path: root/net/ipv6/netfilter/nf_conntrack_reasm.c
2013-11-11netfilter: push reasm skb through instead of original frag skbsJiri Pirko
Pushing original fragments through causes several problems. For example for matching, frags may not be matched correctly. Take following example: <example> On HOSTA do: ip6tables -I INPUT -p icmpv6 -j DROP ip6tables -I INPUT -p icmpv6 -m icmp6 --icmpv6-type 128 -j ACCEPT and on HOSTB you do: ping6 HOSTA -s2000 (MTU is 1500) Incoming echo requests will be filtered out on HOSTA. This issue does not occur with smaller packets than MTU (where fragmentation does not happen) </example> As was discussed previously, the only correct solution seems to be to use reassembled skb instead of separete frags. Doing this has positive side effects in reducing sk_buff by one pointer (nfct_reasm) and also the reams dances in ipvs and conntrack can be removed. Future plan is to remove net/ipv6/netfilter/nf_conntrack_reasm.c entirely and use code in net/ipv6/reassembly.c instead. Signed-off-by: Jiri Pirko <jiri@resnulli.us> Acked-by: Julian Anastasov <ja@ssi.bg> Signed-off-by: Marcelo Ricardo Leitner <mleitner@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-10-23ipv6: split inet6_hash_frag for netfilter and initialize secrets with ↵Hannes Frederic Sowa
net_get_random_once Defer the fragmentation hash secret initialization for IPv6 like the previous patch did for IPv4. Because the netfilter logic reuses the hash secret we have to split it first. Thus introduce a new nf_hash_frag function which takes care to seed the hash secret. Cc: David S. Miller <davem@davemloft.net> Cc: Eric Dumazet <edumazet@google.com> Cc: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-06netfilter: implement RFC3168 5.3 (ecn protection) for ipv6 fragmentation ↵Hannes Frederic Sowa
handling This change brings netfilter reassembly logic on par with reassembly.c. The corresponding change in net-next is (eec2e61 ipv6: implement RFC3168 5.3 (ecn protection) for ipv6 fragmentation handling) Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: Jesper Dangaard Brouer <jbrouer@redhat.com> Cc: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2013-03-19inet: limit length of fragment queue hash table bucket listsHannes Frederic Sowa
This patch introduces a constant limit of the fragment queue hash table bucket list lengths. Currently the limit 128 is choosen somewhat arbitrary and just ensures that we can fill up the fragment cache with empty packets up to the default ip_frag_high_thresh limits. It should just protect from list iteration eating considerable amounts of cpu. If we reach the maximum length in one hash bucket a warning is printed. This is implemented on the caller side of inet_frag_find to distinguish between the different users of inet_fragment.c. I dropped the out of memory warning in the ipv4 fragment lookup path, because we already get a warning by the slab allocator. Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: Jesper Dangaard Brouer <jbrouer@redhat.com> Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-18Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net into netDavid S. Miller
Pull in 'net' to take in the bug fixes that didn't make it into 3.8-final. Also, deal with the semantic conflict of the change made to net/ipv6/xfrm6_policy.c A missing rt6->n neighbour release was added to 'net', but in 'net-next' we no longer cache the neighbour entries in the ipv6 routes so that change is not appropriate there. Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-15net: Add skb_unclone() helper function.Pravin B Shelar
This function will be used in next GRE_GSO patch. This patch does not change any functionality. Signed-off-by: Pravin B Shelar <pshelar@nicira.com> Acked-by: Eric Dumazet <edumazet@google.com>
2013-02-13netfilter: nf_ct_reasm: fix per-netns sysctl initializationMichal Kubeček
Adjusting of data pointers in net/netfilter/nf_conntrack_frag6_* sysctl table for other namespaces points to wrong netns_frags structure and has reversed order of entries. Problem introduced by commit c038a767cd69 in 3.7-rc1 Signed-off-by: Michal Kubecek <mkubecek@suse.cz> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2013-01-29net: frag, move LRU list maintenance outside of rwlockJesper Dangaard Brouer
Updating the fragmentation queues LRU (Least-Recently-Used) list, required taking the hash writer lock. However, the LRU list isn't tied to the hash at all, so we can use a separate lock for it. Original-idea-by: Florian Westphal <fw@strlen.de> Signed-off-by: Jesper Dangaard Brouer <brouer@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-01-29net: frag helper functions for mem limit trackingJesper Dangaard Brouer
This change is primarily a preparation to ease the extension of memory limit tracking. The change does reduce the number atomic operation, during freeing of a frag queue. This does introduce a some performance improvement, as these atomic operations are at the core of the performance problems seen on NUMA systems. Signed-off-by: Jesper Dangaard Brouer <brouer@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-12-16netfilter: nf_ct_reasm: fix conntrack reassembly expire codeHaibo Xi
Commit b836c99fd6c9 (ipv6: unify conntrack reassembly expire code with standard one) use the standard IPv6 reassembly code(ip6_expire_frag_queue) to handle conntrack reassembly expire. In ip6_expire_frag_queue, it invoke dev_get_by_index_rcu to get which device received this expired packet.so we must save ifindex when NF_conntrack get this packet. With this patch applied, I can see ICMP Time Exceeded sent from the receiver when the sender sent out 1/2 fragmented IPv6 packet. Signed-off-by: Haibo Xi <haibbo@gmail.com> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2012-10-28netfilter: nf_defrag_ipv6: solve section mismatch in nf_conntrack_reasmHein Tibosch
WARNING: net/ipv6/netfilter/nf_defrag_ipv6.o(.text+0xe0): Section mismatch in reference from the function nf_ct_net_init() to the function .init.text:nf_ct_frag6_sysctl_register() The function nf_ct_net_init() references the function __init nf_ct_frag6_sysctl_register(). In case nf_conntrack_ipv6 is compiled as a module, nf_ct_net_init could be called after the init code and data are unloaded. Therefore remove the "__net_init" annotation from nf_ct_frag6_sysctl_register(). Signed-off-by: Hein Tibosch <hein_tibosch@yahoo.es> Acked-by: Cong Wang <amwang@redhat.com> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2012-09-27nf_defrag_ipv6: fix oops on module unloadingKonstantin Khlebnikov
fix copy-paste error introduced in linux-next commit "ipv6: add a new namespace for nf_conntrack_reasm" Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Cc: Amerigo Wang <amwang@redhat.com> Cc: David S. Miller <davem@davemloft.net> Acked-by: Cong Wang <amwang@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-19ipv6: unify fragment thresh handling codeAmerigo Wang
Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: Michal Kubeček <mkubecek@suse.cz> Cc: David Miller <davem@davemloft.net> Signed-off-by: Cong Wang <amwang@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-19ipv6: unify conntrack reassembly expire code with standard oneAmerigo Wang
Two years ago, Shan Wei tried to fix this: http://patchwork.ozlabs.org/patch/43905/ The problem is that RFC2460 requires an ICMP Time Exceeded -- Fragment Reassembly Time Exceeded message should be sent to the source of that fragment, if the defragmentation times out. " If insufficient fragments are received to complete reassembly of a packet within 60 seconds of the reception of the first-arriving fragment of that packet, reassembly of that packet must be abandoned and all the fragments that have been received for that packet must be discarded. If the first fragment (i.e., the one with a Fragment Offset of zero) has been received, an ICMP Time Exceeded -- Fragment Reassembly Time Exceeded message should be sent to the source of that fragment. " As Herbert suggested, we could actually use the standard IPv6 reassembly code which follows RFC2460. With this patch applied, I can see ICMP Time Exceeded sent from the receiver when the sender sent out 3/4 fragmented IPv6 UDP packet. Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: Michal Kubeček <mkubecek@suse.cz> Cc: David Miller <davem@davemloft.net> Cc: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org> Cc: Patrick McHardy <kaber@trash.net> Cc: Pablo Neira Ayuso <pablo@netfilter.org> Cc: netfilter-devel@vger.kernel.org Signed-off-by: Cong Wang <amwang@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-19ipv6: add a new namespace for nf_conntrack_reasmAmerigo Wang
As pointed by Michal, it is necessary to add a new namespace for nf_conntrack_reasm code, this prepares for the second patch. Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: Michal Kubeček <mkubecek@suse.cz> Cc: David Miller <davem@davemloft.net> Cc: Patrick McHardy <kaber@trash.net> Cc: Pablo Neira Ayuso <pablo@netfilter.org> Cc: netfilter-devel@vger.kernel.org Signed-off-by: Cong Wang <amwang@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-30netfilter: nf_conntrack_ipv6: improve fragmentation handlingPatrick McHardy
The IPv6 conntrack fragmentation currently has a couple of shortcomings. Fragmentes are collected in PREROUTING/OUTPUT, are defragmented, the defragmented packet is then passed to conntrack, the resulting conntrack information is attached to each original fragment and the fragments then continue their way through the stack. Helper invocation occurs in the POSTROUTING hook, at which point only the original fragments are available. The result of this is that fragmented packets are never passed to helpers. This patch improves the situation in the following way: - If a reassembled packet belongs to a connection that has a helper assigned, the reassembled packet is passed through the stack instead of the original fragments. - During defragmentation, the largest received fragment size is stored. On output, the packet is refragmented if required. If the largest received fragment size exceeds the outgoing MTU, a "packet too big" message is generated, thus behaving as if the original fragments were passed through the stack from an outside point of view. - The ipv6_helper() hook function can't receive fragments anymore for connections using a helper, so it is switched to use ipv6_skip_exthdr() instead of the netfilter specific nf_ct_ipv6_skip_exthdr() and the reassembled packets are passed to connection tracking helpers. The result of this is that we can properly track fragmented packets, but still generate ICMPv6 Packet too big messages if we would have before. This patch is also required as a precondition for IPv6 NAT, where NAT helpers might enlarge packets up to a point that they require fragmentation. In that case we can't generate Packet too big messages since the proper MTU can't be calculated in all cases (f.i. when changing textual representation of a variable amount of addresses), so the packet is transparently fragmented iff the original packet or fragments would have fit the outgoing MTU. IPVS parts by Jesper Dangaard Brouer <brouer@redhat.com>. Signed-off-by: Patrick McHardy <kaber@trash.net>
2012-05-15net: Convert net_ratelimit uses to net_<level>_ratelimitedJoe Perches
Standardize the net core ratelimited logging functions. Coalesce formats, align arguments. Change a printk then vprintk sequence to use printf extension %pV. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-20net: Convert all sysctl registrations to register_net_sysctlEric W. Biederman
This results in code with less boiler plate that is a bit easier to read. Additionally stops us from using compatibility code in the sysctl core, hastening the day when the compatibility code can be removed. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Pavel Emelyanov <xemul@parallels.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-20net: Move all of the network sysctls without a namespace into init_net.Eric W. Biederman
This makes it clearer which sysctls are relative to your current network namespace. This makes it a little less error prone by not exposing sysctls for the initial network namespace in other namespaces. This is the same way we handle all of our other network interfaces to userspace and I can't honestly remember why we didn't do this for sysctls right from the start. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Pavel Emelyanov <xemul@parallels.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-11-01netfilter: Remove unnecessary OOM logging messagesJoe Perches
Site specific OOM messages are duplications of a generic MM out of memory message and aren't really useful, so just delete them. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2011-10-19net: add skb frag size accessorsEric Dumazet
To ease skb->truesize sanitization, its better to be able to localize all references to skb frags size. Define accessors : skb_frag_size() to fetch frag size, and skb_frag_size_{set|add|sub}() to manipulate it. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-20netfilter: add a missing include in nf_conntrack_reasm.cEric Dumazet
After commit ae90bdeaeac6b (netfilter: fix compilation when conntrack is disabled but tproxy is enabled) we have following warnings : net/ipv6/netfilter/nf_conntrack_reasm.c:520:16: warning: symbol 'nf_ct_frag6_gather' was not declared. Should it be static? net/ipv6/netfilter/nf_conntrack_reasm.c:591:6: warning: symbol 'nf_ct_frag6_output' was not declared. Should it be static? net/ipv6/netfilter/nf_conntrack_reasm.c:612:5: warning: symbol 'nf_ct_frag6_init' was not declared. Should it be static? net/ipv6/netfilter/nf_conntrack_reasm.c:640:6: warning: symbol 'nf_ct_frag6_cleanup' was not declared. Should it be static? Fix this including net/netfilter/ipv6/nf_defrag_ipv6.h Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> CC: KOVACS Krisztian <hidden@balabit.hu> Signed-off-by: Patrick McHardy <kaber@trash.net>
2011-01-13Merge branch 'master' of ↵Simon Horman
git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6 into HEAD
2010-11-15netfilter: nf_ct_frag6_sysctl_table is staticEric Dumazet
Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Patrick McHardy <kaber@trash.net>
2010-11-12netfilter: ipv6: fix overlap check for fragmentsShan Wei
The type of FRAG6_CB(prev)->offset is int, skb->len is *unsigned* int, and offset is int. Without this patch, type conversion occurred to this expression, when (FRAG6_CB(prev)->offset + prev->len) is less than offset. Signed-off-by: Shan Wei <shanwei@cn.fujitsu.com> Signed-off-by: Patrick McHardy <kaber@trash.net>
2010-10-26netfilter: Add missing CONFIG_SYSCTL checks in ipv6's nf_conntrack_reasm.cDavid S. Miller
Reported-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-21tproxy: split off ipv6 defragmentation to a separate moduleBalazs Scheidler
Like with IPv4, TProxy needs IPv6 defragmentation but does not require connection tracking. Since defragmentation was coupled with conntrack, I split off the two, creating an nf_defrag_ipv6 module, similar to the already existing nf_defrag_ipv4. Signed-off-by: Balazs Scheidler <bazsi@balabit.hu> Signed-off-by: KOVACS Krisztian <hidden@balabit.hu> Signed-off-by: Patrick McHardy <kaber@trash.net>
2010-09-09Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: net/mac80211/main.c
2010-09-07netfilter: discard overlapping IPv6 fragmentNicolas Dichtel
RFC5722 prohibits reassembling IPv6 fragments when some data overlaps. Bug spotted by Zhang Zuotao <zuotao.zhang@6wind.com>. Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-23net: Rename skb_has_frags to skb_has_frag_listDavid S. Miller
SKBs can be "fragmented" in two ways, via a page array (called skb_shinfo(skb)->frags[]) and via a list of SKBs (called skb_shinfo(skb)->frag_list). Since skb_has_frags() tests the latter, it's name is confusing since it sounds more like it's testing the former. Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-04Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (48 commits) Documentation: update broken web addresses. fix comment typo "choosed" -> "chosen" hostap:hostap_hw.c Fix typo in comment Fix spelling contorller -> controller in comments Kconfig.debug: FAIL_IO_TIMEOUT: typo Faul -> Fault fs/Kconfig: Fix typo Userpace -> Userspace Removing dead MACH_U300_BS26 drivers/infiniband: Remove unnecessary casts of private_data fs/ocfs2: Remove unnecessary casts of private_data libfc: use ARRAY_SIZE scsi: bfa: use ARRAY_SIZE drm: i915: use ARRAY_SIZE drm: drm_edid: use ARRAY_SIZE synclink: use ARRAY_SIZE block: cciss: use ARRAY_SIZE comment typo fixes: charater => character fix comment typos concerning "challenge" arm: plat-spear: fix typo in kerneldoc reiserfs: typo comment fix update email address ...
2010-07-11fix comment/printk typos concerning "already"Uwe Kleine-König
Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-07-05netfilter: nf_conntrack_reasm: add fast path for in-order fragmentsChangli Gao
As the fragments are sent in order in most of OSes, such as Windows, Darwin and FreeBSD, it is likely the new fragments are at the end of the inet_frag_queue. In the fast path, we check if the skb at the end of the inet_frag_queue is the prev we expect. Signed-off-by: Changli Gao <xiaosuo@gmail.com> Signed-off-by: Patrick McHardy <kaber@trash.net>
2010-06-14netfilter: defrag: kill unused work parameter of frag_kfree_skb()Shan Wei
The parameter (work) is unused, remove it. Reported from Eric Dumazet. Signed-off-by: Shan Wei <shanwei@cn.fujitsu.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Patrick McHardy <kaber@trash.net>
2010-06-14netfilter: defrag: remove one redundant atomic opsShan Wei
Instead of doing one atomic operation per frag, we can factorize them. Reported from Eric Dumazet. Signed-off-by: Shan Wei <shanwei@cn.fujitsu.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Patrick McHardy <kaber@trash.net>
2010-04-20Merge branch 'master' of /repos/git/net-next-2.6Patrick McHardy
Conflicts: Documentation/feature-removal-schedule.txt net/ipv6/netfilter/ip6t_REJECT.c net/netfilter/xt_limit.c Signed-off-by: Patrick McHardy <kaber@trash.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-25netfilter: ipv6: use NFPROTO values for NF_HOOK invocationJan Engelhardt
The semantic patch that was used: // <smpl> @@ @@ (NF_HOOK |NF_HOOK_THRESH |nf_hook )( -PF_INET6, +NFPROTO_IPV6, ...) // </smpl> Signed-off-by: Jan Engelhardt <jengelh@medozas.de>
2010-02-19netfilter: nf_conntrack_reasm: properly handle packets fragmented into a ↵Patrick McHardy
single fragment When an ICMPV6_PKT_TOOBIG message is received with a MTU below 1280, all further packets include a fragment header. Unlike regular defragmentation, conntrack also needs to "reassemble" those fragments in order to obtain a packet without the fragment header for connection tracking. Currently nf_conntrack_reasm checks whether a fragment has either IP6_MF set or an offset != 0, which makes it ignore those fragments. Remove the invalid check and make reassembly handle fragment queues containing only a single fragment. Reported-and-tested-by: Ulrich Weber <uweber@astaro.com> Signed-off-by: Patrick McHardy <kaber@trash.net>
2010-02-10Merge branch 'master' of /repos/git/net-next-2.6Patrick McHardy
2010-01-26ipv6: conntrack: Add member of user to nf_ct_frag6_queue structureShan Wei
The commit 0b5ccb2(title:ipv6: reassembly: use seperate reassembly queues for conntrack and local delivery) has broken the saddr&&daddr member of nf_ct_frag6_queue when creating new queue. And then hash value generated by nf_hashfn() was not equal with that generated by fq_find(). So, a new received fragment can't be inserted to right queue. The patch fixes the bug with adding member of user to nf_ct_frag6_queue structure. Signed-off-by: Shan Wei <shanwei@cn.fujitsu.com> Acked-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-20IPv6: reassembly: replace magic number with macro definitionsShan Wei
Use macro to define high/low thresh value, refer to IPV6_FRAG_TIMEOUT. Signed-off-by: Shan Wei <shanwei@cn.fujitsu.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Patrick McHardy <kaber@trash.net>
2010-01-20netfilter: nf_conntrack_ipv6: delete the redundant macro definitionsShan Wei
The following three macro definitions are never used, so delete them. Signed-off-by: Shan Wei <shanwei@cn.fujitsu.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Patrick McHardy <kaber@trash.net>
2009-12-15ipv6: reassembly: use seperate reassembly queues for conntrack and local ↵Patrick McHardy
delivery Currently the same reassembly queue might be used for packets reassembled by conntrack in different positions in the stack (PREROUTING/LOCAL_OUT), as well as local delivery. This can cause "packet jumps" when the fragment completing a reassembled packet is queued from a different position in the stack than the previous ones. Add a "user" identifier to the reassembly queue key to seperate the queues of each caller, similar to what we do for IPv4. Signed-off-by: Patrick McHardy <kaber@trash.net>
2009-11-12sysctl net: Remove unused binary sysctl codeEric W. Biederman
Now that sys_sysctl is a compatiblity wrapper around /proc/sys all sysctl strategy routines, and all ctl_name and strategy entries in the sysctl tables are unused, and can be revmoed. In addition neigh_sysctl_register has been modified to no longer take a strategy argument and it's callers have been modified not to pass one. Cc: "David Miller" <davem@davemloft.net> Cc: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org> Cc: netdev@vger.kernel.org Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2009-06-09netfilter: Use frag list abstraction interfaces.David S. Miller
2009-03-16netfilter: conntrack: check for NEXTHDR_NONE before header sanity checkingChristoph Paasch
NEXTHDR_NONE doesn't has an IPv6 option header, so the first check for the length will always fail and results in a confusing message "too short" if debugging enabled. With this patch, we check for NEXTHDR_NONE before length sanity checkings are done. Signed-off-by: Christoph Paasch <christoph.paasch@gmail.com> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: Patrick McHardy <kaber@trash.net>
2008-11-03net: '&' reduxAlexey Dobriyan
I want to compile out proc_* and sysctl_* handlers totally and stub them to NULL depending on config options, however usage of & will prevent this, since taking adress of NULL pointer will break compilation. So, drop & in front of every ->proc_handler and every ->strategy handler, it was never needed in fact. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-01ipv6: almost identical frag hashing funcs combinedIlpo Järvinen
$ diff-funcs ip6qhashfn reassembly.c netfilter/nf_conntrack_reasm.c --- reassembly.c:ip6qhashfn() +++ netfilter/nf_conntrack_reasm.c:ip6qhashfn() @@ -1,5 +1,5 @@ -static unsigned int ip6qhashfn(__be32 id, struct in6_addr *saddr, - struct in6_addr *daddr) +static unsigned int ip6qhashfn(__be32 id, const struct in6_addr *saddr, + const struct in6_addr *daddr) { u32 a, b, c; @@ -9,7 +9,7 @@ a += JHASH_GOLDEN_RATIO; b += JHASH_GOLDEN_RATIO; - c += ip6_frags.rnd; + c += nf_frags.rnd; __jhash_mix(a, b, c); a += (__force u32)saddr->s6_addr32[3]; And codiff xx.o.old xx.o.new: net/ipv6/netfilter/nf_conntrack_reasm.c: ip6qhashfn | -512 nf_hashfn | +6 nf_ct_frag6_gather | +36 3 functions changed, 42 bytes added, 512 bytes removed, diff: -470 net/ipv6/reassembly.c: ip6qhashfn | -512 ip6_hashfn | +7 ipv6_frag_rcv | +89 3 functions changed, 96 bytes added, 512 bytes removed, diff: -416 net/ipv6/reassembly.c: inet6_hash_frag | +510 1 function changed, 510 bytes added, diff: +510 Total: -376 Compile tested. Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-25net: convert BUG_TRAP to generic WARN_ONIlpo Järvinen
Removes legacy reinvent-the-wheel type thing. The generic machinery integrates much better to automated debugging aids such as kerneloops.org (and others), and is unambiguous due to better naming. Non-intuively BUG_TRAP() is actually equal to WARN_ON() rather than BUG_ON() though some might actually be promoted to BUG_ON() but I left that to future. I could make at least one BUILD_BUG_ON conversion. Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
