commit 731abb9cb27aef6013ce60808a04e04a545f3f4e upstream.
Commit 1c5cae815d removed an explicit call to dev_alloc_name in ip6_tnl_create
because register_netdevice will now create a valid name. This works for the
net_device itself.
However the tunnel keeps a copy of the name in the parms structure for the
ip6_tnl associated with the tunnel. parms.name is set by copying the net_device
name in ip6_tnl_dev_init_gen. That function is called from ip6_tnl_dev_init in
ip6_tnl_create, but it is done before register_netdevice is called so the name
is set to a bogus value in the parms.name structure.
This shows up if you do a simple tunnel add, followed by a tunnel show:
[root@localhost ~]# ip -6 tunnel add remote fec0::100 local fec0::200
[root@localhost ~]# ip -6 tunnel show
ip6tnl0: ipv6/ipv6 remote :: local :: encaplimit 0 hoplimit 0 tclass 0x00 flowlabel 0x00000 (flowinfo 0x00000000)
ip6tnl%d: ipv6/ipv6 remote fec0::100 local fec0::200 encaplimit 4 hoplimit 64 tclass 0x00 flowlabel 0x00000 (flowinfo 0x00000000)
[root@localhost ~]#
Fix this by moving the strcpy out of ip6_tnl_dev_init_gen, and calling it after
register_netdevice has successfully returned.
Signed-off-by: Josh Boyer <jwboyer@redhat.com>
This allows us to move duplicated code in <asm/atomic.h>
(atomic_inc_not_zero() for now) to <linux/atomic.h>
Signed-off-by: Arun Sharma <asharma@fb.com>
Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com>
Force dev_alloc_name() to be called from register_netdevice() by
dev_get_valid_name(). That allows to remove multiple explicit
dev_alloc_name() calls.
The possibility to call dev_alloc_name in advance remains.
This also fixes veth creation regresion caused by
84c49d8c3e4abefb0a41a77b25aa37ebe8d6b743
Signed-off-by: Jiri Pirko <jpirko@redhat.com>
Add const qualifiers to structs iphdr, ipv6hdr and in6_addr pointers
where possible, to make code intention more obvious.
I intend to turn struct flowi into a union of AF specific flowi
structs. There will be a common structure that each variant includes
first, much like struct sock_common.
This is the first step to move in that direction.
The idea here is this minimizes the number of places one has to edit
in order to make changes to how flows are defined and used.
drivers/net/bnx2x/bnx2x_cmn.c
Add necessary alias to autoload ip6ip6 tunnel module.
Instead of on the stack.
drivers/net/wireless/ath/ath9k/ar9003_eeprom.c
net/llc/af_llc.c
The ip6_tunnel always assumes it consumes 40 bytes (ip6 hdr) of the mtu of the
underlaying device. So for a normal ethernet bearer, the mtu of the ip6_tunnel is
1460.
However, when creating a tunnel the encap limit option is enabled by default, and it
consumes 8 bytes more, so the true mtu shall be 1452.
I dont really know if this breaks some statement in some RFC, so this is a request for
comments.
Signed-off-by: Anders Franzen <anders.franzen@ericsson.com>
1. IPV6_TLV_TEL_DST_SIZE
This has not been using for several years since created.
2. RT6_INFO_LEN
commit 33120b30 kill all RT6_INFO_LEN's references, but only this definition remained.
commit 33120b30cc3b8665204d4fcde7288638b0dd04d5
Author: Alexey Dobriyan <adobriyan@sw.ru>
Date: Tue Nov 6 05:27:11 2007 -0800
[IPV6]: Convert /proc/net/ipv6_route to seq_file interface
Signed-off-by: Shan Wei <shanwei@cn.fujitsu.com>
After making rcu protection for tunnels (ipip, gre, sit and ip6) a bug
was introduced into the SIOCCHGTUNNEL code.
The tunnel is first unlinked, then addresses change, then it is linked
back probably into another bucket. But while changing the parms, the
hash table is unlocked to readers and they can lookup the improper tunnel.
Respective commits are b7285b79 (ipip: get rid of ipip_lock), 1507850b
(gre: get rid of ipgre_lock), 3a43be3c (sit: get rid of ipip6_lock) and
94767632 (ip6tnl: get rid of ip6_tnl_lock).
The quick fix is to wait for quiescent state to pass after unlinking,
but if it is inappropriate I can invent something better, just let me
know.
Signed-off-by: Pavel Emelyanov <xemul@openvz.org>
The ip6_tunnel device did not unset the flag,
IFF_XMIT_DST_RELEASE. This will make the dev layer
to release the dst before calling the tunnel.
The tunnel will not update any mtu/pmtu info, since
it does not have a dst on the skb.
In various situations, a device provides a packet to our stack and we
drop it before it enters protocol stack :
- softnet backlog full (accounted in /proc/net/softnet_stat)
- bad vlan tag (not accounted)
- unknown/unregistered protocol (not accounted)
We can handle a per-device counter of such dropped frames at core level,
and automatically adds it to the device provided stats (rx_dropped), so
that standard tools can be used (ifconfig, ip link, cat /proc/net/dev)
This is a generalization of commit 8990f468a (net: rx_dropped
accounting), thus reverting it.
Maintain per_cpu tx_bytes, tx_packets, rx_bytes, rx_packets.
Other seldom used fields are kept in netdev->stats structure, possibly
unsafe.
This is a preliminary work to support lockless transmit path, and
correct RX stats, that are already unsafe.
Under load, netif_rx() can drop incoming packets but administrators dont
have a chance to spot which device needs some tuning (RPS activation for
example)
This patch adds rx_dropped accounting in vlans and tunnels.
As RTNL is held while doing tunnels inserts and deletes, we can remove
ip6_tnl_lock spinlock. My initial RCU conversion was conservative and
converted the rwlock to spinlock, with no RTNL requirement.
Use appropriate rcu annotations and modern lockdep checks as well.
tunnel6_handlers chain being scanned for each incoming packet,
make sure it doesnt share an often dirtied cache line.
remove useless union keyword in rtable, rt6_info and dn_route.
Since there is only one member in a union, the union keyword isn't useful.
Signed-off-by: Changli Gao <xiaosuo@gmail.com>
skb rxhash should be cleared when a skb is handled by a tunnel before
being delivered again, so that correct packet steering can take place.
There are other cleanups and accounting that we can factorize in a new
helper, skb_tunnel_rx()
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Dunno, what was the idea, it wasn't used for a long time.
Same stuff as in ip_gre patch: receive hook can be called before netns
setup is done, oopsing in net_generic().
__net_init/__net_exit are apparently not going away, so use them
to full extent.
In some cases __net_init was removed, because it was called from
__net_exit code.
Take advantage of the new pernet automatic storage management,
and stop using compatibility network namespace functions.
Using dev_get_by_index_rcu() in ip6_tnl_rcv_ctl() & ip6_tnl_xmit_ctl()
avoids touching device refcount.
Speedup module unloading by factorizing synchronize_rcu() calls
ip6_tunnels use one rwlock to protect their hash tables.
This locking scheme can be converted to RCU for free, since netdevice
already must wait for a RCU grace period at dismantle time.
It seems recursion field from "struct ip_tunnel" is not anymore needed.
recursion prevention is done at the upper level (in dev_queue_xmit()),
since we use HARD_TX_LOCK protection for tunnels.
This avoids a cache line ping pong on "struct ip_tunnel" : This structure
should be now mostly read on xmit and receive paths.
This patch is the result of an automatic spatch transformation to convert
all ndo_start_xmit() return values of 0 to NETDEV_TX_OK.
Some occurences are missed by the automatic conversion, those will be
handled in a seperate patch.
Change all the code that deals directly with ICMPv6 type and code
values to use u8 instead of a signed int as that's the actual data
type.
Signed-off-by: Brian Haley <brian.haley@hp.com>
Define three accessors to get/set dst attached to a skb
struct dst_entry *skb_dst(const struct sk_buff *skb)
void skb_dst_set(struct sk_buff *skb, struct dst_entry *dst)
void skb_dst_drop(struct sk_buff *skb)
This one should replace occurrences of :
dst_release(skb->dst)
skb->dst = NULL;
Delete skb->dst field
Patch fixes issues with dev->dev_addr changing from array to pointer.
Hopefully there are no others.
When the user creates IPv6 over IPv6 tunnel, the device name created
by the kernel isn't set to t->parm.name, which is referred as the
result of ioctl().
Signed-off-by: Noriaki TAKAMIYA <takamiya@po.ntts.co.jp>
Pass netns to xfrm_lookup()/__xfrm_lookup(). For that pass netns
to flow_cache_lookup() and resolver callback.
Take it from socket or netdevice. Stub DECnet to init_net.
dev_net_set() should be the very first thing after alloc_netdev().
"ndo_" changes turned simple assignment (which is OK to do before netns
assignment) into quite non-trivial operation (which is not OK, init_net was
used). This leads to incomplete initialisation of tunnel device in netns.
BUG: unable to handle kernel NULL pointer dereference at 00000004
IP: [<c02efdb5>] ip6_tnl_exit_net+0x37/0x4f
*pde = 00000000
Oops: 0000 [#1] PREEMPT DEBUG_PAGEALLOC
last sysfs file: /sys/class/net/lo/operstate
Pid: 10, comm: netns Not tainted (2.6.28-rc6 #1)
EIP: 0060:[<c02efdb5>] EFLAGS: 00010246 CPU: 0
EIP is at ip6_tnl_exit_net+0x37/0x4f
EAX: 00000000 EBX: 00000020 ECX: 00000000 EDX: 00000003
ESI: c5caef30 EDI: c782bbe8 EBP: c7909f50 ESP: c7909f48
DS: 007b ES: 007b FS: 0000 GS: 0000 SS: 0068
Process netns (pid: 10, ti=c7908000 task=c7905780 task.ti=c7908000)
Stack:
c03e75e0 c7390bc8 c7909f60 c0245448 c7390bd8 c7390bf0 c7909fa8 c012577a
00000000 00000002 00000000 c0125736 c782bbe8 c7909f90 c0308fe3 c782bc04
c7390bd4 c0245406 c084b718 c04f0770 c03ad785 c782bbe8 c782bc04 c782bc0c
Call Trace:
[<c0245448>] ? cleanup_net+0x42/0x82
[<c012577a>] ? run_workqueue+0xd6/0x1ae
[<c0125736>] ? run_workqueue+0x92/0x1ae
[<c0308fe3>] ? schedule+0x275/0x285
[<c0245406>] ? cleanup_net+0x0/0x82
[<c0125ae1>] ? worker_thread+0x81/0x8d
[<c0128344>] ? autoremove_wake_function+0x0/0x33
[<c0125a60>] ? worker_thread+0x0/0x8d
[<c012815c>] ? kthread+0x39/0x5e
[<c0128123>] ? kthread+0x0/0x5e
[<c0103b9f>] ? kernel_thread_helper+0x7/0x10
Code: db e8 05 ff ff ff 89 c6 e8 dc 04 f6 ff eb 08 8b 40 04 e8 38 89 f5 ff 8b 44 9e 04 85 c0 75 f0 43 83 fb 20 75 f2 8b 86 84 00 00 00 <8b> 40 04 e8 1c 89 f5 ff e8 98 04 f6 ff 89 f0 e8 f8 63 e6 ff 5b
EIP: [<c02efdb5>] ip6_tnl_exit_net+0x37/0x4f SS:ESP 0068:c7909f48
---[ end trace 6c2f2328fccd3e0c ]---
Remove redundant argument comments in files of net/*
Signed-off-by: Qinghuang Feng <qhfeng.kernel@gmail.com>
Like IPV4, convert the tunnel virtual devices to use net_device_ops.
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
This patch removes CVS keywords that weren't updated for a long time
from comments.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
This tunnel uses its own private structure and requires separate
patch to switch from private stats to on-device ones.
And no need in some IPPROTO_XXX enabling, since ipv6 code
doesn't have any filtering.
So, just set proper net and mark device with NETNS_LOCAL.
All the ip_route_output_key(), dev_get_by_...() and ipv6_chk_addr()
calls are now stubbed with init_net.
Fortunately, all the places already have where to get the proper
net from.
Move hashes in the struct ip6_tnl_net, replace tnls_xxx[] with
ip6n->tnlx_xxx[] and handle init and exit appropriately.
