[ Upstream commit 4c6980462f32b4f282c5d8e5f7ea8070e2937725 ]
Similar to ipv4, when destroying an mrt table the static mfc entries and
the static devices are kept, which leads to devices that can never be
destroyed (because of refcnt taken) and leaked memory. Make sure that
everything is cleaned up on netns destruction.
Fixes: 8229efdaef1e ("netns: ip6mr: enable namespace support in ipv6 multicast forwarding code")
CC: Benjamin Thery <benjamin.thery@bull.net>
Signed-off-by: Nikolay Aleksandrov <nikolay@cumulusnetworks.com>
Reviewed-by: Cong Wang <cwang@twopensource.com>
[ Upstream commit 25b4a44c19c83d98e8c0807a7ede07c1f28eab8b ]
In the IPv6 multicast routing code the mrt_lock was not being released
correctly in the MFC iterator, as a result adding or deleting a MIF would
cause a hang because the mrt_lock could not be acquired.
This fix is a copy of the code for the IPv4 case and ensures that the lock
is released correctly.
Signed-off-by: Richard Laing <richard.laing@alliedtelesis.co.nz>
Acked-by: Cong Wang <cwang@twopensource.com>
On the output paths in particular, we have to sometimes deal with two
socket contexts. First, and usually skb->sk, is the local socket that
generated the frame.
And second, is potentially the socket used to control a tunneling
socket, such as one the encapsulates using UDP.
We do not want to disassociate skb->sk when encapsulating in order
to fix this, because that would break socket memory accounting.
The most extreme case where this can cause huge problems is an
AF_PACKET socket transmitting over a vxlan device. We hit code
paths doing checks that assume they are dealing with an ipv4
socket, but are actually operating upon the AF_PACKET one.
drivers/net/ethernet/mellanox/mlx4/cmd.c
net/core/fib_rules.c
net/ipv4/fib_frontend.c
The fib_rules.c and fib_frontend.c conflicts were locking adjustments
in 'net' overlapping addition and removal of code in 'net-next'.
The mlx4 conflict was a bug fix in 'net' happening in the same
place a constant was being replaced with a more suitable macro.
We need to wait for the flying timers, since we
are going to free the mrtable right after it.
Cc: Hannes Frederic Sowa <hannes@stressinduktion.org>
We have to hold rtnl lock for fib_rules_unregister()
otherwise the following race could happen:
fib_rules_unregister(): fib_nl_delrule():
... ops = lookup_rules_ops();
list_del_rcu(&ops->list);
list_for_each_entry(ops->rules) {
fib_rules_cleanup_ops(ops); ...
list_del_rcu(); list_del_rcu();
Note, net->rules_mod_lock is actually not needed at all,
either upper layer netns code or rtnl lock guarantees
we are safe.
Cc: Alexander Duyck <alexander.h.duyck@redhat.com>
Cc: Thomas Graf <tgraf@suug.ch>
drivers/net/usb/asix_common.c
drivers/net/usb/sr9800.c
drivers/net/usb/usbnet.c
include/linux/usb/usbnet.h
net/ipv4/tcp_ipv4.c
net/ipv6/tcp_ipv6.c
The TCP conflicts were overlapping changes. In 'net' we added a
READ_ONCE() to the socket cached RX route read, whilst in 'net-next'
Eric Dumazet touched the surrounding code dealing with how mini
sockets are handled.
With USB, it's a case of the same bug fix first going into net-next
and then I cherry picked it back into net.
Don't use dev->iflink anymore.
Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com>
The goal of this patch is to prepare the removal of the iflink field. It
introduces a new ndo function, which will be implemented by virtual interfaces.
There is no functional change into this patch. All readers of iflink field
now call dev_get_iflink().
IP addresses are often stored in netlink attributes. Add generic functions
to do that.
For nla_put_in_addr, it would be nicer to pass struct in_addr but this is
not used universally throughout the kernel, in way too many places __be32 is
used to store IPv4 address.
Signed-off-by: Jiri Benc <jbenc@redhat.com>
The ipv6 code uses a mixture of coding styles. In some instances check for NULL
pointer is done as x != NULL and sometimes as x. x is preferred according to
checkpatch and this patch makes the code consistent by adopting the latter
form.
No changes detected by objdiff.
Signed-off-by: Ian Morris <ipm@chirality.org.uk>
pointer is done as x == NULL and sometimes as !x. !x is preferred according to
form.
Having to say
> #ifdef CONFIG_NET_NS
> struct net *net;
> #endif
in structures is a little bit wordy and a little bit error prone.
Instead it is possible to say:
> typedef struct {
> struct net *net;
> #endif
> } possible_net_t;
And then in a header say:
> possible_net_t net;
Which is cleaner and easier to use and easier to test, as the
possible_net_t is always there no matter what the compile options.
Further this allows read_pnet and write_pnet to be functions in all
cases which is better at catching typos.
This change adds possible_net_t, updates the definitions of read_pnet
and write_pnet, updates optional struct net * variables that
write_pnet uses on to have the type possible_net_t, and finally fixes
up the b0rked users of read_pnet and write_pnet.
Contrary to common expectations for an "int" return, these functions
return only a positive value -- if used correctly they cannot even
return 0 because the message header will necessarily be in the skb.
This makes the very common pattern of
if (genlmsg_end(...) < 0) { ... }
be a whole bunch of dead code. Many places also simply do
return nlmsg_end(...);
and the caller is expected to deal with it.
This also commonly (at least for me) causes errors, because it is very
common to write
if (my_function(...))
/* error condition */
and if my_function() does "return nlmsg_end()" this is of course wrong.
Additionally, there's not a single place in the kernel that actually
needs the message length returned, and if anyone needs it later then
it'll be very easy to just use skb->len there.
Remove this, and make the functions void. This removes a bunch of dead
code as described above. The patch adds lines because I did
- return nlmsg_end(...);
+ nlmsg_end(...);
+ return 0;
I could have preserved all the function's return values by returning
skb->len, but instead I've audited all the places calling the affected
functions and found that none cared. A few places actually compared
the return value with <= 0 in dump functionality, but that could just
be changed to < 0 with no change in behaviour, so I opted for the more
efficient version.
One instance of the error I've made numerous times now is also present
in net/phonet/pn_netlink.c in the route_dumpit() function - it didn't
check for <0 or <=0 and thus broke out of the loop every single time.
I've preserved this since it will (I think) have caused the messages to
userspace to be formatted differently with just a single message for
every SKB returned to userspace. It's possible that this isn't needed
for the tools that actually use this, but I don't even know what they
are so couldn't test that changing this behaviour would be acceptable.
drivers/net/ieee802154/fakehard.c
A bug fix went into 'net' for ieee802154/fakehard.c, which is removed
in 'net-next'.
Add build fix into the merge from Stephen Rothwell in openvswitch, the
logging macros take a new initial 'log' argument, a new call was added
in 'net' so when we merge that in here we have to explicitly add the
new 'log' arg to it else the build fails.
pim6_protocol was added when initiation, but it not deleted.
Similarly, unregister RTNL_FAMILY_IP6MR rtnetlink.
Signed-off-by: Duan Jiong <duanj.fnst@cn.fujitsu.com>
Signed-off-by: Fabian Frederick <fabf@skynet.be>
This patch makes no changes to the logic of the code but simply addresses
coding style issues as detected by checkpatch.
Both objdump and diff -w show no differences.
A number of items are addressed in this patch:
* Multiple spaces converted to tabs
* Spaces before tabs removed.
* Spaces in pointer typing cleansed (char *)foo etc.
* Remove space after sizeof
* Ensure spacing around comparators such as if statements.
Extend alloc_netdev{,_mq{,s}}() to take name_assign_type as argument, and convert
all users to pass NET_NAME_UNKNOWN.
Coccinelle patch:
expression sizeof_priv, name, setup, txqs, rxqs, count;
-alloc_netdev_mqs(sizeof_priv, name, setup, txqs, rxqs)
+alloc_netdev_mqs(sizeof_priv, name, NET_NAME_UNKNOWN, setup, txqs, rxqs)
-alloc_netdev_mq(sizeof_priv, name, setup, count)
+alloc_netdev_mq(sizeof_priv, name, NET_NAME_UNKNOWN, setup, count)
-alloc_netdev(sizeof_priv, name, setup)
+alloc_netdev(sizeof_priv, name, NET_NAME_UNKNOWN, setup)
v9: move comments here from the wrong commit
Signed-off-by: Tom Gundersen <teg@jklm.no>
Reviewed-by: David Herrmann <dh.herrmann@gmail.com>
To properly match iif in ip rules we have to provide
LOOPBACK_IFINDEX in flowi6_iif, not 0. Some ip6mr_fib_lookup
and fib6_rule_lookup callers need such fix.
Signed-off-by: Julian Anastasov <ja@ssi.bg>
As suggested by Julian:
Simply, flowi4_iif must not contain 0, it does not
look logical to ignore all ip rules with specified iif.
because in fib_rule_match() we do:
if (rule->iifindex && (rule->iifindex != fl->flowi_iif))
goto out;
flowi4_iif should be LOOPBACK_IFINDEX by default.
We need to move LOOPBACK_IFINDEX to include/net/flow.h:
1) It is mostly used by flowi_iif
2) Fix the following compile error if we use it in flow.h
by the patches latter:
In file included from include/linux/netfilter.h:277:0,
from include/net/netns/netfilter.h:5,
from include/net/net_namespace.h:21,
from include/linux/netdevice.h:43,
from include/linux/icmpv6.h:12,
from include/linux/ipv6.h:61,
from include/net/ipv6.h:16,
from include/linux/sunrpc/clnt.h:27,
from include/linux/nfs_fs.h:30,
from init/do_mounts.c:32:
include/net/flow.h: In function ‘flowi4_init_output’:
include/net/flow.h:84:32: error: ‘LOOPBACK_IFINDEX’ undeclared (first use in this function)
Cc: Eric Biederman <ebiederm@xmission.com>
Cc: Julian Anastasov <ja@ssi.bg>
Signed-off-by: Cong Wang <cwang@twopensource.com>
Commit 812e44dd1829 ("ip6mr: advertise new mfc entries via rtnl") reuses the
function ip6mr_fill_mroute() to notify mfc events.
But this function was used only for dump and thus was always setting the
flag NLM_F_MULTI, which is wrong in case of a single notification.
Libraries like libnl will wait forever for NLMSG_DONE.
CC: Thomas Graf <tgraf@suug.ch>
Acked-by: Thomas Graf <tgraf@suug.ch>
Bob Falken reported that after 4G packets, multicast forwarding stopped
working. This was because of a rule reference counter overflow which
freed the rule as soon as the overflow happend.
This patch solves this by adding the FIB_LOOKUP_NOREF flag to
fib_rules_lookup calls. This is safe even from non-rcu locked sections
as in this case the flag only implies not taking a reference to the rule,
which we don't need at all.
Rules only hold references to the namespace, which are guaranteed to be
available during the call of the non-rcu protected function reg_vif_xmit
because of the interface reference which itself holds a reference to
the net namespace.
Fixes: f0ad0860d01e47 ("ipv4: ipmr: support multiple tables")
Fixes: d1db275dd3f6e4 ("ipv6: ip6mr: support multiple tables")
Reported-by: Bob Falken <NetFestivalHaveFun@gmx.com>
Cc: Patrick McHardy <kaber@trash.net>
The goal of this patch is to harmonize cleanup done on a skbuff on rx path.
Before this patch, behaviors were different depending of the tunnel type.
Merge net into net-next to setup some infrastructure Eric
Dumazet needs for usbnet changes.
Otherwise we end up dereferencing the already freed net->ipv6.mrt pointer
which leads to a panic (from Srivatsa S. Bhat):
BUG: unable to handle kernel paging request at ffff882018552020
IP: [<ffffffffa0366b02>] ip6mr_sk_done+0x32/0xb0 [ipv6]
PGD 290a067 PUD 207ffe0067 PMD 207ff1d067 PTE 8000002018552060
Oops: 0000 [#1] SMP DEBUG_PAGEALLOC
Modules linked in: ebtable_nat ebtables nfs fscache nf_conntrack_ipv4 nf_defrag_ipv4 ipt_REJECT xt_CHECKSUM iptable_mangle iptable_filter ip_tables nfsd lockd nfs_acl exportfs auth_rpcgss autofs4 sunrpc 8021q garp bridge stp llc ip6t_REJECT nf_conntrack_ipv6 nf_defrag_ipv6 xt_state nf_conntrack ip6table_filter
+ip6_tables ipv6 vfat fat vhost_net macvtap macvlan vhost tun kvm_intel kvm uinput iTCO_wdt iTCO_vendor_support cdc_ether usbnet mii microcode i2c_i801 i2c_core lpc_ich mfd_core shpchp ioatdma dca mlx4_core be2net wmi acpi_cpufreq mperf ext4 jbd2 mbcache dm_mirror dm_region_hash dm_log dm_mod
CPU: 0 PID: 7 Comm: kworker/u33:0 Not tainted 3.11.0-rc1-ea45e-a #4
Hardware name: IBM -[8737R2A]-/00Y2738, BIOS -[B2E120RUS-1.20]- 11/30/2012
Workqueue: netns cleanup_net
task: ffff8810393641c0 ti: ffff881039366000 task.ti: ffff881039366000
RIP: 0010:[<ffffffffa0366b02>] [<ffffffffa0366b02>] ip6mr_sk_done+0x32/0xb0 [ipv6]
RSP: 0018:ffff881039367bd8 EFLAGS: 00010286
RAX: ffff881039367fd8 RBX: ffff882018552000 RCX: dead000000200200
RDX: 0000000000000000 RSI: ffff881039367b68 RDI: ffff881039367b68
RBP: ffff881039367bf8 R08: ffff881039367b68 R09: 2222222222222222
R10: 2222222222222222 R11: 2222222222222222 R12: ffff882015a7a040
R13: ffff882014eb89c0 R14: ffff8820289e2800 R15: 0000000000000000
FS: 0000000000000000(0000) GS:ffff88103fc00000(0000) knlGS:0000000000000000
CR2: ffff882018552020 CR3: 0000000001c0b000 CR4: 00000000000407f0
Stack:
ffff881039367c18 ffff882014eb89c0 ffff882015e28c00 0000000000000000
ffff881039367c18 ffffffffa034d9d1 ffff8820289e2800 ffff882014eb89c0
ffff881039367c58 ffffffff815bdecb ffffffff815bddf2 ffff882014eb89c0
Call Trace:
[<ffffffffa034d9d1>] rawv6_close+0x21/0x40 [ipv6]
[<ffffffff815bdecb>] inet_release+0xfb/0x220
[<ffffffff815bddf2>] ? inet_release+0x22/0x220
[<ffffffffa032686f>] inet6_release+0x3f/0x50 [ipv6]
[<ffffffff8151c1d9>] sock_release+0x29/0xa0
[<ffffffff81525520>] sk_release_kernel+0x30/0x70
[<ffffffffa034f14b>] icmpv6_sk_exit+0x3b/0x80 [ipv6]
[<ffffffff8152fff9>] ops_exit_list+0x39/0x60
[<ffffffff815306fb>] cleanup_net+0xfb/0x1a0
[<ffffffff81075e3a>] process_one_work+0x1da/0x610
[<ffffffff81075dc9>] ? process_one_work+0x169/0x610
[<ffffffff81076390>] worker_thread+0x120/0x3a0
[<ffffffff81076270>] ? process_one_work+0x610/0x610
[<ffffffff8107da2e>] kthread+0xee/0x100
[<ffffffff8107d940>] ? __init_kthread_worker+0x70/0x70
[<ffffffff8162a99c>] ret_from_fork+0x7c/0xb0
Code: 20 48 89 5d e8 4c 89 65 f0 4c 89 6d f8 66 66 66 66 90 4c 8b 67 30 49 89 fd e8 db 3c 1e e1 49 8b 9c 24 90 08 00 00 48 85 db 74 06 <4c> 39 6b 20 74 20 bb f3 ff ff ff e8 8e 3c 1e e1 89 d8 4c 8b 65
RIP [<ffffffffa0366b02>] ip6mr_sk_done+0x32/0xb0 [ipv6]
RSP <ffff881039367bd8>
Reported-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com>
Tested-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com>
This patch changes the prototpye of the ip6_mr_forward() method to return void
instead of int.
The ip6_mr_forward() method always returns 0; moreover, the return value of this
method is not checked anywhere.
Signed-off-by: Rami Rosen <ramirose@gmail.com>
Acked-by: Nicolas Dichtel <nicolas.dichtel@6wind.com>
So far, only net_device * could be passed along with netdevice notifier
event. This patch provides a possibility to pass custom structure
able to provide info that event listener needs to know.
Signed-off-by: Jiri Pirko <jiri@resnulli.us>
v2->v3: fix typo on simeth
shortened dev_getter
shortened notifier_info struct name
v1->v2: fix notifier_call parameter in call_netdevice_notifier()
Signed-off-by: Hong Zhiguo <honkiko@gmail.com>
proc_net_remove is only used to remove proc entries
that under /proc/net,it's not a general function for
removing proc entries of netns. if we want to remove
some proc entries which under /proc/net/stat/, we still
need to call remove_proc_entry.
this patch use remove_proc_entry to replace proc_net_remove.
we can remove proc_net_remove after this patch.
Signed-off-by: Gao feng <gaofeng@cn.fujitsu.com>
Right now, some modules such as bonding use proc_create
to create proc entries under /proc/net/, and other modules
such as ipv4 use proc_net_fops_create.
It looks a little chaos.this patch changes all of
proc_net_fops_create to proc_create. we can remove
proc_net_fops_create after this patch.
Bring in the 'net' tree so that we can get some ipv4/ipv6 bug
fixes that some net-next work will build upon.
We did this for IPv4 in b49d3c1e1c "net: ipmr: limit MRT_TABLE
identifiers" but we need to do it for IPv6 as well. On IPv6 the name
is "pim6reg" instead of "pimreg" so there is one less digit allowed.
The strcpy() is in ip6mr_reg_vif().
This patch add the support of proxy multicast, ie being able to build a static
multicast tree. It adds the support of (*,*) and (*,G) entries.
The user should define an (*,*) entry which is not used for real forwarding.
This entry defines the upstream in iif and contains all interfaces from the
static tree in its oifs. It will be used to forward packet upstream when they
come from an interface belonging to the static tree.
Hence, the user should define (*,G) entries to build its static tree. Note that
upstream interface must be part of oifs: packets are sent to all oifs
interfaces except the input interface. This ensures to always join the whole
static tree, even if the packet is not coming from the upstream interface.
Acked-by: David L Stevens <dlstevens@us.ibm.com>
We talk about IPv6, hence the family is RTNL_FAMILY_IP6MR!
rtnl_register() is already called with RTNL_FAMILY_IP6MR.
The bug is here since the beginning of this function (commit 5b285cac3570).
This patch allows to monitor mf6c activities via rtnetlink.
To avoid parsing two times the mf6c oifs, we use maxvif to allocate the rtnl
msg, thus we may allocate some superfluous space.
/proc/net/ip[6]_mr_cache allows to get all mfc entries, even if they are put in
the unresolved list (mfc[6]_unres_queue). But only the table RT_TABLE_DEFAULT is
displayed.
This patch adds the parsing of the unresolved list when the dump is made via
rtnetlink, hence each table can be checked.
In IPv6, we set rtm_type in ip6mr_fill_mroute(), because in case of unresolved
mfc __ip6mr_fill_mroute() will not set it. In IPv4, it is already done.
A mfc entry can be static or not (added via the mroute_sk socket). The patch
reports MFC_STATIC flag into rtm_protocol by setting rtm_protocol to
RTPROT_STATIC or RTPROT_MROUTED.
These statistics can be checked only via /proc/net/ip_mr_cache or
SIOCGETSGCNT[_IN6] and thus only for the table RT_TABLE_DEFAULT.
Advertising them via rtnetlink allows to get statistics for all cache entries,
whatever the table is.
This patch removes the skb manipulations when nested attributes are added by
using standard helpers.
This patch advertise the MC_FORWARDING status for IPv4 and IPv6.
This field is readonly, only multicast engine in the kernel updates it.
Verify the length of the user-space arguments.
Save a few bytes per table by convert mroute_do_assert and
mroute_do_pim from int to bool.
Remove !! as the compiler does that when assigning int to bool.
Allow an unpriviled user who has created a user namespace, and then
created a network namespace to effectively use the new network
namespace, by reducing capable(CAP_NET_ADMIN) and
capable(CAP_NET_RAW) calls to be ns_capable(net->user_ns,
CAP_NET_ADMIN), or capable(net->user_ns, CAP_NET_RAW) calls.
Settings that merely control a single network device are allowed.
Either the network device is a logical network device where
restrictions make no difference or the network device is hardware NIC
that has been explicity moved from the initial network namespace.
In general policy and network stack state changes are allowed while
resource control is left unchanged.
Allow the SIOCSIFADDR ioctl to add ipv6 addresses.
Allow the SIOCDIFADDR ioctl to delete ipv6 addresses.
Allow the SIOCADDRT ioctl to add ipv6 routes.
Allow the SIOCDELRT ioctl to delete ipv6 routes.
Allow creation of ipv6 raw sockets.
Allow setting the IPV6_JOIN_ANYCAST socket option.
Allow setting the IPV6_FL_A_RENEW parameter of the IPV6_FLOWLABEL_MGR
socket option.
Allow setting the IPV6_TRANSPARENT socket option.
Allow setting the IPV6_HOPOPTS socket option.
Allow setting the IPV6_RTHDRDSTOPTS socket option.
Allow setting the IPV6_DSTOPTS socket option.
Allow setting the IPV6_IPSEC_POLICY socket option.
Allow setting the IPV6_XFRM_POLICY socket option.
Allow sending packets with the IPV6_2292HOPOPTS control message.
Allow sending packets with the IPV6_2292DSTOPTS control message.
Allow sending packets with the IPV6_RTHDRDSTOPTS control message.
Allow setting the multicast routing socket options on non multicast
routing sockets.
Allow the SIOCADDTUNNEL, SIOCCHGTUNNEL, and SIOCDELTUNNEL ioctls for
setting up, changing and deleting tunnels over ipv6.
Allow the SIOCADDTUNNEL, SIOCCHGTUNNEL, SIOCDELTUNNEL ioctls for
setting up, changing and deleting ipv6 over ipv4 tunnels.
Allow the SIOCADDPRL, SIOCDELPRL, SIOCCHGPRL ioctls for adding,
deleting, and changing the potential router list for ISATAP tunnels.
It is a frequent mistake to confuse the netlink port identifier with a
process identifier. Try to reduce this confusion by renaming fields
that hold port identifiers portid instead of pid.
I have carefully avoided changing the structures exported to
userspace to avoid changing the userspace API.
I have successfully built an allyesconfig kernel with this change.
Acked-by: Stephen Hemminger <shemminger@vyatta.com>
Signed-off-by: Thomas Graf <tgraf@suug.ch>
RFC 4293 defines ipIfStatsOutOctets (similar definition for
ipSystemStatsOutOctets):
The total number of octets in IP datagrams delivered to the lower
layers for transmission. Octets from datagrams counted in
ipIfStatsOutTransmits MUST be counted here.
And ipIfStatsOutTransmits:
The total number of IP datagrams that this entity supplied to the
lower layers for transmission. This includes datagrams generated
locally and those forwarded by this entity.
Therefore, IPSTATS_MIB_OUTOCTETS must be incremented when incrementing
IPSTATS_MIB_OUTFORWDATAGRAMS.
IP_UPD_PO_STATS is not used since ipIfStatsOutRequests must not
include forwarded datagrams:
The total number of IP datagrams that local IP user-protocols
(including ICMP) supplied to IP in requests for transmission. Note
that this counter does not include any datagrams counted in
ipIfStatsOutForwDatagrams.
Signed-off-by: Vincent Bernat <bernat@luffy.cx>
Add #define pr_fmt(fmt) as appropriate.
Add "IPv6: " to appropriate files.
Convert printk(KERN_<LEVEL> to pr_<level> (but not KERN_DEBUG).
Standardize on "%s: " not "%s(): " when emitting __func__.
Use "%s: ", __func__ instead of embedding function name.
Coalesce formats, align arguments.
ADDRCONF output is now prefixed with "IPv6: "
