[ Upstream commit dc012f3628eaecfb5ba68404a5c30ef501daf63d ]
syzbot found a use-after-free in inet6_mc_check [1]
The problem here is that inet6_mc_check() uses rcu
and read_lock(&iml->sflock)
So the fact that ip6_mc_leave_src() is called under RTNL
and the socket lock does not help us, we need to acquire
iml->sflock in write mode.
In the future, we should convert all this stuff to RCU.
[1]
BUG: KASAN: use-after-free in ipv6_addr_equal include/net/ipv6.h:521 [inline]
BUG: KASAN: use-after-free in inet6_mc_check+0xae7/0xb40 net/ipv6/mcast.c:649
Read of size 8 at addr ffff8801ce7f2510 by task syz-executor0/22432
CPU: 1 PID: 22432 Comm: syz-executor0 Not tainted 4.19.0-rc7+ #280
Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011
Call Trace:
__dump_stack lib/dump_stack.c:77 [inline]
dump_stack+0x1c4/0x2b4 lib/dump_stack.c:113
print_address_description.cold.8+0x9/0x1ff mm/kasan/report.c:256
kasan_report_error mm/kasan/report.c:354 [inline]
kasan_report.cold.9+0x242/0x309 mm/kasan/report.c:412
__asan_report_load8_noabort+0x14/0x20 mm/kasan/report.c:433
__raw_v6_lookup+0x320/0x3f0 net/ipv6/raw.c:98
ipv6_raw_deliver net/ipv6/raw.c:183 [inline]
raw6_local_deliver+0x3d3/0xcb0 net/ipv6/raw.c:240
ip6_input_finish+0x467/0x1aa0 net/ipv6/ip6_input.c:345
NF_HOOK include/linux/netfilter.h:289 [inline]
ip6_input+0xe9/0x600 net/ipv6/ip6_input.c:426
ip6_mc_input+0x48a/0xd20 net/ipv6/ip6_input.c:503
dst_input include/net/dst.h:450 [inline]
ip6_rcv_finish+0x17a/0x330 net/ipv6/ip6_input.c:76
ipv6_rcv+0x120/0x640 net/ipv6/ip6_input.c:271
__netif_receive_skb_one_core+0x14d/0x200 net/core/dev.c:4913
__netif_receive_skb+0x2c/0x1e0 net/core/dev.c:5023
netif_receive_skb_internal+0x12c/0x620 net/core/dev.c:5126
napi_frags_finish net/core/dev.c:5664 [inline]
napi_gro_frags+0x75a/0xc90 net/core/dev.c:5737
tun_get_user+0x3189/0x4250 drivers/net/tun.c:1923
tun_chr_write_iter+0xb9/0x154 drivers/net/tun.c:1968
call_write_iter include/linux/fs.h:1808 [inline]
do_iter_readv_writev+0x8b0/0xa80 fs/read_write.c:680
do_iter_write+0x185/0x5f0 fs/read_write.c:959
vfs_writev+0x1f1/0x360 fs/read_write.c:1004
do_writev+0x11a/0x310 fs/read_write.c:1039
__do_sys_writev fs/read_write.c:1112 [inline]
__se_sys_writev fs/read_write.c:1109 [inline]
__x64_sys_writev+0x75/0xb0 fs/read_write.c:1109
do_syscall_64+0x1b9/0x820 arch/x86/entry/common.c:290
entry_SYSCALL_64_after_hwframe+0x49/0xbe
RIP: 0033:0x457421
Code: 75 14 b8 14 00 00 00 0f 05 48 3d 01 f0 ff ff 0f 83 34 b5 fb ff c3 48 83 ec 08 e8 1a 2d 00 00 48 89 04 24 b8 14 00 00 00 0f 05 <48> 8b 3c 24 48 89 c2 e8 63 2d 00 00 48 89 d0 48 83 c4 08 48 3d 01
RSP: 002b:00007f2d30ecaba0 EFLAGS: 00000293 ORIG_RAX: 0000000000000014
RAX: ffffffffffffffda RBX: 000000000000003e RCX: 0000000000457421
RDX: 0000000000000001 RSI: 00007f2d30ecabf0 RDI: 00000000000000f0
RBP: 0000000020000500 R08: 00000000000000f0 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000293 R12: 00007f2d30ecb6d4
R13: 00000000004c4890 R14: 00000000004d7b90 R15: 00000000ffffffff
Allocated by task 22437:
save_stack+0x43/0xd0 mm/kasan/kasan.c:448
set_track mm/kasan/kasan.c:460 [inline]
kasan_kmalloc+0xc7/0xe0 mm/kasan/kasan.c:553
__do_kmalloc mm/slab.c:3718 [inline]
__kmalloc+0x14e/0x760 mm/slab.c:3727
kmalloc include/linux/slab.h:518 [inline]
sock_kmalloc+0x15a/0x1f0 net/core/sock.c:1983
ip6_mc_source+0x14dd/0x1960 net/ipv6/mcast.c:427
do_ipv6_setsockopt.isra.9+0x3afb/0x45d0 net/ipv6/ipv6_sockglue.c:743
ipv6_setsockopt+0xbd/0x170 net/ipv6/ipv6_sockglue.c:933
rawv6_setsockopt+0x59/0x140 net/ipv6/raw.c:1069
sock_common_setsockopt+0x9a/0xe0 net/core/sock.c:3038
__sys_setsockopt+0x1ba/0x3c0 net/socket.c:1902
__do_sys_setsockopt net/socket.c:1913 [inline]
__se_sys_setsockopt net/socket.c:1910 [inline]
__x64_sys_setsockopt+0xbe/0x150 net/socket.c:1910
Freed by task 22430:
__kasan_slab_free+0x102/0x150 mm/kasan/kasan.c:521
kasan_slab_free+0xe/0x10 mm/kasan/kasan.c:528
__cache_free mm/slab.c:3498 [inline]
kfree+0xcf/0x230 mm/slab.c:3813
__sock_kfree_s net/core/sock.c:2004 [inline]
sock_kfree_s+0x29/0x60 net/core/sock.c:2010
ip6_mc_leave_src+0x11a/0x1d0 net/ipv6/mcast.c:2448
__ipv6_sock_mc_close+0x20b/0x4e0 net/ipv6/mcast.c:310
ipv6_sock_mc_close+0x158/0x1d0 net/ipv6/mcast.c:328
inet6_release+0x40/0x70 net/ipv6/af_inet6.c:452
__sock_release+0xd7/0x250 net/socket.c:579
sock_close+0x19/0x20 net/socket.c:1141
__fput+0x385/0xa30 fs/file_table.c:278
____fput+0x15/0x20 fs/file_table.c:309
task_work_run+0x1e8/0x2a0 kernel/task_work.c:113
tracehook_notify_resume include/linux/tracehook.h:193 [inline]
exit_to_usermode_loop+0x318/0x380 arch/x86/entry/common.c:166
prepare_exit_to_usermode arch/x86/entry/common.c:197 [inline]
syscall_return_slowpath arch/x86/entry/common.c:268 [inline]
do_syscall_64+0x6be/0x820 arch/x86/entry/common.c:293
The buggy address belongs to the object at ffff8801ce7f2500
which belongs to the cache kmalloc-192 of size 192
The buggy address is located 16 bytes inside of
192-byte region [ffff8801ce7f2500, ffff8801ce7f25c0)
The buggy address belongs to the page:
page:ffffea000739fc80 count:1 mapcount:0 mapping:ffff8801da800040 index:0x0
flags: 0x2fffc0000000100(slab)
raw: 02fffc0000000100 ffffea0006f6e548 ffffea000737b948 ffff8801da800040
raw: 0000000000000000 ffff8801ce7f2000 0000000100000010 0000000000000000
page dumped because: kasan: bad access detected
Memory state around the buggy address:
ffff8801ce7f2400: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
ffff8801ce7f2480: fb fb fb fb fb fb fb fb fc fc fc fc fc fc fc fc
>ffff8801ce7f2500: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
ffff8801ce7f2580: fb fb fb fb fb fb fb fb fc fc fc fc fc fc fc fc
ffff8801ce7f2600: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Reported-by: syzbot <syzkaller@googlegroups.com>
[ Upstream commit 6c6da92808442908287fae8ebb0ca041a52469f4 ]
After recieving MLD querys, we update idev->mc_maxdelay with max_delay
from query header. This make the later unsolicited reports have the same
interval with mc_maxdelay, which means we may send unsolicited reports with
long interval time instead of default configured interval time.
Also as we will not call ipv6_mc_reset() after device up. This issue will
be there even after leave the group and join other groups.
Fixes: fc4eba58b4c14 ("ipv6: make unsolicited report intervals configurable for mld")
Signed-off-by: Hangbin Liu <liuhangbin@gmail.com>
There are two scenarios that we will restore deleted records. The first is
when device down and up(or unmap/remap). In this scenario the new filter
mode is same with previous one. Because we get it from in_dev->mc_list and
we do not touch it during device down and up.
The other scenario is when a new socket join a group which was just delete
and not finish sending status reports. In this scenario, we should use the
current filter mode instead of restore old one. Here are 4 cases in total.
old_socket new_socket before_fix after_fix
IN(A) IN(A) ALLOW(A) ALLOW(A)
IN(A) EX( ) TO_IN( ) TO_EX( )
EX( ) IN(A) TO_EX( ) ALLOW(A)
EX( ) EX( ) TO_EX( ) TO_EX( )
Fixes: 24803f38a5c0b (igmp: do not remove igmp souce list info when set link down)
Fixes: 1666d49e1d416 (mld: do not remove mld souce list info when set link down)
[ Upstream commit b9b312a7a451e9c098921856e7cfbc201120e1a7 ]
syzkaller reported crashes in IPv6 stack [1]
Xin Long found that lo MTU was set to silly values.
IPv6 stack reacts to changes to small MTU, by disabling itself under
RTNL.
But there is a window where threads not using RTNL can see a wrong
device mtu. This can lead to surprises, in mld code where it is assumed
the mtu is suitable.
Fix this by reading device mtu once and checking IPv6 minimal MTU.
[1]
skbuff: skb_over_panic: text:0000000010b86b8d len:196 put:20
head:000000003b477e60 data:000000000e85441e tail:0xd4 end:0xc0 dev:lo
kernel BUG at net/core/skbuff.c:104!
invalid opcode: 0000 [#1] SMP KASAN
Dumping ftrace buffer:
(ftrace buffer empty)
Modules linked in:
CPU: 1 PID: 0 Comm: swapper/1 Not tainted 4.15.0-rc2-mm1+ #39
Google 01/01/2011
RIP: 0010:skb_panic+0x15c/0x1f0 net/core/skbuff.c:100
RSP: 0018:ffff8801db307508 EFLAGS: 00010286
RAX: 0000000000000082 RBX: ffff8801c517e840 RCX: 0000000000000000
RDX: 0000000000000082 RSI: 1ffff1003b660e61 RDI: ffffed003b660e95
RBP: ffff8801db307570 R08: 1ffff1003b660e23 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000000 R12: ffffffff85bd4020
R13: ffffffff84754ed2 R14: 0000000000000014 R15: ffff8801c4e26540
FS: 0000000000000000(0000) GS:ffff8801db300000(0000) knlGS:0000000000000000
CR2: 0000000000463610 CR3: 00000001c6698000 CR4: 00000000001406e0
DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400
Call Trace:
<IRQ>
skb_over_panic net/core/skbuff.c:109 [inline]
skb_put+0x181/0x1c0 net/core/skbuff.c:1694
add_grhead.isra.24+0x42/0x3b0 net/ipv6/mcast.c:1695
add_grec+0xa55/0x1060 net/ipv6/mcast.c:1817
mld_send_cr net/ipv6/mcast.c:1903 [inline]
mld_ifc_timer_expire+0x4d2/0x770 net/ipv6/mcast.c:2448
call_timer_fn+0x23b/0x840 kernel/time/timer.c:1320
expire_timers kernel/time/timer.c:1357 [inline]
__run_timers+0x7e1/0xb60 kernel/time/timer.c:1660
run_timer_softirq+0x4c/0xb0 kernel/time/timer.c:1686
__do_softirq+0x29d/0xbb2 kernel/softirq.c:285
invoke_softirq kernel/softirq.c:365 [inline]
irq_exit+0x1d3/0x210 kernel/softirq.c:405
exiting_irq arch/x86/include/asm/apic.h:540 [inline]
smp_apic_timer_interrupt+0x16b/0x700 arch/x86/kernel/apic/apic.c:1052
apic_timer_interrupt+0xa9/0xb0 arch/x86/entry/entry_64.S:920
Tested-by: Xin Long <lucien.xin@gmail.com>
refcount_t type and corresponding API should be
used instead of atomic_t when the variable is used as
a reference counter. This allows to avoid accidental
refcounter overflows that might lead to use-after-free
situations.
Signed-off-by: Elena Reshetova <elena.reshetova@intel.com>
Signed-off-by: Hans Liljestrand <ishkamiel@gmail.com>
Signed-off-by: David Windsor <dwindsor@gmail.com>
It seems like a historic accident that these return unsigned char *,
and in many places that means casts are required, more often than not.
Make these functions (skb_put, __skb_put and pskb_put) return void *
and remove all the casts across the tree, adding a (u8 *) cast only
where the unsigned char pointer was used directly, all done with the
following spatch:
expression SKB, LEN;
typedef u8;
identifier fn = { skb_put, __skb_put };
- *(fn(SKB, LEN))
+ *(u8 *)fn(SKB, LEN)
expression E, SKB, LEN;
type T;
- E = ((T *)(fn(SKB, LEN)))
+ E = fn(SKB, LEN)
which actually doesn't cover pskb_put since there are only three
users overall.
A handful of stragglers were converted manually, notably a macro in
drivers/isdn/i4l/isdn_bsdcomp.c and, oddly enough, one of the many
instances in net/bluetooth/hci_sock.c. In the former file, I also
had to fix one whitespace problem spatch introduced.
A common pattern with skb_put() is to just want to memcpy()
some data into the new space, introduce skb_put_data() for
this.
An spatch similar to the one for skb_put_zero() converts many
of the places using it:
identifier p, p2;
expression len, skb, data;
type t, t2;
-p = skb_put(skb, len);
+p = skb_put_data(skb, data, len);
-p = (t)skb_put(skb, len);
p2 = (t2)p;
-memcpy(p2, data, len);
-memcpy(p, data, len);
type t, t2;
identifier p, p2;
expression skb, data;
t *p;
-p = skb_put(skb, sizeof(t));
+p = skb_put_data(skb, data, sizeof(t));
-p = (t *)skb_put(skb, sizeof(t));
p2 = (t2)p;
-memcpy(p2, data, sizeof(*p));
-memcpy(p, data, sizeof(*p));
expression skb, len, data;
-memcpy(skb_put(skb, len), data, len);
+skb_put_data(skb, data, len);
(again, manually post-processed to retain some comments)
Reviewed-by: Stephen Hemminger <stephen@networkplumber.org>
There were many places that my previous spatch didn't find,
as pointed out by yuan linyu in various patches.
The following spatch found many more and also removes the
now unnecessary casts:
identifier p, p2;
expression len;
expression skb;
type t, t2;
+p = skb_put_zero(skb, len);
... when != p
p2 = (t2)p;
-memset(p2, 0, len);
-memset(p, 0, len);
type t, t2;
identifier p, p2;
expression skb;
t *p;
+p = skb_put_zero(skb, sizeof(t));
... when != p
p2 = (t2)p;
-memset(p2, 0, sizeof(*p));
-memset(p, 0, sizeof(*p));
expression skb, len;
-memset(skb_put(skb, len), 0, len);
+skb_put_zero(skb, len);
Apply it to the tree (with one manual fixup to keep the
comment in vxlan.c, which spatch removed.)
This patch adds support for NETDEV_RESEND_IGMP event similar
to how it works for IPv4.
Signed-off-by: Vladislav Yasevich <vyasevic@redhat.com>
In function igmpv3/mld_add_delrec() we allocate pmc and put it in
idev->mc_tomb, so we should free it when we don't need it in del_delrec().
But I removed kfree(pmc) incorrectly in latest two patches. Now fix it.
Fixes: 24803f38a5c0 ("igmp: do not remove igmp souce list info when ...")
Fixes: 1666d49e1d41 ("mld: do not remove mld souce list info when ...")
Reported-by: Daniel Borkmann <daniel@iogearbox.net>
This is an IPv6 version of commit 24803f38a5c0 ("igmp: do not remove igmp
souce list..."). In mld_del_delrec(), we will restore back all source filter
info instead of flush them.
Move mld_clear_delrec() from ipv6_mc_down() to ipv6_mc_destroy_dev() since
we should not remove source list info when set link down. Remove
igmp6_group_dropped() in ipv6_mc_destroy_dev() since we have called it in
ipv6_mc_down().
Also clear all source info after igmp6_group_dropped() instead of in it
because ipv6_mc_down() will call igmp6_group_dropped().
Baozeng reported this deadlock case:
CPU0 CPU1
lock([ 165.136033] sk_lock-AF_INET6);
lock([ 165.136033] rtnl_mutex);
Similar to commit 87e9f0315952
("ipv4: fix a potential deadlock in mcast getsockopt() path")
this is due to we still have a case, ipv6_sock_mc_close(),
where we acquire sk_lock before rtnl_lock. Close this deadlock
with the similar solution, that is always acquire rtnl lock first.
Fixes: baf606d9c9b1 ("ipv4,ipv6: grab rtnl before locking the socket")
Reported-by: Baozeng Ding <sploving1@gmail.com>
Tested-by: Baozeng Ding <sploving1@gmail.com>
Cc: Marcelo Ricardo Leitner <marcelo.leitner@gmail.com>
Reviewed-by: Marcelo Ricardo Leitner <marcelo.leitner@gmail.com>
Based on RFC3376 5.1 and RFC3810 6.1
If the per-interface listening change that triggers the new report is
a filter mode change, then the next [Robustness Variable] State
Change Reports will include a Filter Mode Change Record. This
applies even if any number of source list changes occur in that
period.
Old State New State State Change Record Sent
INCLUDE (A) EXCLUDE (B) TO_EX (B)
EXCLUDE (A) INCLUDE (B) TO_IN (B)
So we should not send source-list change if there is a filter-mode change.
Here are two scenarios:
1. Group deleted and filter mode is EXCLUDE, which means we need send a
TO_IN { }.
2. Not group deleted, but has pcm->crcount, which means we need send a
normal filter-mode-change.
At the same time, if the type is ALLOW or BLOCK, and have psf->sf_crcount,
we stop add records and decrease sf_crcount directly
Reference: https://www.ietf.org/mail-archive/web/magma/current/msg01274.html
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
The current reserved_tailroom calculation fails to take hlen and tlen into
account.
skb:
[__hlen__|__data____________|__tlen___|__extra__]
head skb_end_offset
In this representation, hlen + data + tlen is the size passed to alloc_skb.
"extra" is the extra space made available in __alloc_skb because of
rounding up by kmalloc. We can reorder the representation like so:
[__hlen__|__data____________|__extra__|__tlen___]
head skb_end_offset
The maximum space available for ip headers and payload without
fragmentation is min(mtu, data + extra). Therefore,
reserved_tailroom
= data + extra + tlen - min(mtu, data + extra)
= skb_end_offset - hlen - min(mtu, skb_end_offset - hlen - tlen)
= skb_tailroom - min(mtu, skb_tailroom - tlen) ; after skb_reserve(hlen)
Compare the second line to the current expression:
reserved_tailroom = skb_end_offset - min(mtu, skb_end_offset)
and we can see that hlen and tlen are not taken into account.
The min() in the third line can be expanded into:
if mtu < skb_tailroom - tlen:
reserved_tailroom = skb_tailroom - mtu
else:
reserved_tailroom = tlen
Depending on hlen, tlen, mtu and the number of multicast address records,
the current code may output skbs that have less tailroom than
dev->needed_tailroom or it may output more skbs than needed because not all
space available is used.
Fixes: 4c672e4b ("ipv6: mld: fix add_grhead skb_over_panic for devs with large MTUs")
Signed-off-by: Benjamin Poirier <bpoirier@suse.com>
Acked-by: Daniel Borkmann <daniel@iogearbox.net>
the OUTMCAST stat is double incremented, getting bumped once in the mcast code
itself, and again in the common ip output path. Remove the mcast bump, as its
not needed
Validated by the reporter, with good results
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
Reported-by: Claus Jensen <claus.jensen@microsemi.com>
CC: Claus Jensen <claus.jensen@microsemi.com>
CC: David Miller <davem@davemloft.net>
Replace dst_output_okfn with dst_output
This is immediately motivated by the bridge code that chains functions that
call into netfilter. Without passing net into the okfns the bridge code would
need to guess about the best expression for the network namespace to process
packets in.
As net is frequently one of the first things computed in continuation functions
after netfilter has done it's job passing in the desired network namespace is in
many cases a code simplification.
To support this change the function dst_output_okfn is introduced to
simplify passing dst_output as an okfn. For the moment dst_output_okfn
just silently drops the struct net.
Pass a network namespace parameter into the netfilter hooks. At the
call site of the netfilter hooks the path a packet is taking through
the network stack is well known which allows the network namespace to
be easily and reliabily.
This allows the replacement of magic code like
"dev_net(state->in?:state->out)" that appears at the start of most
netfilter hooks with "state->net".
In almost all cases the network namespace passed in is derived
from the first network device passed in, guaranteeing those
paths will not see any changes in practice.
The exceptions are:
xfrm/xfrm_output.c:xfrm_output_resume() xs_net(skb_dst(skb)->xfrm)
ipvs/ip_vs_xmit.c:ip_vs_nat_send_or_cont() ip_vs_conn_net(cp)
ipvs/ip_vs_xmit.c:ip_vs_send_or_cont() ip_vs_conn_net(cp)
ipv4/raw.c:raw_send_hdrinc() sock_net(sk)
ipv6/ip6_output.c:ip6_xmit() sock_net(sk)
ipv6/ndisc.c:ndisc_send_skb() dev_net(skb->dev) not dev_net(dst->dev)
ipv6/raw.c:raw6_send_hdrinc() sock_net(sk)
br_netfilter_hooks.c:br_nf_pre_routing_finish() dev_net(skb->dev) before skb->dev is set to nf_bridge->physindev
In all cases these exceptions seem to be a better expression for the
network namespace the packet is being processed in then the historic
"dev_net(in?in:out)". I am documenting them in case something odd
pops up and someone starts trying to track down what happened.
Add a sock paramter to dst_output making dst_output_sk superfluous.
Add a skb->sk parameter to all of the callers of dst_output
Have the callers of dst_output_sk call dst_output.
On the output paths in particular, we have to sometimes deal with two
socket contexts. First, and usually skb->sk, is the local socket that
generated the frame.
And second, is potentially the socket used to control a tunneling
socket, such as one the encapsulates using UDP.
We do not want to disassociate skb->sk when encapsulating in order
to fix this, because that would break socket memory accounting.
The most extreme case where this can cause huge problems is an
AF_PACKET socket transmitting over a vxlan device. We hit code
paths doing checks that assume they are dealing with an ipv4
socket, but are actually operating upon the AF_PACKET one.
The ipv6 code uses a mixture of coding styles. In some instances check for NULL
pointer is done as x != NULL and sometimes as x. x is preferred according to
checkpatch and this patch makes the code consistent by adopting the latter
form.
No changes detected by objdiff.
Signed-off-by: Ian Morris <ipm@chirality.org.uk>
pointer is done as x == NULL and sometimes as !x. !x is preferred according to
form.
in favor of their inner __ ones, which doesn't grab rtnl.
As these functions need to operate on a locked socket, we can't be
grabbing rtnl by then. It's too late and doing so causes reversed
locking.
So this patch:
- move rtnl handling to callers instead while already fixing some
reversed locking situations, like on vxlan and ipvs code.
- renames __ ones to not have the __ mark:
__ip_mc_{join,leave}_group -> ip_mc_{join,leave}_group
__ipv6_sock_mc_{join,drop} -> ipv6_sock_mc_{join,drop}
Signed-off-by: Marcelo Ricardo Leitner <marcelo.leitner@gmail.com>
Joining multicast group on ethernet level via "ip maddr" command would
not work if we have an Ethernet switch that does igmp snooping since
the switch would not replicate multicast packets on ports that did not
have IGMP reports for the multicast addresses.
Linux vxlan interfaces created via "ip link add vxlan" have the group option
that enables then to do the required join.
By extending ip address command with option "autojoin" we can get similar
functionality for openvswitch vxlan interfaces as well as other tunneling
mechanisms that need to receive multicast traffic. The kernel code is
structured similar to how the vxlan driver does a group join / leave.
example:
ip address add 224.1.1.10/24 dev eth5 autojoin
ip address del 224.1.1.10/24 dev eth5
Signed-off-by: Madhu Challa <challa@noironetworks.com>
Based on the igmp v4 changes from Eric Dumazet.
959d10f6bbf6("igmp: add __ip_mc_{join|leave}_group()")
These changes are needed to perform igmp v6 join/leave while
RTNL is held.
Make ipv6_sock_mc_join and ipv6_sock_mc_drop wrappers around
__ipv6_sock_mc_join and __ipv6_sock_mc_drop to avoid
proliferation of work queues.
It has been reported that generating an MLD listener report on
devices with large MTUs (e.g. 9000) and a high number of IPv6
addresses can trigger a skb_over_panic():
skbuff: skb_over_panic: text:ffffffff80612a5d len:3776 put:20
head:ffff88046d751000 data:ffff88046d751010 tail:0xed0 end:0xec0
dev:port1
kernel BUG at net/core/skbuff.c:100!
Modules linked in: ixgbe(O)
CPU: 3 PID: 0 Comm: swapper/3 Tainted: G O 3.14.23+ #4
Call Trace:
<IRQ>
[<ffffffff80578226>] ? skb_put+0x3a/0x3b
[<ffffffff80612a5d>] ? add_grhead+0x45/0x8e
[<ffffffff80612e3a>] ? add_grec+0x394/0x3d4
[<ffffffff80613222>] ? mld_ifc_timer_expire+0x195/0x20d
[<ffffffff8061308d>] ? mld_dad_timer_expire+0x45/0x45
[<ffffffff80255b5d>] ? call_timer_fn.isra.29+0x12/0x68
[<ffffffff80255d16>] ? run_timer_softirq+0x163/0x182
[<ffffffff80250e6f>] ? __do_softirq+0xe0/0x21d
[<ffffffff8025112b>] ? irq_exit+0x4e/0xd3
[<ffffffff802214bb>] ? smp_apic_timer_interrupt+0x3b/0x46
[<ffffffff8063f10a>] ? apic_timer_interrupt+0x6a/0x70
mld_newpack() skb allocations are usually requested with dev->mtu
in size, since commit 72e09ad107e7 ("ipv6: avoid high order allocations")
we have changed the limit in order to be less likely to fail.
However, in MLD/IGMP code, we have some rather ugly AVAILABLE(skb)
macros, which determine if we may end up doing an skb_put() for
adding another record. To avoid possible fragmentation, we check
the skb's tailroom as skb->dev->mtu - skb->len, which is a wrong
assumption as the actual max allocation size can be much smaller.
The IGMP case doesn't have this issue as commit 57e1ab6eaddc
("igmp: refine skb allocations") stores the allocation size in
the cb[].
Set a reserved_tailroom to make it fit into the MTU and use
skb_availroom() helper instead. This also allows to get rid of
igmp_skb_size().
Reported-by: Wei Liu <lw1a2.jing@gmail.com>
Fixes: 72e09ad107e7 ("ipv6: avoid high order allocations")
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
Cc: Eric Dumazet <edumazet@google.com>
Cc: Hannes Frederic Sowa <hannes@stressinduktion.org>
Cc: David L Stevens <david.stevens@oracle.com>
Using a single fixed string is smaller code size than using
a format and many string arguments.
Reduces overall code size a little.
$ size net/ipv4/igmp.o* net/ipv6/mcast.o* net/ipv6/ip6_flowlabel.o*
34269 7012 14824 56105 db29 net/ipv4/igmp.o.new
34315 7012 14824 56151 db57 net/ipv4/igmp.o.old
30078 7869 13200 51147 c7cb net/ipv6/mcast.o.new
30105 7869 13200 51174 c7e6 net/ipv6/mcast.o.old
11434 3748 8580 23762 5cd2 net/ipv6/ip6_flowlabel.o.new
11491 3748 8580 23819 5d0b net/ipv6/ip6_flowlabel.o.old
RFC2710 (MLDv1), section 3.7. says:
The length of a received MLD message is computed by taking the
IPv6 Payload Length value and subtracting the length of any IPv6
extension headers present between the IPv6 header and the MLD
message. If that length is greater than 24 octets, that indicates
that there are other fields present *beyond* the fields described
above, perhaps belonging to a *future backwards-compatible* version
of MLD. An implementation of the version of MLD specified in this
document *MUST NOT* send an MLD message longer than 24 octets and
MUST ignore anything past the first 24 octets of a received MLD
message.
RFC3810 (MLDv2), section 8.2.1. states for *listeners* regarding
presence of MLDv1 routers:
In order to be compatible with MLDv1 routers, MLDv2 hosts MUST
operate in version 1 compatibility mode. [...] When Host
Compatibility Mode is MLDv2, a host acts using the MLDv2 protocol
on that interface. When Host Compatibility Mode is MLDv1, a host
acts in MLDv1 compatibility mode, using *only* the MLDv1 protocol,
on that interface. [...]
While section 8.3.1. specifies *router* behaviour regarding presence
of MLDv1 routers:
MLDv2 routers may be placed on a network where there is at least
one MLDv1 router. The following requirements apply:
If an MLDv1 router is present on the link, the Querier MUST use
the *lowest* version of MLD present on the network. This must be
administratively assured. Routers that desire to be compatible
with MLDv1 MUST have a configuration option to act in MLDv1 mode;
if an MLDv1 router is present on the link, the system administrator
must explicitly configure all MLDv2 routers to act in MLDv1 mode.
When in MLDv1 mode, the Querier MUST send periodic General Queries
truncated at the Multicast Address field (i.e., 24 bytes long),
and SHOULD also warn about receiving an MLDv2 Query (such warnings
must be rate-limited). The Querier MUST also fill in the Maximum
Response Delay in the Maximum Response Code field, i.e., the
exponential algorithm described in section 5.1.3. is not used. [...]
That means that we should not get queries from different versions of
MLD. When there's a MLDv1 router present, MLDv2 enforces truncation
and MRC == MRD (both fields are overlapping within the 24 octet range).
Section 8.3.2. specifies behaviour in the presence of MLDv1 multicast
address *listeners*:
MLDv2 routers may be placed on a network where there are hosts
that have not yet been upgraded to MLDv2. In order to be compatible
with MLDv1 hosts, MLDv2 routers MUST operate in version 1 compatibility
mode. MLDv2 routers keep a compatibility mode per multicast address
record. The compatibility mode of a multicast address is determined
from the Multicast Address Compatibility Mode variable, which can be
in one of the two following states: MLDv1 or MLDv2.
The Multicast Address Compatibility Mode of a multicast address
record is set to MLDv1 whenever an MLDv1 Multicast Listener Report is
*received* for that multicast address. At the same time, the Older
Version Host Present timer for the multicast address is set to Older
Version Host Present Timeout seconds. The timer is re-set whenever a
new MLDv1 Report is received for that multicast address. If the Older
Version Host Present timer expires, the router switches back to
Multicast Address Compatibility Mode of MLDv2 for that multicast
address. [...]
That means, what can happen is the following scenario, that hosts can
act in MLDv1 compatibility mode when they previously have received an
MLDv1 query (or, simply operate in MLDv1 mode-only); and at the same
time, an MLDv2 router could start up and transmits MLDv2 startup query
messages while being unaware of the current operational mode.
Given RFC2710, section 3.7 we would need to answer to that with an MLDv1
listener report, so that the router according to RFC3810, section 8.3.2.
would receive that and internally switch to MLDv1 compatibility as well.
Right now, I believe since the initial implementation of MLDv2, Linux
hosts would just silently drop such MLDv2 queries instead of replying
with an MLDv1 listener report, which would prevent a MLDv2 router going
into fallback mode (until it receives other MLDv1 queries).
Since the mapping of MRC to MRD in exactly such cases can make use of
the exponential algorithm from 5.1.3, we cannot [strictly speaking] be
aware in MLDv1 of the encoding in MRC, it seems also not mentioned by
the RFC. Since encodings are the same up to 32767, assume in such a
situation this value as a hard upper limit we would clamp. We have asked
one of the RFC authors on that regard, and he mentioned that there seem
not to be any implementations that make use of that exponential algorithm
on startup messages. In any case, this patch fixes this MLD
interoperability issue.
Refactor out allocation and initialization and make
the refcount code more readable.
Similarly the code is already protected by rtnl lock.
It's not used anywhere, so just remove these.
Calling setsockopt with IPV6_JOIN_ANYCAST or IPV6_LEAVE_ANYCAST
triggers the assertion in addrconf_join_solict()/addrconf_leave_solict()
ipv6_sock_ac_join(), ipv6_sock_ac_drop(), ipv6_sock_ac_close() need to
take RTNL before calling ipv6_dev_ac_inc/dec. Same thing with
ipv6_sock_mc_join(), ipv6_sock_mc_drop(), ipv6_sock_mc_close() before
calling ipv6_dev_mc_inc/dec.
This patch moves ASSERT_RTNL() up a level in the call stack.
Signed-off-by: Sabrina Dubroca <sd@queasysnail.net>
Reported-by: Tommi Rantala <tt.rantala@gmail.com>
This patch adds a new sysctl_mld_qrv knob to configure the mldv1/v2 query
robustness variable. It specifies how many retransmit of unsolicited mld
retransmit should happen. Admins might want to tune this on lossy links.
Also reset mld state on interface down/up, so we pick up new sysctl
settings during interface up event.
IPv6 certification requests this knob to be available.
I didn't make this knob netns specific, as it is mostly a setting in a
physical environment and should be per host.
Cc: Flavio Leitner <fbl@redhat.com>
Acked-by: Flavio Leitner <fbl@redhat.com>
This patch makes no changes to the logic of the code but simply addresses
coding style issues as detected by checkpatch.
Both objdump and diff -w show no differences.
A number of items are addressed in this patch:
* Multiple spaces converted to tabs
* Spaces before tabs removed.
* Spaces in pointer typing cleansed (char *)foo etc.
* Remove space after sizeof
* Ensure spacing around comparators such as if statements.
Based on RFC3810 6.2, we also need to check the hop limit and router alert
option besides source address.
Acked-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
After commit c15b1ccadb323ea ("ipv6: move DAD and addrconf_verify
processing to workqueue") some counters are now updated in process context
and thus need to disable bh before doing so, otherwise deadlocks can
happen on 32-bit archs. Fabio Estevam noticed this while while mounting
a NFS volume on an ARM board.
As a compensation for missing this I looked after the other *_STATS_BH
and found three other calls which need updating:
1) icmp6_send: ip6_fragment -> icmpv6_send -> icmp6_send (error handling)
2) ip6_push_pending_frames: rawv6_sendmsg -> rawv6_push_pending_frames -> ...
(only in case of icmp protocol with raw sockets in error handling)
3) ping6_v6_sendmsg (error handling)
Fixes: c15b1ccadb323ea ("ipv6: move DAD and addrconf_verify processing to workqueue")
Reported-by: Fabio Estevam <festevam@gmail.com>
Tested-by: Fabio Estevam <fabio.estevam@freescale.com>
The RFC 3810 defines two type of messages for multicast
listeners. The "Current State Report" message, as the name
implies, refreshes the *current* state to the querier.
Since the querier sends Query messages periodically, there
is no need to retransmit the report.
On the other hand, any change should be reported immediately
using "State Change Report" messages. Since it's an event
triggered by a change and that it can be affected by packet
loss, the rfc states it should be retransmitted [RobVar] times
to make sure routers will receive timely.
Currently, we are sending "Current State Reports" after
DAD is completed. Before that, we send messages using
unspecified address (::) which should be silently discarded
by routers.
This patch changes to send "State Change Report" messages
after DAD is completed fixing the behavior to be RFC compliant
and also to pass TAHI IPv6 testsuite.
Signed-off-by: Flavio Leitner <fbl@redhat.com>
This patch removes the net_random and net_srandom macros and replaces
them with direct calls to the prandom ones. As new commits only seem to
use prandom_u32 there is no use to keep them around.
This change makes it easier to grep for users of prandom_u32.
Signed-off-by: Aruna-Hewapathirane <aruna.hewapathirane@gmail.com>
Suggested-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
It is possible for the timer handlers to run after the call to
ipv6_mc_down so use in6_dev_put instead of __in6_dev_put in the
handler function in order to do proper cleanup when the refcnt
reaches 0. Otherwise, the refcnt can reach zero without the
inet6_dev being destroyed and we end up leaking a reference to
the net_device and see messages like the following,
unregister_netdevice: waiting for eth0 to become free. Usage count = 1
Tested on linux-3.4.43.
Signed-off-by: Salam Noureddine <noureddine@aristanetworks.com>
We already have mld_{gq,ifc,dad}_start_timer() functions, so introduce
mld_{gq,ifc,dad}_stop_timer() functions to reduce code size and make it
more readable.
Make igmp6_event_query() a bit easier to read by refactoring code
parts into mld_process_v1() and mld_process_v2().
Similarly as we do in MLDv2 queries, set a forged MLDv1 query with
0 ms mld_maxdelay to minimum timer shot time of 1 jiffies. This is
eventually done in igmp6_group_queried() anyway, so we can simplify
a check there.
RFC3810, 10. Security Considerations says under subsection 10.1.
Query Message:
A forged Version 1 Query message will put MLDv2 listeners on that
link in MLDv1 Host Compatibility Mode. This scenario can be avoided
by providing MLDv2 hosts with a configuration option to ignore
Version 1 messages completely.
Hence, implement a MLDv2-only mode that will ignore MLDv1 traffic:
echo 2 > /proc/sys/net/ipv6/conf/ethX/force_mld_version or
echo 2 > /proc/sys/net/ipv6/conf/all/force_mld_version
Note that <all> device has a higher precedence as it was previously
also the case in the macro MLD_V1_SEEN() that would "short-circuit"
if condition on <all> case.
Get rid of MLDV2_MRC and use our new macros for mantisse and
exponent to calculate Maximum Response Delay out of the Maximum
Response Code.
Replace the macro with a function to make it more readable. GCC will
eventually decide whether to inline this or not (also, that's not
fast-path anyway).
i) RFC3810, 9.2. Query Interval [QI] says:
The Query Interval variable denotes the interval between General
Queries sent by the Querier. Default value: 125 seconds. [...]
ii) RFC3810, 9.3. Query Response Interval [QRI] says:
The Maximum Response Delay used to calculate the Maximum Response
Code inserted into the periodic General Queries. Default value:
10000 (10 seconds) [...] The number of seconds represented by the
[Query Response Interval] must be less than the [Query Interval].
iii) RFC3810, 9.12. Older Version Querier Present Timeout [OVQPT] says:
The Older Version Querier Present Timeout is the time-out for
transitioning a host back to MLDv2 Host Compatibility Mode. When an
MLDv1 query is received, MLDv2 hosts set their Older Version Querier
Present Timer to [Older Version Querier Present Timeout].
This value MUST be ([Robustness Variable] times (the [Query Interval]
in the last Query received)) plus ([Query Response Interval]).
Hence, on *default* the timeout results in:
[RV] = 2, [QI] = 125sec, [QRI] = 10sec
[OVQPT] = [RV] * [QI] + [QRI] = 260sec
Having that said, we currently calculate [OVQPT] (here given as 'switchback'
variable) as ...
switchback = (idev->mc_qrv + 1) * max_delay
RFC3810, 9.12. says "the [Query Interval] in the last Query received". In
section "9.14. Configuring timers", it is said:
This section is meant to provide advice to network administrators on
how to tune these settings to their network. Ambitious router
implementations might tune these settings dynamically based upon
changing characteristics of the network. [...]
iv) RFC38010, 9.14.2. Query Interval:
The overall level of periodic MLD traffic is inversely proportional
to the Query Interval. A longer Query Interval results in a lower
overall level of MLD traffic. The value of the Query Interval MUST
be equal to or greater than the Maximum Response Delay used to
calculate the Maximum Response Code inserted in General Query
messages.
I assume that was why switchback is calculated as is (3 * max_delay), although
this setting seems to be meant for routers only to configure their [QI]
interval for non-default intervals. So usage here like this is clearly wrong.
Concluding, the current behaviour in IPv6's multicast code is not conform
to the RFC as switch back is calculated wrongly. That is, it has a too small
value, so MLDv2 hosts switch back again to MLDv2 way too early, i.e. ~30secs
instead of ~260secs on default.
Hence, introduce necessary helper functions and fix this up properly as it
should be.
Introduced in 06da92283 ("[IPV6]: Add MLDv2 support."). Credits to Hannes
Frederic Sowa who also had a hand in this as well. Also thanks to Hangbin Liu
who did initial testing.
Cc: David Stevens <dlstevens@us.ibm.com>
Instead of hard-coding length values, use a define to make it clear
where those lengths come from.
