path: root/net/ipv6/ipcomp6.c
2011-04-22inet: constify ip headers and in6_addrEric Dumazet
Add const qualifiers to structs iphdr, ipv6hdr and in6_addr pointers where possible, to make code intention more obvious. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-22xfrm: SA lookups signature with markJamal Hadi Salim
pass mark to all SA lookups to prepare them for when we add code to have them search. Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-16Merge branch 'master' of ↵David S. Miller
2010-02-16ipcomp: Avoid duplicate calls to ipcomp_destroyHerbert Xu
When ipcomp_tunnel_attach fails we will call ipcomp_destroy twice. This may lead to double-frees on certain structures. As there is no reason to explicitly call ipcomp_destroy, this patch removes it from ipcomp*.c and lets the standard xfrm_state destruction take place. This is based on the discovery and patch by Alexey Dobriyan. Tested-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-28netns xfrm: ipcomp6 supportAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-28netns xfrm: xfrm6_tunnel in netnsAlexey Dobriyan
I'm not sure about rcu stuff near kmem cache destruction: * checks for non-empty hashes look bogus, they're done _before_ rcu_berrier() * unregistering netns ops is done before kmem_cache destoy (as it should), and unregistering involves rcu barriers by itself So it looks nothing should be done. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-14net: constify struct inet6_protocolAlexey Dobriyan
2009-06-23ipv6: Use correct data types for ICMPv6 type and codeBrian Haley
Change all the code that deals directly with ICMPv6 type and code values to use u8 instead of a signed int as that's the actual data type. Signed-off-by: Brian Haley <brian.haley@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-25netns xfrm: state lookup in netnsAlexey Dobriyan
2008-11-25netns xfrm: add struct xfrm_state::xs_netAlexey Dobriyan
To avoid unnecessary complications with passing netns around. * set once, very early after allocating * once set, never changes For a while create every xfrm_state in init_net. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-29net: replace %p6 with %pI6Harvey Harrison
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-28net: replace uses of NIP6_FMT with %p6Harvey Harrison
2008-07-27ipcomp: Fix warnings after ipcomp consolidation.David S. Miller
net/ipv4/ipcomp.c: In function ‘ipcomp4_init_state’: net/ipv4/ipcomp.c:109: warning: unused variable ‘calg_desc’ net/ipv4/ipcomp.c:108: warning: unused variable ‘ipcd’ net/ipv4/ipcomp.c:107: warning: ‘err’ may be used uninitialized in this function net/ipv6/ipcomp6.c: In function ‘ipcomp6_init_state’: net/ipv6/ipcomp6.c:139: warning: unused variable ‘calg_desc’ net/ipv6/ipcomp6.c:138: warning: unused variable ‘ipcd’ net/ipv6/ipcomp6.c:137: warning: ‘err’ may be used uninitialized in this function Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-25ipsec: ipcomp - Merge IPComp implementationsHerbert Xu
This patch merges the IPv4/IPv6 IPComp implementations since most of the code is identical. As a result future enhancements will no longer need to be duplicated. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-18net: Remove unnecessary inclusions of asm/semaphore.hMatthew Wilcox
None of these files use any of the functionality promised by asm/semaphore.h. It's possible that they rely on it dragging in some unrelated header file, but I can't build all these files, so we'll have fix any build failures as they come up. Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
2008-02-28[IPCOMP]: Disable BH on output when using shared tfmHerbert Xu
Because we use shared tfm objects in order to conserve memory, (each tfm requires 128K of vmalloc memory), BH needs to be turned off on output as that can occur in process context. Previously this was done implicitly by the xfrm output code. That was lost when it became lockless. So we need to add the BH disabling to IPComp directly. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-31[XFRM]: constify 'struct xfrm_type'Eric Dumazet
Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-31[IPCOMP]: Fetch nexthdr before ipch is destroyedHerbert Xu
When I moved the nexthdr setting out of IPComp I accidently moved the reading of ipch->nexthdr after the decompression. Unfortunately this means that we'd be reading from a stale ipch pointer which doesn't work very well. This patch moves the reading up so that we get the correct nexthdr value. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[IPSEC]: Forbid BEET + ipcomp for nowHerbert Xu
While BEET can theoretically work with IPComp the current code can't do that because it tries to construct a BEET mode tunnel type which doesn't (and cannot) exist. In fact as it is it won't even attach a tunnel object at all for BEET which is bogus. To support this fully we'd also need to change the policy checks on input to recognise a plain tunnel as a legal variant of an optional BEET transform. This patch simply fails such constructions for now. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-11-07[IPSEC]: Fix crypto_alloc_comp error checkingHerbert Xu
The function crypto_alloc_comp returns an errno instead of NULL to indicate error. So it needs to be tested with IS_ERR. This is based on a patch by Vicenç Beltran Querol. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-11-02cleanup asm/scatterlist.h includesAdrian Bunk
Not architecture specific code should not #include <asm/scatterlist.h>. This patch therefore either replaces them with #include <linux/scatterlist.h> or simply removes them if they were unused. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-10-17[IPSEC]: Disallow combinations of RO and AH/ESP/IPCOMPHerbert Xu
Combining RO and AH/ESP/IPCOMP does not make sense. So this patch adds a check in the state initialisation function to prevent this. This allows us to safely remove the mode input function of RO since it can never be called anymore. Indeed, if somehow it does get called we'll know about it through an OOPS instead of it slipping past silently. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[IPSEC]: Move IP length/checksum setting out of transformsHerbert Xu
This patch moves the setting of the IP length and checksum fields out of the transforms and into the xfrmX_output functions. This would help future efforts in merging the transforms themselves. It also adds an optimisation to ipcomp due to the fact that the transport offset is guaranteed to be zero. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[IPSEC]: Get rid of ipv6_{auth,esp,comp}_hdrHerbert Xu
This patch removes the duplicate ipv6_{auth,esp,comp}_hdr structures since they're identical to the IPv4 versions. Duplicating them would only create problems for ourselves later when we need to add things like extended sequence numbers. I've also added transport header type conversion headers for these types which are now used by the transforms. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[IPSEC]: Set skb->data to payload in x->mode->outputHerbert Xu
This patch changes the calling convention so that on entry from x->mode->output and before entry into x->type->output skb->data will point to the payload instead of the IP header. This is essentially a redistribution of skb_push/skb_pull calls with the aim of minimising them on the common path of tunnel + ESP. It'll also let us use the same calling convention between IPv4 and IPv6 with the next patch. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[IPSEC]: Store IPv6 nh pointer in mac_header on outputHerbert Xu
Current the x->mode->output functions store the IPv6 nh pointer in the skb network header. This is inconvenient because the network header then has to be fixed up before the packet can leave the IPsec stack. The mac header field is unused on output so we can use that to store this instead. This patch does that and removes the network header fix-up in xfrm_output. It also uses ipv6_hdr where appropriate in the x->type->output functions. There is also a minor clean-up in esp4 to make it use the same code as esp6 to help any subsequent effort to merge the two. Lastly it kills two redundant skb_set_* statements in BEET that were simply copied over from transport mode. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[IPV6]: Remove unneeded pointer iph from ipcomp6_input() in net/ipv6/ipcomp6.cMicah Gruber
This trivial patch removes the unneeded pointer iph, which is never used. Signed-off-by: Micah Gruber <micah.gruber@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[XFRM]: Add module alias for transformation type.Masahide NAKAMURA
It is clean-up for XFRM type modules and adds aliases with its protocol: ESP, AH, IPCOMP, IPIP and IPv6 for IPsec ROUTING and DSTOPTS for MIPv6 It is almost the same thing as XFRM mode alias, but it is added new defines XFRM_PROTO_XXX for preprocessing since some protocols are defined as enum. Signed-off-by: Masahide NAKAMURA <nakam@linux-ipv6.org> Acked-by: Ingo Oeser <netdev@axxeo.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce skb_copy_to_linear_data{_offset}Arnaldo Carvalho de Melo
To clearly state the intent of copying to linear sk_buffs, _offset being a overly long variant but interesting for the sake of saving some bytes. Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net>
2007-04-25[SK_BUFF]: unions of just one member don't get anything done, kill themArnaldo Carvalho de Melo
Renaming skb->h to skb->transport_header, skb->nh to skb->network_header and skb->mac to skb->mac_header, to match the names of the associated helpers (skb[_[re]set]_{transport,network,mac}_header). Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce skb_transport_header(skb)Arnaldo Carvalho de Melo
For the places where we need a pointer to the transport header, it is still legal to touch skb->h.raw directly if just adding to, subtracting from or setting it to another layer header. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce skb_transport_offset()Arnaldo Carvalho de Melo
For the quite common 'skb->h.raw - skb->data' sequence. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce ipv6_hdr(), remove skb->nh.ipv6hArnaldo Carvalho de Melo
Now the skb->nh union has just one member, .raw, i.e. it is just like the skb->mac union, strange, no? I'm just leaving it like that till the transport layer is done with, when we'll rename skb->mac.raw to skb->mac_header (or ->mac_header_offset?), ditto for ->{h,nh}. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce skb_network_header()Arnaldo Carvalho de Melo
For the places where we need a pointer to the network header, it is still legal to touch skb->nh.raw directly if just adding to, subtracting from or setting it to another layer header. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-10[NET] IPV6: Fix whitespace errors.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[IPV6]: 'info' argument of ipv6 ->err_handler() is net-endianAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-04[XFRM]: BEET modeDiego Beltrami
This patch introduces the BEET mode (Bound End-to-End Tunnel) with as specified by the ietf draft at the following link: http://www.ietf.org/internet-drafts/draft-nikander-esp-beet-mode-06.txt The patch provides only single family support (i.e. inner family = outer family). Signed-off-by: Diego Beltrami <diego.beltrami@gmail.com> Signed-off-by: Miika Komu <miika@iki.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Abhinav Pathak <abhinav.pathak@hiit.fi> Signed-off-by: Jeff Ahrenholz <ahrenholz@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-28[XFRM]: xfrm_state_lookup() annotationsAl Viro
spi argument of xfrm_state_lookup() is net-endian Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[XFRM] STATE: Add a hook to find offset to be inserted header in outbound.Masahide NAKAMURA
On current kernel, ip6_find_1stfragopt() is used by IPv6 IPsec to find offset to be inserted header in outbound for transport mode. (BTW, no usage may be needed for IPv4 case.) Mobile IPv6 requires another logic for routing header and destination options header respectively. This patch is common platform for the offset and adopts it to IPsec. Based on MIPL2 kernel patch. Signed-off-by: Masahide NAKAMURA <nakam@linux-ipv6.org> Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[XFRM]: Add XFRM_MODE_xxx for future use.Masahide NAKAMURA
Transformation mode is used as either IPsec transport or tunnel. It is required to add two more items, route optimization and inbound trigger for Mobile IPv6. Based on MIPL2 kernel patch. This patch was also written by: Ville Nuorvala <vnuorval@tcs.hut.fi> Signed-off-by: Masahide NAKAMURA <nakam@linux-ipv6.org> Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-21[CRYPTO] users: Use crypto_comp and crypto_has_*Herbert Xu
This patch converts all users to use the new crypto_comp type and the crypto_has_* functions. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2006-07-12[IPCOMP]: Fix truesize after decompressionHerbert Xu
The truesize check has uncovered the fact that we forgot to update truesize after pskb_expand_head. Unfortunately pskb_expand_head can't update it for us because it's used in all sorts of different contexts, some of which would not allow truesize to be updated by itself. So the solution for now is to simply update it in IPComp. This patch also changes skb_put to __skb_put since we've just expanded tailroom by exactly that amount so we know it's there (but gcc does not). Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-17[NET]: Clean up skb_linearizeHerbert Xu
The linearisation operation doesn't need to be super-optimised. So we can replace __skb_linearize with __pskb_pull_tail which does the same thing but is more general. Also, most users of skb_linearize end up testing whether the skb is linear or not so it helps to make skb_linearize do just that. Some callers of skb_linearize also use it to copy cloned data, so it's useful to have a new function skb_linearize_cow to copy the data if it's either non-linear or cloned. Last but not least, I've removed the gfp argument since nobody uses it anymore. If it's ever needed we can easily add it back. Misc bugs fixed by this patch: * via-velocity error handling (also, no SG => no frags) Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-17[IPSEC] proto: Move transport mode input path into xfrm_mode_transportHerbert Xu
Now that we have xfrm_mode objects we can move the transport mode specific input decapsulation code into xfrm_mode_transport. This removes duplicate code as well as unnecessary header movement in case of tunnel mode SAs since we will discard the original IP header immediately. This also fixes a minor bug for transport-mode ESP where the IP payload length is set to the correct value minus the header length (with extension headers for IPv6). Of course the other neat thing is that we no longer have to allocate temporary buffers to hold the IP headers for ESP and IPComp. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-05-22[NET]: Fix "ntohl(ntohs" bugsAlexey Dobriyan
2006-04-11[PATCH] for_each_possible_cpu: network codesKAMEZAWA Hiroyuki
for_each_cpu() actually iterates across all possible CPUs. We've had mistakes in the past where people were using for_each_cpu() where they should have been iterating across only online or present CPUs. This is inefficient and possibly buggy. We're renaming for_each_cpu() to for_each_possible_cpu() to avoid this in the future. This patch replaces for_each_cpu with for_each_possible_cpu under /net Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-01[IPSEC]: Kill unused decap state argumentHerbert Xu
This patch removes the decap_state argument from the xfrm input hook. Previously this function allowed the input hook to share state with the post_input hook. The latter has since been removed. The only purpose for it now is to check the encap type. However, it is easier and better to move the encap type check to the generic xfrm_rcv function. This allows us to get rid of the decap state argument altogether. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-26[IPSEC]: Fix tunnel error handling in ipcomp6Herbert Xu
The error handling in ipcomp6_tunnel_create is broken in two ways: 1) If we fail to allocate an SPI (this should never happen in practice since there are plenty of 32-bit SPI values for us to use), we will still go ahead and create the SA. 2) When xfrm_init_state fails, we first of all may trigger the BUG_TRAP in __xfrm_state_destroy because we didn't set the state to DEAD. More importantly we end up returning the freed state as if we succeeded! This patch fixes them both. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[IPV6]: Nearly complete kzalloc cleanup for net/ipv6Ingo Oeser
Stupidly use kzalloc() instead of kmalloc()/memset() everywhere where this is possible in net/ipv6/*.c . Signed-off-by: Ingo Oeser <ioe-lkml@rameria.de> Signed-off-by: David S. Miller <davem@davemloft.net>
