path: root/net/ipv6/mcast.c
2012-07-17ipv6: fix unappropriate errno returned for non-multicast addressLi Wei
We need to check the passed in multicast address and return appropriate errno(EINVAL) if it is not valid. And it's no need to walk through the ipv6_mc_list in this situation. Signed-off-by: Li Wei <lw@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-05-19ipv6: bool/const conversions phase2Eric Dumazet
Mostly bool conversions, some inline removals and const additions. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-05-16net: ipv6: Standardize prefixes for message loggingJoe Perches
Add #define pr_fmt(fmt) as appropriate. Add "IPv6: " to appropriate files. Convert printk(KERN_<LEVEL> to pr_<level> (but not KERN_DEBUG). Standardize on "%s: " not "%s(): " when emitting __func__. Use "%s: ", __func__ instead of embedding function name. Coalesce formats, align arguments. ADDRCONF output is now prefixed with "IPv6: " Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-10Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
2012-04-05net: replace continue with break to reduce unnecessary loop in xxx_xmarksourcesRongQing.Li
The conditional which decides to skip inactive filters does not change with the change of loop index, so it is unnecessary to check them many times. Signed-off-by: RongQing.Li <roy.qing.li@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-05ipv6: fix array index in ip6_mc_add_src()RongQing.Li
Convert array index from the loop bound to the loop index. And remove the void type conversion to ip6_mc_del1_src() return code, seem it is unnecessary, since ip6_mc_del1_src() does not use __must_check similar attribute, no compiler will report the warning when it is removed. v2: enrich the commit header Signed-off-by: RongQing.Li <roy.qing.li@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-03-16ipv6: Don't dev_hold(dev) in ip6_mc_find_dev_rcu.RongQing.Li
ip6_mc_find_dev_rcu() is called with rcu_read_lock(), so don't need to dev_hold(). With dev_hold(), not corresponding dev_put(), will lead to leak. [ bug introduced in 96b52e61be1 (ipv6: mcast: RCU conversions) ] Signed-off-by: RongQing.Li <roy.qing.li@gmail.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-28ipv6: Kill rt6i_dev and rt6i_expires defines.David S. Miller
It just obscures that the netdevice pointer and the expires value are implemented in the dst_entry sub-object of the ipv6 route. And it makes grepping for dst_entry member uses much harder too. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-06ipv6: Move xfrm_lookup() call down into icmp6_dst_alloc().David S. Miller
And return error pointers. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-11-30ipv6 : mcast : Delete useless parameter in ip6_mc_add1_src()Jun Zhao
Need not to used 'delta' flag when add single-source to interface filter source list. Signed-off-by: Jun Zhao <mypopydev@gmail.com> Signed-off-by: David S. Miller <davem@drr.davemloft.net>
2011-11-22net: remove ipv6_addr_copy()Alexey Dobriyan
C assignment can handle struct in6_addr copying. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-11-18ipv6: Remove all uses of LL_ALLOCATED_SPACEHerbert Xu
ipv6: Remove all uses of LL_ALLOCATED_SPACE The macro LL_ALLOCATED_SPACE was ill-conceived. It applies the alignment to the sum of needed_headroom and needed_tailroom. As the amount that is then reserved for head room is needed_headroom with alignment, this means that the tail room left may be too small. This patch replaces all uses of LL_ALLOCATED_SPACE in net/ipv6 with the macro LL_RESERVED_SPACE and direct reference to needed_tailroom. This also fixes the problem with needed_headroom changing between allocating the skb and reserving the head room. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-24mcast: Fix source address selection for multicast listener reportYan, Zheng
Should check use count of include mode filter instead of total number of include mode filters. Signed-off-by: Zheng Yan <zheng.z.yan@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1446 commits) macvlan: fix panic if lowerdev in a bond tg3: Add braces around 5906 workaround. tg3: Fix NETIF_F_LOOPBACK error macvlan: remove one synchronize_rcu() call networking: NET_CLS_ROUTE4 depends on INET irda: Fix error propagation in ircomm_lmp_connect_response() irda: Kill set but unused variable 'bytes' in irlan_check_command_param() irda: Kill set but unused variable 'clen' in ircomm_connect_indication() rxrpc: Fix set but unused variable 'usage' in rxrpc_get_transport() be2net: Kill set but unused variable 'req' in lancer_fw_download() irda: Kill set but unused vars 'saddr' and 'daddr' in irlan_provider_connect_indication() atl1c: atl1c_resume() is only used when CONFIG_PM_SLEEP is defined. rxrpc: Fix set but unused variable 'usage' in rxrpc_get_peer(). rxrpc: Kill set but unused variable 'local' in rxrpc_UDP_error_handler() rxrpc: Kill set but unused variable 'sp' in rxrpc_process_connection() rxrpc: Kill set but unused variable 'sp' in rxrpc_rotate_tx_window() pkt_sched: Kill set but unused variable 'protocol' in tc_classify() isdn: capi: Use pr_debug() instead of ifdefs. tg3: Update version to 3.119 tg3: Apply rx_discards fix to 5719/5720 ... Fix up trivial conflicts in arch/x86/Kconfig and net/mac80211/agg-tx.c as per Davem.
2011-05-07net,rcu: convert call_rcu(ipv6_mc_socklist_reclaim) to kfree_rcu()Lai Jiangshan
The rcu callback ipv6_mc_socklist_reclaim() just calls a kfree(), so we use kfree_rcu() instead of the call_rcu(ipv6_mc_socklist_reclaim). Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org>
2011-04-22inet: constify ip headers and in6_addrEric Dumazet
Add const qualifiers to structs iphdr, ipv6hdr and in6_addr pointers where possible, to make code intention more obvious. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-12ipv6: Convert to use flowi6 where applicable.David S. Miller
2011-03-07mcast: net_device dev not usedHagen Paul Pfeifer
ip6_mc_source(), ip6_mc_msfilter() as well as ip6_mc_msfget() declare and assign dev but do not use the variable afterwards. Signed-off-by: Hagen Paul Pfeifer <hagen@jauu.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-02xfrm: Return dst directly from xfrm_lookup()David S. Miller
Instead of on the stack. Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-24ipv6: mcast: RCU conversionEric Dumazet
ipv6_sk_mc_lock rwlock becomes a spinlock. readers (inet6_mc_check()) now takes rcu_read_lock() instead of read lock. Writers dont need to disable BH anymore. struct ipv6_mc_socklist objects are reclaimed after one RCU grace period. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-15net/ipv6/mcast.c: Remove unnecessary semicolonsJoe Perches
2010-06-10net-next: remove useless union keywordChangli Gao
remove useless union keyword in rtable, rt6_info and dn_route. Since there is only one member in a union, the union keyword isn't useful. Signed-off-by: Changli Gao <xiaosuo@gmail.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-09ipv6: mcast: RCU conversionsEric Dumazet
- ipv6_sock_mc_join() : doesnt touch dev refcount - ipv6_sock_mc_drop() : doesnt touch dev/idev refcounts - ip6_mc_find_dev() becomes ip6_mc_find_dev_rcu() (called from rcu), and doesnt touch dev/idev refcounts - ipv6_sock_mc_close() : doesnt touch dev/idev refcounts - ip6_mc_source() uses ip6_mc_find_dev_rcu() - ip6_mc_msfilter() uses ip6_mc_find_dev_rcu() - ip6_mc_msfget() uses ip6_mc_find_dev_rcu() - ipv6_dev_mc_dec(), ipv6_chk_mcast_addr(), igmp6_event_query(), igmp6_event_report(), mld_sendpack(), igmp6_send() dont touch idev refcount Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-06Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/sfc/net_driver.h drivers/net/sfc/siena.c
2010-06-05ipv6: avoid high order allocationsEric Dumazet
With mtu=9000, mld_newpack() use order-2 GFP_ATOMIC allocations, that are very unreliable, on machines where PAGE_SIZE=4K Limit allocated skbs to be at most one page. (order-0 allocations) Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-01net/ipv6/mcast.c: Remove unnecessary kmalloc castsJoe Perches
2010-05-10Merge branch 'master' of /repos/git/net-next-2.6Patrick McHardy
Conflicts: net/bridge/br_device.c net/bridge/br_forward.c Signed-off-by: Patrick McHardy <kaber@trash.net>
2010-04-23ipv6 mcast: Introduce include/net/mld.h for MLD definitions.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2010-04-20Merge branch 'master' of /repos/git/net-next-2.6Patrick McHardy
Conflicts: Documentation/feature-removal-schedule.txt net/ipv6/netfilter/ip6t_REJECT.c net/netfilter/xt_limit.c Signed-off-by: Patrick McHardy <kaber@trash.net>
2010-04-11Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/stmmac/stmmac_main.c drivers/net/wireless/wl12xx/wl1271_cmd.c drivers/net/wireless/wl12xx/wl1271_main.c drivers/net/wireless/wl12xx/wl1271_spi.c net/core/ethtool.c net/mac80211/scan.c
2010-04-03net: convert multicast list to list_headJiri Pirko
Converts the list and the core manipulating with it to be the same as uc_list. +uses two functions for adding/removing mc address (normal and "global" variant) instead of a function parameter. +removes dev_mcast.c completely. +exposes netdev_hw_addr_list_* macros along with __hw_addr_* functions for manipulation with lists on a sandbox (used in bonding and 80211 drivers) Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-25netfilter: ipv6: use NFPROTO values for NF_HOOK invocationJan Engelhardt
The semantic patch that was used: // <smpl> @@ @@ (NF_HOOK |NF_HOOK_THRESH |nf_hook )( -PF_INET6, +NFPROTO_IPV6, ...) // </smpl> Signed-off-by: Jan Engelhardt <jengelh@medozas.de>
2010-02-17IPv6: convert mc_lock to spinlockStephen Hemminger
Only used for writing, so convert to spinlock Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-17net: spread __net_init, __net_exitAlexey Dobriyan
__net_init/__net_exit are apparently not going away, so use them to full extent. In some cases __net_init was removed, because it was called from __net_exit code. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-13ipv6: use RCU to walk list of network devicesEric Dumazet
No longer need read_lock(&dev_base_lock), use RCU instead. We also can avoid taking references on inet6_dev structs. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-15bonding: remap muticast addresses without using dev_close() and dev_open()Moni Shoua
This patch fixes commit e36b9d16c6a6d0f59803b3ef04ff3c22c3844c10. The approach there is to call dev_close()/dev_open() whenever the device type is changed in order to remap the device IP multicast addresses to HW multicast addresses. This approach suffers from 2 drawbacks: *. It assumes tha the device is UP when calling dev_close(), or otherwise dev_close() has no affect. It is worth to mention that initscripts (Redhat) and sysconfig (Suse) doesn't act the same in this matter. *. dev_close() has other side affects, like deleting entries from the routing table, which might be unnecessary. The fix here is to directly remap the IP multicast addresses to HW multicast addresses for a bonding device that changes its type, and nothing else. Reported-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com> Signed-off-by: Moni Shoua <monis@voltaire.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-21mcastv6: Local variable shadows function argumentGerrit Renker
The local variable 'idev' shadows the function argument 'idev' to ip6_mc_add_src(). Fixed by removing the local declaration, as pmc->idev should be identical with 'idev' passed as argument. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Acked-by: David L Stevens <dlstevens@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-03net: skb->dst accessorsEric Dumazet
Define three accessors to get/set dst attached to a skb struct dst_entry *skb_dst(const struct sk_buff *skb) void skb_dst_set(struct sk_buff *skb, struct dst_entry *dst) void skb_dst_drop(struct sk_buff *skb) This one should replace occurrences of : dst_release(skb->dst) skb->dst = NULL; Delete skb->dst field Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-27snmp: add missing counters for RFC 4293Neil Horman
The IP MIB (RFC 4293) defines stats for InOctets, OutOctets, InMcastOctets and OutMcastOctets: http://tools.ietf.org/html/rfc4293 But it seems we don't track those in any way that easy to separate from other protocols. This patch adds those missing counters to the stats file. Tested successfully by me With help from Eric Dumazet. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-14ipv6/mcast: join error paths using gotoIlpo Järvinen
Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-25netns xfrm: lookup in netnsAlexey Dobriyan
Pass netns to xfrm_lookup()/__xfrm_lookup(). For that pass netns to flow_cache_lookup() and resolver callback. Take it from socket or netdevice. Stub DECnet to init_net. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-19include/net net/ - csum_partial - remove unnecessary castsJoe Perches
The first argument to csum_partial is const void * casts to char/u8 * are not necessary Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-29net: replace %#p6 format specifier with %pi6Harvey Harrison
gcc warns when using the # modifier with the %p format specifier, so we can't use this to omit the colons when needed, introduces %pi6 instead. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-28net: replace all current users of NIP6_SEQFMT with %#p6Harvey Harrison
The define in kernel.h can be done away with at a later time. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-08ipv6: added net argument to ICMP6MSGOUT_INC_STATS_BHDenis V. Lunev
Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-08ipv6: added net argument to ICMP6MSGOUT_INC_STATSDenis V. Lunev
2008-10-08ipv6: added net argument to ICMP6_INC_STATS_BHDenis V. Lunev
2008-10-08ipv6: added net argument to ICMP6_INC_STATSDenis V. Lunev
2008-10-08ipv6: added net argument to IP6_INC_STATS_BHDenis V. Lunev
