[ Upstream commit b7ea81a58adc123a4e980cb0eff9eb5c144b5dc7 ]
The AH4/6 ahash input callbacks read out the nexthdr field from the AH
header *after* they overwrite that header. This is obviously not going
to end well. Fix it up.
Signed-off-by: Nick Bowler <nbowler@elliptictech.com>
[ Upstream commit 069294e813ed5f27f82613b027609bcda5f1b914 ]
The AH4/6 ahash output callbacks pass nexthdr to xfrm_output_resume
instead of the error code. This appears to be a copy+paste error from
the input case, where nexthdr is expected. This causes the driver to
continuously add AH headers to the datagram until either an allocation
fails and the packet is dropped or the ahash driver hits a synchronous
fallback and the resulting monstrosity is transmitted.
Correct this issue by simply passing the error code unadulterated.
xfrm_skb_cb
To support IPsec extended sequence numbers, we split the
output sequence numbers of xfrm_skb_cb in low and high order 32 bits
and we add the high order 32 bits to the input sequence numbers.
All users are updated accordingly.
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
Acked-by: Herbert Xu <herbert@gondor.apana.org.au>
skb_cow_data() may allocate a new data buffer, so pointers on
skb should be set after this function.
Bug was introduced by commit dff3bb06 ("ah4: convert to ahash")
and 8631e9bd ("ah6: convert to ahash").
Signed-off-by: Wang Xuefu <xuefu.wang@6wind.com>
Acked-by: Krzysztof Witek <krzysztof.witek@6wind.com>
Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
pass mark to all SA lookups to prepare them for when we add code
to have them search.
Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca>
Instead of using the hardcoded truncation for authentication
algorithms, use the truncation length specified on xfrm_state.
Signed-off-by: Martin Willi <martin@strongswan.org>
This patch converts ah6 to the new ahash interface.
Change all the code that deals directly with ICMPv6 type and code
values to use u8 instead of a signed int as that's the actual data
type.
Signed-off-by: Brian Haley <brian.haley@hp.com>
struct will be kfreed in a moment, so...
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
Al Viro spotted a bogus use of u64 on the input sequence number which
is big-endian. This patch fixes it by giving the input sequence number
its own member in the xfrm_skb_cb structure.
Signed-off-by: Eric Dumazet <dada1@cosmosbay.com>
Let's nip the code duplication in the bud :)
This patch adds a number of new IPsec audit events to meet the auditing
requirements of RFC4303. This includes audit hooks for the following events:
* Could not find a valid SA [sections 2.1, 3.4.2]
. xfrm_audit_state_notfound()
. xfrm_audit_state_notfound_simple()
* Sequence number overflow [section 3.3.3]
. xfrm_audit_state_replay_overflow()
* Replayed packet [section 3.4.3]
. xfrm_audit_state_replay()
* Integrity check failure [sections 3.4.4.1, 3.4.4.2]
. xfrm_audit_state_icvfail()
While RFC4304 deals only with ESP most of the changes in this patch apply to
IPsec in general, i.e. both AH and ESP. The one case, integrity check
failure, where ESP specific code had to be modified the same was done to the
AH code for the sake of consistency.
Signed-off-by: Paul Moore <paul.moore@hp.com>
Acked-by: James Morris <jmorris@namei.org>
This patch releases the lock on the state before calling
x->type->input. It also adds the lock to the spots where they're
currently needed.
Most of those places (all except mip6) are expected to disappear with
async crypto.
Similar to the moving out of the replay processing on the output, this
patch moves the integrity stat collectin from x->type->input into
xfrm_input.
This would eventually allow transforms such as AH/ESP to be lockless.
The error value EBADMSG (currently unused in the crypto layer) is used
to indicate a failed integrity check. In future this error can be
directly returned by the crypto layer once we switch to aead
algorithms.
Not architecture specific code should not #include <asm/scatterlist.h>.
This patch therefore either replaces them with
#include <linux/scatterlist.h> or simply removes them if they were
unused.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
Signed-off-by: Masahide NAKAMURA <nakam@linux-ipv6.org>
Combining RO and AH/ESP/IPCOMP does not make sense. So this patch adds a
check in the state initialisation function to prevent this.
This allows us to safely remove the mode input function of RO since it
can never be called anymore. Indeed, if somehow it does get called we'll
know about it through an OOPS instead of it slipping past silently.
Not every transform needs to zap ip_summed. For example, a pure tunnel
mode encapsulation does not affect the hardware checksum at all. In fact,
every algorithm (that needs this) other than AH6 already does its own
ip_summed zapping.
This patch moves the zapping into AH6 which is in line with what IPv4 does.
Possible future optimisation: Checksum the data as we copy them in IPComp.
This patch removes the duplicate ipv6_{auth,esp,comp}_hdr structures since
they're identical to the IPv4 versions. Duplicating them would only create
problems for ourselves later when we need to add things like extended
sequence numbers.
I've also added transport header type conversion headers for these types
which are now used by the transforms.
This patch changes the calling convention so that on entry from
x->mode->output and before entry into x->type->output skb->data
will point to the payload instead of the IP header.
This is essentially a redistribution of skb_push/skb_pull calls
with the aim of minimising them on the common path of tunnel +
ESP.
It'll also let us use the same calling convention between IPv4
and IPv6 with the next patch.
This patch releases the lock on the state before calling x->type->output.
It also adds the lock to the spots where they're currently needed.
async crypto.
Current the x->mode->output functions store the IPv6 nh pointer in the
skb network header. This is inconvenient because the network header then
has to be fixed up before the packet can leave the IPsec stack. The mac
header field is unused on output so we can use that to store this instead.
This patch does that and removes the network header fix-up in xfrm_output.
It also uses ipv6_hdr where appropriate in the x->type->output functions.
There is also a minor clean-up in esp4 to make it use the same code as
esp6 to help any subsequent effort to merge the two.
Lastly it kills two redundant skb_set_* statements in BEET that were
simply copied over from transport mode.
The replay counter is one of only two remaining things in the output code
that requires a lock on the xfrm state (the other being the crypto). This
patch moves it into the generic xfrm_output so we can remove the lock from
the transforms themselves.
The keys are only used during initialisation so we don't need to carry them
in esp_data. Since we don't have to allocate them again, there is no need
to place a limit on the authentication key length anymore.
It is clean-up for XFRM type modules and adds aliases with its
protocol:
ESP, AH, IPCOMP, IPIP and IPv6 for IPsec
ROUTING and DSTOPTS for MIPv6
It is almost the same thing as XFRM mode alias, but it is added
new defines XFRM_PROTO_XXX for preprocessing since some protocols
are defined as enum.
Acked-by: Ingo Oeser <netdev@axxeo.de>
This patch makes MIPv6 loadable module named "mip6".
Here is a modprobe.conf(5) example to load it automatically
when user application uses XFRM state for MIPv6:
alias xfrm-type-10-43 mip6
alias xfrm-type-10-60 mip6
Some MIPv6 feature is not included by this modular, however,
it should not be affected to other features like either IPsec
or IPv6 with and without the patch.
We may discuss XFRM, MH (RAW socket) and ancillary data/sockopt
separately for future work.
Loadable features:
* MH receiving check (to send ICMP error back)
* RO header parsing and building (i.e. RH2 and HAO in DSTOPTS)
* XFRM policy/state database handling for RO
These are NOT covered as loadable:
* Home Address flags and its rule on source address selection
* XFRM sub policy (depends on its own kernel option)
* XFRM functions to receive RO as IPv6 extension header
* MH sending/receiving through raw socket if user application
opens it (since raw socket allows to do so)
* RH2 sending as ancillary data
* RH2 operation with setsockopt(2)
Kill unnecessary CONFIG_IPV6_MIP6.
o It is redundant for RAW socket to keep MH out with the config then
it can handle any protocol.
o Clean-up at AH.
Signed-off-by: Kazunori MIYAZAWA <miyazawa@linux-ipv6.org>
Renaming skb->h to skb->transport_header, skb->nh to skb->network_header and
skb->mac to skb->mac_header, to match the names of the associated helpers
(skb[_[re]set]_{transport,network,mac}_header).
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
For the places where we need a pointer to the transport header, it is
still legal to touch skb->h.raw directly if just adding to,
subtracting from or setting it to another layer header.
For the cases where the transport header is being set to a offset from
skb->data.
Now the skb->nh union has just one member, .raw, i.e. it is just like the
skb->mac union, strange, no? I'm just leaving it like that till the transport
layer is done with, when we'll rename skb->mac.raw to skb->mac_header (or
->mac_header_offset?), ditto for ->{h,nh}.
For the places where we need a pointer to the network header, it is still legal
to touch skb->nh.raw directly if just adding to, subtracting from or setting it
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
Code diff stats:
[acme@newtoy net-2.6.20]$ codiff /tmp/ipv6.ko.before /tmp/ipv6.ko.after
/pub/scm/linux/kernel/git/acme/net-2.6.20/net/ipv6/ip6_output.c:
ip6_output | -52
ip6_append_data | +2
2 functions changed, 2 bytes added, 52 bytes removed
/pub/scm/linux/kernel/git/acme/net-2.6.20/net/ipv6/addrconf.c:
addrconf_sysctl_register | -27
1 function changed, 27 bytes removed
/pub/scm/linux/kernel/git/acme/net-2.6.20/net/ipv6/tcp_ipv6.c:
tcp_v6_syn_recv_sock | -32
tcp_v6_parse_md5_keys | -24
2 functions changed, 56 bytes removed
/tmp/ipv6.ko.after:
5 functions changed, 2 bytes added, 135 bytes removed
Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
- Remove redundant code. Pointed out by Brian Haley <brian.haley@hp.com>.
- Unify code paths with/without CONFIG_IPV6_MIP.
- Use NIP6_FMT for IPv6 address textual presentation.
- Fold long line. Pointed out by David Miller <davem@davemloft.net>.
Mobile IPv6 defines home address option as an option of destination
options header. It is placed before fragment header then
ip6_find_1stfragopt() is fixed to know about it.
Home address option also carries final source address of the flow,
then outbound AH calculation should take care of it like routing
header case. Based on MIPL2 kernel patch.
On current kernel, ip6_find_1stfragopt() is used by IPv6 IPsec to find
offset to be inserted header in outbound for transport mode. (BTW, no
usage may be needed for IPv4 case.) Mobile IPv6 requires another
logic for routing header and destination options header
respectively. This patch is common platform for the offset and adopts
it to IPsec.
Transformation mode is used as either IPsec transport or tunnel.
It is required to add two more items, route optimization and inbound trigger
for Mobile IPv6.
This patch was also written by: Ville Nuorvala <vnuorval@tcs.hut.fi>
This patch converts IPsec to use the new HMAC template. The names of
existing simple digest algorithms may still be used to refer to their
HMAC composites.
The same structure can be used by other MACs such as AES-XCBC-MAC.
This patch also switches from the digest interface to hash.
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
Now that we have xfrm_mode objects we can move the transport mode specific
input decapsulation code into xfrm_mode_transport. This removes duplicate
code as well as unnecessary header movement in case of tunnel mode SAs
since we will discard the original IP header immediately.
This also fixes a minor bug for transport-mode ESP where the IP payload
length is set to the correct value minus the header length (with extension
headers for IPv6).
Of course the other neat thing is that we no longer have to allocate
temporary buffers to hold the IP headers for ESP and IPComp.
