path: root/net/ipv6/exthdrs.c
2011-03-12ipv6: Convert to use flowi6 where applicable.David S. Miller
2010-06-14ipv6: avoid two atomics in ipv6_rthdr_rcv()Eric Dumazet
Use __in6_dev_get() instead of in6_dev_get()/in6_dev_put() Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-02ipv6: Refactor update of IPv6 flowi destination address for srcrt (RH) optionArnaud Ebalard
There are more than a dozen occurrences of following code in the IPv6 stack: if (opt && opt->srcrt) { struct rt0_hdr *rt0 = (struct rt0_hdr *) opt->srcrt; ipv6_addr_copy(&final, &fl.fl6_dst); ipv6_addr_copy(&fl.fl6_dst, rt0->addr); final_p = &final; } Replace those with a helper. Note that the helper overrides final_p in all cases. This is ok as final_p was previously initialized to NULL when declared. Signed-off-by: Arnaud Ebalard <arno@natisbad.org> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-18ipv6: drop unused "dev" arg of icmpv6_send()Alexey Dobriyan
Dunno, what was the idea, it wasn't used for a long time. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-13ipv6: skb_dst() can be NULL in ipv6_hop_jumbo().David S. Miller
This fixes CERT-FI FICORA #341748 Discovered by Olli Jarva and Tuomo Untinen from the CROSS project at Codenomicon Ltd. Just like in CVE-2007-4567, we can't rely upon skb_dst() being non-NULL at this point. We fixed that in commit e76b2b2567b83448c2ee85a896433b96150c92e6 ("[IPV6]: Do no rely on skb->dst before it is assigned.") However commit 483a47d2fe794328d29950fe00ce26dd405d9437 ("ipv6: added net argument to IP6_INC_STATS_BH") put a new version of the same bug into this function. Complicating analysis further, this bug can only trigger when network namespaces are enabled in the build. When namespaces are turned off, the dev_net() does not evaluate it's argument, so the dereference would not occur. So, for a long time, namespaces couldn't be turned on unless SYSFS was disabled. Therefore, this code has largely been disabled except by people turning it on explicitly for namespace development. With help from Eugene Teo <eugene@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-14net: constify struct inet6_protocolAlexey Dobriyan
2009-06-03net: skb->dst accessorsEric Dumazet
Define three accessors to get/set dst attached to a skb struct dst_entry *skb_dst(const struct sk_buff *skb) void skb_dst_set(struct sk_buff *skb, struct dst_entry *dst) void skb_dst_drop(struct sk_buff *skb) This one should replace occurrences of : dst_release(skb->dst) skb->dst = NULL; Delete skb->dst field Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-29net: replace %p6 with %pI6Harvey Harrison
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-28net: replace uses of NIP6_FMT with %p6Harvey Harrison
2008-10-08ipv6: added net argument to IP6_INC_STATS_BHDenis V. Lunev
Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-19ipv6 netns: Make several "global" sysctl variables namespace aware.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-14Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: net/netfilter/nf_conntrack_proto_tcp.c
2008-07-10ipv6: missed namespace context in ipv6_rthdr_rcvDenis V. Lunev
Signed-off-by: Denis V. Lunev <den@parallels.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-11net: remove CVS keywordsAdrian Bunk
This patch removes CVS keywords that weren't updated for a long time from comments. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETNS][IPV6]: inet6_addr - make ipv6_chk_home_addr namespace awareDaniel Lezcano
Looks if the address is belonging to the network namespace, otherwise discard the address for the check. Signed-off-by: Daniel Lezcano <dlezcano@fr.ibm.com> Signed-off-by: Benjamin Thery <benjamin.thery@bull.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[IPV6]: make extended headers to return an error at initializationDaniel Lezcano
This patch factorize the code for the differents init functions for rthdr, nodata, destopt in a single function exthdrs_init. This function returns an error so the af_inet6 module can check correctly the initialization. Signed-off-by: Daniel Lezcano <dlezcano@fr.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NET]: Eliminate duplicate copies of dst_discardHerbert Xu
We have a number of copies of dst_discard scattered around the place which all do the same thing, namely free a packet on the input or output paths. This patch deletes all of them except dst_discard and points all the users to it. The only non-trivial bit is decnet where it returns an error. However, conceptually this is identical to the blackhole functions used in IPv4 and IPv6 which do not return errors. So they should either all return errors or all return zero. For now I've stuck with the majority and picked zero as the return value. It doesn't really matter in practice since few if any driver would react differently depending on a zero return value or NET_RX_DROP. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-15[IPV6]: Replace sk_buff ** with sk_buff * in input handlersHerbert Xu
With all the users of the double pointers removed from the IPv6 input path, this patch converts all occurances of sk_buff ** to sk_buff * in IPv6 input handlers. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-15[IPV6]: Avoid skb_copy/pskb_copy/skb_realloc_headroom on inputHerbert Xu
This patch replaces unnecessary uses of skb_copy by pskb_expand_head on the IPv6 input path. This allows us to remove the double pointers later. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[IPV6]: Do not send RH0 anymore.YOSHIFUJI Hideaki
Based on <draft-ietf-ipv6-deprecate-rh0-00.txt>. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[IPV6]: Restore semantics of Routing Header processing.YOSHIFUJI Hideaki
The "fix" for emerging security threat was overkill and it broke basic semantic of IPv6 routing header processing. We should assume RT0 (or even RT2, depends on configuration) as "unknown" RH type so that we - silently ignore the routing header if segleft == 0 - send ICMPv6 Parameter Problem message back to the sender, otherwise. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[IPV6] MIP6: Loadable module support for MIPv6.Masahide NAKAMURA
This patch makes MIPv6 loadable module named "mip6". Here is a modprobe.conf(5) example to load it automatically when user application uses XFRM state for MIPv6: alias xfrm-type-10-43 mip6 alias xfrm-type-10-60 mip6 Some MIPv6 feature is not included by this modular, however, it should not be affected to other features like either IPsec or IPv6 with and without the patch. We may discuss XFRM, MH (RAW socket) and ancillary data/sockopt separately for future work. Loadable features: * MH receiving check (to send ICMP error back) * RO header parsing and building (i.e. RH2 and HAO in DSTOPTS) * XFRM policy/state database handling for RO These are NOT covered as loadable: * Home Address flags and its rule on source address selection * XFRM sub policy (depends on its own kernel option) * XFRM functions to receive RO as IPv6 extension header * MH sending/receiving through raw socket if user application opens it (since raw socket allows to do so) * RH2 sending as ancillary data * RH2 operation with setsockopt(2) Signed-off-by: Masahide NAKAMURA <nakam@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-10[IPV6]: Do no rely on skb->dst before it is assigned.YOSHIFUJI Hideaki
Because skb->dst is assigned in ip6_route_input(), it is really bad to use it in hop-by-hop option handler(s). Closes: Bug #8450 (Eric Sesterhenn <snakebyte@gmx.de>) Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-27[IPV6]: Fix thinko in ipv6_rthdr_rcv() changes.YOSHIFUJI Hideaki
2007-04-25[NET]: cleanup extra semicolonsStephen Hemminger
Spring cleaning time... There seems to be a lot of places in the network code that have extra bogus semicolons after conditionals. Most commonly is a bogus semicolon after: switch() { } Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Convert skb->tail to sk_buff_data_tArnaldo Carvalho de Melo
So that it is also an offset from skb->head, reduces its size from 8 to 4 bytes on 64bit architectures, allowing us to combine the 4 bytes hole left by the layer headers conversion, reducing struct sk_buff size to 256 bytes, i.e. 4 64byte cachelines, and since the sk_buff slab cache is SLAB_HWCACHE_ALIGN... :-) Many calculations that previously required that skb->{transport,network, mac}_header be first converted to a pointer now can be done directly, being meaningful as offsets or pointers. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: unions of just one member don't get anything done, kill themArnaldo Carvalho de Melo
Renaming skb->h to skb->transport_header, skb->nh to skb->network_header and skb->mac to skb->mac_header, to match the names of the associated helpers (skb[_[re]set]_{transport,network,mac}_header). Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce skb_network_header_lenArnaldo Carvalho de Melo
For the common sequence "skb->h.raw - skb->nh.raw", similar to skb->mac_len, that is precalculated tho, don't think we need to bloat skb with one more member, so just use this new helper, reducing the number of non-skbuff.h references to the layer headers even more. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Use the helpers to get the layer header pointerArnaldo Carvalho de Melo
Some more cases... Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce skb_transport_header(skb)Arnaldo Carvalho de Melo
For the places where we need a pointer to the transport header, it is still legal to touch skb->h.raw directly if just adding to, subtracting from or setting it to another layer header. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce skb_transport_offset()Arnaldo Carvalho de Melo
For the quite common 'skb->h.raw - skb->data' sequence. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce ipv6_hdr(), remove skb->nh.ipv6hArnaldo Carvalho de Melo
Now the skb->nh union has just one member, .raw, i.e. it is just like the skb->mac union, strange, no? I'm just leaving it like that till the transport layer is done with, when we'll rename skb->mac.raw to skb->mac_header (or ->mac_header_offset?), ditto for ->{h,nh}. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce skb_network_header()Arnaldo Carvalho de Melo
For the places where we need a pointer to the network header, it is still legal to touch skb->nh.raw directly if just adding to, subtracting from or setting it to another layer header. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[IPV6]: Use skb->nh.ipv6h instead of casting skb->nh.rawArnaldo Carvalho de Melo
nh.ipv6h is there exactly for this reason! Use it while it exists ;-) Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[IPV6]: Decentralize EXPORT_SYMBOLs.YOSHIFUJI Hideaki
2007-04-25[NET]: convert network timestamps to ktime_tEric Dumazet
We currently use a special structure (struct skb_timeval) and plain 'struct timeval' to store packet timestamps in sk_buffs and struct sock. This has some drawbacks : - Fixed resolution of micro second. - Waste of space on 64bit platforms where sizeof(struct timeval)=16 I suggest using ktime_t that is a nice abstraction of high resolution time services, currently capable of nanosecond resolution. As sizeof(ktime_t) is 8 bytes, using ktime_t in 'struct sock' permits a 8 byte shrink of this structure on 64bit architectures. Some other structures also benefit from this size reduction (struct ipq in ipv4/ip_fragment.c, struct frag_queue in ipv6/reassembly.c, ...) Once this ktime infrastructure adopted, we can more easily provide nanosecond resolution on top of it. (ioctl SIOCGSTAMPNS and/or SO_TIMESTAMPNS/SCM_TIMESTAMPNS) Note : this patch includes a bug correction in compat_sock_get_timestamp() where a "err = 0;" was missing (so this syscall returned -ENOENT instead of 0) Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> CC: Stephen Hemminger <shemminger@linux-foundation.org> CC: John find <linux.kernel@free.fr> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-24IPv6: fix Routing Header Type 0 handling thinkoYOSHIFUJI Hideaki
Oops, thinko. The test for accempting a RH0 was exatly the wrong way around. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-24[IPV6]: Disallow RH0 by default.YOSHIFUJI Hideaki
A security issue is emerging. Disallow Routing Header Type 0 by default as we have been doing for IPv4. Note: We allow RH2 by default because it is harmless. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-10[NET] IPV6: Fix whitespace errors.YOSHIFUJI Hideaki
2006-12-02[IPV6]: Misc endianness annotations.Al Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[IPV6]: Per-interface statistics support.YOSHIFUJI Hideaki
For IP MIB (RFC4293). Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2006-09-22[IPV6] MIP6: Fix to update IP6CB when cloned skbuff is received at HAO.Masahide NAKAMURA
2006-09-22[IPV6] MIP6: Several obvious clean-ups.YOSHIFUJI Hideaki
- Remove redundant code. Pointed out by Brian Haley <brian.haley@hp.com>. - Unify code paths with/without CONFIG_IPV6_MIP. - Use NIP6_FMT for IPv6 address textual presentation. - Fold long line. Pointed out by David Miller <davem@davemloft.net>. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2006-09-22[IPV6] MIP6: Add inbound interface of home address option.Masahide NAKAMURA
Add inbound function of home address option by registering it to TLV table for destination options header. Based on MIPL2 kernel patch. This patch was also written by: Ville Nuorvala <vnuorval@tcs.hut.fi> Signed-off-by: Masahide NAKAMURA <nakam@linux-ipv6.org> Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[IPV6]: Allow to replace skbuff by TLV parser.Masahide NAKAMURA
In receiving Mobile IPv6 home address option which is a TLV carried by destination options header, kernel will try to mangle source adderss of packet. Think of cloned skbuff it is required to replace it by the parser just like routing header case. This is a framework to achieve that to allow TLV parser to replace inbound skbuff pointer. Signed-off-by: Masahide NAKAMURA <nakam@linux-ipv6.org> Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[IPV6]: Find option offset by type.Masahide NAKAMURA
This is a helper to search option offset from extension header which can carry TLV option like destination options header. Mobile IPv6 home address option will use it. Based on MIPL2 kernel patch. Signed-off-by: Masahide NAKAMURA <nakam@linux-ipv6.org> Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[IPV6] MIP6: Add inbound interface of routing header type 2.Masahide NAKAMURA
Add inbound interface of routing header type 2 for Mobile IPv6. Based on MIPL2 kernel patch. This patch was also written by: Ville Nuorvala <vnuorval@tcs.hut.fi> Signed-off-by: Masahide NAKAMURA <nakam@linux-ipv6.org> Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[NET]: Replace CHECKSUM_HW by CHECKSUM_PARTIAL/CHECKSUM_COMPLETEPatrick McHardy
Replace CHECKSUM_HW by CHECKSUM_PARTIAL (for outgoing packets, whose checksum still needs to be completed) and CHECKSUM_COMPLETE (for incoming packets, device supplied full checksum). Patch originally from Herbert Xu, updated by myself for 2.6.18-rc3. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
