingo Molnar:
"The biggest changes:
- add lockdep support for seqcount/seqlocks structures, this
unearthed both bugs and required extra annotation.
- move the various kernel locking primitives to the new
kernel/locking/ directory"
* 'core-locking-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (21 commits)
block: Use u64_stats_init() to initialize seqcounts
locking/lockdep: Mark __lockdep_count_forward_deps() as static
lockdep/proc: Fix lock-time avg computation
locking/doc: Update references to kernel/mutex.c
ipv6: Fix possible ipv6 seqlock deadlock
cpuset: Fix potential deadlock w/ set_mems_allowed
seqcount: Add lockdep functionality to seqcount/seqlock structures
net: Explicitly initialize u64_stats_sync structures for lockdep
locking: Move the percpu-rwsem code to kernel/locking/
locking: Move the lglocks code to kernel/locking/
locking: Move the rwsem code to kernel/locking/
locking: Move the rtmutex code to kernel/locking/
locking: Move the semaphore core to kernel/locking/
locking: Move the spinlock code to kernel/locking/
locking: Move the lockdep code to kernel/locking/
locking: Move the mutex code to kernel/locking/
hung_task debugging: Add tracepoint to report the hang
x86/locking/kconfig: Update paravirt spinlock Kconfig description
lockstat: Report avg wait and hold times
lockdep, x86/alternatives: Drop ancient lockdep fixup message
In order to enable lockdep on seqcount/seqlock structures, we
must explicitly initialize any locks.
The u64_stats_sync structure, uses a seqcount, and thus we need
to introduce a u64_stats_init() function and use it to initialize
the structure.
This unfortunately adds a lot of fairly trivial initialization code
to a number of drivers. But the benefit of ensuring correctness makes
this worth while.
Because these changes are required for lockdep to be enabled, and the
changes are quite trivial, I've not yet split this patch out into 30-some
separate patches, as I figured it would be better to get the various
maintainers thoughts on how to best merge this change along with
the seqcount lockdep enablement.
Feedback would be appreciated!
Signed-off-by: John Stultz <john.stultz@linaro.org>
Acked-by: Julian Anastasov <ja@ssi.bg>
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Cc: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru>
Cc: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org>
Cc: Jesse Gross <jesse@nicira.com>
Cc: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
Cc: "Michael S. Tsirkin" <mst@redhat.com>
Cc: Mirko Lindner <mlindner@marvell.com>
Cc: Patrick McHardy <kaber@trash.net>
Cc: Roger Luethi <rl@hellgate.ch>
Cc: Simon Horman <horms@verge.net.au>
Cc: Stephen Hemminger <stephen@networkplumber.org>
Cc: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Cc: Wensong Zhang <wensong@linux-vs.org>
Cc: netdev@vger.kernel.org
Link: http://lkml.kernel.org/r/1381186321-4906-2-git-send-email-john.stultz@linaro.org
The code that is implemented is per memory cgroup not per netns, and
having per netns bits is just confusing. Remove the per netns bits to
make it easier to see what is really going on.
Initialize the ehash and ipv6_hash_secrets with net_get_random_once.
Each compilation unit gets its own secret now:
ipv4/inet_hashtables.o
ipv4/udp.o
ipv6/inet6_hashtables.o
ipv6/udp.o
rds/connection.o
The functions still get inlined into the hashing functions. In the fast
path we have at most two (needed in ipv6) if (unlikely(...)).
Cc: Eric Dumazet <edumazet@google.com>
TCP listener refactoring, part 4 :
To speed up inet lookups, we moved IPv4 addresses from inet to struct
sock_common
Now is time to do the same for IPv6, because it permits us to have fast
lookups for all kind of sockets, including upcoming SYN_RECV.
Getting IPv6 addresses in TCP lookups currently requires two extra cache
lines, plus a dereference (and memory stall).
inet6_sk(sk) does the dereference of inet_sk(__sk)->pinet6
This patch is way bigger than its IPv4 counter part, because for IPv4,
we could add aliases (inet_daddr, inet_rcv_saddr), while on IPv6,
it's not doable easily.
inet6_sk(sk)->daddr becomes sk->sk_v6_daddr
inet6_sk(sk)->rcv_saddr becomes sk->sk_v6_rcv_saddr
And timewait socket also have tw->tw_v6_daddr & tw->tw_v6_rcv_saddr
at the same offset.
We get rid of INET6_TW_MATCH() as INET6_MATCH() is now the generic
macro.
There was some bug report on ipv6 module removal path before.
Also, as Stephen pointed out, after vxlan module gets ipv6 support,
the ipv6 stub it used is not safe against this module removal either.
So, let's just remove inet6_exit() so that ipv6 module will not be
able to be unloaded.
Signed-off-by: Cong Wang <amwang@redhat.com>
When loading the ipv6 module, ndisc_init() is called before
ip6_route_init(). As the former registers a handler calling
fib6_run_gc(), this opens a window to run the garbage collector
before necessary data structures are initialized. If a network
device is initialized in this window, adding MAC address to it
triggers a NETDEV_CHANGEADDR event, leading to a crash in
fib6_clean_all().
Take the event handler registration out of ndisc_init() into a
separate function ndisc_late_init() and move it after
ip6_route_init().
Signed-off-by: Michal Kubecek <mkubecek@suse.cz>
This patch adds the IPv6 version of "arp_reduce", ndisc_send_na()
will be needed.
Cc: David Stevens <dlstevens@us.ibm.com>
route short circuit only has IPv4 part, this patch adds
the IPv6 part. nd_tbl will be needed.
In case IPv6 is compiled as a module, introduce a stub
for ipv6_sock_mc_join and ipv6_sock_mc_drop etc.. It will be used
by vxlan module. Suggested by Ben.
This is an ugly but easy solution for now.
Cc: Ben Hutchings <bhutchings@solarflare.com>
Current net name space has only one genid for both IPv4 and IPv6, it has below
drawbacks:
- Add/delete an IPv4 address will invalidate all IPv6 routing table entries.
- Insert/remove XFRM policy will also invalidate both IPv4/IPv6 routing table
entries even when the policy is only applied for one address family.
Thus, this patch attempt to split one genid for two to cater for IPv4 and IPv6
separately in a fine granularity.
Signed-off-by: Fan Du <fan.du@windriver.com>
This adds the ability to send ICMPv6 echo requests without a
raw socket. The equivalent ability for ICMPv4 was added in
2011.
Instead of having separate code paths for IPv4 and IPv6, make
most of the code in net/ipv4/ping.c dual-stack and only add a
few IPv6-specific bits (like the protocol definition) to a new
net/ipv6/ping.c. Hopefully this will reduce divergence and/or
duplication of bugs in the future.
Caveats:
- Setting options via ancillary data (e.g., using IPV6_PKTINFO
to specify the outgoing interface) is not yet supported.
- There are no separate security settings for IPv4 and IPv6;
everything is controlled by /proc/net/ipv4/ping_group_range.
- The proc interface does not yet display IPv6 ping sockets
properly.
Tested with a patched copy of ping6 and using raw socket calls.
Compiles and works with all of CONFIG_IPV6={n,m,y}.
Signed-off-by: Lorenzo Colitti <lorenzo@google.com>
Following patch refactors GRE code into ip tunneling code and GRE
specific code. Common tunneling code is moved to ip_tunnel module.
ip_tunnel module is written as generic library which can be used
by different tunneling implementations.
ip_tunnel module contains following components:
- packet xmit and rcv generic code. xmit flow looks like
(gre_xmit/ipip_xmit)->ip_tunnel_xmit->ip_local_out.
- hash table of all devices.
- lookup for tunnel devices.
- control plane operations like device create, destroy, ioctl, netlink
operations code.
- registration for tunneling modules, like gre, ipip etc.
- define single pcpu_tstats dev->tstats.
- struct tnl_ptk_info added to pass parsed tunnel packet parameters.
ipip.h header is renamed to ip_tunnel.h
Signed-off-by: Pravin B Shelar <pshelar@nicira.com>
This patch requires multicast interface-scoped addresses to supply a
sin6_scope_id. Because the sin6_scope_id is now also correctly used
in case of interface-scoped multicast traffic this enables one to use
interface scoped addresses over interfaces which are not targeted by the
default multicast route (the route has to be put there manually, though).
getsockname() and getpeername() now return the correct sin6_scope_id in
case of interface-local mc addresses.
v2:
a) rebased ontop of patch 1/4 (now uses ipv6_addr_props)
v3:
a) reverted changes for ipv6_addr_props
v4:
a) unchanged
Cc: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
Acked-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
Acked-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>dave
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
Allow privileged users in any user namespace to bind to
privileged sockets in network namespaces they control.
Allow an unpriviled user who has created a user namespace, and then
created a network namespace to effectively use the new network
namespace, by reducing capable(CAP_NET_ADMIN) and
capable(CAP_NET_RAW) calls to be ns_capable(net->user_ns,
CAP_NET_ADMIN), or capable(net->user_ns, CAP_NET_RAW) calls.
Settings that merely control a single network device are allowed.
Either the network device is a logical network device where
restrictions make no difference or the network device is hardware NIC
that has been explicity moved from the initial network namespace.
In general policy and network stack state changes are allowed while
resource control is left unchanged.
Allow the SIOCSIFADDR ioctl to add ipv6 addresses.
Allow the SIOCDIFADDR ioctl to delete ipv6 addresses.
Allow the SIOCADDRT ioctl to add ipv6 routes.
Allow the SIOCDELRT ioctl to delete ipv6 routes.
Allow creation of ipv6 raw sockets.
Allow setting the IPV6_JOIN_ANYCAST socket option.
Allow setting the IPV6_FL_A_RENEW parameter of the IPV6_FLOWLABEL_MGR
socket option.
Allow setting the IPV6_TRANSPARENT socket option.
Allow setting the IPV6_HOPOPTS socket option.
Allow setting the IPV6_RTHDRDSTOPTS socket option.
Allow setting the IPV6_DSTOPTS socket option.
Allow setting the IPV6_IPSEC_POLICY socket option.
Allow setting the IPV6_XFRM_POLICY socket option.
Allow sending packets with the IPV6_2292HOPOPTS control message.
Allow sending packets with the IPV6_2292DSTOPTS control message.
Allow sending packets with the IPV6_RTHDRDSTOPTS control message.
Allow setting the multicast routing socket options on non multicast
routing sockets.
Allow the SIOCADDTUNNEL, SIOCCHGTUNNEL, and SIOCDELTUNNEL ioctls for
setting up, changing and deleting tunnels over ipv6.
Allow the SIOCADDTUNNEL, SIOCCHGTUNNEL, SIOCDELTUNNEL ioctls for
setting up, changing and deleting ipv6 over ipv4 tunnels.
Allow the SIOCADDPRL, SIOCDELPRL, SIOCCHGPRL ioctls for adding,
deleting, and changing the potential router list for ISATAP tunnels.
Sing GSO support is now separate, pull it out of the module
and make it its own init call.
Remove the cleanup functions as they are no longer called.
Signed-off-by: Vlad Yasevich <vyasevic@redhat.com>
Separate IPv6 offload functionality into its own file
in preparation for the move out of the module
Switch IPv6 protocol to using the new GRO/GSO calls and data.
Convert to using the new GSO/GRO registration mechanism and new
packet offload structure.
It seems IPV6_GRO_CB(skb)->proto can be destroyed in skb_gro_receive()
if a new skb is allocated (to serve as an anchor for frag_list)
We copy NAPI_GRO_CB() only (not the IPV6 specific part) in :
*NAPI_GRO_CB(nskb) = *NAPI_GRO_CB(p);
So we leave IPV6_GRO_CB(nskb)->proto to 0 (fresh skb allocation) instead
of IPPROTO_TCP (6)
ipv6_gro_complete() isnt able to call ops->gro_complete()
[ tcp6_gro_complete() ]
Fix this by moving proto in NAPI_GRO_CB() and getting rid of
IPV6_GRO_CB
Cc: Herbert Xu <herbert@gondor.apana.org.au>
IPv4 side of the problem was addressed in commit a9e050f4e7f9d
(net: tcp: GRO should be ECN friendly)
This patch does the same, but for IPv6 : A Traffic Class mismatch
doesnt mean flows are different, but instead should force a flush
of previous packets.
This patch removes artificial packet reordering problem.
ipv6_opt_accepted() returns a bool, and can use const pointers
ipv6_addr_equal(), ipv6_addr_any(), ipv6_addr_loopback(),
ipv6_addr_orchid() return a bool.
Add #define pr_fmt(fmt) as appropriate.
Add "IPv6: " to appropriate files.
Convert printk(KERN_<LEVEL> to pr_<level> (but not KERN_DEBUG).
Standardize on "%s: " not "%s(): " when emitting __func__.
Use "%s: ", __func__ instead of embedding function name.
Coalesce formats, align arguments.
ADDRCONF output is now prefixed with "IPv6: "
af_inet6.c:80: ERROR: do not initialise statics to 0 or NULL
af_inet6.c:259: ERROR: spaces required around that '=' (ctx:VxV)
af_inet6.c:394: WARNING: EXPORT_SYMBOL(foo); should immediately follow its function/variable
af_inet6.c:412: WARNING: EXPORT_SYMBOL(foo); should immediately follow its function/variable
af_inet6.c:422: ERROR: do not use assignment in if condition
af_inet6.c:425: ERROR: do not use assignment in if condition
af_inet6.c:433: ERROR: do not use assignment in if condition
af_inet6.c:437: WARNING: EXPORT_SYMBOL(foo); should immediately follow its function/variable
af_inet6.c:446: ERROR: spaces required around that '=' (ctx:VxV)
af_inet6.c:478: WARNING: EXPORT_SYMBOL(foo); should immediately follow its function/variable
af_inet6.c:485: ERROR: that open brace { should be on the previous line
af_inet6.c:485: ERROR: space required before the open parenthesis '('
af_inet6.c:513: WARNING: EXPORT_SYMBOL(foo); should immediately follow its function/variable
af_inet6.c:629: WARNING: EXPORT_SYMBOL(foo); should immediately follow its function/variable
af_inet6.c:647: WARNING: EXPORT_SYMBOL(foo); should immediately follow its function/variable
af_inet6.c:687: WARNING: EXPORT_SYMBOL(foo); should immediately follow its function/variable
af_inet6.c:709: WARNING: EXPORT_SYMBOL(foo); should immediately follow its function/variable
af_inet6.c:1073: ERROR: space required before the open parenthesis '('
Signed-off-by: Eldad Zack <eldad@fogrefinery.com>
Name them in a "backward compatible" manner, i.e. reuse or not
are still 1 and 0 respectively. The reuse value of 2 means that
the socket with it will forcibly reuse everyone else's port.
Signed-off-by: Pavel Emelyanov <xemul@openvz.org>
sysctl no longer requires explicit creation of directories. The neigh
directory is always populated with at least a default entry so this
should cause no user visible changes.
Acked-by: Pavel Emelyanov <xemul@parallels.com>
