path: root/net/ipv6/anycast.c
2011-04-22inet: constify ip headers and in6_addrEric Dumazet
Add const qualifiers to structs iphdr, ipv6hdr and in6_addr pointers where possible, to make code intention more obvious. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-10net-next: remove useless union keywordChangli Gao
remove useless union keyword in rtable, rt6_info and dn_route. Since there is only one member in a union, the union keyword isn't useful. Signed-off-by: Changli Gao <xiaosuo@gmail.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-07anycast: Some RCU conversionsEric Dumazet
- dev_get_by_flags() changed to dev_get_by_flags_rcu() - ipv6_sock_ac_join() dont touch dev & idev refcounts - ipv6_sock_ac_drop() dont touch dev & idev refcounts - ipv6_sock_ac_close() dont touch dev & idev refcounts - ipv6_dev_ac_dec() dount touch idev refcount - ipv6_chk_acast_addr() dont touch idev refcount Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> CC: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-01-17net: spread __net_init, __net_exitAlexey Dobriyan
__net_init/__net_exit are apparently not going away, so use them to full extent. In some cases __net_init was removed, because it was called from __net_exit code. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-13ipv6: use RCU to walk list of network devicesEric Dumazet
No longer need read_lock(&dev_base_lock), use RCU instead. We also can avoid taking references on inet6_dev structs. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-04net: Introduce for_each_netdev_rcu() iteratorEric Dumazet
Adds RCU management to the list of netdevices. Convert some for_each_netdev() users to RCU version, if it can avoid read_lock-ing dev_base_lock Ie: read_lock(&dev_base_loack); for_each_netdev(net, dev) some_action(); read_unlock(&dev_base_lock); becomes : rcu_read_lock(); for_each_netdev_rcu(net, dev) some_action(); rcu_read_unlock(); Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-29net: replace %#p6 format specifier with %pi6Harvey Harrison
gcc warns when using the # modifier with the %p format specifier, so we can't use this to omit the colons when needed, introduces %pi6 instead. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-28net: replace all current users of NIP6_SEQFMT with %#p6Harvey Harrison
The define in kernel.h can be done away with at a later time. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-19ipv6 netns: Make several "global" sysctl variables namespace aware.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-14Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/ehea/ehea_main.c drivers/net/wireless/iwlwifi/Kconfig drivers/net/wireless/rt2x00/rt61pci.c net/ipv4/inet_timewait_sock.c net/ipv6/raw.c net/mac80211/ieee80211_sta.c
2008-04-03[IPV6]: Fix refcounting for anycast dst entries.Denis V. Lunev
Anycast DST entries allocated inside ipv6_dev_ac_inc are leaked when network device is stopped without removing IPv6 addresses from it. The bug has been observed in the reality on 2.6.18-rhel5 kernel. In the above case addrconf_ifdown marks all entries as obsolete and ip6_del_rt called from __ipv6_dev_ac_dec returns ENOENT. The referrence is not dropped. The fix is simple. DST entry should not keep referrence when stored in the FIB6 tree. Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-03[IPV6]: Unify ip6_onlink() and ipip6_onlink().YOSHIFUJI Hideaki
Both are identical, let's create ipv6_chk_prefix() and use it in both places.
2008-03-26[NETNS][IPV6] anycast - handle several network namespaceDaniel Lezcano
Make use of the network namespace information to have this protocol to handle several network namespace. Signed-off-by: Daniel Lezcano <dlezcano@fr.ibm.com> Signed-off-by: Benjamin Thery <benjamin.thery@bull.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-04[NETNS][IPV6] route6 - Pass the network namespace parameter to rt6_lookupDaniel Lezcano
Add a network namespace parameter to rt6_lookup(). Signed-off-by: Daniel Lezcano <dlezcano@fr.ibm.com> Signed-off-by: Benjamin Thery <benjamin.thery@bull.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETNS][IPV6]: inet6_addr - check ipv6 address per namespaceDaniel Lezcano
When a new address is added, we must check if the new address does not already exists. This patch makes this check to be aware of a network namespace, so the check will look if the address already exists for the specified network namespace. While the addresses are browsed, the addresses which do not belong to the namespace are discarded. Signed-off-by: Daniel Lezcano <dlezcano@fr.ibm.com> Signed-off-by: Benjamin Thery <benjamin.thery@bull.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NET]: Add some acquires/releases sparse annotations.Eric Dumazet
Add __acquires() and __releases() annotations to suppress some sparse warnings. example of warnings : net/ipv4/udp.c:1555:14: warning: context imbalance in 'udp_seq_start' - wrong count at exit net/ipv4/udp.c:1571:13: warning: context imbalance in 'udp_seq_stop' - unexpected unlock Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Make core networking code use seq_open_privatePavel Emelyanov
This concerns the ipv4 and ipv6 code mostly, but also the netlink and unix sockets. The netlink code is an example of how to use the __seq_open_private() call - it saves the net namespace on this private. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: sparse warning fixesStephen Hemminger
Fix a bunch of sparse warnings. Mostly about 0 used as NULL pointer, and shadowed variable declarations. One notable case was that hash size should have been unsigned. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Make the device list and device lookups per namespace.Eric W. Biederman
This patch makes most of the generic device layer network namespace safe. This patch makes dev_base_head a network namespace variable, and then it picks up a few associated variables. The functions: dev_getbyhwaddr dev_getfirsthwbytype dev_get_by_flags dev_get_by_name __dev_get_by_name dev_get_by_index __dev_get_by_index dev_ioctl dev_ethtool dev_load wireless_process_ioctl were modified to take a network namespace argument, and deal with it. vlan_ioctl_set and brioctl_set were modified so their hooks will receive a network namespace argument. So basically anthing in the core of the network stack that was affected to by the change of dev_base was modified to handle multiple network namespaces. The rest of the network stack was simply modified to explicitly use &init_net the initial network namespace. This can be fixed when those components of the network stack are modified to handle multiple network namespaces. For now the ifindex generator is left global. Fundametally ifindex numbers are per namespace, or else we will have corner case problems with migration when we get that far. At the same time there are assumptions in the network stack that the ifindex of a network device won't change. Making the ifindex number global seems a good compromise until the network stack can cope with ifindex changes when you change namespaces, and the like. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Make /proc/net per network namespaceEric W. Biederman
This patch makes /proc/net per network namespace. It modifies the global variables proc_net and proc_net_stat to be per network namespace. The proc_net file helpers are modified to take a network namespace argument, and all of their callers are fixed to pass &init_net for that argument. This ensures that all of the /proc/net files are only visible and usable in the initial network namespace until the code behind them has been updated to be handle multiple network namespaces. Making /proc/net per namespace is necessary as at least some files in /proc/net depend upon the set of network devices which is per network namespace, and even more files in /proc/net have contents that are relevant to a single network namespace. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[NET]: Make all initialized struct seq_operations const.Philippe De Muyter
Make all initialized struct seq_operations in net/ const Signed-off-by: Philippe De Muyter <phdm@macqel.be> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-03[NET]: Rework dev_base via list_head (v3)Pavel Emelianov
Cleanup of dev_base list use, with the aim to simplify making device list per-namespace. In almost every occasion, use of dev_base variable and dev->next pointer could be easily replaced by for_each_netdev loop. A few most complicated places were converted to using first_netdev()/next_netdev(). Signed-off-by: Pavel Emelianov <xemul@openvz.org> Acked-by: Kirill Korotaev <dev@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-28[IPV6]: /proc/net/anycast6 unbalanced inet6_dev refcntDavid Stevens
Reading /proc/net/anycast6 when there is no anycast address on an interface results in an ever-increasing inet6_dev reference count, as well as a reference to the netdevice you can't get rid of. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-12[PATCH] mark struct file_operations const 7Arjan van de Ven
Many struct file_operations in the kernel can be "const". Marking them const moves these to the .rodata section, which avoids false sharing with potential dirty data. In addition it'll catch accidental writes at compile time to these shared resources. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-10[NET] IPV6: Fix whitespace errors.YOSHIFUJI Hideaki
2006-09-22[IPV6] ADDRCONF: Convert addrconf_lock to RCU.YOSHIFUJI Hideaki
2006-09-22[IPV6]: Fixup ip6_del_rt() call for new args.David S. Miller
2006-09-22[IPv6] route: Simplify ip6_ins_rt()Thomas Graf
Provide a simple ip6_ins_rt() for the majority of users and an alternative for the exception via netlink. Avoids code obfuscation. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[IPV6]: Nearly complete kzalloc cleanup for net/ipv6Ingo Oeser
Stupidly use kzalloc() instead of kmalloc()/memset() everywhere where this is possible in net/ipv6/*.c . Signed-off-by: Ingo Oeser <ioe-lkml@rameria.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-17[IPV6]: Preserve procfs IPV6 address output formatYOSHIFUJI Hideaki
Procfs always output IPV6 addresses without the colon characters, and we cannot change that. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-13[NET]: Use NIP6_FMT in kernel.hJoe Perches
There are errors and inconsistency in the display of NIP6 strings. ie: net/ipv6/ip6_flowlabel.c There are errors and inconsistency in the display of NIPQUAD strings too. ie: net/netfilter/nf_conntrack_ftp.c This patch: adds NIP6_FMT to kernel.h changes all code to use NIP6_FMT fixes net/ipv6/ip6_flowlabel.c adds NIPQUAD_FMT to kernel.h fixes net/netfilter/nf_conntrack_ftp.c changes a few uses of "%u.%u.%u.%u" to NIPQUAD_FMT for symmetry to NIP6_FMT Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-11[PATCH] capable/capability.h (net/)Randy Dunlap
net: Use <linux/capability.h> where capable() is used. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-21[IPV6]: V6 route events reported with wrong netlink PID and seq numberJamal Hadi Salim
Essentially netlink at the moment always reports a pid and sequence of 0 always for v6 route activities. To understand the repurcassions of this look at: http://lists.quagga.net/pipermail/quagga-dev/2005-June/003507.html While fixing this, i took the liberty to resolve the outstanding issue of IPV6 routes inserted via ioctls to have the correct pids as well. This patch tries to behave as close as possible to the v4 routes i.e maintains whatever PID the socket issuing the command owns as opposed to the process. That made the patch a little bulky. I have tested against both netlink derived utility to add/del routes as well as ioctl derived one. The Quagga folks have tested against quagga. This fixes the problem and so far hasnt been detected to introduce any new issues. Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Acked-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
