[ Upstream commit 6af1799aaf3f1bc8defedddfa00df3192445bbf3 ]
This began with a syzbot report. syzkaller was injecting
IPv6 TCP SYN packets having a v4mapped source address.
After an unsuccessful 4-tuple lookup, TCP creates a request
socket (SYN_RECV) and calls reqsk_queue_hash_req()
reqsk_queue_hash_req() calls sk_ehashfn(sk)
At this point we have AF_INET6 sockets, and the heuristic
used by sk_ehashfn() to either hash the IPv4 or IPv6 addresses
is to use ipv6_addr_v4mapped(&sk->sk_v6_daddr)
For the particular spoofed packet, we end up hashing V4 addresses
which were not initialized by the TCP IPv6 stack, so KMSAN fired
a warning.
I first fixed sk_ehashfn() to test both source and destination addresses,
but then faced various problems, including user-space programs
like packetdrill that had similar assumptions.
Instead of trying to fix the whole ecosystem, it is better
to admit that we have a dual stack behavior, and that we
can not build linux kernels without V4 stack anyway.
The dual stack API automatically forces the traffic to be IPv4
if v4mapped addresses are used at bind() or connect(), so it makes
no sense to allow IPv6 traffic to use the same v4mapped class.
Fixes: 1da177e4c3f4 ("Linux-2.6.12-rc2")
Cc: Florian Westphal <fw@strlen.de>
Cc: Hannes Frederic Sowa <hannes@stressinduktion.org>
Reported-by: syzbot <syzkaller@googlegroups.com>
A function in kernel/bpf/syscall.c which got a bug fix in 'net'
was moved to kernel/bpf/verifier.c in 'net-next'.
We lack a saddr check for ::1. This causes security issues e.g. with acls
permitting connections from ::1 because of assumption that these originate
from local machine.
Assuming a source address of ::1 is local seems reasonable.
RFC4291 doesn't allow such a source address either, so drop such packets.
Reported-by: Eric Dumazet <edumazet@google.com>
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
Certain system process significant unconnected UDP workload.
It would be preferrable to disable UDP early demux for those systems
and enable it for TCP only.
By disabling UDP demux, we see these slight gains on an ARM64 system-
782 -> 788Mbps unconnected single stream UDPv4
633 -> 654Mbps unconnected UDPv4 different sources
The performance impact can change based on CPU architecure and cache
sizes. There will not much difference seen if entire UDP hash table
is in cache.
Both sysctls are enabled by default to preserve existing behavior.
v1->v2: Change function pointer instead of adding conditional as
suggested by Stephen.
v2->v3: Read once in callers to avoid issues due to compiler
optimizations. Also update commit message with the tests.
v3->v4: Store and use read once result instead of querying pointer
again incorrectly.
v4->v5: Refactor to avoid errors due to compilation with IPV6={m,n}
Signed-off-by: Subash Abhinov Kasiviswanathan <subashab@codeaurora.org>
Suggested-by: Eric Dumazet <edumazet@google.com>
Cc: Stephen Hemminger <stephen@networkplumber.org>
Cc: Tom Herbert <tom@herbertland.com>
Add support for locally originated traffic to VRF-local IPv6 addresses.
Similar to IPv4 a local dst is set on the skb and the packet is
reinserted with a call to netif_rx. With this patch, ping, tcp and udp
packets to a local IPv6 address are successfully routed:
$ ip addr show dev eth1
4: eth1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast master red state UP group default qlen 1000
link/ether 02:e0:f9:1c:b9:74 brd ff:ff:ff:ff:ff:ff
inet 10.100.1.1/24 brd 10.100.1.255 scope global eth1
valid_lft forever preferred_lft forever
inet6 2100:1::1/120 scope global
inet6 fe80::e0:f9ff:fe1c:b974/64 scope link
$ ping6 -c1 -I red 2100:1::1
ping6: Warning: source address might be selected on device other than red.
PING 2100:1::1(2100:1::1) from 2100:1::1 red: 56 data bytes
64 bytes from 2100:1::1: icmp_seq=1 ttl=64 time=0.098 ms
ip6_input is exported so the VRF driver can use it for the dst input
function. The dst_alloc function for IPv4 defaults to setting the input and
output functions; IPv6's does not. VRF does not need to duplicate the Rx path
so just export the ipv6 input function.
Signed-off-by: David Ahern <dsa@cumulusnetworks.com>
When performing foo-over-UDP, UDP packets are processed by the
encapsulation handler which returns another protocol to process.
This may result in processing two (or more) protocols in the
loop that are marked as INET6_PROTO_FINAL. The actions taken
for hitting a final protocol, in particular the skb_postpull_rcsum
can only be performed once.
This patch set adds a check of a final protocol has been seen. The
rules are:
- If the final protocol has not been seen any protocol is processed
(final and non-final). In the case of a final protocol, the final
actions are taken (like the skb_postpull_rcsum)
- If a final protocol has been seen (e.g. an encapsulating UDP
header) then no further non-final protocols are allowed
(e.g. extension headers). For more final protocols the
final actions are not taken (e.g. skb_postpull_rcsum).
Signed-off-by: Tom Herbert <tom@herbertland.com>
In ip6_input_finish the nexthdr protocol is retrieved from the
next header offset that is returned in the cb of the skb.
This method does not work for UDP encapsulation that may not
even have a concept of a nexthdr field (e.g. FOU).
This patch checks for a final protocol (INET6_PROTO_FINAL) when a
protocol handler returns > 0. If the protocol is not final then
resubmission is performed on nhoff value. If the protocol is final
then the nexthdr is taken to be the return value.
Currently the VRF driver uses the rx_handler to switch the skb device
to the VRF device. Switching the dev prior to the ip / ipv6 layer
means the VRF driver has to duplicate IP/IPv6 processing which adds
overhead and makes features such as retaining the ingress device index
more complicated than necessary.
This patch moves the hook to the L3 layer just after the first NF_HOOK
for PRE_ROUTING. This location makes exposing the original ingress device
trivial (next patch) and allows adding other NF_HOOKs to the VRF driver
in the future.
dev_queue_xmit_nit is exported so that the VRF driver can cycle the skb
with the switched device through the packet taps to maintain current
behavior (tcpdump can be used on either the vrf device or the enslaved
devices).
Rename IP6_UPD_PO_STATS_BH() to __IP6_UPD_PO_STATS()
Rename IP6_INC_STATS_BH() to __IP6_INC_STATS()
and IP6_ADD_STATS_BH() to __IP6_ADD_STATS()
Signed-off-by: Nikolay Borisov <kernel@kyup.com>
In order to solve a problem with 802.11, the so-called hole-196 attack,
add an option (sysctl) called "drop_unicast_in_l2_multicast" which, if
enabled, causes the stack to drop IPv6 unicast packets encapsulated in
link-layer multi- or broadcast frames. Such frames can (as an attack)
be created by any member of the same wireless network and transmitted
as valid encrypted frames since the symmetric key for broadcast frames
is shared between all stations.
Reviewed-by: Julian Anastasov <ja@ssi.bg>
This is immediately motivated by the bridge code that chains functions that
call into netfilter. Without passing net into the okfns the bridge code would
need to guess about the best expression for the network namespace to process
packets in.
As net is frequently one of the first things computed in continuation functions
after netfilter has done it's job passing in the desired network namespace is in
many cases a code simplification.
To support this change the function dst_output_okfn is introduced to
simplify passing dst_output as an okfn. For the moment dst_output_okfn
just silently drops the struct net.
Pass a network namespace parameter into the netfilter hooks. At the
call site of the netfilter hooks the path a packet is taking through
the network stack is well known which allows the network namespace to
be easily and reliabily.
This allows the replacement of magic code like
"dev_net(state->in?:state->out)" that appears at the start of most
netfilter hooks with "state->net".
In almost all cases the network namespace passed in is derived
from the first network device passed in, guaranteeing those
paths will not see any changes in practice.
The exceptions are:
xfrm/xfrm_output.c:xfrm_output_resume() xs_net(skb_dst(skb)->xfrm)
ipvs/ip_vs_xmit.c:ip_vs_nat_send_or_cont() ip_vs_conn_net(cp)
ipvs/ip_vs_xmit.c:ip_vs_send_or_cont() ip_vs_conn_net(cp)
ipv4/raw.c:raw_send_hdrinc() sock_net(sk)
ipv6/ip6_output.c:ip6_xmit() sock_net(sk)
ipv6/ndisc.c:ndisc_send_skb() dev_net(skb->dev) not dev_net(dst->dev)
ipv6/raw.c:raw6_send_hdrinc() sock_net(sk)
br_netfilter_hooks.c:br_nf_pre_routing_finish() dev_net(skb->dev) before skb->dev is set to nf_bridge->physindev
In all cases these exceptions seem to be a better expression for the
network namespace the packet is being processed in then the historic
"dev_net(in?in:out)". I am documenting them in case something odd
pops up and someone starts trying to track down what happened.
Avoid silly redundant code
Similar check was added in ip_rcv but not in ipv6_rcv.
BUG: unable to handle kernel NULL pointer dereference at (null)
IP: [<ffffffff81734e0a>] ipv6_rcv+0xfa/0x500
Call Trace:
[<ffffffff816c9786>] ? ip_rcv+0x296/0x400
[<ffffffff817732d2>] ? packet_rcv+0x52/0x410
[<ffffffff8168e99f>] __netif_receive_skb_core+0x63f/0x9a0
[<ffffffffc02b34a0>] ? br_handle_frame_finish+0x580/0x580 [bridge]
[<ffffffff8109912c>] ? update_rq_clock.part.81+0x1c/0x40
[<ffffffff8168ed18>] __netif_receive_skb+0x18/0x60
[<ffffffff8168fa1f>] process_backlog+0x9f/0x150
Fixes: ee122c79d422 (vxlan: Flow based tunneling)
Signed-off-by: Wei-Chun Chao <weichunc@plumgrid.com>
Acked-by: Thomas Graf <tgraf@suug.ch>
Before commit daad151263cf ("ipv6: Make ipv6_is_mld() inline and use it
from ip6_mc_input().") MLD packets were only processed locally. After the
change, a copy of MLD packet goes through ip6_mr_input, causing
MRT6MSG_NOCACHE message to be generated to user space.
Make MLD packet only processed locally.
Fixes: daad151263cf ("ipv6: Make ipv6_is_mld() inline and use it from ip6_mc_input().")
Signed-off-by: Hermin Anggawijaya <hermin.anggawijaya@alliedtelesis.co.nz>
This reverts commit 0243508edd317ff1fa63b495643a7c192fbfcd92.
It introduces new regressions.
UDP encapsulation is broken on IPv6. This is because the logic to resubmit
the nexthdr is inverted, checking for a ret value > 0 instead of < 0. Also,
the resubmit label is in the wrong position since we already get the
nexthdr value when performing decapsulation. In addition the skb pull is no
longer necessary either.
This changes the return value check to look for < 0, using it for the
nexthdr on the next iteration, and moves the resubmit label to the proper
location.
With these changes the v6 code now matches what we do in the v4 ip input
code wrt resubmitting when decapsulating.
Signed-off-by: Josh Hunt <johunt@akamai.com>
Acked-by: "Tom Herbert" <tom@herbertland.com>
On the output paths in particular, we have to sometimes deal with two
socket contexts. First, and usually skb->sk, is the local socket that
generated the frame.
And second, is potentially the socket used to control a tunneling
socket, such as one the encapsulates using UDP.
We do not want to disassociate skb->sk when encapsulating in order
to fix this, because that would break socket memory accounting.
The most extreme case where this can cause huge problems is an
AF_PACKET socket transmitting over a vxlan device. We hit code
paths doing checks that assume they are dealing with an ipv4
socket, but are actually operating upon the AF_PACKET one.
The ipv6 code uses a mixture of coding styles. In some instances check for NULL
pointer is done as x != NULL and sometimes as x. x is preferred according to
checkpatch and this patch makes the code consistent by adopting the latter
form.
No changes detected by objdiff.
Signed-off-by: Ian Morris <ipm@chirality.org.uk>
This change has no functional impact and simply addresses some coding
style issues detected by checkpatch. Specifically this change
adjusts "if" statements which also include the assignment of a
variable.
No changes to the resultant object files result as determined by objdiff.
This patch makes no changes to the logic of the code but simply addresses
coding style issues as detected by checkpatch.
Both objdump and diff -w show no differences.
A number of items are addressed in this patch:
* Multiple spaces converted to tabs
* Spaces before tabs removed.
* Spaces in pointer typing cleansed (char *)foo etc.
* Remove space after sizeof
* Ensure spacing around comparators such as if statements.
I see a memory leak when using a transparent HTTP proxy using TPROXY
together with TCP early demux and Kernel v3.8.13.15 (Ubuntu stable):
unreferenced object 0xffff88008cba4a40 (size 1696):
comm "softirq", pid 0, jiffies 4294944115 (age 8907.520s)
hex dump (first 32 bytes):
0a e0 20 6a 40 04 1b 37 92 be 32 e2 e8 b4 00 00 .. j@..7..2.....
02 00 07 01 00 00 00 00 00 00 00 00 00 00 00 00 ................
backtrace:
[<ffffffff810b710a>] kmem_cache_alloc+0xad/0xb9
[<ffffffff81270185>] sk_prot_alloc+0x29/0xc5
[<ffffffff812702cf>] sk_clone_lock+0x14/0x283
[<ffffffff812aaf3a>] inet_csk_clone_lock+0xf/0x7b
[<ffffffff8129a893>] netlink_broadcast+0x14/0x16
[<ffffffff812c1573>] tcp_create_openreq_child+0x1b/0x4c3
[<ffffffff812c033e>] tcp_v4_syn_recv_sock+0x38/0x25d
[<ffffffff812c13e4>] tcp_check_req+0x25c/0x3d0
[<ffffffff812bf87a>] tcp_v4_do_rcv+0x287/0x40e
[<ffffffff812a08a7>] ip_route_input_noref+0x843/0xa55
[<ffffffff812bfeca>] tcp_v4_rcv+0x4c9/0x725
[<ffffffff812a26f4>] ip_local_deliver_finish+0xe9/0x154
[<ffffffff8127a927>] __netif_receive_skb+0x4b2/0x514
[<ffffffff8127aa77>] process_backlog+0xee/0x1c5
[<ffffffff8127c949>] net_rx_action+0xa7/0x200
[<ffffffff81209d86>] add_interrupt_randomness+0x39/0x157
But there are many more, resulting in the machine going OOM after some
days.
From looking at the TPROXY code, and with help from Florian, I see
that the memory leak is introduced in tcp_v4_early_demux():
void tcp_v4_early_demux(struct sk_buff *skb)
iph = ip_hdr(skb);
th = tcp_hdr(skb);
if (th->doff < sizeof(struct tcphdr) / 4)
return;
sk = __inet_lookup_established(dev_net(skb->dev), &tcp_hashinfo,
iph->saddr, th->source,
iph->daddr, ntohs(th->dest),
skb->skb_iif);
if (sk) {
skb->sk = sk;
where the socket is assigned unconditionally to skb->sk, also bumping
the refcnt on it. This is problematic, because in our case the skb
has already a socket assigned in the TPROXY target. This then results
in the leak I see.
The very same issue seems to be with IPv6, but haven't tested.
Reviewed-by: Florian Westphal <fw@strlen.de>
Signed-off-by: Holger Eitzenberger <holger@eitzenberger.org>
With GRO/LRO processing, there is a problem because Ip[6]InReceives SNMP
counters do not count the number of frames, but number of aggregated
segments.
Its probably too late to change this now.
This patch adds four new counters, tracking number of frames, regardless
of LRO/GRO, and on a per ECN status basis, for IPv4 and IPv6.
Ip[6]NoECTPkts : Number of packets received with NOECT
Ip[6]ECT1Pkts : Number of packets received with ECT(1)
Ip[6]ECT0Pkts : Number of packets received with ECT(0)
Ip[6]CEPkts : Number of packets received with Congestion Experienced
lph37:~# nstat | egrep "Pkts|InReceive"
IpInReceives 1634137 0.0
Ip6InReceives 3714107 0.0
Ip6InNoECTPkts 19205 0.0
Ip6InECT0Pkts 52651828 0.0
IpExtInNoECTPkts 33630 0.0
IpExtInECT0Pkts 15581379 0.0
IpExtInCEPkts 6 0.0
Erik Hugne's errata proposal (Errata ID: 3480) to RFC4291 has been
verified: http://www.rfc-editor.org/errata_search.php?eid=3480
We have to check for pkt_type and loopback flag because either the
packets are allowed to travel over the loopback interface (in which case
pkt_type is PACKET_HOST and IFF_LOOPBACK flag is set) or they travel
over a non-loopback interface back to us (in which case PACKET_TYPE is
PACKET_LOOPBACK and IFF_LOOPBACK flag is not set).
Cc: Erik Hugne <erik.hugne@ericsson.com>
Cc: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
v2:
a) used struct ipv6_addr_props
v3:
a) reverted changes for ipv6_addr_props
v4:
a) do not use __ipv6_addr_needs_scope_id
Acked-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
I had a report recently of a user trying to use dropwatch to localise some frame
loss, and they were getting false positives. Turned out they were using a user
space SCTP stack that used raw sockets to grab frames. When we don't have a
registered protocol for a given packet, we record it as a drop, even if a raw
socket receieves the frame. We should only record the drop in the event a raw
socket doesnt exist to receive the frames
Tested by the reported successfully
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
Reported-by: William Reich <reich@ulticom.com>
Tested-by: William Reich <reich@ulticom.com>
CC: "David S. Miller" <davem@davemloft.net>
CC: William Reich <reich@ulticom.com>
CC: eric.dumazet@gmail.com
v2:
a) moved before multicast source address check
b) changed comment to netdev style
Router Alert option is very small and we can store the value
itself in the skb.
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
Move generalized version of ipv6_is_mld() to header,
early_demux() handlers should be called in RCU context, and as we
use skb_dst_set_noref(skb, dst), caller must not exit from RCU context
before dst use (skb_dst(skb)) or release (skb_drop(dst))
Therefore, rcu_read_lock()/rcu_read_unlock() pairs around
->early_demux() are confusing and not needed :
Protocol handlers are already in an RCU read lock section.
(__netif_receive_skb() does the rcu_read_lock() )
This is the IPv6 missing bits for infrastructure added in commit
41063e9dd1195 (ipv4: Early TCP socket demux.)
Don't pretend that inet_protos[] and inet6_protos[] are hashes, thay
are just a straight arrays. Remove all unnecessary hash masking.
Document MAX_INET_PROTOS.
Use RAW_HTABLE_SIZE when appropriate.
Reported-by: Ben Hutchings <bhutchings@solarflare.com>
Mostly bool conversions, some inline removals and const additions.
While parsing through IPv6 extension headers, fragment headers are
skipped making them invisible to the caller. This reports the
fragment offset of the last header in order to make it possible to
determine whether the packet is fragmented and, if so whether it is
a first or last fragment.
Signed-off-by: Jesse Gross <jesse@nicira.com>
RFC 4291 Section 2.7 says Multicast addresses must not be used as source
addresses in IPv6 packets - drop them on input so we don't process the
packet further.
Signed-off-by: Brian Haley <brian.haley@hp.com>
Reported-and-Tested-by: Kumar Sanghvi <divinekumar@gmail.com>
Add const qualifiers to structs iphdr, ipv6hdr and in6_addr pointers
where possible, to make code intention more obvious.
Documentation/feature-removal-schedule.txt
net/ipv6/netfilter/ip6t_REJECT.c
net/netfilter/xt_limit.c
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
The semantic patch that was used:
// <smpl>
(NF_HOOK
|NF_HOOK_THRESH
|nf_hook
-PF_INET6,
+NFPROTO_IPV6,
// </smpl>
Signed-off-by: Jan Engelhardt <jengelh@medozas.de>
Dunno, what was the idea, it wasn't used for a long time.
The routine ipv6_rcv() uses magic number 0 for a return when it drops a
packet. This corresponds to NET_RX_SUCCESS, which is obviously
incorrect. Correct this by using NET_RX_DROP instead.
ps. It isn't exactly clear who the IPv6 maintainers are, apologies if
I've missed any.
Signed-off-by: Mark Smith <markzzzsmith@yahoo.com.au>
As transparent proxying looks up the socket early and assigns
it to the skb for later processing, we must drop any existing
socket ownership prior to that in order to distinguish between
the case where tproxy is active and where it is not.
Define three accessors to get/set dst attached to a skb
struct dst_entry *skb_dst(const struct sk_buff *skb)
void skb_dst_set(struct sk_buff *skb, struct dst_entry *dst)
void skb_dst_drop(struct sk_buff *skb)
This one should replace occurrences of :
dst_release(skb->dst)
skb->dst = NULL;
Delete skb->dst field
The IP MIB (RFC 4293) defines stats for InOctets, OutOctets, InMcastOctets and
OutMcastOctets:
http://tools.ietf.org/html/rfc4293
But it seems we don't track those in any way that easy to separate from other
protocols. This patch adds those missing counters to the stats file. Tested
successfully by me
With help from Eric Dumazet.
Commit 778d80be52699596bf70e0eb0761cf5e1e46088d
(ipv6: Add disable_ipv6 sysctl to disable IPv6 operaion on specific interface)
seems to have introduced a leak of sk_buff's for ipv6 traffic,
at least in some configurations where idev is NULL, or when ipv6
is disabled via sysctl.
The problem is that if the first condition of the if-statement
returns non-NULL, it returns an skb with only one reference,
and when the other conditions apply, execution jumps to the "out"
label, which does not call kfree_skb for it.
To plug this leak, change to use the "drop" label instead.
(this relies on it being ok to call kfree_skb on NULL)
This also allows us to avoid calling rcu_read_unlock here,
and removes the only user of the "out" label.
Signed-off-by: Jesper Nilsson <jesper.nilsson@axis.com>
This patch addresses the IPv6 multicast routing issues described
below. It was tested with XORP 1.4/1.5 as the IPv6 PIM-SM routing
daemon against FreeBSD peers.
net/ipv6/ip6_input.c:
- Don't try to forward link-local multicast packets.
- Don't reset skb2->dev before calling ip6_mr_input() so packets can
be identified as coming from the PIM register vif properly.
net/ipv6/ip6mr.c:
- Fix incoming PIM register messages processing:
* The IPv6 pseudo-header should be included when checksumming PIM
messages (RFC 4601 section 4.9; RFC 3973 section 4.7.1).
* Packets decapsulated from PIM register messages should have
skb->protocol ETH_P_IPV6.
- Enable/disable IPv6 multicast forwarding on the corresponding
interface when a routing daemon adds/removes a multicast virtual
interface.
- Remove incorrect skb_pull() to fix userspace signaling.
- Enable/disable global IPv6 multicast forwarding when an IPv6
multicast routing socket is opened/closed.
net/ipv6/route.c:
- Don't use strict routing logic for packets decapsulated from PIM
register messages (similar to disabling rp_filter for the IPv4
case).
Signed-off-by: Thomas Goff <thomas.goff@boeing.com>
Reviewed-by: Fred Templin <fred.l.templin@boeing.com>
Signed-off-by: Denis V. Lunev <den@openvz.org>
